- 20-Network Management and Monitoring Command Reference
- 01-sFlow commands
- 02-CWMP commands
- 03-Event MIB commands
- 04-iNQA commands
- 05-IPv6 NetStream commands
- 06-NetStream commands
- 07-NQA commands
- 08-NTP commands
- 09-Packet capture commands
- 10-Ping and tracert commands
- 11-RMON commands
- 12-Sampler commands
- 13-SNMP commands
- 14-Cloud connection commands
- 15-System debugging commands
- 16-Mirroring commands
- 17-IP traffic statistics collection commands
- 18-iFIT commands
| 17-IP traffic statistics collection commands | 89.54 KB |
display ip traffic-statistics live application
display ip traffic-statistics history
ip traffic-statistics config remove-all
ip traffic-statistics live application enable
ip traffic-statistics interval
ip traffic-statistics history enable
reset ip traffic-statistics history
reset ip traffic-statistics statistics
Use display ip traffic-statistics live application to display real-time traffic statistics for applications.
display ip traffic-statistics live application [ app app-name | direction { both | downlink | uplink } [ top top-number ] ] [ slot slot-number ]
display ip traffic-statistics live application top top-number [ slot slot-number ]
app app-name: Specifies an application by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays real-time traffic statistics based on the top top-number option.
direction { both | downlink | uplink }: Specifies the traffic direction to rank application traffic. The both keyword specifies the total traffic (uplink traffic plus downlink traffic). The downlink keyword specifies the downlink traffic. The uplink keyword specifies the uplink traffic. If you do not specify this option, the command ranks application traffic by total traffic.
top top-number: Displays real-time traffic statistics for the top top-number applications. The value range for the top-number argument is 10 to 100. If you do not specify this option, the command displays the top 10 applications by traffic rate.
slot slot-number: Specifies a card by its slot number. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays the total traffic rate of all cards.
Application scenarios
This command can help you monitor the traffic rates of applications in real time.
Operating mechanism
This command ranks applications in descending order of the traffic rate based on the specified conditions.
If the specified application does not exist, this command does not displays any traffic statistics.
If the collected traffic rate is smaller than 0.01 KB/s, it is displayed as 0.01 KB/s.
# Display real-time traffic statistics for applications.
<Sysname> display ip traffic-statistics live application
AppName Total(KB/s) Uplink(KB/s) Downlink(KB/s)
test1 1022.46 411.11 611.35
QQ 835.87 523.52 312.34
Genshen 601.08 550.02 51.06
AppName |
Application name. |
Total |
Total rate of the uplink traffic and downlink traffic during the specified time period, up to two decimal places and in KB/s. |
Uplink |
Uplink traffic rate during the specified time period, up to two decimal places and in KB/s. |
Downlink |
Downlink traffic rate during the specified time period, up to two decimal places and in KB/s. |
Use display ip traffic-statistics history to display historical traffic statistics.
display ip traffic-statistics history application [ time start-date start-time end-date end-time ] [ direction { both | downlink | uplink } ] [ user-ip { ip-address | ipv6-address } ] [ top top-number ]
display ip traffic-statistics history user [ time start-date start-time end-date end-time ] [ direction { both | downlink | uplink } ] [ app app-name ] [ top top-number ]
application: Displays historical traffic statistics for applications.
user: Displays historical traffic statistics for users.
time: Specifies a time period for which historical traffic statistics are displayed. If you do not specify a time period, this command displays all locally stored traffic statistics.
· start-date: Specifies the start date in the format of MM/DD/YYYY or YYYY/MM/DD. MM represents the value of month in the range of 1 to 12. DD represents the value of the specified day that depends on the value of the month. YYYY represents the value of year in the range of 2000 to 2035.
· start-time: Specifies the start time in the format of HH:MM:SS. HH represents the value of hour in the range of 0 to 23. MM represents the value of minute in the range of 0 to 59. SS represents the value of second in the range of 0 to 59. To configure whole minutes, you do not need to enter seconds. To configure whole hours, you do not need to enter minutes or seconds. For example, to configure 0 o’clock, specify 0 for the start-time argument.
· end-date: Specifies the end date in the format of MM/DD/YYYY or YYYY/MM/DD. MM represents the value of month in the range of 1 to 12. DD represents the value of the specified day that depends on the value of the month. YYYY represents the value of year in the range of 2000 to 2035.
· end-time: Specifies the end time in the format of HH:MM:SS. HH represents the value of hour in the range of 0 to 23. MM represents the value of minute in the range of 0 to 59. SS represents the value of second in the range of 0 to 59. To configure whole minutes, you do not need to enter seconds. To configure whole hours, you do not need to enter minutes or seconds. For example, to configure 0 o’clock, specify 0 for the end-time argument.
app app-name: Specifies an application by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays historical traffic statistics based on the top top-number option.
direction { both | downlink | uplink }: Specifies the traffic direction to rank application traffic. The both keyword specifies the total traffic (uplink traffic plus downlink traffic). The downlink keyword specifies the downlink traffic. The uplink keyword specifies the uplink traffic. If you do not specify this option, the command ranks historical traffic by total traffic.
user-ip { ip-address | ipv6-address }: Specifies a user by its IPv4 or IPv6 address. If you do not specify this option, the command displays historical traffic statistics for all users.
top top-number: Displays historical traffic statistics for the top top-number users. The value range for the top-number argument is 10 to 100. If you do not specify this option, the command displays historical traffic statistics for the top 10 users.
This command can help you monitor the traffic sizes of users and applications.
Operating mechanism
This command ranks users or applications in descending order of the traffic size based on the specified conditions.
If the specified application does not exist the start date and time is later than the end date and time, this command does not displays any traffic statistics.
If the collected traffic size is smaller than 0.01 MB, it is displayed as 0.01 MB.
# Display historical traffic statistics for applications.
<Sysname> display ip traffic-statistics history application time 7/28/2022 14:19:03 7/28/2022 14:23:03
AppName Total(MB) Uplink(MB) Downlink(MB) Packet count
test1 1986.88 998.32 988.56 38321
QQ 462.85 198.02 264.82 9451
Genshen 200.22 97.11 103.11 4578
# Display historical traffic statistics for users.
<Sysname> display ip traffic-statistics history user time 7/28/2022 14:19:03 7/28/2022 14:23:03 app QQ
UserIP Total(MB) Uplink(MB) Downlink(MB) Packet count
172.16.0.1 256.37 64.31 192.06 5821
172.16.0.2 128.96 63.45 65.51 2821
172.16.0.3 78.47 34.32 44.16 1651
AppName |
Application name. |
UserIP |
IPv4 or IPv6 address of the user. |
Total |
Total size of the uplink traffic and downlink traffic during the specified time period, up to two decimal places and in MB. If you do not specify a time period, this field displays the size of all historical uplink traffic and downlink traffic. |
Uplink |
Total size of the uplink traffic during the specified time period, up to two decimal places and in MB. If you do not specify a time period, this field displays the size of all historical uplink traffic. |
Downlink |
Total size of the downlink traffic during the specified time period, up to two decimal places and in MB. If you do not specify a time period, this field displays the size of all historical downlink traffic. |
Packet count |
Total number of packets for historical uplink traffic and downlink traffic. |
Use ip traffic-statistics config remove-all to end the IP traffic statistics collection process and delete all data in the IP traffic statistics collection module.
The IP traffic statistics collection module is memory intensive and affect device performance.
Operating mechanism
This command deletes all configuration data and running data in the IP traffic statistics collection module and ends the IP traffic statistics collection process.
# End the IP traffic statistics collection process and delete all data in the IP traffic statistics collection module.
[Sysname] ip traffic-statistics config remove-all
The command will delete all IP traffic statistics settings. Continue? [Y/N]:y
[Sysname]
Use ip traffic-statistics live application enable to enable real-time traffic statistics collection for applications.
Use undo ip traffic-statistics live application enable to disable real-time traffic statistics collection for applications.
Real-time traffic statistics collection is disabled for applications.
Use this command on a gateway device to monitor the traffic rates of applications.
Operating mechanism
This command enables IP the traffic statistics collection module to collect traffic rate statistics during a statistics collection interval. To set the statistics collection interval, use the ip traffic-statistics interval command.
To display real-time traffic statistics for applications, use the display ip traffic-statistics live application.
This feature is memory intensive and degrades device performance. As a best practice, use this feature only when necessary and disable this feature when you do not use it.
# Enable real-time traffic statistics collection for applications.
[Sysname] ip traffic-statistics live application enable
Use ip traffic-statistics interval to set the interval for collecting real-time traffic rate statistics.
Use undo ip traffic-statistics interval to restore the default.
ip traffic-statistics interval interval
The interval for collecting real-time traffic rate statistics is 10 seconds.
interval: Specifies a statistics collection interval in the range 1 to 60 seconds.
The ip traffic-statistics live application enable command enables the device to collect real-time traffic rate statistics for applications during the specified statistics collection interval. You can use the ip traffic-statistics interval command to set a statistics collection interval.
Operating mechanism
This command enables the device to collect traffic rate statistics in real time during a statistics collection interval.
Recommended configuration
If the traffic rates change significantly, set a shorter statistics collection interval as a best practice. Otherwise, set a longer statistics collection interval.
# Set the interval for collecting real-time traffic rate statistics to 20 seconds.
[Sysname] ip traffic-statistics interval 20
Use ip traffic-statistics history enable to enable historical traffic statistics collection.
Use undo ip traffic-statistics history enable to disable historical traffic statistics collection.
Historical traffic statistics collection is disabled.
Use this command on a gateway device to monitor the traffic sizes of users and applications.
Operating mechanism
This command enables the IP traffic statistics collection module to save the collected historical traffic statistics locally. To view historical traffic statistics, use the display ip traffic-statistics history command.
This feature is memory intensive and affects device performance. As a best practice, disable this feature when you do not use it.
# Enable historical traffic statistics collection.
[Sysname] ip traffic-statistics history enable
Use reset ip traffic-statistics history to clear historical traffic statistics.
The ip traffic-statistics history enable enables the IP traffic statistics collection module to save the collected traffic statistics locally, which occupies a large amount of memory. You can use the reset ip traffic-statistics history command to release the occupied memory.
# Clear historical traffic statistics.
<Sysname> reset ip traffic-statistics history
Use reset ip traffic-statistics statistics to clear key operation counters of the IP traffic statistics collection module.
The IP traffic statistics collection feature is memory intensive. You can use this command to release memory.
# Clear key operation counters of the IP traffic statistics collection module.
