H3C G6 Servers HDM2 Configuration Examples-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C G6 Servers HDM2 Configuration Examples-6W100
04-H3C HDM2 Memory Intelligent Repair Configuration Examples
H3C G6 Servers HDM2
Copyright © 2025 New H3C Technologies Co., Ltd. All rights reserved.
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Introduction
HDM supports memory intelligent repair, allowing users to limit OS access to faulty memory pages to prevent anomalies during access. Users can view the number of repairs and repair records from the HDM Web interface. This feature enhances the stability and reliability of the system. The following information describes the typical configuration of the memory intelligent repair feature in H3C HDM management software.
Procedures and information in the document might be slightly different depending on the software or hardware version of the device.
The following information is provided based on the assumption that you have basic knowledge of memory intelligent repair.
Application scenarios
This document applies to using the memory intelligent repair function provided by HDM to prevent potential memory errors on the server. Only servers installed with Intel processors support the memory intelligent repair feature.
Example: Configuring memory intelligent repair
As shown in Figure 1, the HDM management interface of the H3C UniServer R4900 G6 server (hereafter referred to as R4900 G6) connects to the PC through the switch. Users can log in to the HDM Web interface through the PC to perform storage management.
·     The information related to the HDM management software for the R4900 G6 server is as follows:
¡     IP address: 192.168.20.177
¡     Administrator account: admin
¡     Administrator cipher: Password@_
·     PC IP address: 10.41.50.29
Figure 1 Network diagram
Analysis
Log into the HDM Web interface of the R4900 G6 and use the intelligent monitoring menu under O&M diagnostics to perform memory intelligent repair operations.
Software versions used
This configuration example was created and verified on HDM2-1.54.
Logging into the HDM Web interface
1.     Open a browser on the PC and enter IP address 192.168.20.177 in the address bar to access the HDM Web interface. Enter the default administrator username admin and password Password@_ to log into HDM Web.
Figure 2 Logging in to the HDM Web interface
2.     Navigate to the O&M Diagnosis > Intelligent Monitoring page.
Figure 3 Memory page
Performing memory intelligent repair
1.     Navigate to the O&M Diagnosis > Intelligent Monitoring page.
2.     Enable memory intelligent repair. By default, intelligent memory repair is enabled.
3.     Select DIMMs from the Select DIMMs field. To select all DIMMs in the repair records, click the  icon.
4.     To hide the repair record marks in the graph, click Repair record. By default, the repair record marks are displayed. The larger a mark, the more the repair times of the DIMM in the slot at the corresponding time.
Figure 4 Memory repair status
5.     To view the most recent repair records, click Displays the most recent 40 records. The system displays only the most recent 40 records. To view repair records during the memory lifetime, click Displays repair records during the life cycle.
Figure 5 Displaying repair records during the life cycle
Setting the memory intelligent repair policy
3.     Click the button to the right of the memory intelligent repair feature. In the dialog box that opens, perform the following tasks:
Figure 6 Memory intelligent repair policy
4.     Select a page size in the PageSize field. The default is 4KB/page.
5.     Set the upper limit of memory capacity that can be isolated in the Control level field.
Figure 7 Memory intelligent repair policy
4.     Select a page size in the PageSize field to 4KB/page.
5.     Set the upper limit of memory capacity that can be isolated in the Control level field to level 2.
6.     Simulate memory error scenarios through the applet, and inject memory CEs multiple times.
Figure 8 Injecting CEs
7.     View memory repair records during the memory repair process. Hover over the green identifier to see the location and number of memory repairs.
Figure 9 Memory repair status
8.     Access the applet and verify that the applet is operating correctly and the memory errors do not affect the system. Verify that the memory isolation volume increases from 0KB to 4KB.
Figure 10 Memory repair result
Related documentation
·     H3C G6 Servers HDM2 User Guide
·     H3C G6 Servers HDM2 Technology White Paper
