- 04-Network Connectivity Command Reference
- 01-MAC address table commands
- 02-Ethernet link aggregation commands
- 03-Port isolation commands
- 04-VLAN commands
- 05-Loop detection commands
- 06-Spanning tree commands
- 07-LLDP commands
- 08-Layer 2 forwarding commands
- 09-PPP commands
- 10-ARP commands
- 11-IP addressing commands
- 12-DHCP commands
- 13-DHCPv6 commands
- 14-DNS commands
- 15-NAT commands
- 16-EoGRE commands
- 17-IP performance optimization commands
- 18-IPv6 basics commands
- 19-Basic IP routing commands
- 20-Static routing commands
- 21-IPv6 static routing commands
- 22-IGMP snooping commands
- 23-MLD snooping commands
| 21-IPv6 static routing commands | 113.45 KB |
display ipv6 route-static routing-table
ipv6 route-static default-preference
ipv6 route-static fast-reroute auto
delete ipv6 static-routes all
Use delete ipv6 static-routes all to delete all IPv6 static routes.
CAUTION: This command might interrupt network communication and cause packet forwarding failure. Before executing the command, make sure you fully understand the potential impact on the network. |
When you use this command, the system will prompt you to confirm the operation before deleting all the IPv6 static routes.
# Delete all IPv6 static routes.
[Sysname] delete ipv6 static-routes all
This will erase all IPv6 static routes and their configurations, you must reconfigure all static routes.
Are you sure?[Y/N]:y
ipv6 route-static
display ipv6 route-static nib
Use display ipv6 route-static nib to display IPv6 static route next hop information.
display ipv6 route-static nib [ nib-id ] [ verbose ]
nib-id: Specifies a NIB by its ID, a hexadecimal string in the range of 1 to ffffffff.
verbose: Displays detailed IPv6 static route next hop information. If you do not specify this keyword, the command displays brief IPv6 static route next hop information.
# Display brief IPv6 static route next hop information.
<Sysname> display ipv6 route-static nib
Total number of nexthop(s): 35
NibID: 0x21000000 Sequence: 0
Type: 0x41 Flushed: Yes
UserKey0: 0x0 VrfNthp: 0
UserKey1: 0x0 Nexthop: 2::3
IFIndex: 0x0 LocalAddr: ::
NewUK0: 0x0 NewUK1: 0x0
NewUK2: 0x0 NewUK3: 0x0
NewUK4: 0x0 NewUK5: 0x0
NewUK6: 0x0 NewUK7: 0x0
TopoNthp: Invalid ExtType: 0x0
Color: 0 COFlag: 0x0
LinkID: 0x0
SIDIndex: 0x0 SRPName:
OriNexthop: ::
NibID: 0x21000001 Sequence: 1
UserKey1: 0x0 Nexthop: 3::4
LinkID: 0x0
OriNexthop: ::
NibID |
ID of the NIB. |
Sequence |
Sequence number of the NIB. |
Type |
Type of the NIB. |
Flushed |
Indicates whether the route with the NIB has been flushed to the FIB. |
UserKey0 |
Reserved data 1. |
UserKey1 |
Reserved data 2. |
VrfNthp |
This field is not supported in the current software version. Index of the VPN instance to which the next hop belongs. This field displays 0 if the next hop is on the public network. |
Nexthop |
Next hop address. |
IFIndex |
Interface index |
LocalAddr |
Local interface address. |
NewUK0 |
New reserved data 1. |
NewUK1 |
New reserved data 2. |
NewUK2 |
New reserved data 3. |
NewUK3 |
New reserved data 4. |
NewUK4 |
New reserved data 5. |
NewUK5 |
New reserved data 6. |
NewUK6 |
New reserved data 7. |
NewUK7 |
New reserved data 8. |
TopoNthp |
This field is not supported in the current software version. Index of the topology that contains the next hop. This field displays 0 if the next hop is on the public network. This field displays Invalid if the next hop is on an IPv6 network, because the router does not support non-base topologies. |
ExtType |
NIB extension type. |
Color |
This field is not supported in the current software version. Color extended community attribute. |
COFlag |
This field is not supported in the current software version. Flag of the color extended community attribute. |
LinkID |
This field is not supported in the current software version. Link ID of the SDWAN TTE connection. |
SIDIndex |
This field is not supported in the current software version. SID index value. |
SRPName |
This field is not supported in the current software version. SR-MPLS TE policy name. |
OriNexthop |
Original next hop address of the route. |
# Display detailed IPv6 static route next hop information.
<Sysname> display ipv6 route-static nib verbose
LinkID: 0x0
OriNexthop: ::
RefCnt: 1 FlushRefCnt: 0
Flag: 0x12 Version: 1
1 nexthop(s):
PrefixIndex: 0 OrigNexthop: 2::3
RelyDepth: 2 RealNexthop: ::
Interface: NULL0 LocalAddr: ::
TunnelCnt: 0 Vrf: default-vrf
TunnelID: N/A Topology:
Weight: 0 Flags: 0x0
SRPolicyNID: 4294967295 SRInterface:
ColorWeight: 0 Locator: N/A
OrigLinkID: 0x0 RealLinkID: 0x0
LinkID: 0x0
OriNexthop: ::
1 nexthop(s):
PrefixIndex: 0 OrigNexthop: 3::4
RelyDepth: 1 RealNexthop: ::
Interface: Vlan11 LocalAddr: ::
x nexthop(s) |
Number of next hops. |
PrefixIndex |
Prefix index of the next hop for an ECMP route. |
Vrf |
This field is not supported in the current software version. VPN instance name. For the public network, this field displays default-vrf. |
OrigNexthop |
Original next hop. |
RealNexthop |
Real next hop. |
Output interface. |
localAddr |
RelyDepth |
Recursion depth. |
TunnelCnt |
This field is not supported in the current software version. Number of tunnels after route recursion. |
TunnelID |
This field is not supported in the current software version. ID of the tunnel after route recursion. |
Topology |
This field is not supported in the current software version. Topology name. This field is blank for IPv6, because IPv6 does not support non-base topologies. |
Weight |
ECMP route weight. This field displays 0 for non-ECMP routes. |
RefCnt |
Reference count of the next hop. |
FlushRefCnt |
Reference count of the next hop that is flushed to the FIB. |
Flag |
Flag of the next hop. |
Version |
Version of the next hop. |
Flags |
Flags of the detailed next hop. |
SRPolicyNID |
This field is not supported in the current software version. NIB ID of the route obtained from an SR-MPLS TE policy through route recursion. |
SRInterface |
This field is not supported in the current software version. Output interface of the route obtained from the SR-MPLS TE policy through route recursion. |
ColorWeight |
This field is not supported in the current software version. Weight value of the color attribute in the SR-MPLS TE policy. |
Locator |
This field is not supported in the current software version. IPv6 prefix of the locator to which the SID belongs. If no locator is available, this field displays N/A. |
OrigLinkID |
This field is not supported in the current software version. Original link ID of the SDWAN TTE connection. |
RealLinkID |
This field is not supported in the current software version. Real link ID of the SDWAN TTE connection. |
Use display ipv6 route-static routing-table to display IPv6 static routing table information.
display ipv6 route-static routing-table [ ipv6-address prefix-length ]
ipv6-address: Specifies the destination IPv6 address.
prefix-length: Specifies the prefix length in the range of 0 to 128.
# Display IPv6 static routing table information.
<Sysname> display ipv6 route-static routing-table
Total number of routes: 5
Status: * - valid
*Destination: 1::1/128
NibID: 0x21000000 NextHop: 2::2
MainNibID: N/A BkNextHop: N/A
BkNibID: N/A Interface: Vlan-interface11
TableID: 0xa BkInterface: N/A
Flag: 0x80d0a BfdSrcIp: N/A
DbIndex: 0x3 BfdIfIndex: 0x0
Type: Normal BfdVrfIndex: 0
TrackIndex: 0xffffffff Label: NULL
Preference: 60 vrfIndexDst: 0
BfdMode: N/A vrfIndexNH: 0
Permanent: 0 RecurseMaskLen: N/A
Tag: 0
*Destination: 1::1234/128
BkNibID: N/A Interface: NULL0
DbIndex: 0x1 BfdIfIndex: 0x0
Tag: 0
Destination |
Destination address/prefix. |
NibID |
ID of the NIB. |
MainNibID |
ID of the primary next hop for static route FRR. |
BkNibID |
ID of the backup next hop for static route FRR. |
NextHop |
Next hop address. |
BkNextHop |
Backup next hop address. |
Output interface of the route. |
BkInterface |
Backup output interface. |
TableID |
ID of the table to which the route belongs. |
DbIndex |
Index of the database to which the route belongs. |
Type |
Route type: · Normal. · DHCP. · NAT. · IPSGT. |
BfdSrcIp |
This field is not supported in the current software version. Source IPv6 address of the indirect BFD session. |
BfdIfIndex |
This field is not supported in the current software version. Index of the interface where BFD is enabled. |
BfdVrfIndex |
This field is not supported in the current software version. Index of the VPN instance where BFD is enabled. This field displays 0 if BFD is enabled for the public network. |
BfdMode |
This field is not supported in the current software version. BFD session mode: · N/A—No BFD session is configured. · Ctrl—Control packet mode. · Echo—Echo packet mode. |
TrackIndex |
This field is not supported in the current software version. NQA Track index. |
Label |
This field is not supported in the current software version. Label of the route. |
vrfIndexDst |
This field is not supported in the current software version. Index of the VPN instance to which the destination belongs. For the public network, this field displays 0. |
vrfIndexNH |
This field is not supported in the current software version. Index of the VPN instance to which the next hop belongs. For the public network, this field displays 0. |
Permanent |
Permanent static route flag. 1 indicates a permanent static route. |
RecurseMaskLen |
Exact mask length for route recursion. If the device uses the longest match principle for route recursion, this field displays N/A. |
BfdStatic |
Name of the static BFD session associated with the route. If no static BFD session is associated with the route, this field is not available. |
ipv6 route-static
Use ipv6 route-static to configure an IPv6 static route.
Use undo ipv6 route-static to remove an IPv6 static route.
ipv6 route-static ipv6-address prefix-length { interface-type interface-number [ next-hop-address ] [ permanent ] | next-hop-address [ permanent ] } [ preference preference ] [ tag tag-value ] [ description text ]
ipv6 route-static ipv6-address prefix-length interface-type interface-number gateway [ preference preference ] [ tag tag-value ] [ description text ]
undo ipv6 route-static ipv6-address prefix-length [ interface-type interface-number [ next-hop-address | gateway ] | next-hop-address ] [ preference preference ]
No IPv6 static route is configured.
ipv6-address prefix-length: Specifies the IPv6 address and prefix length.
interface-type interface-number: Specifies an output interface by its type and number. If the output interface is an NBMA interface or broadcast interface and not a point-to-point (P2P) interface, the next hop address must be specified.
next-hop-address: Specifies the next hop IPv6 address.
gateway: Specifies the next hop IPv6 address of the IPv6 static route as the gateway address obtained by the interface in IPv6 address autoconfiguration. When the gateway address changes, the device automatically updates the next hop IPv6 address of the IPv6 static route accordingly. For more information about IPv6 address autoconfiguration, see IPv6 basics and DHCPv6 in Network Connectivity Configuration Guide.
permanent: Specifies the IPv6 route as a permanent IPv6 static route. After you specify this keyword, an active IPv6 static route will always be active and stay in the IPv6 routing table, regardless of whether the output interface is up or down. If the IPv6 static route has not been activated, it will not appear in the IPv6 routing table, even if the permanent keyword is specified.
preference preference: Specifies a preference for IPv6 static routes, in the range of 1 to 255. The default is 60. The smaller the value, the higher the preference. To enable load sharing for multiple routes to the same destination, assign the same preference to the routes. To enable the routes to back up one another, assign different preferences to them.
tag tag-value: Sets a tag for marking the static route, in the range of 1 to 4294967295. The default is 0. Tags of routes are used for route control in routing policies.
description text: Configures a description for the IPv6 static route, which consists of 1 to 60 characters, including special characters such as the space, but excluding the question mark (?).
Application scenarios
If a network's topology is simple, you only need to configure static routes for the network to work correctly. You can also configure static routes when the device cannot use dynamic routing protocols or cannot establish routes to the destination network.
Follow these guidelines to configure the output interface, next hop address, or both for a static route:
· If the output interface is a broadcast interface or an NBMA interface, the next hop address must be specified.
· If the output interface is a P2P interface, you can specify only the output interface. You do not need to change the configuration of the route even if the peer address is changed.
If the specified interface has not obtained the gateway address, the IPv6 static route with the gateway address as the next hop address does not take effect.
# Configure an IPv6 static route, with the destination address 1:1:2::/64 and next hop 1:1:3::1.
[Sysname] ipv6 route-static 1:1:2:: 64 1:1:3::1
display ipv6 routing-table protocol
Use ipv6 route-static default-preference to set a default preference for IPv6 static routes.
Use undo ipv6 route-static default-preference to restore the default.
ipv6 route-static default-preference default-preference
The default preference of IPv6 static routes is 60.
default-preference: Specifies a default preference for IPv6 static routes, in the range of 1 to 255. The smaller the value, the higher the preference.
If no preference is specified for an IPv6 static route, the default preference applies.
When the default preference is reconfigured, it applies only to newly added IPv6 static routes.
# Set a default preference of 120 for IPv6 static routes.
[Sysname] ipv6 route-static default-preference 120
Use ipv6 route-static fast-reroute auto to configure IPv6 static route FRR to automatically select a backup next hop.
Use undo ipv6 route-static fast-reroute auto to disable IPv6 static route FRR from automatically selecting a backup next hop.
IPv6 static route FRR is disabled from automatically selecting a backup next hop.
# Configure IPv6 static route FRR to automatically select a backup next hop.
[Sysname] ipv6 route-static fast-reroute auto
