- 04-Layer 3—IP Services Command Reference
- 01-ARP commands
- 02-IP addressing commands
- 03-DHCP commands
- 04-DNS commands
- 05-IP forwarding basics commands
- 06-Fast forwarding commands
- 07-Adjacency table commands
- 08-IRDP commands
- 09-IP performance optimization commands
- 10-UDP helper commands
- 11-IPv6 basics commands
- 12-DHCPv6 commands
- 13-IPv6 fast forwarding commands
- 14-Tunneling commands
- 15-HTTP redirect commands
| 01-ARP commands | 251.42 KB |
arp mac-interface-consistency check enable
arp timer aging probe-interval
arp user-ip-conflict record enable
display arp user-ip-conflict record
gratuitous-arp mac-change retransmit
gratuitous-arp-learning enable
ARP direct route advertisement commands
display arp route-direct advertise
ARP commands
arp check enable
Use arp check enable to enable dynamic ARP entry check.
Use undo arp check enable to disable dynamic ARP entry check.
arp check enable
Dynamic ARP entry check is enabled.
Dynamic ARP entry check disables a device from supporting dynamic ARP entries with multicast MAC addresses. The device cannot learn dynamic ARP entries containing multicast MAC addresses. You cannot manually add static ARP entries that contain multicast MAC addresses.
When dynamic ARP entry check is disabled, ARP entries containing multicast MAC addresses are supported. The device can learn dynamic ARP entries containing multicast MAC addresses obtained from the ARP packets sourced from a unicast MAC address. You can also manually add static ARP entries containing multicast MAC addresses.
# Enable dynamic ARP entry check.
[Sysname] arp check enable
arp check log enable
Use arp check log enable to enable the ARP logging feature.
Use undo arp check log enable to disable the ARP logging feature.
ARP logging is disabled.
This feature enables a device to log ARP events when ARP cannot resolve IP addresses correctly. The log information helps administrators locate and solve problems. The device can log the following ARP events:
· On a proxy ARP-disabled interface, the target IP address of a received ARP packet is not one of the following IP addresses:
¡ The IP address of the receiving interface.
¡ The virtual IP address of the VRRP group.
· The sender IP address of a received ARP reply conflicts with one of the following IP addresses:
The device sends ARP log messages to the information center. You can use the info-center source command to specify the log output rules for the information center. For more information about information center, see Network Management and Monitoring Configuration Guide.
The device can generate a large number of ARP logs. To conserve system resources, enable ARP logging only when you are auditing or troubleshooting ARP events.
# Enable ARP logging.
[Sysname] arp check log enable
Use arp mac-interface-consistency check enable to enable interface consistency check between ARP and MAC address entries.
Use undo arp mac-interface-consistency check enable to disable interface consistency check between ARP and MAC address entries.
Interface consistency check between ARP and MAC address entries is disabled.
In an unstable network, the receiving interface for packets from a user might change. The interface in the MAC address entry can be updated immediately while the interface in the ARP entry cannot. In this case, the packets matching the ARP entry will be sent out of an incorrect interface. To solve this problem, you can use this feature to periodically check the interface consistency between the ARP and MAC address entry for a user. If the interfaces are not the same, ARP sends ARP requests in the VLAN of the ARP entry and updates the entry with the ARP reply receiving interface.
Use the display mac-address command to display MAC address entries.
# Enable interface consistency check between ARP and MAC address entries.
[Sysname] arp mac-interface-consistency check enable
display mac-address (Layer 2—LAN Switching Command Reference)
arp max-learning-num
Use arp max-learning-num to set the dynamic ARP learning limit for an interface.
Use undo arp max-learning-num to restore the default.
arp max-learning-num max-number [ alarm alarm-threshold ]
For the S5570S-EI switch series, an interface can learn a maximum of 8192 dynamic ARP entries. For the S5500V3-SI switch series, an interface can learn a maximum of 4096 dynamic ARP entries.
VLAN interface view
max-number: Specifies the maximum number of dynamic ARP entries for an interface. For the S5570S-EI switch series, the value range is 0 to 8192. For the S5500V3-SI switch series, the value range is 0 to 4096
alarm alarm-threshold: Specifies an alarm threshold for dynamic ARP learning, in percentage. The value range for the alarm-threshold argument is 1 to 100. The device generates a log message when the number of dynamic ARP entries learned on an interface reaches the value calculated by using the formula: (max-number × alarm-threshold)/100. If you do not specify the alarm threshold, the device does not generate log messages.
An interface can dynamically learn ARP entries. To prevent an interface from holding too many ARP entries, you can set the maximum number of dynamic ARP entries that the interface can learn. When the maximum number is reached, the interface stops learning ARP entries.
When the number argument is set to 0, the interface is disabled from learning dynamic ARP entries.
# Specify VLAN-interface 40 to learn a maximum of 10 dynamic ARP entries.
[Sysname] interface vlan-interface 40
[Sysname-Vlan-interface40] arp max-learning-num 10
# Specify GigabitEthernet 1/0/1 to learn a maximum of 10 dynamic ARP entries.
[Sysname-GigabitEthernet1/0/1] arp max-learning-num 10
# Specify Layer 2 aggregate interface Bridge-Aggregation 1 to learn a maximum of 10 dynamic ARP entries.
[Sysname-Bridge-Aggregation1] arp max-learning-num 10
# Specify Layer 3 aggregate interface Route-Aggregation 1 to learn a maximum of 10 dynamic ARP entries.
[Sysname-Route-Aggregation1] arp max-learning-num 10
arp max-learning-number
Use arp max-learning-number to set the dynamic ARP learning limit for a device.
Use undo arp max-learning-number to restore the default.
arp max-learning-number max-number slot slot-number
undo arp max-learning-number slot slot-number
For the S5570S-EI switch series, a device can learn a maximum of 8192 dynamic ARP entries.
For the S5500V3-SI switch series, a device can learn a maximum of 4096 dynamic ARP entries.
max-number: Specifies the maximum number of dynamic ARP entries for a device. For the S5570S-EI switch series, the value range is 0 to 8192. For the S5500V3-SI switch series, the value range is 0 to 4096.
slot slot-number: Specifies an IRF member device by its member ID.
A device can dynamically learn ARP entries. To prevent a device from holding too many ARP entries, you can set the maximum number of dynamic ARP entries that the device can learn. When the maximum number is reached, the device stops learning ARP entries.
When the number argument is set to 0, the device is disabled from learning dynamic ARP entries.
# Set the ARP learning limit to 64 for slot 1.
[Sysname] arp max-learning-number 64 slot 1
arp static
Use arp static to configure a static ARP entry.
Use undo arp to delete an ARP entry.
arp static ip-address mac-address [ vlan-id interface-type interface-number ] [ vpn-instance vpn-instance-name ] [ description text ]
undo arp ip-address [ vpn-instance-name ]
No static ARP entries exist.
ip-address: Specifies an IP address for the static ARP entry.
mac-address: Specifies a MAC address for the static ARP entry, in the format of H-H-H.
vlan-id: Specifies the ID of a VLAN to which the static ARP entry belongs. The value range is 1 to 4094.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the static ARP entry belongs. The vpn-instance-name argument represents the VPN instance name, a case-sensitive string of 1 to 31 characters. The VPN instance must already exist. To specify a static ARP entry on the public network, do not specify this option.
description text: Specifies the description for the static ARP entry, a case-sensitive string of 1 to 255 characters.
A static ARP entry is manually configured and maintained. It does not age out and cannot be overwritten by any dynamic ARP entry.
Static ARP entries can be short or long.
A resolved short static ARP entry becomes unresolved upon certain events, for example, when the resolved output interface goes down, or the corresponding VLAN or VLAN interface is deleted.
Long static ARP entries are effective or ineffective. Ineffective long static ARP entries cannot be used for packet forwarding. A long static ARP entry is ineffective when any of the following conditions exists:
· The IP address in the entry conflicts with a local IP address.
· No local interface has an IP address in the same subnet as the IP address in the ARP entry.
If you specify the vlan-id interface-type interface-number argument, follow these restrictions and guidelines:
· The interface can be an Ethernet interface or an aggregate interface.
· The VLAN and VLAN interface must already exist. The specified Ethernet interface must belong to the specified VLAN.
· The IP address of the VLAN interface and the IP address specified by the ip-address argument must be on the same network.
· A long static ARP entry for a VLAN is deleted if the VLAN or VLAN interface is deleted.
For easy identification of static ARP entries, you can configure a description for each static ARP entry.
# Configure a long static ARP entry that contains IP address 202.38.10.2, MAC address 00e0-fc01-0000, and output interface GigabitEthernet 1/0/1 in VLAN 10.
[Sysname] arp static 202.38.10.2 00e0-fc01-0000 10 gigabitethernet 1/0/1
display arp
reset arp
arp timer aging
Use arp timer aging to set the aging timer for dynamic ARP entries.
Use undo arp timer aging to restore the default.
arp timer aging { aging-minutes | second aging-seconds }
In system view, the aging timer for dynamic ARP entries is 20 minutes.
In interface view, the aging timer for dynamic ARP entries is the aging timer set in system view.
VLAN interface view
aging-minutes: Specifies the aging timer in minutes. The value range for this argument is 1 to 1440.
second aging-seconds: Specifies the aging timer in seconds. The value range for the aging-seconds argument is 5 to 86400.
Each dynamic ARP entry in the ARP table has a limited lifetime, called an aging timer. The aging timer of a dynamic ARP entry is reset each time the dynamic ARP entry is updated. Dynamic ARP entries that are not updated before their aging timers expire are deleted from the ARP table.
You can set the aging timer for dynamic ARP entries in system view or in interface view. The aging timer set in interface view takes precedence over the aging timer set in system view.
Set the aging timer for dynamic ARP entries as needed. For example, when you configure proxy ARP, set a short aging time so that invalid dynamic ARP entries can be deleted in a timely manner.
# Set the aging timer for dynamic ARP entries to 10 minutes.
# Set the aging timer for dynamic ARP entries to 200 seconds.
[Sysname] arp timer aging second 200
# Set the aging timer for dynamic ARP entries to 200 seconds on VLAN-interface 2.
[Sysname-Vlan-interface2] arp timer aging second 200
arp timer aging probe-count
display arp timer aging
Use arp timer aging probe-count to set the maximum number of probes for dynamic ARP entries.
Use undo arp timer aging probe-count to restore the default.
arp timer aging probe-count count
In system view, the maximum number of probes is three for dynamic ARP entries.
In interface view, the maximum number of probes for dynamic ARP entries is the maximum probe count set in system view.
VLAN interface view
count: Specifies the maximum number of probes. The value range for this argument is 0 to 10. To disable the device from probing dynamic ARP entries, set the value to 0.
This probe mechanism keeps legal dynamic ARP entries valid and avoids unnecessary ARP resolution during later traffic forwarding. This probe feature sends ARP requests for the IP address in a dynamic ARP entry.
· If the device receives an ARP reply before the entry aging timer expires, the device resets the aging timer.
· If the device does not receive any ARP reply after the maximum number of probes is made, the device deletes the entry when the entry aging timer expires.
You can set the maximum number of probes in system view and in interface view. The probe count set in interface view takes precedence over the probe count set in system view.
# Allow the device to perform a maximum of five probes for dynamic ARP entries.
[Sysname] arp timer aging probe-count 5
# Allow the device to perform a maximum of five probes for dynamic ARP entries on VLAN-interface 2.
[Sysname-Vlan-interface2] arp timer aging probe-count 5
arp timer aging
Use arp timer aging probe-interval to set the interval for probing dynamic ARP entries.
Use undo arp timer aging probe-interval to restore the default.
arp timer aging probe-interval interval
In system view, the probe interval is 5 seconds.
In interface view, the probe interval equals the setting in system view.
VLAN interface view
Interval: Specifies the probe interval in seconds. The value rang is 1 to 60.
The probing feature keeps legal dynamic ARP entries valid and avoids unnecessary ARP resolution during later traffic forwarding.
Before a dynamic ARP entry is aged out, the device sends ARP requests for the IP address in the ARP entry.
· If the device receives an ARP reply during the probe interval, the device resets the aging timer.
· If the device does not receive any ARP reply during the probe interval, the device starts a new probe.
· If the maximum number probes are made, and still no ARP reply is received, the device deletes the entry.
You can set the probe interval in system view and in interface view. The probe interval in interface view takes precedence over the probe interval in system view.
# Set the probe interval to 10 seconds for dynamic ARP entries.
[Sysname] arp timer aging probe-interval 10
# Set the probe interval to 10 seconds for dynamic ARP entries on VLAN-interface 2.
[Sysname-Vlan-interface2] arp timer aging probe-interval 10
arp timer aging
Use arp user-ip-conflict record enable to enable recording user IP address conflicts.
Use undo arp user-ip-conflict record enable to disable recording user IP address conflicts.
NOTE: This command is only supported in Release 1122 and later. |
Recording user IP address conflicts is disabled.
This feature enables the device to detect and record user IP address conflicts. The device determines that a conflict occurs if an incoming ARP packet has the same sender IP address as an existing ARP entry but a different sender MAC address. The device generates a user IP address conflict record, logs the conflict, and sends the log to the information center. For information about the log destination and output rule configuration, see the information center in Network Management and Monitoring Configuration Guide.
An IRF member device can generate a maximum of 10 user IP address conflict logs per second.
To display user IP address conflict records, use the display arp user-ip-conflict record command.
# Enable recording user IP address conflicts.
[Sysname] arp user-ip-conflict record enable
arp user-move record enable
Use user-move record enable to enable recording user port migrations.
Use undo arp user-move record enable to disable recording user port migrations.
Recording user port migrations is disabled.
Each IRF member device can generate a maximum of 10 user port migration logs per second.
To display user port migration records, use the display arp user-move record command.
# Enable recording user port migration.
[Sysname] arp user-move record enable
display arp
Use display arp to display ARP entries.
display arp [ [ all | dynamic | static ] [ slot slot-number ] | vlan vlan-id | interface interface-type interface-number ] [ count | verbose ]
all: Displays all ARP entries.
dynamic: Displays dynamic ARP entries.
static: Displays static ARP entries.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays ARP entries for the master device.
vlan vlan-id: Specifies a VLAN by its VLAN ID. The VLAN ID is in the range of 1 to 4094.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays ARP entries for all interfaces.
count: Displays the number of ARP entries.
verbose: Displays detailed information about ARP entries.
This command displays information about ARP entries, including the IP address, MAC address, VLAN ID, output interface, entry type, and aging timer.
# Display all ARP entries.
Type: S-Static D-Dynamic O-Openflow R-Rule I-Invalid
IP address MAC address VLAN/VSI name Interface Aging Type
192.168.1.8 02e0-f102-0023 40 GE1/0/23 792 D
192.168.1.16 00e0-fc00-0001 40 GE1/0/23 1148 D
192.168.1.24 00e0-fe50-6503 40 GE1/0/23 359 D
192.168.1.28 00e0-fe60-5000 40 GE1/0/23 963 D
# Display detailed information about all ARP entries.
IP address : 1.1.1.1 MAC address : 02e0-f102-0023
Type : Static Aging : --
Interface : GE1/0/1 VLAN : 1
VPN instance : --
Link ID : --
Service instance : 1
VXLAN ID : --
VSI name : --
VSI interface : --
Nickname : --
Description : User1
IP address : 1.1.1.2 MAC address : 0015-e944-adc5
Type : Dynamic Aging : 960 sec
Interface : GE1/0/2 VLAN : 12
VPN instance : --
Link ID : --
Service instance : --
VXLAN ID : --
VSI name : --
VSI interface : --
Nickname : --
Description : --
# Display the number of all ARP entries.
<Sysname> display arp all count
Total number of entries : 4
IP address |
IP address in an ARP entry. |
MAC address |
MAC address in an ARP entry. |
VLAN/VSI name |
ID of the VLAN to which the ARP entry belongs. This field displays hyphens (--) in either of the following situations: · The ARP entry is an unresolved short static ARP entry. · The output interface of the ARP entry does not belong to the VLAN. |
Output interface in an ARP entry. This field displays hyphens (--) in either of the following situations: · The ARP entry is an unresolved short static ARP entry. · The ARP entry is a multiport ARP entry and has
no output interface information. |
Link ID |
This field is not supported in the current software version. Link ID in an ARP entry. This field displays hyphens (--) if the ARP entry does not belong to any VSI. |
Aging |
Aging time for an ARP entry in seconds. For a static ARP entry, this field always displays hyphens (--). The static ARP entry never ages out unless you delete it manually. For a dynamic ARP entry, this field displays hyphens (--) if the aging time is unknown. |
Type |
OpenFlow is not supported in the current software version. ARP entry type: · D—Dynamic. · S—Static. · O—OpenFlow. · R—Rule. · I—Invalid. |
VPN instance |
Name of VPN instance. If no VPN instance is configured for the ARP entry, this field displays hyphens (--). |
Service instance |
Ethernet service instance in an ARP entry. This field displays hyphens (--) if no Ethernet service instance is specified for the Layer 2 Ethernet interface or Layer 2 aggregate interface in the ARP entry. |
VXLAN ID |
This field is not supported in the current software version. ID of the VXLAN to which the ARP entry belongs. VXLAN ID is also called VNI. If the ARP entry does not belong to any VXLAN, this field displays hyphens (--). |
VSI name |
This field is not supported in the current software version. Name of the VSI to which the ARP entry belongs. If the ARP entry does not belong to any VSI, this field displays hyphens (--). |
VSI interface |
This field is not supported in the current software version. Name of the gateway interface of the VSI. If no gateway interface is specified for the VSI, this field displays hyphens (--). |
Nickname |
This field is not supported in the current software version. Nickname of the ARP entry. The nickname is a string of four hexadecimal numbers, for example, 012a. |
Description of the ARP entry. If no description is configured for the ARP entry, this field displays hyphens (--). |
Total number of entries |
Number of ARP entries. |
arp static
reset arp
display arp entry-limit
Use display arp entry-limit to display the maximum number of ARP entries that a device supports.
# Display the maximum number of ARP entries that the device supports.
<Sysname> display arp entry-limit
ARP entries: 8092
display arp ip-address
Use display arp ip-address to display the ARP entry for an IP address.
display arp ip-address [ slot slot-number ] [ verbose ]
ip-address: Displays the ARP entry for the specified IP address.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information for the master device.
verbose: Displays the detailed information about the specified ARP entry.
The ARP entry information includes the IP address, MAC address, VLAN ID, output interface, entry type, and aging timer.
# Display the ARP entry for the IP address 20.1.1.1.
<Sysname> display arp 20.1.1.1
192.168.1.8 00e0-fc00-0001 40 GE1/0/23 562 D
arp static
reset arp
Use display arp timer aging to display the aging timer of dynamic ARP entries.
This command always displays the aging time in seconds no matter which unit you set in the arp timer aging command.
# Display the aging timer of dynamic ARP entries.
<Sysname> display arp timer aging
Current ARP aging time is 1200 seconds
arp timer aging
display arp usage
Use display arp usage to display the ARP table usage.
display arp usage
This command displays the maximum number of ARP entries supported on the device in addition to the history ARP table usage. You can use this command to monitor the number of ARP entries on the device and to determine whether ARP flood attacks exist on the network.
The device can display the ARP table usage only in the most recent hour.
# Display the ARP table usage.
<Sysname> display arp usage
ARP table upper limit: 8092
Time ARP entry count Usage
Current 45 1%
1 min ago 45 1%
2 min ago 45 1%
3 min ago 45 1%
59 min ago 45 1%
60 min ago 45 1%
ARP table upper limit |
Maximum number of ARP entries supported on the device. |
Time |
Time when the number of ARP entries were counted. This field displays Current if the number of ARP entries were counted just now. |
ARP entry count |
Usage |
ARP table usage, which is the ratio of the real-time ARP entry count to the ARP table upper limit. |
Use display arp user-ip-conflict record to display user IP address conflict records.
display arp user-ip-conflict record [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays user IP address conflict records for the master device.
Each IRF member device can save a maximum of 200 user IP address conflict records.
If the maximum number is reached, a new record will override the earliest record.
# Display all user IP address conflict records.
<Sysname> display arp user-ip-conflict record
IP address: 10.1.1.1
System time: 2018-02-02 11:22:29
Conflict count: 1
Log suppress count: 0
Old interface: GigabitEthernet1/0/1
New interface: GigabitEthernet1/0/2
Old SVLAN/CVLAN: 100/2
New SVLAN/CVLAN: 100/2
Old MAC: 00e0-ca63-8141
New MAC: 00e0-ca63-8142
IP address: 10.1.1.2
System time: 2018-02-02 10:20:30
Conflict count: 1
Old SVLAN/CVLAN: 100/--
New SVLAN/CVLAN: 100/--
IP address |
IP address of a user. |
System time |
Time when the user IP address conflict occurred. |
Conflict count |
Number of times that conflicts for the IP address. |
Log suppress count |
Number of times that user IP address conflict logs are suppressed. |
Old interface |
Output interface in the old ARP entry. |
New interface |
Output interface in the new ARP entry. |
Old SVLAN/CVLAN |
ID of the outer VLAN or inner VLAN in the old ARP entry. This field displays hyphens (--) if the ARP entry does not belong to any outer VLAN or inner VLAN. |
New SVLAN/CVLAN |
ID of the outer VLAN or inner VLAN in the new ARP entry. This field displays hyphens (--) if the ARP entry does not belong to any outer VLAN or inner VLAN. |
Old MAC |
MAC address in the old ARP entry. |
New MAC |
MAC address in the new ARP entry. |
Use display arp user-move record to display user port migration records.
display arp user-move record [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays user port migration records for the master device.
Each IRF member device can save a maximum of 200 user port migration records.
When the number of user port migration records reaches the upper limit, new records will overwrite the earliest ones.
# Display all user port migration records.
<Sysname> display arp user-move record
MAC address: 0001-0201-0e81
Move count: 1
Before:
SVLAN/CVLAN: 100/2
After:
SVLAN/CVLAN: 100/2
MAC address: 0001-0201-0e82
Move count: 1
Before:
SVLAN/CVLAN: 100/--
After:
SVLAN/CVLAN: 100/--
IP address |
IP address of the user. |
MAC address |
MAC address of the user. |
System time |
Time when the user port migration occurred. |
Move count |
Number of times that user port migrated. |
Number of times that the generation of user port migration logs is suppressed. |
Output interface in the ARP entry. |
SVLAN/CVLAN |
ID of the outer VLAN or inner VLAN in the ARP entry. This field displays hyphens (--) if the ARP entry does not belong to any outer VLAN or inner VLAN. |
display arp vpn-instance
Use display arp vpn-instance to display the ARP entries for a VPN instance.
display arp vpn-instance vpn-instance-name [ count | verbose ]
vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. The VPN instance name cannot contain any spaces.
This command displays information about ARP entries for a VPN instance, including the IP address, MAC address, VLAN ID, output interface, entry type, and aging timer.
# Display ARP entries for VPN instance test.
<Sysname> display arp vpn-instance test
20.1.1.1 00e0-fc00-0001 -- -- -- S
arp static
reset arp
reset arp
Use reset arp to clear ARP entries from the ARP table.
reset arp { all | dynamic | interface interface-type interface-number | slot slot-number | static }
all: Clears all ARP entries.
dynamic: Clears all dynamic ARP entries.
static: Clears all static ARP entries.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears ARP entries for the master device.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command clears ARP entries for all interfaces.
CAUTION: The reset arp command clears existing ARP entries on the device. It might cause external traffic unable to quickly reach the LAN users. |
# Clear all static ARP entries.
<Sysname> reset arp static
arp static
display arp
Gratuitous ARP commands
arp ip-conflict log prompt
Use arp ip-conflict log prompt to enable IP conflict notification.
Use undo arp ip-conflict log prompt to restore the default.
IP conflict notification is disabled.
By default, the device performs the following operations if it is using the sender IP address of a received ARP packet:
· Sends a gratuitous ARP request.
· Displays an error message after the device receives an ARP reply about the conflict.
You can use this command to enable the device to display error messages before sending a gratuitous ARP reply or request for conflict confirmation.
# Enable IP conflict notification on the device.
[Sysname] arp ip-conflict log prompt
arp send-gratuitous-arp
Use arp send-gratuitous-arp to enable periodic sending of gratuitous ARP packets on an interface.
Use undo arp send-gratuitous-arp to disable the interface from periodically sending gratuitous ARP packets.
arp send-gratuitous-arp [ interval interval ]
Periodic sending of gratuitous ARP packets is disabled.
VLAN interface view
interval interval: Specifies the sending interval in the range of 200 to 200000 milliseconds. The default value is 2000 milliseconds.
This feature takes effect on an interface only when the interface has an IP address and the data link layer state of the interface is up.
This feature can send gratuitous ARP requests only for a VRRP virtual IP address, or the sending interface's primary IP address or manually configured secondary IP address. The primary IP address can be configured manually or automatically, whereas the secondary IP address must be configured manually.
If you change the sending interval for gratuitous ARP packets, the configuration takes effect at the next sending interval.
The sending interval for gratuitous ARP packets might be much longer than the set interval when any of the following conditions exist:
· This feature is enabled on multiple interfaces.
· Each interface is configured with multiple secondary IP addresses.
· A small sending interval is configured in the preceding cases.
# Enable VLAN-interface 2 to send gratuitous ARP packets every 300 milliseconds.
[Sysname-Vlan-interface2] arp send-gratuitous-arp interval 300
Use gratuitous-arp mac-change retransmit to set the times and the interval for retransmitting a gratuitous ARP packet for the device MAC address change.
Use undo gratuitous-arp mac-change retransmit to restore the default.
gratuitous-arp mac-change retransmit times interval seconds
The device sends a gratuitous packet for its MAC address change once only.
times: Specifies the times of retransmitting a gratuitous packet, in the range of 1 to 10.
interval seconds: Specifies the interval for retransmitting a gratuitous packet, in the range of 1 to 10 seconds.
The device sends a gratuitous ARP packet to inform other devices of its MAC address change. However, the other devices might fail to receive the packet because the device sends the gratuitous ARP packet once only by default. Use this command to configure gratuitous ARP retransmission parameters to ensure that the other devices can receive the packet.
After you execute this command, the device will retransmit a gratuitous ARP packet for its MAC address change at the specified interval for the specified times.
# Set the times to 3 and the interval to 5 for retransmitting a gratuitous ARP packet for the device MAC address change.
[Sysname] gratuitous-arp mac-change retransmit 3 interval 5
Use gratuitous-arp-learning enable to enable learning of gratuitous ARP packets.
Use undo gratuitous-arp-learning enable to disable learning of gratuitous ARP packets.
Learning of gratuitous ARP packets is enabled.
The learning of gratuitous ARP packets feature allows a device to maintain its ARP table by creating or updating ARP entries based on received gratuitous ARP packets.
When this feature is disabled, the device uses received gratuitous ARP packets to update existing ARP entries only. ARP entries are not created based on the received gratuitous ARP packets, which saves ARP table space.
# Enable learning of gratuitous ARP packets.
[Sysname] gratuitous-arp-learning enable
gratuitous-arp-sending enable
Use gratuitous-arp-sending enable to enable sending gratuitous ARP packets upon receiving ARP requests whose sender IP address is on a different subnet.
Use undo gratuitous-arp-sending enable to disable sending gratuitous ARP packets upon receiving ARP requests whose sender IP address is on a different subnet.
A device does not send gratuitous ARP packets when it receives ARP requests whose sender IP address is on a different subnet.
# Disable a device from sending gratuitous ARP packets upon receiving ARP requests whose sender IP address is on a different subnet.
[Sysname] undo gratuitous-arp-sending enable
Proxy ARP commands
display local-proxy-arp
Use display local-proxy-arp to display the local proxy ARP status.
display local-proxy-arp [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the local proxy ARP status for all interfaces.
You can use this command to check whether local proxy ARP is enabled or disabled.
# Display the local proxy ARP status for VLAN-interface 2.
<Sysname> display local-proxy-arp interface vlan-interface 2
Interface Vlan-interface2
Local Proxy ARP status: enabled
local-proxy-arp enable
display proxy-arp
Use display proxy-arp to display the proxy ARP status.
display proxy-arp [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the proxy ARP status for all interfaces.
You can use this command to check whether proxy ARP is enabled or disabled.
# Display the proxy ARP status on VLAN-interface 2.
<Sysname> display proxy-arp interface vlan-interface 2
Proxy ARP status: disabled
proxy-arp enable
display proxy-arp statistics
Use display proxy-arp statistics to display statistics about proxy ARP reply packets.
This command displays the proxy ARP reply statistics within the most recent minute on a per-second basis and displays the statistics one minute ago on a five-minute basis. The device can display the proxy ARP reply statistics in the most recent hour.
# Display proxy ARP reply statistics.
<Sysname> display proxy-arp statistics
Last 1 sec proxy count: 200
Last 2 sec proxy count: 400
Last 1 min proxy count: 12000
Last 5 min proxy count: 18000
Last 10 min proxy count: 24000
Last 60 min proxy count: 182445
Table 5 Command output
Last n sec proxy count: |
Number of proxy ARP reply packets within the most recent nth second. |
Last n min proxy count: |
Number of proxy ARP reply packets within the most recent nth minute. |
Use local-proxy-arp enable to enable local proxy ARP.
Use undo local-proxy-arp enable to disable local proxy ARP.
local-proxy-arp enable [ ip-range start-ip-address to end-ip-address ]
Local proxy ARP is disabled.
VLAN interface view
ip-range start-ip-address to end-ip-address: Specifies the IP address range for which local proxy ARP is enabled. The start IP address must be lower than or equal to the end IP address.
Proxy ARP enables a device on a network to answer ARP requests for an IP address not on that network. With proxy ARP, hosts in different broadcast domains can communicate with each other as they do on the same network.
Proxy ARP includes common proxy ARP and local proxy ARP.
Common proxy ARP allows communication between hosts that connect to different Layer 3 interfaces and reside in different broadcast domains.
Local proxy ARP allows communication between hosts that connect to the same Layer 3 interface and reside in different broadcast domains.
# Enable local proxy ARP on VLAN-interface 2.
[Sysname-Vlan-interface2] local-proxy-arp enable
# Enable local proxy ARP on VLAN-interface 2 for an IP address range.
[Sysname-Vlan-interface2] local-proxy-arp enable ip-range 1.1.1.1 to 1.1.1.20
proxy-arp enable
Use proxy-arp enable to enable proxy ARP.
Use undo proxy-arp enable to disable proxy ARP.
proxy-arp enable
Proxy ARP is disabled.
VLAN interface view
# Enable proxy ARP on VLAN-interface 2.
[Sysname-Vlan-interface2] proxy-arp enable
display proxy-arp
ARP snooping commands
arp snooping enable
Use arp snooping enable to enable ARP snooping.
Use undo arp snooping enable to disable ARP snooping.
arp snooping enable
ARP snooping is disabled.
VLAN view
# Enable ARP snooping for VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] arp snooping enable
arp snooping uplink
Use arp snooping uplink to configure an interface as an uplink interface to disable it from learning ARP snooping entries.
Use undo arp snooping uplink to restore the default.
NOTE: This command is only supported in Release 1125 and later. |
arp snooping uplink
An interface is not an uplink interface for ARP snooping. After you enable ARP snooping, the interface learns ARP snooping entries.
After you enable ARP snooping on an access device by using the arp snooping enable command, the access device will generate ARP snooping entries by listening to ARP packets. On a network where the aggregate device acts as the gateway, if you enable local proxy ARP on the gateway by using the local-proxy-arp enable command, the uplink interface of the access device will also learn ARP snooping entries. As a result, the input interface of an ARP snooping entry flaps between the uplink and downlink interfaces. To avoid such an issue, you can configure this feature on the access device.
After you configure this feature on an access device enabled with ARP snooping, the uplink interface no longer learns ARP snooping entries from incoming ARP packets.
# Configure Layer 2 Ethernet interface GigabitEthernet 1/0/1 as an uplink interface to disable it from learning ARP snooping entries.
[Sysname-GigabitEthernet1/0/1] arp snooping uplink
# Configure Layer 2 aggregate interface Bridge-Aggregation 1 as an uplink interface to disable it from learning ARP snooping entries.
[Sysname-Bridge-Aggregation1] arp snooping uplink
display arp snooping
Use display arp snooping to display ARP snooping entries.
display arp snooping vlan [ vlan-id ] [ slot slot-number ] [ count ]
display arp snooping vlan ip ip-address [ slot slot-number ]
vlan: Displays ARP snooping entries for a VLAN.
vlan-id: Specifies a VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays ARP snooping entries for all VLANs.
count: Displays the number of the ARP snooping entries. If you do not specify this keyword, the command displays ARP snooping entries.
ip ip-address: Displays the ARP snooping entry for the specified IP address in VLANs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays ARP snooping entries for the master device.
# Display ARP snooping entries for VLAN 2.
<Sysname> display arp snooping vlan 2
IP Address MAC Address VLAN ID Interface Aging Status
3.3.3.3 0003-0003-0003 2 GE1/0/1 20 Valid
3.3.3.4 0004-0004-0004 2 GE1/0/2 5 Invalid
# Display the ARP snooping entry for IP address 1.1.1.1 in a VLAN.
<Sysname> display arp snooping vlan ip 1.1.1.1
IP address MAC address VLAN ID Interface Aging Status
1.1.1.1 001f-e201-0111 2 GE1/0/1 15 Valid
Table 6 Command output
IP Address |
IP address in an ARP snooping entry. |
MAC Address |
MAC address in an ARP snooping entry. |
VLAN ID |
ID of the VLAN to which the ARP snooping entry belongs. |
Input interface in an ARP snooping entry. |
Aging |
Aging time for an ARP snooping entry in minutes. If the member device learns an ARP snooping entry from another member device, the member device cannot learn the aging time of the entry, and this field displays N/A. |
Status |
Status of an ARP snooping entry: Valid, Invalid, Collision. |
reset arp snooping
reset arp snooping
Use reset arp snooping to delete ARP snooping entries.
reset arp snooping vlan [ vlan-id ]
reset arp snooping vlan ip ip-address
vlan: Deletes ARP snooping entries for a VLAN.
vlan-id: Specifies a VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command deletes ARP snooping entries for all VLANs.
ip ip-address: Deletes the ARP snooping entry for the specified IP address in VLANs.
# Delete ARP snooping entries for VLAN 2.
<Sysname> reset arp snooping vlan 2
Use arp route-direct advertise to enable ARP direct route advertisement.
Use undo arp route-direct advertise to disable ARP direct route advertisement.
arp route-direct advertise [ preference preference-value | tag tag-value ] *
ARP direct route advertisement is disabled.
Interface view
preference preference-value: Specifies the preference for the ARP-advertised direct routes. The value range for the preference-value argument is 1 to 255, and the default is 0. The smaller the value, the higher the preference.
tag tag-value: Specifies the route tag for the ARP-advertised direct routes. The value range for the tag-value argument is 1 to 4294967295, and the default is 0.
If ARP direct route advertisement is configured, ARP advertises ARP entries to the route management module to generate direct routes with an optional preference or route tag.
# Enable ARP direct route advertisement on VLAN-interface 10.
[Sysname-Vlan-interface10] arp route-direct advertise
Use display arp route-direct advertise to display information about ARP direct route advertisement.
display arp route-direct advertise interface interface-type interface-number
interface interface-type interface-number: Specifies an interface by its type and number. Make sure you specify the interface where ARP direct route advertisement is enabled.
When ARP direct route advertisement is enabled, the device generates direct routes based on ARP entries for packet forwarding and route advertisement. You can use this command to check whether the route management module has generated direct routes for ARP entries.
If the Route field displays Unknown, it indicates that the route management module is busy and the ARP module is not aware that whether a direct route is generated for the entry. As a best practice, execute this command later.
# Display ARP-advertised direct route information on VLAN-interface 10.
<Sysname> display arp route-direct advertise interface vlan-interface 10
IP address MAC address VLAN/VSI Interface Route
1.1.1.1 02e0-f102-0023 1 Vlan10 Yes
1.1.1.2 00e0-fc00-0001 12 Vlan10 No
Table 7 Command output
IP address |
IP address in the ARP entry. |
MAC address |
MAC address in the ARP entry. |
VLAN/VSI |
Route |
Whether a direct route is generated or not based on the ARP entry: · Unknown—Whether a direct route is generated based on the ARP entry is unknown. · Yes—A direct route is generated based on the ARP entry. · No—No direct route is generated based on the ARP entry. |
