11-Network Management and Monitoring Command Reference
HomeSupportSwitchesS5170-EI SeriesReference GuidesCommand ReferencesH3C S5170-EI Command References-R11xx-6W10411-Network Management and Monitoring Command Reference
16-Cloud connection commands
16-Cloud connection commands 78.25 KB
cloud-management keepalive
Use cloud-management keepalive to set the keepalive interval for the local device to send keepalive packets to the H3C cloud server.
Use undo cloud-management keepalive to restore the default.
cloud-management keepalive interval
The keepalive interval is 180 seconds.
interval: Specifies the keepalive interval in the range of 180 to 600 seconds.
If the device does not receive a response from the H3C cloud server within three keepalive intervals, the device sends a registration request to re-establish the cloud connection.
# Set the keepalive interval to 360 seconds.
[Sysname] cloud-management keepalive 360
cloud-management server domain
Use cloud-management server domain to configure the IPv4 domain name of the H3C cloud server.
Use cloud-management server ipv6 domain to configure the IPv6 domain name of the H3C cloud server.
Use undo cloud-management server domain to restore the default.
cloud-management server { domain domain-name [ vpn-instance vpn-instance-name ] [ source-ip ipv4-address ] | port port-number }
cloud-management server ipv6 domain domain-name [ vpn-instance vpn-instance-name ] [ source-ip ipv6-address ]
undo cloud-management server [ ipv6 ] domain
The domain name of the H3C cloud server is not configured.
domain-name: Specifies the domain name of the H3C cloud server, a case-sensitive string of 1 to 253 characters.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, it indicates that the server is on the public network. Only R1122 and higher versions support this option.
source-ip ipv4-address: Specifies the source IPv4 address used to connect to the cloud server. Make sure the IPv4 address has been configured on the device. If you do not specify this option, the device uses the primary IPv4 address of the device outgoing interface to establish a connection with the cloud server.
port port-number: Specifies the destination TCP port number used by the device to initiate an authentication request to the cloud server, in the range of 1 to 65535. If you do not specify this option, the device uses the port number configured by using the cloud-management server port command. Only R1122 and higher versions support this option.
source-ip ipv6-address: Specifies the source IPv6 address used to connect to the cloud server. Make sure the IPv6 address has been configured on the device. If you do not specify this option, the device uses the primary IPv6 address of the device outgoing interface to establish a connection with the cloud server. Only R1122 and higher versions support this option.
Before you configure the domain name of the H3C cloud server, make sure a DNS server has been configured to translate the domain name.
If you execute the command multiple times, the most recent configuration takes effect.
# Configure the domain name of the H3C cloud server as abc.com.
[Sysname] cloud-management server domain abc.com
cloud-management server password
Use cloud-management server password to set the password for establishing cloud connections to the cloud server.
Use undo cloud-management server password to restore the default.
Only software versions of R1107 and later support configuring this command.
cloud-management server password { cipher | simple } string
No password is set for establishing cloud connections to the cloud server.
cipher: Specifies the password in cipher text.
simple: Specifies the password in plain text. For security purposes, the password specified in plain text will be stored in cipher text.
string: Specifies the password. The password in plain text is a case-sensitive string of 1 to 63 characters. The password in cipher text is a case-sensitive string of 1 to 117 characters.
After you change the password, the device terminates the cloud connections that have been established and uses the new password to re-establish the cloud connections.
# Set the password to 12345678TESTplat&! in plain text for establishing cloud connections to the cloud server.
[Sysname] cloud-management server password simple 12345678TESTplat&!
Use cloud-management server port to specify the TCP port number used to establish cloud connections.
Use undo cloud-management server port to restore the default.
cloud-management server port port-number
TCP port number 443 is used to establish cloud connections.
port-number: Specifies a TCP port number in the range of 1 to 65535.
After you change the port number, the device terminates the cloud connections that have been established and uses the new port number to establish cloud connections.
# Specify the TCP port number used to establish cloud connections as 80.
[Sysname] cloud-management server port 80
cloud-management unbinding-code
Use cloud-management unbinding-code to send the verification code for device unbinding to the Oasis server.
cloud-management unbinding-code code
code: Specifies the verification code obtained from the Oasis server. The verification code is a case-sensitive string of 16 characters.
A device can be registered on the Oasis server by only one user.
To register a device that has been registered by another user, you need to take the following steps:
1.     Obtain a verification code for device unbinding from the Oasis server.
2.     Execute this command on the device to send the verification code to the Oasis server.
3.     Register the device on the Oasis server.
# Send the verification code for device unbinding to the Oasis server.
[Sysname] cloud-management unbinding-code A6B9C3C2D5A8Z1S7
display cloud-management state
Use display cloud-management state to display cloud connection state information.
# Display cloud connection state information.
<Sysname> display cloud-management state
Cloud connection state   : Established
Device state             : Request_success
Cloud server address     : 10.1.1.1
Cloud server domain name : abc.com
Cloud server port        : 443
Connected at             : Wed Jan  27 14:18:40 2019
Duration                 : 00d 00h 02m 01s
Process state            : Message received
Failure reason           : N/A
Cloud connection state: Unconnected, Request, and Established.
Device state
Local device state:
·     Idle—In idle state.
·     Connecting—Connecting to the H3C cloud server.
·     Request_CAS_url—Sent a central authentication service (CAS) URL request.
·     Request_CAS_url_success—Requesting CAS URL succeeded.
·     Request_CAS_TGT—Sent a ticket granting ticket (TGT) request.
·     Request_CAS_TGT_success—Requesting TGT succeeded.
·     Request_CAS_ST—Sent a service ticket (ST) request.
·     Request_CAS_ST_success—Requesting ST succeeded.
·     Request_cloud_auth—Sent an authentication request.
·     Request_cloud_auth_success—Authentication succeeded.
·     Register—Sent a registration request.
·     Register_success—Registration succeeded.
·     Request—Sent a handshake request.
·     Request_success—Handshake succeeded.
IP address of the H3C cloud server.
Domain name of the H3C cloud server.
Cloud server port
Connected at
Time when the cloud connection was established.
Duration
Duration since the establishment of the cloud connection.
Process state
Cloud connection processing state:
·     DNS not parsed.
·     DNS parsed.
·     Message not sent.
·     Message sent.
·     Message not received.
·     Message received.
Failure reason
Cloud connection failure reason:
·     DNS parse failed.
·     Socket connection failed.
·     SSL creation failed.
·     Sending CAS url request failed.
·     Sending CAS TGT failed.
·     Sending CAS ST failed.
·     Sending cloud auth request failed.
·     Sending registration request failed.
·     Processing CAS URL response failed.
·     Processing CAS TGT response failed.
·     Processing CAS ST response failed.
·     Processing cloud auth response failed.
·     Processing registration response failed.
·     Sending handshake request failed.
·     Processing handshake failed.
·     Sending websocket request failed.
·     Processing websocket packet failed.
reset cloud-management tunnel
Use reset cloud-management tunnel to re-establish the cloud connection to the H3C cloud server.
# Re-establish the cloud connection to the H3C cloud server.
<Sysname> reset cloud-management tunnel
