- 01-Fundamentals Configuration Guide
- 01-CLI configuration
- 02-RBAC configuration
- 03-Login management configuration
- 04-License management
- 05-Device management configuration
- 06-FTP and TFTP configuration
- 07-File system management configuration
- 08-RAID management configuration (security devices)
- 09-Configuration file management configuration
- 10-Software upgrade configuration
- 11-ISSU configuration
- 12-Automatic configuration
- 13-Tcl configuration
- 14-Python configuration
| 00-Preface | 109.77 KB |
Preface
This configuration guide describes features and tasks that help you get started with the device
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
