08-HH3C-STRUNK-MIB | 72.92 KB |
(1.3.6.1.4.1.25506.2.208.1.1.2)
hh3cStrunkMemberStatus (1.3.6.1.4.1.25506.2.208.1.1.3)
hh3cStrunkMemberReason (1.3.6.1.4.1.25506.2.208.1.1.4)
hh3cStrunkGroupId (1.3.6.1.4.1.25506.2.208.1.1.5)
(1.3.6.1.4.1.25506.2.208.1.1.6)
(1.3.6.1.4.1.25506.2.208.1.1.7)
HH3C-STRUNK-MIB
About this MIB
This MIB is defined to obtain S-Trunk configuration information and send notifications upon S-Trunk state changes.
MIB file name
hh3c-strunk.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cStrunk(208)
Scalar objects
hh3cStrunkMemberId
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cStrunkMemberId (1.3.6.1.4.1.25506.2.208.1.1.2) |
accessible-for-notify |
Integer32 |
bagg(1), ragg(2) |
Member ID. |
Supported |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cStrunkMemberStatus (1.3.6.1.4.1.25506.2.208.1.1.3) |
Integer32 |
primary(1), secondary(2) |
Member status. |
Supported |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cStrunkMemberReason (1.3.6.1.4.1.25506.2.208.1.1.4) |
OCET STRING |
STRING(SIZE(0..255)) |
Reason for member status change. |
Supported |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cStrunkGroupId (1.3.6.1.4.1.25506.2.208.1.1.5) |
Integer32 |
Standard MIB values. |
Group ID. |
Supported |
hh3cStrunkGroupStatus
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cStrunkGroupStatus (1.3.6.1.4.1.25506.2.208.1.1.6) |
Integer32 |
init(1) primary(2) secondary(3) |
Reason for group status change. |
Supported |
hh3cStrunkGroupReason
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cStrunkGroupReason (1.3.6.1.4.1.25506.2.208.1.1.7) |
OCTET STRING |
Group status. |
Supported |
Notifications
hh3cStrunkMemberStatusChange
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.208.1.0.1 |
The S-Trunk member role of the device changes. |
Informational |
Warning |
ON |
Notification triggers
This notification is generated when the S-Trunk member role of the device changes.
System impact
If the S-Trunk member role of the device changes to primary, the device can forward data.
If the S-Trunk member role of the device changes to secondary, the device cannot forward data.
Status control
This notification cannot be disabled.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.208.1.1.1 (hh3cStrunkMemberType) |
Member type. |
N/A |
Integer32 |
bagg(1),, ragg(2) |
1.3.6.1.4.1.25506.2.208.1.1.2 (hh3cStrunkMemberId) |
Member ID. |
N/A |
Integer32 |
1.3.6.1.4.1.25506.2.208.1.1.3 (hh3cStrunkMemberStatus) |
Member status. |
N/A |
Integer32 |
primary(1),, secondary(2) |
1.3.6.1.4.1.25506.2.208.1.1.4 (hh3cStrunkMemberReason) |
N/A |
OCTET STRING |
Recommended action
No action is required.
hh3cStrunkStatusChange
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.208.1.0.2 |
The status of the S-Trunk group changes. |
Informational |
Warning |
ON |
This notification is generated when the status of the S-Trunk group changes.
System impact
No impact on the system.
Status control
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.208.1.1.5 (hh3cStrunkGroupId) |
Group ID. |
N/A |
Integer32 |
1.3.6.1.4.1.25506.2.208.1.1.6 (hh3cStrunkGroupStatus) |
Group status. |
N/A |
Integer32 |
init(1), primary(2), secondary(3) |
1.3.6.1.4.1.25506.2.208.1.1.7 (hh3cStrunkGroupReason) |
N/A |
OCTET STRING |
Recommended action
