- 20-Network Management and Monitoring Command Reference
- 01-sFlow commands
- 02-CWMP commands
- 03-Event MIB commands
- 04-iNQA commands
- 05-IPv6 NetStream commands
- 06-NetStream commands
- 07-NQA commands
- 08-NTP commands
- 09-Packet capture commands
- 10-Ping and tracert commands
- 11-RMON commands
- 12-Sampler commands
- 13-SNMP commands
- 14-Cloud connection commands
- 15-System debugging commands
- 16-Mirroring commands
- 17-IP traffic statistics collection commands
- 18-iFIT commands
| 18-iFIT commands | 235.66 KB |
iFIT commands for application-level measurement
display ifit global-information
iFIT commands for tunnel-level measurement
display ifit srv6-segment-list
service-type srv6-segment-list
bind interface
Use bind interface to bind an interface to an instance.
Use undo bind interface to unbind an interface from an instance.
bind interface interface-type interface-number
undo bind interface [ interface-type interface-number ]
An instance is not bound to any interface.
iFIT instance view
interface-type interface-number: Specifies an interface by its type and number. If you do not specify this argument, the default setting will be restored. Currently, you can only bind a Layer 3 physical interface to an instance.
Before enabling iFIT measurement on the ingress node of an instance, execute this command to bind an interface to the instance. After you bind an interface to an instance, iFIT parses the packets passing through the interface to identify the target packets and add an iFIT header to each target packets. Meanwhile, iFIT will count the number of target packets, and send the packet count and timestamp to the analyzer at intervals through gRPC.
# Bind interface GigabitEthernet2/0/1 to instance abc.
[Sysname] ifit enable
[Sysname-ifit] instance abc
[Sysname-ifit-instance-abc] bind interface gigabitethernet 2/0/1
delay-measure disable
Use delay-measure disable to disable packet delay measurement.
Use undo delay-measure disable to enable packet delay measurement.
Packet delay measurement is enabled.
iFIT instance view
By default, packet delay measurement is enabled. You can execute this command to disable packet delay measurement as required.
# Disable packet delay measurement.
[Sysname-ifit-instance-abc] delay-measure disable
delete dynamic-flow
Use delete dynamic-flow to delete iFIT dynamic flows.
delete dynamic-flow { all | device-id device-id flow-id flow-id }
iFIT view
all: Specifies all dynamic flows.
device-id device-id: Specifies an iFIT device by its ID in the range of 1 to 1048575.
flow-id flow-id: Specifies an iFIT flow by its ID in the range of 1 to 1048575.
A flow ID is generated on the ingress node and passed to the transmit nodes and egress node. A flow ID and a device ID uniquely identify a flow and you can execute the display ifit instance command to view the flow ID.
# Delete the dynamic flow with device ID 2 and flow ID 4098.
[Sysname-ifit] delete dynamic-flow device-id 2 flow-id 4098
device-id
Use device-id to specify a device ID.
Use undo device-id to restore the default.
device-id device-id
undo device-id
No device ID is specified.
iFIT view
device-id: Specifies a device ID in the range of 1 to 1048575.
A device ID uniquely identifies a device in an iFIT network. To make iFIT function correctly, specify a device ID and make sure the specified device ID is unique.
# Specify 100 as the device ID.
[Sysname-ifit] device-id 100
Use display ifit global-information to display global iFIT flow information.
# Display global iFIT flow information.
<Sysname> display ifit global-information
Current instance count : 2
Enabled instance count : 1
Current static flow count : 1
Current dynamic flow count : 1
Current SRv6 TE policy created flow count : 1
Current SRv6 TE policy created inactive flow count : 1
Current instance count |
Number of configured iFIT instances. |
Enabled instance count |
Number of instances enabled with iFIT. |
Current static flow count |
Number of static flows. |
Current dynamic flow count |
Number of dynamic flows. |
Current SRv6 TE policy created flow count |
Number of iFIT target flows for the SRv6 TE policy |
Current SRv6 TE policy created inactive flow count |
Number of inactive iFIT target flows for the SRv6 TE policy. |
Use display ifit instance to display iFIT instance information.
display ifit instance [ instance-name ]
instance-name: Specifies an iFIT instance by its name, a case-sensitive string of 1 to 31 characters.
# Display IPv4 iFIT instance information.
<Sysname> display ifit instance 1
Instance name : 1
Device ID : 1
Flow information:
Flow type : Static
Flow direction : Unidirection
Source IP/mask length : 1.1.1.1/24
Destination IP/mask length : 2.2.2.2/32
Protocol : TCP
Source port : Any
Destination port : Any
DSCP : 23
VPN instance name : --
Measurement information:
Period : 10 sec
Measurement mode : e2e
Loss measurement : Enabled
Delay measurement : Enabled
Measurement configuration : Disabled
Measurement status : Inactive
Flow items:
Flow ID Interface
1 GigabitEthernet2/0/1
# Display the IPv6 static flow configuration.
<Sysname> display ifit instance 3
Instance name : 3
Device ID : 1
Flow information:
Flow type : Static
Source IPv6/prefix length : 1::1/68
Destination IPv6/prefix length : 2::2/128
Protocol : UDP
Source port : 8080
Destination port : 2308
DSCP : --
VPN instance name : vpn3
Period : 30 sec
Measurement configuration : Enabled
Measurement status : Active
Flow items:
Flow ID Interface
11 GigabitEthernet2/0/1
12 GigabitEthernet2/0/2
Instance Name |
iFIT instance name. |
Device ID |
iFIT device ID. |
Flow information |
iFIT target flow information. |
Flow type |
iFIT flow type: · Static. · Dynamic. |
Flow direction |
iFIT flow direction. |
Source IP/maskLength |
Source IP address and mask length of the target flow. |
Destination IP/maskLength |
Destination IP address and mask length of the target flow. |
Source IPv6/prefix length |
Source IPv6 address and prefix length of the target flow. |
Destination IPv6/prefix length |
Destination IPv6 address and prefix length of the target flow. |
Protocol |
Target flow protocol: · any. · udp. · tcp. · sctp. |
Source port |
Source port number of the target flow. |
Destination port |
Destination port number of the target flow. |
DSCP |
DSCP value of the target flow. |
VPN-instance name |
Name of the VPN instance bound to the iFIT flow. |
Measurement information |
Measurement information. |
Period |
Measurement period. |
Measurement mode |
Measurement mode: · e2e—End to end measurement. · trace—Hop by hop measurement. |
Loss measurement |
Whether packet loss measurement is enabled: · Enabled. · Disabled. |
Delay measurement |
Whether delay measurement is enabled: · Enabled. · Disabled. |
Measurement configuration |
Whether measurement is enabled: · Enabled. · Disabled. |
Measurement status |
Actual measurement state: · Active—iFIT measurement is in progress. · Inactive—iFIT measurement has not started. |
Flow items |
iFIT target flow. Flow information is displayed only when the measure enable command is executed. |
Flow ID |
iFIT target flow ID. -- indicates that the flow has not been assigned with an ID. |
Interface bound to the iFIT target flow. All indicates that the iFIT flow has been bound to all Layer 3 physical interfaces. |
display ifit flow dynamic
Use display ifit flow dynamic to display dynamic flow information.
display ifit flow dynamic [ device-id device-id flow-id flow-id ]
flow-id flow-id: Display information about a dynamic flow by its ID. The value range for the flow-id argument is 1 to 1048575.
A transmit node or the egress node parses the received packets and identifies the target flow according to the iFIT headers of the packets. A dynamic flow is identified by the device ID and flow ID in the iFIT headers of the packets. If the device does not receive the packets using the same device ID and the same flow ID for a period of time, the device will age out the dynamic flow entry.
A flow ID is generated on the ingress node and passed to the transmit nodes and egress node. A flow ID and device ID uniquely identify a flow and you can execute the display ifit instance command to view the flow ID.
# Display dynamic flow information.
<Sysname> display ifit flow dynamic
Device ID : 1
Flow ID : 4099
Flow type : Dynamic
Period : 10 sec
Actual aging-time : 300 sec
Interface information
Name Direction
GigabitEthernet2/0/1 TransitInput
GigabitEthernet2/0/2 TransitOutput
Device ID |
iFIT device ID. |
Flow ID |
Flow ID of a dynamic flow. |
Flow type |
Flow type: · Static. · Dynamic. |
Flow direction |
Flow direction. If the field value is Unidirection, the flow is a unidirectional flow. |
Period |
Measurement period in seconds. |
Actual aging-time |
Actual time when the dynamic flow is aged out. |
Interface information |
Information about the interfaces that receive the dynamic flow. |
Name |
Interface name. |
Direction |
Flow direction for the interface: · Ingress—The target flow enters the transit network from this interface. · TransitInput—The target flow enters the node from this interface. · TransitOutput—The target flow leaves the node from this interface. · Egress—The target flow leaves the transit network from this interface. |
display ifit flow static
Use display ifit flow static to display static flow information for the most recent 10 measurement periods.
display ifit flow static [ flow-id flow-id ]
flow-id flow-id: Display information about a static flow by its ID. The value range for the flow-id argument is 1 to 1048575.
You can specify a flow on the ingress node by using any combination of the following items: source IP address/segment, source port number, destination IP address/segment, destination port number, protocol type, DSCP value, and VPN instance. If a packet matches the configured items, the ingress node will add an iFIT header to the packet and the flow is the static flow.
# Display the IPv4 static flow configuration.
<Sysname> display ifit flow static flow-id 4097
Instance name : 1
Device ID : 1
Flow ID : 4097
Flow information:
Flow type : Static
Protocol : TCP
Source port : Any
DSCP : 23
Period : 10 sec
Bound interface:
All
<Sysname> display ifit flow static flow-id 4099
Instance name : 3
Device ID : 1
Flow ID : 4099
Flow information:
Flow type : Static
Protocol : UDP
Source port : 8080
DSCP : --
Period : 30 sec
Bound interface:
Instance Name |
Name of the iFIT instance. |
Device ID |
ID of the device that generates the iFIT target flow. |
Flow ID |
Flow ID of the target flow. |
Flow information |
Information about the target flow. |
Flow type |
Flow direction |
Source IP address and mask length. |
Destination IP address and mask length. |
Source IPv6 address and prefix length. |
Destination IPv6 address and prefix length. |
Protocol |
Protocol: · Any. · UDP. · TCP. · SCTP. |
Source port |
Source port number. |
Destination port |
Destination port number. |
DSCP |
VPN-instance name |
Name of the VPN instance bound to the target flow. |
Information about iFIT measurement. |
Period |
Measurement mode |
Measurement mode: · trace—Hop-by-hop measurement. · e2e—End-to-end measurement. |
Next hop configuration |
Configured next hop. |
Loss measurement |
Delay measurement state: · Enabled. · Disabled. |
Delay measurement |
Loss measurement state: · Enabled. · Disabled. |
Configured measurement state: · Enabled. · Disabled. |
Bound interface |
Interface bound with the target flow. |
display ifit statistic
Use display ifit statistic to display statistics about an iFIT flow for the most recent 10 measurement periods.
display ifit statistic device-id device-id flow-id flow-id [ verbose ]
flow-id flow-id: Displays statistics about an iFIT flow by its flow ID. The value range for the flow-id argument is 1 to 1048575.
verbose: Displays detailed statistics about an iFIT flow. If you do not specify this keyword, this command displays brief statistics about an iFIT flow.
# Display brief measurement information about the flow with device ID 1 and flow ID 123.
<Sysname> display ifit statistic device-id 1 flow-id 123
Period ID Direction PktCount Timestamp(sec, nsec) Interface
159627365 TransitIn 1500 1596273655,349433112 GE2/0/1
# Display detailed measurement information about the flow with device ID 1 and flow ID 123.
<Sysname> display ifit statistic device-id 1 flow-id 123 verbose
Period ID : 159627365
Period started at : 2020-08-01 17:20:55
Direction : TransitInput
Interface : GigabitEthernet2/0/1
PktCount : 1500
ByteCount : 1295489456450
Timestamp (sec, nsec): 2020-08-01 17:20:55.349433112 (1619278726, 349433112)
TTL : 0
Table 5 Command output
PeriodID |
Measurement period number. |
Period started at |
Start time of the measurement period. |
Direction |
Flow direction of the interface: · Ingress—The target flow enters the transit network from this interface. · TransitIn—The target flow enters the node from this interface. You can view this value only in the simplified iFIT flow statistics. · TransitInput—The target flow enters the node from this interface. You can view this value only in the detailed iFIT flow statistics. · TransitOut—The target flow leaves the node from this interface. You can view this value only in the simplified iFIT flow statistics. · TransitOutput—The target flow leaves the node from this interface. You can view this value only in the detailed iFIT flow statistics. · Egress—The target flow leaves the transit network from this interface. |
Interface name. |
PktCount |
Number of packets measured in the period. |
ByteCount |
Number of bytes detected in the period. |
Timestamp (sec, nsec) |
Timestamp value for the delay measurement. In the detailed information, this field is displayed in the YY-MM-DD HH:MM:SS.nanosecond format. |
TTL |
This field is not supported in the current software version. TTL value of the packet. |
dynamic-flow aging-time
Use dynamic-flow aging-time to specify the aging time for dynamic flows.
Use undo dynamic-flow aging-time to restore the default.
dynamic-flow aging-time multi-value
The aging time for dynamic flows is 10 times the measurement period and it cannot be less than 5 minutes.
iFIT view
multi-value: Specifies a multiplier value. The aging time for dynamic flows is equal to the measurement period multiplied by the multiplier value. The value range is 2 to 100.
The aging time for dynamic flows must be equal to or greater than 5 minutes. If the configured aging time is less than 5 minutes, the actual aging time will be 5 minutes.
# Configure the aging time for dynamic flows to be 20 times the measurement period.
[Sysname-ifit] dynamic-flow aging-time 20
flow
Use flow to specify a static flow to be monitored by an iFIT instance.
Use undo flow to remove the static flow settings.
· iFIT measurement based on 5-tuple granularity:
¡ IPv4:
flow unidirection source-ip src-ip-address [ src-mask-length ] destination-ip dest-ip-address [ dest-mask-length ] [ protocol { { tcp | udp | sctp } [ source-port src-port-number ] [ destination-port dest-port-number ] | protocol-number } ] [ dscp dscp-value ] [ vpn-instance vpn-instance-name ]
undo flow
¡ IPv6:
flow unidirection source-ipv6 src-ipv6-address [ src-prefix-length ] destination-ipv6 dest-ipv6-address [ dest-prefix-length ] [ protocol { { tcp | udp | sctp } [ source-port src-port-number ] [ destination-port dest-port-number ] | protocol-number } ] [ dscp dscp-value ] [ vpn-instance vpn-instance-name ]
undo flow
· iFIT measurement based on PeerLocator granularity:
¡ IPv4:
flow unidirection source-ip any destination-ip any [ vpn-instance vpn-instance-name ] peer-locator ipv6-address prefix-length
undo flow
¡ IPv6:
flow unidirection source-ipv6 any destination-ipv6 any [ vpn-instance vpn-instance-name ] peer-locator ipv6-address prefix-length
undo flow
No static flow is specified for an iFIT instance.
iFIT instance view
unidirection: Specifies the unidirectional flows.
source-ip src-ip-address: Specifies a source IPv4 address of the flow, in dotted decimal format.
src-mask-length: Specifies a mask length for the source IPv4 address. The value range is 1 to 32. If you do not specify this argument, the exact match of the source IPv4 address is used.
destination-ip dest-ip-address: Specifies a destination IPv4 address of the flow, in dotted decimal format.
dest-mask-length: Specifies a mask length for the destination IPv4 address. The value range is 1 to 32. If you do not specify this argument, the exact match of the source IPv4 address is used.
source-ipv6 src-ipv6-address: Specifies a source IPv6 address of the flow.
src-prefix-length: Specifies a prefix length for the source IPv6 address. The value range is 1 to 128. If you do not specify this argument, the exact match of the source IPv6 address is used.
destination-ipv6 dest-ipv6-address: Specifies a destination IPv6 address of the flow.
dest-prefix-length: Specifies a prefix length for the destination IPv6 address. The value range is 1 to 128. If you do not specify this argument, the exact match of the destination IPv6 address is used.
protocol: Specifies a protocol type of the flow. If you do not specify this keyword, the flow can use any protocol.
· { tcp | udp | sctp }: Specifies the TCP, UDP, or SCTP protocol.
· destination-port dest-port-number: Specifies a destination port number. The value range is 0 to 65535. If you do not specify this option, the flow can use any port number as the destination port number.
· source-port src-port-number: Specifies a source port number. The value range is 0 to 65535. If you do not specify this option, the flow can use any port number as the source port number.
· protocol-number: Specifies the number of the protocol type. The value range is 0 to 255, excluding 6 (TCP protocol number), 17 (UDP protocol number), and 132 (SCTP protocol number).
dscp dscp-value: Specifies a DSCP value of the flow, in the range of 0 to 63.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To specify a flow on the public network, do not specify this option.
source-ip any: Specifies any source IPv4 address.
destination-ip any: Specifies any destination IPv4 address.
source-ipv6 any: Specifies any source IPv6 address.
destination-ipv6 any: Specifies any destination IPv6 address.
peer-locator ipv6-address prefix-length: Specifies the locator to which the flow belongs. The ipv6-address argument represents the IPv6 address prefix. The prefix-length argument represents the prefix length, in the range of 32 to 120. The IPv6 address prefix cannot be an IPv4-compatible IPv6 address.
Operating mechanism
Static flows are key elements for iFIT measurement. Before starting an iFIT measurement, you must execute this command to specify a flow to be measured on the ingress node. You do not need to specify a flow on the transmit nodes and egress node because the device can automatically learn the target flow through the iFIT header of the packets.
The device can perform iFIT measurement based on the following granularities in different scenarios:
· 5-tuple granularity—Used for measuring communication quality of the specified service flow. You can use 5-tuple to match service flows or perform iFIT measurement on any service traffic on a network. This granularity is available for all networks supported by iFIT.
· PeerLocator granularity—Used for measuring end-to-end communication quality on the entire network. The peer-locator keyword can specify a tunnel. The device performs iFIT measurement on any service flows through the tunnel.
An iFIT instance can monitor only one flow. If you execute this command multiple times for the same iFIT instance, the most recent configuration takes effect.
For the flows to be monitored by different instances, the flow attributes must not be identical.
The source and destination IP addresses must be legal unicast IP addresses, and they cannot be broadcast or multicast IP addresses.
# Configure instance 1 to monitor the unidirectional flow from 10.10.10.1 to 10.10.10.2 with the VPN instance vpn1.
[Sysname-ifit-instance-abc] flow unidirection source-ip 10.10.10.1 24 destination-ip 10.10.10.2 24 vpn-instance vpn1
# On an L3VPN/EVPN L3VPN over SRv6 network, configure instance abc to monitor IPv4 service flows based on PeerLocator granularity of unidircetional flow and PeerLocator 2001::1.
[Sysname-ifit-instance-abc] flow unidirection source-ip any destination-ip any peer-locator 2001::1 64
# On an L3VPN/EVPN L3VPN over SRv6 network, configure instance abc to monitor IPv6 service flows based on PeerLocator granularity of unidirectional flow and PeerLocator 2001::1.
[Sysname-ifit-instance-abc] flow unidirection source-ipv6 any destination-ipv6 any peer-locator 2001::1 64
ifit enable
Use ifit enable to enable the iFIT functionality globally and enter its view, or enter the existing iFIT view.
Use undo ifit enable to disable the iFIT functionality globally.
ifit enable
undo ifit enable
The iFIT functionality is disabled.
To measure the packet loss and packet delay of the network in real time, you can enable iFIT measurement.
To start iFIT measurement, perform the following tasks:
· On the ingress node, enable the iFIT functionality, configure iFIT device ID, create an instance, and configure a flow to be monitored by the instance. The configured flow is a static flow. The ingress node automatically uses the device ID to generates a flow ID, and encapsulates the flow ID and local iFIT device ID in the iFIT header of packets transmitted to the transmit nodes and egress node. The flow ID uniquely identifies a flow.
· On the transmit nodes and egress node, enable the iFIT functionality. If the received packet carries an iFIT header, a transmit node or the egress node will perform iFIT measurement according to the flow ID, measurement period number, timestamp in the iFIT header.
# Enable iFIT and enter its view.
[Sysname-ifit]
instance
Use instance to create an iFIT instance and enter its view, or enter the view of an existing iFIT instance.
Use undo instance to delete an iFIT instance.
instance instance-name
undo instance instance-name
No iFIT instance exists.
iFIT view
instance-name: Specifies an iFIT instance by its name. The instance name is a case-sensitive string of 1 to 31 characters.
You must configure an iFIT instance on the ingress node. You can configure target flow match criteria in instance view. An instance can be bound to multiple interfaces, and an interface is associated with one target flow.
To perform iFIT measurement on the transmit nodes and egress node, you only need to enable iFIT. After you enable iFIT on a transmit node or the egress node, the node automatically identifies the flow according to the iFIT header, and perform iFIT measurement on the flow. The flow identified automatically is a dynamic flow.
# Create iFIT instance abc and enter its view.
[Sysname-ifit-abc]
measure enable
Use measure enable to enable iFIT measurement for an iFIT instance.
Use undo measure enable to disable iFIT measurement for an iFIT instance.
measure enable
undo measure enable
iFIT measurement for an iFIT instance is disabled.
iFIT instance view
You can execute this command to start iFIT measurement for an iFIT instance to monitor the packet delay and packet loss of the flow.
Before starting iFIT measurement, configure a device ID, create an iFIT instance, configure a flow, and then bind an interface to the iFIT instance.
To modify the configuration for the device-id command or an iFIT enabled instance, disable iFIT measurement for the instance firstly.
# Enable iFIT measurement for iFIT instance abc.
[Sysname-ifit-instance-abc] measure enable
measure mode
Use measure mode to specify an iFIT measurement mode.
Use undo measure mode to restore the default.
measure mode { e2e | trace }
undo measure mode
End-to-end measurement is used.
iFIT instance view
e2e: Specifies end-to-end measurement. In this mode, only the ingress node and egress node report the measurement data.
trace: Specifies hop-by-hop measurement. In this mode, all nodes that are enabled with iFIT and receive the flow packets will report the measurement data.
iFIT measurement helps you to measure the network performance, troubleshoot the network faults, and measure the service quality.
To measure the packet loss and packet delay of the whole network, you can use end-to-end measurement. To accurately locate the packet loss and packet delay of each network node, you can use the hop-by-hop measurement.
# Specify hop-by-hop measurement as the measurement mode.
[Sysname-ifit-instance-abc] measure mode trace
period
Use period to specify the measurement period for an iFIT instance.
Use undo period to restore the default.
period period
undo period
The measurement period for an iFIT instance is 30 seconds.
iFIT instance view
period: Specifies the measurement period in seconds. Valid values include 1, 10, 30, 60, and 300.
iFIT collects performance statistics based on the measurement period.
· The sender records the sending time of the first iFIT packet in each sending interval, and counts the number of the iFIT packets sent from an interface in each sending interval. Sending interval = iFIT measurement period.
· The receiver records the receiving time of the first iFIT packet in each receiving interval, and counts the number of the iFIT packets received by an interface in each receiving interval. To reduce the impact of network delay and disorder on statistics, the receiving interval equals to (1+1/3) measurement period.
If network delay between the ingress and egress nodes is greater than 1/3 measurement period, the accuracy of iFIT packet loss statistics might be affected. This is because iFIT considers packets received beyond the receiving interval as packet loss. For example, if the measurement period is 1 second and the network delay greater than 1/3 seconds (333 milliseconds), the accuracy of iFIT packet loss statistics might be affected. In this case, set the measurement period to a greater value.
# Specify 60 seconds as the measurement period for an iFIT instance.
[Sysname-ifit-instance-abc] period 60
reset ifit statistic
Use reset ifit statistic to clear iFIT statistics for the most recent 10 measurement periods.
reset ifit statistic [ device-id device-id flow-id flow-id | instance instance-name ]
flow-id flow-id: Clears statistics about an iFIT flow by its flow ID. The value range for the flow-id argument is 1 to 1048575.
instance instance-name: Clears statistics about an iFIT flow by its instance name. The instance name is a case-sensitive string of 1 to 31 characters. Only the ingress node supports instances. The transmit nodes and egress node do not support instances.
# Clear iFIT statistics generated in the most recent 10 measurement periods for the flow with device ID 1 and flow ID 40962.
<Sysname> reset ifit statistic device-id 1 flow-id 40962
Use display ifit global-information to display global information of iFIT target flows.
# Display global information of iFIT target flows.
Table 6 Command output
Number of iFIT instances. |
Number of iFIT static target flows. |
Number of iFIT dynamic target flows. |
Number of the iFIT target flows for the SRv6 TE policy |
Use display ifit srv6-segment-list to display information about iFIT target flows for SRv6 TE policies on iFIT Analyzer.
display ifit srv6-segment-list [ segment-list-id ]
segment-list-id: Specifies a segment list by its ID in the range of 0 to 4294967295. This value is automatically assigned to an SRv6 path by the SRv6 TE policy. If you do not specify a segment list, this command displays iFIT target flows for all SRv6 TE policies.
# Display information about the iFIT target flows for SRv6 TE policies on iFIT Analyzer.
<Sysname> display ifit srv6-segment-list
Device ID : 1
Flow ID : 2866
Flow direction : Unidirectional
Period : 30(s)
Segment list information:
Segment list ID : 0
Color : 4
Binding SID : 2001:DB8:1::1
EndPoint : 2001:DB8:3::3
Reverse binding SID : 2001:DB8:2::1
Device ID : 1
Flow ID : 2867
Period : 30(s)
Segment list ID : 0
Color : 4
Device ID : 1
Flow ID : 2868
Period : 30(s)
Segment list ID : 0
Color : 4
Table 7 Command output
Device ID |
iFIT device ID. |
Flow ID |
iFIT flow ID. |
Flow direction |
iFIT flow direction. The value is Unidirectional. |
Information about the measurement parameters. |
Loss measurement |
Whether packet loss is measured. · Enabled. · Disabled. |
Delay measurement |
Whether delay is measured. · Enabled. · Disabled. |
Measurement mode |
Measurement Mode: · e2e: End-to-end measurement. · Trace: Hop-by-hop measurement. |
Period |
Measurement interval, in seconds. |
Segment list information |
SRv6 segment list information |
Segment list ID |
ID of the segment list for the SRv6 TE policy candidate path. |
Color |
Color value of the SRv6 TE policy. |
Binding SID |
Binding SID of the SRv6 TE policy. |
EndPoint |
Destination address of the SRv6 TE policy. |
Reverse binding SID |
Reverse binding SID of the SRv6 TE policy. |
work-mode analyzer
display ifit statistic-type
Use display ifit statistic-type to display the iFIT measurement result from iFIT Analyzer.
display ifit statistic-type { one-way-delay | two-way-delay | one-way-loss } { srv6-segment-list segment-list-id | device-id device-id flow-id flow-id }
one-way-delay: Displays the iFIT one-way delay measurement result.
two-way-delay: Displays the iFIT two-way delay measurement result.
one-way-loss: Displays the iFIT one-way packet loss measurement result.
srv6-segment-list segment-list-id: Specifies an SRv6 path by its segment list ID in the range of 0 to 4294967295. The value is automatically assigned to the SRv6 path by the SRv6 TE policy.
device-id device-id flow-id flow-id: Specifies the target flow. The device-id argument represents the iFIT device ID in the range of 1 to 1048575. The flow-id argument represents the target slow in the range of 1 to 1048575.
Application scenarios
The command displays the iFIT measurement result for the SRv6 TE policy from iFIT Analyzer in the SRv6 TE policy and iFIT collaboration scenario.
This command is not available for static iFIT flows configured by using the flow command and dynamically learned iFIT flows.
# Display the one-way packet loss information for the iFIT target flow with device ID 1 and flow ID 123.
<Sysname> display ifit statistic-type one-way-loss device-id 1 flow-id 123
One-way-loss statistics:
Period ID Loss Loss Ratio Trust flag (Error code)
1 0 0 Untrusted (1)
2 0 0 Untrusted (1)
3 0 0 Trusted (0)
4 0 0 Trusted (0)
5 0 0 Trusted (0)
6 0 0 Trusted (0)
7 0 0 Trusted (0)
8 0 0 Trusted (0)
9 0 0 Trusted (0)
10 0 0 Trusted (0)
# Display the two-way delay information for the iFIT target flow with device ID 1 and flow ID 123.
<Sysname> display ifit statistic-type two-way-delay device-id 1 flow-id 123
Two-way-delay statistics:
Period ID Delay(us) Jitter(us) Trust flag (Error code)
1 1000000 0 Untrusted (1)
2 1000000 0 Untrusted (1)
3 1000000 0 Trusted (0)
4 1000000 0 Trusted (0)
5 1000000 0 Trusted (0)
6 1000000 0 Trusted (0)
7 1000000 0 Trusted (0)
8 1000000 0 Trusted (0)
9 1000000 0 Trusted (0)
10 1000000 0 Trusted (0)
# Display the one-way delay information for the iFIT target flow with device ID 1 and flow ID 123.
<Sysname> display ifit statistic-type one-way-delay device-id 1 flow-id 123
One-way-delay statistics:
1 0 0 Untrusted (1)
2 0 0 Untrusted (1)
3 0 0 Trusted (0)
4 0 0 Trusted (0)
5 0 0 Trusted (0)
6 0 0 Trusted (0)
7 0 0 Trusted (0)
8 0 0 Trusted (0)
9 0 0 Trusted (0)
10 0 0 Trusted (0)
Table 8 Command output
One-way-loss statistics |
One-way packet loss statistics. |
Period ID |
Measurement cycle ID. |
Loss |
Dropped packet count |
Loss Ratio |
Packet loss rate, with accuracy to one part per million. |
Delay(us) |
End-to-end delay from the ingress node to the egress node on the SRv6 path, in microseconds. |
Jitter(us) |
End-to-end jitter from the ingress node to the egress node on the SRv6 path, in microseconds. |
Trust flag (Error code) |
Whether the data reported in this cycle can be trusted. · Trusted: The data can be trusted. · Untrusted: The data cannot be trusted. The accuracy of the measurement data for the new target flow generated in the first and second cycles cannot be guaranteed and is considered untrustworthy. As a best practice, configure the controller to not use the data generated in the first and second measurement cycles for the new target flow. The values of the error code are 0 and 1. · 0: Indicates that the data can be trusted. · 1: Indicates that the data cannot be trusted. |
work-mode analyzer
Use service-type srv6-segment-list to configure iFIT Collector to only collect and report the iFIT measurement results for SRv6 paths.
undo service-type to restore the default.
undo service-type
iFIT Collector does not collect or report the iFIT measurement results for SRv6 paths.
iFIT Collector view
In the SRv6 TE policy and iFIT collaboration scenario, you need to execute this command on the egress node for iFIT Collector to only collect and report the iFIT measurement results for SRv6 paths.
Operating mechanism
In the SRv6 TE policy and iFIT collaboration scenario, iFIT is used to measure the end-to-end latency from the ingress node to the egress node on the SRv6 TE policy path. The measurement result will be used to guide SRv6 TE policy routing on the ingress node. An iFIT flow is created on the ingress node, and the egress node performs iFIT measurement only on packets carrying the iFIT header. The egress node can perform iFIT measurements for multiple service flows simultaneously. If you execute this command on the egress node, the egress node will only collect and report the iFIT measurement result for the SRv6 paths.
# Specify the SRv6 TE policy service for iFIT measurement.
[Sysname-ifit] work-mode collector
[Sysname-ifit-work-mode-collector] service-type srv6-segment-list
work-mode collector
work-mode analyzer
Use work-mode analyzer to configure the device to act as iFIT Analyzer and enter iFIT Analyzer view.
Use undo work-mode analyzer to cancel iFIT Analyzer settings.
Use undo work-mode to restore the default.
work-mode analyzer
undo work-mode [ analyzer ]
The device does not act as iFIT Analyzer or iFIT Collector.
iFIT view
In the scenario where the SRv6 TE policy and iFIT do not operate collaboratively, the device sends the iFIT measurement data to a separately deployed analyzer through Telemetry. This analyzer gathers the statistics transmitted from the ingress, transmit, and egress nodes and performs the aggregation and analysis.
In the scenario where the SRv6 TE policy and iFIT operate collaboratively, iFIT is used to measure the end-to-end delay from the ingress node to the egress node on the SRv6 paths. The measurement results are used to guide route selection on the ingress node. If the device acts as the ingress node of SRv6 paths, you must execute this command on the device.
Operating mechanism
In scenarios where an SRv6 TE policy and iFIT operate collaboratively, iFIT reuses BFD sessions of the SRv6 TE policy to encapsulate iFIT headers to the matched BFD packets for iFIT measurement. An SRv6 TE policy supports both SBFD and BFD in echo packet mode for iFIT measurement , with slightly different Analyzer processing as follows:
· For iFIT measurement based on SBFD, the Analyzer (ingress node) performs the following steps:
a. Enable iFIT to periodically send the measurement results to Analyzer on the same node.
b. Calculate the packet loss rate based on the number of SBFD packets received on both the ingress and egress nodes.
c. Calculate the one-way delay and one-way jitter based on the timestamp when the ingress node sent the SBFD packet and the timestamp when the egress node received the same SBFD packet.
d. Report the iFIT calculation results to the local SRv6 TE policy module for intelligent route selection by the SRv6 TE policy.
· For iFIT measurement based on iFIT in echo packet mode, the Analyzer (ingress node) performs the following steps:
a. Enables iFIT to periodically send the measurement results to Analyzer on the same node.
b. Calculate the packet loss rate based on the number of BFD echo packets received on both the ingress and egress nodes.
c. Calculate the two-way delay and two-way jitter based on the timestamp when the ingress node sent a BFD echo packet and the timestamp when the ingress node received a BFD echo packet.
# Configure the device to act as iFIT Analyzer and enter iFIT Analyzer view.
[Sysname-ifit] work-mode analyzer
[Sysname-ifit-work-mode-analyzer]
work-mode collector
Use work-mode collector to configure the device to act as iFIT Collector and enter iFIT Collector view.
Use undo work-mode collector to cancel the iFIT Collector settings.
work-mode collector
iFIT view
In the scenario where iFIT collaborates with the SRv6 TE policy for intelligent route selection, you can execute this command on the egress node of the SRv6 TE policy path.
Operating mechanism
After you configure the egress node of an SRv6 TE policy to act as iFIT Collector, the egress node establishes a UDP session using the source address of the received SRv6 packets with the ingress node. Over this UDP session, the egress node sends the packet count statistics and timestamps to the ingress node at the iFIT monitoring cycle of the SRv6 TE policy.
# Configure the device to act as iFIT Collector and enter iFIT Collector view.
