07-Layer 2 - WAN Access
HomeSupportRoutersH3C SR8800-F Router SeriesReference GuidesMIB CompanionH3C SR8800-F Routers MIB Reference-R8530Pxx-6W10007-Layer 2 - WAN Access
05-PPP-IP-NCP-MIB
05-PPP-IP-NCP-MIB 72.38 KB
PPP-IP-NCP-MIB
About this MIB
Use this MIB to get the PPP IPCP negotiation information and local negotiation configuration.
MIB file name
rfc1473-ppp-ip.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).transmission(10).ppp(23)
Tabular objects
pppIpTable
About this table
This table gets the PPP IPCP negotiation information.
Support for operations
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table index is ifIndex.
Object (OID)
Access
Value range
Implementation
pppIpOperStatus (1.3.6.1.2.1.10.23.3.1.1.1)
read-only
INTEGER
opened(1)
 not-opened(2)
PPP IPCP status.
As per the MIB.
pppIpLocalToRemoteCompressionProtocol (1.3.6.1.2.1.10.23.3.1.1.2)
read-only
INTEGER
none(1)
vj-tcp(2)
Remote compression protocol for PPP IPCP.
This object is not configurable and is fixed at 1.
pppIpRemoteToLocalCompressionProtocol (1.3.6.1.2.1.10.23.3.1.1.3)
read-only
INTEGER
none(1)
vj-tcp(2)
Local compression protocol for PPP IPCP.
pppIpRemoteMaxSlotId (1.3.6.1.2.1.10.23.3.1.1.4)
read-only
Integer32
Integer32 (0..255)
Maximum slot number on the remote end.
This object is not configurable and is fixed at 0.
pppIpLocalMaxSlotId (1.3.6.1.2.1.10.23.3.1.1.5)
read-only
Integer32
Integer32 (0..255)
Maximum slot number on the local end.
pppIpConfigTable
About this table
This table gets the local PPP IPCP negotiation configuration.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
pppIpConfigAdminStatus (1.3.6.1.2.1.10.23.3.2.1.1)
read-only
INTEGER
open(1)
close(2)
PPP IPCP negotiation status.
As per the MIB.
pppIpConfigCompression (1.3.6.1.2.1.10.23.3.2.1.2)
read-only
INTEGER
none(1)
vj-tcp(2)
PPP IPCP compression protocol.
