03-Common container and open application parameter configuration | 85.81 KB |
Configuring common container and open application parameters
About configuring common container and open application parameters
Configuring common container parameters
Configuring common open application parameters
Specifying a source IP address for open applications
Reserving port numbers for open client applications
Reserving port numbers for open server applications
Preconditioning incoming IP packets
Comware V9 supports deploying the Guest Shell container and Docker containers as well as applications based the containers or RPM on the device. The container applications and RPM applications can run on the device if only they are compliant with the packaging, orchestration, and running requirements of the containers or RPM. These applications feature high openness and are hereinafter referred to as "open applications" in this chapter.
Container applications are isolated from Comware applications. You can use container applications as supplements to Comware, without affecting the operating of Comware.
This chapter describes how to configure common parameters for the previously mentioned containers and open applications.
Backing up container data
This task backs up Guest shell container data and Docker container data to the standby MPU so the containers can continue to use the data after an active/standby switchover.
1. Enter system view.
2. Back up Guest Shell container data and Docker container data.
tpa data sync
For the following applications to communicate with indirectly connected networks, you must specify a source IPv4 or IPv6 address for their outgoing packets:
· RPM applications.
· Guest Shell container applications.
· Open applications in containers that share the network namespace of Comware.
The applications will use the specified address as the source address for packets that they send.
Open applications in containers that do not share the network namespace of Comware uses interface Virtual-Eth-Group 0 to communicate with indirectly connected networks. You do not need to configure a source IP address for such open applications.
Make sure the specified interface has an IP address and is in up state, and a connection is available between the interface and the destination device.
As a best practice, specify a loopback interface as the source interface. The physical layer status of a loopback interface is always up unless the loopback interface is manually shut down.
The specified source IPv6 address must be an IPv6 global unicast address.
Specifying a source IP address for open applications in system view
2. Specify a source IP address for open applications.
IPv4:
tpa ip source interface interface-type interface-number
By default, the primary IPv4 address of interface Loopback 0 is used as the source IPv4 address.
IPv6:
tpa ipv6 source { interface interface-type interface-number | ipv6 ipv6-address }
By default, an IPv6 address of interface Loopback 0 is used as the source IPv6 address.
Specifying a source IP address for open applications in interface view
2. Enter interface view.
3. Specify a source IP address for open applications.
IPv4:
By default, the source IPv4 address specified in system view is used.
IPv6:
By default, the source IPv6 address specified in system view is used.
The device forwards received packets to applications based on the destination port numbers in the packets. To avoid port conflicts and to correctly forward packets destined for open client applications, you must reserve port numbers for the open client applications.
As a best practice, configure this feature before running open applications.
The number of reserved port numbers must be an even number.
The reserved port numbers cannot include the port numbers being used by Comware client applications. Before reserving port numbers for open client applications, execute the following commands to identify the TCP and UDP port numbers that Comware applications are using:
· display system internal tcp port-info
· display system internal udp port-info
To change the reserved port number range while one or more open client applications are running:
1. Identify whether the new range includes the port numbers that the open client applications are using.
2. If not, stop the open client applications that are using an out-of-range port number. You can restart the applications after you change the reserved port number range.
2. Specify the range of port numbers to be reserved for open client applications.
tpa socket client-port-range start-port end-port
By default, the port number range reserved for open client applications is 64512 to 65535.
The device forwards received packets to applications based on the destination port numbers in the packets. To avoid port conflicts and to correctly forward packets destined for open server applications, you must reserve port numbers for the open server applications.
The reserved port numbers cannot include the port numbers being used by Comware client applications. Before reserving port numbers for open server applications, execute the following commands to identify the TCP and UDP port numbers that Comware applications are using:
2. Specify the range of port numbers to be reserved for open server applications.
tpa socket server-port port-id1 [ to port-id2 ]
By default, no port numbers are reserved for open server applications.
By default, the device processes received open application packets as follows:
· Unicast packets that are destined for the device itself—Sends the packets to CPUs.
· Broadcast packets—Sends the packets to CPUs.
· Multicast packets—Does not send the packets to CPUs.
You can configure the device to precondition open application packets that match certain rules and then send the packets to its CPUs. Preconditioning actions include rate limiting packets to prevent open application packets from using too many CPU resources.
If you configure this feature in interface view, the configuration applies to the current interface. If you configure this feature in system view, the configuration applies to all interfaces. If you configure this feature in both interface view and system view, the device preconditions open application packets that match the rules configured in either view.
Preconditioning incoming IP packets in system view
2. Configure the device to precondition certain incoming IPv4 packets of open applications and send the packets to its CPUs.
IPv4:
¡ Configure the device to precondition incoming IPv4 TCP open application packets and send the packets to its CPUs.
tpa ip send-to-cpu protocol 6 { destination-port destination-port-number | source-port source-port-number } *
¡ Configure the device to precondition incoming IPv4 UDP open application packets and send the packets to its CPUs.
tpa ip send-to-cpu protocol 17 { destination-port destination-port-number | source-port source-port-number } * [ destination-ip destination-ip-address ]
¡ Configure the device to precondition incoming IPv4 open application packets of other protocols and send the packets to its CPUs.
tpa ip send-to-cpu protocol protocol-number [ destination-ip destination-ip-address ]
By default, the device processes incoming open application IPv4 packets as follows:
- Unicast packets that are destined for the device itself—Sends the packets to CPUs.
- Broadcast packets—Sends the packets to CPUs.
- Multicast packets—Does not send the packets to CPUs.
IPv6:
¡ Configure the device to precondition incoming IPv6 TCP open application packets and send the packets to its CPUs.
tpa ipv6 send-to-cpu protocol 6 { destination-port destination-port-number | source-port source-port-number } *
¡ Configure the device to precondition incoming IPv6 UDP open application packets and send the packets to its CPUs.
tpa ipv6 send-to-cpu protocol 17 { destination-port destination-port-number | source-port source-port-number } * [ destination-ipv6 destination-ipv6-address ]
¡ Configure the device to precondition incoming IPv6 open application packets of other protocols and send the packets to its CPUs.
tpa ipv6 send-to-cpu protocol protocol-number [ destination-ipv6 destination-ipv6-address ]
By default, the device processes incoming open application IPv6 packets as follows:
Preconditioning incoming IP packets in interface view
3. Configure the device to precondition certain incoming IPv4 packets of open applications and send the packets to its CPUs.
IPv4:
By default, the configuration in system view is used.
IPv6:
