14-User Access and Authentication
HomeSupportRoutersCR16000-F SeriesDiagnose & MaintainAlarms ReferencesH3C CR16000-F Routers Alarm Reference-R8530Pxx-6W10014-User Access and Authentication
05-HH3C-PORTAL-MIB
05-HH3C-PORTAL-MIB 55.75 KB
HH3C-PORTAL-MIB
About this MIB
Use this MIB to configure portal authentication and obtain portal authentication information.
MIB file name
hh3c-portal.mib
Notifications
hh3cPortalServerLost
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.99.3.0.1
Portal authentication server is unreachable.
Error
Major
1.3.6.1.4.1.25506.2.99.3.0.2 (hh3cPortalServerGet)
OFF
Notification triggers
This notification is generated when the device receives no portal packets sent by the portal authentication server within the specified detection period.
This notification might be generated when the following events occur:
The device and the portal authentication server cannot reach each other.
The server heartbeat feature is disabled on the portal authentication server.
System impact
Portal users cannot log in.
Status control
ON
CLI: Use the server-detect trap command in portal authentication server view.
OFF
CLI: Use the undo server-detect command in portal authentication server view.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.99.2.1.1.1 (hh3cPortalServerName)
Name of the portal authentication server.
hh3cPortalExtSrvName
OCTET STRING
OCTET STRING (1..32)
1.3.6.1.4.1.25506.2.99.3.1.1 (hh3cPortalFirstTrapTime)
Time when this notification is triggered.
N/A
Timeticks
Standard MIB values.
1.3.6.1.4.1.25506.2.99.3.1.2 (hh3cPortalServerIP)
IP address of the portal authentication server.
InetAddress
OCTET STRING (0..255)
1.3.6.1.4.1.25506.2.99.2.1.1.3 (hh3cPortalServerPort)
Port number of the portal authentication server.
Integer32
Integer32 (1..65534)
Recommended action
To resolve this issue:
1.Use the ping or ping ipv6 command to check whether the portal authentication server is reachable:
  - If no, troubleshoot the reachability between the device and the portal authentication server.
  - If yes, go to step 2.
2.Check whether the server heartbeat feature is enabled on the portal authentication server. If the heartbeat feature is enabled, make sure the server heartbeat interval configured on the portal authentication server is smaller than the detection timeout configured on the device.
  - If no, enable the server heartbeat feature on the portal authentication server and configure the server heartbeat interval as required.
  - If yes, go to step 3.
3.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
hh3cPortalServerGet
Basic information
OID
Event
Severity
Default status
Portal authentication server is reachable.
Recovery
Major
N/A (N/A)
OFF
This notification is generated when the device receives portal packets sent by the portal authentication server within the specified detection period.
The device receives portal packets sent by the portal authentication server within the specified detection period.
The server detection feature is disabled for the portal authentication server.
System impact
No negative impact on services.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
OCTET STRING
N/A
Timeticks
InetAddress
Integer32
Recommended action
No action is required.
