11-MPLS
HomeSupportRoutersH3C SR8800-X Router SeriesReference GuidesMIB CompanionH3C SR8800-X Routers MIB Reference-R8530Pxx-6W10011-MPLS
14-MPLS-FRR-FACILITY-STD-MIB
14-MPLS-FRR-FACILITY-STD-MIB 121.91 KB
About this MIB
Use this MIB to manage tunnels on the MPLS interfaces configured for FRR protection.
MIB file name
rfc6445-mpls-frr-facility-std.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).mplsFrrFacilityMIB(204)
Scalar objects
mplsFrrConfiguredInterfaces (1.3.6.1.2.1.204.1.1)
Object (OID)
Access
Value range
Implementation
read-only
Integer32
Integer32
(0..2147483647)
Number of MPLS interfaces configured for FRR protection.
As per the MIB.
mplsFrrActiveInterfaces (1.3.6.1.2.1.204.1.2)
Object (OID)
Access
Value range
Implementation
read-only
Gauge32
Gauge32
(0..4294967295)
Number of interfaces currently being protected.
An interface is being protected as long as the bypass tunnel on the interface is up.
As per the MIB.
mplsFrrConfiguredBypassTunnels (1.3.6.1.2.1.204.1.3)
Object (OID)
Access
Value range
Implementation
read-only
Gauge32
Gauge32
(0..4294967295)
Number of bypass tunnels configured to protect tunnels on this LSR.
As per the MIB.
mplsFrrActiveBypassTunnels (1.3.6.1.2.1.204.1.4)
Object (OID)
Access
Value range
Implementation
read-only
Gauge32
Gauge32
(0..4294967295)
Number of bypass tunnels in up state (ready to protect tunnels).
As per the MIB.
mplsFrrFacilityNotificationsEnabled (1.3.6.1.2.1.204.1.5)
Object (OID)
Access
Value range
Implementation
read-write
Integer32
true(1),
false(2)
The capability of sending FRR notifications.
As per the MIB.
mplsFrrFacilityNotificationsMaxRate (1.3.6.1.2.1.204.1.6)
Object (OID)
Access
Value range
Implementation
read-write
Gauge32
Gauge32
(0..4294967295)
Maximum number of FRR notifications sent per second.
Not supported.
This value is always 0.
Tabular objects
mplsFrrFacilityDBTable
About this table
Use this table to obtain FRR database information.
Support for operations
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadThe mplsFrrFacilityDBProtectingTunnelResvBw object displays only the bandwidth information. It does not display the CT information.
The value active(1) for mplsFrrFacilityDBProtectingTunnelStatus indicates that a primary/bypass tunnel FRR switchover has occurred.
The value ready(2) for mplsFrrFacilityDBProtectingTunnelStatus indicates a bypass tunnel has been bound to the primary tunnel but no FRR switchover has occurred.
Columns
The table indexes are mplsFrrFacilityProtectedIfIndex, mplsFrrFacilityProtectingTunnelIndex, mplsFrrFacilityBackupTunnelIndex, mplsFrrFacilityBackupTunnelInstance, and mplsFrrFacilityBackupTunnelIngressLSRId.
Object (OID)
Access
Value range
Implementation
mplsFrrFacilityProtectedIfIndex (1.3.6.1.2.1.204.1.7.1.1)
not-accessible
InterfaceIndex
Integer32
(1..2147483647)
Index of an interface configured for FRR protection.
As per the MIB.
mplsFrrFacilityProtectingTunnelIndex (1.3.6.1.2.1.204.1.7.1.2)
not-accessible
MplsTunnelIndex
Unsigned32
(0..65535)
Index for a bypass tunnel on the interface specified by mplsFrrFacilityProtectedIfIndex.
As per the MIB.
mplsFrrFacilityBackupTunnelIndex (1.3.6.1.2.1.204.1.7.1.3)
not-accessible
MplsTunnelIndex
Unsigned32
(0..65535)
Index of the protected tunnel on the interface specified by mplsFrrFacilityProtectedIfIndex.
As per the MIB.
mplsFrrFacilityBackupTunnelInstance (1.3.6.1.2.1.204.1.7.1.4)
not-accessible
MplsTunnelInstanceIndex
Unsigned32
(0..2147483647)
Index of the protected tunnel instance.
As per the MIB.
mplsFrrFacilityBackupTunnelIngressLSRId (1.3.6.1.2.1.204.1.7.1.5)
not-accessible
MplsLsrIdentifier
OCTET STRING
(0..255)
Ingress LSR ID of the protected tunnel.
As per the MIB.
mplsFrrFacilityBackupTunnelEgressLSRId (1.3.6.1.2.1.204.1.7.1.6)
not-accessible
MplsLsrIdentifier
OCTET STRING
(0..255)
Egress LSR ID of the protected tunnel.
As per the MIB.
mplsFrrFacilityDBNumProtectingTunnelOnIf (1.3.6.1.2.1.204.1.7.1.7)
read-only
Gauge32
Gauge32
(0..4294967295)
Number of bypass tunnels on the interface.
As per the MIB.
mplsFrrFacilityDBNumProtectedLspOnIf (1.3.6.1.2.1.204.1.7.1.8)
read-only
Gauge32
Gauge32
(0.. 4294967295)
Number of LSPs being protected on the interface.
As per the MIB.
mplsFrrFacilityDBNumProtectedTunnels (1.3.6.1.2.1.204.1.7.1.9)
read-only
Gauge32
Gauge32 (0.. 4294967295)
Number of tunnels being protected on the interface.
As per the MIB.
mplsFrrFacilityDBProtectingTunnelStatus (1.3.6.1.2.1.204.1.7.1.10)
read-only
Integer32
active(1), ready(2), partial(3)
State of the bypass tunnel.
Supports only active(1) and ready(2)
mplsFrrFacilityDBProtectingTunnelResvBw (1.3.6.1.2.1.204.1.7.1.11)
read-only
Unsigned32
Unsigned32
(0..4294967295)
Bandwidth reserved for the bypass tunnel to provide bandwidth protection.
As per the MIB.
Notifications
mplsFrrFacilityInitialBackupTunnelInvoked
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.2.1.204.0.1
Interface failed and bypass tunnel took over.
Error
Major
1.3.6.1.2.1.204.0.2 (mplsFrrFacilityFinalTunnelRestored)
ON
Notification triggers
This notification is generated when the interface or link protected by a bypass tunnel goes down and the service traffic is switched to the bypass tunnel accordingly.
System impact
The tunnel service is switched to the bypass tunnel. The service traversed path is not the expected primary tunnel, thus risks might increase for the service.
Status control
ON
CLI: Use the snmp-agent trap enable te command.
OFF
CLI: Use the undo snmp-agent trap enable te command.
Object
OID (object name)
Index
Value range
 (mplsFrrFacilityDBNumProtectingTunnelOnIf)
Number of bypass tunnels on an interface for protection.
(mplsFrrFacilityProtectedIfIndex)
(mplsFrrFacilityProtectingTunnelIndex)
(mplsFrrFacilityBackupTunnelIndex)
(mplsFrrFacilityBackupTunnelInstance)
(mplsFrrFacilityBackupTunnelIngressLSRId)
Gauge32
Standard MIB values.
 (mplsFrrFacilityDBNumProtectedLspOnIf)
Number of CRLSPs protected on the interface.
No1.3.6.1.2.1.204.1.7.1.1
Gauge32
 (mplsFrrFacilityDBNumProtectedTunnels)
Number of tunnels protected on the interface.
Gauge32
 (mplsFrrFacilityDBProtectingTunnelStatus)
State of a bypass tunnel on the interface.
INTEGER
active(1), ready(2)
1.3.6.1.2.1.204.1.7.1.11 (mplsFrrFacilityDBProtectingTunnelResvBw)
Amount of bandwidth reserved by a bypass tunnel on the interface.
Unsigned32
Recommended action
To resolve this issue, perform the following tasks:
1.Check the current tunnel interface configuration, RSVP and IGP configuration, and check whether the tunnel path and its bandwidth satisfy the tunnel configuration requirements.
  - If an explicit path is configured, check whether the interfaces on each hop of the explicit path are faulty.
If yes, clear link faults.
If no, go to step 2.
2.If no explicit path is configured, check whether a path that satisfies the tunnel requirements exists. If yes, execute step 2.
3.If the issue persists, collect log messages and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.204.0.2
Interface recovered and primary tunnel recovered.
Recovery
Major
N/A (N/A)
ON
This notification is generated when the state of the interface or link protected by a bypass tunnel changes from down to up and the service traffic is switched from the bypass tunnel back to the primary tunnel accordingly.
System impact
No negative impact on services.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Number of bypass tunnels for FRR facility backup.
Unsigned32
Number of LSPs protected by FRR facility backup.
Unsigned32
Number of tunnels protected by FRR facility backup.
Unsigned32
State of a bypass tunnel for FRR facility backup.
Integer32
active(1), ready(2)
Amount of bandwidth reserved by the bypass tunnel for FRR facility backup.
Unsigned32
Recommended action
No action is required.
