H3C G7 Servers HDM3 Technology White Paper-6W100
HomeSupportConfigure & DeployUser ManualsH3C G7 Servers HDM3 Technology White Paper-6W100
02-Appendix B Sensor Name and Description
02-Appendix B Sensor Name and Description 42.49 KB
Appendix A
Table 1 Sensor name and description
Sensor type
Sensor name
Sensor description
Temperature
Inlet_Temp
Air inlet temperature (only one available)
Outlet_Temp
Air outlet temperature (only one available)
CPUx_Temp
CPUx core temperature
CPUx_DTS
Remaining temperature before CPU throttling
CPUx_DIMM_Temp
Max. temperature of common DIMMs for CPUx (x represents the CPU number starting from 1, such as 1 and 2)
Front_HD_Max
Max. temperature of front drives
Mid_HD_Max
Max. temperature of middle drives
Rear_HD_Max
Max. temperature of rear drives
Front_NVMe_Max
Max. temperature of front NVMe drives
Mid_NVMe_Max
Max. temperature of middle NVMe drives
Rear_NVMe_Max
Max. temperature of rear NVMe drives
M.2_Max
Max. temperature of M.2 drives
M.2_Zone
M.2 zone temperature
PCH_Temp
PCH temperature
PSUx_Temp
Power supply x air inlet temperature
CPUx_VR_Temp
Max. CPU VR value
PCIex_Temp
PCIe x temperature
OCPx_Temp
OCP card temperature
Busbarx_Zone
BusBar temperature
DSFP_Max
Max. transceiver module temperature
Voltage
CPUx_VCORE
CPUx core voltage
PSUx_VIN
Power supply N input voltage
PSUx_VOUT
Power supply N output voltage
SYS_12V
System 12V voltage (system HSC output voltage)
SYS_5V
System 5V voltage
SYS_3V3_Standby
System 3.3V voltage
SYS_3V_BAT
Voltage of the RTC battery on the system board
CPUx_DDR_VDDQ1
Memory voltage sensor (VDDQ1)
CPUx_DDR_VDDQ2
Memory voltage sensor (VDDQ2)
Current
PSUN_IIN
Power supply N input current
PSUN_IOUT
Power supply N output current
Power
Total_Power
Total chassis power
FAN_Power
Total fan power
CPU_Power
Total CPU power
MEM_Power
Total memory power
DISK_Power
Total drive power
GPU_Power
Total GPU power
PSUx_PIN
Power supply x input power
PSUx_POUT
Power supply x output power
Rotation speed
FANx_Speed
or FANx_F_Speed
or FANx_R_Speed
Rotation speed of fan module x in RPM
or rotation speed of the front fan in fan module x in RPM
or rotation speed of the rear fan in fan module x in RPM
Status
CPUx_Status
CPU x status (x: 0 to n)
CPUx_Chy_Dz
Memory status, including status in the BIOS and MCA error parsing status The sensor is displayed in the following modes:
·     Mode 1:
¡     x represents the CPU number, starting from 1, such as 1 and 2.
¡     y represents the DIMM channel number (channel ID), starting from 1, such as 1 to 8.
¡     z represents the DIMM ID in each channel, starting from 0, such as 0 and 1.
·     Mode 2: x represents the CPU number, A#, B#, C#...
A pound sign (#) represents the DIMM ID in each channel, starting from 0, such as 0 and 1.
A=Channel1
B=Channel2
Watchdog2
System watchdog overflow and action
Sys_Restart
System startup/startup reason
SysShutdown
System shutdown reason
Boards
Exceptional host power outage
Sys_FW_Progress
System firmware (BIOS) and POST status
ACPI_State
ACPI power status
PSUx_Status
System power supply x status (x: 0 to n)
PSU_Mismatch
Overall power status
PSU_Redundant
System power redundancy status
FANx_Status
or FANx_F_Speed
or FANx_R_Speed
Fan x status
Status of front/rear fan in fan module x (x: 0 to n)
A centrifugal fan module includes front and rear fans.
The status sensors for upper and down fans are named in different formats, such as FANx_U_Status and FANx_D_Status, or FANx_U_F_Status,
FANx_U_R_Status, FANx_D_F_Status, and FANx_D_R_Status
Front: Disk_Fx_Status
Rear: Disk_Rx_Status
Middle: Disk_Mx_Status
Drive status (x: 0 to n)
Front:
M2_SSD_Fx_Status
M2_NVMe_Fx_Sts
Rear:
M2_SSD_Rx_Status
M2_NVMe_Rx_Sts
Drive status (x: 0 to 2)
LAN_Leash_Lost
Link status of network adapter ports
PCIe_Status
Overall PCIe alarm status
PCIex_PM_LNK
PCIe link status of port M in standard PCIe slot x
Px_PCIe_Status
PCIe status of the module in standard PCIe slot x
This status indicates the fault status of the PCIe bus and slot with x representing the PCIe slot number, in the range of 0 to n. The status information is obtained by PCIe faults from the BIOS or is interpreted from the MCA register
BMC_Boot_Up
BMC startup
UID_Button
Long press on the UID button on the panel for BMC reset
SEL_Status
SEL status
PCIe_Riserx_PG
Riser card PG status
F_BPx_Status
Status of front drive backplane x (x: 0 to n, depending on product marks)
M_BPx_Status
Status of middle drive backplane x (x: 0 to n, depending on product marks)
R_BPx_Status
Status of rear drive backplane x (x: 0 to n, depending on product marks)
AreaIntrusion
Chassis status
Liquid_Cooler
Liquid-cooled leak sensor
BMC_Boot_Up
BMC startup
