19-High Availability
HomeSupportRoutersCR16000-M SeriesReference GuidesMIB CompanionH3C CR16000-M Routers MIB Reference-R8530Pxx-6W10019-High Availability
01-DOT3-OAM-MIB
01-DOT3-OAM-MIB 149.33 KB
DOT3-OAM-MIB
About this MIB
Ethernet Operation, Administration, and Maintenance (OAM) is a tool that monitors Layer 2 link status. It checks the connectivity of a link by sending OAM protocol data units (OAMPDUs) and reports to the network administrators when a link error occurs.
This MIB focuses on Ethernet OAM functions.
MIB file name
rfc4878-dot3-oam.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).dot3OamMIB(25506)
Tabular objects
dot3OamTable
About this table
This table contains information about basic Ethernet OAM functions of a port.
Support for operations
CreateSupported
Edit/ModifySupported
DeleteSupported
ReadSupported
Columns
The table index is ifIndex.
Object (OID)
Access
Value range
Implementation
dot3OamAdminState (1.3.6.1.2.1.158.1.1.1.1)
read-write
INTEGER
1..2
Whether Ethernet OAM is enabled on the port.
As per the MIB.
dot3OamOperStatus (1.3.6.1.2.1.158.1.1.1.2)
read-only
INTEGER
disabled(1),linkFault(2),passiveWait(3),activeSendLocal(4),sendLocalAndRemote(5),sendLocalAndRemoteOk(6),oamPeeringLocallyRejected(7),oamPeeringRemotelyRejected(8),operational(9),nonOperHalfDuplex(10)
OAM capability of the link when the interface enters discovery state upon initialization or link error of the OAM entities.
As per the MIB.
dot3OamMode (1.3.6.1.2.1.158.1.1.1.3)
read-write
IINTEGER
1...2
OAM mode. Ethernet interfaces have two OAM modes: passive(1) and active(2).
As per the MIB.
dot3OamMaxOamPduSize (1.3.6.1.2.1.158.1.1.1.4)
read-only
Unsigned32
64…1518
Largest OAMPDU that the OAM entity supports.
As per the MIB.
dot3OamConfigRevision (1.3.6.1.2.1.158.1.1.1.5)
read-only
Unsigned32
0…65535
Configuration revision of the local OAM entity.
As per the MIB.
dot3OamFunctionsSupported (1.3.6.1.2.1.158.1.1.1.6)
read-only
BITS
unidirectionalSupport(0),loopbackSupport(1),eventSupport(2),variableSupport(3)
Functions supported by the OAM port.
As per the MIB.
dot3OamPeerTable
About this table
This table contains OAM peer configuration information.
CreateSupported
DeleteSupported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
dot3OamPeerMacAddress (1.3.6.1.2.1.158.1.2.1.1)
read-only
MacAddress
OCTET STRING (6)
Originaltype + valid length.
MAC address of the OAM peer.
As per the MIB.
dot3OamPeerVendorOui (1.3.6.1.2.1.158.1.2.1.2)
read-only
EightOTwoOui
OCTET STRING(3)
Peer OUI.
Not supported
dot3OamPeerVendorInfo (1.3.6.1.2.1.158.1.2.1.3)
read-only
Gauge32
Standard MIB values.
Vendor information of the OAM peer.
Not supported
dot3OamPeerMode (1.3.6.1.2.1.158.1.2.1.4)
read-only
INTEGER
passive(1), active(2),unknown(3)
Mode of the OAM peer.
As per the MIB.
dot3OamPeerMaxOamPduSize (1.3.6.1.2.1.158.1.2.1.5)
read-only
Unsigned32
1:0,2:64…1518
Maximum OAMPDU length of the OAM peer.
As per the MIB.
dot3OamPeerConfigRevision (1.3.6.1.2.1.158.1.2.1.6)
read-only
Unsigned32
0..65535
Configuration revision of the OAM peer.
As per the MIB.
dot3OamPeerFunctionsSupported (1.3.6.1.2.1.158.1.2.1.7)
read-only
BITS
unidirectionalSupport(0), loopbackSupport(1), eventSupport(2), variableSupport(3)
Functions supported by the OAM peer.
As per the MIB.
dot3OamStatsTable
About this table
This table contains OAM statistics information.
CreateSupported
DeleteSupported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
dot3OamInformationTx (1.3.6.1.2.1.158.1.4.1.1)
read-only
Counter32
Number of sent Information OAMPDUs.
As per the MIB.
dot3OamInformationRx (1.3.6.1.2.1.158.1.4.1.2)
read-only
Counter32
Number of received Information OAMPDUs.
As per the MIB.
dot3OamUniqueEventNotificationTx (1.3.6.1.2.1.158.1.4.1.3)
read-only
Counter32
Number of sent unique Event Notification OAMPDUs.
As per the MIB.
dot3OamUniqueEventNotificationRx (1.3.6.1.2.1.158.1.4.1.4)
read-only
Counter32
Number of received unique Event Notification OAMPDUs.
As per the MIB.
dot3OamDuplicateEventNotificationTx (1.3.6.1.2.1.158.1.4.1.5)
read-only
Counter32
Number of sent duplicate Event Notification OAMPDUs.
As per the MIB.
dot3OamDuplicateEventNotificationRx (1.3.6.1.2.1.158.1.4.1.6)
read-only
Counter32
Number of received duplicate Event Notification OAMPDUs.
As per the MIB.
dot3OamLoopbackControlTx (1.3.6.1.2.1.158.1.4.1.7)
read-only
Counter32
Number of sent Loopback Control OAMPDUs.
As per the MIB.
dot3OamLoopbackControlRx (1.3.6.1.2.1.158.1.4.1.8)
read-only
Counter32
Number of received Loopback Control OAMPDUs.
As per the MIB.
dot3OamVariableRequestTx (1.3.6.1.2.1.158.1.4.1.9)
read-only
Counter32
Number of sent Variable Request OAMPDUs.
Not supported
dot3OamVariableRequestRx (1.3.6.1.2.1.158.1.4.1.10)
read-only
Counter32
Number of received Variable Request OAMPDUs.
Not supported
dot3OamVariableResponseTx (1.3.6.1.2.1.158.1.4.1.11)
read-only
Counter32
Number of sent Variable Response OAMPDUs.
Not supported
dot3OamVariableResponseRx (1.3.6.1.2.1.158.1.4.1.12)
read-only
Counter32
Number of received Variable Response OAMPDUs.
Not supported
dot3OamOrgSpecificTx (1.3.6.1.2.1.158.1.4.1.13)
read-only
Counter32
Number of sent Organization Specific OAMPDUs.
Not supported
dot3OamOrgSpecificRx (1.3.6.1.2.1.158.1.4.1.14)
read-only
Counter32
Number of received Organization Specific OAMPDUs.
Not supported
dot3OamUnsupportedCodesTx (1.3.6.1.2.1.158.1.4.1.15)
read-only
Counter32
Number of sent OAMPDUs that do not support operation codes.
Not supported
dot3OamUnsupportedCodesRx (1.3.6.1.2.1.158.1.4.1.16)
read-only
Counter32
Number of received OAMPDUs that do not support operation codes.
Not supported
dot3OamFramesLostDueToOam (1.3.6.1.2.1.158.1.4.1.17)
read-only
Counter32
Number of dropped frames due to OAM.
Not supported
dot3OamEventConfigTable
About this table
This table contains OAM link event detection information.
CreateSupported
DeleteSupported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
dot3OamErrSymPeriodWindowHi (1.3.6.1.2.1.158.1.5.1.1)
read-write
Unsigned32
High 32 bits of the errored symbol event detection window.
Not supported
dot3OamErrSymPeriodWindowLo (1.3.6.1.2.1.158.1.5.1.2)
read-write
Unsigned32
Low 32 bits of the errored symbol event detection window.
Not supported
dot3OamErrSymPeriodThresholdHi (1.3.6.1.2.1.158.1.5.1.3)
read-write
Unsigned32
High 32 bits of the errored symbol event triggering threshold within the detection window.
Not supported
dot3OamErrSymPeriodThresholdLo (1.3.6.1.2.1.158.1.5.1.4)
read-write
Unsigned32
Low 32 bits of the errored symbol event triggering threshold within the detection window.
Not supported
dot3OamErrSymPeriodEvNotifEnable (1.3.6.1.2.1.158.1.5.1.5)
read-write
TruthValue
true(1),
false(2)
Whether errored symbol event notification is enabled.
As per the MIB.
dot3OamErrFramePeriodWindow (1.3.6.1.2.1.158.1.5.1.6)
read-write
Unsigned32
100..60000(V5) 1-65535(V7)
Errored frame period event detection window.
Value range: 1 to 65535.
Default: 1000.
dot3OamErrFramePeriodThreshold (1.3.6.1.2.1.158.1.5.1.7)
read-write
Unsigned32
0.. 4294967295
Errored frame period event triggering threshold.
As per the MIB.
dot3OamErrFramePeriodEvNotifEnable (1.3.6.1.2.1.158.1.5.1.8)
read-write
TruthValue
true(1),
false(2)
Whether errored frame period event notification is enabled.
As per the MIB.
dot3OamErrFrameWindow (1.3.6.1.2.1.158.1.5.1.9)
read-write
Unsigned32
10..600
Errored frame event detection window.
Value range: 10 -600.
Default: 10.
dot3OamErrFrameThreshold (1.3.6.1.2.1.158.1.5.1.10)
read-write
Unsigned32
0.. 4294967295
Errored frame event triggering threshold.
As per the MIB.
dot3OamErrFrameEvNotifEnable (1.3.6.1.2.1.158.1.5.1.11)
read-write
TruthValue
true(1),
false(2)
Whether errored frame event notification is enabled.
As per the MIB.
dot3OamErrFrameSecsSummaryWindow (1.3.6.1.2.1.158.1.5.1.12)
read-write
Integer32
100..9000
Errored frame seconds event detection window.
Value range: 100 to 9000
Default: 600.
dot3OamErrFrameSecsSummaryThreshold (1.3.6.1.2.1.158.1.5.1.13)
read-write
Integer32
1..900
Errored frame seconds event triggering threshold.
As per the MIB.
dot3OamErrFrameSecsEvNotifEnable (1.3.6.1.2.1.158.1.5.1.14)
read-write
TruthValue
true(1),
false(2)
Whether errored frame seconds event notification is enabled.
As per the MIB.
dot3OamDyingGaspEnable (1.3.6.1.2.1.158.1.5.1.15)
read-write
TruthValue
true(1),
false(2)
Whether Dying Gasp notification is enabled.
Not supported
dot3OamCriticalEventEnable (1.3.6.1.2.1.158.1.5.1.16)
read-write
TruthValue
true(1),
false(2)
Whether critical event notification is enabled.
Not supported
dot3OamEventLogTable
About this table
This table contains OAM event log information.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are ifIndex and dot3OamEventLogIndex.
Object (OID)
Access
Value range
Implementation
dot3OamEventLogIndex (1.3.6.1.2.1.158.1.6.1.1)
not-accessible
Unsigned32
1..100
Event index.
As per the MIB.
dot3OamEventLogTimestamp (1.3.6.1.2.1.158.1.6.1.2)
read-only
TimeStamp
Timestamp of the event.
As per the MIB.
dot3OamEventLogOui (1.3.6.1.2.1.158.1.6.1.3)
read-only
EightOTwoOui
OCTET STRING(3)
OUI of the event packet.
As per the MIB.
dot3OamEventLogType (1.3.6.1.2.1.158.1.6.1.4)
read-only
Unsigned32
erroredSymbolEvent(1),erroredFramePeriodEvent(2),erroredFrameEvent(3),erroredFrameSecondsEvent(4),linkFault(256),dyingGaspEvent(257),criticalLinkEvent(258)
Event type.
As per the MIB.
dot3OamEventLogLocation (1.3.6.1.2.1.158.1.6.1.5)
read-only
INTEGER
local(1), remote(2)
Whether the event is a local event or a peer event.
As per the MIB.
dot3OamEventLogWindowHi (1.3.6.1.2.1.158.1.6.1.6)
read-only
Unsigned32
High bits of the event statistics window.
As per the MIB.
dot3OamEventLogWindowLo (1.3.6.1.2.1.158.1.6.1.7)
read-only
Unsigned32
Low bits of the event statistics window.
As per the MIB.
dot3OamEventLogThresholdHi (1.3.6.1.2.1.158.1.6.1.8)
read-only
Unsigned32
High bits of the event statistics threshold.
As per the MIB.
dot3OamEventLogThresholdLo (1.3.6.1.2.1.158.1.6.1.9)
read-only
Unsigned32
Low bits of the event statistics threshold.
As per the MIB.
dot3OamEventLogValue (1.3.6.1.2.1.158.1.6.1.10)
read-only
CounterBasedGauge64
Number of occurrences for the event exceeding the threshold within the window.
As per the MIB.
dot3OamEventLogRunningTotal (1.3.6.1.2.1.158.1.6.1.11)
read-only
CounterBasedGauge64
Total number of occurrences for the running event.
As per the MIB.
dot3OamEventLogEventTotal (1.3.6.1.2.1.158.1.6.1.12)
read-only
Unsigned32
Total number of times the event has occurred.
As per the MIB.
Notifications
dot3OamThresholdEvent
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.2.1.158.0.1
A threshold-crossing event is detected.
Informational
Warning
N/A (N/A)
OFF
Notification triggers
This notification is generated when one of the following threshold-exceeded events occurs on the local or remote end:
Errored symbol event.
Error frame event.
Error frame period event.
Error frame seconds event.
System impact
The link is faulty and service traffic is interrupted.
Status control
ON
MIB: Set dot3OamErrSymEvNotifEnable to true(1).
MIB: Set dot3OamErrFramePeriodEvNotifEnable to true(1).
MIB: Set dot3OamErrFrameEvNotifEnable to true(1).
MIB: Set dot3OamErrFrameSecsEvNotifEnable to true(1).
OFF
MIB: Set dot3OamErrSymEvNotifEnable to false(0)
MIB: Set dot3OamErrFramePeriodEvNotifEnable to false(0).
MIB: Set dot3OamErrFrameEvNotifEnable to false(0).
MIB: Set dot3OamErrFrameSecsEvNotifEnable to false(0).
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.158.1.6.1.2 (dot3OamEventLogTimestamp)
ifIndex
TimeStamp
TimeTicks
1.3.6.1.2.1.158.1.6.1.3 (dot3OamEventLogOui)
ifIndex
EightOTwoOui
OCTET STRING (SIZE (1..255))
1.3.6.1.2.1.158.1.6.1.4 (dot3OamEventLogType)
Event type.
ifIndex
Unsigned32
1.3.6.1.2.1.158.1.6.1.5 (dot3OamEventLogLocation)
ifIndex
INTEGER
local(1), remote(2)
1.3.6.1.2.1.158.1.6.1.6 (dot3OamEventLogWindowHi)
ifIndex
Unsigned32
0..65535
1.3.6.1.2.1.158.1.6.1.7 (dot3OamEventLogWindowLo)
ifIndex
Unsigned32
0..65535
1.3.6.1.2.1.158.1.6.1.8 (dot3OamEventLogThresholdHi)
ifIndex
Unsigned32
1.3.6.1.2.1.158.1.6.1.9 (dot3OamEventLogThresholdLo)
ifIndex
Unsigned32
1.3.6.1.2.1.158.1.6.1.10 (dot3OamEventLogValue)
ifIndex
CounterBasedGauge64
Counter64
1.3.6.1.2.1.158.1.6.1.11 (dot3OamEventLogRunningTotal)
ifIndex
CounterBasedGauge64
Counter64
1.3.6.1.2.1.158.1.6.1.12 (dot3OamEventLogEventTotal)
ifIndex
Unsigned32
Recommended action
Check the link.
dot3OamNonThresholdEvent
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.158.0.2
A non-threshold-crossing event is detected.
Failure
Warning
1.3.6.1.4.1.25506.2.226.1.0.1 (hh3cEthoamNonThresholdRecovery)
ON
This notification is generated when one of the following non-threshold-crossing events is detected on the local or remote end.
Link Fault event.
Dying Gasp event.
Critical Event.
System impact
Status control
The notification cannot be disabled.
Object
OID (object name)
Index
Value range
ifIndex
TimeStamp
TimeTicks
ifIndex
EightOTwoOui
Event type.
ifIndex
Unsigned32
linkFault(256), dyingGaspEvent(257), criticalLinkEvent(258)
ifIndex
INTEGER
local(1), remote(2)
ifIndex
Unsigned32
Recommended action
To resolve the issue, check the value of the EventLogType field in the notification.
If the value is 256, a Link Fault event has occurred on the local or remoted end. Check whether the interface is shut down.
  - If the interface is shut down, execute the undo shutdown command to resolve the issue.
  - If the interface is not shut down, check the physical link.
If the value is 257, a Dying Gasp event has occurred on the local or remoted end. Check whether the device is rebooting.
  - If the device is rebooting, wait for the device to start and then check whether the issue has been resolved.
  - If the device is not rebooting, collect related information and then contact H3C Support.
If the value is 258, a Critical Event has occurred on the remote end. Check the peer device.
