- 10-Network Management and Monitoring Configuration Guide
- 02-NQA configuration
- 03-NTP configuration
- 04-PoE configuration
- 05-SNMP configuration
- 06-RMON configuration
- 07-NETCONF configuration
- 08-Ansible configuration
- 09-SmartMC configuration
- 10-EPA configuration
- 11-CWMP configuration
- 12-EAA configuration
- 13-Process monitoring and maintenance configuration
- 14-Sampler configuration
- 15-Mirroring configuration
- 16-sFlow configuration
- 17-Information center configuration
- 18-Packet capture configuration
- 19-VCF fabric configuration
- 20-NetStream configuration
- 21-IPv6 NetStream configuration
- 22-Performance management configuration
- 23-Cloud connection configuration
- 24-eMDI configuration
- 25-TCP connection trace configuration
| 14-Sampler configuration | 42.89 KB |
Restrictions: Hardware compatibility with samplers
Display and maintenance commands for a sampler
Configuring samplers
About sampler
A sampler selects a packet from sequential packets and sends the packet to other service modules for processing. Sampling is useful when you want to limit the volume of traffic to be analyzed. The sampled data is statistically accurate and sampling decreases the impact on the forwarding capacity of the device.
The device supports random sampling mode.
In random sampling mode, any packet might be selected from sequential packets in each sampling.
Samplers are supported only on the S5130S-HI-G switch series.
Creating a sampler
1. Enter system view.
2. Create a sampler.
sampler sampler-name mode random packet-interval n-power rate
By default, no samplers exist.
Task |
Command |
Display configuration information about the sampler. |
display sampler [ sampler-name ] [ slot slot-number ] |
