03-Interface Configuration Guide
HomeSupportRoutersSR6600-M SeriesConfigure & DeployConfiguration GuidesH3C SR6608-M Router Configuration Guides-R9141-6W10103-Interface Configuration Guide
07-Tunnel interface configuration
07-Tunnel interface configuration 120.44 KB
Configuring tunnel interfaces
About tunnel interfaces
Tunneling encapsulates the packets of a network protocol within the packets of a second network protocol and transfers them over a virtual point-to-point connection. The virtual connection is called a tunnel. Packets are encapsulated at the tunnel source and de-encapsulated at the tunnel destination.
Configure a tunnel interface (Layer 3 virtual interface) at both ends of a tunnel. The devices use the tunnel interface to identify, process, and send packets for the tunnel.
Restrictions and guidelines: Tunnel interface configuration
When an active/standby switchover occurs or the standby MPU is removed on a distributed device, the tunnel interfaces configured on the active or standby MPU still exist. To delete a tunnel interface, use the undo interface tunnel command.
Do not specify the same tunnel source and destination addresses for the tunnel interfaces on the same device.
For information about the description, bandwidth, and shutdown commands, see common interface commands in Interface Command Reference.
Configuring a tunnel interface
Tunnel interface configuration tasks at a glance
To configure a tunnel interface, perform the following tasks:
1.     Creating a tunnel interface
2.     (Optional.) Specifying traffic processing slots for the tunnel interface
3.     (Optional.) Configuring parameters for tunneled packets
4.     (Optional.) Specifying the tunnel destination VPN instance
5.     (Optional.) Restoring the default settings of the tunnel interface
6.     (Optional.) Specifying an output interface for tunneled packets
7.     (Optional.) Enabling path MTU learning on a tunnel interface
8.     (Optional.) Enabling SNMP notifications for the tunneling module
2.     Create a tunnel interface, specify the tunnel mode, and enter tunnel interface view.
interface tunnel number  mode { advpn { gre | udp } [ ipv6 ] | ds-lite-aftr | eogre | eogre-udp | gre [ ipv6 ] | gre-p2mp [ ipv6 ] | ipsec [ ipv6 ] | ipv4-ipv4 | ipv4-ipv6 | ipv6 | ipv6-ipv4 [ 6rd | 6to4 | auto-tunnel | isatap ] | ipv6-ipv6 | map-e | mpls-te | sdwan udp [ ipv6 ] | sdwan-ex gre [ ipv6 ] }
For packet tunneling to succeed, the two ends of a tunnel must use the same tunnel mode.
3.     Configure a source address or source interface for the tunnel interface.
source { ipv4-address | ipv6-address | interface-type interface-number }
By default, no source address or source interface is configured for the tunnel interface.
If you specify a source address, it is used as the source address of tunneled packets.
If you specify a source interface, the primary IP address of this interface is used as the source IP address of tunneled packets.
4.     Configure a destination address for the tunnel interface.
destination { ipv4-address | ipv6-address }
By default, no destination address is configured for the tunnel interface.
The tunnel destination address must be the IP address of the receiving interface on the tunnel peer. It is used as the destination IP address of tunneled packets.
5.     (Optional.) Configure a description for the interface.
By default, the description for a tunnel interface is Tunnel number Interface.
6.     (Optional.) Set the MTU of the tunnel interface.
mtu size
The default settings are as follows:
¡     If the tunnel interface has never been up, the MTU is 8100 bytes.
¡     If the tunnel interface is up, its MTU is identical to the outgoing interface's MTU minus the length of the tunnel headers. The outgoing interface is automatically obtained through routing table lookup based on the tunnel destination address.
7.     (Optional.) Set the expected bandwidth for the tunnel interface.
bandwidth bandwidth-value
The default expected bandwidth (in kbps) is the interface maximum rate divided by 1000.
8.     Bring up the tunnel interface.
The default setting varies by device model.
Specify a traffic processing slot if a feature (for example, IPsec antireplay) requires that all traffic on a tunnel interface be processed on the same slot.
2.     Enter tunnel interface view.
3.     Specify a traffic processing slot for the tunnel interface.
service slot slot-number
By default, no traffic processing slot is specified.
3.     Set the ToS for tunneled packets.
tunnel tos tos-value
The default setting is the same as the ToS of the original packets.
4.     Set the TTL for tunneled packets.
tunnel ttl ttl-value
The default TTL for tunneled packets is 255.
5.     Set the DF bit for tunneled packets.
tunnel dfbit enable
By default, the DF bit is not set for tunneled packets.
For a tunnel interface to come up, the tunnel source and destination must belong to the same VPN instance. To specify a VPN instance for the tunnel source, use the ip binding vpn-instance command on the tunnel source interface. For more information about this command, see MPLS L3VPN in MPLS Command Reference.
3.     Specify the VPN instance to which the tunnel destination belongs.
tunnel vpn-instance vpn-instance-name
By default, the tunnel destination belongs to the public network.
CAUTION
CAUTION:
This operation might interrupt ongoing network services. Make sure you are fully aware of the impact of this operation when you perform it on a live network.
This operation might fail to restore the default settings for some commands for reasons such as command dependencies or system restrictions. Use the display this command in interface view to identify these commands. Use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
For more information about the default command, see common interface commands in Interface Command Reference.
3.     Restore the default settings of the tunnel interface.
default
If ECMP routes exist, the device randomly selects an output interface to forward tunneled packets. To forward tunneled packets over a specific path, perform this task to specify the output interface for the tunneled packets.
To ensure successful packet forwarding, the specified output interface must meet the following requirements:
·     The interface is up.
·     The interface has an IP address.
·     The interface has a route to reach the destination.
This feature takes effect only on tunneled packets that are processed by CPU. Whether the CPUs process tunneled packets depends on the device model.
This feature is available only for IPv4 ADVPN, IPv6 ADVPN, GRE/IPv4, and GRE/IPv6 tunnel interfaces.
3.     Specify an output interface for tunneled packets.
tunnel out-interface interface-type interface-number
By default, no output interface is specified for tunneled packets. If ECMP routes exist, the device randomly selects an output interface to forward tunneled packets.
If the size of a tunneled packet exceeds the MTU of an interface in the tunnel path, the packet will be discarded. With the path MTU learning feature, the tunnel source can adjust the MTU of the tunnel interface according to the MTU information in received ICMP destination unreachable messages. After MTU adjustment, the tunnel source will resend the oversized tunneled packets, improving the forwarding reliability of tunnel packets.
If path MTU learning is enabled on a GRE/IPv4 tunnel interface and the passenger protocol is IPv4, make sure the MTU of all interfaces in the tunnel path is equal to or greater than 1312 bytes. If the MTU of an interface in the tunnel path is less than 1312 bytes, forwarding failure will occur.
If path MTU learning is enabled on a GRE/IPv6 tunnel interface and the passenger protocol is IPv6, make sure the MTU of all interfaces in the tunnel path is equal to or greater than 1332 bytes. If the MTU of an interface in the tunnel path is less than 1332 bytes, forwarding failure will occur.
The tunnel path-mtu enable command cannot be used together with the mtu command on a tunnel interface.
The tunnel path-mtu enable command is supported only on GRE/IPv4 and GRE/IPv6 tunnel interfaces.
3.     Enable path MTU learning on the tunnel interface.
By default, path MTU learning is disabled on a tunnel interface.
Enabling tunnel traffic forwarding acceleration
Enable tunnel traffic forwarding acceleration to accelerate the forwarding of tunneled packets when the NAT, IPsec, AFT, and LB services are not deployed.
2.     Enable tunnel traffic forwarding acceleration.
tunnel accelerate
By default, tunnel traffic forwarding acceleration is disabled.
Enabling dropping IPv6 packets that use IPv4-compatible IPv6 addresses
Automatic IPv4-compatible IPv6 tunnels do not support this feature.
2.     Enable dropping IPv6 packets that use IPv4-compatible IPv6 addresses.
tunnel discard ipv4-compatible-packet
By default, IPv6 packets that use IPv4-compatible IPv6 addresses are not dropped.
After you enable the max-threshold-reached notification, when the number of tunnel interfaces exceeds the warning threshold (80% of the maximum), the device generates SNMP notifications that record the chassis number and slot number of the exceeding tunnel interfaces.
For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
2.     Enable SNMP notifications for the tunneling module.
snmp-agent trap enable tunnel [ max-threshold-reached ]
By default, SNMP notifications for the tunneling module are disabled.
Verifying and maintaining tunnel interface configuration
Displaying tunnel interface information
·     Display tunnel interface information.
display tunnel-interface [ number ]
·     Display information about tunnel interfaces.
display interface [ tunnel [ number ] ] [ brief [ description | down ] ]
·     Display IPv6 information on tunnel interfaces.
display ipv6 interface [ tunnel [ number ] ] [ brief ]
For more information about this command, see IPv6 basics commands in Layer 3—IP Services Command Reference.
Clearing tunnel interface statistics
Perform clear tasks in user view.
·     Clear statistics on tunnel interfaces.
reset counters interface [ tunnel [ number ] ]
For more information about this command, see common interface commands in Interface Command Reference.
·     Clear IPv6 statistics on tunnel interfaces.
Troubleshooting tunnel interface configuration
Tunnel interface not up
Symptom
A tunnel interface configured with related parameters such as tunnel source address, tunnel destination address, and tunnel mode cannot come up.
Analysis
The physical interface of the tunnel does not come up, or the tunnel destination is unreachable.
Solution
1.     To resolve the issue:
¡     Use the display interface or display ipv6 interface command to verify that the physical interface of the tunnel is up. If the physical interface is down, check the network connection.
¡     Use the display ipv6 routing-table or display ip routing-table command to verify that the tunnel destination is reachable. If the route is not available, configure a route to reach the tunnel destination.
2.     If the issue persists, contact H3C Support.
