- 08-Layer 3 - IP Services
- 01-HH3C-ARP-RATELIMIT-MIB
- 02-HH3C-ARP-SUPPRESSION-MIB
- 03-HH3C-ARP-TRAP-MIB
- 04-HH3C-BPA-MIB
- 05-HH3C-DHCP-SNOOP2-MIB
- 06-HH3C-DHCP4-CLIENT-MIB
- 07-HH3C-DHCP4-MIB
- 08-HH3C-DHCP6-MIB
- 09-HH3C-FIB-MIB
- 10-HH3C-IP-ADDRESS-MIB
- 11-HH3C-IPFW-MIB
- 12-HH3C-IPV6-ADDRESS-MIB
- 13-HH3C-NAT-MIB
- 14-HH3C-ND-TRAP-MIB
- 15-HH3C-SESSION-MIB
- 16-HH3C-TCP-MIB
- 17-HH3C-DNS-MIB
- 18-IP-MIB
- 19-IPV6-ICMP-MIB
- 20-IPV6-MIB
- 21-IPV6-TCP-MIB
- 22-IPV6-UDP-MIB
- 23-TCP-MIB
- 24-UDP-MIB
| 07-HH3C-DHCP4-MIB | 564.51 KB |
hh3cDhcpServer2Enabled (1.3.6.1.4.1.25506.2.122.1.1.1)
hh3cDhcpServer2AlwaysBroadcast (1.3.6.1.4.1.25506.2.122.1.1.2)
hh3cDhcpServer2IgnoreBootp (1.3.6.1.4.1.25506.2.122.1.1.3)
hh3cDhcpServer2BootpReplyRfc1048 (1.3.6.1.4.1.25506.2.122.1.1.4)
hh3cDhcpServer2Opt82Enabled (1.3.6.1.4.1.25506.2.122.1.1.5)
hh3cDhcpServer2PingNumber (1.3.6.1.4.1.25506.2.122.1.1.6)
hh3cDhcpServer2PingTimeout (1.3.6.1.4.1.25506.2.122.1.1.7)
(1.3.6.1.4.1.25506.2.122.1.1.8)
hh3cDhcpServer2BadNum (1.3.6.1.4.1.25506.2.122.1.2.1)
hh3cDhcpServer2BootpRequestNum (1.3.6.1.4.1.25506.2.122.1.2.2)
hh3cDhcpServer2DiscoverNum (1.3.6.1.4.1.25506.2.122.1.2.3)
hh3cDhcpServer2RequestNum (1.3.6.1.4.1.25506.2.122.1.2.4)
hh3cDhcpServer2DeclineNum (1.3.6.1.4.1.25506.2.122.1.2.5)
hh3cDhcpServer2ReleaseNum (1.3.6.1.4.1.25506.2.122.1.2.6)
(1.3.6.1.4.1.25506.2.122.1.2.7)
(1.3.6.1.4.1.25506.2.122.1.2.8)
(1.3.6.1.4.1.25506.2.122.1.2.9)
(1.3.6.1.4.1.25506.2.122.1.2.10)
(1.3.6.1.4.1.25506.2.122.1.2.11)
(1.3.6.1.4.1.25506.2.122.1.2.12)
(1.3.6.1.4.1.25506.2.122.1.2.13)
h3cDhcpServer2ConflictNum (1.3.6.1.4.1.25506.2.122.1.2.14)
(1.3.6.1.4.1.25506.2.122.1.2.15)
(1.3.6.1.4.1.25506.2.122.1.2.16)
(1.3.6.1.4.1.25506.2.122.1.2.17)
(1.3.6.1.4.1.25506.2.122.1.2.18)
(1.3.6.1.4.1.25506.2.122.1.2.19)
(1.3.6.1.4.1.25506.2.122.1.2.20)
(1.3.6.1.4.1.25506.2.122.1.2.21)
(1.3.6.1.4.1.25506.2.122.1.2.22)
hh3cDhcpSever2IPExcludeTotalNum
(1.3.6.1.4.1.25506.2.122.1.2.23)
hh3cDhcpServer2OnlineFailReason (1.3.6.1.4.1.25506.2.122.1.2.24)
hh3cDhcpServer2IfApplyPoolTable
hh3cDhcpServer2PoolStaticTable
hh3cDhcpServer2PoolOptionTable
hh3cDhcpServer2PoolForbidTable
hh3cDhcpServer2ValidClassTable
hh3cDhcpServer2RuleHwAddrTable
hh3cDhcpServer2OptionGroupTable
hh3cDhcpServer2PoolGpStatTable
hh3cDhcpServer2AddrExhaustRecov
hh3cDhcpServer2IpUsageOverflow
hh3cDhcpServer2IpUsageOverflowRecov
hh3cDhcpServer2NetUsageOverflow
hh3cDhcpServer2NetUsageOverflowRecov
hh3cDhcpServer2GpNetExhaustRecov
hh3cDhcpSvr2GpAddrExhaustRecov
hh3cDhcpServer2OdapReleaseFail
hh3cDhcpSvr2GpUsageOverflowRecov
HH3C-DHCP4-MIB
About this MIB
Use this MIB to configure DHCP, obtain DHCP address allocation information, and configure alarm settings.
MIB file name
hh3c-dhcp4.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cDhcp4(122)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2Enabled (1.3.6.1.4.1.25506.2.122.1.1.1) |
read-write |
TruthValue |
true(1), false(2) |
Enabling status of the DHCP server. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2AlwaysBroadcast (1.3.6.1.4.1.25506.2.122.1.1.2) |
read-write |
TruthValue |
true(1), false(2) |
Whether to enable the DHCP server to broadcast responses. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2IgnoreBootp (1.3.6.1.4.1.25506.2.122.1.1.3) |
read-write |
TruthValue |
true(1), false(2) |
Whether to ignore BOOTP requests. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2BootpReplyRfc1048 (1.3.6.1.4.1.25506.2.122.1.1.4) |
read-write |
TruthValue |
true(1), false(2) |
Whether to enable the sending of BOOTP responses in RFC 1048 format. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2Opt82Enabled (1.3.6.1.4.1.25506.2.122.1.1.5) |
read-write |
TruthValue |
true(1), false(2) |
Whether to enable the DHCP server to handle Option 82. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2PingNumber (1.3.6.1.4.1.25506.2.122.1.1.6) |
read-write |
Unsigned32 |
Unsigned32(0..10) |
Maximum number of attempts that the DHCP server pings an IP address before assigning the IP address to a DHCP client. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2PingTimeout (1.3.6.1.4.1.25506.2.122.1.1.7) |
read-write |
Unsigned32 |
Unsigned32(0..10000) |
Ping response timeout time for the DHCP server to ping an IP address. |
As per the MIB. |
hh3cDhcpServer2AllocThreshold
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2AllocThreshold (1.3.6.1.4.1.25506.2.122.1.1.8) |
read-write |
Unsigned32 |
Unsigned32(0..100) |
IP address allocation success rate threshold. The success rate is the rate of successfully allocated IP addresses to received DHCP requests within a specific time period. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2BadNum (1.3.6.1.4.1.25506.2.122.1.2.1) |
read-only |
Counter64 |
INTEGER(0..18446744073709551615) |
Number of error packets received by the DHCP server. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2BootpRequestNum (1.3.6.1.4.1.25506.2.122.1.2.2) |
read-only |
Counter64 |
Number of BOOTP-REQUEST messages received by the DHCP server. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2DiscoverNum (1.3.6.1.4.1.25506.2.122.1.2.3) |
read-only |
Counter64 |
Number of DHCP-DISCOVER messages received by the DHCP server. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2RequestNum (1.3.6.1.4.1.25506.2.122.1.2.4) |
read-only |
Counter64 |
Number of DHCP-REQUEST messages received by the DHCP server. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2DeclineNum (1.3.6.1.4.1.25506.2.122.1.2.5) |
read-only |
Counter64 |
Number of DHCP-DECLINE messages received by the DHCP server. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2ReleaseNum (1.3.6.1.4.1.25506.2.122.1.2.6) |
read-only |
Counter64 |
Number of DHCP-RELEASE messages received by the DHCP server. |
As per the MIB. |
hh3cDhcpServer2InformNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2InformNum (1.3.6.1.4.1.25506.2.122.1.2.7) |
read-only |
Counter64 |
Number of DHCP-INFORM messages received by the DHCP server. |
As per the MIB. |
hh3cDhcpServer2BootpReplyNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2BootpReplyNum (1.3.6.1.4.1.25506.2.122.1.2.8) |
read-only |
Counter64 |
Number of BOOTP-REPLY messages sent by the DHCP server. |
As per the MIB. |
hh3cDhcpServer2OfferNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2OfferNum (1.3.6.1.4.1.25506.2.122.1.2.9) |
read-only |
Counter64 |
Number of DHCP-OFFER messages sent by the DHCP server. |
As per the MIB. |
hh3cDhcpServer2AckNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2AckNum (1.3.6.1.4.1.25506.2.122.1.2.10) |
read-only |
Counter64 |
Number of DHCP-ACK messages sent by the DHCP server. |
As per the MIB. |
hh3cDhcpServer2NakNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2NakNum (1.3.6.1.4.1.25506.2.122.1.2.11) |
read-only |
Counter64 |
Number of DHCP-NAK messages sent by the DHCP server. |
As per the MIB. |
hh3cDhcpServer2TotalPoolUsage
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2TotalPoolUsage (1.3.6.1.4.1.25506.2.122.1.2.12) |
read-only |
Unsigned32 |
DHCP address pool usage. |
As per the MIB. |
hh3cDhcpServer2PoolNumber
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2PoolNumber (1.3.6.1.4.1.25506.2.122.1.2.13) |
read-only |
Unsigned32 |
Standard MIB values. |
Number of DHCP address pools. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
h3cDhcpServer2ConflictNum (1.3.6.1.4.1.25506.2.122.1.2.14) |
read-only |
Unsigned32 |
Total number of conflicting IP addresses on the DHCP server. |
As per the MIB. |
hh3cDhcpServer2AutoBindNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2AutoBindNum (1.3.6.1.4.1.25506.2.122.1.2.15) |
read-only |
Unsigned32 |
Number of dynamic DHCP bindings. |
As per the MIB. |
hh3cDhcpServer2ManualBindNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2ManualBindNum (1.3.6.1.4.1.25506.2.122.1.2.16) |
read-only |
Unsigned32 |
Number of static DHCP bindings. |
As per the MIB. |
hh3cDhcpServer2ExpiredBindNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2ExpiredBindNum (1.3.6.1.4.1.25506.2.122.1.2.17) |
read-only |
Unsigned32 |
Number of expired DHCP bindings. |
As per the MIB. |
hh3cDhcpServer2ReqCnt
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2ReqCnt (1.3.6.1.4.1.25506.2.122.1.2.18) |
read-only |
Counter64 |
Number of address requests received by the DHCP server. |
As per the MIB. |
hh3cDhcpServer2ReqSuccCnt
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2ReqSuccCnt (1.3.6.1.4.1.25506.2.122.1.2.19) |
read-only |
Counter64 |
Number of address requests that the DHCP server processed successfully. |
As per the MIB. |
hh3cDhcpServer2IPTotalNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2IPTotalNum (1.3.6.1.4.1.25506.2.122.1.2.20) |
read-only |
Unsigned32 |
Total number of IP addresses in all DHCP address pools on the DHCP server. |
As per the MIB. |
hh3cDhcpServer2IPUsedNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2IPUsedNum (1.3.6.1.4.1.25506.2.122.1.2.21) |
read-only |
Unsigned32 |
Number of assigned IP addresses on the DHCP server. |
As per the MIB. |
hh3cDhcpServer2IPIdleNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2IPIdleNum (1.3.6.1.4.1.25506.2.122.1.2.22) |
read-only |
Unsigned32 |
Number of free IP addresses on the DHCP server. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpSever2IPExcludeTotalNum (1.3.6.1.4.1.25506.2.122.1.2.23) |
read-only |
Unsigned32 |
Number of IP addresses excluded from dynamic address allocation on the DHCP server. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2OnlineFailReason (1.3.6.1.4.1.25506.2.122.1.2.24) |
accessible-for-notify |
OCTET STRING |
Reason for the DHCP server online failure. |
As per the MIB. |
Tabular objects
hh3cDhcpServer2PoolTable
About this table
This table records the address pool configuration on a DHCP server.
Support for operations
Create:Supported. When you create a new address pool, this table automatically creates an instance for the pool.
Edit/Modify:Supported
Delete:Supported
Read:Supported
Columns
The table index is h3cDhcpServer2PoolIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2PoolIndex (1.3.6.1.4.1.25506.2.122.2.1.1.1) |
Unsigned32 |
DHCP address pool index. |
Implementation varies by product. |
hh3cDhcpServer2PoolName (1.3.6.1.4.1.25506.2.122.2.1.1.2) |
read-create |
OCTET STRING |
OCTET STRING (1..63) |
DHCP address pool name. |
As per the MIB. |
hh3cDhcpServer2PoolVpnName (1.3.6.1.4.1.25506.2.122.2.1.1.3) |
read-create |
OCTET STRING |
OCTET STRING (0..31) |
VPN to which the DHCP address pool is bound. |
As per the MIB. |
hh3cDhcpServer2PoolNetwork (1.3.6.1.4.1.25506.2.122.2.1.1.4) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
Primary network address of the DHCP address pool. |
As per the MIB. |
hh3cDhcpServer2PoolNetworkMask (1.3.6.1.4.1.25506.2.122.2.1.1.5) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
Mask for the primary network address. |
As per the MIB. |
hh3cDhcpServer2PoolStartAddr (1.3.6.1.4.1.25506.2.122.2.1.1.6) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
Start IP address of an IP address range in the DHCP address pool. |
As per the MIB. |
hh3cDhcpServer2PoolEndAddr (1.3.6.1.4.1.25506.2.122.2.1.1.7) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
End IP address of an IP address range in the DHCP address pool. |
As per the MIB. |
hh3cDhcpServer2PoolLeaseDay (1.3.6.1.4.1.25506.2.122.2.1.1.8) |
read-create |
Integer32 |
Integer32(0..365) |
Lease duration in days. |
As per the MIB. |
hh3cDhcpServer2PoolLeaseHour (1.3.6.1.4.1.25506.2.122.2.1.1.9) |
read-create |
Integer32 |
Integer32 (0..23) |
Lease duration in hours. |
As per the MIB. |
hh3cDhcpServer2PoolLeaseMinute (1.3.6.1.4.1.25506.2.122.2.1.1.10) |
read-create |
Integer32 |
Integer32 (0..59) |
Lease duration in minutes. |
As per the MIB. |
hh3cDhcpServer2PoolLeaseSecond (1.3.6.1.4.1.25506.2.122.2.1.1.11) |
read-create |
Integer32 |
Integer32 (0..59) |
Lease duration in seconds. |
As per the MIB. |
hh3cDhcpServer2PoolLeaseUnlimit (1.3.6.1.4.1.25506.2.122.2.1.1.12) |
read-create |
TruthValue |
true(1), false(2) |
Whether the lease duration is unlimited. |
As per the MIB. |
hh3cDhcpServer2PoolLeaseTime (1.3.6.1.4.1.25506.2.122.2.1.1.13) |
read-create |
TimeTicks |
DHCP lease time in TimeTicks |
As per the MIB. |
hh3cDhcpServer2PoolDomainName (1.3.6.1.4.1.25506.2.122.2.1.1.14) |
read-create |
OCTET STRING |
Domain name assigned to DHCP clients. |
As per the MIB. |
hh3cDhcpServer2PoolGatewayIP (1.3.6.1.4.1.25506.2.122.2.1.1.15) |
read-create |
OCTET STRING |
OCTET STRING (0..127) |
Gateway IP address. |
As per the MIB. |
hh3cDhcpServer2PoolDNSIP(1.3.6.1.4.1.25506.2.122.2.1.1.16) |
read-create |
OCTET STRING |
DNS server IP address. |
As per the MIB. |
hh3cDhcpServer2PoolPrimaryDNSIP (1.3.6.1.4.1.25506.2.122.2.1.1.17) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
Primary DNS server IP address. |
As per the MIB. |
hh3cDhcpServer2PoolSecondDNSIP (1.3.6.1.4.1.25506.2.122.2.1.1.18) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
Secondary DNS server IP address. |
As per the MIB. |
hh3cDhcpServer2PoolNetbiosType (1.3.6.1.4.1.25506.2.122.2.1.1.19) |
read-create |
INTEGER |
null(0), bnode(1), pnode(2), mnode(4), hnode(8) |
NETBIOS node type. |
As per the MIB. |
hh3cDhcpServer2PoolNbnsIP(1.3.6.1.4.1.25506.2.122.2.1.1.20) |
read-create |
OCTET STRING |
SIZE(0..127) |
NETBIOS server IP address. |
As per the MIB. |
hh3cDhcpServer2PoolBootFileName (1.3.6.1.4.1.25506.2.122.2.1.1.21) |
read-create |
OCTET STRING |
SIZE(0..63) |
Name of a configuration file to be assigned to DHCP clients. |
As per the MIB. |
hh3cDhcpServer2PoolBimsIP(1.3.6.1.4.1.25506.2.122.2.1.1.22) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
BIMS server IP address. |
As per the MIB. |
hh3cDhcpServer2PoolBimsPort (1.3.6.1.4.1.25506.2.122.2.1.1.23) |
read-create |
Unsigned32 |
Unsigned32(0..65534) |
BIMS server port number. |
As per the MIB. |
hh3cDhcpServer2PoolBimsKeyStr (1.3.6.1.4.1.25506.2.122.2.1.1.24) |
read-create |
OCTET STRING |
OCTET STRING (0..16) |
Shared key for the DHCP clients to encrypt packets sent to the BIMS server. |
Does not support GET. |
hh3cDhcpServer2PoolNextServer (1.3.6.1.4.1.25506.2.122.2.1.1.25) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
IP address of the next DHCP server. |
As per the MIB. |
hh3cDhcpServer2PoolTftpDomName (1.3.6.1.4.1.25506.2.122.2.1.1.26) |
read-create |
OCTET STRING |
OCTET STRING (0..63) |
TFTP server domain name. |
As per the MIB. |
hh3cDhcpServer2PoolTftpIP (1.3.6.1.4.1.25506.2.122.2.1.1.27) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
TFTP server IP address. |
As per the MIB. |
hh3cDhcpServer2PoolVoiceAsIP (1.3.6.1.4.1.25506.2.122.2.1.1.28) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
IP address of the backup network calling processor. |
As per the MIB. |
hh3cDhcpServer2PoolVoiceFailIP (1.3.6.1.4.1.25506.2.122.2.1.1.29) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
Failover IP address. |
As per the MIB. |
hh3cDhcpServer2PoolVoiceFailStr (1.3.6.1.4.1.25506.2.122.2.1.1.30) |
read-create |
OCTET STRING |
OCTET STRING (0..39) |
Failover dialer string. |
As per the MIB. |
hh3cDhcpServer2PoolVoiceNCPIP (1.3.6.1.4.1.25506.2.122.2.1.1.31) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
IP address of the primary network calling processor. |
As per the MIB. |
hh3cDhcpServer2PoolVoiceVlanId (1.3.6.1.4.1.25506.2.122.2.1.1.32) |
read-create |
Unsigned32 |
Unsigned32(2..4094|65535) |
Voice VLAN ID. |
As per the MIB. |
hh3cDhcpServer2PoolVoiceVlanEnbl (1.3.6.1.4.1.25506.2.122.2.1.1.33) |
read-create |
TruthValue |
true(1), false(2) |
Enabling status of the voice VLAN. |
As per the MIB. |
hh3cDhcpServer2PoolRowStatus (1.3.6.1.4.1.25506.2.122.2.1.1.34) |
read-create |
RowStatus |
Active(1) createAndGo(4) destroy(6) |
Row status. |
As per the MIB. |
hh3cDhcpServer2PoolVerifyClass(1.3.6.1.4.1.25506.2.122.2.1.1.35) |
read-create |
TruthValue |
true(1), false(2) |
Enabling status of the user class whitelist. |
As per the MIB. |
hh3cDhcpServer2PoolThreshold (1.3.6.1.4.1.25506.2.122.2.1.1.36) |
read-create |
Unsigned32 |
IP address usage threshold for the address pool. |
As per the MIB. |
About this table
This table records the address pool bound to an interface.
Create:Not supported
Delete:Not supported
Read:Supported
Columns
The table index is ifIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2IfApplyPoolName (1.3.6.1.4.1.25506.2.122.2.2.1.1) |
read-write |
OCTET STRING |
Name of the address pool bound to an interface. |
As per the MIB. |
hh3cDhcpServer2PoolSecNwTable
About this table
This table records the secondary network configuration in the DHCP address pool.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table indexes are h3cDhcpServer2PoolIndex, h3cDhcpServer2PoolSecNw, and h3cDhcpServer2PoolSecNwMask.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2PoolSecNw(1.3.6.1.4.1.25506.2.122.2.3.1.1) |
not-accessible |
InetAddressIPv4 |
OCTET STRING (4) |
Secondary network IP address. |
As per the MIB. |
hh3cDhcpServer2PoolSecNwMask (1.3.6.1.4.1.25506.2.122.2.3.1.2) |
not-accessible |
InetAddressIPv4 |
OCTET STRING (4) |
Mask of the secondary network IP address. |
As per the MIB. |
hh3cDhcpServer2PoolSecNwGwIP (1.3.6.1.4.1.25506.2.122.2.3.1.3) |
read-create |
OCTET STRING |
Gateway IP address for the secondary network. |
As per the MIB. |
hh3cDhcpServer2PoolSecNwStatus (1.3.6.1.4.1.25506.2.122.2.3.1.4) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
hh3cDhcpServer2PoolClassTable
About this table
This table records address ranges for DHCP user classes in a DHCP address pool on a DHCP server.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2PoolClassName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2PoolClassName (1.3.6.1.4.1.25506.2.122.2.4.1.1) |
not-accessible |
OCTET STRING |
User class name. |
As per the MIB. |
hh3cDhcpServer2PoolClassStart (1.3.6.1.4.1.25506.2.122.2.4.1.2) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
Start IP address of an address range for a DHCP user class. |
As per the MIB. |
hh3cDhcpServer2PoolClassEnd (1.3.6.1.4.1.25506.2.122.2.4.1.3) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
End IP address of an address range for a DHCP user class. |
As per the MIB. |
hh3cDhcpServer2PoolClassStatus (1.3.6.1.4.1.25506.2.122.2.4.1.4) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
About this table
This table records static bindings in a DHCP address pool.
Create:Supported
Edit/Modify:Not supported
Delete:Supported
Read:Supported
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2PoolStaticIP.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2PoolStaticIP (1.3.6.1.4.1.25506.2.122.2.5.1.1) |
not-accessible |
InetAddressIPv4 |
OCTET STRING (4) |
IP address in a static binding. |
As per the MIB. |
hh3cDhcpServer2PoolStaticMask (1.3.6.1.4.1.25506.2.122.2.5.1.2) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
IP address mask in the static binding. |
As per the MIB. |
hh3cDhcpServer2PoolStaticCID (1.3.6.1.4.1.25506.2.122.2.5.1.3) |
read-create |
OCTET STRING |
OCTET STRING (0|4..254) |
Client identifier in the static binding. |
As per the MIB. |
hh3cDhcpServer2PoolStaticHAddr (1.3.6.1.4.1.25506.2.122.2.5.1.4) |
read-create |
OCTET STRING |
OCTET STRING (0|4..39) |
Hardware address in the static binding. |
As per the MIB. |
hh3cDhcpServer2PoolStaticHType (1.3.6.1.4.1.25506.2.122.2.5.1.5) |
read-create |
INTEGER |
default(1), ethernet(2), tokenRing(3) |
Hardware address type. |
As per the MIB. |
hh3cDhcpServer2PoolStaticStatus (1.3.6.1.4.1.25506.2.122.2.5.1.6) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
About this table
This table records user-defined options in the DHCP address pool.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2PoolOptCode.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2PoolOptCode (1.3.6.1.4.1.25506.2.122.2.6.1.1) |
not-accessible |
Integer32 |
Integer32(2..254), excluding 50..54, 56, 58, 59, 61, 82. |
Option code. |
As per the MIB. |
hh3cDhcpServer2PoolOptType (1.3.6.1.4.1.25506.2.122.2.6.1.2) |
read-create |
INTEGER |
ascii(1), hex(2), ip(3) |
Option type. |
As per the MIB. |
hh3cDhcpServer2PoolOptAscii (1.3.6.1.4.1.25506.2.122.2.6.1.3) |
read-create |
OCTET STRING |
OCTET STRING (0..255) |
ASCII string as the option content. |
As per the MIB. |
hh3cDhcpServer2PoolOptHexStr (1.3.6.1.4.1.25506.2.122.2.6.1.4) |
read-create |
OCTET STRING |
OCTET STRING (0..510) |
Hexadecimal number as the option content. |
The string length cannot exceed 256. |
hh3cDhcpServer2PoolOptIPStr (1.3.6.1.4.1.25506.2.122.2.6.1.5) |
read-create |
OCTET STRING |
IP address as the option content. |
As per the MIB. |
hh3cDhcpServer2PoolOptRowStatus (1.3.6.1.4.1.25506.2.122.2.6.1.6) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
About this table
This table records excluded IP addresses in a DHCP address pool.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2PoolForbidIP.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2PoolForbidIP (1.3.6.1.4.1.25506.2.122.2.7.1.1) |
not-accessible |
InetAddressIPv4 |
IP address excluded from dynamic allocation. |
As per the MIB. |
hh3cDhcpServer2PoolForbidStatus (1.3.6.1.4.1.25506.2.122.2.7.1.2) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
hh3cDhcpServer2ClassTable
About this table
This table records DHCP user class information.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table index is h3cDhcpServer2ClassName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2ClassName (1.3.6.1.4.1.25506.2.122.2.8.1.1) |
not-accessible |
OCTET STRING |
User class name. |
As per the MIB. |
hh3cDhcpServer2ClassRowStatus (1.3.6.1.4.1.25506.2.122.2.8.1.2) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
hh3cDhcpServer2RuleTable
About this table
This table records DHCP user class match rules.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table indexes are h3cDhcpServer2ClassName and h3cDhcpServer2RuleNumber.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2RuleNumber (1.3.6.1.4.1.25506.2.122.2.9.1.1) |
not-accessible |
Integer32 |
Integer32(1..16) |
Rule ID. |
As per the MIB. |
hh3cDhcpServer2RuleOptCode (1.3.6.1.4.1.25506.2.122.2.9.1.2) |
read-create |
Integer32 |
Integer32(1..254) |
Option code. |
As per the MIB. |
hh3cDhcpServer2RuleOptHexStr (1.3.6.1.4.1.25506.2.122.2.9.1.3) |
read-create |
OCTET STRING |
Content to match specific options in packets. |
The length of the content cannot exceed 256. |
hh3cDhcpServer2RuleOptMask (1.3.6.1.4.1.25506.2.122.2.9.1.4) |
read-create |
OCTET STRING |
Hexadecimal mask for the match operation. |
If it is bound to hh3cDhcpServer2RuleOptHexStr, the entire command length cannot exceed 512. |
hh3cDhcpServer2RuleOptOffset (1.3.6.1.4.1.25506.2.122.2.9.1.5) |
read-create |
Integer32 |
Integer32(0..254) |
Offset in bytes after which the match operation starts |
As per the MIB. |
hh3cDhcpServer2RuleOptLength (1.3.6.1.4.1.25506.2.122.2.9.1.6) |
read-create |
Integer32 |
Integer32(0..255) |
Length of the option content to be matched. |
As per the MIB. |
hh3cDhcpServer2RuleRowStatus (1.3.6.1.4.1.25506.2.122.2.9.1.7) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
hh3cDhcpServer2ForbidTable
About this table
This table records excluded IP address ranges.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table indexes are h3cDhcpServer2ForbidVpnName, h3cDhcpServer2ForbidStart, and h3cDhcpServer2ForbidEnd.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2ForbidVpnName (1.3.6.1.4.1.25506.2.122.2.10.1.1) |
not-accessible |
OCTET STRING |
OCTET STRING (1..31) |
Name of the VPN to which the excluded IP address belongs. |
As per the MIB. |
hh3cDhcpServer2ForbidStart (1.3.6.1.4.1.25506.2.122.2.10.1.2) |
not-accessible |
InetAddressIPv4 |
OCTET STRING (4) |
Start IP address of the excluded IP address range. |
As per the MIB. |
hh3cDhcpServer2ForbidEnd (1.3.6.1.4.1.25506.2.122.2.10.1.3) |
not-accessible |
InetAddressIPv4 |
OCTET STRING (4) |
End IP address of the excluded IP address range. |
As per the MIB. |
hh3cDhcpServer2ForbidRowStatus (1.3.6.1.4.1.25506.2.122.2.10.1.4) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
hh3cDhcpServer2FreeTable
About this table
This table records free IP address ranges on a DHCP server.
Read:Supported
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2FreeStart.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2FreeStart (1.3.6.1.4.1.25506.2.122.2.11.1.1) |
not-accessible |
InetAddressIPv4 |
Start IP address of a free IP address range. |
As per the MIB. |
hh3cDhcpServer2FreeEnd (1.3.6.1.4.1.25506.2.122.2.11.1.2) |
read-only |
InetAddressIPv4 |
End IP address of a free IP address range. |
As per the MIB. |
hh3cDhcpServer2ConflictTable
About this table
This table records conflicting IP addresses on a DHCP server.
Delete:Supported
Read:Supported
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2ConflictIP.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2ConflictIP (1.3.6.1.4.1.25506.2.122.2.12.1.1) |
not-accessible |
InetAddressIPv4 |
Conflicting IP address. |
As per the MIB. |
hh3cDhcpServer2ConflictType (1.3.6.1.4.1.25506.2.122.2.12.1.2) |
read-only |
INTEGER |
detectByServer(1), detectByClient(2) |
Conflict type. |
As per the MIB. |
hh3cDhcpServer2ConflictTime (1.3.6.1.4.1.25506.2.122.2.12.1.3) |
read-only |
OCTET STRING |
OCTET STRING (1..19) |
Time when the conflict was detected. |
As per the MIB. |
hh3cDhcpServer2ConflictRowStatus (1.3.6.1.4.1.25506.2.122.2.12.1.4) |
read-create |
RowStatus |
destroy |
Row status. |
As per the MIB. |
hh3cDhcpServer2ExpiredTable
About this table
This table records lease expiration information on a DHCP server.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2ExpiredIP.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2ExpiredIP (1.3.6.1.4.1.25506.2.122.2.13.1.1) |
not-accessible |
InetAddressIPv4 |
Expired IP address. |
As per the MIB. |
hh3cDhcpServer2ExpiredClientId (1.3.6.1.4.1.25506.2.122.2.13.1.2) |
read-only |
OCTET STRING |
OCTET STRING (4..254) |
ID of the DHCP client of the expired IP address. |
As per the MIB. |
hh3cDhcpServer2ExpiredTime (1.3.6.1.4.1.25506.2.122.2.13.1.3) |
read-only |
OCTET STRING |
OCTET STRING (1..19), a time string in the format of MM/DD/YYYY hh:mm:ss. |
Time when the lease expired. |
As per the MIB. |
hh3cDhcpServer2ExpiredRowStatus (1.3.6.1.4.1.25506.2.122.2.13.1.4) |
read-create |
RowStatus |
destroy |
Row status. |
As per the MIB. |
hh3cDhcpServer2IPInUseTable
About this table
This table records binding information about IP addresses in use on a DHCP server.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2IPInUseIP.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2IPInUseIP (1.3.6.1.4.1.25506.2.122.2.14.1.1) |
not-accessible |
InetAddressIPv4 |
OCTET STRING (4) |
IP address in use. |
As per the MIB. |
hh3cDhcpServer2IPInUseClientId (1.3.6.1.4.1.25506.2.122.2.14.1.2) |
read-only |
OCTET STRING |
Client ID of the IP address. |
As per the MIB. |
hh3cDhcpServer2IPInUseHardAddr (1.3.6.1.4.1.25506.2.122.2.14.1.3) |
read-only |
OCTET STRING |
Hardware address of the DHCP client. |
As per the MIB. |
hh3cDhcpServer2IPInUseHardType (1.3.6.1.4.1.25506.2.122.2.14.1.4) |
read-only |
INTEGER |
As per the MIB. |
hh3cDhcpServer2IPInUseVlanId (1.3.6.1.4.1.25506.2.122.2.14.1.5) |
read-only |
Unsigned32 |
Unsigned32(1..4094 | 65535) |
VLAN where the DHCP client resides. |
As per the MIB. |
hh3cDhcpServer2IPInUseEndLease (1.3.6.1.4.1.25506.2.122.2.14.1.6) |
read-only |
OCTET STRING |
Lease expiration time. |
As per the MIB. |
hh3cDhcpServer2IPInUseType (1.3.6.1.4.1.25506.2.122.2.14.1.7) |
read-only |
INTEGER |
staticUnallocated(1), staticOffered(2), staticCommitted(3), autoOffered(4), autoCommitted(5) |
Binding type. |
As per the MIB. |
hh3cDhcpServer2IPInUseIfIndex (1.3.6.1.4.1.25506.2.122.2.14.1.8) |
read-only |
InterfaceIndexOrZero |
Integer32(0..2147483647) |
Index of the interface that connects to the DHCP client. |
As per the MIB. |
hh3cDhcpServer2IPInUseRowStatus (1.3.6.1.4.1.25506.2.122.2.14.1.9) |
read-create |
RowStatus |
destroy |
Row status. |
As per the MIB. |
hh3cDhcpServer2IPInUseSecondVlanId (1.3.6.1.4.1.25506.2.122.2.14.1.10) |
read-only |
Unsigned32 |
Inner VLAN (customer VLAN) tag contained in the DHCP request. |
As per the MIB. |
hh3cDhcpServer2DefOptGrpTable
About this table
This table defines option information associated with the DHCP user class.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2DefOptGrpClass.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2DefOptGrpClass (1.3.6.1.4.1.25506.2.122.2.15.1.1) |
not-accessible |
OCTET STRING |
User class name. |
As per the MIB. |
hh3cDhcpServer2DefOptGrpId (1.3.6.1.4.1.25506.2.122.2.15.1.2) |
read-create |
Integer32 |
Integer32(1..32768) |
Option group ID. |
As per the MIB. |
hh3cDhcpServer2DefOptGrpStatus(1.3.6.1.4.1.25506.2.122.2.15.1.3) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
About this table
This table defines user class whitelist.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2ValidClassName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2ValidClassName (1.3.6.1.4.1.25506.2.122.2.16.1.1) |
not-accessible |
OCTET STRING |
User class name. |
As per the MIB. |
hh3cDhcpServer2ValidClassStatus (1.3.6.1.4.1.25506.2.122.2.16.1.2) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
About this table
This table defines the user class hardware address match rule.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table indexes are h3cDhcpServer2ClassName and h3cDhcpServer2RuleHwAddrNumber.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2RuleHwAddrNumber (1.3.6.1.4.1.25506.2.122.2.17.1.1) |
not-accessible |
Integer32 |
Integer32 (1..16) |
Rule ID. |
As per the MIB. |
hh3cDhcpServer2RuleHwAddress (1.3.6.1.4.1.25506.2.122.2.17.1.2) |
read-create |
OCTET STRING |
OCTET STRING (4..39) |
Hardware address. |
As per the MIB. |
hh3cDhcpServer2RuleHwAddrMask (1.3.6.1.4.1.25506.2.122.2.17.1.3) |
read-create |
OCTET STRING |
Hardware address mask. |
As per the MIB. |
hh3cDhcpServer2RuleHwAddrType (1.3.6.1.4.1.25506.2.122.2.17.1.4) |
read-create |
Integer32 |
1, representing the Ethernet |
As per the MIB. |
hh3cDhcpServer2RuleHwAddrStatus (1.3.6.1.4.1.25506.2.122.2.17.1.5) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
About this table
This table defines a DHCP option group for a DHCP user class.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table index is h3cDhcpServer2OptionGroupId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2OptionGroupId (1.3.6.1.4.1.25506.2.122.2.18.1.1) |
not-accessible |
Integer32 |
Option group ID. |
As per the MIB. |
hh3cDhcpServer2OptionGroupStatus (1.3.6.1.4.1.25506.2.122.2.18.1.2) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
hh3cDhcpServer2OptionTable
About this table
This table defines user option information in a DHCP option group.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table indexes are h3cDhcpServer2OptionGroupId and h3cDhcpServer2OptionCode.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2OptionCode (1.3.6.1.4.1.25506.2.122.2.19.1.1) |
not-accessible |
Integer32 |
Integer32(2..254),excluding 50..54, 56, 58, 59, 61, 82 |
Option code. |
As per the MIB. |
hh3cDhcpServer2OptionType (1.3.6.1.4.1.25506.2.122.2.19.1.2) |
read-create |
INTEGER |
Option type. |
As per the MIB. |
hh3cDhcpServer2OptionAscii (1.3.6.1.4.1.25506.2.122.2.19.1.3) |
read-create |
OCTET STRING |
OCTET STRING(0..255) |
The value read from this object is 0 if ascii(1) is specified as the option type but no ASCII string is specified. |
hh3cDhcpServer2OptionHexStr (1.3.6.1.4.1.25506.2.122.2.19.1.4) |
read-create |
OCTET STRING |
OCTET STRING(0|2..510) |
The value read from this object is 0 if hex(2) is specified as the option type but no hexadecimal string is specified. |
hh3cDhcpServer2OptionIPStr (1.3.6.1.4.1.25506.2.122.2.19.1.5) |
read-create |
OCTET STRING |
OCTET STRING(0..127) |
As per the MIB. |
hh3cDhcpServer2OptionRowStatus (1.3.6.1.4.1.25506.2.122.2.19.1.6) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
hh3cDhcpServer2PoolStatTable
About this table
This table records DHCP address pool statistics.
Read:Supported
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2PoolUsage (1.3.6.1.4.1.25506.2.122.2.20.1.1) |
read-only |
Unsigned32 |
IP address usage of the address pool. |
As per the MIB. |
hh3cDhcpServer2PoolReqCnt (1.3.6.1.4.1.25506.2.122.2.20.1.2) |
read-only |
Counter64 |
Number of address requests received by the address pool. |
As per the MIB. |
hh3cDhcpServer2PoolReqSuccCnt (1.3.6.1.4.1.25506.2.122.2.20.1.3) |
read-only |
Counter64 |
Number of successfully processed received requests in the address pool. |
As per the MIB. |
hh3cDhcpServer2PoolDiscoverCnt (1.3.6.1.4.1.25506.2.122.2.20.1.4) |
read-only |
Counter64 |
Number of DHCP-DISCOVER messages received by the address pool. |
As per the MIB. |
hh3cDhcpServer2PoolOfferCnt (1.3.6.1.4.1.25506.2.122.2.20.1.5) |
read-only |
Counter64 |
Number of DHCP-OFFER messages sent by the address pool. |
As per the MIB. |
hh3cDhcpServer2PoolAckCnt (1.3.6.1.4.1.25506.2.122.2.20.1.6) |
read-only |
Counter64 |
Number of DHCP-ACK messages sent by the address pool. |
As per the MIB. |
hh3cDhcpServer2PoolIPTotalNum (1.3.6.1.4.1.25506.2.122.2.20.1.7) |
read-only |
Unsigned32 |
Total number of addresses in the address pool. |
As per the MIB. |
hh3cDhcpServer2PoolIPUsedNum (1.3.6.1.4.1.25506.2.122.2.20.1.8) |
read-only |
Unsigned32 |
Number of assigned IP addresses in the address pool. |
As per the MIB. |
hh3cDhcpServer2PoolIPIdleNum (1.3.6.1.4.1.25506.2.122.2.20.1.9) |
read-only |
Unsigned32 |
Number of free IP addresses in the address pool. |
As per the MIB. |
hh3cDhcpServer2PoolIPExcludeNum (1.3.6.1.4.1.25506.2.122.2.20.1.10) |
read-only |
Unsigned32 |
Number of excluded IP addresses in the address pool. |
As per the MIB. |
hh3cDhcpServer2PoolConflictNum (1.3.6.1.4.1.25506.2.122.2.20.1.11) |
read-only |
Unsigned32 |
Number of conflicting IP addresses in the address pool. |
As per the MIB. |
hh3cDhcpServer2PoolAutoBindNum (1.3.6.1.4.1.25506.2.122.2.20.1.12) |
read-only |
Unsigned32 |
Number of dynamic IP bindings in the address pool. |
As per the MIB. |
hh3cDhcpServer2PoolManualBindNum (1.3.6.1.4.1.25506.2.122.2.20.1.13) |
read-only |
Unsigned32 |
Number of static IP bindings in the address pool. |
As per the MIB. |
hh3cDhcpServer2PoolExpiredBindNum (1.3.6.1.4.1.25506.2.122.2.20.1.14) |
read-only |
Unsigned32 |
Number of expired IP bindings in the address pool. |
As per the MIB. |
hh3cDhcpServer2PoolNameInfo (1.3.6.1.4.1.25506.2.122.2.20.1.15) |
read-create |
OCTET STRING |
As per the MIB. |
hh3cDhcpServer2PoolReserveIpNum (1.3.6.1.4.1.25506.2.122.2.20.1.16) |
read-only |
Unsigned32 |
Number of reserved IP addresses in the pool. |
As per the MIB. |
hh3cDhcpServer2PoolGpTable
About this table
This table defines DHCP pool group information.
Create:Supported.
It must be bound to h3cDhcpServer2PoolGroupName when you create an entry.
Edit/Modify:Not editable after you create hh3cDhcp6Server2PoolGroupName.
Read:Not supported
Columns
The table index is hh3cDhcpServer2PoolGpName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2PoolGpName (1.3.6.1.4.1.25506.2.122.2.21.1.1) |
read-only |
OCTET STRING |
DHCP pool group name. |
hh3cDhcpServer2PoolGpVpnName (1.3.6.1.4.1.25506.2.122.2.21.1.2) |
read-create |
OCTET STRING |
VPN instance to which the DHCP pool group is applied. |
As per the MIB. |
hh3cDhcpServer2PoolGpIncUndo (1.3.6.1.4.1.25506.2.122.2.21.1.3) |
read-write |
TruthValue |
Deleting all pools from the DHCP pool group. |
As per the MIB. |
hh3cDhcpServer2PoolGpRowSta (1.3.6.1.4.1.25506.2.122.2.21.1.4) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
hh3cDhcpServer2PoolGpExtTable
About this table
This table defines DHCP pool information for a DHCP pool group.
Create:Supported.
It must be bound to hh3cDhcpServer2PoolGroupName when you create an entry.
The pool must have been created.
Edit/Modify:Not supported.
Read:Not supported
Columns
The table indexes are hh3cDhcpServer2PoolIndex and hh3cDhcpServer2PoolGpName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
read-only |
OCTET STRING |
DHCP pool name. |
As per the MIB. |
hh3cDhcpServer2PoolGpExtRowSta (1.3.6.1.4.1.25506.2.122.2.22.1.2) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
About this table
This table records DHCP pool group statistics.
Create:Not supported.
Read:Supported
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2PoolGpPoolNum (1.3.6.1.4.1.25506.2.122.2.23.1.1) |
read-only |
Unsigned32 |
Number of IP pools in the DHCP pool group. |
As per the MIB. |
hh3cDhcpServer2PoolGpBndDomNum (1.3.6.1.4.1.25506.2.122.2.23.1.2) |
read-only |
Counter64 |
Number of domains specified for the DHCP pool group. |
As per the MIB. |
hh3cDhcpServer2PoolGpUsage (1.3.6.1.4.1.25506.2.122.2.23.1.3) |
read-only |
Counter64 |
IP address usage of the DHCP pool group. |
As per the MIB. |
hh3cDhcpServer2PoolGpIPTotalNum (1.3.6.1.4.1.25506.2.122.2.23.1.4) |
read-only |
Counter64 |
Total number of IP addresses in the DHCP pool group. |
As per the MIB. |
hh3cDhcpServer2PoolGpIPUsedNum (1.3.6.1.4.1.25506.2.122.2.23.1.5) |
read-only |
Counter64 |
Number of allocated IP addresses in the DHCP pool group. |
As per the MIB. |
hh3cDhcpServer2PoolGpIPIdleNum (1.3.6.1.4.1.25506.2.122.2.23.1.6) |
read-only |
Counter64 |
Number of free IP addresses in the DHCP pool group. |
As per the MIB. |
hh3cDhcpServer2PoolGpIPExcNum (1.3.6.1.4.1.25506.2.122.2.23.1.7) |
read-only |
Unsigned32 |
Number of excluded IP addresses in the DHCP pool group. |
As per the MIB. |
hh3cDhcpServer2PoolGpConfNum (1.3.6.1.4.1.25506.2.122.2.23.1.8) |
read-only |
Unsigned32 |
Number of conflicting IP addresses in the DHCP pool group. |
As per the MIB. |
hh3cDhcpServer2PoolGpAutoBndNum (1.3.6.1.4.1.25506.2.122.2.23.1.9) |
read-only |
Unsigned32 |
Number of dynamically allocated IP addresses in the DHCP pool group. |
As per the MIB. |
hh3cDhcpServer2PoolGpManuBndNum (1.3.6.1.4.1.25506.2.122.2.23.1.10) |
read-only |
Unsigned32 |
Number of statically allocated IP addresses in the DHCP pool group. |
As per the MIB. |
hh3cDhcpServer2PoolGpExpiBndNum (1.3.6.1.4.1.25506.2.122.2.23.1.11) |
read-only |
Counter64 |
Number of expired IP addresses in the DHCP pool group. |
As per the MIB. |
hh3cDhcpServer2PoolGpReserveIpNum (1.3.6.1.4.1.25506.2.122.2.23.1.12) |
read-only |
Counter64 |
Number of reserved IP addresses in the DHCP pool group. |
As per the MIB. |
hh3cDhcpRelay2ConfigGroup
About this table
This table configures global DHCP relay agent settings.
Read:Supported
Columns
Object (OID)
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpRelay2UserInfoRecord (1.3.6.1.4.1.25506.2.122.3.1.1) |
read-write |
TruthValue |
true(1), false(2) |
Enabling status of recording client information in relay entries. |
As per the MIB. |
hh3cDhcpRelay2UserInfoRefresh (1.3.6.1.4.1.25506.2.122.3.1.2) |
read-write |
TruthValue |
true(1), false(2) |
Enabling status of refreshing relay entries. |
As per the MIB. |
hh3cDhcpRelay2UserInfoFlushTime (1.3.6.1.4.1.25506.2.122.3.1.3) |
read-write |
Unsigned32 |
Unsigned32(0..120) |
Interval at which the DHCP relay agent refreshes relay entries. |
As per the MIB. |
hh3cDhcpRelay2ReleaseAddr (1.3.6.1.4.1.25506.2.122.3.1.4) |
read-write |
OCTET STRING |
OCTET STRING (0..47) |
IP address release request sent to the server. |
The set operation enables the relay agent to send a release request for the specified IP address to the DHCP server. When you perform a get operation on this object, a value of 0 is returned. |
hh3cDhcpRelay2StatisticsGroup
About this table
This table records the global statistics on a DHCP relay agent.
Read:Supported
Columns
Object (OID)
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpRelay2RxClientNum (1.3.6.1.4.1.25506.2.122.3.2.1) |
read-only |
Counter64 |
Number of received packets that are sent by the DHCP clients. |
As per the MIB. |
hh3cDhcpRelay2TxClientNum (1.3.6.1.4.1.25506.2.122.3.2.2) |
read-only |
Counter64 |
Number of packets sent to the DHCP clients. |
As per the MIB. |
hh3cDhcpRelay2RxServerNum (1.3.6.1.4.1.25506.2.122.3.2.3) |
read-only |
Counter64 |
Number of received packets sent by DHCP servers. |
As per the MIB. |
hh3cDhcpRelay2TxServerNum (1.3.6.1.4.1.25506.2.122.3.2.4) |
read-only |
Counter64 |
Number of packets sent to the DHCP servers. |
As per the MIB. |
hh3cDhcpRelay2BadNum (1.3.6.1.4.1.25506.2.122.3.2.5) |
read-only |
Counter64 |
Number of error packets processed by the DHCP relay agent. |
As per the MIB. |
hh3cDhcpRelay2BootpRequestNum (1.3.6.1.4.1.25506.2.122.3.2.6) |
read-only |
Counter64 |
Number of BOOTP requests processed by the DHCP relay agent. |
As per the MIB. |
hh3cDhcpRelay2DiscoverNum (1.3.6.1.4.1.25506.2.122.3.2.7) |
read-only |
Counter64 |
Number of DHCP-DISCOVER messages processed by the DHCP relay agent. |
As per the MIB. |
hh3cDhcpRelay2RequestNum (1.3.6.1.4.1.25506.2.122.3.2.8) |
read-only |
Counter64 |
Number of DHCP-REQUEST messages processed by the DHCP relay agent. |
As per the MIB. |
hh3cDhcpRelay2DeclineNum (1.3.6.1.4.1.25506.2.122.3.2.9) |
read-only |
Counter64 |
Number of DHCP-DECLINE messages processed by the DHCP relay agent. |
As per the MIB. |
hh3cDhcpRelay2ReleaseNum (1.3.6.1.4.1.25506.2.122.3.2.10) |
read-only |
Counter64 |
Number of DHCP-RELEASE messages processed by the DHCP relay agent. |
As per the MIB. |
hh3cDhcpRelay2InformNum (1.3.6.1.4.1.25506.2.122.3.2.11) |
read-only |
Counter64 |
Number of DHCP-INFORM messages processed by the DHCP relay agent. |
As per the MIB. |
hh3cDhcpRelay2BootpReplyNum (1.3.6.1.4.1.25506.2.122.3.2.12) |
read-only |
Counter64 |
Number of BOOTP replies processed by the DHCP relay agent. |
As per the MIB. |
hh3cDhcpRelay2OfferNum (1.3.6.1.4.1.25506.2.122.3.2.13) |
read-only |
Counter64 |
Number of DHCP-OFFER messages processed by the DHCP relay agent. |
As per the MIB. |
hh3cDhcpRelay2AckNum (1.3.6.1.4.1.25506.2.122.3.2.14) |
read-only |
Counter64 |
Number of DHCP-ACK messages processed by the DHCP relay agent. |
As per the MIB. |
hh3cDhcpRelay2NakNum (1.3.6.1.4.1.25506.2.122.3.2.15) |
read-only |
Counter64 |
Number of DHCP-NAK messages processed by the DHCP relay agent. |
As per the MIB. |
hh3cDhcpRelay2IfConfigTable
About this table
This table records the DHCP relay agent configuration on an interface.
Read:Supported
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpRelay2IfSelectRelay (1.3.6.1.4.1.25506.2.122.4.1.1.1) |
read-write |
TruthValue |
true(1), false(2) |
Enabling status of the DHCP relay agent. |
As per the MIB. |
hh3cDhcpRelay2IfCheckMac (1.3.6.1.4.1.25506.2.122.4.1.1.2) |
read-write |
TruthValue |
true(1), false(2) |
Enabling status of MAC address check. |
As per the MIB. |
hh3cDhcpRelay2IfOpt82Enable (1.3.6.1.4.1.25506.2.122.4.1.1.3) |
read-write |
TruthValue |
true(1), false(2) |
Enabling status of support for option 82. |
As per the MIB. |
hh3cDhcpRelay2IfOpt82Strategy (1.3.6.1.4.1.25506.2.122.4.1.1.4) |
read-write |
INTEGER |
drop(1), keep(2), replace(3) |
Strategy for handling DHCP requests that contain Option 82. |
As per the MIB. |
hh3cDhcpRelay2IfOpt82CIDMode (1.3.6.1.4.1.25506.2.122.4.1.1.5) |
read-write |
INTEGER |
normal(1), verbose(2), userDefine(3) |
Mode of the circuit ID sub-option in option 82. |
The return value is normal(1) if the system reads an unsupported mode. |
hh3cDhcpRelay2IfOpt82CIDNodeType (1.3.6.1.4.1.25506.2.122.4.1.1.6) |
read-write |
INTEGER |
invalid(1), mac(2), sysname(3), userDefine(4) |
Access node identifier for the circuit ID sub-option in verbose mode. |
If no access node identifier is specified, the value read from this object is invalid(1). |
hh3cDhcpRelay2IfOpt82CIDNodeStr (1.3.6.1.4.1.25506.2.122.4.1.1.7) |
read-write |
OCTET STRING |
OCTET STRING (0..50) |
User-defined string as the access node identifier for the circuit ID sub-option in verbose mode. |
As per the MIB. |
hh3cDhcpRelay2IfOpt82CIDStr (1.3.6.1.4.1.25506.2.122.4.1.1.8) |
read-write |
OCTET STRING |
OCTET STRING (0|3..63) |
User-defined string as the access node identifier for the circuit ID sub-option in userDefine mode. |
As per the MIB. |
hh3cDhcpRelay2IfOpt82CIDFormat (1.3.6.1.4.1.25506.2.122.4.1.1.9) |
read-write |
INTEGER |
hex(1), ascii(2), undefine(3) |
Padding format of the circuit ID sub-option in option 82. |
As per the MIB. |
hh3cDhcpRelay2IfOpt82RIDMode (1.3.6.1.4.1.25506.2.122.4.1.1.10) |
read-write |
INTEGER |
normal(1), sysname(2), userDefine(3) |
Mode of the remote ID sub-option in option 82. |
As per the MIB. |
hh3cDhcpRelay2IfOpt82RIDStr (1.3.6.1.4.1.25506.2.122.4.1.1.11) |
read-write |
OCTET STRING |
User-defined string as the access node identifier for the remote ID sub-option in userDefine mode. |
If the mode of the remote ID sub-option is sysname(2), the value read from this object is 0. |
hh3cDhcpRelay2IfOpt82RIDFormat (1.3.6.1.4.1.25506.2.122.4.1.1.12) |
read-write |
INTEGER |
hex(1), ascii(2) |
Padding format of the remote ID sub-option in normal mode. |
As per the MIB. |
hh3cDhcpRelay2SrvAddrTable
About this table
This table obtains the IP address of a DHCP server.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table indexes are ifIndex and h3cDhcpRelay2SrvAddrIP.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpRelay2SrvAddrIP (1.3.6.1.4.1.25506.2.122.4.2.1.1) |
not-accessible |
InetAddressIPv4 |
OCTET STRING (4) |
DHCP server IP address. |
As per the MIB. |
hh3cDhcpRelay2SrvAddrRowStatus (1.3.6.1.4.1.25506.2.122.4.2.1.2) |
read-create |
RowStatus |
Active, createAndGo, destroy |
Row status. |
As per the MIB. |
hh3cDhcpRelay2UserInfoTable
About this table
Use this table to delete DHCP relay entries.
Delete:Supported
Read:Supported
Columns
The table indexes are h3cDhcpRelay2UserInfoVpnIndex and h3cDhcpRelay2UserInfoIpAddr.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpRelay2UserInfoVpnIndex (1.3.6.1.4.1.25506.2.122.4.3.1.1) |
not-accessible |
Unsigned32 |
Unsigned32 (0 . 65534), 0 represents the public network. |
VPN to which the IP address of the relay entry belongs. |
As per the MIB. |
hh3cDhcpRelay2UserInfoIpAddr (1.3.6.1.4.1.25506.2.122.4.3.1.2) |
not-accessible |
InetAddressIPv4 |
OCTET STRING (0.255) |
Client IP address in the relay entry. |
As per the MIB. |
hh3cDhcpRelay2UserInfoMacAddr (1.3.6.1.4.1.25506.2.122.4.3.1.3) |
read-only |
MacAddress |
OCTET STRING (6) |
Client MAC address in the relay entry. |
As per the MIB. |
hh3cDhcpRelay2UserInfoIfIndex (1.3.6.1.4.1.25506.2.122.4.3.1.4) |
read-only |
Index of the Layer 3 interface that connects to the DHCP client. |
As per the MIB. |
hh3cDhcpRelay2UserInfoRowStatus (1.3.6.1.4.1.25506.2.122.4.3.1.5) |
read-create |
RowStatus |
destroy |
Row status. |
As per the MIB. |
Notifications
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.122.5.0.1 |
Exhaustion of addresses in a DHCP address pool. |
Error |
Major |
1.3.6.1.4.1.25506.2.122.5.0.2 (hh3cDhcpServer2AddrExhaustRecov) |
ON |
Notification triggers
This notification is generated when all addresses in a DHCP address pool are assigned.
System impact
New DHCP users cannot obtain IP addresses from the DHCP server.
Status control
ON
CLI: Use the snmp-agent trap enable dhcp server address-exhaust command.
OFF
CLI: Use the undo snmp-agent trap enable dhcp server address-exhaust command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.122.2.1.1.1 (hh3cDhcpServer2PoolIndex) |
hh3cDhcpServer2PoolIndex |
Unsigned32 |
Recommended action
To resolve this issue:
1.Use one of the following methods to increase address resources:
- Add the current address pool and other address pools to an address pool group.
- Add secondary network segments for dynamic address allocation in the current address pool.
If the issue persists, proceed to step 2.
2.If the issue persists, collect alarm information, log messages, and configuration data, and then contact H3C Support for help.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.122.5.0.2 |
A DHCP address pool has recovered from address exhaustion. |
Recovery |
Major |
N/A (N/A) |
ON |
This notification is generated when a DHCP address pool has recovered from address exhaustion.
System impact
No negative impact on the system.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Unsigned32 |
Recommended action
No action is required.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.122.5.0.3 |
The address usage of an address pool has exceeded the threshold. |
Error |
Warning |
1.3.6.1.4.1.25506.2.122.5.0.5 (hh3cDhcpServer2IpUsageOverflowRecov) |
ON |
This notification is generated when the address usage of an address pool has exceeded the threshold. The address usage of an address pool is read every 5 minutes.
System impact
If the DHCP server continues to assign IP addresses from the address pool to clients, the address pool might run out of addresses. As a result, new DHCP users cannot obtain IP addresses and thus cannot come online.
Status control
ON
CLI: Use the snmp-agent trap enable dhcp server ip-in-use command.
OFF
CLI: Use the undo snmp-agent trap enable dhcp server ip-in-use command.
Object
OID (object name) |
Index |
Type |
Value range |
Unsigned32 |
Recommended action
1.Use the display ip pool command in any view to check whether the address usage threshold specified in the current address pool is appropriate.
- If the address usage threshold is too low, increase the threshold.
- If the address usage threshold is appropriate, proceed to step 2.
2.Use the display dhcp server statistics command in any view to view the address usage of the current address pool and the number of assignable addresses in the current address pool.
- If the assignable addresses are insufficient, use one of the following methods to increase address resources:
- If the assignable addresses are sufficient, keep observing the address usage of the current address pool. When the address pool has a high address usage, increase address resources timely to ensure that new DHCP users can obtain addresses.
3.If the issue persists, collect alarm information, log messages, and configuration data, and then contact H3C Support for help.
hh3cDhcpServer2AllocOverflow
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.122.5.0.4 |
DHCP address allocation success rate is below the specified threshold. |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when the DHCP address allocation success rate is below the specified threshold during the past five minutes.
System impact
If this issue occurs due to address exhaustion, new DHCP users cannot obtain addresses from the DHCP server and thus cannot come online.
Status control
ON
CLI: Use the snmp-agent trap enable dhcp server allocated-ip command.
OFF
CLI: Use the undo snmp-agent trap enable dhcp server allocated-ip command.
Object
OID (object name) |
Index |
Type |
Value range |
无 (无) |
无 |
无 |
无 |
无 |
Recommended action
1.Use the display dhcp server statistics command in any view to view the address usage of the current address pool and the number of assignable addresses in the current address pool:
- If the address pool has both assigned addresses and assignable addresses, proceed to step 2.
- If the address pool does not have any assignable addresses, use one of the following methods to increase address resources:
If the issue persists, proceed to step 3.
2.Verify that all DHCP settings are configured correctly. If the issue persists, proceed to step 3.
3.Collect alarm information, log messages, and configuration data, and then contact H3C Support for help.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.122.5.0.5 |
The address usage of an address pool has dropped below the specified threshold. |
Recovery |
Warning |
N/A (N/A) |
ON |
This notification is generated when the address usage of an address pool has dropped below the specified threshold.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Unsigned32 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.122.5.0.6 |
Subnet usage of an address pool has reached or exceeded the threshold. |
Error |
Warning |
1.3.6.1.4.1.25506.2.122.5.0.7 (hh3cDhcpServer2NetUsageOverflowRecov) |
ON |
This notification is generated when the subnet usage of an address pool has reached or exceeded the threshold.
System impact
If the DHCP server continues to assign subnets from the address pool to clients, the address pool might run out of address resources. As a result, new DHCP users cannot obtain addresses and thus cannot come online.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Unsigned32 |
Recommended action
1.Use the display ip pool command in any view to check whether the subnet usage threshold specified for the current address pool is appropriate:
- If the subnet usage threshold is too low, increase the threshold.
- If the subnet usage threshold is appropriate, proceed to step 2.
2.Use the display dhcp server statistics command in any view to view the subnet usage of the current address pool and the number of assignable subnets in the current address pool:
- If the assignable subnets are insufficient, use one of the following methods to increase subnet resources:
Add secondary network segments for dynamic subnet allocation in the current address pool.
- If the assignable addresses are sufficient, keep observing the subnet usage of the current address pool. When the address pool has a high subnet usage, increase subnet resources timely to ensure that new DHCP users can obtain addresses.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.122.5.0.7 |
Subnet usage of an address pool has dropped below the threshold. |
Recovery |
Warning |
N/A (N/A) |
ON |
This notification is generated when the subnet usage of an address pool has dropped below the threshold.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Unsigned32 |
Recommended action
hh3cDhcpServer2NetExhaust
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.122.5.0.8 |
Subnets in an address pool have been exhausted. |
Error |
Major |
1.3.6.1.4.1.25506.2.122.5.0.9 (hh3cDhcpServer2NetExhaustRecov) |
ON |
This notification is generated when an address pool has recovered from subnet resource exhaustion.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Unsigned32 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.122.5.0.10 |
Subnets in an address pool group have been exhausted. |
Error |
Major |
1.3.6.1.4.1.25506.2.122.5.0.11 (hh3cDhcpServer2GpNetExhaustRecov) |
ON |
This notification is generated when an address pool group has run out of subnet resources.
System impact
New DHCP users might fail to obtain addresses and thus cannot come online.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.122.2.21.1.1 (hh3cDhcpServer2PoolGpName) |
Name of the DHCP address pool group. |
hh3cDhcpServer2PoolGpName |
OCTET STRING |
Recommended action
1.Use one of the following methods to increase subnet resources for the address pool group:
- Add new address pools to the address pool group.
- Add secondary network segments for address pools in the address pool group.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.122.5.0.11 |
An address pool group has recovered from subnet resource exhaustion. |
Recovery |
Major |
N/A (N/A) |
ON |
This notification is generated when an address pool group has recovered from subnet resource exhaustion.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
OCTET STRING |
Recommended action
hh3cDhcpSvr2AllocIpFailed
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.122.5.0.12 |
The DHCP server fails to allocate an IP address in the ISP domain. |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated in one of the following scenarios:
The DHCP relay agent is disconnected from the DHCP server.
The DHCP server does not have assignable addresses.
System impact
The DHCP relay agent cannot obtain IP addresses from the DHCP server. As a result, users attached to the DHCP relay agent cannot come online.
Status control
ON
CLI: Use the snmp-agent trap enable dhcp server ip-alloc-failed command.
OFF
CLI: Use the undo snmp-agent trap enable dhcp server ip-alloc-failed command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.122.1.2.24 (hh3cDhcpServer2OnlineFailReason) |
Reason for the address allocation failure on the DHCP server. |
N/A |
OCTET STRING |
Recommended action
1.Verify that the link between the DHCP relay agent and the DHCP server is in good condition and they can reach each other.
2.Use the display dhcp server statistics command in any view to view the address usage of the current address pool and the number of assignable addresses in the current address pool:
- If the address pool has both assigned addresses and assignable addresses, proceed to step 3.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.122.5.0.14 |
An address pool group has no assignable IP addresses. |
Error |
Warning |
1.3.6.1.4.1.25506.2.122.5.0.15 (hh3cDhcpSvr2GpAddrExhaustRecov) |
ON |
This notification is generated when an address pool group has run out of IP addresses.
System impact
New DHCP users cannot obtain addresses and thus cannot come online.
Status control
ON
CLI: Use the snmp-agent trap enable dhcp server pool-group-exhaust command.
OFF
CLI: Use the undo snmp-agent trap enable dhcp server pool-group-exhaust command.
Object
OID (object name) |
Index |
Type |
Value range |
Name of the address pool group. |
The value range varies by product type. |
Recommended action
1.Use one of the following methods to increase address resources for the address pool group:
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.122.5.0.15 |
An address pool group recovers from the address resource exhaustion condition. |
Recovery |
Warning |
N/A (N/A) |
ON |
This notification is generated when an address pool group has recovered from the address resource exhaustion condition.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable dhcp server group-used-exhaustion command.
OFF
CLI: Use the undo snmp-agent trap enable dhcp server group-used-exhaustion command.
Object
OID (object name) |
Index |
Type |
Value range |
Recommended action
hh3cDhcpServer2DevOdapFull
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.122.5.0.16 |
All ODAP address pools have run out of subnet resources. |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when all ODAP address pools have run out of subnet resources.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable dhcp server odap-subnet-alarm command.
OFF
CLI: Use the undo snmp-agent trap enable dhcp server odap-subnet-alarm command.
Object
OID (object name) |
Index |
Type |
Value range |
无 (无) |
无 |
无 |
无 |
无 |
Recommended action
1.Use the display dhcp dynamic-alloc address command in any view to view the address usage of each subnet. If the address usage of each subnet is not high, use the subnet utilization mark command to increase the low utilization mark. When the address usage of each subnet in an ODAP client address pool is lower than the low utilization mark, the address pool releases idle subnets.
2.Collect alarm information, log messages, and configuration data, and then contact H3C Support for help.
hh3cDhcpServer2OdapApplyFail
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.122.5.0.17 |
An ODAP address pool fails to request subnet resources. |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when one of the following conditions exists:
The ODAP server does not respond to the subnet request.
The ODAP server is configured incorrectly.
The ODAP server has run out of subnet resources.
System impact
Users cannot come online.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Reason why the ODAP address pool failed to request subnet resources. |
N/A |
OCTET STRING |
Recommended action
1.Use the display dhcp dynamic-alloc address command in any view to view the address usage of each subnet. If the address usage of each subnet is high, use the subnet utilization mark command to adjust the low utilization mark. When the address usage of each subnet in an ODAP client address pool is lower than the low utilization mark, the address pool releases idle subnets.
hh3cDhcpServer2OdapReleaseFail
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.122.5.0.18 |
An ODAP address pool fails to release subnets. |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when the ODAP server is disconnected from an ODAP client.
System impact
This issue might disable the ODAP server from reclaiming subnets from the ODAP client and the ODAP server might run out of subnet resources.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Reason why the ODAP address pool failed to release subnet resources. |
N/A |
OCTET STRING |
Recommended action
hh3cDhcpSvr2GpUsageOverflow
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.122.5.0.19 |
The IP address usage of an address pool group has reached or exceeded the threshold. |
Error |
Warning |
1.3.6.1.4.1.25506.2.122.5.0.20 (hh3cDhcpSvr2GpUsageOverflowRecov) |
ON |
This notification is generated when the IP address usage of an address pool group has reached or exceeded the threshold.
System impact
If the DHCP server continues to assign IP addresses from the address pool group to clients, the address pool group might run out of addresses. As a result, new DHCP users cannot obtain IP addresses and thus cannot come online.
Status control
ON
CLI: Use the snmp-agent trap enable dhcp server pool-group-threshold command.
OFF
CLI: Use the undo snmp-agent trap enable dhcp server pool-group-threshold command.
Object
OID (object name) |
Index |
Type |
Value range |
Recommended action
1.Use the display ip pool-group command in any view to check whether the address usage threshold specified in the current address pool group is appropriate.
2.Use the display dhcp server statistics command in any view to view the address usage of the current address pool group and the number of assignable addresses in the current address pool group.
- If the assignable addresses are insufficient, use one of the following methods to increase address resources for the address pool group:
- If the assignable addresses are sufficient, keep observing the address usage of the current address pool group. When the address pool group has a high address usage, increase address resources timely to ensure that new DHCP users can obtain addresses.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.122.5.0.20 |
The IP address usage of an address pool group has dropped below the threshold. |
Recovery |
Warning |
N/A (N/A) |
ON |
This notification is generated when the IP address usage of an address pool group has dropped below the threshold.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Recommended action
hh3cDhcpSvr2UserIpConflict
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.122.5.0.21 |
The DHCP server assigns a conflicting address to a client. |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when the DHCP server assigns a conflicting address to a client.
System impact
If excessive conflicting addresses exist, the DHCP server might run out of address pool resources.
Status control
ON
CLI: Use the snmp-agent trap enable dhcp server ip-conflict command.
OFF
CLI: Use the undo snmp-agent trap enable dhcp server ip-conflict command.
Object
OID (object name) |
Index |
Type |
Value range |
Index of the address pool. |
Unsigned32 |
Conflicting IP address assigned to the DHCP client. |
N/A |
InetAddressIPv4 |
Recommended action
1.Use the display dhcp server conflict command in any view to identify whether the IP address conflicts are excessive. If too many IP address conflicts exist, identify whether they are real.
- If those IP address conflicts do exist, replan the network.
- If some IP address conflicts are not real, proceed to step 2.
