17-NAT and IPv6 Transition Technologies Command Reference
HomeSupportRoutersSR6602-I[IE] SeriesReference GuidesCommand ReferencesH3C SR6602-I[IE] AI-Powered ICT Converged Gateways Command References(V9)- R9141-6W10017-NAT and IPv6 Transition Technologies Command Reference
01-NAT commands
01-NAT commands 608.44 KB
NAT commands· 1
address· 1
block-size· 1
display nat address-group· 2
display nat all 4
display nat dns-map· 11
display nat eim·· 13
display nat eim statistics· 14
display nat inbound· 15
display nat log· 17
display nat no-pat 18
display nat outbound· 19
display nat outbound port-block-group· 21
display nat port-block· 22
display nat port-block-group· 25
display nat server 27
display nat server-group· 30
display nat session· 31
display nat static· 33
display nat statistics· 36
global-ip-pool 37
inside ip· 38
local-ip-address· 39
nat address-group· 40
nat alg· 41
nat dns-map· 42
nat hairpin enable· 43
nat inbound· 44
nat inbound rule move· 46
nat log enable· 47
nat log flow-active· 48
nat log flow-begin· 49
nat log flow-end· 49
nat log port-block usage threshold· 50
nat log port-block-assign· 51
nat log port-block-withdraw· 51
nat mapping-behavior endpoint-independent 52
nat outbound· 53
nat outbound port-block-group· 56
nat outbound rule move· 57
nat port-block flow-trigger enable· 58
nat port-block synchronization enable· 59
nat port-block-group· 59
nat server rule move· 60
nat server (interface-based NAT) 61
nat server-group· 66
nat static enable· 67
nat static inbound· 68
nat static inbound net-to-net 70
nat static inbound net-to-net rule move· 72
nat static inbound rule move· 73
nat static outbound· 73
nat static outbound net-to-net 76
nat static outbound net-to-net rule move· 78
nat static outbound rule move· 79
nat timestamp delete· 80
port-block· 81
port-range· 81
reset nat session· 82
vrrp vrid (interface-based NAT) 83
NAT commands
address
Use address to add an address range to a NAT address group.
Use undo address to remove an address range from a NAT address group.
address start-address end-address
undo address start-address end-address
No address ranges exist.
NAT address group view
start-address end-address: Specifies the start and end IP addresses of the address range. The end address must not be lower than the start address. If they are the same, the address range has only one IP address. Each address range can contain a maximum of 256 addresses.
A NAT address group is a set of address ranges. The source address in a packet destined for an external network is translated into an address in one of the address ranges.
You can repeat this command to add multiple address ranges to a NAT address group. Make sure the address ranges do not overlap in the NAT address group.  The device supports a maximum of 4096 address ranges in total for all NAT address groups.
If a public address range overlaps with the address range in static port block mappings, make sure the port ranges in static port block mappings do not overlap with those in dynamic port block mappings. Otherwise, the device might assign the same IP address and port block to two different users, in which condition NAT sessions might not be established for one user.
# Add two address ranges to an address group.
[Sysname] nat address-group 2
[Sysname-address-group-2] address 10.1.1.1 10.1.1.15
[Sysname-address-group-2] address 10.1.1.20 10.1.1.30
nat address-group
block-size
Use block-size to set the port block size.
Use undo block-size to restore the default.
block-size block-size
undo block-size
The port block size is 256.
NAT port block group view
block-size: Specifies the number of ports for a port block. The value range for this argument is 1 to 65535.
Set an appropriate port block size based on the number of private IP addresses, the number of public IP addresses, and the port range in the port block group.
The port block size cannot be larger than the number of ports in the port range.
# Set the port block size to 1024 for port block group 1.
[Sysname] nat port-block-group 1
[Sysname-port-block-group-1] block-size 1024
Use display nat address-group to display NAT address group information.
display nat address-group [ group-id ]
group-id: Specifies the ID of a NAT address group. The value range for this argument is 0 to 65535.If you do not specify the group-id argument, this command displays information about all NAT address groups.
# Display information about all NAT address groups.
<Sysname> display nat address-group
NAT address group information:
  Totally 5 NAT address groups.
  Address group 1:
    VRID      : 1
    Port range: 1-65535
    Address information:
      Start address         End address
      202.110.10.10         202.110.10.15
  Address group 2:
    Port range: 1-65535
      202.110.10.20         202.110.10.25
      202.110.10.30         202.110.10.35
  Address group 3:
    Port range: 1024-65535
      202.110.10.40         202.110.10.50
  Address group 4:
    Port range: 10001-65535
    Port block size: 500
    Extended block number: 1
      202.110.10.60         202.110.10.65
  Address group 6:
    Port range: 1-65535
# Display information about NAT address group 1.
<Sysname> display nat address-group 1
  Address group 1:
    VRID      : 1
    Port range: 1-65535
Information about the NAT address group
Totally n NAT address groups
Total number of NAT address groups.
Address group
ID of the NAT address group.
VRID
Virtual router ID (VRRP group number). If no VRRP group is specified, this field is not displayed.
Port range
Port range for public IP addresses.
Block size
Number of ports in a port block. This field is not displayed if the port block size is not set.
Number of extended port blocks. This field is not displayed if the number of extended port blocks is not set.
Address information
Information about the IP addresses in the address group.
Start address
Start IP address of an address range. If you do not specify a start address for the range, this field displays hyphens (---).
End address
End IP address of an address range. If you do not specify an end address for the range, this field displays hyphens (---).
nat address-group
display nat all
Use display nat all to display all NAT configuration information.
display nat all
# Display all NAT configuration information.
<Sysname> display nat all
  Address group 1:
    VRID      : 1
    Port range: 1-65535
  Address group 2:
    Port range: 1-65535
  Address group 3:
  Address group 4:
  Address group 6:
    Port range: 1-65535
NAT server group information:
  Totally 3 NAT server groups.
  Group Number        Inside IP             Port        Weight
  1                   192.168.0.26          23          100
                      192.168.0.27          23          500
  2                   ---                   ---         ---
  3                   192.168.0.26          69          100
NAT inbound information:
  Totally 1 NAT inbound rules.
  Interface: Ten-GigabitEthernet0/0/6
    ACL: 2038         Address group: 2      Add route: Y
    NO-PAT: Y         Reversible: N
    VPN instance: vpn_nat
    Rule name: ruleinbound
    Priority: 1000
    Config status: Active
NAT outbound information:
  Totally 2 NAT outbound rules.
    ACL: 2036         Address group: 1      Port-preserved: Y
    NO-PAT: N         Reversible: N
    Rule name: ruleoutbound1
    Priority: 1001
    Config status: Inactive
    Reasons for inactive status:
      The following items don't exist or aren't effective: address group, and ACL.
  Interface: Ten-GigabitEthernet0/0/7
    ACL: 2037         Address group: 1      Port-preserved: N
    NO-PAT: Y         Reversible: Y
    Rule name: ruleoutbound2
    Priority: 1002
NAT internal server information:
  Totally 5 internal servers.
    VRID          : 10
    Global ACL    : 2000
    Local IP/port : 192.168.10.1/23
    Rule name     : rule1
    Priority      : 1000
    Config status : Active
Interface: Ten-GigabitEthernet0/0/8
    Protocol: 6(TCP)
    Global IP/port: 50.1.1.1/23
    Local IP/port : 192.168.10.15/23
    ACL           : 2000
    Rule name     : rule2
  Interface: Ten-GigabitEthernet0/0/9
    Protocol: 6(TCP)
    Global IP/port: 50.1.1.1/23-30
    Local IP/port : 192.168.10.15-192.168.10.22/23
    Global VPN    : vpn1
    Local VPN     : vpn3
    Rule name     : rule3
    Protocol: 255(Reserved)
    Global IP/port: 50.1.1.100/---
    Local IP/port : 192.168.10.150/---
    Global VPN    : vpn2
    Local VPN     : vpn4
    ACL           : 3000
    Rule name     : rule4
    Config status : Inactive
      The following items don't exist or aren't effective: local VPN, and ACL.
  Interface: Ten-GigabitEthernet0/0/10
    Protocol: 17(UDP)
    Global IP/port: 50.1.1.2/23
    Local IP/port : server group 1
                    192.168.0.26/23       (Connections: 10)
                    192.168.0.27/23       (Connections: 20)
    Global VPN    : vpn1
    Local VPN     : vpn3
    Rule name     : rule5
Static NAT mappings:
  Totally 2 inbound static NAT mappings.
  Net-to-net:
    Global IP    : 2.2.2.1 – 2.2.2.255
    Local IP     : 1.1.1.0
    Netmask      : 255.255.255.0
    Global VPN   : vpn2
    Local VPN    : vpn1
    ACL          : 2000
    Reversible   : Y
    Rule name    : rulestatic1
    Priority     : 1000
  IP-to-IP:
    Global IP    : 5.5.5.5
    Local IP     : 4.4.4.4
    Global VPN   : vpn3
    Local VPN    : vpn4
    ACL          : 2001
    Reversible   : Y
    Rule name    : rulestatic2
    Priority     : 1000
    Packet type ignore: Y
      The following items don't exist or aren't effective: local VPN, global VPN, and ACL.
  Totally 2 outbound static NAT mappings.
  Net-to-net:
    VRID          : 10
    Local IP     : 1.1.1.1 - 1.1.1.255
    Global IP    : 2.2.2.0
    Local VPN    : vpn1
    Global VPN   : vpn2
    ACL          : 2000
    Reversible   : Y
    Rule name    : rulenettonet1
    Priority     : 1000
  IP-to-IP:
    VRID          : 10
    Local IP     : 4.4.4.4
    Global IP    : 5.5.5.5
    Local VPN    : vpn1
    Global VPN   : vpn2
    ACL:         : 2001
    Reversible   : Y
    Rule name    : rulenettonet2
    Priority     : 1000
      The following items don't exist or aren't effective: ACL.
Interfaces enabled with static NAT:
  Totally 2 interfaces enabled with static NAT.
  Interface: Ten-GigabitEthernet0/0/11
NAT DNS mappings:
  Totally 2 NAT DNS mappings.
  Domain name  : www.example.com
  Global IP    : 6.6.6.6
  Global port  : 23
  Protocol     : TCP(6)
  Domain name  : service.example.com
  Global IP    : ---
  Global port  : 12
  Protocol     : TCP(6)
    The following items don't exist or aren't effective: interface IP address.
NAT logging:
  Log enable               : Enabled
  Flow-begin               : Disabled
  Flow-end                 : Disabled
  Flow-active              : Disabled
  Port-block-assign        : Disabled
  Port-block-withdraw      : Disabled
  Port-alloc-fail          : Enabled
  Port-block-alloc-fail    : Disabled
  Port-usage               : Disabled
  Port-block-usage         : Enabled(40%)
NAT hairpinning:
  Totally 2 interfaces enabled with NAT hairpinning.
NAT mapping behavior:
  Mapping mode : Endpoint-Independent
  ACL          : 2050
NAT ALG:
  DNS        : Enabled
  FTP        : Enabled
  H323       : Disabled
  ICMP-ERROR : Enabled
  ILS        : Disabled
  MGCP       : Disabled
  NBT        : Disabled
  PPTP       : Enabled
  RTSP       : Enabled
  RSH        : Disabled
  SCCP       : Disabled
  SIP        : Disabled
  SQLNET     : Disabled
  TFTP       : Disabled
  XDMCP      : Disabled
NAT port block group information:
  Totally 3 NAT port block groups.
  Port block group 1:
    Port range: 1-65535
    Block size: 256
    Local IP address information:
      Start address        End address          VPN instance
      172.16.1.1           172.16.1.254         ---
      192.168.1.1          192.168.1.254        vpna
      192.168.3.1          192.168.3.254        vpna
    Global IP pool information:
      201.1.1.1            201.1.1.10
      201.1.1.21           201.1.1.25
  Port block group 2:
    Port range: 10001-30000
    Block size: 500
      10.1.1.1             10.1.10.255          vpnb
      202.10.10.101        202.10.10.120
  Port block group 3:
    Port range: 1-65535
    Block size: 256
NAT outbound port block group information:
  Totally 2 outbound port block group items.
    port-block-group: 2
    port-block-group: 10
      The following items don't exist or aren't effective: port block group.
The output shows all NAT configuration information. Table 2 describes only the fields for the output of the nat hairpin enable and nat mapping-behavior commands.
Information about the NAT address group. See Table 1 for output description.
Information about the internal server group. See Table 15 for output description.
Inbound dynamic NAT configuration. See Table 6 for output description.
Outbound dynamic NAT configuration. See Table 9 for output description.
NAT server mapping configuration. See Table 14 for output description.
Static NAT mappings
Static NAT mappings. See Table 17 for output description.
NAT DNS mappings
NAT DNS mappings. See Table 3 for output description.
NAT logging
NAT logging configuration. See Table 7 for output description.
NAT hairpinning
NAT hairpin configuration.
Totally n interfaces enabled NAT hairpinning
Number of interfaces with NAT hairpin enabled.
NAT hairpin-enabled interface.
Rule name
Name of the NAT rule.
Priority
Priority of the NAT rule.
Config status
Status of the NAT hairpin configuration.
Mapping behavior mode of PAT:
·     Endpoint-Independent.
·     Address and Port-Dependent Mapping.
ACL
ACL number or name. If no ACL is specified for NAT, this field displays hyphens (---).
Config status
Status of the NAT mapping behavior configuration:
·     Active—The configuration is taking effect.
·     Inactive—The configuration is not taking effect.
Reasons why the NAT mapping behavior configuration does not take effect. This field is available when the Config status field displays Inactive.
NAT ALG
NAT ALG configuration for different protocols.
Configuration information about NAT port block groups. See Table 13 for output description.
Configuration information about static outbound port block mapping. See Table 10 for output description.
display nat dns-map
Use display nat dns-map to display NAT DNS mappings.
display nat dns-map
# Display NAT DNS mappings.
<Sysname> display nat dns-map
NAT DNS mapping information:
  Global IP    : 6.6.6.6
  Global port  : 23
  Protocol     : TCP(6)
  Global IP    : ---
  Global port  : 12
  Protocol     : TCP(6)
Information about NAT DNS mappings.
Totally n NAT DNS mappings
Total number of NAT DNS mappings.
Domain name
Domain name of the internal server.
Global IP
Public IP address of the internal server.
·     If Easy IP is configured, this field displays the IP address of the specified interface.
·     If you do not specify a public IP address, this field displays hyphens (---).
Global port
Public port number of the internal server.
Protocol
Protocol name and number of the internal server.
Config status
Status of the DNS mapping configuration:
Reasons why the DNS mapping configuration does not take effect. This field is available when the Config status field displays Inactive.
nat dns-map
display nat eim
Use display nat eim to display information about NAT Endpoint-Independent Mapping (EIM) entries.
display nat eim [ slot slot-number ] [ protocol { tcp | udp } ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays EIM entry information for all cards.
protocol: Specifies a protocol by its type.
tcp: Specifies the TCP protocol.
udp: Specifies the UDP protocol.
EIM entries are created when PAT operates in EIM mode. An EIM entry is a 3-tuple entry, and it records the mapping between a private address/port and a public address/port.
The EIM entry provides the following functions:
·     The same EIM entry applies to subsequent connections initiated from the same source IP and port.
·     The EIM entries allow reverse translation for connections initiated from external hosts to internal hosts.
# Display information about NAT EIM entries on the specified slot.
<Sysname> display nat eim slot 0
slot 0:
Local  IP/port: 192.168.100.100/1024
Global IP/port: 200.100.1.100/2048
DS-Lite tunnel peer: -
Local  VPN: vpn1
Global VPN: vpn2
Protocol: TCP(6)
Local  IP/port: 192.168.100.200/2048
Global IP/port: 200.100.1.200/4096
Protocol: UDP(17)
Total entries found: 2
# Display information about NAT EIM entries for TCP on the specified slot.
<Sysname> display nat eim slot 0 protocol tcp
slot 0:
Local  VPN: vpn1
Global VPN: vpn2
Protocol: TCP(6)
Total entries found: 1
DS-Lite tunnel peer
DS-Lite tunnel B4 address. If the session does not belong to any DS-Lite tunnel, this field displays a hyphen (-).
Local VPN
MPLS L3VPN instance to which the private IP address belongs. If the private IP address does not belong to any VPN instance, this field is not displayed.
Global VPN
MPLS L3VPN instance to which the public IP address belongs. If the public IP address does not belong to any VPN instance, this field is not displayed.
Protocol
Protocol name and number.
Total entries found
Total number of EIM entries.
nat outbound
Use display nat eim statistics to display NAT EIM entry statistics.
display nat eim statistics [ slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays EIM entry statistics for all cards.
The NAT EIM entry statistics includes the following information:
·     The number of EIM entries.
·     The creation rate of EIM entries for TCP.
·     The creation rate of EIM entries for UDP.
# Display EIM entry statistics for the specified slot.
<Sysname> display nat eim statistics slot 2
EIM: Total EIM entries.
TCP: Total EIM entries for TCP.
UDP: Total EIM entries for UDP.
Rate: Creating rate of EIM entries.
TCP rate: Creating rate of EIM entries for TCP.
UDP rate: Creating rate of EIM entries for UDP.
Slot EIM       TCP       UDP       Rate          TCP rate      UDP rate
                                  (entries/s)   (entries/s)   (entries/s)
2    0         0         0         0             0             0
Table 5 Command output
Total EIM entries
Total number of EIM entries for TCP.
Total number of EIM entries for UDP.
Creation rate of EIM entries.
Creation rate of EIM entries for TCP.
Creation rate of EIM entries for UDP.
display nat inbound
Use display nat inbound to display inbound dynamic NAT configuration.
display nat inbound
# Display inbound dynamic NAT configuration.
<Sysname> display nat inbound
  Totally 2 NAT inbound rules.
    VPN instance: vpn1
    Rule name: ruleinbound1
    Priority: 1000
    ACL: 2037         Address group: 1      Add route: Y
    VPN instance: vpn2
    Rule name: ruleinbound2
    Priority: 1000
Table 6 Command output
Information about inbound dynamic NAT configuration.
Totally n NAT inbound rules
Total number of inbound dynamic NAT rules.
Interface where the inbound dynamic NAT rule is configured.
ACL
ACL number or name.
Address group
NAT address group used by the inbound dynamic NAT rule.
Add route
Whether to add a route when a packet matches the inbound dynamic NAT rule:
·     YAdds a route.
·     NDoes not add a route.
NO-PAT
Whether NO-PAT or PAT is used:
·     YNO-PAT is used.
·     NPAT is used.
Reversible
Whether reverse address translation is allowed:
·     YReverse address translation is allowed.
·     NReverse address translation is not allowed.
VPN instance
MPLS L3VPN instance to which the NAT address group belongs. If the NAT address group does not belong to any VPN instance, the field is not displayed.
Rule name
Priority
Config status
Status of the inbound dynamic NAT configuration:
Reasons why the inbound dynamic NAT configuration does not take effect.
nat inbound
display nat log
Use display nat log to display NAT logging configuration.
display nat log
# Display NAT logging configuration.
<Sysname> display nat log
NAT logging:
  Flow-end                 : Disabled
Table 7 Command output
NAT logging
Log enable
Enabling status of NAT logging.
·     Enabled—NAT logging is enabled. If an ACL is specified for NAT logging, this field also displays the ACL number or name.
·     Disabled—NAT logging is disabled.
Flow-begin
Enabling status of logging for NAT session establishment events.
Flow-end
Enabling status of logging for NAT session removal events.
Flow-active
Enabling status of logging for active NAT flows. If it is enabled, this field also displays the interval in minutes at which active flow logs are generated.
Port-block-assign
Enabling status of logging for NAT port block assignment.
Port-block-withdraw
Enabling status of logging for NAT port block withdrawal.
Port-alloc-fail
Enabling status of logging for NAT port allocation failures.
Enabling status of logging for NAT port block assignment failures.
Port-usage
Enabling status of logging for port usage in port blocks. If logging for port usage in port blocks is enabled, this field also displays the usage threshold in percentage.
Port-block-usage
Logging is enabled for port block usage. This field also displays the port block usage threshold in percentage. The default threshold value is 90%.
nat log enable
nat log flow-active
nat log flow-begin
display nat no-pat
Use display nat no-pat command to display information about NAT NO-PAT entries.
display nat no-pat [ slot slot-number ]
Default user roles
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays NO-PAT entry information for all cards.
A NO-PAT entry records the mapping between a private address and a public address.
The NO-PAT entry provides the following functions:
·     The same entry applies to subsequent connections initiated from the same source IP address.
·     The NO-PAT entries allow reverse translation for connections initiated from external hosts to internal hosts.
Outbound and inbound NO-PAT address translations create their own NO-PAT tables. These two types of tables are displayed separately.
# Display information about NO-PAT entries for the specified slot.
<Sysname> display nat no-pat slot 1
Slot 1:
Global  IP: 200.100.1.100
Local   IP: 192.168.100.100
Global VPN: vpn2
Local  VPN: vpn1
Reversible: N
Type      : Inbound
Local   IP: 192.168.100.200
Global  IP: 200.100.1.200
Reversible: Y
Type      : Outbound
Table 8 Command output
Local VPN
Global VPN
Reversible
·     Y—Reverse address translation is allowed.
·     N—Reverse address translation is not allowed.
Type of the NO-PAT entry:
·     Inbound—A NO-PAT entry created during inbound dynamic NAT.
·     Outbound—A NO-PAT entry created during outbound dynamic NAT.
Total entries found
Total number of NO-PAT entries.
nat inbound
nat outbound
Use display nat outbound to display outbound dynamic NAT configuration.
# Display outbound dynamic NAT configuration.
<Sysname> display nat outbound
    Priority: 1000
    ACL: 2037         Address group: 2      Port-preserved: N
    Priority: 1000
      The following items don't exist or aren't effective: global VPN, and ACL.
Table 9 Command output
Information about outbound dynamic NAT configuration.
Totally n NAT outbound rules
Total number of outbound dynamic NAT rules.
Interface where the outbound dynamic NAT rule is configured.
ACL
IPv4 ACL number or name. If no IPv4 ACL is specified for outbound dynamic NAT configuration, this field displays hyphens (---).
Address group
Address group used by the outbound dynamic NAT rule. If no address group is specified for address translation, the field displays hyphens (---).
Port-preserved
Whether to try to preserve the port numbers for PAT.
NO-PAT
Whether NO-PAT is used:
·     YNO-PAT is used.
·     NPAT is used.
Reversible
VPN instance
Configuration mode
Configuration method of the device.
·     This field displays NETCONF (action) if the device is configured by using a NETCONF action operation. Only the SmartMC network supports this configuration method.
·     This field is not displayed if the device is configured by using other methods.
Rule name
Priority
Config status
Status of the outbound dynamic NAT configuration:
Reasons why the outbound dynamic NAT configuration does not take effect. This field is available when the Config status field displays Inactive. The following are possible reasons that the system might display:
·     The following items don't exist or aren't effective: global VPN, interface IP address, address group, and ACL.
·     NAT address conflicts.
nat outbound
Use display nat outbound port-block-group to display static outbound port block group mapping rules for NAT444.
# Display static outbound port block mapping rules for NAT444.
<Sysname> display nat outbound port-block-group
    Rule name: rule1
    port-block-group: 2
    Rule name: rule2
Table 10 Command output
Information about static outbound port block mapping rules.
Totally n outbound port block group items
Total number of static outbound port block mapping rules.
Interface where the static outbound port block mapping rules configured.
port-block-group
ID of the port block group.
Rule name
Name of the mapping rule.
Config status
Status of the port block mapping rule configuration:
Reasons why the port block mapping rule configuration does not take effect. This field is available when the Config status field displays Inactive.
Use display nat port-block to display NAT port block mappings.
display nat port-block { dynamic | static } [ ip ipv4-source-address ] [ slot slot-number ] [ verbose ]
dynamic: Displays dynamic port block mappings.
static: Displays static port block mappings.
ip ipv4-source-address: Specifies a source IPv4 address. The IPv4 address must be the private source IPv4 address in a port block mapping.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays port block mappings for all cards.
verbose: Displays detailed information about NAT port block mappings. If you do not specify this keyword, this command displays brief information about NAT port block mappings.
# Display static port block mappings for the specified slot.
<Sysname> display nat port-block static slot 1
Slot 1:
Local VPN     Local IP         Global IP        Port block   Connections  Extend
---           100.100.100.111  202.202.100.101  10001-10256  0            ---
---           100.100.100.112  202.202.100.101  10257-10512  0            ---
---           100.100.100.113  202.202.100.101  10513-10768  0            ---
vpn012345678  100.100.100.113  202.202.100.101  10769-11024  0            ---
901234567890
1234567
---           100.100.100.114  0.0.0.0          ---          0            ---
Total mappings found: 5
# Display dynamic port block mappings.
<Sysname> display nat port-block dynamic slot 1
Slot 1:
---           101.1.1.12       192.168.135.201  10001-11024  1            ---
Total mappings found: 1
# Display detailed information about dynamic port block mappings for the specified slot.
<Sysname> display nat port-block dynamic slot 1 verbose
Slot 1:
  Dynamic port block entry
Local IP         : 200.1.24.219
Local vpn        : ---(0)
Global IP        : 202.2.1.8
Global vpn       : ---(0)
Port block       : 24774-26023
Connections      : 0
FailgroupID      : 16
PortLimit TCP    : N/A
PortLimit UDP    : N/A
PortLimit ICMP   : N/A
PortLimit total  : 100
PortUsed  TCP    : 0
PortUsed  UDP    : 0
PortUsed  ICMP   : 0
PortUsed  total  : 0
Extend port block: N
Local IP         : 200.1.40.231
Local vpn        : ---(0)
Global IP        : 202.2.1.10
Global vpn       : ---(0)
Port block       : 32274-33523
Connections      : 0
FailgroupID      : 16
PortLimit TCP    : N/A
PortLimit UDP    : N/A
PortUsed  TCP    : 0
PortUsed  UDP    : 0
PortUsed  ICMP   : 0
PortUsed  total  : 0
Total mappings found: 2
# Display detailed information about static port block mappings for the specified slot.
<Sysname> display nat port-block static slot 1 verbose
Slot 1:
    Static port block entry
Local vpn        : ---(0)
Global vpn       : ---(0)
Connections      : 0
FailgroupID      : 16
PortLimit TCP    : N/A
PortLimit UDP    : N/A
PortUsed  TCP    : 0
PortUsed  UDP    : 0
PortUsed  ICMP   : 0
PortUsed  total  : 0
Local vpn        : ---(0)
Global IP        : 0.0.0.0
Global vpn       : ---(0)
Port block       : ---
Connections      : 0
FailgroupID      : 16
PortLimit TCP    : N/A
PortLimit UDP    : N/A
PortUsed  TCP    : 0
PortUsed  UDP    : 0
PortUsed  ICMP   : 0
PortUsed  total  : 0
Table 11 Command output
Local VPN
MPLS L3VPN instance to which the private IP address belongs. If the private IP address does not belong to any VPN instance, this field displays hyphens (---).
Local IP
Private IP address.
Global IP
Public IP address. If no public address is allocated due to insufficient public network resources, this field displays 0.0.0.0.
Port block
Port block defined by a start port and an end port. If public network resources are insufficient, this field displays hyphens (---).
Connections
Number of connections established by using the ports in the port block.
Extend
Number of extended port blocks. If no extended port blocks are configured, this field displays hyphens (---).
Total number of port block mappings.
Table 12 Command output
Local IP
Private IP address.
Local vpn
MPLS L3VPN instance to which the private IP address belongs. If the private IP address does not belong to any VPN instance, this field displays ---(0).
Global IP
Global IP address. If no public address is allocated due to insufficient public network resources, this field displays 0.0.0.0.
Global vpn
MPLS L3VPN instance to which the global IP address belongs. If the global IP address does not belong to any VPN instance, this field displays ---(0).
Port block
Port block defined by a start port number and an end port number. If public network resources are insufficient, this field displays hyphens (---).
Connections
PortLimit TCP
Maximum number of ports that can be assigned to TCP.
PortLimit UDP
Maximum number of ports that can be assigned to UDP.
PortLimit ICMP
Maximum number of ports that can be assigned to ICMP.
PortLimit total
Maximum number of ports that are available for assignment.
PortUsed  TCP
Number of ports assigned to TCP packets.
PortUsed  UDP
Number of ports assigned to UDP packets.
PortUsed  ICMP
Number of ports assigned to ICMP packets.
PortUsed  total
Total number of ports in use.
Extend port block
Number of extended port blocks. If no extended port blocks are configured, this field displays N.
Use display nat port-block-group to display NAT port block group configuration.
display nat port-block-group [ group-id ]
group-id: Specifies the ID of a NAT port block group. The value range for this argument is 0 to 65535. If you do not specify this argument, the command displays configuration of all NAT port block groups.
# Display configuration of all NAT port block groups.
<Sysname> display nat port-block-group
  Port block group 1:
    VRID      : 2
    Port range: 1-65535
    Block size: 256
  Port block group 2:
    Block size: 500
  Port block group 3:
    Port range: 1-65535
    Block size: 256
# Display information about NAT port block group 1.
<Sysname> display nat port-block-group 1
  Port block group 1:
    VRID      : 2
    Port range: 1-65535
    Block size: 256
Table 13 Command output
Information about the port block group configuration.
Totally n NAT port block groups
Total number of port block groups.
VRID
Port block group
ID of the NAT port block group.
Port range
Port range for the public IP addresses.
Block size
Information about private IP addresses.
Information about public IP addresses.
Start address
Start IP address of a private or public IP address range. If no start IP address is specified for the address range, this field displays hyphens (---).
End address
End IP address of a private or public IP address range. If no end IP address is specified for the address range, this field displays hyphens (---).
VPN instance
MPLS L3VPN instance to which the private IP address range belongs. If no VPN instance is specified for the private address range, this field displays hyphens (---).
display nat server
Use display nat server to display NAT server mappings.
display nat server
# Display NAT server mappings.
<Sysname> display nat server
    VRID          : 1
    Global ACL    : 2000
    Rule name     : rule1
    Priority      : 1000
    VRID          : 1
    Protocol: 6(TCP)
    Rule name     : rule2
    VRID          : 1
    Protocol: 6(TCP)
    Global VPN    : vpn1
    Local VPN     : vpn3
    Rule name     : rule3
      The following items don't exist or aren't effective: local VPN.
    VRID          : 1
    Global VPN    : vpn2
    Local VPN     : vpn4
    Rule name     : rule4
    VRID          : 1
    Protocol: 17(UDP)
                    1.1.1.1/21            (Connections: 10)
                    192.168.100.200/80    (Connections: 20)
    Global VPN    : vpn1
    Local VPN     : vpn10
    Rule name     : rule5
Table 14 Command output
Information about NAT server mappings.
Totally n internal servers
Total number of NAT server mappings.
Interface where NAT server mapping is configured.
VRID
Protocol
Protocol number and name of the internal server.
Global IP/port
Public IP address and port number of the internal server.
·     Global IP—A single IP address or an IP address range. If you use Easy IP, this field displays the IP address of the specified interface. If you do not specify an address for the interface, the Global IP field displays hyphens (---).
·     port—A single port number or a port number range. If no port number is in the specified protocol, the port field displays hyphens (---).
Local IP/port
For common NAT server mapping, this field displays the private IP address and port number of the internal server.
·     Local IP—A single IP address or an IP address range.
For load sharing NAT server mapping, this field displays the internal server group ID, IP address, port number, and number of connections of each member.
Global VPN
MPLS L3VPN instance to which the public IP addresses belong. If the public IP addresses do not belong to any VPN instance, this field is not displayed.
Local VPN
MPLS L3VPN instance to which the private IP addresses belong. If the private IP addresses do not belong to any VPN instance, this field is not displayed.
ACL
ACL number or name. If no ACL is specified, this field is not displayed.
Rule name
Name of the NAT server mapping.
Priority
Priority of the NAT server mapping.
Configuration mode
Config status
Status of the NAT server mapping configuration:
Reasons why the NAT server mapping configuration does not take effect. This field is available when the Config status field displays Inactive. The following are possible reasons that the system might display:
·     The following items don't exist or aren't effective: global VPN, interface IP address, server group, and ACL.
·     Server configuration conflicts.
nat server
Use display nat server-group to display internal server group configuration.
display nat server-group [ group-id ]
group-id: Specifies the ID of the internal server group. The value range is 0 to 65535. If you do not specify this argument, the command displays configuration about all internal server groups.
# Display configuration about all internal server groups.
<Sysname> display nat server-group
                      192.168.0.27          23          500
  2                   ---                   ---         ---
# Display configuration about internal server group 1.
<Sysname> display nat server-group 1
                      192.168.0.27          23          500
Table 15 Command output
Information about the NAT server group configuration.
Totally n NAT server groups
Total number of NAT server groups.
Group Number
Inside IP
Private IP address of a member in the internal server group. If no address is specified, this field displays hyphens (---).
Port
Private port number of a member in the internal server group. If no port number is specified, this field displays hyphens (---).
Weight
Weight of a member in the internal server group. If no weight value is specified, this field displays hyphens (---).
nat server-group
display nat session
Use display nat session to display NAT sessions.
display nat session [ { source-ip source-ip | destination-ip destination-ip } * [ vpn-instance vpn-instance-name ] ] [ slot slot-number ] [ brief | verbose ]
source-ip source-ip: Displays NAT sessions for the source IP address specified by the source-ip argument. The IP address must be the source IP address of the packet that triggers the session establishment.
destination-ip destination-ip: Displays NAT sessions for the destination IP address specified by the destination-ip argument. The IP address must be the destination IP address of the packet that triggers the session establishment.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. The VPN must be the VPN inside the packet. If you do not specify a VPN instance, this command displays NAT sessions that do not belong to any VPN instance.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays NAT sessions for all cards.
brief: Display brief information about NAT sessions.
verbose: Display detailed information about NAT sessions. If you do not specify this keyword, this command displays brief information about NAT sessions.
If you do not specify any parameters, this command displays detailed information about all NAT sessions.
# Display detailed information about NAT sessions for the specified slot.
<Sysname> display nat session slot 1 verbose
Slot 1:
Initiator:
  Source      IP/port: 192.168.1.18/1877
  Destination IP/port: 192.168.1.55/22
  VPN instance/VLAN ID/VLL ID: -/-/-
  Protocol: TCP(6)
  Inbound interface: Ten-GigabitEthernet0/0/6
Responder:
  Source      IP/port: 192.168.1.55/22
  Destination IP/port: 192.168.1.10/1877
  Protocol: TCP(6)
  Inbound interface: Ten-GigabitEthernet0/0/7
State: TCP_SYN_SENT
Application: SSH
Start time: 2019-07-29 19:12:36
Initiator->Responder:         1 packets         48 bytes
Responder->Initiator:         0 packets          0 bytes
Total sessions found: 1
# Display brief information about NAT sessions for the specified slot.
<Sysname> display nat session slot 1 brief
Slot 1:
Protocol   Source IP/port      Destination IP/port    Global IP/port
TCP        10.2.1.58/2477      20.1.1.2/1025          30.2.4.9/226
Table 16 Command output
Source IP/port
Source IP address and port number.
Destination IP/port
Destination IP address and port number.
DS-Lite tunnel peer
Destination address of the DS-Lite tunnel interface. If the session does not belong to any DS-Lite tunnel, this field displays a hyphen (-).
The fields identify the following information:
·     VPN instance—MPLS L3VPN instance to which the session belongs. ‌
·     VLAN ID—VLAN to which the session belongs for Layer 2 forwarding.
·     VLL ID—INLINE to which the session belongs for Layer 2 forwarding.
If no VPN instance, VLAN ID, or VLL ID is specified, a hyphen (-) is displayed for the related field.
Protocol
Transport layer protocol type: DCCP, ICMP, Raw IP, SCTP, TCP, UDP, or UDP-Lite.
Inbound interface
Input interface.
NAT session status.
Application
Application layer protocol type, such as FTP and DNS.
This field displays OTHER for the protocol types identified by non-well-known ports.
Start time
Time when the session starts.
TTL
Remaining NAT session lifetime in seconds.
Number of packets and packet bytes from the initiator to the responder.
Number of packets and packet bytes from the responder to the initiator.
Total number of sessions.
Source IP/port
Source IP address and port number of the initiator.
Destination IP/port
Destination IP address and port number of the initiator.
Global IP/port
Public IP address and port number.
reset nat session
display nat static
Use display nat static to display static NAT mappings.
display nat static
# Display static NAT mappings.
<Sysname> display nat static
  Net-to-net:
    Global IP    : 1.1.1.1 - 1.1.1.255
    Local IP     : 2.2.2.0
    Global VPN   : vpn2
    Local VPN    : vpn1
    ACL          : 2000
    Reversible   : Y
    Rule name    : ruleinbound1
    Priority     : 1000
  IP-to-IP:
    Global IP   : 5.5.5.5
    Local IP     : 4.4.4.4
    Global VPN   : vpn3
    Local VPN    : vpn4
    ACL          : 2001
    Reversible   : Y
    Rule name    : ruleinbound2
    Priority     : 1000
  Net-to-net:
    VRID         : 10
    Global IP    : 2.2.2.0
    Local VPN    : vpn1
    Global VPN   : vpn2
    ACL          : 2000
    Reversible   : Y
    Rule name    : ruleout1
    Priority     : 1000
  IP-to-IP:
    VRID         : 10
    Local IP     : 4.4.4.4
    Global IP    : 5.5.5.5
    Local VPN    : vpn4
    Global VPN   : vpn3
    ACL:         : 2000
    Reversible   : Y
    Rule name    : ruleout2
    Priority     : 1000
      The following items don't exist or aren't effective: local VPN, and global VPN.
Table 17 Command output
Static NAT mappings
Information about static NAT mapping configuration.
Totally n inbound static NAT mappings
Total number of inbound static NAT mappings.
Totally n outbound static NAT mappings
Total number of outbound static NAT mappings.
Net-to-net
Net-to-net static NAT mapping.
IP-to-IP
One-to-one static NAT mapping.
VRID
Local IP
Private IP address or address range.
Global IP
Public IP address or address range.
Netmask
Network mask.
Local VPN
Global VPN
ACL
Reversible
Whether reverse address translation is allowed. If reverse address translation is allowed, this field displays Y. If reverse address translation is not allowed, this field is not displayed.
Interfaces on which static NAT is enabled.
Totally n interfaces enabled with static NAT
Total number of interfaces where static NAT is enabled.
Interface on which static NAT is enabled.
Rule name
Name of the static NAT mapping.
Priority
Priority of the static NAT mapping.
Packet type ignore
Whether the NAT device checks the protocol packet type when TCP, ICMP, or SCTP packet exchanges trigger the creation of session entries.
·     If this field displays Y, the NAT device does not check the protocol packet type.
·     If this field is not displayed, the NAT device checks the protocol packet type.
Config status
Status of the static NAT mapping configuration:
Reasons why the static NAT mapping configuration does not take effect. This field is available when the Config status field displays Inactive. The following are possible reasons that the system might display:
·     The following items don't exist or aren't effective: local VPN, global VPN, and ACL.
nat static
nat static net-to-net
nat static enable
Use display nat statistics to display NAT statistics.
display nat statistics [ summary ] [ slot slot-number ]
summary: Displays NAT statistics summary. If you do not specify this keyword, this command displays detailed NAT statistics.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays NAT statistics for all cards.
# Display detailed information about NAT statistics.
<Sysname> display nat statistics
Slot 1:
  Total session entries: 100
  Total EIM entries: 1
  Total inbound NO-PAT entries: 0
  Total outbound NO-PAT entries: 0
  Total static port block entries: 10
  Total dynamic port block entries: 15
  Active static port block entries: 0
  Active dynamic port block entries: 0
Table 18 Command output
Number of NAT session entries.
Total EIM entries
Number of EIM entries.
Number of inbound NO-PAT entries.
Number of outbound NO-PAT entries.
Number of static port block mappings.
Number of dynamic port block mappings that can be created. It equals the number of port blocks for dynamic assignment, including the assigned and unassigned port blocks.
Number of static port block mappings that are in use.
Number of dynamic port block mappings that have been created. It equals the number of dynamically assigned port blocks.
# Display summary information about NAT statistics.
<Sysname> display nat statistics summary
SPB: Total static port block entries.
DPB: Total dynamic port block entries.
ASPB: Active static port block entries.
ADPB: Active dynamic port block entries.
Slot Sessions  EIM       SPB       DPB       ASPB      ADPB
2    0         0         0         1572720   0         0
Table 19 Command output
Sessions
EIM
SPB
DPB
ASPB
Number of static port block mappings in use.
ADPB
global-ip-pool
Use global-ip-pool to add a public IP address range to a NAT port block group.
Use undo global-ip-pool to remove a public IP address range from a NAT port block group.
global-ip-pool start-address end-address
undo global-ip-pool start-address end-address
No public IP address ranges exist.
start-address end-address: Specifies the start IP address and end IP address of a public IP address range. The end IP address cannot be lower than the start IP address. If the start and end IP addresses are the same, only one public IP address is specified.
A static port block mapping maps a public IP address to multiple private IP addresses and assigns a unique port block to each private IP address. The number of port blocks that a public IP address can assign is determined by dividing the number of ports in the port range by the port block size.
Every time you execute this command, an address range can contain a maximum of 256 public IP addresses. All public IP address ranges in one port block group cannot overlap.
Public IP address ranges in different port block groups can overlap. The port ranges for overlapped public IP address ranges cannot overlap.
# Add a public IP address range to the port block group 1. The public IP address range consists of IP addresses from 202.10.1.1 to 202.10.1.10.
[Sysname-port-block-group-1] global-ip-pool 202.10.1.1 202.10.1.10
inside ip
Use inside ip to add a server to an internal server group.
Use undo inside ip to remove a server from an internal server group.
inside ip inside-ip port port-number [ weight weight-value ]
undo inside ip inside-ip port port-number
An internal server group has no server members.
Internal server group view
inside-ip: Specifies the IP address of an internal server.
port port-number: Specifies the port number of an internal server, in the range of 1 to 65535, excluding FTP port 20.
weight weight-value: Specifies the weight of the internal server. The value range is 1 to 1000, and the default value is 100. An internal server with a larger weight receives a larger percentage of connections in the internal server group.
# Add a server with IP address 10.1.1.2 and port number 30 to internal server group 1.
[Sysname] nat server-group 1
[Sysname-nat-server-group-1] inside ip 10.1.1.2 port 30
nat server-group
local-ip-address
Use local-ip-address to add a private IP address range to a NAT port block group.
Use undo local-ip-address to remove a private IP address range from a NAT port block group.
local-ip-address start-address end-address [ vpn-instance vpn-instance-name ]
undo local-ip-address start-address end-address [ vpn-instance vpn-instance-name ]
No private IP address ranges exist in a NAT port block group.
start-address end-address: Specifies the start IP address and end IP address of a private IP address range. The end IP address cannot be lower than the start IP address. If the start and end IP addresses are the same, only one private IP address is specified.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the private IP address range belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the private IP address range does not belong to any VPN instance, do not specify this option.
A static port block mapping maps one public IP address to multiple private IP addresses and assigns a unique port block to each private IP address.
You can add multiple private IP address ranges to the same port block group.
·     The private IP address ranges in the same VPN instance cannot overlap.
·     The private IP address ranges that do not belong to any VPN instances cannot overlap.
When you add private IP address ranges to different port block groups with the same VPN instance, make sure the IP address ranges do not overlap.
In a NAT port block group, the number of private IP addresses cannot be larger than the number of assignable port blocks. Otherwise, some private IP addresses cannot obtain port blocks. The number of port blocks that a public IP address can assign is determined by dividing the number of ports in the port range by the port block size.
# Add a private IP address range to port block group 1. The private IP address range consists of IP addresses from 172.16.1.1 to 172.16.1.255 in VPN instance vpn1.
[Sysname-port-block-group-1] local-ip-address 172.16.1.1 172.16.1.255 vpn-instance vpn1
nat address-group
Use nat address-group to create a NAT address group and enter its view, or enter the view of an existing NAT address group.
Use undo nat address-group to delete a NAT address group.
nat address-group group-id
undo nat address-group group-id
No NAT address groups exist.
group-id: Assigns an ID to the NAT address group. The value range for this argument is 0 to 65535.
A NAT address group can contain multiple address ranges added by using the address command.
# Create a NAT address group numbered 1.
[Sysname] nat address-group 1
address
display nat all
nat inbound
nat outbound
nat alg
Use nat alg to enable NAT ALG for the specified or all supported protocols.
Use undo nat alg to disable NAT ALG for the specified or all supported protocols.
nat alg { all | dns | ftp | h323 | icmp-error | ils | mgcp | nbt | pptp | rsh | rtsp | sccp | sip | sqlnet | tftp | xdmcp }
undo nat alg { all | dns | ftp | h323 | icmp-error | ils | mgcp | nbt | pptp | rsh | rtsp | sccp | sip | sqlnet | tftp | xdmcp }
NAT ALG is enabled for DNS, FTP, ICMP error messages, PPTP, and RTSP, and is disabled for the other supported protocols.
all: Enables NAT ALG for all supported protocols.
dns: Enables NAT ALG for DNS.
ftp: Enables NAT ALG for FTP.
h323: Enables NAT ALG for H.323.
icmp-error: Enables NAT ALG for ICMP error packets.
ils: Enables NAT ALG for ILS.
mgcp: Enables NAT ALG for MGCP.
nbt: Enables NAT ALG for NBT.
pptp: Enables NAT ALG for PPTP.
rsh: Enables NAT ALG for RSH.
rtsp: Enables NAT ALG for RTSP.
sccp: Enables NAT ALG for SCCP.
sip: Enables NAT ALG for SIP.
sqlnet: Enables NAT ALG for SQLNET.
tftp: Enables NAT ALG for TFTP.
xdmcp: Enables NAT ALG for XDMCP.
NAT ALG translates address or port information in the application layer payload to ensure connection establishment.
For example, an FTP application includes a data connection and a control connection. The IP address and port number for the data connection depend on the payload information of the control connection. This requires NAT ALG to translate the address and port information to establish the data connection.
# Enable NAT ALG for FTP.
[Sysname] nat alg ftp
display nat all
nat dns-map
Use nat dns-map to configure a NAT DNS mapping.
Use undo nat dns-map to remove a NAT DNS mapping.
nat dns-map domain domain-name protocol pro-type { interface interface-type interface-number | ip global-ip } port global-port
undo nat dns-map domain domain-name
No NAT DNS mappings exist.
domain domain-name: Specifies the domain name of an internal server. A domain name is a dot-separated case-insensitive string that can include letters, digits, hyphens (-), underscores (_), and dots (.) (for example, aabbcc.com). The domain name can contain a maximum of 253 characters, and each separated string contains no more than 63 characters.
protocol pro-type: Specifies the type of the protocol used by the internal server, tcp or udp.
interface interface-type interface-number: Enables Easy IP to use the IP address of the interface specified by its type and number as the public address of the internal server.
ip global-ip: Specifies the public IP address used by the internal server to provide services for the external network.
port global-port: Specifies the public port number used by the internal server to provide services for the external network. The port number format can be one of the following:
·     A number in the range of 1 to 65535.
·     A protocol name, a string of 1 to 15 characters. For example, ftp and telnet.
The NAT DNS mapping must cooperate with the NAT Server feature.
·     A NAT DNS mapping maps the domain name of an internal server to the public IP address, public port number, and protocol type of the internal server.
·     A NAT server mapping maps the public IP and port to the private IP and port of the internal server.
The cooperation allows an internal host to access an internal server on the same private network by using the domain name of the internal server when the DNS server is on the public network. The DNS reply from the external DNS server contains only the domain name and public IP address of the internal server in the payload. The NAT interface might have multiple internal servers configured with the same public IP address but different private IP addresses. If a DNS mapping is configured, the device can obtain the public IP address, public port number, and protocol type of the internal server by using the domain name. Then it can find the correct internal server by using the public IP address, public port number, and protocol type of the internal server.
You can configure multiple NAT DNS mappings.
# Configure a NAT DNS mapping to map the domain name www.example.com to the public IP address 202.112.0.1, public port number 12345, and protocol type TCP.
[Sysname] nat dns-map domain www.example.com protocol tcp ip 202.112.0.1 port 12345
display nat all
display nat dns-map
nat server
nat hairpin enable
Use nat hairpin enable to enable NAT hairpin.
Use undo nat hairpin enable to disable NAT hairpin.
nat hairpin enable
NAT hairpin is disabled.
Interface view
NAT hairpin allows internal hosts to access each other or allows internal hosts to access internal servers. It must cooperate with NAT Server, outbound dynamic NAT, or outbound static NAT. The source and destination IP addresses of the packets are translated on the interface connected to the internal network.
# Enable NAT hairpin on Ten-GigabitEthernet 0/0/6.
[Sysname] interface ten-gigabitethernet 0/0/6
[Sysname-Ten-GigabitEthernet0/0/6] nat hairpin enable
display nat all
nat inbound
Use nat inbound to configure an inbound dynamic NAT rule.
Use undo nat inbound to delete an inbound dynamic NAT rule.
nat inbound { ipv4-acl-number | name ipv4-acl-name } address-group group-id [ vpn-instance vpn-instance-name ] [ no-pat [ reversible ] [ add-route ] ] [ rule rule-name ] [ priority priority ]
undo nat inbound { ipv4-acl-number | name ipv4-acl-name }
No inbound dynamic NAT rules exist.
Interface view
ipv4-acl-number: Specifies an ACL by its number in the range of 2000 to 3999.
name ipv4-acl-name: Specifies an ACL by its name, a case-insensitive string of 1 to 63 characters. The ACL name must start with an English letter and to avoid confusion, it cannot be all.
address-group group-id: Specifies an address group for address translation. The value range for the group-id argument is 0 to 65535.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the addresses in the address group belong. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the addresses in the address group do not belong to any VPN instance, do not specify this option.
no-pat: Uses NO-PAT for inbound NAT. If you do not specify this keyword, PAT is used. PAT supports only TCP, UDP, and ICMP query packets. For an ICMP packet, the ICMP ID is used as its source port number.
reversible: Enables reverse address translation. Reverse address translation uses existing NO-PAT entries to translate the destination address for connections actively initiated from the internal network to the external network.
add-route: Automatically adds a route to the source address after translation. The output interface is the NAT interface and the next hop is the source address before translation.
rule rule-name: Specifies a name for the rule, a case-sensitive string of 1 to 63 characters. It cannot contain backward slashes (\), forward slashes (/), colons (:), asterisks (*), question marks (?), left angle brackets (<), right angle brackets (>), vertical bars (|), quotation marks ("), or at signs (@). If you do not specify this option, the rule does not have a name.
priority priority: Specifies a priority for the rule, in the range of 0 to 2147483647. A smaller value represents a higher priority. If you do not specify this option, the rule has the lowest priority among the same type of NAT rules.
Inbound dynamic NAT translates the source IP addresses of incoming packets permitted by the ACL into IP addresses in the address group.
Inbound dynamic NAT supports the PAT and NO-PAT modes.
·     PAT—Performs both IP address translation and port translation.
·     NO-PAT—Performs only IP address translation.
The NO-PAT mode supports reverse address translation. Reverse address translation uses ACL reverse matching to identify packets to be translated. ACL reverse matching works as follows:
·     Compares the source IP address/port of a packet with the destination IP addresses/ports in the ACL.
·     Translates the destination IP address of the packet according to the matching NO-PAT entry, and then compares the translated destination IP address/port with the source IP addresses/ports in the ACL.
Inbound dynamic NAT typically cooperates with one of the following to implement bidirectional NAT:
·     Outbound dynamic NAT (the nat outbound command).
·     NAT Server (the nat server command).
·     Outbound static NAT (the nat static command).
An address group cannot be used by both the nat inbound and nat outbound commands. It cannot be used by the nat inbound command in both PAT and NO-PAT modes.
Do not specify the add-route keyword if the subnets where the internal and external networks reside overlap. For other network scenarios:
·     If you specify the add-route keyword, the device automatically adds a route to the source address after translation for a packet. To avoid communication failure caused by ARP resolution failure, configure a route on the device in the following condition:
To ensure successful communication, when the device receives a packet in which the source address and its input interface address belong to different subnets, it typically performs ARP resolution on the source address to obtain its corresponding MAC address. However, if ARP resolution fails, the packet cannot reach its destination, causing communication failure.
To resolve such an issue, configure a static route on the device. Configure the destination address of the static route as the source address of the packet and the next hop address as the peer device address in the target network. The 32-bit host route (with a mask of 255.255.255.255) makes sure all packets sent to the source address can be forwarded to the correct next hop, which does not need ARP resolution. The configuration avoids ARP resolution failure in communication between different network subnets and ensures network stability and communication reliability.
·     If you do not specify the add-route keyword, you must manually add the route. As a best practice, add routes manually because automatic route adding is slow.
An ACL can be used by only one inbound dynamic NAT rule on an interface.
You can configure multiple inbound dynamic NAT rules on an interface.
The vpn-instance parameter is required if you deploy inbound dynamic NAT for VPNs. The specified VPN instance must be the VPN instance to which the NAT interface belongs.
If the inbound dynamic NAT rules have the same priority value, the device uses the following rules to determine their match order:
·     NAT rules with named ACLs have higher priorities than NAT rules with numbered ACLs.
·     NAT rules with named ACLs are matched in alphanumeric order of their ACL names.
·     NAT rules with numbered ACLs are matched in descending order of their ACL numbers.
# Configure ACL 2001 to permit packets only from subnet 10.110.10.0/24 in VPN vpn10 to pass through.
[Sysname] acl basic 2001
[Sysname-acl-ipv4-basic-2001] rule permit vpn-instance vpn10 source 10.110.10.0 0.0.0.255
[Sysname-acl-ipv4-basic-2001] rule deny
# Configure the MPLS L3VPN instance named vpn10.
[Sysname] ip vpn-instance vpn10
[Sysname-vpn-instance-vpn10] route-distinguisher 100:001
[Sysname-vpn-instance-vpn10] vpn-target 100:1 export-extcommunity
[Sysname-vpn-instance-vpn10] vpn-target 100:1 import-extcommunity
[Sysname-vpn-instance-vpn10] quit
# Create address group 1 and add the address range of 202.110.10.10 to 202.110.10.12 to the group.
[Sysname-address-group-1] address 202.110.10.10 202.110.10.12
[Sysname-address-group-1] quit
# Configure an inbound NO-PAT rule on interface Ten-GigabitEthernet 0/0/6. NAT translates the source addresses of incoming packets into the addresses in address group 1, and automatically adds routes for translated packets. Set the rule name to abc, and the priority to 0.
[Sysname-Ten-GigabitEthernet0/0/6] nat inbound 2001 address-group 1 vpn-instance vpn10 no-pat add-route rule abc priority 0
display nat all
display nat inbound
display nat no-pat
nat inbound rule move
Use nat inbound rule move to change the priority of an inbound dynamic NAT rule.
nat inbound rule move nat-rule-name1 { after | before } nat-rule-name2
The priority of a rule is determined by its location on the rule list. A NAT rule appearing earlier on the rule list has a higher priority for packet matching.
Interface view
nat-rule-name1: Specifies the name of the rule be moved.
after: Moves the rule nat-rule-name1 to the line after the rule nat-rule-name2 (called the reference rule). The priority value of the reference rule does not change. The priority value of the moved rule equals the priority value of the reference rule plus one.
before: Moves the rule nat-rule-name1 to the line before the rule nat-rule-name2. The priority value of the reference rule does not change. The priority value of the moved rule equals the priority value of the reference rule minus one.
nat-rule-name2: Specifies the name of the NAT rule as a reference rule for the NAT rule to be moved.
This command is applicable only to named inbound dynamic NAT rules.
# Move the inbound dynamic NAT rule abc to the line before the rule def.
[Sysname-Ten-GigabitEthernet0/0/6] nat inbound rule move abc before def
nat inbound
nat log enable
Use nat log enable to enable NAT logging.
Use undo nat log enable to disable NAT logging.
nat log enable [ acl { ipv4-acl-number | name ipv4-acl-name } ]
undo nat log enable
acl: Specifies an ACL.
You must enable NAT logging before you enable NAT session logging, NAT user logging, or NAT alarm logging.
The acl keyword takes effect only for NAT session logging. If an ACL is specified, flows matching the permit rule might trigger NAT session logs. If you do not specify an ACL, all flows processed by NAT might trigger NAT session logs.
# Enable NAT logging.
[Sysname] nat log enable
display nat all
display nat log
nat log flow-active
nat log flow-begin
nat log flow-end
nat log port-alloc-fail
nat log port-block-alloc-fail
nat log port-block-assign
nat log port-block-withdraw
nat log flow-active
Use nat log flow-active to enable logging for active NAT flows and set the logging interval.
Use undo nat log flow-active to disable logging for active NAT flows.
nat log flow-active time-value
Logging for active NAT flows is disabled.
time-value: Specifies the interval for logging active NAT flows, in the range of 10 to 120 minutes.
Active NAT flows are NAT sessions that last for a long time. The logging feature helps track active NAT flows by periodically logging the active NAT flows.
This command takes effect only after you use the nat log enable command to enable NAT logging.
# Enable logging for active NAT flows and set the logging interval to 10 minutes.
[Sysname] nat log flow-active 10
display nat all
display nat log
nat log enable
nat log flow-begin
Use nat log flow-begin to enable logging for NAT session establishment events.
Use undo nat log flow-begin to disable logging for NAT session establishment events.
nat log flow-begin
Logging for NAT session establishment events is disabled.
# Enable logging for NAT session establishment events.
[Sysname] nat log flow-begin
display nat all
display nat log
nat log enable
nat log flow-end
Use nat log flow-end to enable logging for NAT session removal events.
Use undo nat log flow-end to disable logging for NAT session removal events.
nat log flow-end
Logging for NAT session removal events is disabled.
# Enable logging for NAT session removal events.
[Sysname] nat log flow-end
display nat all
display nat log
nat log enable
nat log port-block usage threshold
Use nat log port-block usage threshold to set the port block usage threshold.
Use undo nat log port-block port-usage threshold to restore the default.
nat log port-block usage threshold value
undo nat log port-block usage threshold
The port block usage threshold is 90%.
value: Specifies a threshold in the range of 40 to 100 in percentage.
A log is generated when the port block usage exceeds the threshold.
# Set the port block usage threshold to 80%.
[Sysname] nat log port-block usage threshold 80
display nat all
display nat log
nat log enable
Use nat log port-block-assign to enable NAT user logging for port block assignment.
Use undo nat log port-block-assign to disable NAT user logging for port block assignment.
NAT user logging is disabled for port block assignment.
For static port block mapping, the NAT gateway generates a user log when it translates the first connection from a private IP address.
For dynamic port block mapping, the NAT gateway generates a user log when it assigns or extends a port block for a private IP address.
# Enable NAT user logging for port block assignment.
[Sysname] nat log port-block-assign
display nat all
display nat log
nat log enable
Use nat log port-block-withdraw to enable NAT user logging for port block withdrawal.
Use undo nat log port-block-withdraw to disable NAT user logging for port block withdrawal.
NAT user logging is disabled for port block withdrawal.
For static port block mapping, the NAT gateway generates a user log when all connections from a private IP address are disconnected.
For dynamic port block mapping, the NAT gateway generates a user log when all the following conditions are met:
·     The port blocks (including the extended ones) assigned to the private IP address are withdrawn.
·     The corresponding mapping entry is deleted.
# Enable NAT user logging for port block withdrawal.
[Sysname] nat log port-block-withdraw
display nat all
display nat log
nat log enable
nat mapping-behavior endpoint-independent
Use nat mapping-behavior endpoint-independent to specify the Endpoint-Independent Mapping mode for PAT.
Use undo nat mapping-behavior endpoint-independent to restore the default.
nat mapping-behavior endpoint-independent [ acl { ipv4-acl-number | name ipv4-acl-name } ]
Address and Port-Dependent Mapping applies.
acl: Specifies an ACL to define the applicable scope of Endpoint-Independent Mapping.
PAT supports the following types of NAT mappings:
·     Endpoint-Independent Mapping—Uses the same IP and port mapping (EIM entry) for packets from the same source and port to any destination. EIM allows external hosts to access the internal hosts by using the translated IP address and port. It allows internal hosts behind different NAT gateways to access each other.
·     Address and Port-Dependent Mapping—Uses different IP and port mappings for packets with the same source IP and port to different destination IP addresses and ports. APDM allows an external host to access an internal host only under the condition that the internal host has previously accessed the external host. It is secure, but it does not allow internal hosts behind different NAT gateways to access each other.
This command takes effect only on outbound PAT. Address and Port-Dependent Mapping always applies to inbound PAT.
If you specify an ACL, Endpoint-Independent Mapping applies to packets that are permitted by the ACL. If you do not specify an ACL, Endpoint-Independent Mapping applies to all packets.
# Apply the Endpoint-Independent Mapping mode to all packets for address translation.
[Sysname] nat mapping-behavior endpoint-independent
# Apply the Endpoint-Independent Mapping to FTP and HTTP packets, and the Address and Port-Dependent Mapping to other packets for address translation.
[Sysname] acl advanced 3000
[Sysname-acl-ipv4-adv-3000] rule permit tcp destination-port eq 80
[Sysname-acl-ipv4-adv-3000] rule permit tcp destination-port eq 21
[Sysname] nat mapping-behavior endpoint-independent acl 3000
nat outbound
display nat eim
nat outbound
Use nat outbound to configure an outbound dynamic NAT rule.
Use undo nat outbound to delete an outbound dynamic NAT rule.
NO-PAT:
nat outbound [ ipv4-acl-number | name ipv4-acl-name ] address-group group-id [ vpn-instance vpn-instance-name ] no-pat [ reversible ] [ rule rule-name ] [ priority priority ]
undo nat outbound [ ipv4-acl-number | name ipv4-acl-name ]
PAT:
nat outbound [ ipv4-acl-number | name ipv4-acl-name ] [ address-group group-id ] [ vpn-instance vpn-instance-name ] [ port-preserved ] [ rule rule-name ] [ priority priority ]
No outbound dynamic NAT rules exist.
Interface view
address-group group-id: Specifies an address group for NAT. The value range for the group-id argument is 0 to 65535. If you do not specify an address group, the IP address of the interface is used as the NAT address. Easy IP is used.
no-pat: Uses NO-PAT for outbound NAT. If you do not specify this keyword, PAT is used. PAT only supports TCP, UDP, and ICMP query packets. For an ICMP packet, the ICMP ID is used as its source port number.
reversible: Enables reverse address translation. Reverse address translation uses existing NO-PAT entries to translate the destination address for connections actively initiated from the external network to the internal network.
port-preserved: Tries to preserve port number for PAT. This keyword does not take effect on dynamic port block mappings.
Outbound dynamic NAT is typically configured on the interface connected to the external network. You can configure multiple outbound dynamic NAT rules on an interface.
Outbound dynamic NAT supports the following modes:
·     PAT—Performs both IP address translation and port translation. The PAT mode allows external hosts to actively access the internal hosts if the Endpoint-Independent Mapping behavior is used.
·     NO-PAT—Performs only IP address translation. The NO-PAT mode allows external hosts to actively access the internal hosts if you specify the reversible keyword. If an ACL is specified, reverse address translation only applies to packets permitted by ACL reverse matching. ACL reverse matching works as follows:
¡     Compares the source IP address/port of a packet with the destination IP addresses/ports in the ACL.
¡     Translates the destination IP address of the packet according to the matching NO-PAT entry, and then compares the translated destination IP address/port with the source IP addresses/ports in the ACL.
The dynamic port block mapping does not support the NO-PAT mode.
When you specify a NAT address group, follow these restrictions and guidelines:
·     An address group cannot be used by both the nat inbound and nat outbound commands.
·     An address group cannot be used by the nat outbound command in both PAT and NO-PAT modes.
·     When a port range and port block parameters are specified in the NAT address group, this command configures a dynamic port block mapping rule. Packets matching the ACL permit rule are processed by dynamic port block mapping.
When you specify an ACL, follow these restrictions and guidelines:
·     An ACL can be used by only one outbound dynamic NAT rule on an interface.
·     If you configure multiple outbound dynamic NAT rules, only one outbound dynamic NAT rule can contain no ACL.
·     If you specify an ACL, NAT translates the source IP addresses of outgoing packets permitted by the ACL into IP addresses in the address group. If you do not specify an ACL, NAT translates all packets.
·     Outbound dynamic NAT rules with ACLs configured on an interface takes precedence over those without ACLs. If two ACL-based dynamic NAT rules are configured, the rule with the higher ACL number has higher priority.
·     For dynamic port block mappings, make sure the ACL rules in a newly added NAT rule do not overlap with ACL rules in existing NAT rules that already have matching traffic.
A user is not allowed to access a service on an internal server through different external addresses or external port numbers. When configuring load sharing NAT Server, the number of members cannot be less than the value N in one of the following situations:
·     A public address, N consecutive public port numbers, and one internal server group.
·     N consecutive public addresses, a public port number, and one internal server group.
The vpn-instance parameter is required if you deploy outbound dynamic NAT for VPNs. The specified VPN instance must be the VPN instance to which the NAT interface belongs.
If the ACL-based outbound dynamic NAT rules have the same priority value, the device uses the following rules to determine their match order:
# Configure ACL 2001 to permit packets only from subnet 10.110.10.0/24 to pass through.
[Sysname-acl-ipv4-basic-2001] rule permit source 10.110.10.0 0.0.0.255
# Configure an outbound dynamic PAT rule on Ten-GigabitEthernet 0/0/6 to translate the source addresses of outgoing packets permitted by ACL 2001 into the addresses in address group 1.
[Sysname-Ten-GigabitEthernet0/0/6] nat outbound 2001 address-group 1
[Sysname-Ten-GigabitEthernet0/0/6] quit
Or
# Configure an outbound NO-PAT rule on Ten-GigabitEthernet 0/0/6 to translate the source addresses of outgoing packets permitted by ACL 2001 into the addresses in address group 1.
[Sysname-Ten-GigabitEthernet0/0/6] nat outbound 2001 address-group 1 no-pat
Or
# Enable Easy IP to use the IP address of Ten-GigabitEthernet 0/0/6 as the translated address.
[Sysname-Ten-GigabitEthernet 0/0/6] nat outbound 2001
[Sysname-Ten-GigabitEthernet 0/0/6] quit
Or
# Configure an outbound NO-PAT rule on Ten-GigabitEthernet 0/0/6 to translate the source addresses of outgoing packets permitted by ACL 2001 into the addresses in address group 1. Enable reverse address translation.
[Sysname-Ten-GigabitEthernet0/0/6] nat outbound 2001 address-group 1 no-pat reversible
display nat eim
Use nat outbound port-block-group to configure a static outbound NAT port block mapping rule on an interface.
Use undo nat outbound port-block-group to delete a static port block mapping rule on an interface.
nat outbound port-block-group group-id [ rule rule-name ]
undo nat outbound port-block-group group-id
No static outbound port block mapping rule is configured on an interface.
Interface view
group-id: Specifies a NAT port block group by its ID. The value range for this argument is 0 to 65535.
After you configure this command on an interface, the system automatically computes the mappings and creates entries for them. When a private IP address accesses the public network, the private IP address is translated to the mapped public IP address, and the ports are translated to ports in the selected port block.
You can configure multiple port block mapping rules on an interface.
# Configure a static outbound port block mapping rule on Ten-GigabitEthernet 0/0/6.
[Sysname-Ten-GigabitEthernet0/0/6] nat outbound port-block-group 1
display nat all
nat outbound rule move
Use nat outbound rule move to change the priority of an outbound dynamic NAT rule.
nat outbound rule move nat-rule-name1 { after | before } nat-rule-name2
Interface view
nat-rule-name1: Specifies the name of the NAT rule to be moved.
This command is applicable only to named outbound dynamic NAT rules.
# Move the outbound dynamic NAT rule abc to the line before the rule def.
[Sysname-Ten-GigabitEthernet0/0/6] nat outbound rule move abc before def
nat outbound
nat port-block flow-trigger enable
Use nat port-block flow-trigger enable to enable flow-triggered port block assignment.
Use undo nat port-block flow-trigger enable to disable flow-triggered port block assignment.
Flow-triggered port block assignment is disabled.
The flow-triggered port block assignment feature is applicable to port block-based NAT. If unification is not configured between NAT and BRAS, you must enable this feature. If unification is configured, port block assignment is triggered when users come online.
# Enable flow-triggered port block assignment.
[Sysname] nat port-block flow-trigger enable
nat port-block synchronization enable
Use nat port-block synchronization enable to enable dynamic NAT port block mapping synchronization.
Use undo nat port-block synchronization enable to disable dynamic NAT port block mapping synchronization.
Dynamic NAT port block mapping synchronization is disabled.
Dynamic NAT port block mapping synchronization enables the master and the backup to synchronize dynamic port block mappings, which ensures smooth switchover without service interruption.
Dynamic NAT port block mapping synchronization is supported only on a hot backup system. For more information about configuring a hot backup system, see high availability group configuration in High Availability Configuration Guide.
# Enable dynamic NAT port block mapping synchronization.
[Sysname] nat port-block synchronization enable
Use nat port-block-group to create a NAT port block group and enter its view, or enter the view of an existing NAT port block group.
Use undo nat port-block-group to delete a NAT port block group.
nat port-block-group group-id
undo nat port-block-group group-id
No NAT port block groups exist.
group-id: Assigns an ID to the NAT port block group. The value range for this argument is 0 to 65535.
A NAT port block group is configured to implement static port block mapping.
You must configure the following items for a NAT port block group:
·     A minimum of one private IP address range (see the local-ip-address command).
·     A minimum of one public IP address range (see the global-ip-address command).
·     A port range (see the port-range command).
·     A port block size (see the block-size command).
The system computes static port block mappings according to the port block group configuration, and creates entries for the mappings.
# Create NAT port block group 1.
[Sysname] nat port-block-group 1
block-size
display nat all
global-ip-pool
local-ip-address
port-range
nat server rule move
Use nat server rule move to change the priority of an ACL-based NAT server rule.
nat server rule move nat-rule-name1 { after | before } nat-rule-name2
Interface view
This command is applicable only to named NAT server rules that use ACLs.
# Move the ACL-based NAT server rule abc to the line before the ACL-based NAT server rule def.
[Sysname-Ten-GigabitEthernet0/0/6] nat server rule move abc before def
nat server
nat server (interface-based NAT)
Use nat server to create a NAT server mapping (also called NAT server rule). The mapping maps the private IP address and port of an internal server to a public address and port.
Use undo nat server to delete a NAT server mapping.
·     Common NAT server mapping:
¡     A single public address with no or one single public port:
nat server [ protocol pro-type ] global { global-address | current-interface | interface interface-type interface-number } [ global-port ] [ vpn-instance global-vpn-instance-name ] inside local-address [ local-port ] [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } ] [ reversible ] [ vrrp virtual-router-id ] [ rule rule-name ]
undo nat server [ protocol pro-type ] global { global-address | current-interface | interface interface-type interface-number } [ global-port ] [ vpn-instance global-vpn-instance-name ]
¡     A single public address with consecutive public ports:
nat server protocol pro-type global { global-address | current-interface | interface interface-type interface-number } global-port1 global-port2 [ vpn-instance global-vpn-instance-name ] inside { { local-address | local-address1 local-address2 } local-port | local-address local-port1 local-port2 } [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } ] [ vrrp virtual-router-id ] [ rule rule-name ]
undo nat server protocol pro-type global { global-address | current-interface | interface interface-type interface-number } global-port1 global-port2 [ vpn-instance global-vpn-instance-name ]
¡     Consecutive public addresses with no or one single public port:
nat server protocol pro-type global global-address1 global-address2 [ global-port ] [ vpn-instance global-vpn-instance-name ] inside { local-address | local-address1 local-address2 } [ local-port ] [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } ] [ vrrp virtual-router-id ] [ rule rule-name ]
undo nat server protocol pro-type global global-address1 global-address2 [ global-port ] [ vpn-instance global-vpn-instance-name ]
¡     Consecutive public addresses with one single public port:
nat server protocol pro-type global global-address1 global-address2 global-port [ vpn-instance global-vpn-instance-name ] inside local-address local-port1 local-port2 [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } ] [ vrrp virtual-router-id ] [ rule rule-name ]
undo nat server protocol pro-type global global-address1 global-address2 global-port [ vpn-instance global-vpn-instance-name ]
·     Load sharing NAT server mapping:
nat server protocol pro-type global { { global-address | current-interface | interface interface-type interface-number } { global-port | global-port1 global-port2 } | global-address1 global-address2 global-port } [ vpn-instance global-vpn-instance-name ] inside server-group group-id [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } ] [ vrrp virtual-router-id ] [ rule rule-name ]
undo nat server protocol pro-type global { { global-address | current-interface | interface interface-type interface-number } { global-port | global-port1 global-port2 } | global-address1 global-address2 global-port } [ vpn-instance global-vpn-instance-name ]
·     ACL-based NAT server mapping:
nat server global { ipv4-acl-number | name ipv4-acl-name } inside local-address [ local-port ] [ vpn-instance local-vpn-instance-name ]  [ vrrp virtual-router-id ] [ rule rule-name ] [ priority priority ]
undo nat server global { ipv4-acl-number | name ipv4-acl-name }
No NAT server mappings exist.
Interface view
protocol pro-type: Specifies a protocol type. When the protocol is TCP or UDP, a NAT server mapping can be configured with port information. If you do not specify a protocol type, the command applies to packets of all protocols. The protocol type format can be one of the following:
·     A number in the range of 1 to 255.
·     A protocol name of icmp, tcp, or udp.
global: Specifies the external network information that the server uses to provide services to the external network.
global-address: Specifies the public address of an internal server.
global-address1 global-address2: Specifies a public IP address range, which can include a maximum of 10001 addresses. The global-address1 argument specifies the start address, and the global-address2 argument specifies the end address that must be greater than the start address.
current-interface: Enables Easy IP on the current interface. The primary IP address of the interface is used as the public address for the internal server.
interface interface-type interface-number: Enables Easy IP on the interface specified by its type and number. The primary IP address of the interface is used as the public address for the internal server. Only loopback interfaces are supported.
global-port1 global-port2: Specifies a public port number range, which can include a maximum of 10001 ports. The global-port1 argument specifies the start port, and the global-port2 argument specifies the end port that must be greater than the start port. The public port number format can be one of the following:
·     A number in the range of 1 to 65535. Both the start port and the end port support this format.
·     A protocol name, a string of 1 to 15 characters. For example, http and telnet. Only the start port supports this format.
inside: Specifies the internal information about the internal server.
local-address1 local-address2: Specifies a private IP address range. The local-address1 argument specifies the start address, and the local-address2 argument specifies the end address that must be greater than the start address. The number of addresses in the range must equal the number of ports in the public port number range.
local-port: Specifies the private port number. The private port number format can be one of the following:
·     A number in the range of 1 to 65535, excluding FTP port 20.
global-port: Specifies the public port number. The default value and value range are the same as those for the local-port argument.
local-address: Specifies the private IP address.
vpn-instance global-vpn-instance-name: Specifies the MPLS L3VPN instance to which the advertised public IP addresses belong. The global-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the public IP addresses do not belong to any VPN instance, do not specify this option.
vpn-instance local-vpn-instance-name: Specifies the MPLS L3VPN instance to which the internal server belongs. The local-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the internal server does not belong to any VPN instance, do not specify this option.
server-group group-id: Specifies the internal server group to which the internal server belongs. With this parameter, the load sharing NAT Server feature is configured. The group-id argument specifies the internal server group ID. The value range for this argument is 0 to 65535.
acl: Specifies an ACL. If you specify an ACL, only packets permitted by the ACL can be translated by using the mapping.
reversible: Allows reverse address translation. Reverse address translation applies to connections actively initiated by internal servers to the external network. It translates the private IP addresses of the internal servers to their public IP addresses.
vrrp virtual-router-id: Specifies a VRRP group by its virtual router ID in the range of 1 to 255.
rule rule-name: Specifies a name for the mapping, a case-sensitive string of 1 to 63 characters. It cannot contain backward slashes (\), forward slashes (/), colons (:), asterisks (*), question marks (?), left angle brackets (<), right angle brackets (>), vertical bars (|), quotation marks ("), or at signs (@). If you do not specify this option, the mapping does not have a name.
priority priority: Specifies a priority for the mapping, in the range of 0 to 2147483647. A smaller value represents a higher priority. If you do not specify this option, the mapping has the lowest priority among the same type of NAT rules.
Application scenarios
You can configure the NAT server mapping to allow internal servers (such as Web, FTP, Telnet, POP3, and DNS servers) in the internal network or an MPLS VPN instance to provide services for external users.
NAT server mappings are usually configured on the interface connected to the external network on a NAT device. By using the global-address and global-port arguments, external users can access the internal server at local-address and local-port. When the protocol type is not udp (protocol number 17) or tcp (protocol number 6), you can configure only one-to-one IP address mappings. The following table describes the address-port mappings between an external network and an internal network for NAT Server.
Table 20 Address-port mappings for NAT Server
External network
Internal network
One public address
One private address
One public address and one public port number
One private address and one private port number
One public address and N consecutive public port numbers
N consecutive private addresses and one private port number
One private address and N consecutive private port numbers
One private address
N consecutive public addresses and one public port number
One internal server group
Public addresses matching an ACL
One private address
Recommended configuration
As a best practice, do not configure Easy IP for multiple internal servers by using the same interface.
On a hot backup system that collaborates with VRRP, when you configure a NAT server mapping on the primary device in the hot backup system, bind the NAT server to the VRRP group facing the external network. If you do not perform the binding, the upstream Layer 3 device directly connected to the hot backup system might incorrectly send downlink packets to a VRRP backup device, causing service anomalies.
The number of the nat server commands that can be configured on an interface varies by device model. The mapping of the protocol type, public address, and public port number must be unique for an internal server on an interface. This restriction also applies when Easy IP is used. The maximum number of NAT server mappings equals the number of public ports in the specified public port range.
The vpn-instance parameter is required if you deploy NAT Server for VPNs. The specified VPN instance must be the VPN instance to which the NAT interface belongs.
If the IP address of an interface used by Easy IP changes and conflicts with the IP address of a NAT server mapping not using Easy IP, the Easy IP configuration becomes invalid. If the conflicting IP address is modified to another IP address or the NAT server mapping without Easy IP is removed, the Easy IP configuration takes effect.
When you configure a load sharing NAT server mapping, you must make sure a user uses the same public address and public port to access the same service on an internal server. For this purpose, make sure value N in the following mappings is equal to or less than the number of servers in the internal server group:
·     One public address and N consecutive public port numbers are mapped to one internal server group.
·     N consecutive public addresses and one public port number are mapped to one internal server group.
If the ACL-based NAT server mappings have the same priority value, the device uses the following rules to determine their match order:
·     Mappings with named ACLs have higher priorities than mappings with numbered ACLs.
·     Mappings with named ACLs are matched in alphanumeric order of their ACL names.
·     Mappings with numbered ACLs are matched in descending order of their ACL numbers.
# Allow external users to access the internal Web server at 10.110.10.10 through https://202.110.10.10:8080.
[Sysname-Ten-GigabitEthernet0/0/6] nat server protocol tcp global 202.110.10.10 8080 inside 10.110.10.10 https
# Allow external users to access the internal FTP server at 10.110.10.11 in the VPN instance vrf10 through ftp://202.110.10.10.
[Sysname-Ten-GigabitEthernet0/0/6] nat server protocol tcp global 202.110.10.10 21 inside 10.110.10.11 vpn-instance vrf10
# Allow external hosts to ping the host at 10.110.10.12 in the VPN instance vrf10 by using the ping 202.110.10.11 command.
[Sysname-Ten-GigabitEthernet0/0/6] nat server protocol icmp global 202.110.10.11 inside 10.110.10.12 vpn-instance vrf10
# Allow external hosts to access the Telnet services of internal servers at 10.110.10.1 to 10.110.10.100 in the VPN instance vrf10 through the public address 202.110.10.10 and port numbers from 1001 to 1100. As a result, a user can Telnet to 202.110.10.10:1001 to access 10.110.10.1, Telnet to 202.110.10.10:1002 to access 10.110.10.2, and so on.
[Sysname-Ten-GigabitEthernet0/0/6] nat server protocol tcp global 202.110.10.10 1001 1100 inside 10.110.10.1 10.110.10.100 telnet vpn-instance vrf10
# Configure an ACL-based NAT server mapping to allow users to use IP addresses in subnet 192.168.0.0/24 to access the internal server at 10.0.0.172.
[Sysname-acl-ipv4-adv-3000] rule 5 permit ip destination 192.168.0.0 0.0.0.255
[Sysname-Ten-GigabitEthernet0/0/6] nat server global 3000 inside 10.0.0.172
display nat all
display nat server
nat server-group
nat server-group
Use nat server-group to create an internal server group and enter its view, or enter the view of an existing internal server group.
Use undo nat server-group to delete an internal server group.
nat server-group group-id
undo nat server-group group-id
No internal server groups exist.
group-id: Assigns an ID to the internal server group. The value range is 0 to 65535.
An internal server group can contain multiple members configured by the inside ip command.
# Create internal server group 1.
display nat all
inside ip
nat server
nat static enable
Use nat static enable to enable static NAT on an interface.
Use undo nat static enable to disable static NAT on an interface.
nat static enable
Static NAT is disabled.
Interface view
Static NAT mappings take effect on an interface only after static NAT is enabled on the interface.
# Configure an outbound static NAT mapping between private IP address 192.168.1.1 and public IP address 2.2.2.2, and enable static NAT on interface Ten-GigabitEthernet 0/0/6.
[Sysname] nat static outbound 192.168.1.1 2.2.2.2
[Sysname-Ten-GigabitEthernet0/0/6] nat static enable
display nat all
display nat static
nat static
nat static inbound
Use nat static inbound to configure a one-to-one mapping for inbound static NAT.
Use undo nat static inbound to delete a one-to-one mapping for inbound static NAT.
nat static inbound global-ip [ vpn-instance global-vpn-instance-name ] local-ip [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } [ reversible ] ] [ rule rule-name ] [ priority priority ] [ packet-type-ignore ]
undo nat static inbound global-ip [ vpn-instance global-vpn-instance-name ] local-ip [ vpn-instance local-vpn-instance-name ]
No NAT mappings exist.
global-ip: Specifies a public IP address.
vpn-instance global-vpn-instance-name: Specifies the MPLS L3VPN instance to which the public IP address belongs. The global-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the public IP address does not belong to any VPN instance, do not specify this option.
local-ip: Specifies a private IP address.
vpn-instance local-vpn-instance-name: Specifies the MPLS L3VPN instance to which the private IP address belongs. The local-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the private IP address does not belong to any VPN instance, do not specify this option.
acl: Specifies an ACL to identify packets for address translation.
ipv4-acl-number: Specifies an ACL by its number in the range of 3000 to 3999.
reversible: Enables reverse address translation for connections actively initiated from the internal network to the private IP address.
packet-type-ignore: Ignores the protocol packet type when the device creates session entries for TCP, ICMP, or SCTP. If you do not specify this keyword, the NAT device checks the protocol packet type and creates session entries for only protocol packets that pass the check. For example, the NAT device creates session entries for TCP packets only when the packet type is SYN or ACK.
Operating mechanism
When the source IP address of a packet from the external network to the internal network matches the global-ip, the source IP address is translated into the local-ip. When the destination IP address of a packet from the internal network to the external network matches the local-ip, the destination IP address is translated into the global-ip.
In an asymmetric routing scenario, if a session contains different types of protocol packets that are forwarded by different NAT devices, protocol packets of some types might be discarded. As a result, session status cannot be updated through protocol packet exchanges, causing abnormal service traffic forwarding. To avoid such an issue, specify the packet-type-ignore keyword when you use this command.
·     If you do not specify an ACL, the source address of all incoming packets and the destination address of all outgoing packets are translated.
·     If you specify an ACL and do not specify the reversible keyword, the source address of incoming packets permitted by the ACL is translated. The destination address is not translated for connections actively initiated from the internal network to the private IP address.
·     If you specify both an ACL and the reversible keyword, the source address of incoming packets permitted by the ACL is translated. If packets of connections actively initiated from the internal network to the private IP address are permitted by ACL reverse matching, the destination address is translated. ACL reverse matching works as follows:
¡     Translates the destination IP address of the packet according to the mapping, and then compares the translated destination IP address/port with the source IP addresses/ports in the ACL.
Static NAT takes precedence over dynamic NAT when both are configured on an interface.
You can configure multiple inbound static NAT mappings by using the nat static inbound command and the nat static inbound net-to-net command.
The vpn-instance parameter is required if you deploy inbound static NAT for VPNs. The specified VPN instance must be the VPN instance to which the NAT interface belongs.
If the ACL-based inbound one-to-one static mappings have the same priority value, the device uses the following rules to determine their match order:
# Configure an inbound static NAT mapping between public IP address 2.2.2.2 and private IP address 192.168.1.1.
[Sysname] nat static inbound 2.2.2.2 192.168.1.1
display nat all
display nat static
nat static enable
Use nat static inbound net-to-net to configure a net-to-net mapping for inbound static NAT.
Use undo nat static inbound net-to-net to remove a net-to-net mapping for inbound static NAT.
nat static inbound net-to-net global-start-address global-end-address [ vpn-instance global-vpn-instance-name ] local local-network { mask-length | mask } [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } [ reversible ] ] [ rule rule-name ] [ priority priority ]
undo nat static inbound net-to-net global-start-address global-end-address [ vpn-instance global-vpn-instance-name ] local local-network { mask-length | mask } [ vpn-instance local-vpn-instance-name ]
global-start-address global-end-address: Specifies a public address range which can contain a maximum of 256 addresses. The global-end-address must not be lower than global-start-address. If they are the same, only one public address is specified.
vpn-instance global-vpn-instance-name: Specifies the MPLS L3VPN instance to which the public IP addresses belong. The global-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the public IP addresses do not belong to any VPN instance, do not specify this option.
local-network: Specifies a private network address.
mask-length: Specifies the mask length of the private network address, in the range of 8 to 31.
mask: Specifies the mask of the private network address.
vpn-instance local-vpn-instance-name: Specifies the MPLS L3VPN instance to which the private network address belongs. The local-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the private network address does not belong to any VPN instance, do not specify this option.
reversible: Enables reverse address translation for connections actively initiated from the internal network to the private IP addresses.
Specify a public network through a start address and an end address, and a private network through a private address and a mask.
When the source address of a packet from the external network matches the public address range, the source address is translated into a private address in the private address range. When the destination address of a packet from the internal network matches the private address range, the destination address is translated into a public address in the public address range.
The public end address cannot be greater than the greatest IP address in the subnet determined by the public start address and the private network mask. For example, if the private address is 2.2.2.0 with a mask 255.255.255.0 and the public start address is 1.1.1.100, the public end address cannot be greater than 1.1.1.255, the greatest IP address in the subnet 1.1.1.0/24.
·     If you specify an ACL and do not specify the reversible keyword, the source address of incoming packets permitted by the ACL is translated. The destination address is not translated for connections actively initiated from the internal network to the private IP addresses.
·     If you specify both an ACL and the reversible keyword, the source address of incoming packets permitted by the ACL is translated. If packets of connections actively initiated from the internal network to the private IP addresses are permitted by ACL reverse matching, the destination address is translated. ACL reverse matching works as follows:
If the ACL-based inbound net-to-net static mappings have the same priority value, the device uses the following rules to determine their match order:
# Configure an inbound static NAT between public network address 202.100.1.0/24 and private network address 192.168.1.0/24.
[Sysname] nat static inbound net-to-net 202.100.1.1 202.100.1.255 local 192.168.1.0 24
display nat all
display nat static
nat static enable
nat static inbound net-to-net rule move
Use nat static inbound net-to-net rule move to change the priority of an inbound net-to-net static NAT rule.
nat static inbound net-to-net rule move nat-rule-name1 { after | before } nat-rule-name2
An inbound net-to-net static NAT rule appearing earlier on the rule list has a higher priority for packet matching.
after: Moves the rule nat-rule-name1 to the line after the rule nat-rule-name2 (called the reference rule). The priority value of the reference rule is not changed. The priority value of the moved rule equals the priority value of the reference rule plus one.
before: Moves the rule nat-rule-name1 to the line before the rule nat-rule-name2. The priority value of the reference rule is not changed. The priority value of the moved rule equals the priority value of the reference rule minus one.
# Move the inbound net-to-net static NAT rule abc to the line before the inbound net-to-net static NAT rule def.
[Sysname] nat static inbound net-to-net rule move abc before def
nat static inbound rule move
Use nat static inbound rule move to change the priority of an inbound one-to-one static NAT rule.
nat static inbound rule move nat-rule-name1 { after | before } nat-rule-name2
# Move the inbound one-to-one static NAT rule abc to the line before the inbound one-to-one static NAT rule def.
[Sysname] nat static inbound rule move abc before def
nat static inbound
nat static outbound
Use nat static outbound to configure a one-to-one mapping for outbound static NAT.
Use undo nat static outbound to remove a one-to-one mapping for outbound static NAT.
nat static outbound local-ip [ vpn-instance local-vpn-instance-name ] global-ip [ vpn-instance global-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } [ reversible ] ] [ vrrp virtual-router-id ] [ rule rule-name ] [ priority priority ] [ packet-type-ignore ]
undo nat static outbound local-ip [ vpn-instance local-vpn-instance-name ] global-ip [ vpn-instance global-vpn-instance-name ]
reversible: Enables reverse address translation for connections actively initiated from the external network to the public IP address.
Operating mechanism
When the source IP address of an outgoing packet matches the local-ip, the IP address is translated into the global-ip. When the destination IP address of an incoming packet matches the global-ip, the destination IP address is translated into the local-ip.
·     If you do not specify an ACL, the source address of all outgoing packets and the destination address of all incoming packets are translated.
·     If you specify an ACL and do not specify the reversible keyword, the source address of outgoing packets permitted by the ACL is translated. The destination address is not translated for connections actively initiated from the external network to the public IP address.
·     If you specify both an ACL and the reversible keyword, the source address of outgoing packets permitted by the ACL is translated. If packets of connections actively initiated from the external network to the public IP address are permitted by ACL reverse matching, the destination address is translated. ACL reverse matching works as follows:
You can configure multiple outbound static NAT mappings by using the nat static outbound command and the nat static outbound net-to-net command.
The vpn-instance parameter is required if you deploy outbound static NAT for VPNs. The specified VPN instance must be the VPN instance to which the NAT interface belongs.
On a hot backup system that collaborates with VRRP, when you configure a one-to-one mapping for outbound static NAT on the primary device in the hot backup system, bind the mapping to the VRRP group facing the external network. If you do not perform the binding, the upstream Layer 3 device directly connected to the hot backup system might incorrectly send downlink packets to a VRRP backup device, causing service anomalies.
If the ACL-based outbound one-to-one static mappings have the same priority value, the device uses the following rules to determine their match order:
# Configure an outbound static NAT mapping between public IP address 2.2.2.2 and private IP address 192.168.1.1.
# Configure outbound static NAT, and allow the internal user 192.168.1.1 to access the external network 3.3.3.0/24 by using the public IP address 2.2.2.2.
[Sysname] acl advanced 3001
[Sysname-acl-ipv4-adv-3001] rule permit ip destination 3.3.3.0 0.0.0.255
[Sysname-acl-ipv4-adv-3001] quit
[Sysname] nat static outbound 192.168.1.1 2.2.2.2 acl 3001
display nat all
display nat static
nat static enable
Use nat static outbound net-to-net to configure a net-to-net outbound static NAT mapping.
Use undo nat static outbound net-to-net to remove the specified net-to-net outbound static NAT mapping.
nat static outbound net-to-net local-start-address local-end-address [ vpn-instance local-vpn-instance-name ] global global-network { mask-length | mask } [ vpn-instance global-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } [ reversible ] ] [ vrrp virtual-router-id ] [ rule rule-name ] [ priority priority ]
undo nat static outbound net-to-net local-start-address local-end-address [ vpn-instance local-vpn-instance-name ] global global-network { mask-length | mask } [ vpn-instance global-vpn-instance-name ]
local-start-address local-end-address: Specifies a private address range which can contain a maximum of 256 addresses. The local-end-address must not be lower than local-start-address. If they are the same, only one private address is specified.
vpn-instance local-vpn-instance-name: Specifies the MPLS L3VPN instance to which the private IP addresses belong. The local-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the private IP addresses do not belong to any VPN instance, do not specify this option.
global-network: Specifies a public network address.
vpn-instance global-vpn-instance-name: Specifies the MPLS L3VPN instance to which the public network address belongs. The global-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the public network address does not belong to any VPN instance, do not specify this option.
mask-length: Specifies the mask length of the public network address, in the range of 8 to 31.
mask: Specifies the mask of the public network address.
ipv4-acl-number: Specifies an ACL number in the range of 3000 to 3999.
reversible: Enables reverse address translation for connections actively initiated from the external network to the public IP addresses.
Specify a private network through a start address and an end address, and a public network through a public address and a mask.
When the source address of a packet from the internal network matches the private address range, the source address is translated into a public address in the public address range. When the destination address of a packet from the external network matches the public address range, the destination address is translated into a private address in the private address range.
The private end address cannot be greater than the greatest IP address in the subnet determined by the private start address and the public network mask. For example, the public address is 2.2.2.0 with a mask 255.255.255.0, and the private start address is 1.1.1.100. The private end address cannot be greater than 1.1.1.255, the greatest IP address in the subnet 1.1.1.0/24.
·     If you specify an ACL and do not specify the reversible keyword, the source address of outgoing packets permitted by the ACL is translated. The destination address is not translated for connections actively initiated from the external network to the public IP addresses.
·     If you specify both an ACL and the reversible keyword, the source address of outgoing packets permitted by the ACL is translated. If packets of connections actively initiated from the external network to the public IP addresses are permitted by ACL reverse matching, the destination address is translated. ACL reverse matching works as follows:
On a hot backup system that collaborates with VRRP, when you configure a net-to-net outbound static NAT mapping on the primary device in the hot backup system, bind the mapping to the VRRP group facing the external network. If you do not perform the binding, the upstream Layer 3 device directly connected to the hot backup system might incorrectly send downlink packets to a VRRP backup device, causing service anomalies.
If the ACL-based outbound net-to-net static mappings have the same priority value, the device uses the following rules to determine their match order:
# Configure an outbound static NAT mapping between private network address 192.168.1.0/24 and public network address 2.2.2.0/24.
[Sysname] nat static outbound net-to-net 192.168.1.1 192.168.1.255 global 2.2.2.0 24
# Configure outbound static NAT. Allow internal users on subnet 192.168.1.0/24 to access the external subnet 3.3.3.0/24 by using public IP addresses on subnet 2.2.2.0/24.
[Sysname] nat static outbound net-to-net 192.168.1.1 192.168.1.255 global 2.2.2.0 24 acl 3001
display nat all
display nat static
nat static enable
nat static outbound net-to-net rule move
Use nat static outbound net-to-net rule move to change the priority of an outbound net-to-net static NAT rule.
nat static outbound net-to-net rule move nat-rule-name1 { after | before } nat-rule-name2
An outbound net-to-net static NAT rule appearing earlier on the rule list has a higher priority for packet matching.
# Move the outbound net-to-net static NAT rule abc to the line before the outbound net-to-net static NAT rule def.
[Sysname] nat static outbound net-to-net rule move abc before def
nat static outbound rule move
Use nat static outbound rule move to change the priority of an outbound one-to-one static NAT rule.
nat static outbound rule move nat-rule-name1 { after | before } nat-rule-name2
This command is applicable only to named outbound one-to-one static NAT rules.
# Move the outbound one-to-one static NAT rule abc to the line before the outbound one-to-one static NAT rule def.
[Sysname] nat static outbound rule move abc before def
nat static outbound
nat timestamp delete
Use nat timestamp delete to enable the deletion of timestamps in TCP SYN and SYN ACK packets.
Use undo nat timestamp delete to restore the default.
nat timestamp delete [ vpn-instance vpn-instance-name ]
undo nat timestamp delete [ vpn-instance vpn-instance-name ]
The TCP SYN and SYN ACK packets carry the timestamp.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN to which the TCP SYN and SYN ACK packets belong. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If you do not specify this option, this command applies to TCP SYN and SYN ACK packets on the public network.
With this feature configured, the system deletes the timestamps from the TCP SYN and SYN ACK packets after dynamic address translation.
If PAT mode is configured on an interface by using nat inbound or nat outbound, and the tcp_timestamp and tcp_tw_recycle function is configured on the TCP server, TCP connections might not be established. To solve the problem, you can shut down the tcp_tw_recycle function or use the nat timestamp delete command.
You can enable this feature for multiple VPN instances by repeating the command with different VPN parameters.
# Enable the deletion of the timestamp for TCP SYN and SYN ACK packets on the public network.
[Sysname] nat timestamp delete
# Enable the deletion of the timestamp for TCP SYN and SYN ACK packets on the VPN instance aa.
[Sysname] nat timestamp delete vpn-instance aa
nat outbound
nat inbound
port-block
Use port-block to configure port block parameters for a NAT address group.
Use undo port block to restore the default.
port-block block-size block-size [ extended-block-number extended-block-number ]
undo port block
Port block parameters are not configured for a NAT address group.
NAT address group view
block-size block-size: Specifies the port block size. The value range for this argument is 1 to 65535. In a NAT address group, the port block size cannot be larger than the number of ports in the port range.
extended-block-number extended-block-number: Specifies the number of extended port blocks, in the range of 1 to 5. When a private IP address accesses the public network, but the ports in the selected port block are all occupied, the NAT gateway extends port blocks one by one for the private IP address.
To configure dynamic port block mapping, port block parameters are required in the NAT address group. When a private IP address initiates a connection to the public network, the NAT gateway assigns it a public IP address and a port block, and creates an entry for the mapping. For subsequent connections from the private IP address, the NAT gateway translates the private IP address to the mapped public IP address and the ports to ports in the selected port block.
# Set the port block size to 256 and the number of extended port blocks to 1 in NAT address group 2.
[Sysname] nat address-group 2
[Sysname-address-group-2] port-block block-size 256 extended-block-number 1
nat address-group
port-range
Use port-range to specify a port range for public IP addresses.
Use undo port-range to restore the default.
port-range start-port-number end-port-number
undo port-range
The port range for public IP addresses is 1 to 65535.
NAT port block group view
start-port-number end-port-number: Specifies the start port number and end port number for the port range. The end port number cannot be smaller than the start port number.
The port range must include all ports that public IP addresses use for address translation.
The number of ports in a port range cannot be smaller than the port block size.
# Specify the port range as 1024 to 65535 for NAT address group 1.
[Sysname] nat address-group 1
[Sysname-address-group-1] port-range 1024 65535
# Specify the port range as 30001 to 65535 for NAT port block group 1.
[Sysname-port-block-group-1] port-range 30001 65535
nat address-group
reset nat session
Use reset nat session to clear NAT sessions.
reset nat session [ protocol { tcp | udp } ] [ slot slot-number ]
protocol: Specifies a protocol by its type. If you do not specify this keyword, the command clears NAT sessions of all protocol types.
tcp: Specifies the TCP protocol.
udp: Specifies the UDP protocol.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command clears NAT sessions for all cards.
# Clear NAT sessions for the specified slot.
<Sysname> reset nat session slot 1
display nat session
vrrp vrid (interface-based NAT)
Use vrrp vrid to bind a VRRP group to a NAT address group or a NAT port block group.
Use undo vrrp vrid to restore the default.
vrrp vrid virtual-router-id
undo vrrp vrid
A NAT address group or a NAT port block group is not bound to any VRRP group.
On a hot backup system that collaborates with VRRP, source address translation that uses a NAT address group or port block group assigns the public IP address after translation to the address management module. Both the hot backup active and standby devices advertise the mappings between the public IP address and MAC addresses of their own physical interfaces to all nodes in the same LAN. As a result, the upstream Layer 3 device directly connected to the hot backup system might incorrectly send downlink packets to a VRRP backup device, causing service anomalies.
To avoid such an issue, bind the NAT address group or port block group to the VRRP group. Then, only the VRRP master device performs the following tasks:
·     Assigns the public IP address after translation to the address management module.
·     Advertises the mapping between the public IP address and virtual MAC address of the VRRP group to all nodes in the same LAN.
·     Responds to ARP requests with the virtual MAC address of the VRRP group.
# Bind VRRP group 1 to NAT address group 2.
[Sysname-address-group-2] vrrp vrid 1
display nat address-group
display nat port-block-group
nat address-group
vrrp vrid (High Availability Command Reference)
