03-Interface Configuration Guide
HomeSupportRoutersSR6600-M SeriesConfigure & DeployConfiguration GuidesH3C SR6608-M Router Configuration Guides-R9141-6W10103-Interface Configuration Guide
03-WAN interface configuration
03-WAN interface configuration 157.23 KB
Configuring WAN interfaces
About WAN interfaces
This chapter describes how to configure the following types of WAN interfaces:
·     Asynchronous serial interface.
·     CE1/PRI interface.
·     E1-F interface.
WAN interface and hardware compatibility
Support for WAN interfaces varies by interface card. For interfaces provided by a device, see the installation guide and card manuals.
Model
WAN interface compatibility
SR6608-M
This feature is supported on SR6608-M devices installed with RT-HMIC-ET16 cards.
SR6608-F
No
Configuring common WAN interface settings
This section only describes the common properties configuration for WAN interfaces.
2.     Enter an interface view.
¡     Enter synchronous serial/ E1-F interface view.
interface serial interface-number
¡     Enter CE1/PRI interface view.
controller e1 interface-number
3.     Configure the interface description.
By default, the description of an asynchronous serial interface is interface name Interface, for example, Serial2/1/0 Interface.
4.     Set the expected bandwidth for the interface.
bandwidth bandwidth-value
By default, the expected bandwidth (in kbps) is the interface baud rate divided by 1000.
Interfaces that support this feature include serial interfaces and E1-F interfaces.
5.     Configure the keepalive interval and retry limit.
¡     Set the keepalive interval.
timer-hold seconds
The default setting is 10 seconds.
¡     Set the keepalive retry limit.
timer-hold retry retries
The default setting is 5.
6.     Set the MTU.
mtu size
The default setting is 1500 bytes.
7.     Bring up the interface.
By default, an interface is up.
Configuring a serial interface
About serial interfaces
The serial interfaces on the device refer to the logical interfaces channelized from CE1/PRI or E1-F interfaces. The serial interface has the same logical features as a standard synchronous serial interface. You can configure this serial interface in the same way you configure a standard synchronous serial interface.
Synchronous serial interfaces are typically used for receiving, transmitting, and processing synchronous serial data flows. Their interface type name is Serial.
The synchronous serial interface supports the following protocols:
·     Data link layer protocols, such as PPP and HDLC.
·     Network layer protocols, such as IP.
Restrictions and guidelines for configuring serial interfaces
·     In E1 unchannelized mode, the CE1/PRI interface automatically creates a serial interface that has the same logical features as a standard synchronous serial interface. You can configure this serial interface in the same way you configure a standard synchronous serial interface.
·     In CE1 channelized mode, after you bundle timeslots of a CE1/PRI interface into a channel set, the system automatically creates a serial interface named serial interface-number:set-number. This interface has the same logical features as a standard synchronous serial interface.
·     In unframed mode, an E1-F interface is a 2048 kbps interface without timeslot division and has the same logical features as a standard synchronous serial interface.
·     In framed mode, an E1-F interface is physically divided into 32 timeslots numbered 0 through 31, with timeslot 0 for synchronization. You can bundle the remaining timeslots into a channel set. The E1-F interface has a speed of n × 64 kbps, which has the same logical features as a standard synchronous serial interface.
Configuring a synchronous serial interface
This section only describes the interface properties configuration. Depending on the network requirements, you might also need to configure PPP, IP address, and interface backup.
2.     Enter synchronous serial interface view.
3.     Set the link layer protocol.
link-protocol { hdlc | ppp }
The default is PPP.
4.     Configure line detection settings.
¡     Set the CRC mode.
crc { 16 | 32 | none }
The default is 16-bit CRC.
¡     Initiate a loopback test.
loopback-test [ -c count | -p { pattern | special { ascending | descending | random } } | -s packetsize | -t timeout ] * interface interface-type interface-number
By default, no loopback test is performed on an interface.
This command is available only on synchronous serial interfaces that are created for E1 and E1-F interfaces.
Verifying and maintaining serial interfaces
Clearing serial interface statistics
Perform all clear tasks in user view.
·     Clear statistics for serial interfaces.
reset counters interface serial [ interface-number ]
Displaying serial interface information
Perform all display tasks in any view.
·     Display serial interface information.
display interface serial [ interface-number ] [ brief [ description | down ] ]
Configuring a CE1/PRI interface
About CE1/PRI interfaces
A CE1/PRI interface can operate in channelized or unchannelized mode:
·     The unchannelized mode is also called E1 mode.
·     Channelized modes include CE1 mode and PRI mode.
In CE1 or PRI mode, a CE1/PRI interface is physically divided into 32 timeslots numbered 0 to 31. Timeslot 0 is used to transmit synchronizing information.
E1 mode
For a CE1/PRI interface in E1 mode, the system automatically creates a serial interface named serial interface-number:0. This interface has the same logical features as a standard synchronous serial interface. You can configure the serial interface as described in "Configuring a synchronous serial interface."
CE1 mode
In CE1 mode, you can bundle all timeslots except timeslot 0 into a maximum of 31 channel sets..
·     For each channel set, the system automatically creates a serial interface named serial interface-number:set-number. This interface has the same logical features as a standard synchronous serial interface. You can configure the serial interface as described in "Configuring a synchronous serial interface."
Configuring unchannelized mode for a CE1/PRI interface
Configuring a CE1/PRI interface in E1 mode
2.     Enter CE1/PRI interface view.
3.     Configure the interface to operate in E1 mode.
using e1
By default, a CE1/PRI interface operates in channelized mode.
4.     Set other interface parameters.
See "Configuring other CE1/PRI interface parameters."
Configuring channelized mode for a CE1/PRI interface
Configuring a CE1/PRI interface in CE1 mode
3.     Configure the interface to operate in channelized mode.
using ce1
4.     Bundle timeslots on the interface into a channel set.
channel-set set-number timeslot-list list
For each channel set, the system automatically creates a serial interface that has the same logical features as a standard synchronous serial interface. The serial interface name uses the serial interface-number:set-number format.
5.     Set the framing format.
frame-format { crc4 | no-crc4 }
The default is no-CRC4.
A CE1/PRI interface in CE1 mode supports both CRC4 and no-CRC4 framing formats.
6.     Enable RAI detection on the interface.
alarm-detect rai
By default, RAI detection is enabled on the interface.
7.     Set other interface parameters.
Configuring a CE1/PRI interface in PRI mode
using ce1
4.     Bundle timeslots on the interface into a PRI set.
pri-set [ timeslot-list list ]
5.     Set other interface parameters.
3.     Set the line code format.
code { ami | hdb3 }
The default is high density bipolar 3 (HDB3).
4.     Enable or disable user data inversion.
data-coding { inverted | normal }
By default, user data inversion is disabled.
5.     Set the clock mode.
clock { master | slave }
The default clock mode is slave, which is line clock.
6.     Enable automatic clock mode change.
clock-change auto
By default, automatic clock mode change is disabled.
When automatic clock mode switchover is enabled, the interface automatically switches to the master clock mode when both of the following conditions exist:
¡     The interface uses the slave clock mode.
¡     The interface receives an alarm indication signal (AIS), loss of signal (LOS), or loss of frame (LOF) alarm.
After the alarm is cleared, the interface automatically switches back to the slave clock mode.
7.     Set the line idle code type.
idle-code { 7e | ff }
The default is 0x7E.
8.     Set the type and the number of interframe filling tags.
itf { number number | type { 7e | ff } }
By default:
¡     The type of the interframe filling tag is 0x7E.
¡     The number of interframe filling tags is four.
When a CE1/PRI interface is operating in unframed mode and the interframe filling tag type is set to ff, all "1" data will be transmitted on the line when no service data is present, which can easily trigger AIS alarms. To prevent generation of AIS alarms in this situation, execute the undo fe1 detect-ais command to disable AIS detection.
Enabling local loopback on a CE1/PRI interface
Loopback is intended for testing only. Disable loopback when the interface is operating correctly.
After you enable this feature on an interface, the interface does not forward data traffic.
3.     Enable local loopback.
loopback { local | payload | remote }
By default, local loopback is disabled.
Verifying and maintaining CE1/PRI interfaces
Clearing statistics for CE1/PRI interfaces
To clear statistics for CE1/PRI interfaces, execute the following command in user view:
reset counters controller e1 [ interface-number ]
Displaying CE1/PRI interface information
·     Display information about CE1/PRI interfaces.
display controller [ e1 [interface-number ] ]
·     Display information about a channel set or PRI set.
display interface serial interface-number:set-number
Configuring an E1-F interface
About E1-F interfaces
E1-F interfaces, which are fractional E1 interfaces, are simplified CE1/PRI interfaces. They are a cost-effective alternative to CE1/PRI interfaces for E1 access services that do not require multiple channel sets.
An E1-F interface has the following features:
·     In framed mode, an E1-F interface can bind timeslots into only one channel set. In contrast, a CE1/PRI interface can group and bundle timeslots randomly into multiple channel sets.
·     An E1-F interface does not support PRI mode.
·     An E1-F interface can operate in either framed (the default) or unframed mode.
¡     In unframed mode, an E1-F interface provides 2048 kbps of data bandwidth. For the interface, a synchronous serial interface is created automatically.
¡     In framed mode, an E1-F interface is physically divided into 32 timeslots numbered 0 through 31. Timeslot 0 is used for transmitting synchronization information. All other timeslots can randomly form one channel set. For the channel set, a synchronous serial interface is created automatically. The interface rate is n × 64 kbps, where n is the number of bundled timeslots.
·     The synchronous serial interface created in either mode has the same logical features as a standard synchronous serial interface and supports the following protocols:
¡     Data link layer protocols, such as PPP and HDLC.
¡     Network layer protocols, such as IP.
You can configure this interface in the same way a standard synchronous serial interface is configured.
Restrictions: Hardware compatibility with E1-F interfaces
Only SR6608-M devices installed with RT-HMIC-ET16 interface cards support E1-F interfaces.
Configuring an E1-F interface in framed mode
2.     Enter E1-F interface view.
3.     Configure the interface to operate in framed mode.
undo fe1 unframed
The default is framed mode.
4.     Bundle timeslots on the interface.
fe1 timeslot-list range
By default, if no timeslot range is specified, all timeslots are bundled.
fe1 frame-format { crc4 | no-crc4 }
fe1 alarm-detect rai
See "Configuring other E1-F interface parameters."
Configuring an E1-F interface in unframed mode
3.     Configure the interface to operate in unframed mode.
fe1 unframed
4.     Enable AIS detection.
fe1 detect-ais
By default, AIS detection is disabled.
interface serial serial-number
fe1 code { ami | hdb3 }
The default is HDB3.
fe1 data-coding { inverted | normal }
fe1 clock { master | slave }
The default is slave, which is line clock.
clock-change auto
7.     Set the CRC mode.
8.     Configuring interface properties
¡     Set the line idle code type.
fe1 idle-code { 7e | ff }
¡     Set the type and the number of interframe filling tags.
fe1 itf { number number | type { 7e | ff } }
By default:
-     The type of the interframe filling tag is 0x7E.
-     The number of interframe filling tags is four.
When an E1-F interface is operating in unframed mode and the interframe filling tag type is set to ff, all "1" data will be transmitted on the line when no service data is present, which can easily trigger AIS alarms. To prevent generation of AIS alarms in this situation, execute the undo fe1 detect-ais command to disable AIS detection.
Enabling local loopback on an E1-F interface
After you enable this feature on an E1-F interface, the interface does not forward data traffic.
3.     Enable loopback and set the loopback mode.
fe1 loopback { local | payload | remote }
By default, loopback is disabled.
Verifying and maintaining E1-F interfaces
Clearing statistics for E1-F interfaces
To clear statistics for E1-F interfaces, execute the following command in user view:
Displaying E1-F interface information
·     Display information about E1-F interfaces.
display fe1 [ serial interface-number ]
·     Display the operating status of an E1-F interface.
Restoring the default settings for an interface
This feature might interrupt ongoing network services. Make sure you are fully aware of the impact of this feature when you use it on a live network.
This feature might fail to restore the default settings for some commands because of command dependencies or system restrictions. You can use the display this command in interface view to check for these commands and perform their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message to resolve the problem.
2.     Enter interface view.
3.     Restore the default settings for the interface.
default
