- 11-MPLS
- 01-HH3C-MPLSRSVP-MIB
- 02-HH3C-MPLSLSPV-MIB
- 03-HH3C-EVC-MIB
- 04-HH3C-L2VPN-MIB
- 05-HH3C-L3VPN-MIB
- 06-HH3C-MPLS-LDP-MIB
- 07-HH3C-MPLS-VPN-BGP-MIB
- 08-HH3C-MPLSCRLSP-MIB
- 09-HH3C-MPLSEXT-MIB
- 10-HH3C-VSI-MIB
- 11-HH3C-MPLSTE-MIB
- 12-HH3C-MPLSSLSP-MIB
- 13-HH3C-MPLSPCE-MIB
- 14-MPLS-FRR-FACILITY-STD-MIB
- 15-MPLS-FRR-GENERAL-STD-MIB
- 16-MPLS-FTN-STD-MIB
- 17-MPLS-L3VPN-STD-MIB
- 18-MPLS-LDP-STD-MIB
- 19-MPLS-LSR-STD-MIB
- 20-MPLS-TE-STD-MIB
- 21-PW-ENET-STD-MIB
- 22-PW-MPLS-STD-MIB
- 23-PW-STD-MIB
- 24-TE-MIB
04-HH3C-L2VPN-MIB | 275.81 KB |
HH3C-L2VPN-MIB
About this MIB
Use this MIB to obtain L2VPN configuration information. This MIB also contains notifications about PW state changes.
MIB file name
hh3c-l2vpn.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3L2vpn(162)
Tabular objects
hh3cL2vpnPwcTable
About this table
This table contains PW class information.
Support for operations
Create:Not supported
Edit/Modify:Not supported
Delete:Not supported
Read:Supported
Columns
The table index is hh3cL2vpnPwcName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cL2vpnPwcName (1.3.6.1.4.1.25506.2.162.2.1.1.1) |
not-accessible |
OCTET STRING |
OCTET STRING (0..19) |
PW class name. |
As per the MIB. |
hh3cL2vpnPwcCvType (1.3.6.1.4.1.25506.2.162.2.1.1.2) |
read-create |
INTEGER |
unknown(1), bfd(2), rawBFD(3) |
Encapsulation mode used by BFD packets for PW fault detection. |
Supports only the read operation. |
hh3cL2vpnPwcCcType (1.3.6.1.4.1.25506.2.162.2.1.1.3) |
read-create |
INTEGER |
unknown(1), controlWord(2), routerAlert(3), ttl(4) |
VCCV control channel type. |
hh3cL2vpnPwcControlWord (1.3.6.1.4.1.25506.2.162.2.1.1.4) |
read-create |
TruthValue |
true(1) false(2) |
Whether the control word feature is enabled. |
hh3cL2vpnPwcPwType (1.3.6.1.4.1.25506.2.162.2.1.1.5) |
read-create |
INTEGER |
vlan(4), ethernet(5) |
PW data encapsulation type. |
hh3cL2vpnPwcRowStatus (1.3.6.1.4.1.25506.2.162.2.1.1.6) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status. |
hh3cL2vpnPwcFlowLabel (1.3.6.1.4.1.25506.2.162.2.1.1.7) |
read-create |
INTEGER |
unknown(1), send(2), receive(3), both(4) |
PW flow label. |
hh3cL2vpnXcgTable
About this table
This table contains L2VPN cross-connect group information.
Read:Supported
Columns
The table index is hh3cL2vpnXcgName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cL2vpnXcgName (1.3.6.1.4.1.25506.2.162.3.1.1.1) |
not-accessible |
OCTET STRING |
OCTET STRING (1..31)) |
Name of the cross-connect group. |
As per the MIB. |
hh3cL2vpnXcgAdminState (1.3.6.1.4.1.25506.2.162.3.1.1.2) |
read-create |
INTEGER |
adminUp(1), adminDown(2) |
Administrative state of the cross-connect group. |
hh3cL2vpnXcgRowStatus (1.3.6.1.4.1.25506.2.162.3.1.1.3) |
read-create |
RowStatus |
Row status. |
hh3cL2vpnXcgConnTable
About this table
This table contains L2VPN cross-connect information.
Read:Supported
Columns
The table indexes are hh3cL2vpnXcgName and hh3cL2vpnXcgConnName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cL2vpnXcgConnName (1.3.6.1.4.1.25506.2.162.3.2.1.1) |
not-accessible |
OCTET STRING |
OCTET STRING (1..20) |
Name of the cross-connect. |
As per the MIB. |
hh3cL2vpnXcgConnRowStatus (1.3.6.1.4.1.25506.2.162.3.2.1.2) |
read-create |
RowStatus |
Row status. |
hh3cL2vpnXcgConnRedundancy (1.3.6.1.4.1.25506.2.162.3.2.1.3) |
read-create |
INTEGER |
slave(1), master(2) |
PW redundancy mode. |
hh3cL2vpnXcgAcTable
About this table
This table contains cross-connect group AC information.
Read:Supported
Columns
The table indexes are hh3cL2vpnXcgName, hh3cL2vpnXcgConnName, hh3cL2vpnXcgAcIfIndex, and hh3cL2vpnXcgAcEvcSrvInstId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cL2vpnXcgAcIfIndex (1.3.6.1.4.1.25506.2.162.3.3.1.1) |
not-accessible |
InterfaceIndex |
InterfaceIndex (1..2147483647) |
Interface index of the AC. |
As per the MIB. |
hh3cL2vpnXcgAcEvcSrvInstId (1.3.6.1.4.1.25506.2.162.3.3.1.2) |
not-accessible |
Unsigned32 |
Unsigned32 (0..4294967295) |
ID of the Ethernet service instance bound to the cross-connect group. |
As per the MIB. The value of this object is fixed at 0 for a Layer 3 interface. |
hh3cL2vpnXcgAcAccessMode (1.3.6.1.4.1.25506.2.162.3.3.1.3) |
read-create |
INTEGER |
vlan(1), ethernet(2) |
Access mode of the AC. |
Supports only the read operation. This object is meaningless when the AC is not a Layer 2 Ethernet interface. |
hh3cL2vpnXcgAcRowStatus (1.3.6.1.4.1.25506.2.162.3.3.1.4) |
read-create |
RowStatus |
Row status. |
hh3cL2vpnXcgPwTable
About this table
This table contains cross-connect group PW information.
Read:Supported
Columns
The table indexes are hh3cL2vpnXcgName, hh3cL2vpnXcgConnName, and hh3cL2vpnXcgPwIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cL2vpnXcgPwIndex (1.3.6.1.4.1.25506.2.162.3.4.1.1) |
accessible-for-notify |
Unsigned32 |
PW index. |
As per the MIB. |
hh3cL2vpnXcgPwCfgType (1.3.6.1.4.1.25506.2.162.3.4.1.2) |
read-create |
INTEGER |
primary(1), backup(2) |
PW type, primary PW or backup PW. |
hh3cL2vpnXcgPwClassName (1.3.6.1.4.1.25506.2.162.3.4.1.3) |
read-create |
OCTET STRING |
OCTET STRING (1..19) |
Name of the used PW class. |
hh3cL2vpnXcgPwTunnelPolicy (1.3.6.1.4.1.25506.2.162.3.4.1.4) |
read-create |
OCTET STRING |
Name of the used tunnel policy. |
hh3cL2vpnXcgPwPeerIp (1.3.6.1.4.1.25506.2.162.3.4.1.5) |
IpAddress |
OCTET STRING (SIZE (4)) |
Peer's IP address. |
As per the MIB. |
hh3cL2vpnXcgPwPwID (1.3.6.1.4.1.25506.2.162.3.4.1.6) |
Unsigned32 |
PW ID. |
As per the MIB. |
hh3cL2vpnXcgPwRowStatus (1.3.6.1.4.1.25506.2.162.3.4.1.7) |
read-create |
RowStatus |
Row status. |
hh3cL2vpnXcgPwIgnoreStandby (1.3.6.1.4.1.25506.2.162.3.4.1.8) |
read-create |
TruthValue |
true(1) false(2) |
Ignoring the PW standby status. |
hh3cL2vpnCCCTable
About this table
This table contains remote Circuit Cross Connect (CCC) connection information in a cross-connect group.
Read:Supported
Columns
The table indexes are hh3cL2vpnInInterfaceIndex and hh3cL2vpnOutInterfaceIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cL2vpnInInterfaceIndex (1.3.6.1.4.1.25506.2.162.3.5.1.1) |
InterfaceIndex |
Inbound interface index. |
As per the MIB. |
hh3cL2vpnOutInterfaceIndex (1.3.6.1.4.1.25506.2.162.3.5.1.2) |
InterfaceIndex |
Outbound interface index. |
As per the MIB. |
hh3cL2vpnChangeReason (1.3.6.1.4.1.25506.2.162.3.5.1.3) |
OCTET STRING |
OCTET STRING (0..255) |
CCC connection status change reason. |
As per the MIB. |
hh3cL2vpnInInterfaceName (1.3.6.1.4.1.25506.2.162.3.5.1.4) |
OCTET STRING |
Inbound interface name. |
As per the MIB. |
hh3cL2vpnOutInterfaceName (1.3.6.1.4.1.25506.2.162.3.5.1.5) |
OCTET STRING |
Outbound interface name. |
As per the MIB. |
hh3cL2vpnPwCfgTable
About this table
This table contains L2VPN PW information.
Read:Supported
Columns
The table indexes are hh3cL2vpnPwPeerIp and hh3cL2vpnPwId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cL2vpnPwPeerIp (1.3.6.1.4.1.25506.2.162.5.1.1.1) |
not-accessible |
IpAddress |
OCTET STRING (4) |
Peer IP address of a PW. |
As per the MIB. |
hh3cL2vpnPwId (1.3.6.1.4.1.25506.2.162.5.1.1.2) |
not-accessible |
Unsigned32 |
PW ID. |
As per the MIB. |
hh3cL2vpnPwOutboundQosCarCir (1.3.6.1.4.1.25506.2.162.5.1.1.16) |
read-only |
Unsigned32 |
Outbound CAR CIR. |
As per the MIB. |
hh3cL2vpnPwOutboundQosCarCbs (1.3.6.1.4.1.25506.2.162.5.1.1.17) |
read-only |
Unsigned32 |
Outbound CAR CBS. |
As per the MIB. |
hh3cL2vpnPwOutboundQosCarEbs (1.3.6.1.4.1.25506.2.162.5.1.1.18) |
read-only |
Unsigned32 |
Outbound CAR EBS. |
As per the MIB. |
hh3cL2vpnPwOutboundQosCarPir (1.3.6.1.4.1.25506.2.162.5.1.1.19) |
read-only |
Unsigned32 |
Outbound CAR PIR. |
As per the MIB. |
hh3cL2vpnPwType (1.3.6.1.4.1.25506.2.162.5.1.1.20) |
read-only |
Unsigned32 |
PW encapsulation type. |
As per the MIB. |
hh3cL2vpnPwIndex (1.3.6.1.4.1.25506.2.162.5.1.1.21) |
read-only |
Unsigned32 |
PW index. |
As per the MIB. |
hh3cL2vpnMacLimitPwTable
About this table
This table contains L2VPN MAC limit alarm information.
Read:Supported
Columns
The table indexes are hh3cL2vpnMacLimitPwVsiIndex and hh3cL2vpnMacLimitPwLinkID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cL2vpnMacLimitPwVsiIndex (1.3.6.1.4.1.25506.2.162.2.3.1.1) |
Unsigned32 |
VSI index. |
As per the MIB. |
hh3cL2vpnMacLimitPwLinkID (1.3.6.1.4.1.25506.2.162.2.3.1.2) |
Unsigned32 |
Link ID of the PW. |
As per the MIB. |
hh3cL2vpnMacLimitPwVsiName (1.3.6.1.4.1.25506.2.162.2.3.1.3) |
read-create |
DisplayString |
OCTET STRING (1..31) |
VSI name. |
As per the MIB. |
hh3cL2vpnMacLimitPwRowStatus (1.3.6.1.4.1.25506.2.162.2.3.1.4) |
read-create |
RowStatus |
Row status of the MacLimitPw table. |
hh3cL2vpnPwInfoTable
About this table
This table contains PW notifications information.
Read:Supported
Columns
The table indexes are hh3cL2vpnPeerIp and hh3cL2vpnPWPwID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cL2vpnPeerIp (1.3.6.1.4.1.25506.2.162.2.4.1.1) |
IpAddress |
Peer IP for the PW. |
As per the MIB. |
hh3cL2vpnPWPwID (1.3.6.1.4.1.25506.2.162.2.4.1.2) |
Unsigned32 |
Pw ID |
As per the MIB. |
hh3cL2vpnPwType (1.3.6.1.4.1.25506.2.162.2.4.1.3) |
read-only |
INTEGER |
Interface encapsulation type for the PW |
As per the MIB. |
hh3cL2vpnFlowLabelNonSuppTable
About this table
This contains information about interface modules that do not support the flow label feature.
Read:Supported
Columns
The table index is hh3cL2vpnFlowLabelSlotId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cL2vpnFlowLabelSlotId (1.3.6.1.4.1.25506.2.162.2.5.1.1) |
Unsigned32 |
Interface module number. |
As per the MIB. |
hh3cL2vpnFlowLabelOID (1.3.6.1.4.1.25506.2.162.2.5.1.2) |
read-only |
OBJECT IDENTIFIER |
OID ID |
As per the MIB. |
Notifications
hh3cL2vpnPwSwitchPtoB
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.162.0.1 |
Traffic is switched from the primary PW to the backup PW. |
Error |
Warning |
1.3.6.1.4.1.25506.2.162.0.2 (hh3cL2vpnPwSwitchBtoP) |
OFF |
Notification triggers
This notification is generated when the traffic is switched from the primary PW to the backup PW.
System impact
Millisecond-level packet loss will occur when the traffic is switched from the primary PW to the backup PW.
Status control
ON
CLI: Use the snmp-agent trap enable l2vpn pw-switch command.
OFF
CLI: Use the undo snmp-agent trap enable l2vpn pw-switch command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.162.3.4.1.1 (hh3cL2vpnXcgPwIndex) |
PW index associated with the cross-connect. |
hh3cL2vpnXcgPwIndex hh3cL2vpnXcgName hh3cL2vpnXcgConnName |
Unsigned32 |
As per the MIB. |
1.3.6.1.4.1.25506.2.162.3.4.1.5 (hh3cL2vpnXcgPwPeerIp) |
IP address of the PW associated with the cross-connect. |
IpAddress |
As per the MIB. |
1.3.6.1.4.1.25506.2.162.3.4.1.6 (hh3cL2vpnXcgPwPwID) |
ID of the PW associated with the cross-connect. |
Unsigned32 |
As per the MIB. |
Recommended action
No action is required.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.162.0.2 |
Traffic is switched from the backup PW to the primary PW. |
Recovery |
Warning |
N/A (N/A) |
OFF |
This notification is generated when the traffic is switched from the backup PW to the primary PW.
System impact
Millisecond-level packet loss will occur when the traffic is switched from the backup PW to the primary PW.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Unsigned32 |
As per the MIB. |
IpAddress |
As per the MIB. |
Unsigned32 |
As per the MIB. |
Recommended action
hh3cL2vpnMacLimitMaxPw
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.162.0.5 |
The number of MAC addresses learned on a PW reached the upper threshold value. |
Error |
Warning |
1.3.6.1.4.1.25506.2.162.0.6 (hh3cL2vpnMacLimitMaxPw_Clear) |
OFF |
This notification is generated when the number of MAC addresses learned on a PW exceeds the limit.
System impact
No new MAC addresses can be learned on the PW.
Status control
ON
CLI: Use the snmp-agent trap enable l2vpn maclimit-pw command.
OFF
CLI: Use the undo snmp-agent trap enable l2vpn maclimit-pw command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.162.2.3.1.1 (hh3cL2vpnMacLimitPwVsiIndex) |
VSI index. |
hh3cL2vpnMacLimitPwVsiIndex hh3cL2vpnMacLimitPwLinkID |
Unsigned32 |
As per the MIB. |
1.3.6.1.4.1.25506.2.162.2.3.1.2 (hh3cL2vpnMacLimitPwLinkID) |
PW index. |
Unsigned32 |
As per the MIB. |
1.3.6.1.4.1.25506.2.162.2.3.1.3 (hh3cL2vpnMacLimitPwVsiName) |
VSI name. |
DisplayString |
As per the MIB. |
Recommended action
To resolve this issue:
1.Use the display l2vpn mac-address vsi vsi-name pw command to display information about MAC address entries learned on the PW.
2.From the command output, identify the unneeded static MAC address entries and then delete them. Alternatively, wait for dynamic MAC address entries to age out.
hh3cL2vpnMacLimitMaxPwClear
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.162.0.6 |
The number of MAC addresses learned on a PW dropped below the lower threshold value. |
Recovery |
Warning |
N/A (N/A) |
OFF |
This notification is generated when the number of MAC addresses learned on a PW drops below the lower threshold value.
System impact
No impact on services.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
VSI index. |
Unsigned32 |
As per the MIB. |
PW index. |
Unsigned32 |
As per the MIB. |
VSI name. |
DisplayString |
As per the MIB. |
Recommended action
hh3cL2vpnMacLimitMaxAc
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.162.0.3 |
The number of MAC addresses learned on an AC reached the maximum. |
Error |
Warning |
1.3.6.1.4.1.25506.2.162.0.4 (hh3cL2vpnMacLimitMaxAcClear) |
OFF |
This notification is generated when the number of MAC addresses learned on an AC exceeds the maximum.
System impact
The AC has learned the maximum number of MAC addresses. It cannot learn new MAC addresses.
Status control
ON
CLI: Use the snmp-agent trap enable l2vpn maclimit-ac command.
OFF
CLI: Use the undo snmp-agent trap enable l2vpn maclimit-ac command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.162.4.1.1.3 (hh3cL2vpnAcIfName) |
Name of the interface (AC). |
hh3cL2vpnAcIfIndex hh3cL2vpnAcSrvId |
DisplayString |
As per the MIB. |
1.3.6.1.4.1.25506.2.162.4.1.1.4 (hh3cL2vpnAcVsiName) |
Name of the VSI bound to the AC. |
DisplayString |
As per the MIB. |
Recommended action
1.Use the display l2vpn mac-address vsi vsi-name ac command to display information about MAC address entries learned on the AC.
2.From the command output, identify the unneeded static MAC address entries and then delete them. Or, wait for dynamic MAC address entries to age out.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.162.0.4 |
The number of MAC addresses learned on an AC dropped below the lower threshold value. |
Recovery |
Warning |
N/A (N/A) |
OFF |
This notification is generated when the number of MAC addresses learned on an AC drops below the lower threshold value.
System impact
No negative impact on services.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
DisplayString |
As per the MIB. |
DisplayString |
As per the MIB. |
Recommended action
hh3cL2vpnPwParaMisMatch
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.162.0.7 |
PW parameter settings do not match. |
Error |
Warning |
1.3.6.1.4.1.25506.2.162.0.8 (hh3cL2vpnPwParaMatch) |
OFF |
This notification is generated when the PW negotiation parameter settings are inconsistent on the two ends of the PW.
System impact
The PW cannot be established or cannot forward service packets correctly.
Status control
ON
CLI: Use the snmp-agent trap enable l2vpn pw-parameter command.
OFF
CLI: Use the undo snmp-agent trap enable l2vpn pw-parameter command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.162.5.1.1.6 (hh3cL2vpnPwVsiName) |
Name of the VSI to which the PW is bound. |
hh3cL2vpnPwPeerIp hh3cL2vpnPwId |
DisplayString |
As per the MIB. |
1.3.6.1.4.1.25506.2.162.5.1.1.7 (hh3cL2vpnPwXcgName) |
Name of the cross-connect group to which the PW is bound. |
DisplayString |
As per the MIB. |
1.3.6.1.4.1.25506.2.162.5.1.1.8 (hh3cL2vpnPwXcgConnName) |
Name of the cross-connect to which the PW is bound. |
DisplayString |
As per the MIB. |
Recommended action
1.On the two peers of the PW, use the display l2vpn ldp verbose command to display detailed information about PW labels advertised by LDP.
2.From the command output, check the values for the PW Type, Control Word, and MTU fields.
3.If the values of those fields are inconsistent on the two peers of the PW, edit the settings of the corresponding parameters to make sure the two peers use the same settings.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.162.0.8 |
PW parameter settings are consistent. |
Recovery |
Warning |
N/A (N/A) |
OFF |
This notification is generated when the PW negotiation parameter settings are consistent on the two ends of the PW.
System impact
This event has impact on the PW setup status and service forwarding status.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
DisplayString |
As per the MIB. |
DisplayString |
As per the MIB. |
DisplayString |
As per the MIB. |
Recommended action
hh3cL2vpnPwOutAge
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.162.0.9 |
Both the primary and backup PWs are unavailable. |
Error |
Warning |
1.3.6.1.4.1.25506.2.162.0.10 (hh3cL2vpnPwOutAgeClear) |
OFF |
This notification is generated when both the primary and backup PWs are unavailable.
System impact
PW service forwarding will be impacted.
Status control
ON
CLI: snmp-agent trap enable l2vpn [pw-up-down]
OFF
CLI: undo snmp-agent trap enable l2vpn [pw-up-down]
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.162.2.4.1.1 (hh3cL2vpnPeerIp) |
Peer IP for the PW |
hh3cL2vpnPeerIp hh3cL2vpnPWPwID |
IpAddress |
As per the MIB. |
1.3.6.1.4.1.25506.2.162.2.4.1.2 (hh3cL2vpnPWPwID) |
PW ID |
Unsigned32 |
As per the MIB. |
1.3.6.1.4.1.25506.2.162.2.4.1.3 (hh3cL2vpnPwType) |
PW encapsulation type |
INTEGER |
As per the MIB. |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.162.0.10 |
Both the primary and backup PWs are available. |
Recovery |
Warning |
OFF |
This notification is generated when both the primary and backup PWs become available.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
IpAddress |
As per the MIB. |
PW ID |
Unsigned32 |
As per the MIB. |
INTEGER |
As per the MIB. |
Recommended action
hh3cL2vpnSingleCCCVcUp
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.162.0.11 |
CCC status changed to up in the inbound or outbound direction |
Recovery |
Warning |
OFF |
This notification is generated when CCC status changes to up.
System impact
CCC service forwarding will be impacted.
Status control
ON
CLI: snmp-agent trap enable l2vpn [ccc-up-down]
OFF
CLI: undo snmp-agent trap enable l2vpn [ccc-up-down]
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.162.3.5.1.1 (hh3cL2vpnInInterfaceIndex) |
Inbound interface index |
hh3cL2vpnInInterfaceIndex hh3cL2vpnOutInterfaceIndex |
InterfaceIndex |
As per the MIB. |
1.3.6.1.4.1.25506.2.162.3.5.1.2 (hh3cL2vpnOutInterfaceIndex) |
Outbound interface index |
InterfaceIndex |
As per the MIB. |
1.3.6.1.4.1.25506.2.162.3.5.1.3 (hh3cL2vpnChangeReason) |
Remote connection status change reason |
Unsigned32 |
As per the MIB. |
1.3.6.1.4.1.25506.2.162.3.5.1.4 (hh3cL2vpnInInterfaceName) |
Inbound interface name |
OCTET STRING |
As per the MIB. |
1.3.6.1.4.1.25506.2.162.3.5.1.5 (hh3cL2vpnOutInterfaceName) |
Outbound interface name |
OCTET STRING |
As per the MIB. |
Recommended action
hh3cL2vpnSingleCCCVcDown
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.162.0.12 |
CCC status changed to down in the inbound or outbound direction |
Error |
Warning |
1.3.6.1.4.1.25506.2.162.0.11 (hh3cL2vpnSingleCCCVcUp) |
OFF |
This notification is generated when CCC status changes to down.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
InterfaceIndex |
As per the MIB. |
InterfaceIndex |
As per the MIB. |
Unsigned32 |
As per the MIB. |
OCTET STRING |
As per the MIB. |
OCTET STRING |
As per the MIB. |
Recommended action
Possible causes for CCC status changes:
● 11 -- "Label (not) allocated"
● 8 -- "Local Xconnect-group Up/Down"
● 5 -- “Local AC (not) bind”
● 4 -- “Local AC Up/Down”
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.162.0.13 |
The device detected a card that does not support flow labels. |
Error |
Warning |
OFF |
This notification is generated when the device detects a card that does not support the flow label feature.
System impact
The flow label feature is impacted.
Status control
ON
CLI: Use the snmp-agent trap enable l2vpn flow-label command.
OFF
CLI: Use the undo snmp-agent trap enable l2vpn flow-label command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.162.2.5.1.1 (hh3cL2vpnFlowLabelSlotId) |
Interface module number |
hh3cL2vpnFlowLabelSlotId |
Unsigned32 |
As per the MIB. |
1.3.6.1.4.1.25506.2.162.2.5.1.2 (hh3cL2vpnFlowLabelOID) |
OID ID |
OBJECT IDENTIFIER |
As per the MIB. |
Recommended action
