20-Network Management and Monitoring
HomeSupportRoutersCR16000-M SeriesReference GuidesMIB CompanionH3C CR16000-M Routers MIB Reference-R8530Pxx-6W10020-Network Management and Monitoring
22-SNMP-VIEW-BASED-ACM-MIB
22-SNMP-VIEW-BASED-ACM-MIB 95.92 KB
About this MIB
Use this MIB to manage SNMPv3 settings, including access control view, group, VACM security mode, and security level.
MIB file name
rfc3415-snmp-vacm.mib
Root object
iso(1).org(3).dod(6).internet(1).snmpV2(6).snmpModules(3).snmpVacmMIB(16).vacmMIBObjects(1)
Tabular objects
vacmContextTable
About this table
This table contains locally available contexts.
Support for operations
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table index is vacmContextName.
Object (OID)
Access
Value range
Implementation
vacmContextName (1.3.6.1.6.3.16.1.1.1.1)
read-only
SnmpAdminString
OCTET STRING (0..32)
A human readable name identifying a context at an SNMP entity.
An empty contextName (zero length) represents the default context.
As per the MIB.
vacmSecurityToGroupTable
About this table
This table maps a combination of securityModel and securityName into a groupName that is used to define an access control policy for a group of principals.
CreateSupported
Edit/ModifySupported
DeleteSupported
ReadSupported
Columns
The table indexes are vacmSecurityModel and vacmSecurityName.
Object (OID)
Access
Value range
Implementation
vacmSecurityModel (1.3.6.1.6.3.16.1.2.1.1)
not-accessible
SnmpSecurityModel
Integer32 (1.. 2147483647)
Security model, by which the vacmSecurityName referenced by this entry is provided.
As per the MIB.
vacmSecurityName (1.3.6.1.6.3.16.1.2.1.2)
not-accessible
SnmpAdminString
OCTET STRING (1..32)
Security Name.
The value can contain only displayable characters except question marks.
vacmGroupName (1.3.6.1.6.3.16.1.2.1.3)
read-create
SnmpAdminString
Name of the group to which this entry (combination of securityModel and securityName) belongs
vacmSecurityToGroupStorageType (1.3.6.1.6.3.16.1.2.1.4)
read-create
StorageType
other(1),
volatile(2),
nonVolatile(3),
permanent(4),
readOnly(5)
Storage type for this conceptual row.
Supports only be nonVolatile(3).
vacmSecurityToGroupStatus (1.3.6.1.6.3.16.1.2.1.5)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
As per the MIB.
vacmAccessTable
About this table
Use this table to configure access rights for groups.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are vacmGroupName, vacmAccessContextPrefix, vacmAccessSecurityModel, and vacmAccessSecurityLevel.
Object (OID)
Access
Value range
Implementation
vacmAccessContextPrefix (1.3.6.1.6.3.16.1.4.1.1)
not-accessible
SnmpAdminString
In order to gain the access rights allowed by this conceptual row, a contextName must match exactly (if the value of vacmAccessContextMatch is exact) or partially (if the value of vacmAccessContextMatch is prefix) the value of the instance of this object.
Only the value - is effective. Other values do not take effect.
vacmAccessSecurityModel (1.3.6.1.6.3.16.1.4.1.2)
not-accessible
SnmpSecurityModel
Integer32 (0.. 2147483647)
In order to gain the access rights allowed by this conceptual row, this securityModel must be in use.
As per the MIB.
vacmAccessSecurityLevel (1.3.6.1.6.3.16.1.4.1.3)
not-accessible
SnmpSecurityLevel
noAuthNoPriv(1),
authNoPriv(2),
authPriv(3)
Minimum level of security required to gain the access rights allowed by this conceptual row.
As per the MIB.
vacmAccessContextMatch (1.3.6.1.6.3.16.1.4.1.4)
read-create
INTEGER
exact(1),
prefix(2)
Match type.
If the value of this object is exact(1), all rows where the contextName exactly matches vacmAccessContextPrefix are selected.
If the value of this object is prefix(2), all rows where the contextName whose starting octets exactly match vacmAccessContextPrefix are selected.
The default value is exact(1).
vacmAccessReadViewName (1.3.6.1.6.3.16.1.4.1.5)
read-create
SnmpAdminString
The value of an instance of this object identifies the MIB view of the SNMP context to which this conceptual row authorizes read access.
vacmAccessWriteViewName (1.3.6.1.6.3.16.1.4.1.6)
read-create
SnmpAdminString
The value of an instance of this object identifies the MIB view of the SNMP context to which this conceptual row authorizes write access.
vacmAccessNotifyViewName (1.3.6.1.6.3.16.1.4.1.7)
read-create
SnmpAdminString
The value of an instance of this object identifies the MIB view of the SNMP context to which this conceptual row authorizes access for notifications.
vacmAccessStorageType (1.3.6.1.6.3.16.1.4.1.8)
read-create
StorageType
other(1),
volatile(2),
nonVolatile(3),
permanent(4),
readOnly(5)
Supports only nonVolatile(3).
vacmAccessStatus (1.3.6.1.6.3.16.1.4.1.9)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
As per the MIB.
vacmViewTreeFamilyTable
About this table
Use this table to save information about families of subtrees within MIB views locally.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are vacmViewTreeFamilyViewName and vacmViewTreeFamilySubtree.
Object (OID)
Access
Value range
Implementation
vacmViewTreeFamilyViewName (1.3.6.1.6.3.16.1.5.2.1.1)
not-accessible
SnmpAdminString
Name for a family of view subtrees.
vacmViewTreeFamilySubtree (1.3.6.1.6.3.16.1.5.2.1.2)
not-accessible
OBJECT IDENTIFIER
Standard MIB values
MIB subtree which, when combined with the corresponding instance of vacmViewTreeFamilyMask, defines a family of view subtrees.
As per the MIB.
vacmViewTreeFamilyMask (1.3.6.1.6.3.16.1.5.2.1.3)
read-create
OCTET STRING
OCTET STRING (0..16)
Bit mask which, in combination with the corresponding instance of vacmViewTreeFamilySubtree, defines a family of view subtrees.
The default value is a zero-length character string.
vacmViewTreeFamilyType (1.3.6.1.6.3.16.1.5.2.1.4)
read-create
INTEGER
included(1),
excluded(2)}
Indicates whether the corresponding instances of vacmViewTreeFamilySubtree and vacmViewTreeFamilyMask define a family of view subtrees which is included in or excluded from the MIB view.
The default value is included(1).
vacmViewTreeFamilyStorageType (1.3.6.1.6.3.16.1.5.2.1.5)
read-create
StorageType
other(1),
volatile(2),
nonVolatile(3),
permanent(4),
readOnly(5)
vacmViewTreeFamilyStatus (1.3.6.1.6.3.16.1.5.2.1.6)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
As per the MIB.
