HomeSupportConfigure & DeployConfiguration GuidesH3C SecPath F1000[F5000] Firewalls Series Configuration Guides(V7)-6W90201-Fundamentals Configuration Guide
12-Automatic configuration
12-Automatic configuration 139.39 KB
Using automatic configuration
About automatic configuration
With the automatic configuration feature, the device can automatically obtain a set of configuration settings at startup. This feature simplifies network configuration and maintenance.
Automatic configuration can be implemented by using the implementation methods in Table 1.
Table 1 Automatic configuration implementation methods
Implementation method
Configuration file location
Application scenarios
URL-based automatic configuration
Saved on the device before the device is shipped
Devices are geographically distributed.
USB-based automatic configuration
USB disk
·     On a small network, the devices reside near to each other, and no host can be used as a file server.
·     On a large network, only a few devices require automatic configuration or configuration update.
Automatic configuration can be implemented by using the implementation methods in Table 2.
Table 2 Automatic configuration implementation methods
Server-based automatic configuration
File server
A number of geographically distributed devices need to be configured.
USB disk
If both server-based automatic configuration and USB-based automatic configuration are available, the device prefers USB-based automatic configuration.
As a best practice, use SMS-based automatic configuration only if you do not have any other choices. SMS-based automatic configuration has the following disadvantages:
·     High cost.
·     Low reliability. Short messages depend on 3G or 4G networks. Wireless signals might be unstable.
Using URL-based automatic configuration
About URL-based automatic configuration
URL-based automatic configuration uses a customizable configuration file saved on the device by default to implement basic device configuration after the device starts up. The configuration file contains the basic network configuration command lines. This feature requires you to construct a URL to indicate the values for the parameters in the command lines. The URL can be in either of the following forms:
·     Plaintext form—The user directly configures the plaintext URL. Parameters in the URL are configured and transmitted in plaintext form.
·     Encrypted form—The administrator generates the encrypted URL and an authentication password for the URL by using the controller. Within the validity of the URL, a user can enter the authentication password as prompted to use the URL to perform URL-based automatic configuration.
Hardware compatibility with URL-based automatic configuration
Series
Models
URL-based automatic configuration compatibility
F5000 series
F5000-AI360, F5000-AI160, F5000-AI120, F5000-AI-40, F5000-AI-20, F5000-AI-15
Yes
F5000-CN60, F5000-CN30
Yes
F5000-CN160, F5000-CN-G85, F5000-CN-G65, F5000-CN-G55
No
F1000 series
F1000-AI-90, F1000-AI-80,  F1000-AI-75, F1000-AI-70,  F1000-AI-65, F1000-AI-60 , F1000-AI-25
Yes
F1000-CN-G35
No
How URL-based automatic configuration works
The basic device configuration defines how the device connects to the network. By default, the following connection modes are available: PPPoE mode, static IP address mode, and DHCP mode. The customizable configuration file contains the command lines for the connection modes. The required URL varies by connection mode.
PPPoE mode
Table 3 lists the parameters required or optional in the URL in PPPoE mode. The following is the format of the URL in PPPoE mode:
http://Device IP address/urlcfg?sys_name=Device name&link_mode=Link mode&dialer_if=Dialer interface name&ntp_server=NTP server (optional)&link_if=WAN interface&ac_host=Server IP address&ac_port=Server port&ac_password=Server password&pap_user=PPPoE PAP authentication password&pap_password=PPPoE PAP authentication password&chap_user=PPPoE CHAP authentication username&chap_password=PPPoE CHAP authentication password
Table 3 Parameters required for PPPoE mode
Item
Parameter
Value type
Value range
Corresponding command
Required
Device address
Device IP address
IP address
N/A
N/A
Yes
Device name
sys_name
String
1 to 64
sysname sysname
Yes
Server address
ac_host
IP address
N/A
cloud-management server domain ip-address
Yes
Server port
ac_port
Integer
1 to 65535
cloud-management server port port-number
Yes
Server password
ac_password
String
1 to 63
cloud-management server password simple password
Yes
NTP server
ntp_server
IP address
N/A
ntp-service unicast-server ip-address
No
WAN interface
link_if
Interface type and number
N/A
Yes
PPPoE connection mode
link_mode
String
PPPoE
N/A
Yes
PPPoE dialer interface
dialer_if
String
N/A
interface dialer number
Yes
PPPoE PAP authentication username
pap_user
String
1 to 80
ppp pap local-user user-name password simple password
Yes
pap_password
String
1 to 255
Yes
chap_user
String
1 to 80
ppp chap user user-name
Yes
chap_password
String
1 to 255
ppp chap password simple password
Yes
Static IP address mode
Table 4 lists the parameters required or optional in static IP address mode. The following is the format of the URL in static IP address mode:
http://Device IP address/urlcfg?sys_name=Device name&link_mode=Link mode&ntp_server=NTP server (optional)&dest_ip=Destination IP address&dest_mask=Destination IP mask&next_hop=IP address of the next hop&link_if=WAN interface&static_ip=Static IP address&static_mask=Static IP mask&ac_host=Server address&ac_port=Server port&ac_password=Server password
Table 4 Parameters required for static IP address mode
Item
Parameter
Value type
Value range
Required
Device address
Device IP address
IP address
N/A
N/A
Yes
Device name
sys_name
String
1 to 64
sysname sysname
Yes
Server address
ac_host
IP address
N/A
Yes
Server port
ac_port
Integer
1 to 65535
Yes
Server password
ac_password
String
1 to 63
Yes
NTP server
ntp_server
IP address
N/A
No
dest_ip
IP address
N/A
ip route-static dest-address mask next-hop-address
Yes
Destination IP mask
dest_mask
IP mask
N/A
Yes
next_hop
IP address
N/A
Yes
WAN interface
link_if
N/A
Yes
Static IP address connection mode
link_mode
String
STATIC
N/A
Yes
Static IP address
static_ip
IP address
N/A
ip address ip-address mask
Yes
Static IP mask
static_mask
IP mask
N/A
Yes
Static default gateway
gateway
IP address
N/A
ip route-static 0.0.0.0 0.0.0.0 next-hop-address
Yes
DHCP mode
Table 5 lists the parameters required or optional in DHCP mode. The following is the format of the URL in DHCP mode:
http://Device IP address/urlcfg?sys_name=Device name&link_mode=Link mode&ntp_server=NTP server (optional)&link_if=WAN interface&ac_host=Server address&ac_port=Server port&ac_password=Server password
Table 5 Parameters required for DHCP mode
Item
Parameter
Value type
Value range
Required
Device address
Device IP address
IP address
N/A
N/A
Yes
Device name
sys_name
String
1 to 64
sysname sysname
Yes
Server address
ac_host
IP address
N/A
Yes
Server port
ac_port
Integer
1 to 65535
Yes
Server password
ac_password
String
1 to 63
Yes
NTP server
ntp_server
IP address
N/A
No
WAN interface
link_if
N/A
Yes
DHCP connection mode
link_mode
String
DHCP
N/A
Yes
1.     Power on the device.
2.     Enable URL-based automatic configuration.
a.     Enter system view.
b.     Enable URL-based automatic configuration.
autodeploy url enable
By default, URL-based automatic configuration is enabled the state.
c.     Save the current configuration.
save
If URL-based automatic configuration is disabled on a device, you must execute this command, save the configuration, and reboot the device to make this feature take effect.
3.     On the configuration terminal, launch a Web browser and enter the default IP address of the device in the address bar. Then, enter the default username and password as prompted to log in to the device.
You can change the default IP address, username, and password on the device. The IP address and username are the device address and device name required in the URL.
4.     Construct a URL as describe in "How URL-based automatic configuration works."
5.     Enter the URL in the address bar and enter the username and password as prompted.
The device will use the parameters and values in the URL and the customizable configuration file to reconstruct a configuration file, and then execute the file to complete automatic configuration.
Configuration file
IMPORTANT
IMPORTANT:
The contents of the configuration file might vary by device model.
PPPoE mode section
{link_mode = PPPoE}
 sysname [sys_name]
 dialer-group 1 rule ip permit
interface Dialer1
 1:ppp chap password simple [chap_password]
 1:ppp chap user [chap_user]
 ppp ipcp dns admit-any
 ppp ipcp dns request
 1:ppp pap local-user [pap_user] password simple [pap_password]
 dialer bundle enable
 dialer-group 1
 dialer timer idle 0
 dialer timer autodial 5
 ip address ppp-negotiate
 tcp mss 1024
 nat outbound
interface [link_if]
 port link-mode route
 pppoe-client dial-bundle-number 1
 1:ntp-service unicast-server [ntp_server]
 cloud-management server domain [ac_host]
 cloud-management server port [ac_port]
 cloud-management server password simple [ac_password]
 ip route-static 0.0.0.0 0 Dialer1
Static IP address mode section
{link_mode = STATIC}
 sysname [sys_name]
interface [link_if]
 ip address [static_ip] [static_mask]
 nat outbound
 qu
 ip route-static 0.0.0.0 0.0.0.0 [gateway]
DHCP mode section
{link_mode = DHCP}
 sysname [sys_name]
interface [link_if]
 ip address dhcp-alloc
 nat outbound
 qu
Using USB-based automatic configuration
About USB-based automatic configuration
USB-based automatic configuration enables the device to obtain a configuration file from a connected USB disk at startup. The configuration file can be in either of the following forms:
·     Plaintext form—The configuration file is saved in plaintext form.
·     Encrypted form—The configuration file is generated by the administrator in encrypted form by using the controller. When being transmitted to a USB disk, the configuration data in the file is transmitted in encrypted form. When being used to perform automatic configuration, the configuration data is automatically decrypted by the device.
After obtaining a configuration file, the device compares the file with its main startup configuration file. If the two files have the same settings, the device loads its main startup configuration file. If the two files have different settings, the device performs the following operations:
1.     Identifies whether its main startup configuration file is using the same name as the obtained configuration file.
¡     If yes, the device renames its main startup configuration file by adding _bak to the base name of the file, and copies the obtained configuration file.
¡     If not, the system uses the obtained configuration file to overwrite its main startup configuration file.
2.     Loads the obtained configuration file.
¡     If all commands in the obtained configuration file are successfully loaded, the device sets the obtained configuration file as the main startup configuration file.
¡     If a command in the obtained configuration file fails, the device removes all loaded settings
and searches for a local configuration file.
-     If a configuration file is found, the device loads the configuration file.
-     If no configuration file is found, the device finishes the automatic configuration process without loading any configurations.
Preparing the USB disk for automatic configuration
1.     Prepare a USB disk that has only one partition.
2.     Display the serial number of the device.
display device manuinfo
For more information about this command, see Fundamentals Command Reference.
3.     Create a configuration file named Device serial number.cfg or autodeploy.cfg, and save the file to the root directory of the file system on the USB disk.
If a configuration file named Device serial number.cfg coexists with configuration file autodeploy.cfg, configuration file Device serial number.cfg is used.
Configuring and using USB-based automatic configuration
1.     Enable USB-based automatic configuration on the device:
b.     Enable USB-based automatic configuration.
autodeploy udisk enable
By default, USB-based automatic configuration is enabled.
c.     Save the running configuration.
save
A device reboot is required for USB-based automatic configuration. Save the running configuration to ensure that the USB-based automatic configuration feature takes effect after a reboot.
2.     The device supports USB-based automatic configuration only if it has only one member device. When multiple member devices exist, use the shutdown command to shut down all IRF physical ports, and then perform USB-based automatic configuration for the master device.
3.     Connect the USB disk to the USB1 interface on the device.
The USB disk will be identified as usba0.
4.     Reboot the device and observe the LEDs of the device.
If the device finds no configuration files to load at startup, it performs the following operations:
a.     Copies the configuration file on the USB disk.
b.     Specifies the file as the startup configuration file.
c.     Reboots to load the configuration file.
¡     If the SYS LED flashes green quickly for 5 seconds, the automatic configuration succeeded. Proceed to step 5.
¡     If the SYS LED flashes yellow quickly for 10 seconds, the automatic configuration failed. Display the log file named Fully qualified configuration file name.log in the USB disk root directory to locate and resolve the problem.
For more information about the LEDs, see the installation guide.
5.     If the automatic configuration succeeded, use the display current-configuration command to verify that the configuration file has been loaded correctly.
6.     Rebuild the IRF fabric.
The subordinate members automatically synchronize their configurations with the master at startup.
