11-MPLS
HomeSupportRoutersH3C SR8800-X Router SeriesReference GuidesMIB CompanionH3C SR8800-X Routers MIB Reference-R8530Pxx-6W10011-MPLS
21-PW-ENET-STD-MIB
21-PW-ENET-STD-MIB 70.14 KB
PW-ENET-STD-MIB
About this MIB
Use this MIB to configure Ethernet PW related settings.
MIB file name
rfc5603-pw-enet-std.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).pwEnetStdMIB(180)
Tabular objects
pwEnetTable
About this table
This table contains the AC configuration for Ethernet PW.
Support for operations
CreateSupported
Edit/ModifyNot supported
DeleteSupported
ReadSupported
Columns
The table indexes are pwIndex and pwEnetPwInstance.
Object (OID)
Access
Value range
Implementation
pwEnetPwInstance (1.3.6.1.2.1.180.1.1.1.1)
not-accessible
Unsigned32
Unsigned32 (0..4294967295)
Index of an AC configuration entry for an Ethernet PW.
As per the MIB.
pwEnetPwVlan (1.3.6.1.2.1.180.1.1.1.2)
read-create
VlanIdOrAnyOrNone
Integer32 (0 | 1..4094 | 4095)
Negotiated VLAN ID.
As per the MIB.
pwEnetVlanMode (1.3.6.1.2.1.180.1.1.1.3)
read-create
INTEGER
other(0),
portBased(1),
noChange(2),
changeVlan(3),
addVlan(4),
removeVlan(5)
VLAN handling mode.
As per the MIB.
pwEnetPortVlan (1.3.6.1.2.1.180.1.1.1.4)
read-create
VlanIdOrAnyOrNone
Port VLAN ID.
As per the MIB.
pwEnetPortIfIndex (1.3.6.1.2.1.180.1.1.1.5)
read-create
InterfaceIndexOrZero
Integer32 (0..2147483647)
Index of the Ethernet port.
As per the MIB.
pwEnetPwIfIndex (1.3.6.1.2.1.180.1.1.1.6)
read-create
Interface index of the PW when it acts as an interface.
As per the MIB.
pwEnetRowStatus (1.3.6.1.2.1.180.1.1.1.7)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
Supports only active(1), createAndGo(4), and destroy(6).
pwEnetStorageType (1.3.6.1.2.1.180.1.1.1.8)
read-create
StorageType
other(1),
volatile(2),
nonVolatile(3),
permanent(4),
readOnly(5)
Storage type for the AC configuration entry.
Supports only the read operation.
The value is always nonVolatile(3).
