H3C WA7330X Access Point Installation Guide-5W100
HomeSupportWirelessWA7300 Series Access PointsTechnical DocumentsInstall & UpgradeInstallation GuidesH3C WA7330X Access Point Installation Guide-5W100
01-Installing the device
01-Installing the device 1.74 MB
1 Preparing for installation
WARNING
WARNING!
Install the AP under the guidance of technical engineers and read this chapter carefully before installation.
Examining the installation site
Examine the installation site before installation to ensure that the AP will work in a good environment.
Installation site selection
The installation site must be selected according to the network planning and technical requirements of telecommunications equipment, with factors such as climate, hydrology, geology, earthquake, electric power, and transportation taken into consideration.
Determine the installation location by observing the following principles:
·     The AP will not be exposed to high temperature, dust, harmful gases, electromagnetic interference sources (high power radars, radio stations, or electrical substations), unstable voltage, heavy vibration, and loud noise.
·     The location is not water seeping, water soaking, and condensing.
·     The location is away from inflammable and explosive substances.
Temperature and humidity requirements
Table1-1 Temperature and humidity requirements
Item
Specification
Operating temperature
–40°C to +65°C (–40°F to +149°F)
Storage temperature
–40°C to +70°C (–40°F to +158°F)
Operating humidity
0% RH to 100% RH, noncondensing
Storage humidity
Protection class
IP68
Power supply
You can power the AP through PoE, or by using a hybrid copper-fiber cable or power injector. For information about powering the AP, see "Powering the AP."
No power injector is provided with the AP. Purchase a power injector from H3C as required.
Grounding and lightning protection
The AP must be reliably grounded. Make sure the grounding points of the grounding conductor of the AP, lightning arresters, PE wire of the power cord, and antenna support are separate from each other, make good contact, and are securely connected and treated with corrosion protection.
Ground resistance
The ground resistance is typically required to be less than 5 ohms, and less than 10 ohms in an area with less than 20 thunderstorm days a year. For a piece of angle steel buried in the earth as a grounding conductor, the ground resistance is required to be less than 10 ohms. In an area with a higher ground resistance, reduce the ground resistance by using brine or resistance reducing agent around the grounding conductor.
The top of the grounding conductor must be a minimum of 0.7 m (2.30 ft) away from the ground surface. In cold areas, the grounding conductor must be buried below the frozen soil layer.
Grounding conductor
If a grounding strip is available, connect the yellow and green grounding cable to the grounding strip. To make a grounding cable, make sure the cable has a cross-section area of a minimum of 3.3 mm2 (0.01 in2) and a length of no longer than 3 m (9.84 ft).
If no grounding strip is available, bury a piece of angle steel/steel tube a minimum of 0.5 m (1.64 ft) long in the earth to act as the grounding conductor. It must be zinc-plated. In the case of a piece of angle steel, the size must be a minimum of 50 × 50 × 5 mm (1.97 × 1.97 × 0.20 in). In the case of a piece of steel tube, it must have a wall thickness of a minimum of 3.5 mm (0.14 in). Weld the grounding cable of the AP onto the grounding conductor and use anti-erosion treatment on the welding joint. With a cross-section area of a minimum of 3.3 mm2 (0.01 in2), the grounding cable must be as short as possible and must not be coiled.
Make sure the grounding terminals of all the lightning arresters of the AP and the peer device of the AP are reliably grounded.
Ground lead
A ground lead is a metal conductor connecting a grounding net and a grounding strip. The grounding cable of the AP must be connected to the grounding strip. The ground lead must be 30 m (98.43 ft) or shorter. A piece of zinc-coated flat steel with a cross-section area of 40 × 4 mm (1.57 × 0.16 in) or 50 × 5 mm (1.97 × 0.20 in) is recommended. Connect the grounding strip and the ground lead of the AP through the yellow and green grounding cable with an area of 35 mm2 (0.05 in2), or weld them directly. Use anti-erosion treatment on the welding joint.
Power grounding (AC)
Use a power cord with a protective earth (PE). Do not use a power cord with only an L line and an N line.
The neutral line of the power cord must not be connected with the PGND of other communications equipment. The L and N lines cannot be connected.
Lightning rod
The lightning protection grounding (for example, the grounding of the lightning rod) must be connected to the grounding conductor of the equipment room.
The lightning rod must be tall enough to protect the AP and its antennas.
In plain areas, the shielding angle of the lightning rod must be less than 45 degrees. In mountainous areas or lightning areas, the shielding angle must be less than 30 degrees.
Ethernet cable
Use a shielded twisted pair cable for outdoor installation. Make sure the devices at the two ends of the cable are reliably grounded.
If a metal tube is used, make sure the Ethernet cable is reliably grounded at both ends of the tube.
Installation accessories
Figure1-1 Installation accessories
Installation tools
When installing the AP, you might need the following tools. Prepare the installation tools yourself as required.
Figure1-2 Installation tools
2 Installing the AP
IMPORTANT
IMPORTANT:
As a best practice to ensure wireless signal coverage, have the AP installed by technical personnel.
Pre-installation tasks
Before installing an AP, perform the following tasks:
·     Connect the AP to the power source and the network. Examine the LED to verify that the AP can operate correctly. For more information about the AP LED, see "Appendix A  Technical specifications, LEDs, and ports."
·     Verify that cabling at the installation site has been completed.
·     Record the AP MAC address and serial number marked on the rear of the AP for future use.
Before installing an AP, read the following guidelines carefully:
·     The AP is large and heavy. Avoid bodily injury and device damage during the installation.
·     If you install the AP on a pole, make sure the pole is vertical to the ground and iron components have been treated with corrosion protection. The installation height and position of the AP must comply with the requirements of the design plan.
·     If you pole-mount the AP on the top of a building, make sure the AP does not project beyond the sides of the building.
·     To avoid high temperature caused by exposure to the sun, install the AP in a place without or with less direct sunlight and take protection measures if necessary.
Before connecting cables to the AP, read the following guidelines carefully:
·     Route cables according to the cabling design.
·     Arrange cables firmly and neatly without crossing, twisting, or cracking them.
·     Do not route cables together with high-voltage electric power pipelines, fire-fighting pipes, or lightning protection cables to avoid the electromagnetic interference.
·     Use PVC pipes, iron pipes, Plica tube, or cable troughs for cable routing. Route cable pipes and troughs neatly against the wall and connect them through hoses or pipe joints at the bend. Secure cable pipes and troughs by using cable ties or angle steels at the spacing of 1 m (3.28 ft) to 1.5 m (4.92 ft) and ground the two ends in the case of metal tubes.
·     As a best practice to avoid water accumulation, cut an opening at the bottom of the PVC pipes every 6 m (19.69 ft) if you route cables by using PVC pipes.
·     Seal the holes for routing cables in the wall with waterproof and flame retardant material.
Installation flowchart
Figure2-1 Installation flowchart
Installing the AP
Mounting the AP on a vertical pole
Attaching the AP bracket to the AP
When you attach the AP bracket to the AP, make sure the arrow on the AP bracket faces towards the port direction.
The procedure for attaching the AP bracket to the AP is the same for mounting the AP on a horizontal pole and a wall.
This procedure is required only for wall mounting and pole mounting.
Align the AP bracket with the screw holes on the rear of the AP, and then use M5 × 12 screws to attach the AP bracket to the AP.
Figure2-2 Attaching the AP bracket to the AP
Attaching the wall/pole bracket to the pole
The optional band clamps support poles with a diameter of 51 to 127 mm (2.01 to 5.00 in). If the diameter of the pole is not in the range, prepare band clamps yourself.
To attach the wall/pole bracket to the pole:
1.     As shown in Figure2-3, slide the two band clamps through the mounting slots on the wall/pole bracket. Then, use the band clamps to attach the wall/pole bracket to the vertical pole and fasten the screws.
Figure2-3 Attaching the wall/pole bracket to the vertical pole
2.     Use M5 × 18 screws to secure the AP bracket attached to the AP to the wall/pole bracket.
Figure2-4 Attaching the AP to the wall/pole bracket
Adjusting the AP angle
The adjustable angle of each arc-shaped fixing hole is 30 degrees, and the maximum adjustable angle supported by the AP bracket is 120 degrees.
To adjust the AP angle:
1.     Use an M5 × 18 screw to secure the central screw holes in the AP bracket and wall/pole bracket.
2.     Adjust the AP to the desired azimuth angle, and then use an M5 × 18 screw to secure the AP bracket attached to the AP to the wall/pole bracket.
Figure2-5 Adjusting the AP angle
Mounting the AP on a horizontal pole
Figure2-6 Attaching the AP bracket to the AP
1.     As shown in Figure2-7, slide the two band clamps through the mounting slots on the wall/pole bracket. Then, use the band clamps to attach the wall/pole bracket to the horizontal pole and fasten the screws.
Figure2-7 Securing the wall/pole bracket to the horizontal pole
Figure2-8 Attaching the AP to the wall/pole bracket
IMPORTANT
IMPORTANT:
After the AP is installed, you can adjust the AP angle as required. For more information, see "Adjusting the AP angle."
Mounting the AP on a wall
No expansion bolts are provided with the AP. Purchase them yourself as required.
For the procedure of attaching the AP bracket to the AP, see "Mounting the AP on a vertical pole."
Attaching the wall/pole bracket to the wall
1.     Use the wall/pole bracket to mark four installation holes on the wall.
Figure2-9 Marking the installation holes
2.     Drill four holes with a diameter of 8 mm (0.32 in) at the marked locations. Use a rubber hammer to tap an expansion bolt into each hole, fasten the nut on each expansion bolt to expand the expansion sleeve, and then remove the nut and washers.
¡     Keep the drill bit perpendicular to the wall and hold the drill handle tightly with both hands when drilling holes.
¡     In a sturdy and smooth wall, use a punch to create a hole to help locate the drill bit.
¡     The depths of four holes must be the same.
¡     Do not tap the expansion bolts all the way in, leaving a certain space for hanging the AP.
Figure2-10 Installing an expansion bolt in the wall
3.     Align the installation holes on the wall/pole bracket with the bolts on the wall, and then fasten the nuts and washers on the expansion bolts to secure the wall/pole bracket to the wall.
Figure2-11 Attaching the wall/pole bracket to the wall
4.     Use M5 × 18 screws to secure the AP bracket attached to the AP to the wall/pole bracket.
Figure2-12 Attaching the AP to the wall/pole bracket
Connecting cables
When you apply weatherproof tape to a cable connection, follow these restrictions and guidelines:
·     Make sure you attach the adhesive side of the tape to the cable connector.
·     Pull the tape as needed for overlap.
·     Start wrapping at the top of the connector, and overlap the tape to half-width. Avoid creases or wrinkles and press the tape against the connection so that there are no gaps. Smooth each wrapped layer with your hands to ensure full adhesion.
·     After you finish wrapping the tape, tightly bind cable ties at both ends of the weatherproof tape and liquid-tight adapter to prevent the tape from aging and falling off.
·     To prevent device damage, attach weatherproof caps tightly to connectors that are not in use.
Connecting an Ethernet cable
Use Category-5e or above Ethernet cables only. As a best practice, use shielded twisted pair (STP) cables.
To connect an Ethernet cable:
1.     Disassemble the weatherproof connector and sealing nut, and then feed the cable through the connector.
2.     Attach the split sealing washer to the cable, connect the Ethernet cable to the target port on the AP, and insert the sealing washer into the weatherproof connector.
3.     Use a wrench or wear nonslip gloves to fasten the sealing nut and the weatherproof connector.
Figure2-13 Connecting an Ethernet cable
4.     Start wrapping weatherproof tape from the connection point between the AP and the liquid-tight adapter. Make sure the entire liquid-tight adapter is covered. Smooth the tape edges to ensure full adhesion and use cable ties to secure the tape.
Figure2-14 Wrapping the liquid-tight adapter
5.     As a best practice to avoid water accumulation, cut an opening at the bottom of the PVC pipes every 6 m (19.69 ft) if you route cables by using PVC pipes.
Connecting a fiber cable
WARNING
WARNING!
·     To avoid cable damage, do not pull the fiber cable with excessive force.
·     To avoid affecting fiber performance, make sure the fiber cable is not bended or folded when fastening the sealing nut.
IMPORTANT
IMPORTANT:
·     Before connecting a fiber cable, remove the dust caps from the fiber connectors.
·     To use a fiber pigtail that does not have any protective sleeve, first use weatherproof tape to wrap the fiber pigtail before you connect the fiber pigtail.
To connect a fiber cable:
1.     Use weatherproof tape to start wrapping below the fiber connector, build up the fiber cable diameter near the opening in the split sealing washer. Smooth the tape edges to ensure full adhesion.
Figure2-15 Wrapping the fiber cable
2.     Disassemble the weatherproof connector and sealing nut, feed the cable through the connector, and then attach the split sealing washer to the cable.
Figure2-16 Feeding the cable through the weatherproof connector
3.     Insert the sealing washer into the weatherproof connector.
Figure2-17 Inserting the sealing washer into the weatherproof connector
4.     Attach a transceiver module to the P++SFP connector, and then connect the fiber cable to the transceiver module.
Figure2-18 Connecting a fiber cable
5.     Adjust the weatherproof connector to ensure that the fiber is not bended or folded, and then fasten the weatherproof connector.
Figure2-19 Fastening the weatherproof connector
6.     Fasten the sealing nut.
Figure2-20 Fastening the sealing nut
7.     Start wrapping weatherproof tape from the connection point between the AP and the liquid-tight adapter. Make sure the entire liquid-tight adapter is covered. Smooth the tape edges to ensure full adhesion and use cable ties to secure the tape.
Figure2-21 Wrapping the liquid-tight adapter
Connecting a hybrid copper-fiber cable
WARNING
WARNING!
·     To avoid cable damage, do not pull the hybrid copper-fiber cable with excessive force.
·     To avoid affecting the cable performance, make sure the hybrid copper-fiber cable is not bended or folded when fastening the sealing nut.
IMPORTANT
IMPORTANT:
Before connecting a hybrid copper-fiber cable, remove the dust caps from the connectors.
To connect a hybrid copper-fiber cable:
1.     Use weatherproof tape to start wrapping below the connector, build up the cable diameter near the opening in the split sealing washer. Smooth the tape edges to ensure full adhesion.
Figure2-22 Wrapping the hybrid copper-fiber cable
Figure2-23 Feeding the cable through the weatherproof connector
Figure2-24 Inserting the sealing washer into the weatherproof connector
4.     Attach a hybrid copper-fiber transceiver module to the P++SFP connector, and then connect the hybrid copper-fiber cable to the hybrid copper-fiber transceiver module.
Figure2-25 Connecting a hybrid copper-fiber cable
5.     Adjust the weatherproof connector to make sure the cable is not bended or folded, and then fasten the weatherproof connector.
Figure2-26 Fastening the weatherproof connector
Figure2-27 Fastening the sealing nut
7.     Start wrapping weatherproof tape from the connection point between the AP and the extended liquid-tight adapter. Make sure the entire extended liquid-tight adapter is covered. Smooth the tape edges to ensure full adhesion and use cable ties to secure the tape.
Figure2-28 Wrapping the extended liquid-tight adapter
Connecting the grounding cable
CAUTION
CAUTION:
·     Correctly connecting the grounding cable is crucial to lightning protection and EMI protection.
·     Before connecting the AP to the power source, make sure the grounding cable is correctly connected.
To connect the grounding cable:
1.     Make a grounding cable.
Figure2-29 Making a grounding cable
2.     Feed the ring terminal-end of the grounding cable through the base and then use the grounding screw to attach the ring terminal to grounding point on the AP.
Figure2-30 Connecting the grounding cable to the AP
Powering the AP
Powering the AP through PoE
CAUTION
CAUTION:
·     Only the 10GE1 port on the AP supports IEEE 802.3at PoE input.
·     To avoid damaging the GE/PSE port on the AP, do not connect a cable carrying power to the GE/PSE port.
To power the AP through PoE, use an Ethernet cable to connect an Ethernet port on a PoE switch to the 10GE1 port on the AP.
Figure2-31 Powering the AP through PoE
Powering the AP by using a hybrid copper-fiber cable
An uplink port on the AP uses a hybrid copper-fiber transceiver module and a hybrid copper-fiber cable for receiving power and communication. You do not need to connect other cables.
Figure2-32 Powering the AP by using a hybrid copper-fiber cable
Powering the AP by using a power injector
CAUTION
CAUTION:
Follow these restrictions and guidelines for powering the AP by using a power injector:
·     Make sure the AP is installed correctly before powering on the AP.
·     Place the power injector stable in a well-ventilated location near the switch or access controller. Do not suspend the power injector in the air or place it on another device.
·     If multiple power injectors are installed in one equipment room or low voltage room, use one power strip for all these injectors and lead in the power strip from the spare air switch of the AC power distribution box.
You can supply power to the AP by using a dual-port power injector. Use a power injector that meets the requirements listed in Table2-1.
Table2-1 Power injector specifications
Item
Specification
Model
EWPAM1UPOE2
Input
100 V to 240 V @ 1.5 A
Output
55 V @ 1100 mA
The power injector connection is different depending on whether a copper cable or optical fiber is used to connect the AP to the uplink network.
Using a copper cable for uplink network connection
To use a power injector to power the AP, the switch or AC to which the power injector connects does not need to be PoE-capable.
The PoE1 port on the PoE injector is connected to the uplink network through the LAN1 port, and PoE2 through LAN2.
To power the AP by using a power injector:
1.     Connect the PoE1 port on the injector to the 10GE1 port of the AP.
2.     Connect the LAN1 port on the injector to a switch or access controller.
3.     Connect the power injector and the Ethernet switch or AC to AC power sources.
Figure2-33 Powering the AP by using a power injector (1)
Using an optical fiber for uplink network connection
1.     Use an optical fiber to connect the P++SFP port on the AP to an Ethernet switch or access controller.
2.     Connect the power input end of the power injector to an AC power source.
3.     Connect the PoE1 port on the injector to the 10GE1 port of the AP.
Figure2-34 Powering the AP by using a power injector (2)
Labeling cables
After cable connection, attach labels to each cable as a best practice for future maintenance.
·     Attach a label to both ends of a cable and every certain distance.
·     Use cable flags or cable sleeves to label Ethernet cables. Use cable flags to label fiber cables.
·     Use waterproof labels with clear content. Attach labels to proper places where they can be seen directly.
·     When you route the cables outdoors, use transparent weatherproof tape to seal the labels to prevent them from falling off.
Verifying the installation
After the installation is complete, check the following items before powering on the AP:
·     The power source meets the power specification of the AP.
·     The AP is reliably grounded.
·     The Ethernet cables are correctly connected.
·     The cables are correctly labeled.
·     The unused ports on the AP are sealed with waterproof plugs.
Powering on the AP
IMPORTANT
IMPORTANT:
Make sure all cables are correctly connected and the AP is connected to the power source correctly before powering on the AP.
Switch on the external power source and verify that the AP is operating correctly by examining the LED on the AP. For more information about the LED, see "Appendix A  Technical specifications, LEDs, and ports."
3 Connecting the AP to the network
The AP operates as a fit AP and all AP settings are configured on the AC. Execute the display wlan ap all command on the AC. If the AP status is R/M, the AP has been connected to the network.
<AC> display wlan ap all
Total number of APs: 1
Total number of connected APs: 1
Total number of connected manual APs: 1
Total number of connected auto APs: 0
Total number of connected common APs: 1
Total number of connected WTUs: 0
Total number of inside APs: 0
Maximum supported APs: 3072
Remaining APs: 3071
Total AP licenses: 128
Remaining AP licenses: 127
                                 AP information
 State : I = Idle,       J  = Join,       JA = JoinAck,    IL = ImageLoad
         C = Config,     DC = DataCheck,  R  = Run   M = Master,  B = Backup
AP name                        APID  State Model           Serial ID
ap1                             1      R/M   WA7330X         219801A5F38206E00001
