18-Security
HomeSupportRoutersH3C SR8800-F Router SeriesReference GuidesMIB CompanionH3C SR8800-F Routers MIB Reference-R8530Pxx-6W10018-Security
11-HH3C-SSLVPN-MIB
11-HH3C-SSLVPN-MIB 41.86 KB
HH3C-SSLVPN-MIB
About this MIB
Use this MIB to configure the SSL VPN service.
MIB file name
hh3c-sslvpn.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3csslvpn(170)
Scalar objects
hh3cSslvpnTrapEnable (1.3.6.1.4.1.25506.2.170.1.2.1.1)
Object (OID)
Access
Value range
Implementation
read-write
INTEGER
enabled(1),
disabled(2)
Enabling status of trap notification of SSL VPN.
As per the MIB.
hh3cSslvpnDrvUserNumSpec (1.3.6.1.4.1.25506.2.170.1.2.1.2)
Object (OID)
Access
Value range
Implementation
read-only
Integer32
Standard MIB values.
Maximum number of login users allowed on the device.
Implementation depends on the installed license.
