20-Network Management and Monitoring
HomeSupportRoutersCR16000-M SeriesReference GuidesMIB CompanionH3C CR16000-M Routers MIB Reference-R8530Pxx-6W10020-Network Management and Monitoring
04-HH3C-HTTP-MIB
04-HH3C-HTTP-MIB 71.27 KB
HH3C-HTTP-MIB
About this MIB
Use this MIB to obtain and manage HTTP settings.
MIB file name
hh3c-http.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cHttp(255)
Scalar objects
hh3cHttpUserIPAddressType (1.3.6.1.4.1.25506.2.255.1.1.2)
Object (OID)
Access
Value range
Implementation
accessible-for-notify
InetAddressType
Standard MIB values.
IP address type of the HTTP user
As per the MIB
hh3cHttpUserIPAddress (1.3.6.1.4.1.25506.2.255.1.1.3)
Object (OID)
Access
Value range
Implementation
DisplayString
SIZE(1..80)
IP address of the HTTP user
As per the MIB
hh3cHttpUserService (1.3.6.1.4.1.25506.2.255.1.1.4)
Object (OID)
Access
Value range
Implementation
DisplayString
SIZE(1..80)
Service type of the HTTP user
As per the MIB
Notifications
hh3cHttpUserLogin
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.255.2.0.1
Successful login of an HTTP user.
Informational
Warning
N/A (N/A)
ON
Notification triggers
This notification is generated when an HTTP user successfully logs in.
System impact
No negative impact on services
Status control
This notification cannot be disabled.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.255.1.1.1 (hh3cHttpUserName)
Username of an HTTP user.
N/A
DisplayString
SIZE(1..80)
 (hh3cHttpUserIPAddressType)
IP address type of the HTTP user.
N/A
InetAddressType
 (hh3cHttpUserIPAddress)
IP address of the HTTP user.
N/A
DisplayString
SIZE(1..80)
1.3.6.1.4.1.25506.2.255.1.1.4 (hh3cHttpUserService)
Service type used by the HTTP user.
N/A
DisplayString
SIZE(1..80)
Recommended action
No action is required.
hh3cHttpUserLoginFail
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.255.2.0.2
Login failure of an HTTP user.
Informational
Warning
N/A (N/A)
ON
This notification is generated when an HTTP user fails to log in.
System impact
No negative impact on the system.
Status control
Object
OID (object name)
Index
Value range
N/A
DisplayString
SIZE(1..80)
N/A
InetAddressType
N/A
DisplayString
SIZE(1..80)
N/A
DisplayString
SIZE(1..80)
Recommended action
This notification is only available for Web login currently. Check whether HTTP service is enabled, the username and password are correct, the verification code is correct and not timed out, and the number of Web users does not reach the upper limit.
If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
hh3cHttpUserLogout
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.255.2.0.3
Successful logout of an HTTP user.
Informational
Warning
N/A (N/A)
ON
This notification is generated when an HTTP user successfully logs out.
System impact
Status control
Object
OID (object name)
Index
Value range
N/A
DisplayString
SIZE(1..80)
N/A
InetAddressType
N/A
DisplayString
SIZE(1..80)
N/A
DisplayString
SIZE(1..80)
Recommended action
