14-Layer 3—IP Services Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SecPath F1000[F5000] Firewalls Series Command Reference(V7)-6W90214-Layer 3—IP Services Command Reference
03-Fast forwarding commands
03-Fast forwarding commands 119.26 KB
Non-default vSystems do not support some of the fast forwarding commands. For information about vSystem support for a command, see the usage guidelines on that command. For information about vSystem, see Virtual Technologies Configuration Guide.
display ip fast-forwarding aging-time
Use display ip fast-forwarding aging-time to display the aging time of fast forwarding entries.
context-admin
context-operator
vsys-admin
vsys-operator
# Display the aging time of fast forwarding entries.
<Sysname> display ip fast-forwarding aging-time
 Aging time: 30s
display ip fast-forwarding cache
Use display ip fast-forwarding cache to display fast forwarding entries.
display ip fast-forwarding cache [ ip-address ] [ slot slot-number ]
context-admin
context-operator
vsys-admin
vsys-operator
ip-address: Specifies an IP address. If you do not specify an IP address, this command displays all fast forwarding entries.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays fast forwarding entries for all member devices.
# Display all fast forwarding entries.
<Sysname> display ip fast-forwarding cache
Total number of fast-forwarding entries: 1
SIP            SPort DIP            DPort Pro Input_If   Output_If   Flg
7.0.0.13       68    8.0.0.1        67    17  GE1/0/3    GE1/0/1     5
SIP
Source IP address.
SPort
Source port number.
DIP
Destination IP address.
DPort
Destination port number.
Pro
Protocol number.
Input_If
Input interface type and number.
If no interface is involved in fast forwarding, this field displays N/A.
If the input interface does not exist, this field displays a hyphen (-).
Output_If
Output interface type and number.
If the output interface does not exist, this field displays a hyphen (-).
Flg
Internal tag, marking internal operation information, such as fragmentation.
reset ip fast-forwarding cache
display ip fast-forwarding fragcache
Use display ip fast-forwarding fragcache to display fast forwarding entries for fragmented packets.
display ip fast-forwarding fragcache [ ip-address ] [ slot slot-number ]
context-admin
context-operator
vsys-admin
vsys-operator
ip-address: Specifies an IP address. If you do not specify an IP address, this command displays fast forwarding entries for all fragmented packets.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays fast forwarding entries for fragmented packets on all member devices.
The system creates fast forwarding entries for fragments only when virtual fragment reassembly (VFR) is enabled. If VFR is disabled, this command does not display fast forwarding entries for fragments.
# Display fast forwarding entries about all fragmented packets.
<Sysname> display ip fast-forwarding fragcache
Total number of fragment fast-forwarding entries: 1
SIP             SPort DIP             DPort Pro Input_If    ID     Relay_flag
7.0.0.13        68    8.0.0.1         67    17  GE1/0/3     2      1
SIP
Source IP address.
SPort
Source port number.
DIP
DPort
Pro
Protocol number.
Input_If
ID
Fragment ID.
Relay_flag
Fragment pass-through flag:
·     0—Not pass through.
·     1—Pass through.
hardware fast-forwarding checksum encap incremental
Use hardware fast-forwarding checksum encap incremental to enable the incremental checksum encapsulation for outgoing packets on hardware fast forwarding chips.
Use undo hardware fast-forwarding checksum encap incremental to restore the default.
hardware fast-forwarding checksum encap incremental [ slot slot-number ]
undo hardware fast-forwarding checksum encap incremental [ slot slot-number ]
The following compatibility matrix shows the support of hardware platforms for this command:
Series
Models
Command compatibility
F5000 series
F5000-AI360, F5000-AI160, F5000-AI120, F5000-CN160
Yes
F5000-CN-G85, F5000-CN-G65, F5000-CN-G55, F5000-CN60, F5000-CN30, F5000-AI-40, F5000-AI-20, F5000-AI-15
No
F1000 series
F1000-CN-G35, F1000-AI-90, F1000-AI-80, F1000-AI-75, F1000-AI-70, F1000-AI-65, F1000-AI-60, F1000-AI-25
No
The incremental checksum is encapsulated into the outgoing packets on hardware fast forwarding chips.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, the command enables incremental checksum encapsulation for outgoing packets on hardware fast forwarding chips of all cards.
This command takes effect only on service modules that support hardware fast forwarding.
# Enable the incremental checksum encapsulation for outgoing packets on the hardware fast forwarding chip for CPU 1 on the specified slot.
[Sysname] hardware fast-forwarding checksum encap incremental slot 1
hardware fast-forwarding checksum inspect action
Use hardware fast-forwarding checksum inspect action { drop-err | log } to specify an action for a packet alteration event.
Use undo hardware fast-forwarding checksum inspect action { drop-err | log } to cancel the specified action.
hardware fast-forwarding checksum inspect action { drop-err | log } [ slot slot-number ]
undo hardware fast-forwarding checksum inspect action { drop-err | log } [ slot slot-number ]
Series
Models
F5000 series
Yes
No
F1000 series
No
When the device detects a packet alteration event, it forwards the altered packet and generates a log message.
drop-err: Drops the altered packets.
log: Generates a log message when the device detects a packet alteration event.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, the command configuration applies to all cards.
If you execute this command multiple times, the specified action in each execution takes effect.
# Disable logging for packet alteration for CPU 1 on the specified slot.
[Sysname] undo hardware fast-forwarding checksum inspect action log slot 1
hardware fast-forwarding checksum inspect enable
Use hardware fast-forwarding checksum inspect enable to enable alteration detection for outgoing packets on hardware fast forwarding chips.
Use undo hardware fast-forwarding checksum inspect enable to disable alteration detection for outgoing packets on hardware fast forwarding chips.
hardware fast-forwarding checksum inspect [ l3 | l4 [ tcp | udp ] ] enable [ slot slot-number]
undo hardware fast-forwarding checksum inspect [ l3 | l4 [ tcp | udp ] ] enable [ slot slot-number]
Series
Models
F5000 series
Yes
No
F1000 series
No
Alteration detection is enabled for outgoing packets on hardware fast forwarding chips.
l3: Enables the packet alteration detection on the Layer 3 information.
l4: Enables the packet alteration detection on the Layer 4 information.
tcp: Enables the TCP packet alteration detection.
udp: Enables the UDP packet alteration detection.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, the command enables alteration detection for outgoing packets on hardware fast forwarding chips of all cards.
To enable alteration detection on different types of packets, execute this command multiple times.
To enable TCP or UDP packet alteration detection, specify the l4 keyword before you specify the tcp or udp keyword.
If you do not specify any parameters, the device detects alterations for outgoing packets on both the Layer 3 and Layer 4 information.
If you specify the l4 keyword without specifying the tcp or udp keyword, the device detects alterations for outgoing packets on the Layer 4 information.
# Disable alteration detection on outgoing TCP packets for CPU 1 on slot 1.
[Sysname] undo hardware fast-forwarding checksum inspect l4 tcp enable slot 1
hardware fast-forwarding enable
Use hardware fast-forwarding enable to enable hardware fast forwarding.
Use undo hardware fast-forwarding enable to disable hardware fast forwarding.
hardware fast-forwarding enable [ slot slot-number ]
undo hardware fast-forwarding enable [ slot slot-number ]
hardware fast-forwarding enable [ chassis chassis-number slot slot-number ]
undo hardware fast-forwarding enable [ chassis chassis-number slot slot-number ]
Series
Models
F5000 series
Yes
No
F1000 series
No
Hardware fast forwarding is enabled.
Non-default vSystems do not support this command.
Hardware fast forwarding stores session information during fast forwarding to speed up subsequent traffic forwarding by comparing the traffic with session information.
Disable hardware fast forward when you troubleshoot problems on forwarding chips.
In dual-master IRF scenarios, the device does not support transparent packet transmission:
·     If the device is deployed with a version earlier than EXX90P07, you must execute the undo hardware fast-forwarding enable command on the master device after IRF fabric setup. This command disables hardware fast forwarding.
·     If the device is deployed with EXX90P07 or a later version, hardware fast forwarding is automatically disabled during IRF fabric setup. The device then uses the CPU's software forwarding function to forward packets, which will lead to performance degradation. As a best practice, use RBM networking rather than IRF networking. When IRF networking is required, use it with caution. For more information about RBM networking, see RBM-based hot backup configuration in High Availability Configuration Guide.
Non-default context does not support this command.
# Disable hardware fast forwarding on slot 1.
[Sysname] undo hardware fast-forwarding enable slot 1
hardware fast-forwarding standalone
Use hardware fast-forwarding standalone to enable single-chip hardware forwarding for upstream packets.
Use undo hardware fast-forwarding standalone to restore the default.
hardware fast-forwarding standalone [ slot slot-number ]
undo hardware fast-forwarding standalone [ slot slot-number ]
Series
Models
F5000 series
Yes
No
F1000 series
No
Dual-chip hardware forwarding is enabled for upstream packets.
slot slot-number: Specifies a card by the slot number.
This feature applies only to modules that have more than one hardware forwarding chip.
It enables a dual-chip module to forward upstream packets by using only one of the chips. This feature does not apply to downstream packets. The module uses both chips to forward downstream packets.
After you change the hardware forwarding mode for upstream packets, you must restart the module for the change to take effect.
To change the hardware forwarding mode for upstream packets in a security engine group with multiple security engines (multiple modules), perform the following tasks:
1.     Execute the hardware fast-forwarding standalone or undo hardware fast-forwarding standalone command on all modules one by one to change their hardware forwarding mode for upstream packets.
2.     Restart all modules.
# Enable single-chip hardware forwarding for upstream packets on slot 1.
[Sysname] hardware fast-forwarding standalone slot 1
Use ip fast-forwarding aging-time to configure the aging time for fast forwarding entries.
Use undo ip fast-forwarding aging-time to restore the default.
ip fast-forwarding aging-time aging-time
The aging time is 30 seconds.
context-admin
vsys-admin
aging-time: Specifies the aging time in the range of 10 to 300 seconds.
# Set the aging time to 20 seconds for fast forwarding entries.
[Sysname] ip fast-forwarding aging-time 20
ip fast-forwarding dscp
Use ip fast-forwarding dscp to enable DSCP-based fast forwarding for GRE and VXLAN packets.
Use undo ip fast-forwarding dscp to restore the default.
DSCP-based fast forwarding for GRE and VXLAN packets is disabled.
context-admin
vsys-admin
This command is applicable to GRE packets (with IP as the passenger protocol) and VXLAN packets that are processed by software.
This feature uses the DSCP value in the outer header instead of the source port number among the identification criteria to identify GRE and VXLAN traffic flows.
This command is mutually exclusive with NAT and load balancing.
# Enable DSCP-based GRE and VXLAN packet fast forwarding.
[Sysname] ip fast-forwarding dscp
ip fast-forwarding load-sharing
Use ip fast-forwarding load-sharing to enable fast forwarding load sharing.
Use undo ip fast-forwarding load-sharing to disable fast forwarding load sharing.
Fast forwarding load sharing is enabled.
context-admin
vsys-admin
Fast forwarding load sharing enables the device to load share packets of the same flow. This feature identifies a data flow by using the packet information.
If fast forwarding load sharing is disabled, the device identifies a data flow by the packet information and the input interface. No load sharing is implemented.
# Enable fast forwarding load sharing.
<Sysname> system-Views
[Sysname] ip fast-forwarding load-sharing
ip fast-forwarding vxlan-port
Use ip fast-forwarding vxlan-port to specify the destination UDP port number for identifying VXLAN packets.
Use undo ip fast-forwarding vxlan-port to restore the default.
ip fast-forwarding vxlan-port port-number
The destination UDP port number is 4789.
Predefined use roles
context-admin
vsys-admin
port-number: Specifies a UDP port number in the range of 1 to 65535.
This feature is applicable to only the UDP packets that are processed by software.
In a VXLAN network, configure this command on intermediate devices to identify VXLAN packets.
# Specify the destination UDP port number to 4900 for identifying VXLAN packets.
[Sysname] ip fast-forwarding vxlan-port 4900
Use reset ip fast-forwarding cache to clear the fast forwarding table.
reset ip fast-forwarding cache [ slot slot-number ]
context-admin
vsys-admin
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears the fast forwarding table for all member devices.
# Clear the fast forwarding table.
<Sysname> reset ip fast-forwarding cache
