08-Layer 3 - IP Services
HomeSupportRoutersCR16000-M SeriesReference GuidesMIB CompanionH3C CR16000-M Routers MIB Reference-R8530Pxx-6W10008-Layer 3 - IP Services
01-HH3C-ARP-RATELIMIT-MIB
01-HH3C-ARP-RATELIMIT-MIB 73.81 KB
About this MIB
This MIB contains ARP rate limiting notifications.
MIB file name
hh3c-arp-ratelimit.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cARPRatelimit(110)
Tabular objects
hh3cARPRatelimitConfigTable
About this table
This table obtains the ARP packet rate on an interface.
Support for operations
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadNot supported
Columns
The table index is ifIndex.
Object (OID)
Access
Value range
Implementation
hh3cARPRatelimitValue (1.3.6.1.4.1.25506.2.110.1.2.1.1.1)
read-write
Unsigned32
Standard MIB values.
ARP packet rate.
Not supported.
Notifications
hh3cARPRatelimitOverspeedTrap
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.110.1.1.0.1
Rate of ARP packets delivered to the CPU on a device exceeded the threshold.
Informational
Warning
N/A (N/A)
OFF
Notification triggers
This notification is generated when the ARP packet rate on an interface exceeds the upper limit.
System impact
The interface discards ARP packets that exceed the rate limit. This might affect ARP learning and responding, resulting in communication failure.
Status control
ON
CLI: Use the snmp-agent trap enable arp rate-limit command.
OFF
CLI: Use the undo snmp-agent trap enable arp rate-limit command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.110.1.1.1.1 (hh3cARPRatelimitTrapVer)
Version of the trap.
N/A
Unsigned32
1
1.3.6.1.4.1.25506.2.110.1.1.1.2 (hh3cARPRatelimitTrapCount)
Alarm threshold that the ARP packet rate exceeded.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.110.1.1.1.3 (hh3cARPRatelimitTrapMsg)
Trap messages.
N/A
OCTET STRING
SIZE (1..254)
Recommended action
To resolve this issue:
1.Execute the arp rate-limit command to set a higher ARP packet rate limit for the interface.
2.If the issue persists, collect configuration files and alarm information, and then contact H3C Support for help.
