07-HH3C-PORTATK-TRAP-MIB | 87.60 KB |
About this MIB
Use this table to configure port attack notifications.
MIB file name
hh3c-portatk-trap.mib
Notifications
hh3cPortAtkTrapPtkAlarm
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.250.0.1 |
A port attack alarm notification was sent to the SNMP module. |
Informational |
Major |
1.3.6.1.4.1.25506.2.250.0.2 (hh3cPortAtkTrapPtkResume) |
OFF |
Notification triggers
This notification is generated when certificate and CRL files failed to be written to flash, possibly because the device does not have enough storage space to store these files.
System impact
OID
Event
Severity
Default status
Informational
Major
1.3.6.1.4.1.25506.2.250.0.2(hh3cPortAtkTrapPtkResume)
OFF
This notification is generated when a port attack alarm notification is sent to the SNMP module.
【System impact】
Status control
ON
CLI: Use the snmp-agent trap enable port-attack command.
OFF
CLI: Use the undo snmp-agent trap enable port-attack command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.250.1.1 (hh3cPortAtkTrapPacketIf) |
Interface name. |
No |
OCTET STRING |
OCTET STRING (1..47) |
1.3.6.1.4.1.25506.2.250.1.2 (hh3cPortAtkTrapPacketType) |
Packet type. |
No |
INTEGER |
isis(1), esis(2), clnp(3), vrrp(4), unknownIpv4Mc(5), unknownIpv6Mc(6), ipv4McastRip(7), ipv4BcastRip(8), mcastNtp(9), bcastNtp(10), ipv4McastOspfDip5(11), ipv4McastOspfDip6(12), ipv4UcastOspf(13), ipv4McastPim(14), ipv4UcastPim(15), ipv4Igmp(16), ucastLdp(17), ipv6McastPim(18), ipv6UcastPim(19), ipv6Mld(20), ipv6Ripng(21), ipv6UcastOspfv3(22), ipv6McastOspfv3Dip5(23), ipv6McastOspfv3Dip6(24), ipv6Ldp(25), ipv6Vrrp(26), rrpp(27), ipv4Autorp(28), dot1x(29), stp(30), lacp(31), gvrp(32), hgmp(33), ucastBgp(34), ucastIcmp(35), ucastTtl(36), ucastIpOption(37), ipv6Bgp(38), ipv6NdPass(39), ipv6NdDest(40), lldp(41), dldp(42), bpduTunnelDmac3(43), bpduTunnelDmac0(44), bpduTunnelDmac1(45), bpduTunnelDmac2(46), msdp(47), telnetSsh(48), httpHttps(49), snmp(50), smlk(51), dot1ag(52), cdp(53), acsei(54), ucastNtp(55), md(56), ipv4UcDhcp(57), ipv4UcOspfTtl(58), ipv4UcPimTtl(59), ipv6Icmp(60), gmrp(61), pvst(62), oam(63), hgmpBc(64), eapolBridgemac(65), wpiBridgemac(66), cfdBridgemac(67), hgmpBridgemac(68), acseiBridgemac(69), ipv6DhcpUcClient(70), ipv6DhcpUcRelay(71), l2Stationmove(72), icmpRdm(73), ipv6CpudstCar(74), ptp(75), fcoeFipUc(76), fcoeToCpu(77), ipv6UcastRtrenum(78), ipv6McastRtrenum(79), ipv6UcastNtp(80), ipv6McastNtp(81), trillAllisis(82), drcp(83), rlinkHigh(84), rlinkMiddle(85), vdp(86), ipv4McastCbt(87), arp(88), arpReply(89), ipv6Ttl(90), ipv6Ping(91), snapCis(92), macBasevlan(93), trillStp(94), routeToCpuMask(95), spbm(96), ipv6IpOption(97), ipv4UcBgpTtl(98), dhcpClient(99), dhcpServer(100), dhcpRelayClient(101), dhcpRelayServer(102), ipv6Dhcp(103), ipv6DhcpClient(104), ipv6DhcpServer(105), ipv6DhcpRelayServer(106), bfdEcho(107), bfdCtrl(108), bfdMultihop(109), bfdIntfCtrl(110), lspPing(111), loopbackDetection(112), loopTest(113), ipv6TelnetSsh(114), mplsRsvp(115), rrppFd(116), ptpUdp(117), ofpMiss(118), ofpMatch(119), ofpDevconfTtl(120), ofpMacipMiss(121), ftpCtrl(122), vxlanUdp(123), capwap(124), rlinkextNormal(125), rlinkextMiddle(126), rlinkextHigh(127), ipv4Siph225(128), ipv4Siph245(129), typeErps(130), esmc(131), rlinkNormal(132), onvifv4(133), onvifv6(134), ipv4Sip(135), twamp(136), pppoe(137), ipv6RaGuard(138), tcpToCpuLow(139), ipv4BcmpServer(140), wlanAcToCpu(141), lwappAcToCpu(142), smartmcUc(143), smartmcBc(144), rlinkLow(145), drniUdp(146), sipSnooping(147), douPsg(148), h323Snooping(149), mdns(150), erps(151), sadp(152), dhcpProtectionClient(153), dhcpProtectionServer(154), bfdMultihopVxlan(155), rarp(156), inof(157), inofMobile(158), ipv6UcBgpTtl(159), ipv4McastOspf5High(160), ipv4McastOspf6High(161), ipv6Drcp(162), l2ptusr(163), rarpReply(164) |
Recommended action
No action is required.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.250.0.2 |
A port attack alarm was cleared. |
Informational |
Major |
N/A (N/A) |
OFF |
System impact
OID
Event
Severity
Default status
Informational
Major
N/A
OFF
This notification is generated when a port attack alarm is cleared.
【System impact】
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.250.1.1 (hh3cPortPacketIfIndex) |
Interface name. |
No |
OCTET STRING |
1.3.6.1.4.1.25506.2.250.1.2 (hh3cPortPacketType) |
Packet type. |
No |
INTEGER |
Recommended action
