03-Appendix A Technical specifications, LEDs, and ports | 315.75 KB |
1 Appendix A Technical specifications, LEDs, and ports
Table1-1 Technical specifications
Item |
Dimensions (H × W × D) |
260 × 260 × 84 mm (10.24 × 10.24 × 3.11 in) |
Weight |
2.1 kg (4.63 lb) |
System power consumption |
50 W |
Antenna |
· 2.4GHz peak gain: 6.8dBi · 5GHz peak gain: 7.2dBi · 6GHz peak gain: 7.3dBi Note: The equivalent antenna gain is 4.7dBi in 6GHz, 4.3dBi in 5GHz and 4.0dBi in 2.4GHz |
Protocol |
IEEE802.11a/b/g/n/ac/ax/be |
LEDs
Table1-2 LED description (fit mode)
LED status |
Off |
No power is present or the LED has been turned off. |
Yellow |
Flashing (twice per second) |
The Ethernet interfaces are down and no mesh links are established. |
Steady on |
The AP is initializing, or an initialization exception has occurred. |
Green |
Flashing (once every two seconds) |
The AP has started up but has not registered to any AC. |
Flashing (once per second) |
Only the 2.4G radio has associated clients. |
The AP is upgrading the image. |
Steady on |
The AP has registered with an AC, but does not have any associated clients. |
Blue |
Only the 5G radio has associated clients. |
Alternating between green and blue at 1 Hz |
Both the 2.4G and 5G radios have associated clients. |
Table1-3 LED description (cloud mode)
LED status |
Off |
Yellow |
Steady on |
Green |
Steady on |
The AP is in standby state, has connected to Cloudnet, but does not have any associated clients. |
The AP has connected to Cloudnet, and the radios have associated clients. |
Blue |
Steady on |
The AP is in standby state, has not connected to Cloudnet, and does not have any associated clients. |
The AP has not connected to Cloudnet, but the radios have associated clients. |
Table1-4 LED description (anchor AC mode)
LED status |
Off |
Yellow |
Steady on |
Green |
Steady on |
The AP has started up and is in standby state, but does not have any associated clients. |
Blue |
Alternating between green and blue |
Table1-5 RESET button description
Press and hold duration (sec) |
Button LED status |
0 to 5 |
Steady green |
Reset the AP. |
5 to 20 |
Flashing green (twice per second) |
Restore to the factory defaults. |
20 to 30 |
Yellow |
The AP is operating in fit AP mode. NOTE: The system will change the operating mode to cloud if you press and hold the button until the LED flashes green four times per second. |
The AP is operating in anchor AC mode. |
Flashing (four times per second) |
The AP is operating in cloud mode. |
> 30 |
Yellow |
Green |
Change the AP operating mode to cloud. NOTE: If you release the button, the AP will restart for the new mode to take effect. |
Ports
The AP provides the following ports:
· One 10GE1/PoE++ port.
· One 10GE2/P++SFP port.
· One GE/PSE port.
· One console port.
· One USB port.
It also provides a reset button (RESET).
Figure1-1 Ports on the AP
(1) USB port |
(2) Reset button |
(3) Console port |
(4) GE/PSE port |
(5) 10GE1/PoE++ port |
(6) 10GE2/P++SFP port |
Port |
Standards and protocols |
10GE1/PoE++ |
· IEEE802.3 · IEEE802.3u · IEEE802.3bt · IEEE802.3at · IEEE802.3af |
100M/1000M/2.5G/5G/10G Ethernet copper port that can act as an uplink port to connect to the Internet or MAN and as a standard PoE port at the same time. When the AP operates in fit AP mode, the port is represented by interface 10GE1/0/1 in the MAP file and gigabitethernet 1 for configuration on the AC. |
10GE2/P++SPF |
· IEEE802.3 · SFP MSA · SFF-8427 |
1000M/2.5G/5G/10G hybrid copper-fiber port |
GE/PSE |
· IEEE802.3 · IEEE802.3u |
10M/100M/1000M Ethernet copper port, used for connecting a downlink device. The AP can supply power through this port to a device with a maximum power consumption of 15 W. When the AP operates in fit AP mode, the port is represented by interface GE1/0/1 in the MAP file and gigabitethernet 1 for configuration on the AC. |
CONSOLE |
RS/EIA-232 |
Used for device configuration and management by the maintenance personnel. |
USB port |
USB2.0 |
Used for charging as well as data reading or writing. |
Reset button |
N/A |
For more information, see Table1-5. |
Optional transceiver modules
Common transceiver module
Transceiver module, fiber connector, and fiber view
You must use an SFP transceiver module and optical fiber with an LC connector to connect the fiber port on the AP.
Figure1-2 SFP transceiver module
Figure1-3 Optical fibers with LC connectors
(1) LC connector |
(2) Optical fiber |
Specifications
A transceiver module that has MM in its name supports multimode optical fibers. A transceiver module that has SM in its name supports single-mode optical fibers.
Table1-7 SFP-GE-SX-MM850-A transceiver module specifications
Item |
SFP-GE-SX-MM850-A |
Central wavelength |
850 nm |
Max transmission distance |
550 m (1804.46 ft) |
Data rate |
1250 Mbps |
Connector type |
Duplex LC |
Fiber mode |
MMF |
Fiber diameter |
50 μm |
Output optical power |
–9.5 to 0 dBm |
Receiver sensitivity |
≤ –17 dBm |
Light saturation |
≤ –3 dBm |
Table1-8 SFP-GE-LX-SM1310-A transceiver module specifications
Item |
SFP-GE-LX-SM1310-A |
1310 nm |
10 km (6.21 miles) |
Data rate |
1250 Mbps |
Connector type |
Duplex LC |
Fiber mode |
SMF |
Fiber diameter |
9 μm |
–9.5 to –3 dBm |
≤ –20 dBm |
Light saturation |
≤ –3 dBm |
Table1-9 SFP-GE-LH40-SM1310 transceiver module specifications
Item |
SFP-GE-LH40-SM1310 |
1310 nm |
40 km (24.86 miles) |
Data rate |
1250 Mbps |
Connector type |
Duplex LC |
Fiber mode |
SMF |
Fiber diameter |
9 μm |
–2 to +5 dBm |
≤ –22 dBm |
Light saturation |
≤ –3 dBm |
Table1-10 SFP-GE-LH40-SM1550 transceiver module specifications
Item |
SFP-GE-LH40-SM1550 |
1550 nm |
Data rate |
1250 Mbps |
Connector type |
Duplex LC |
Fiber mode |
SMF |
Fiber diameter |
9 μm |
–4 to +1 dBm |
≤ –21 dBm |
Light saturation |
≤ –3 dBm |
Hybrid copper-fiber transceiver module
Hybrid copper-fiber transceiver module and hybrid copper-fiber connector
Insert hybrid copper-fiber transceiver modules only into the hybrid copper-fiber ports (PSFP or PSFP+ ports). To connect the hybrid copper-fiber ports, use hybrid copper-fiber cables with fiber PoE patch cords.
Figure1-1 Hybrid copper-fiber transceiver module
Figure1-2 Hybrid copper-fiber cable with a hybrid copper-fiber connector
(1) Hybrid copper-fiber connector |
(2) Hybrid copper-fiber cable |
Table1-11 H3C-LS5M1SFPPOE-SFP GE hybrid copper-fiber transceiver module specifications
Item |
H3C-LS5M1SFPPOE-SFP |
1310 nm |
Data rate |
1.25 Gbps |
Connector type |
LC connector |
Max power consumption |
1.0 W |
Operating temperature range |
–40ºC to +85ºC (–40°F to +185°F) |
–9 to –1 dBm |
Table1-12 H3C-LS5M1SFPPOEA-SFP 10-GE multirate hybrid copper-fiber transceiver module specifications
Item |
H3C--LS5M1SFPPOEA-SFP |
1310 nm |
1.4 km (0.87 miles) |
Data rate |
10.3125 Gbps |
Connector type |
LC connector |
1.2 W |
–8.2 to +0.5 dBm |
