14-Layer 3—IP Services Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SecPath F1000[F5000] Firewalls Series Command Reference(V7)-6W90214-Layer 3—IP Services Command Reference
01-IP addressing commands
01-IP addressing commands 96.55 KB
vSystem supports all IP addressing features. For more information about vSystem, see Virtual Technologies Configuration Guide.
display ip address float
Use display ip address float to display detailed information about the floating IP addresses.
display ip address float [ interface interface-type interface-number | vpn-instance vpn-instance-name [ ip-address ] ] [ slot slot-number ]
context-admin
context-operator
interface interface-type interface-number: Specifies an interface by its type and number. This command will display detailed floating IP address information for the specified interface.
vpn-instance vpn-instance-name: Specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays detailed floating IP address information for the public network.
ip-address: Specifies a floating IP address. This command will display detailed information about the specific floating IP address.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays detailed floating IP address information for the master device.
If you do not specify any of the interface interface-type interface-number, vpn-instance vpn-instance-name, and ip-address parameters, this command displays detailed information about all floating IP addresses.
# Display detailed information about all floating IP addresses.
<Sysname> display ip address float
Interface     IP address/Mask       Type   State    Virtual MAC
GE1/0/1       100.100.100.100/24    Main   Active   40fe-9555-1234
GE1/0/1       100.100.100.101/24    Sub    Active   40fe-9555-1234
Abbreviated name of the interface that uses the floating IP address.
IP address
Floating IP address.
Mask
Subnet mask of the floating IP address.
Type of the floating IP address.
·     Main—Main floating IP address.
·     Sub—Sub floating IP address.
Status of the floating IP address:
·     Active—Active floating IP address.
·     Inactive—Inactive floating IP address.
Virtual MAC
Virtual MAC address used by the floating IP address for ARP response.
display ip interface
Use display ip interface to display IP configuration and statistics for Layer 3 interfaces.
display ip interface [ interface-type [ interface-number ] ]
context-admin
context-operator
vsys-admin
vsys-operator
interface-type: Specifies an interface by its type.
interface-number: Specifies an interface by its number.
Use the display ip interface command to display IP configuration and statistics for the specified Layer 3 interface. The statistics include the following information:
·     The number of unicast packets and bytes the interface has sent and received.
·     The number of TTL-invalid packets and ICMP packets the interface has received.
The packet statistics helps you locate a possible attack on the network.
If you specify only the interface type, this command displays IP configuration and statistics for all interfaces of this interface type. If you do not specify any optional parameters, this command displays IP configuration and statistics for all Layer 3 interfaces except VA interfaces. For more information about VA interfaces, see the PPPoE configuration in Layer 2—WAN Access Configuration Guide.
# Display IP configuration and statistics for GigabitEthernet 1/0/1.
<Sysname> display ip interface gigabitethernet 1/0/1
GigabitEthernet1/0/1 current state : DOWN
Line protocol current state : DOWN
Internet address is 1.1.1.1/8 Primary
Broadcast address : 1.255.255.255
The Maximum Transmit Unit : 1500 bytes
input packets : 0, bytes : 0, multicasts : 0
output packets : 0, bytes : 0, multicasts : 0
TTL invalid packet number:         0
ICMP packet input number:          0
  Echo reply:                      0
  Unreachable:                     0
  Source quench:                   0
  Routing redirect:                0
  Echo request:                    0
  Router advert:                   0
  Router solicit:                  0
  Time exceed:                     0
  IP header bad:                   0
  Timestamp request:               0
  Timestamp reply:                 0
  Information request:             0
  Information reply:               0
  Netmask request:                 0
  Netmask reply:                   0
  Unknown type:                    0
current state
Physical link state of the interface:
·     Administrative DOWN—The interface has been shut down by using the shutdown command.
·     DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed).
·     UP—The interface is both administratively and physically up.
Data link layer state of the interface.
·     UP (spoofing)—The data link layer protocol is up, but the link is an on-demand link or does not exist.
Internet address is ip-address/mask-length (Type)
IP address of the interface and type of the address in parentheses.
Possible IP address types include:
·     Primary—Manually configured primary IP address.
·     Sub—Manually configured secondary IP address.
·     SSLVPN—An SSL VPN AC interface IP address. For more information, see SSL VPN configuration in VPN Configuration Guide.
·     PPP-negotiated—IP address assigned by the PPP server during PPP negotiation. For more information, see PPP configuration in Layer 2WAN Access Configuration Guide.
·     Unnumbered—IP address borrowed from another interface.
·     DHCP-allocated—DHCP allocated IP address. For more information, see DHCP client configuration in Layer 3IP Services Configuration Guide.
·     BOOTP-allocated—BOOTP allocated IP address. For more information, see BOOTP client configuration in Layer 3IP Services Configuration Guide.
Broadcast address
Broadcast address of the subnet attached to an interface.
MTU of the interface, in bytes.
input packets, bytes, multicasts
output packets, bytes, multicasts
All received and sent packets and bytes, and received and sent multicast packets on an interface (statistics start at the device startup).
Number of TTL-invalid packets received on the interface (statistics start at the device startup).
  Echo reply:
  Unreachable:
  Source quench:
  Routing redirect:
  Echo request:
  Router advert:
  Router solicit:
  Time exceed:
  IP header bad:
  Timestamp request:
  Timestamp reply:
  Information reply:
  Netmask request:
  Netmask reply:
  Unknown type:
Total number of ICMP packets received on the interface (statistics start at the device startup):
·     Echo reply packets.
·     Unreachable packets.
·     Source quench packets.
·     Routing redirect packets.
·     Echo request packets.
·     Router advertisement packets.
·     Router solicitation packets.
·     Time exceeded packets.
·     IP header bad packets.
·     Timestamp request packets.
·     Timestamp reply packets.
·     Information request packets.
·     Information reply packets.
·     Netmask request packets.
·     Netmask reply packets.
·     Unknown type packets.
display ip interface brief
ip address
Use display ip interface brief to display brief IP configuration for Layer 3 interfaces.
display ip interface [ interface-type [ interface-number ] ] brief [ description ]
context-admin
context-operator
vsys-admin
vsys-operator
interface-type: Specifies an interface type. If you do not specify an interface type, this command displays brief IP configuration for all Layer 3 interfaces.
interface-number: Specifies an interface number. If you do not specify an interface number, this command displays brief IP configuration for all Layer 3 interfaces of the specified type.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays a maximum of 11 characters for each interface description. If the description is longer than 11 characters, the first eight characters are displayed, followed by an ellipsis (...).
Information displayed by the command includes the state of the physical and link layer protocols, IP address, and interface descriptions.
# Display brief IP configuration for GigabitEthernet interfaces.
<Sysname> display ip interface gigabitethernet brief
*down: administratively down
(s): spoofing  (l): loopback
Interface           Physical Protocol IP address/Mask    VPN instance Description
GE1/0/1             up       up       5.5.5.1/24         --           Link to ...
<Sysname> display ip interface gigabitethernet brief description
GE1/0/1             up       up       5.5.5.1/24         --           Link to Cor
        eRouter
The interface is administratively shut down by using the shutdown command.
(s) : spoofing
Spoofing attribute of the interface. The link protocol state of the interface is up, but the link is temporarily established on demand or does not exist.
Interface name.
Physical
Physical state of the interface:
·     *down—The interface is administratively shut down by using the shutdown command.
·     down—The interface is administratively up but its physical state is down, possibly because of a connection or link failure.
·     up—Both the administrative and physical states of the interface are up.
Protocol
Link layer protocol state of the interface:
·     down—The protocol state of the interface is down.
·     down(l)—The protocol state of the interface is down (loopback).
·     up—The protocol state of the interface is up.
·     up(l)—The protocol state of the interface is up (loopback).
·     up(s)—The protocol state of the interface is up (spoofing).
IP address/Mask
IP address and mask length of the interface. If no IP address is configured, this field displays hyphens (--).
VPN instance
Name of the VPN instance to which the interface belongs.
This field displays a maximum of 12 characters. If the VPN instance name is longer than 12 characters, the first 9 characters are displayed, followed by an ellipsis (...).
If the interface does not belong to any VPN instance, this field displays hyphens (--).
Description of the interface.
This field displays a maximum of 13 characters. If the description is longer than 13 characters, the first 10 characters are displayed, followed by an ellipsis (...).
If no description is configured, this field displays hyphens (--).
ip address
ip address
Use ip address to assign an IP address to the interface.
Use undo ip address to remove the IP address from the interface.
ip address ip-address { mask-length | mask } [ sub ] [ float ]
undo ip address [ ip-address { mask-length | mask } [ sub ] ]
No IP address is assigned to an interface.
Interface view
context-admin
vsys-admin
ip-address: Specifies the IP address of the interface, in dotted decimal notation.
mask-length: Specifies the subnet mask length in the range of 1 to 31. For a loopback interface, the value range is 1 to 32.
mask: Specifies the subnet mask in dotted decimal notation.
sub: Assigns a secondary IP address to the interface.
float: Assigns a floating IP address to the interface, which is only used in RBM networking.
Use the command to assign a primary or secondary IP address to an interface.
An interface can have only one primary IP address. If you execute this command multiple times to specify different primary IP addresses, the most recent configuration takes effect. If the interface connects to multiple subnets, configure primary and secondary IP addresses on the interface so the subnets can communicate with each other through the interface.
You cannot assign secondary IP addresses to an interface that obtains an IP address through BOOTP, DHCP, or IP unnumbered.
If you do not specify any parameters, the undo ip address command removes all IP addresses from the interface. The undo ip address ip-address { mask | mask-length } command removes the primary IP address. The undo ip address ip-address { mask | mask-length } sub command removes a secondary IP address.
The primary and secondary IP addresses assigned to the interface can be located on the same network segment. Different interfaces on your device must reside on different network segments.
You can configure floating IP addresses on RBM-based hot backup networks. The floating attribute simplifies the configuration of High Availability (HA). After you configure an floating IP address on the tenant-facing interface of the active device, the floating IP address is automatically synchronized to the standby device. You do not need to configure a Virtual Router Redundancy Protocol (VRRP) virtual address for the active device and the standby device separately. Floating IP address configuration is available only for the active device in active/standby mode. You canot configure, edit, or delete floating IP addresses on the standby devices. For more information about HA and RBM, see RBM-based hot backup configuration in High Availability Configuration Guide. For more information about VRRP, see VRRP configuration in High Availability Configuration Guide.
To cancel the floating attribute of an IP address, specify that IP address in the ip address command, and then execute this command without specifying the float keyword.
# Assign GigabitEthernet 1/0/1 a primary IP address 129.102.0.1 and a secondary IP address 202.38.160.1, with the subnet masks both 255.255.255.0.
[Sysname-GigabitEthernet1/0/1] ip address 129.102.0.1 255.255.255.0
[Sysname-GigabitEthernet1/0/1] ip address 202.38.160.1 255.255.255.0 sub
ip address unnumbered
Use ip address unnumbered to configure the current interface as IP unnumbered to borrow an IP address from the specified interface.
Use undo ip address unnumbered to restore the default.
The interface does not borrow IP addresses from other interfaces.
Interface view
context-admin
vsys-admin
interface interface-type interface-number: Specifies an interface from which the current interface can borrow an IP address.
Typically, you assign an IP address to an interface either manually or through DHCP. If the IP addresses are not enough, or the interface is used only occasionally, you can configure an interface to borrow an IP address from other interfaces. This is called IP unnumbered, and the interface borrowing the IP address is called IP unnumbered interface.
Loopback interfaces cannot borrow IP addresses of other interfaces, but other interfaces can borrow IP addresses of loopback interfaces.
Multiple interfaces can use the same unnumbered IP address. If an interface has multiple manually configured IP addresses, only the primary IP address manually configured can be borrowed.
You cannot enable a dynamic routing protocol on the interface that has no IP address configured. To enable the interface to communicate with other devices, you must configure a static route to the peer device on the interface.
# Configure GigabitEthernet 1/0/2 to borrow the IP address of GigabitEthernet 1/0/1.
[Sysname] interface GigabitEthernet1/0/2
[Sysname-GigabitEthernet1/0/2] ip address unnumbered interface gigabitethernet 1/0/1
