- H3C Unified Platform Configuration Examples-E07xx-5W107
- 01-Unified Platform Operator Permission Management Configuration Examples
- 02-Unified Platform Dashboard Configuration Examples
- 03-Unified Platform Trap Filter Rule Configuration Examples
- 04-Unified Platform Trap-to-Alarm Rule Configuration Examples
- 05-Unified Platform Alarm Forwarding via SMS Configuration Examples
- 06-Unified Platform Alarm Aggregation Configuration Examples
- 07-Unified Platform Component License Registration and Expansion Configuration Examples
- 08-Unified Platform Alarm Forwarding via Mail Configuration Examples
- 09-Unified Platform Two-Factor Authentication Configuration Examples
| 05-Unified Platform Alarm Forwarding via SMS Configuration Examples | 645.16 KB |
Document version: 5W107-20250326
Product Version: E0714
Copyright © 2025 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
The Unified Platform supports sending alarm SMS messages through the Emay or third-party SMS platform. The Unified Platform allows you to configure the SMS sending method through SMS settings and send alarm messages to the network administrator through SMS messages.
This document describes how to configure the Emay SMS platform and send alarm messages through the Emay SMS platform.
NOTE: The Emay SMS platform is a third-party SMS platform. However, the system uses the Emay SMS platform as the default SMS platform. To use the Emay SMS platform to send messages, you only need to configure the serial number and encryption key. To use a third-party SMS platform other than Emay, you must configure the interface for it to send messages and the interface for it to authenticate tokens. |
Application scenarios
After the system is installed, the network managed by the system must be monitored in real time. To help the network administrator to promptly discover alarms, you can send alarm messages to the administrator through SMS messages. This document describes how to use the Emay SMS platform to send alarm messages.
· Make sure you have the license information (serial number and encryption key) of the Emay SMS platform.
· Make sure the monitored network devices have been incorporated in the system, and the system can receive alarm messages from devices.
Restrictions for Emay messages: A message of 70 or less characters is counted as one message. For the exceeding characters, every 67 characters are counted as one message. A message can contain up to 500 characters. A letter, digit, punctuation mark, space, or Chinese character is counted as one character.
Configuration examples
Connect the Emay SMS platform to the system through a direct connection or an HTTP proxy. If the Emay SMS platform can directly connect to the system, directly connect them. If the Emay SMS platform cannot be directly connected to the system and you must configure a proxy server, select the HTTP proxy connection method. This document takes direct connection as an example.
A company uses Unified Platform to manage the network. The topology of the network in the company is as shown in Figure 1. The operator needs to receive alarm messages through SMS messages during the company network management process.
Figure 1 Topology of the network in the company
DNS server configuration procedure
1. Log in to Matrix.
2. On the top navigation bar, click DEPLOY. From the navigation pane, select Clusters. Click the Cluster Parameters tab, as shown in Figure 2.
3. To edit cluster parameters, click the Modify
icon.
4. Select External DNS Server, and click Add DNS Server. In the Add DNS Server dialog box that opens, enter a DNS server IP address and a port number, as shown in Figure 3.
5. Click Apply to configure the DNS server.
6. Click Apply to save the cluster parameters.
Configuring the SMS center
1. Log in to Unified Platform.
2. On the top navigation bar, click System. From the navigation pane, select System Settings > SMS Settings to enter the SMS settings page, as shown in Figure 4.
3. Select the Emay SMS Sender option for the Sending Method field.
4. Enter the serial number and encryption key for the Emay license.
5. In the Internet Connection Info area, click Edit. On the Internet Connection Info window that opens, as shown in Figure 5, select a connection type. In this example, select Direct Connection, and click OK to return to the SMS settings page. The Internet connection information is successfully set.
6. In the SMS Signature area, enter a signature template.
7. In the Test Info area, enter a test number and test content.
8. Click Test to send the test content to the test number, as shown in Figure 6. Test succeeded
Figure 6 Sending an SMS message
Configuring alarm forwarding via SMS messages
2. On the top navigation bar, click Monitor. From the navigation pane, select Alarm > Alarm Forwarding Rules to enter the alarm forwarding rules page, as shown in Figure 7.
3. Click Add to enter the page for adding an alarm forwarding rule, as shown in Figure 8.
4. Enter alarm forwarding rule information.
¡ Rule Name: Assign a name to the SMS alarm forwarding rule.
¡ Forward Type: Select a forward type. If you select Forward Matching Alarms, alarms that match the forwarding rule are forwarded. If you select Forward Unmatching Alarms, alarms that do not match the forwarding rule are forwarded.
¡ Enable Duration-Triggered Notifications: Select whether to enable the Duration-Triggered Notifications feature. If you enable this feature, alarms that exist for the specified duration are forwarded.
¡ Alarm Severity Levels to be Concerned: Select the severity levels of alarms that can be sent via SMS messages. Alarms of unselected severity levels are not sent.
¡ Resources to be Concerned: Select the resources to be concerned. Alarms of resources not concerned are not sent via SMS messages. By default, the All Resources option is selected.
¡ Alarm to be Concerned: Select the alarms that can be sent via SMS messages. Alarms not concerned are not sent via SMS messages. In this example, select the All Alarms option.
5. Click SMS Forwarding to enter the SMS forwarding page, as shown in Figure 9.
6. Select the alarm time. By default, the All option is selected. In this example, enable phased notification and set the duration to 2 minutes. Enter a cellphone number, and click Add, as shown in Figure 10.
Figure 10 Adding a cellphone number
7. Click OK to return to the page for adding an alarm forwarding rule. In the Action Settings area, an SMS alarm forwarding rule is added, as shown in Figure 11.
Figure 11 Adding an SMS alarm forwarding rule
8. Click OK to return to the page for adding an alarm forwarding rule. A new rule is added, with the state as Enabled, as shown in Figure 12. The SMS alarm forwarding rule is set.
Figure 12 Enabled an SMS alarm forwarding rule successfully
9. When an alarm is generated in the system, the cellphone will receive an alarm message, as shown in Figure 13. In this example, the administrator receives an alarm that the account of operator wsg will expire.
10. On the top navigation bar, click System. From the navigation pane, select System Settings > SMS Message Records to view the SMS messages that have been sent, as shown in Figure 14.
11. If an alarm can be ignored or the failure represented by the alarm has been resolved, you can clear the alarm to change the alarm state from Active to Recovered. Additionally, you can acknowledge an alarm to record whether the alarm has been processed by the system or operator.
¡ Navigate to the Monitor > Alarm > Active Alarms page. Active alarms include all uncleared alarms and alarms that were cleared today.
¡ Click the Search Conditions link. Select All for the Status field to view alarms in any state, as shown in Figure 15. The administrator receives two alarm messages.
¡ Click the link in the Alarm Info column for an alarm to view alarm details, as in Figure 16.
