17-Network Management and Monitoring Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SecPath M9000 Command Reference(V7)(R9X71)-6W70117-Network Management and Monitoring Command Reference
18-Interface collaboration commands
18-Interface collaboration commands 97.66 KB
collaboration-group
Use collaboration-group to create a collaboration group and enter its view, or enter the view of an existing collaboration group.
Use undo collaboration-group to delete a collaboration group.
collaboration-group group-id
undo collaboration-group group-id
No collaboration groups exist.
context-admin
group-id: Specifies a collaboration group ID. The value range for this argument is 1 to 16.
Interface collaboration assigns different interfaces on a device to a collaboration group and associates the states of these interfaces. All member interfaces in a collaboration group can or cannot transmit packets.
You must remove all member interfaces from a collaboration group before deleting the collaboration group.
# Create collaboration group 1 and enter its view.
[Sysname] collaboration-group 1
[Sysname-collaboration-group1]
collaboration-group clean
Use collaboration-group clean to remove ineffective member interfaces from all collaboration groups.
context-admin
A member interface in a collaboration group becomes ineffective when the card that hosts the interface is removed or changed to another slot or the ID of the IRF member device that hosts the interface changes. This command prevents an ineffective interface from causing all other member interfaces in the same collaboration group to go down.
An ineffective interface cannot be automatically assigned to the original collaboration group when its hosting card is reinstalled or changed back to the original slot or the IRF member ID is changed back to the original ID. You must assign it to the original collaboration group manually.
# Remove ineffective member interfaces from all collaboration groups.
[Sysname] collaboration-group clean
display collaboration-group
Use display collaboration-group to display information about collaboration groups.
display collaboration-group { group-id | all } [ verbose ]
context-admin
context-operator
group-id: Specifies a collaboration group by its ID. The value range for this argument is 1 to 16.
all: Specifies all collaboration groups.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
# Display brief information about all collaboration groups.
<Sysname> display collaboration-group all
  Group ID                 Group status
  1                        DOWN
  2                        DOWN
# Display detailed information about all collaboration groups.
<Sysname> display collaboration-group all verbose
Collaboration group protocol status: Enabled
Collaboration group 1 information:
  Group status     : DOWN
  Member up delay  : 0 seconds
  Last up time     : 16:55:34 2017/04/05
  Last down time   : 16:57:22 2017/04/05
  Member                    Status
  GE1/0/1                   DOWN
  GE1/0/2                   Collaboration-down
Group status
Collaboration group status:
·     DOWN.
·     UP.
·     N/A—Monitor Link is disabled globally. The collaboration group does not take effect.
·     UP-Pending—The collaboration group is transitioning from DOWN to UP. It takes 10 seconds for the system to determine the collaboration group state (DOWN or UP).
Whether interface collaboration is enabled globally:
·     Enabled.
·     Disabled.
Member up delay
Delay time for the member interfaces in the collaboration group to come up after a device restart, in seconds.
Last up time
Last time when the collaboration group came up.
Last down time
Last time when the collaboration group went down.
Member
Member interfaces of the collaboration group.
Status
Member interface status:
·     UP—The interface is up.
·     DOWN—The interface is down. To identify cause, use the display interface command.
·     Collaboration-down—The interface is shut down by interface collaboration.
·     Not available—The interface is ineffective because the hosting card is not in position.
port
Use port to assign an interface to a collaboration group.
Use undo port to remove an interface from a collaboration group.
port interface-type interface-number
undo port interface-type interface-number
No member interfaces exist in a collaboration group.
Collaboration group view
context-admin
You can assign an interface to only one collaboration group.
For a collaboration group to work correctly, do not assign its member interfaces to a redundancy group.
Do not add both Selected ports and Unselected ports in a dynamic aggregation group to the same collaboration group.
You can also assign an interface to a collaboration group by using the port collaboration-group command in interface view.
# Assign GigabitEthernet 1/0/1 to collaboration group 1.
[Sysname-collaboration-group1] port gigabitethernet 1/0/1
Use port collaboration-group to assign the current interface to a collaboration group.
Use undo port collaboration-group to remove the current interface from a collaboration group.
port collaboration-group group-id
The interface is not a collaboration group member.
context-admin
To assign an interface to a collaboration group by using this command, make sure the collaboration group have been created.
You can also assign an interface to a collaboration group by using the port command in collaboration group view.
[Sysname-collaboration-group1] quit
[Sysname-GigabitEthernet1/0/1] port collaboration-group 1
port
up-delay
Use up-delay to set the delay time for the member interfaces in a collaboration group to come up after a device restart.
Use undo up-delay to restore the default.
up-delay delay
undo up-delay
The delay time is 0 seconds. The member interfaces come up as soon as the device restarts.
context-admin
delay: Specifies the delay time in the range of 1 to 3600 seconds.
This command enables the member interfaces to come up after a configurable delay time upon a device restart.
# Set the delay time to 10 seconds for the member interfaces in collaboration group 1.
[Sysname-collaboration-group1] up-delay 10
