- 08-Layer 3—IP Routing Command Reference
- 01-Basic IP routing commands
- 02-Static routing commands
- 03-RIP commands
- 04-OSPF commands
- 05-IS-IS commands
- 06-Basic BGP commands
- 07-Advanced BGP commands
- 08-Policy-based routing commands
- 09-IPv6 static routing commands
- 10-RIPng commands
- 11-OSPFv3 commands
- 12-IPv6 policy-based routing commands
- 13-Routing policy commands
- 14-RIR commands
| 01-Basic IP routing commands | 837.75 KB |
display ip routing-table ip-address
display ip routing-table prefix-list
display ip routing-table protocol
display ip routing-table record
display ip routing-table statistics
display ip routing-table summary
display ipv6 routing-table acl
display ipv6 routing-table ipv6-address
display ipv6 routing-table prefix-list
display ipv6 routing-table protocol
display ipv6 routing-table record
display ipv6 routing-table statistics
display ipv6 routing-table summary
ip load-sharing symmetric enable
ipv6 route fast-switchover enable
nexthop recursive-lookup restrain clear-interval
nexthop recursive-lookup restrain disable
protocol nexthop recursive-lookup
reset ip routing-table statistics protocol
reset ipv6 routing-table record
reset ipv6 routing-table statistics protocol
snmp-agent trap enable ipv6 rib
address-family ipv4
Use address-family ipv4 to create the RIB IPv4 address family and enter its view, or enter the view of the existing RIB IPv4 address family.
Use undo address-family ipv4 to delete the RIB IPv4 address family and all configurations in the view.
address-family ipv4
No RIB IPv4 address family exists.
RIB view
# Create the RIB IPv4 address family and enter its view.
[Sysname] rib
[Sysname-rib] address-family ipv4
[Sysname-rib-ipv4]
address-family ipv6
Use address-family ipv6 to create the RIB IPv6 address family and enter its view, or enter the view of the existing RIB IPv6 address family.
Use undo address-family ipv6 to delete the RIB IPv6 address family and all configurations in the view.
address-family ipv6
No RIB IPv6 address family exists.
RIB view
# Create the RIB IPv6 address family and enter its view.
[Sysname] rib
[Sysname-rib] address-family ipv6
[Sysname-rib-ipv6]
bandwidth-based-sharing
Use bandwidth-based-sharing to enable IPv4 load sharing based on bandwidth.
Use undo bandwidth-based-sharing to disable IPv4 load sharing based on bandwidth.
The IPv4 load sharing based on bandwidth is disabled.
This feature load shares flow traffic among multiple output interfaces based on their load percentages. The device calculates the load percentage for each output interface in terms of their expected bandwidths.
Devices that run load sharing protocols implement load sharing based on the ratios defined by these protocols.
# Enable IPv4 load sharing based on bandwidth.
[Sysname] bandwidth-based-sharing
display ecmp mode
Use display ecmp mode to display the IPv4 and IPv6 ECMP mode.
display ecmp mode
# Display the IPv4 and IPv6 ECMP mode.
<Sysname> display ecmp mode
ECMP-Mode in use: Default
ECMP-Mode at the next reboot: Enhanced
ECMP-Mode in use |
The current ECMP mode: · Default—Normal mode. · Enhanced—Enhanced mode. |
ECMP-Mode at the next reboot |
ECMP mode used at the next startup: · Default—Normal mode. · Enhanced—Enhanced mode. |
ecmp mode enhanced
display ip load-sharing mode
Use display ip load-sharing mode to display the load sharing mode in use.
display ip load-sharing mode slot slot-number
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the load sharing mode for all cards.
# Display the load sharing mode in use.
<Sysname> display ip load-sharing mode slot 1
Load-sharing mode: per-flow
Load-sharing options: dest-ip | src-ip | ip-pro | dest-port | src-port | ingress-port
Load-sharing algorithm: 0
IP tunnel load-sharing mode: outer
Load-sharing algorithm: 1
Load-sharing algorithm: 2
Load-sharing mode |
The load sharing mode in use: · per-flow—Per-flow load sharing. · per-packet—Per-packet load sharing. |
Load-sharing options |
Options configured for load sharing: · dest-ip—Identifies flows by destination IP address. · src-ip—Identifies flows by source IP address. · ip-pro—Identifies flows by IP protocol. · dest-port—Identifies flows by destination port number. · src-port—Identifies flows by source port number. · ingress-port—Identifies flows by ingress port. · flow-label—Identifies flows by IPv6 flow label. |
Load-sharing algorithm |
Algorithm used by load sharing. |
display ip load-sharing path
Use display ip load-sharing path to display the load sharing path selected for a flow.
display ip load-sharing path ingress-port interface-type interface-number packet-format { ipv4oe dest-ip ip-address [ src-ip ip-address ] | ipv6oe dest-ipv6 ipv6-address [ flow-label flow-label | src-ipv6 ipv6-address ] * } [ dest-port port-id | ip-pro protocol-id | src-port port-id | vpn-instance vpn-instance-name ] *
ingress-port interface-type interface-number: Specifies an ingress port by its type and number.
packet-format { ipv4oe dest-ip ip-address [src-ip ip-address ] | ipv6oe dest-ipv6 ipv6-address [ src-ipv6 ipv6-address ] }: Specifies the packet encapsulation format.
ipv4oe: Specifies the format of IPv4 over Ethernet.
dest-ip ip-address: Specifies the destination IPv4 address in dotted decimal notation. If you do not specify this argument, the calculation uses 0.0.0.0 for path selection.
src-ip ip-address: Specifies the source IPv4 address in dotted decimal notation. If you do not specify this argument, the calculation uses 0.0.0.0 for path selection.
ipv6oe: Specifies the format of IPv6 over Ethernet.
dest-ipv6 ipv6-address: Specifies the destination IPv6 address. If you do not specify this option, the calculation uses 0:0:0:0:0:0:0:0 for path selection.
flow-label flow-label: Specifies the flow label of IPv6 packets. The value range for the flow-label argument is 0 to 1048575. If you do not this option, the calculation uses 0 for path selection.
src-ipv6 ipv6-address: Specifies the source IPv6 address. If you do not specify this option, the calculation uses 0:0:0:0:0:0:0:0 for path selection.
dest-port port-id: Specifies a destination port number in the range of 1 to 65535. If you do not specify this option, the calculation uses 0 for path selection.
ip-pro protocol-id: Specifies an IP protocol by its number in the range of 1 to 65535. If you do not specify this option, the calculation uses 0 for path selection.
source-port port-id: Specifies a source port number in the range of 1 to 65535. If you do not specify this option, the calculation uses 0 for path selection.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To display the path on the public network, do not specify this option.
The option settings in this command must match both the options displayed in the display ip load-sharing mode command and the field values in load shared packets. If the option settings do not meet the requirement, the path displayed by this command might be different from the real path for load sharing.
# Display the load sharing path selected for the flow with the following attributes: ingress port GigabitEthernet 1/0/3, destination IP address 10.110.0.2, source IP address 10.100.0.2, IP protocol number 153, destination port number 2000, source port number 2000.
<Sysname> display ip load-sharing path ingress-port gigabitethernet 1/0/3 packet-format ipv4oe dest-ip 10.110.0.2 src-ip 10.100.0.2 ip-pro 153 dest-port 2000 src-port 2000
Load-sharing parameters:
Missing configured are set to 0.
ingress-port: GigabitEthernet1/0/3
packet-format: IPv4oE
dest-ip: 10.110.0.2
src-ip: 10.100.0.2
ip-pro: 153
dest-port: 2000
src-port: 2000
Path selected: 20.0.0.2(interface GigabitEthernet1/0/3)
Load sharing algorithm ID. |
Load sharing options specified by the ip load-sharing mode command. |
Load-sharing parameters |
Load sharing parameters that you specify for the display ip load-sharing path command. |
Missing configured are set to 0. |
Values of the unconfigured parameters are set to 0. |
ingress-port |
Ingress port of the packet. |
packet-format |
Packet encapsulation format. |
dest-ip |
Destination IP address of the packet. |
src-ip |
Source IP address of the packet. |
ip-pro |
IP protocol number. |
dest-port |
Destination port number. |
src-port |
Source port number. |
flow-label |
Flow label of IPv6 packets. |
Path selected |
Selected path information, including the IPv4 or IPv6 address of the next hop and the egress port. |
Use display ip routing-table to display routing table information.
display ip routing-table [ all-vpn-instance | vpn-instance vpn-instance-name ] [ verbose ]
display ip routing-table all-routes
all-vpn-instance: Specifies all VPN instances.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays routing table information for the public network.
all-routes: Displays routing table information for the public network and all VPN instances.
verbose: Displays detailed routing table information, including information about both active and inactive routes. If you do not specify this keyword, the command displays only brief information about active routes.
# Display brief information about active routes in the routing table.
<Sysname> display ip routing-table
Destinations : 10 Routes : 10
0.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
1.1.1.0/24 Static 60 0 192.168.47.4 GE1/0/1
Static 60 0 192.168.47.4 GE1/0/2
127.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
127.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
192.168.1.40/32 Direct 0 0 127.0.0.1 InLoop0
224.0.0.0/4 Direct 0 0 0.0.0.0 NULL0
224.0.0.0/24 Direct 0 0 0.0.0.0 NULL0
255.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
# Display brief information about active routes in the routing table for the public network and all VPN instances.
<Sysname> display ip routing-table all-routes
VPN instance: public instance
VPN instance: vpn1
1.1.2.0/24 Static 60 0 2.2.1.1 GE1/0/1
3.3.1.0/24 BGP 255 0 55.1.1.2 GE1/0/2
# Display information about IPv4 routes for all VPN instances.
<Sysname> display ip routing-table all-vpn-instance
VPN instance: vpn1
VPN instance: vpn2
Destinations : 9 Routes : 9
1.1.3.0/24 Static 60 0 3.3.1.1 GE1/0/1
Destinations |
Number of destination addresses. |
Routes |
Number of routes. |
Destination/Mask |
Destination address/mask length. |
Proto |
Route type or protocol that installed the route: · Direct—Direct route. · Static—Static route. · RIP—RIP route. · OSPF—OSPF route. · ISIS—IS-IS route. · EIGRP—EIGRP route. · BGP—BGP route. · OpenR—Open Routing (OpenR) route. · LDP—LDP route. · SLSP—Static LSP. · PIM—PIM route. · MSTATIC—Multicast static route. · O_INTRA—OSPF intra-area route. · O_INTER—OSPF inter-area route. · O_ASE1—OSPF Type-1 external route. · O_ASE2—OSPF Type-2 external route. · O_SUM—OSPF summary route. · IS_L1—IS-IS Level-1 route. · IS_L2—IS-IS Level-2 route. · IS_SUM—IS-IS summary route. |
Pre |
Preference of the route. |
Cost |
Cost of the route. |
NextHop |
Next hop address of the route. |
Output interface for packets to be forwarded along the route. |
Summary count |
Number of routes. |
# Display detailed information about all routes in the routing table.
<Sysname> display ip routing-table verbose
Destinations : 13 Routes : 13
Destination: 0.0.0.0/32
Protocol: Direct
Process ID: 0
SubProtID: 0x0 Age: 08h34m37s
Cost: 0 Preference: 0
IpPre: N/A QosLocalID: N/A
Tag: 0 State: Active NoAdv
TableID: 0x2 OrigAs: 0
NibID: 0x10000000 LastAs: 0
AttrID: 0xffffffff Neighbor: 0.0.0.0
Flags: 0x1000c OrigNextHop: 127.0.0.1
Label: NULL RealNextHop: 127.0.0.1
BkLabel: NULL BkNextHop: N/A
SRLabel: NULL Interface: InLoopBack0
BkSRLabel: NULL BkInterface: N/A
Tunnel ID: Invalid IPInterface: InLoopBack0
BkTunnel ID: Invalid BKIPInterface: N/A
InLabel: NULL ColorInterface: N/A
SIDIndex: NULL BKColorInterface: N/A
FtnIndex: 0x0 TunnelInterface: N/A
TrafficIndex: N/A BKTunnelInterface: N/A
Connector: N/A PathID: 0x0
SRTunnelID: Invalid
SID Type: N/A NID: Invalid
FlushNID: Invalid BkNID: Invalid
BkFlushNID: Invalid StatFlags: 0x0
Exp: N/A
VpnPeerId: N/A Dscp: N/A
SID: N/A OrigLinkID: 0x0
BkSID: N/A RealLinkID: 0x0
CommBlockLen: 0
Destination: 1.1.1.0/24
Protocol: Static
Process ID: 0
SubProtID: 0x0 Age: 04h20m37s
Cost: 0 Preference: 60
Tag: 0 State: Active Adv
NibID: 0x10000003 LastAs: 0
Flags: 0x1008c OrigNextHop: 192.168.47.4
Label: NULL RealNextHop: 192.168.47.4
SRLabel: NULL Interface: GigabitEthernet1/0/1
Tunnel ID: Invalid IPInterface: GigabitEthernet1/0/1
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
Destination: 1.2.3.4/32
Protocol: BGP instance default
Process ID: 0
SubProtID: 0x1 Age: 02h38m34s
Cost: 0 Preference: 255
TableID: 0x2 OrigAs: 200
NibID: 0x16000000 LastAs: 200
AttrID: 0x2 Neighbor: 2.2.3.4
Flags: 0x10060 OrigNextHop: 2.2.3.4
Label: NULL RealNextHop: 2.2.3.4
SRLabel: NULL Interface: GigabitEthernet1/0/3
Tunnel ID: Invalid IPInterface: GigabitEthernet1/0/3
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
# Display detailed information about all routes in the routing table for all VPN instances.
<Sysname> display ip routing-table all-vpn-instance verbose
VPN instance: vpn1
Destinations : 1 Routes : 1
Protocol: Direct
Process ID: 0
OrigTblID: 0x0 OrigVrf: vpn1
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
VPN instance: vpn2
Protocol: Static
Process ID: 0
OrigTblID: 0x0 OrigVrf: vpn2
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
Destinations |
Routes |
Number of routes. |
Destination |
Protocol |
SubProtID |
ID of the subprotocol for routing. |
Age |
Time for which the route has been in the routing table. |
Cost |
Preference |
IpPre |
IP precedence. |
QosLocalID |
Local QoS ID. N/A represents an invalid value. |
Tag |
Route tag. |
State |
Route status: · Active—Active unicast route. · Adv—Route that can be advertised. · Inactive—Inactive route. · NoAdv—Route that the router must not advertise. · Vrrp—Routes generated by VRRP. · Nat—Routes generated by NAT. · TunE—Tunnel. · Derived—Derived route. If a route recurses to multiple related routes, all related routes except the first one are derived routes. The number of derived routes is not included in the total number of routes. · Backup—Backup route. |
OrigTblID |
Original routing table ID. |
OrigVrf |
Original VPN instance to which the route belongs. This field displays default-vrf if the route is on the public network. |
TableID |
ID of the routing table. |
OrigAs |
Original AS number. |
NibID |
ID of the next hop. |
LastAs |
Last AS number. |
AttrID |
Attribute ID. |
Neighbor |
Address of the neighbor determined by the routing protocol. |
Flags |
Flags of the route. |
OrigNextHop |
Label |
Label. |
RealNextHop |
Real next hop of the route. |
BkLabel |
Backup label. |
BkNexthop |
Backup next hop. |
SRLabel |
This field is not supported in the current software version. Segment routing (SR) label. |
BkSRLabel |
This field is not supported in the current software version. Backup SR label. |
SIDIndex |
This field is not supported in the current software version. SID index value. |
InLabel |
Incoming label of the route. |
Tunnel ID |
Tunnel ID. |
BkTunnel ID |
Backup tunnel ID. An ellipsis (…) in this field indicates that multiple backup tunnels exist and only the first backup tunnel takes effect. |
BkInterface |
Backup output interface. An ellipsis (…) in this field indicates that multiple backup output interfaces exist and only the first backup output interface takes effect. |
IPInterface |
IP output interface. |
BkIPInterface |
Backup IP output interface. |
ColorInterface |
This field is not supported in the current software version. Color output interface obtained through SR-MPLS TE policy-based or SRv6 TE policy-based recursion. |
BkColorInterface |
Backup color output interface. |
FtnIndex |
Index of the FTN entry. |
TunnelInterface |
Tunnel output interface. |
TrafficIndex |
Traffic index in the range of 1 to 64. This field displays N/A when the value is invalid. |
BkTunnelInterface |
Backup tunnel output interface. |
Connector |
BGP connector attribute exchanged between BGP peers along with a VPN IPv4 route. The value of the attribute is the IP address of the remote PE device. The BGP connector attribute is used for MD VPN. This field displays N/A if the BGP connector attribute is not supported. |
Summary count |
Number of routes. |
PathID |
Path ID. |
SRTunnelID |
This field is not supported in the current software version. SR tunnel ID. |
SID Type |
This field is not supported in the current software version. SID type. If the route does not have an SID, this field displays N/A. |
NID |
Index of the Next Hop Label Forwarding Entry (NHLFE) issued by the routing protocol. |
FlushNID |
Actual NHLFE index issued to the FIB. |
BkNID |
Backup NHLFE index issued by the routing protocol. |
BkFlushNID |
Actual backup NHLFE index issued to the FIB. |
StatFlags |
This field is not supported in the current software version. Flags for SRv6 traffic statistics. |
VpnPeerId |
ID of the VPN peer to which the route belongs, in the range of 1 to 134217727. This field displays N/A when the value is invalid. |
Dscp |
DSCP value of the route, in the range of 0 to 63. This field displays N/A when the value is invalid. |
Exp |
MPLS EXP value of the route, which is supported only by BGP. This field displays N/A when the value is invalid. |
SID |
This field is not supported in the current software version. Primary SID. N/A indicates that the attribute is not available. |
BkSID |
This field is not supported in the current software version. Backup SID. N/A indicates that the attribute is not available. |
CommBlockLen |
This field is not supported in the current software version. Common prefix length in the locator. |
OrigLinkID |
Original link ID of the SDWAN TTE connection. |
RealLinkID |
Real link ID of the SDWAN TTE connection. |
display ip routing-table acl
Use display ip routing-table acl to display information about routes permitted by a basic ACL.
display ip routing-table [ vpn-instance vpn-instance-name ] acl ipv4-acl-number [ verbose ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays routing information for the public network.
ipv4-acl-number: Specifies a basic ACL by its number in the range of 2000 to 2999.
verbose: Displays detailed information about all routes permitted by the basic ACL. If you do not specify this keyword, the command displays only brief information about active routes permitted by the basic ACL.
If the specified ACL does not exist or has no rules configured, the command displays information about all routes.
If a rule in the specified ACL has the VPN instance match criterion configured, the rule will not take effect.
# Define basic ACL 2000 and set the route filtering rules.
[Sysname] acl basic 2000
[Sysname-acl-ipv4-basic-2000] rule permit source 192.168.1.0 0.0.0.255
[Sysname-acl-ipv4-basic-2000] rule deny source any
# Display brief information about active routes permitted by basic ACL 2000.
[Sysname-acl-ipv4-basic-2000] display ip routing-table acl 2000
Summary count : 4
192.168.1.0/24 Direct 0 0 192.168.1.111 GE1/0/1
192.168.1.0/32 Direct 0 0 192.168.1.111 GE1/0/1
192.168.1.111/32 Direct 0 0 127.0.0.1 InLoop0
192.168.1.255/32 Direct 0 0 192.168.1.111 GE1/0/1
For command output, see Table 4.
# Display detailed information about all routes permitted by basic ACL 2000.
<Sysname> display ip routing-table acl 2000 verbose
Summary count : 4
Destination: 192.168.1.0/24
Protocol: Direct
Process ID: 0
SubProtID: 0x1 Age: 04h20m37s
Flags: 0x10080 OrigNextHop: 192.168.1.111
Label: NULL RealNextHop: 192.168.1.111
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
Destination: 192.168.1.111/32
Protocol: Direct
Process ID: 0
Flags: 0x10004 OrigNextHop: 127.0.0.1
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
Destination: 192.168.1.255/32
Protocol: Direct
Process ID: 0
Flags: 0x1008c OrigNextHop: 192.168.1.111
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
For command output, see Table 5.
Use display ip routing-table ip-address to display information about routes to a specific destination address.
Use display ip routing-table ip-address1 to ip-address2 to display information about routes to a range of destination addresses.
display ip routing-table [ vpn-instance vpn-instance-name ] ip-address [ mask-length | mask ] [ longer-match ] [ verbose ]
display ip routing-table [ vpn-instance vpn-instance-name ] ip-address1 to ip-address2 [ verbose ]
ip-address: Specifies a destination IP address in dotted decimal notation.
mask-length: Specifies the mask length, an integer in the range of 0 to 32.
mask: Specifies the IP address mask in dotted decimal notation.
longer-match: Displays the route entries that meet the matching rules as described in the usage guidelines.
ip-address1 to ip-address2: Specifies a destination IP address range.
verbose: Displays detailed routing table information, including information about both active and inactive routes. If you do not specify this keyword, the command displays brief information about active routes.
Executing the command with different parameters yields different outputs.
· display ip routing-table ip-address
¡ The system ANDs the entered destination IP address with the subnet mask in each active route entry.
¡ The system ANDs the destination IP address in each active route entry with its own subnet mask.
If the two operations yield the same result for an entry, the entry is displayed.
· display ip routing-table ip-address mask
¡ The system ANDs the entered destination IP address with the entered subnet mask.
¡ The system ANDs the destination IP address in each active route entry with the entered subnet mask.
If the two operations yield the same result for an entry with a subnet mask not greater than the entered subnet mask, the entry is displayed.
· display ip routing-table ip-address longer-match
¡ The system ANDs the entered destination IP address with the subnet mask in the following way:
- If the entered IP address belongs to class A, B, or C, the system ANDs it with the default subnet mask of the corresponding class.
- If the entered IP address is 0.0.0.0, the system ANDs it with the subnet mask 0.0.0.0.
- Except the previous cases, for example, if the entered IP address is a multicast address or loopback address, the system ANDs it with the subnet mask 255.255.255.255.
¡ The system ANDs the destination IP address in each active route entry with the subnet mask of the entered IP address.
If the two operations yield the same result for multiple entries, all the entries are displayed.
· display ip routing-table ip-address mask longer-match
· display ip routing-table ip-address1 to ip-address2
The system displays active route entries with destinations in the range of ip-address1/32 to ip-address2/32.
# Display brief information about the routes to the destination IP address 11.0.0.1.
<Sysname> display ip routing-table 11.0.0.1
Summary count : 3
11.0.0.0/8 Static 60 0 0.0.0.0 NULL0
11.0.0.0/16 Static 60 0 0.0.0.0 NULL0
11.0.0.0/24 Static 60 0 0.0.0.0 NULL0
# Display brief information about the routes to the destination IP address 11.0.0.1 with mask length 20.
<Sysname> display ip routing-table 11.0.0.1 20
Summary count : 2
# Display brief information about the routes to the destination IP address 11.0.0.1 with the default mask length for class A networks.
<Sysname> display ip routing-table 11.0.0.1 longer-match
Summary count : 3
<Sysname> display ip routing-table 11.0.0.1 20 longer-match
Summary count : 3
# Display brief information about the routes to destination addresses in the range of 1.1.1.0 to 5.5.5.0.
<Sysname> display ip routing-table 1.1.1.0 to 5.5.5.0
Summary count : 5
1.1.1.1/32 Direct 0 0 127.0.0.1 InLoop0
3.3.3.0/24 Direct 0 0 3.3.3.1 GE1/0/2
3.3.3.1/32 Direct 0 0 127.0.0.1 InLoop0
4.4.4.0/24 Direct 0 0 4.4.4.1 GE1/0/1
4.4.4.1/32 Direct 0 0 127.0.0.1 InLoop0
# Display detailed information about the routes to the destination IP address 1.2.3.4.
<Sysname> display ip routing-table 1.2.3.4 verbose
Summary count : 1
Protocol: Static
Process ID: 0
SubProtID: 0x1 Age: 00h00m37s
NibID: 0x15000000 LastAs: 0
AttrID: 0x0 Neighbor: 0.0.0.0
Flags: 0x10060 OrigNextHop: 192.168.47.2
Label: NULL RealNextHop: 192.168.47.2
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
Use display ip routing-table prefix-list to display routes permitted by an IP prefix list.
display ip routing-table [ vpn-instance vpn-instance-name ] prefix-list prefix-list-name [ verbose ]
prefix-list-name: Specifies an IP prefix list by its name, a case-sensitive string of 1 to 63 characters.
verbose: Displays detailed information about all routes permitted by the IP prefix list. If you do not specify this keyword, the command displays brief information about active routes permitted by the IP prefix list.
If the specified IP prefix list does not exist, the command displays information about all routes.
# Create an IP prefix list named test to permit the route 1.1.1.0/24.
[Sysname] ip prefix-list test permit 1.1.1.0 24
# Display brief information about the active route permitted by the IP prefix list.
[Sysname] display ip routing-table prefix-list test
Summary count : 1
1.1.1.0/24 Direct 0 0 1.1.1.2 GE1/0/2
# Display detailed information about all routes permitted by the IP prefix list.
[Sysname] display ip routing-table prefix-list test verbose
Summary count : 1
Protocol: Direct
Process ID: 0
Flags: 0x1008c OrigNextHop: 1.1.1.2
Label: NULL RealNextHop: 1.1.1.2
SRLabel: NULL Interface: GigabitEthernet1/0/2
Tunnel ID: Invalid IPInterface: GigabitEthernet1/0/2
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
Use display ip routing-table protocol to display information about routes installed by a protocol.
display ip routing-table [ vpn-instance vpn-instance-name ] protocol protocol [ inactive | verbose ]
protocol: Specifies a routing protocol.
inactive: Displays information about inactive routes. If you do not specify this keyword, the command displays information about both active and inactive routes.
verbose: Displays detailed routing table information. If you do not specify this keyword, the command displays brief routing information.
# Display brief information about direct routes.
<Sysname> display ip routing-table protocol direct
Summary count : 9
Direct Routing table status : <Active>
Summary count : 9
192.168.80.0/24 Direct 0 0 192.168.80.10 GE1/0/1
192.168.80.0/32 Direct 0 0 192.168.80.10 GE1/0/1
192.168.80.10/32 Direct 0 0 127.0.0.1 InLoop0
192.168.80.255/32 Direct 0 0 192.168.80.10 GE1/0/1
Direct Routing table status : <Inactive>
Summary count : 0
# Display brief information about static routes.
<Sysname> display ip routing-table protocol static
Summary count : 1
Static Routing table status : <Active>
Summary count : 0
Static Routing table status : <Inactive>
Summary count : 1
3.0.0.0/8 Static 60 0 2.2.2.2 GE1/0/1
# Display brief information about OpenR routes.
<Sysname> display ip routing-table protocol openr
Summary count : 1
OpenR Routing table status : <Active>
Summary count : 1
192.11.3.0/24 OpenR 30 0 12.13.3.12 GE1/0/1
Summary count : 0
# Display detailed information about BGP routes.
<Sysname> display ip routing-table protocol bgp verbose
Summary count : 1
Destination: 1.1.1.2/32
Process ID: 0
SubProtID: 0x6 Age: 00h03m54s
AttrID: 0x0 Neighbor: 192.168.47.2
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
# Display detailed information about OpenR routes.
<Sysname> display ip routing-table protocol openr verbose
Summary count : 1
Destination: 192.11.3.0/24
Protocol: OpenR
Process ID: 0
SubProtID: 0xfe Age: 01h13m48s
Cost: 0 Preference: 30
NibID: 0x19000000 LastAs: 0
Flags: 0x10040 OrigNextHop: 12.13.3.12
Label: NULL RealNextHop: 12.13.3.12
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
Use display ip routing-table record to display IPv4 route entry records.
display ip routing-table record flush [ delete | update ] [ verbose ]
display ip routing-table record notify [ delete | update ] [ verbose ]
display ip routing-table record receive [ add | delete | update ] [ verbose ]
flush: Displays the records for the route entries issued by the RIB to the FIB.
notify: Displays the records for the route entries notified by the RIB to the routing protocol.
receive: Displays the records for the route entries received by the RIB from the routing protocol.
add: Displays the records for the added route entries.
delete: Displays the records for the deleted route entries.
update: Displays the records for the updated route entries. If you specify the flush or notify keyword, the system takes added route entries as updated route entries when displaying the associated records.
verbose: Displays detailed information about IPv4 route entry records. If you do not specify this keyword, the command displays only brief information about IPv4 route entry records.
If you do not specify the add, delete, or update keyword, the command displays records for the added, deleted, and updated route entries.
When the system enters the level-1 memory threshold alarm status, it stops recording new route entry information. When the system enters the level-3 memory threshold alarm status, it clears existing route entry records. When the system exits the level-1 memory threshold alarm status, it starts recording new route entry information again.
# Display brief information about the records for the route entries issued by the RIB to the FIB.
<Sysname> display ip routing-table record flush
Total number of records: 2
Date Time Action Destination/Mask/VNID/Vrf
210907 15:38:50:961 update 200.0.0.0/24/0x111000000/default-vrf
210907 15:40:13:331 delete 200.0.0.0/24/0x0/default-vrf
Total number of records |
Total number of route entry records. |
Date |
Date when a record was generated. |
Time |
Time when the record was generated. |
Action |
Action on the route entry in the record: · update. · delete. |
Destination |
Destination address. |
Mask |
Mask length. |
VNID |
VN entry ID. |
Vrf |
Name of the VPN instance to which the route belongs. If the route belongs to the public network, this field displays default-vrf. |
# Display detailed information about the records for the updated route entries issued by the RIB to the FIB.
<Sysname> display ip routing-table record flush update verbose
Total number of records: 1
Limit of records: 1000
Time: 210907 15:38:50:961 Action: update
Destination: 200.0.0.0/24
VrfIndex: 0 VrfName: default-vrf
SrcVrfIndex: 0 PriNibID: 0x0
OrigAs: 0 LastAs: 0
VNID: 0x111000000 AttrId: 0xffffffff
Flags: 0x10020000 ExtFlags: 0x0
Label: 0xffffffff BkLabel: 0xffffffff
LabelType: None InstanceId: 0
IpPrecedence: 65535 QosLocalId: 65535
TrafficIndex: 65535 UserID: 0x0
Limit of records |
Maximum number of route entry records. |
Time |
Date and time when a record was generated. |
Action |
Destination |
Destination address and mask length. |
VrfIndex |
VPN instance index. |
VrfName |
SrcVrfIndex |
Index of the source VPN instance for the copied route. |
PriNibID |
This field is not supported in the current software version. SRv6 forwarding entry index. |
OrigAs |
LastAs |
Last AS number. |
VNID |
VN entry ID. |
AttrId |
Route attribute ID. |
Flags |
ExtFlags |
Extended flags of the route. |
Label |
Label. |
BkLabel |
Backup label. |
LabelType |
Protocol generated the labels. Values include: · None—No label. · BGP—BGP protocol. · LDP—LDP protocol. · SLSP—SLSP protocol. · OSPF—OSPF protocol. · ISIS—IS-IS protocol. · UNR—User network route. · Unknown—Unknown protocol. |
InstanceId |
ID of the multi-instance process. |
IpPre |
IP preference. |
QosLocalID |
Local QoS ID. |
TrafficIndex |
Traffic index. This field displays N/A when the value is invalid. |
UserID |
Access user ID. |
SID Type |
This field is not supported in the current software version. SID type. |
VsiIndex |
This field is not supported in the current software version. Index of the VSI to which the EVPN SRv6 SID belongs. |
LinkId |
This field is not supported in the current software version. Link ID of the L2VPN End.DX2 SID. |
ArgLen |
Arguments field length. |
# Display brief information about the records for the route entries notified by the RIB to the routing protocol.
<Sysname> display ip routing-table record notify
Total number of records: 3
Date Time Action Destination/Mask/NibID/Vrf
210907 15:38:50:961 update 200.0.0.0/24/0x11000000/default-vrf
210907 15:39:46:496 update 200.0.0.0/24/0x11000000/default-vrf
210907 15:39:51:825 update 200.0.0.0/24/0x11000000/default-vrf
Date |
Time |
Action |
Destination |
Mask |
Mask length. |
NibID |
Vrf |
# Display detailed information about the records for the deleted route entries notified by the RIB to the routing protocol.
<Sysname> display ip routing-table record notify delete verbose
Time: 210908 09:22:11:460 Action: delete
Destination: 200.0.0.0/8
TableID: 0x2 NibID: 0x0
ActCnt: 0 InactNibID: 0x0
OldProtocol: STATIC NewProtocol: UnSpec
Flags: 0xc00 ExtFlags: 0x22
Limit of records |
Time |
Action |
Action on the route entry in the record: · add. · update. · delete. |
Destination |
TableID |
ID of the routing table for the route. |
NibID |
Next hop ID. |
ActCnt |
Number of active routes using the route prefix. |
InactNibID |
Next hop ID of the inactive route reported to MPLS. |
VrfIndex |
VrfName |
OldProtocol |
Routing protocol reported by the route the previous time. |
NewProtocol |
Routing protocol reported by the route the current time. |
Flags |
ExtFlags |
# Display brief information about the records for the route entries received by the RIB from the routing protocol.
<Sysname> display ip routing-table record receive
Date Time Action Proto Destination/Mask/NibID/Vrf
210907 15:38:50:957 add STATIC 200.0.0.0/24/0x11000000/default-vrf
210907 15:39:51:825 update STATIC 200.0.0.0/24/0x11000000/default-vrf
210907 15:40:13:329 delete STATIC 200.0.0.0/24/0x11000000/default-vrf
Date |
Time |
Action |
Action on the route entry: · add. · update. · delete. |
Protocol |
Routing protocol discovered the route. |
Destination |
Mask |
Mask length. |
PrefixLength |
IPv6 address prefix length. |
NibID |
Vrf |
# Display detailed information about the records for the added route entries received by the RIB from the routing protocol.
<Sysname> display ip routing-table record receive add verbose
Time: 210907 15:38:50:957 Action: add
TableID: 0x2 ProcessID: 0
Protocol: STATIC SubProtID: 0x1
ModFlags: 0x0
NibID: 0x11000000 NewNibID: N/A
AttrID: 0xffffffff BkAttrID: 0xffffffff
Flags: 0x60 ExtFlags: 0x0
ResetFlags: 0x0 ResetExtFlags: 0x0
SRLabel: 0xffffffff BkSRLabel: 0xffffffff
InLabel: 0xffffffff SIDIndex: 0xffffffff
CommID: 0x8000000 Tag: 0
UserID: 0x0 SID Type: N/A
SID: N/A
BkSID: N/A
Limit of records |
Time |
Action |
Destination |
TableID |
Routing table ID of the route entry. |
ProcessID |
Process ID. |
VrfIndex |
VrfName |
Protocol |
SubProtID |
Routing subprotocol ID. |
NibID |
Next hop ID. |
NewNibID |
ID of the updated next hop. This field displays N/A if the attribute is not available. |
AttrID |
BkAttrID |
Attribute ID for the backup route. This field displays the attribute ID for only the backup route added to the IP routing table through BGP. |
Flags |
ExtFlags |
ResetFlags |
Reset flags of the route upon an update. This field displays 1 if any bit in the Flags field is changed. |
ResetExtFlags |
Reset extended flags of the route upon an update. This field displays 1 if any bit in the ExtFlags field is changed. |
ModFlags |
Modified flags of the route. |
Label |
Label. |
BkLabel |
Backup label. |
SRLabel |
This field is not supported in the current software version. SR label. |
BkSRLabel |
InLabel |
SIDIndex |
CommID |
Common informatin entry ID of the route. |
Tag |
Route tag. |
Cost |
Preference |
IpPre |
IP precedence. |
QosLocalID |
Local QoS ID. |
Connector |
BGP Connector attribute. This field displays N/A if the attribute is not available. In inter-AS option B MDT-based MVPN, the value for this field is the source PE address carried in the VPN IPv4 route exchanged between BGP peers. For more information about the BGP connector attribute, see multicast VPN in IP Multicast Configuration Guide. |
PathID |
Path ID. |
UserID |
Access user ID. |
SID Type |
SID |
Primary SID. If no primary SID is available, this field displays N/A. |
BkSID |
Backup SID. If no backup SID is available, this field displays N/A. |
Use display ip routing-table statistics to display IPv4 route or route prefix statistics.
display ip routing-table [ all-routes | all-vpn-instance | vpn-instance vpn-instance-name ] [ prefix ] statistics
all-routes: Specifies the public network and all VPN instances.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays IPv4 route statistics for the public network.
prefix: Displays statistics about IPv4 route prefixes. If you do not specify this keyword, the command displays statistics about IPv4 routes.
If you do not specify any parameters, this command displays statistics about IPv4 routes in the public network.
# Display IPv4 route statistics for the public network.
<Sysname> display ip routing-table statistics
Total prefixes: 15 Active prefixes: 15
Proto Routes Active Added Deleted
DIRECT 12 12 30 18
STATIC 3 3 5 2
UNR 0 0 0 0
RIP 0 0 0 0
OSPF 0 0 0 0
IS-IS 0 0 0 0
LISP 0 0 0 0
EIGRP 0 0 0 0
BGP 0 0 0 0
OpenR 0 0 0 0
Total 15 15 35 20
# Display IPv4 route statistics for the public network and all VPN instances.
<Sysname> display ip routing-table all-routes statistics
Total prefixes: 11 Active prefixes: 11
DIRECT 8 8 8 0
STATIC 3 3 5 2
UNR 0 0 0 0
RIP 0 0 0 0
OSPF 0 0 0 0
IS-IS 0 0 0 0
LISP 0 0 0 0
EIGRP 0 0 0 0
BGP 0 0 0 0
OpenR 0 0 0 0
Total 11 11 13 2
# Display IPv4 route statistics for VPN instance vpn1.
<Sysname> display ip routing-table vpn-instance vpn1 statistics
DIRECT 8 8 8 0
STATIC 3 3 5 2
UNR 0 0 0 0
RIP 0 0 0 0
OSPF 0 0 0 0
IS-IS 0 0 0 0
LISP 0 0 0 0
EIGRP 0 0 0 0
BGP 0 0 0 0
OpenR 0 0 0 0
Total 11 11 13 2
# Display IPv4 route statistics for all VPN instances.
<Sysname> display ip routing-table all-vpn-instance statistics
DIRECT 8 8 8 0
STATIC 3 3 5 2
UNR 0 0 0 0
RIP 0 0 0 0
OSPF 0 0 0 0
IS-IS 0 0 0 0
LISP 0 0 0 0
EIGRP 0 0 0 0
BGP 0 0 0 0
OpenR 0 0 0 0
Total 11 11 13 2
# Display IPv4 route prefix statistics for the public network.
<Sysname> display ip routing-table prefix statistics
Proto Prefixes Active Added Deleted
DIRECT 7 7 7 0
STATIC 0 0 0 0
UNR 0 0 0 0
RIP 1 0 1 0
OSPF 0 0 0 0
IS-IS 0 0 0 0
LISP 0 0 0 0
EIGRP 0 0 0 0
BGP 0 0 0 0
OpenR 0 0 0 0
Total 8 7 8 0
Table 12 Command output
Proto |
Protocol that installed the route. |
Routes |
Number of routes installed by the protocol. |
Prefixes |
Number of IPv4 route prefixes. |
Active |
Number of active routes. |
Added |
Number of routes added to the routing table after the router started up or the routing table was cleared most recently. |
Deleted |
Number of routes marked as deleted, which will be cleared after a period. |
Total |
Total number of routes. |
Use display ip routing-table summary to display brief routing table information, including maximum number of ECMP routes, maximum number of active routes, and number of remaining active routes.
display ip routing-table [ vpn-instance vpn-instance-name ] summary
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays brief routing table information for the public network.
# Display brief routing table information for the public network.
<Sysname> display ip routing-table summary
Max ECMP: 32
Max Active Route: 262144
Remain Active Route: 262126
# Display brief routing table information for the MPLS L3VPN instance vpn1.
<Sysname> display ip routing-table vpn-instance vpn1 summary
Max ECMP: 32
Remain Active Route: 262134
Threshold value percentage of max active routes: 100%
Max ECMP |
Maximum number of ECMP routes supported by the system. |
Max Active Route |
Maximum number of supported routes. |
Remain Active Route |
Number of the remaining inactive routes. |
Threshold value xxx |
Alarm threshold of active routes specified by using the routing-table limit command in a VPN instance: · Threshold value of active routes alert—This field is displayed when the alarm threshold is specified by using the routing-table limit number simply-alert command. When the number of active routes exceeds the alarm threshold, the system logs the event and sends traps but still accepts active routes. · Threshold value percentage of max active routes—This field is displayed when the routing-table limit number simply-alert command is not configured or when the alarm threshold is specified by using the routing-table limit number warn-threshold command. The value range for the alarm threshold is 1 to 100 in percentage. When the percentage of active routes exceeds the alarm threshold, the system logs the event and sends traps but still accepts active routes. If the number of active routes reaches the maximum number, no more routes can be added. The percentage of active routes equals the number of active routes divided by the maximum number of active routes supported in a VPN instance, and multiplied by 100. |
display ipv6 max-ecmp-num
Use display ipv6 max-ecmp-num to display the maximum number of IPv6 ECMP routes.
# Display the maximum number of IPv6 ECMP routes.
<Sysname> display ipv6 max-ecmp-num
Max-ECMP-Num in use: 6
Max-ECMP-Num at the next reboot: 10
Table 14 Command output
Max-ECMP-Num in use |
Maximum number of current IPv6 ECMP routes in use. |
Max-ECMP-Num at the next reboot |
Maximum number of IPv6 ECMP routes at the next reboot of the device. |
display ipv6 rib attribute
Use display ipv6 rib attribute to display route attribute information in the IPv6 RIB.
attribute-id: Specifies a route attribute by its ID, a hexadecimal string in the range of 0 to ffffffff.
# Display route attribute information in the IPv6 RIB.
<Sysname> display ipv6 rib attribute
Total number of attribute(s): 1
Detailed information of attribute 0x9:
Flag: 0x0
Protocol: BGP4+ instance default
Address family: IPv6
Reference count: 0
Local preference: 0
Ext-communities number: 0
Ext-communities value: N/A
Communities number: 0
Communities value: N/A
AS-path number: 0
AS-path value: N/A
For command output, see Table 19.
Use display ipv6 rib graceful-restart to display IPv6 RIB GR state information.
# Display IPv6 RIB GR state information.
<Sysname> display ipv6 rib graceful-restart
RIB GR state : Phase2-calculation end
RCOM GR state : Flush end
Protocol GR state:
No. Protocol Lifetime FD State Start/End
1 DIRECT6 480 29 End No/No
2 STATIC6 480 32 End No/No
3 ISISV6 480 30 End No/No
4 BGP4+ instance default
480 31 End No/No
5 BGP4+ instance ebcdefg
480 32 End No/No
6 OpenR6 480 83 End No/No
For command output, see Table 20.
display ipv6 rib nib
Use display ipv6 rib nib to display next hop information in the IPv6 RIB.
display ipv6 rib nib [ sub-nib nib-id ] [ verbose ]
self-originated: Displays information about next hops of self-originated routes in the IPv6 RIB.
sub-nib nib-id: Specifies a sub-NIB by its ID to display information about its parent NIB.
nib-id: Specifies a NIB by its ID, a hexadecimal string in the range of 1 to ffffffff.
verbose: Displays detailed next hop information in the IPv6 RIB. If you do not specify this keyword, the command displays brief next hop information in the IPv6 RIB.
protocol protocol: Specifies a protocol by its name.
# Display brief next hop information in the IPv6 RIB.
<Sysname> display ipv6 rib nib
Total number of nexthop(s): 151
NibID: 0x20000000 Sequence: 0
Type: 0x1 Flushed: Yes
Age: 00h01m50s
UserKey0: 0x0 VrfNthp: 0
UserKey1: 0x0 Nexthop: ::
UserKey2: 0x0 IFIndex: 0x111
UserKey3: 0x0 LocalAddr: ::
TopoNthp: Invalid ExtType: 0x0
Color: 0 COFlag: 0x0
LinkID: 0x0 AS-path: 0 0
SIDIndex: 0x0 SRPName:
OriNexthop: ::
NibID: 0x20000001 Sequence: 1
Age: 00h01m50s
UserKey1: 0x0 Nexthop: ::1
UserKey2: 0x0 IFIndex: 0x112
UserKey3: 0x0 LocalAddr: ::1
LinkID: 0x0 AS-path: 10 20
OriNexthop: ::
# Display detailed next hop information in the IPv6 RIB.
<Sysname> display ipv6 rib nib verbose
Age: 00h01m50s
OriNexthop: ::
RefCnt: 4 FlushRefCnt: 1
Flag: 0x84 Version: 1
1 nexthop(s):
PrefixIndex: 0 OrigNexthop: ::
RelyDepth: 0 RealNexthop: ::
Interface: NULL0 LocalAddr: ::
TunnelCnt: 0 Vrf: default-vrf
TunnelID: N/A Topology:
Weight: 0 Flags: 0x0
SRPolicyNID: 4294967295 SRInterface:
ColorWeight: 0 Locator: N/A
OrigLinkID: 0x0 RealLinkID: 0x0
Age: 00h01m50s
OriNexthop: ::
1 nexthop(s):
PrefixIndex: 0 OrigNexthop: ::1
RelyDepth: 0 RealNexthop: ::1
Interface: InLoop0 LocalAddr: ::1
NibID: 0x26000002 Sequence: 1
Age: 00h01m50s
UserKey1: 0x0 Nexthop: 122::2
UserKey3: 0x0 LocalAddr: 122::2
OriNexthop: ::
Instance: abc
1 nexthop(s):
PrefixIndex: 0 OrigNexthop: 122::2
RelyDepth: 0 RealNexthop: 122::2
For command output, see Table 21 and Table 22.
display ipv6 rib nib record
Use display ipv6 rib nib record to display next hop records in the IPv6 RIB.
display ipv6 rib nib record flush [ delete | update ] [ verbose ]
display ipv6 rib nib record receive [ add | delete | update ] [ verbose ]
flush: Displays the records for the next hops issued by the IPv6 RIB to the FIB.
receive: Displays the records for the next hops received by the IPv6 RIB from the routing protocol.
add: Displays the records for the added next hops.
delete: Displays the records for the deleted next hops.
update: Displays the records for the updated next hops. If you specify the flush keyword, the system takes added next hops as updated next hops when displaying the associated records.
verbose: Displays detailed information about next hop records. If you do not specify this keyword, the command displays only brief information about next hop records.
If you do not specify the add, delete, or update keyword, the command displays records for the added, deleted, and updated next hops.
When the system enters the level-1 memory threshold alarm status, it stops recording new next hop information. When the system enters the level-3 memory threshold alarm status, it clears existing next hop records. When the system exits the level-1 memory threshold alarm status, it starts recording new next hop information again.
# Display brief information about the records for the next hops issued by the IPv6 RIB to the FIB.
<Sysname> display ipv6 rib nib record flush
Date Time Action VNID
210908 15:31:55:364 update 0x20000000
210908 15:31:55:364 update 0x120000001
For descriptions about the command output, see Table 23.
# Display detailed information about the records for the updated next hops issued by the IPv6 RIB to the FIB.
<Sysname> display ipv6 rib nib record flush update verbose
Time: 210908 15:31:55:364 Action: update
NibID: 0x20000000 VNID: 0x20000000
Sequence: 0 Version: 1
Flags: 0x80 ExtFlags: 0x0
Type: 0xd
VrfIndex: 0 Nexthop: ::
IfIndex: 1410 LocalAddr: ::
MemberPort: 0
ExtType1: 0x0 NibInstance: IFM
ExtType2: 0x0
UserKey0: 0x0 UserKey1: 0x0
NewUK0: 0x0 NewUK1: 0x0
NewUK2: 0x0 NewUK3: 0x0
NewUK4: 0x0 NewUK5: 0x0
NewUK6: 0x0 NewUK7: 0x0
SIDIndex: 0x0 SrPolicyName:
Color: 0 OriNexthop: ::
COFlag: 0x0 Locator: N/A
1 nexthop(s):
Interface: 258 LocalAddr: ::
VrfIndex: 0 Topology:
Weight: 0 Flags: 0x800
SRPolicyNID: 4294967295 SRInterface: 0
MemberPort: 0 SRL2Interface: 0
NibID: 0x20000001 VNID: 0x120000001
Sequence: 1 Version: 1
Type: 0x1
VrfIndex: 0 Nexthop: ::1
IfIndex: 1410 LocalAddr: ::1
MemberPort: 0
ExtType2: 0x0
1 nexthop(s):
For descriptions about the command output, see Table 24.
# Display brief information about the records for the next hops received by the IPv6 RIB from the routing protocol.
<Sysname> display ipv6 rib nib record receive
Date Time Action NibID NibInstance
210908 10:45:35:211 add 0x21000000 USR
210908 10:45:35:215 update 0x21000000 USR
210908 10:49:47:785 delete 0x21000000 USR
For descriptions about the command output, see Table 25.
# Display detailed information about the records for the added next hops received by the IPv6 RIB from the routing protocol.
<Sysname> display ipv6 rib nib record receive add verbose
Time: 210928 14:39:14:147 Action: add
NibInstance: IFM Version: 1
Flag: 0x0 UsrData: 0xffffffffffffffff
Type: 0x1 ExtType1: 0x0
ExtType2: 0x0
InstanceId: 0 Nexthop: ::1
L2IfIndex: 0
BandWidth: 0 Weight: 0
ProtNibID: 0xffffffff NibFlags: 0x0
1 nexthop(s):
Interface: 1410 LocalAddr: ::1
For descriptions about the command output, see Table 26.
display ipv6 route-direct nib
Use display ipv6 route-direct nib to display next hop information for IPv6 direct routes.
verbose: Displays detailed next hop information for IPv6 direct routes. If you do not specify this keyword, the command displays brief next hop information for IPv6 direct routes.
# Display brief next hop information for IPv6 direct routes.
<Sysname> display ipv6 route-direct nib
Total number of nexthop(s): 115
Age: 00h01m50s
LinkID: 0x0
OriNexthop: ::
Age: 00h01m50s
LinkID: 0x0
OriNexthop: ::
# Display detailed next hop information for IPv6 direct routes.
<Sysname> display ipv6 route-direct nib verbose
Age: 00h01m50s
LinkID: 0x0
OriNexthop: ::
RefCnt: 1 FlushRefCnt: 0
Flag: 0x2 Version: 1
1 nexthop(s):
Age: 00h01m50s
LinkID: 0x0
OriNexthop: ::
1 nexthop(s):
For command output, see Table 27 and Table 28.
Use display ipv6 routing-table to display IPv6 routing table information.
display ipv6 routing-table [ all-vpn-instance | vpn-instance vpn-instance-name ] [ verbose ]
display ipv6 routing-table all-routes
all-vpn-instance: Displays IPv6 routing table information for all VPN instances.
all-routes: Displays IPv6 routing table information for the public network and all VPN instances.
# Display brief information about active routes in the IPv6 routing table.
<Sysname> display ipv6 routing-table
Destinations : 3 Routes : 3
Destination: ::1/128 Protocol : Direct
NextHop : ::1 Preference: 0
Interface : InLoop0 Cost : 0
Destination: 6::/64 Protocol : Static
NextHop : 5::2 Preference: 60
Interface : GE1/0/1 Cost : 0
Interface : GE1/0/2 Cost : 0
Destination: FE80::/10 Protocol : Direct
NextHop : :: Preference: 0
Destination: FF00::/8 Protocol : Direct
Interface : NULL0 Cost : 0
Destinations |
Routes |
Number of routes. |
Destination |
IPv6 address and prefix of the destination network or host. |
NextHop |
Preference |
Protocol |
Route type or protocol that installed the route: · Direct—Direct route. · Static—Static route. · RIPng—RIPng route. · OSPFv3—OSPFv3 route. · ISISv6—IPv6 IS-IS route. · EIGRPv6—IPv6 EIGRP route. · BGP4+—IPv6 BGP route. · OpenR6—IPv6 Open Routing (IPv6 OpenR) route. · LDP—LDP route. · SLSP—Static LSP. · PIM—PIM route. · MSTATIC—Multicast static route. · O_INTRA—OSPF intra-area route. · O_INTER—OSPF inter-area route. · O_ASE1—OSPF Type-1 external route. · O_ASE2—OSPF Type-2 external route. · O_SUM—OSPF summary route. · IS_L1—IS-IS Level-1 route. · IS_L2—IS-IS Level-2 route. · IS_SUM—IS-IS summary route. |
Cost |
Summary count |
Number of routes. |
<Sysname> display ipv6 routing-table verbose
Destinations : 6 Routes : 6
Protocol: Direct
Process ID: 0
SubProtID: 0x0 Age: 19h23m02s
TableID: 0xa OrigAs: 0
NibID: 0x20000000 LastAs: 0
AttrID: 0xffffffff Neighbor: ::
Flags: 0x10004 OrigNextHop: ::1
Label: NULL RealNextHop: ::1
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
Destination: 6::/64
Protocol: Static
Process ID: 0
SubProtID: 0x0 Age: 00h01m47s
NibID: 0x21000000 LastAs: 0
Flags: 0x10080 OrigNextHop: 5::2
Label: NULL RealNextHop: 3::3
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
Destination: 12::/96
Protocol: Direct
Process ID: 0
NibID: 0x20000003 LastAs: 0
Flags: 0x10080 OrigNextHop: ::
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
Destination: 12::1/128
Protocol: Direct
Process ID: 0
SubProtID: 0x0 Age: 00h01m45s
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
Destination: FF::11/128
Process ID: 0
SubProtID: 0x6 Age: 00h00m33s
TableID: 0xa OrigAs: 200
NibID: 0x26000000 LastAs: 200
AttrID: 0x1 Neighbor: 12::2
Flags: 0x10060 OrigNextHop: 12::2
Label: NULL RealNextHop: 12::2
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
Destination |
Protocol |
Route type or protocol that installed the route: · Direct—Direct route. · Static—Static route. · RIPng—RIPng route. · OSPFv3—OSPFv3 route. · ISISv6—IPv6 IS-IS route. · EIGRPv6—IPv6 EIGRP route. · BGP4+—IPv6 BGP route. · OpenR6—IPv6 Open Routing (IPv6 OpenR) route. · LDP—LDP route. · SLSP—Static LSP. · PIM—PIM route. · MSTATIC—Multicast static route. · O_INTRA—OSPF intra-area route. · O_INTER—OSPF inter-area route. · O_ASE1—OSPF Type-1 external route. · O_ASE2—OSPF Type-2 external route. · O_SUM—OSPF summary route. · IS_L1—IS-IS Level-1 route. · IS_L2—IS-IS Level-2 route. · IS_SUM—IS-IS summary route. · SRv6—SRv6 route. |
SubProtID |
Age |
Cost |
Preference |
IpPre |
IP precedence. |
QosLocalID |
Tag |
Tag of the route. |
State |
Route status: · Active—Active unicast route. · Adv—Route that can be advertised. · Inactive—Inactive route. · NoAdv—Route that the router must not advertise. · Vrrp—Routes generated by VRRP. · Nat—Routes generated by NAT. · TunE—Tunnel. · Derived—Derived route. If a route recurses to multiple related routes, all related routes except the first one are derived routes. The number of derived routes is not included in the total number of routes. |
OrigTblID |
OrigVrf |
TableID |
OrigAs |
NibID |
LastAs |
Last AS number. |
AttrID |
Attribute ID. |
Neighbor |
Flags |
OrigNextHop |
Label |
Label. |
RealNextHop |
BkLabel |
Backup label. |
BkNexthop |
Backup next hop. |
SRLabel |
BkSRLabel |
SIDIndex |
InLabel |
Tunnel ID |
Tunnel ID. |
BkTunnel ID |
BkInterface |
IPInterface |
BkIPInterface |
ColorInterface |
This field is not supported in the current software version. Color output interface obtained through SRv6 TE policy-based recursion. |
BkColorInterface |
This field is not supported in the current software version. Backup color output interface. |
TunnelInterface |
BkTunnelInterface |
FtnIndex |
TrafficIndex |
Connector |
BGP connector attribute exchanged between BGP peers along with a VPN IPv4 route. The value of the attribute is the IP address of the remote PE device. The BGP connector attribute is used for MD VPN. This field displays N/A if BGP connector attribute is not supported. |
PathID |
Path ID. |
SRTunnelID |
SID Type |
NID |
FlushNID |
BkNID |
BkFlushNID |
StatFlags |
VpnPeerId |
Dscp |
Exp |
SID |
BkSID |
CommBlockLen |
OrigLinkID |
This field is not supported in the current software version. Original link ID of the SDWAN TTE connection. |
RealLinkID |
This field is not supported in the current software version. Real link ID of the SDWAN TTE connection. |
Use display ipv6 routing-table acl to display routing information permitted by an IPv6 basic ACL.
display ipv6 routing-table [ vpn-instance vpn-instance-name ] acl ipv6-acl-number [ verbose ]
ipv6-acl-number: Specifies a basic IPv6 ACL by its number in the range of 2000 to 2999.
verbose: Displays detailed information about all routes permitted by the basic IPv6 ACL. If you do not specify this keyword, the command displays only brief information about active routes permitted by the basic IPv6 ACL.
If the specified IPv6 ACL does not exist or has no rules configured, the command displays information about all IPv6 routes.
If a rule in the specified IPv6 ACL has the VPN instance match criterion configured, the rule will not take effect.
# Display brief information about active routes permitted by IPv6 ACL 2000.
<Sysname> display ipv6 routing-table acl 2000
Summary count : 6
Destination : ::1/128 Protocol : Direct
Destination: 12::/96 Protocol : Direct
Destination: 12::1/128 Protocol : Direct
Destination: FF::11/128 Protocol : BGP4+
NextHop : 12::2 Preference: 255
For command output, see Table 15.
# Display detailed information about all routes permitted by IPv6 ACL 2000.
<Sysname> display ipv6 routing-table acl 2000 verbose
Summary count : 6
Protocol: Direct
Process ID: 0
SubProtID: 0x0 Age: 19h29m12s
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
Protocol: Direct
Process ID: 0
SubProtID: 0x0 Age: 00h07m57s
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
For command output, see Table 16.
Use display ipv6 routing-table ipv6-address to display information about routes to an IPv6 destination address.
Use display ipv6 routing-table ipv6-address1 to ipv6-address2 to display information about routes to a range of IPv6 destination addresses.
display ipv6 routing-table [ vpn-instance vpn-instance-name ] ipv6-address [ prefix-length ] [ longer-match ] [ verbose ]
display ipv6 routing-table [ vpn-instance vpn-instance-name ] ipv6-address1 to ipv6-address2 [ verbose ]
ipv6-address: Specifies a destination IPv6 address.
prefix-length: Specifies the prefix length in the range of 0 to 128.
ipv6-address1 to ipv6-address2: Specifies a destination IPv6 address range.
Executing the command with different parameters yields different output.
· display ipv6 routing-table ipv6-address
¡ The system ANDs the entered destination IPv6 address with the prefix length in each active route entry.
¡ The system ANDs the destination IPv6 address in each active route entry with the prefix length in the entry.
· display ipv6 routing-table ipv6-address prefix-length
¡ The system ANDs the entered destination IPv6 address with the entered prefix length.
¡ The system ANDs the destination IPv6 address in each active route entry with the entered prefix length.
If the two operations yield the same result for an entry with a prefix length not greater than the entered prefix length, the entry is displayed.
· display ipv6 routing-table ipv6-address longer-match
If you do not specify the prefix-length argument, the command yields the same result as the display ipv6 routing-table command.
· display ipv6 routing-table ipv6-address prefix-length longer-match
· display ipv6 routing-table ipv6-address1 to ipv6-address2
The system displays route entries with destinations in the range of ipv6-address1/128 to ipv6-address2/128.
# Display brief information about the routes to the destination IPv6 address 10::1 127.
<Sysname> display ipv6 routing-table 10::1 127
Summary count: 3
Destination: 10::/64 Protocol : Static
NextHop : :: Preference: 60
Destination: 10::/68 Protocol : Static
Destination: 10::/120 Protocol : Static
# Display brief information about the routes to the destination IPv6 address 10::1 with prefix length 127.
<Sysname> display ipv6 routing-table 10::1 127 longer-match
Summary count : 3
# Display brief information about the routes to destination addresses in the range of 100:: to 300::.
<Sysname> display ipv6 routing-table 100:: to 300::
Summary count : 3
Destination: 100::/64 Protocol : Static
Destination: 200::/64 Protocol : Static
Destination: 300::/64 Protocol : Static
# Display detailed information about the routes to destination IPv6 addresses 1:2::3:4/128.
<Sysname> display ipv6 routing-table 1:2::3:4 128 verbose
Summary count : 1
Destination: 1:2::3:4/128
Protocol: BGP4+ instance abc
Process ID: 0
SubProtID: 0x1 Age: 00h01m14s
TableID: 0x1 OrigAs: 200
AttrID: 0x0 Neighbor: 2:2::3:4
Flags: 0x10060 OrigNextHop: 2:2::3:4
Label: NULL RealNextHop: 2:2::3:4
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
display ipv6 routing-table prefix-list
Use display ipv6 routing-table prefix-list to display information about IPv6 routes permitted by an IPv6 prefix list.
display ipv6 routing-table [ vpn-instance vpn-instance-name ] prefix-list prefix-list-name [ verbose ]
prefix-list-name: Specifies an IPv6 prefix list by its name, a case-sensitive string of 1 to 63 characters.
verbose: Displays detailed information about all IPv6 routes permitted by the IPv6 prefix list. If you do not specify this keyword, the command displays brief information about active IPv6 routes permitted by the IPv6 prefix list.
If the specified IPv6 prefix list does not exist, the command displays information about all routes.
# Create an IPv6 prefix list named test to permit the prefix ::1/128.
[Sysname] ipv6 prefix-list test permit ::1 128
# Display brief information about the active IPv6 route permitted by the IPv6 prefix list.
[Sysname] display ipv6 routing-table prefix-list test
Summary count : 1
# Display detailed information about all routes permitted by the IPv6 prefix list.
[Sysname] display ipv6 routing-table prefix-list test verbose
Summary count : 1
Protocol: Direct
Process ID: 0
SubProtID: 0x0 Age: 08h57m19s
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
display ipv6 routing-table protocol
Use display ipv6 routing-table protocol to display information about IPv6 routes installed by a protocol.
display ipv6 routing-table [ vpn-instance vpn-instance-name ] protocol protocol [ inactive | verbose ]
# Display brief information about IPv6 direct routes.
<Sysname> display ipv6 routing-table protocol direct
Summary count : 3
Summary count : 3
Summary count : 0
# Display brief information about IPv6 static routes.
<Sysname> display ipv6 routing-table protocol static
Summary count : 3
Summary count : 3
Destination: 2::2/128 Protocol : Static
NextHop : fe80::2 Preference: 60
NextHop : fe80::3 Preference: 60
Destination: 3::3/128 Protocol : Static
NextHop : 2::2 Preference: 60
Summary count : 0
# Display brief information about IPv6 OpenR routes.
<Sysname> display ipv6 routing-table protocol openr
Summary count : 1
OpenR6 Routing table status : <Active>
Summary count : 1
Destination: 2::2/128 Protocol : OpenR6
NextHop : fe80::2 Preference: 30
OpenR6 Routing table status : <Inactive>
Summary count : 0
# Display detailed information about IPv6 BGP routes.
<Sysname> display ipv6 routing-table protocol bgp4+ verbose
Summary count : 1
Destination: 22::22/128
Process ID: 0
SubProtID: 0x6 Age: 00h04m15s
NibID: 0x25000001 LastAs: 200
AttrID: 0x3 Neighbor: 121::2
Flags: 0x10060 OrigNextHop: 121::2
Label: NULL RealNextHop: 121::2
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
# Display detailed information about IPv6 OpenR routes.
<Sysname> display ipv6 routing-table protocol openr verbose
Summary count : 1
Protocol: OpenR6
Process ID: 0
SubProtID: 0x1 Age: 01h28m12s
Flags: 0x10060 OrigNextHop: 200::6
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
display ipv6 routing-table record
Use display ipv6 routing-table record to display IPv6 routing entry records.
display ipv6 routing-table record flush [ delete | update ] [ verbose ]
display ipv6 routing-table record notify [ delete | update ] [ verbose ]
display ipv6 routing-table record receive [ add | delete | update ] [ verbose ]
flush: Displays the records for the route entries issued by the IPv6 RIB to the FIB.
notify: Displays the records for the route entries notified by the IPv6 RIB to the routing protocol.
receive: Displays the records for the route entries received by the IPv6 RIB from the routing protocol.
verbose: Displays detailed information about IPv6 route entry records. If you do not specify this keyword, the command displays only brief information about IPv6 route entry records.
# Display brief information about the records for the route entries issued by the IPv6 RIB to the FIB.
<Sysname> display ipv6 routing-table record flush
Date Time Action Destination/PrefixLength/VNID/Vrf
210908 09:33:21:996 update 1001::/64/0x520000004/default-vrf
210908 09:33:23:386 update 1001::1/128/0x120000001/default-vrf
For descriptions about the command output, see Table 6.
# Display detailed information about the records for the updated route entries issued by the IPv6 RIB to the FIB.
<Sysname> display ipv6 routing-table record flush update verbose
Time: 210908 09:33:21:996 Action: update
Destination: 1001::/64
OrigAs: 0 LastAs: 0
VNID: 0x520000004
Flags: 0x10040000 ExtFlags: 0x0
FlowIndex: 65535 UserID: 0x0
SID Type: 0 VsiIndex: 0xffffffff
LinkId: 0xffffffff ArgLen: 0
Time: 210908 09:33:23:386 Action: update
Destination: 1001::1/128
OrigAs: 0 LastAs: 0
VNID: 0x120000001
For descriptions about the command output, see Table 7.
# Display brief information about the records for the route entries notified by the IPv6 RIB to the routing protocol.
<Sysname> display ipv6 routing-table record notify
Date Time Action Destination/PrefixLength/NibID/Vrf
210908 10:47:03:698 update 2000::/64/0x21000000/default-vrf
For descriptions about the command output, see Table 8.
# Display detailed information about the records for the deleted route entries notified by the IPv6 RIB to the routing protocol.
<Sysname> display ipv6 routing-table record notify delete verbose
Time: 210908 10:49:47:787 Action: delete
Destination: 2000::/64
TableID: 0xa NibID: 0x0
RtFlags: 0xc00 ExtRtFlags: 0x22
For descriptions about the command output, see Table 9.
# Display brief information about the records for the route entries received by the IPv6 RIB from the routing protocol.
<Sysname> display ipv6 routing-table record receive
Date Time Action Proto Destination/PrefixLength/NibID/Vrf
210908 09:33:23:385 add DIRECT 1001::1/128/0x20000001/default-vrf
For descriptions about the command output, see Table 10.
# Display detailed information about the records for the added route entries received by the IPv6 RIB from the routing protocol.
<Sysname> display ipv6 routing-table record receive add verbose
Time: 210908 09:33:23:385 Action: add
TableID: 0xa ProcessID: 0
Protocol: DIRECT SubProtID: 0x0
ModFlags: 0x0
NibID: 0x20000001 NewNibID: N/A
Flags: 0x4 ExtFlags: 0x0
CommID: 0x5000001 Tag: 0
SID: N/A
BkSID: N/A
For descriptions about the command output, see Table 11.
display ipv6 routing-table statistics
Use display ipv6 routing-table statistics to display IPv6 route and route prefix statistics.
display ipv6 routing-table [ all-routes | all-vpn-instance | vpn-instance vpn-instance-name ] [ prefix ] statistics
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays route statistics for the public network.
prefix: Displays statistics about IPv6 route prefixes. If you do not specify this keyword, the command displays statistics about IPv6 routes.
If you do not specify any parameters, this command displays statistics about IPv6 routes in the public network.
# Display IPv6 route statistics for the public network.
<Sysname> display ipv6 routing-table statistics
Total prefixes: 8 Active prefixes: 8
DIRECT 5 5 5 0
STATIC 3 3 3 0
UNR 0 0 0 0
RIPng 0 0 0 0
OSPFv3 0 0 0 0
IS-ISv6 0 0 0 0
LISP 0 0 0 0
SRv6 0 0 0 0
BGP4+ 0 0 0 0
OpenR6 0 0 0 0
Total 8 8 8 0
# Display IPv6 route statistics for the public network and all VPN instances.
<Sysname> display ipv6 routing-table all-routes statistics
Total prefixes: 6 Active prefixes: 6
DIRECT 3 3 3 0
STATIC 3 3 5 2
UNR 0 0 0 0
RIPng 0 0 0 0
OSPFv3 0 0 0 0
IS-ISv6 0 0 0 0
LISP 0 0 0 0
SRv6 0 0 0 0
BGP4+ 0 0 0 0
OpenR6 0 0 0 0
Total 6 6 8 2
# Display IPv6 route statistics for VPN instance vpn1.
<Sysname> display ipv6 routing-table vpn-instance vpn1 statistics
DIRECT 8 8 8 0
STATIC 3 3 5 2
UNR 0 0 0 0
RIPng 0 0 0 0
OSPFv3 0 0 0 0
IS-ISv6 0 0 0 0
LISP 0 0 0 0
SRv6 0 0 0 0
BGP4+ 0 0 0 0
OpenR6 0 0 0 0
Total 11 11 13 2
# Display IPv6 route statistics for all VPN instances.
<Sysname> display ipv6 routing-table all-vpn-instance statistics
DIRECT 8 8 8 0
STATIC 3 3 5 2
UNR 0 0 0 0
RIPng 0 0 0 0
OSPFv3 0 0 0 0
IS-ISv6 0 0 0 0
LISP 0 0 0 0
SRv6 0 0 0 0
BGP4+ 0 0 0 0
OpenR6 0 0 0 0
Total 11 11 13 2
# Display IPv6 route prefix statistics for the public network.
<Sysname> display ipv6 routing-table prefix statistics
DIRECT 5 5 5 0
STATIC 1 1 1 0
UNR 0 0 0 0
RIPng 0 0 0 0
OSPFv3 0 0 0 0
IS-ISv6 0 0 0 0
LISP 0 0 0 0
SRv6 0 0 0 0
BGP4+ 0 0 0 0
OpenR6 0 0 0 0
Total 6 6 6 0
Table 17 Command output
Proto |
Routes |
Prefixes |
Number of IPv6 route prefixes. |
Active |
Added |
Deleted |
Total |
display ipv6 routing-table summary
Use display ipv6 routing-table summary to display brief IPv6 routing table information, including maximum number of ECMP routes, maximum number of active routes, and number of remaining active routes.
display ipv6 routing-table [ vpn-instance vpn-instance-name ] summary
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays brief IPv6 routing table information for the public network.
# Display brief IPv6 routing table information for the public network.
<Sysname> display ipv6 routing-table summary
Max ECMP: 32
# Display brief IPv6 routing table information for the MPLS L3VPN instance vpn1.
<Sysname> display ipv6 routing-table vpn-instance vpn1 summary
Max ECMP: 32
Threshold value of active routes alert: 65100
For command output, see Table 13.
display max-ecmp-num
Use display max-ecmp-num to display the maximum number of ECMP routes.
# Display the maximum number of ECMP routes.
<Sysname> display max-ecmp-num
Table 18 Command output
Maximum number of current ECMP routes in use. |
Maximum number of ECMP routes at the next reboot of the device. |
max-ecmp-num
display rib attribute
Use display rib attribute to display route attribute information in the RIB.
# Display route attribute information in the RIB.
<Sysname> display rib attribute
Total number of attribute(s): 10
Detailed information of attribute 0x0:
Flag: 0x0
Address family: IPv4
Reference count: 0
Act-RT reference count: 0
Flush flag: 0
Local preference: 0
Ext-communities number: 26
Ext-communities value: <RT: 1:1> <RT: 2:2> <RT: 3:3> <RT: 123.123.123.123:65535
> <RT: 1234567890:65535> <RT: 123.123.123.123:65534> <RT
: 4:4> <RT: 5:5> <RT: 6:6> <RT: 7:7> <RT: 8:8> <RT: 9:9>
<RT: 10:10> <RT: 10:1> <RT: 10:11> <RT: 10:12> <RT: 10:
13> <RT: 10:14> <RT: 10:15> <RT: 10:16> ...
AS-path number: 0
AS-path value: N/A
SFlow AS-path length: 0
SFlow AS-path value: N/A
Detailed information of attribute 0x1:
Flag: 0x0
Protocol: BGP
Reference count: 0
Flush flag: 0
Local preference: 0
Ext-communities number: 1
Ext-communities value: <RT: 1:2>
AS-path number: 0
AS-path value: N/A
Protocol |
Protocol that generates the attribute. |
Act-RT reference count |
Reference count of active routes. |
Flush flag |
Flag of flushing route attribute information to the FIB: · 0—The route attribute information is not flushed to the FIB. · 1—The route attribute information is flushed to the FIB. |
Ext-communities number |
Number of the extended community attribute values. |
Ext-communities value |
Values of the extended community attribute. This field displays N/A when no values exist, and it can display a maximum of 20 values. |
Communities number |
Number of the COMMUNITY attribute values. |
Communities value |
Values of the COMMUNITY attribute. This field displays N/A when no values exist, and it can display a maximum of 20 values. |
AS-path number |
Number of ASs in the AS_PATH attribute. |
AS-path value |
Values of the AS_PATH attribute, including AS_SET, AS_SEQUENCE, confederation AS_SET, and confederation AS_SEQUENCE. This field displays N/A when no values exist, and it can display a maximum of 20 values. |
SFlow AS-path length |
Length of the sFlow AS-path attribute. |
SFlow AS-path value |
Value of the sFlow AS-path attribute. This field displays N/A if the length of the sFlow AS-path attribute is 0. This field can display a maximum of 80 characters. |
display rib graceful-restart
Use display rib graceful-restart to display RIB GR state information.
# Display RIB GR state information.
<Sysname> display rib graceful-restart
Protocol GR state:
1 DIRECT 100 30 End No/No
2 STATIC 480 34 End No/No
3 OSPF 480 36 End No/No
4 ISIS 480 32 End No/No
5 BGP instance abc
480 22 End No/No
6 BGP instance default
480 25 End No/No
7 LDP 480 35 End No/No
8 SLSP 480 29 End No/No
9 OpenR 480 85 End No/No
RIB GR state |
RIB GR status: · Start—GR starts. · IGP end—All IGP protocols complete GR. · VPN-triggering end—Optimal route selection triggered by VPN routes completes. · VPN-calculation end—Optimal VPN route selection completes. · Routing protocol end—All routing protocols complete GR. · NSR-calculation unfinished—NSR has not finished optimal route selection. · Triggering start—All triggered optimal route selection starts. · Triggering end—All triggered optimal route selection completes. · Phase1-calculation end—Optimal route selection phase 1 completes. · All end—All protocols complete GR. · Phase2-calculation end—Optimal route selection phase 2 completes. |
RCOM GR state |
RCOM GR status: · Start—GR starts. · VPN-calculation end—Optimal VPN route selection completes. · VPN-notification end—VPN routes have been delivered to the route management module. · Routing protocol end—All routing protocols complete GR. · NSR-calculation unfinished—NSR has not finished optimal route selection. · Phase1-calculation end—Optimal route selection phase 1 completes. · Notification end—All routes have been delivered to the route management module. · Phase2-calculation end—Optimal route selection phase 2 completes. · Flush start—Starts to flush routes to the FIB. · Flush end—Completes flushing routes to the FIB. |
No. |
Protocol number. |
Lifetime |
Lifetime (in seconds) of routes/labels in the RIB during GR. |
FD |
Handle between the protocol and the RIB. |
State |
Protocol GR state: · Init—Initialization state. · Listen—Listening state. · Idle. · Active. · Start—GR starts. · End—GR completes. |
Start/End |
Message sending state: · No—The message has not been sent. · Yes—The message has been sent. |
display rib nib
Use display rib nib to display next hop information in the RIB.
display rib nib [ sub-nib nib-id ] [ verbose ]
self-originated: Displays information about next hops of self-originated routes in the RIB.
verbose: Displays detailed next hop information in the RIB. If you do not specify this keyword, the command displays brief next hop information in the RIB.
# Display brief next hop information in the RIB.
<Sysname> display rib nib
Total number of nexthop(s): 176
NibID: 0x10000000 Sequence: 0
Age: 00h01m50s
UserKey1: 0x0 Nexthop: 0.0.0.0
UserKey3: 0x0 LocalAddr: 0.0.0.0
TopoNthp: 0 ExtType: 0x0
OriNexthop: 0.0.0.0
NibID: 0x10000001 Sequence: 1
Age: 00h01m50s
UserKey1: 0x0 Nexthop: 127.0.0.1
UserKey3: 0x0 LocalAddr: 127.0.0.1
OriNexthop: 0.0.0.0
NibID: 0x10000002 Sequence: 2
Type: 0x5 Flushed: Yes
Age: 00h01m50s
OriNexthop: 0.0.0.0
NibID: 0x16000000 Sequence: 3
Type: 0x21 Flushed: No
Age: 00h01m50s
UserKey1: 0x0 Nexthop: 12.1.1.2
UserKey2: 0x0 IFIndex: 0x0
LinkID: 0x0 AS-path: 300 100
OriNexthop: 0.0.0.0
Instance: abc
NibID |
ID of the next hop. |
Sequence |
Sequence number of the next hop. |
Type |
Type of the next hop. |
Flushed |
Indicates whether the route with the next hop has been flushed to the FIB. |
Age |
Elapsed time since the next hop information was last updated. |
UserKey0 |
Reserved data 1. |
UserKey1 |
Reserved data 2. |
UserKey2 |
Reserved data 3. |
UserKey3 |
Reserved data 4. |
VrfNthp |
Index of the VPN instance to which the next hop belongs. This field displays 0 if the next hop is on the public network. |
Nexthop |
Next hop address. |
IFIndex |
Interface index. |
LocalAddr |
Local interface address. |
TopoNthp |
(Non-base topologies are not supported in the current software version.) Index of the topology that contains the next hop. For IPv4 routes, this field displays 0 if the next hop is on the public network. For IPv6 routes, this field displays Invalid. |
ExtType |
NIB extension type. |
Color |
Color extended community attribute. |
COFlag |
Flag of the color extended community attribute. |
LinkID |
This field is not supported in the current software version. Link ID of the SDWAN TTE connection. |
AS-path |
AS-path subattribute in the next hop attribute. This value is the first two AS numbers nearest to the local end, separated by a space. If such AS numbers do not exist, this field displays 0. |
SIDIndex |
SID index value. |
Instance |
BGP instance name. |
SubNibID |
ID of the sub-next hop. |
SubSeq |
Sequence number of the sub-next hop. |
NthpCnt |
Number of sub-next hops. |
Samed |
Number of the same sub-next hops. |
NthpType |
Type of the sub-next hop: · IP—IP forwarding. · MPLS—MPLS forwarding. |
SRPName |
This field is not supported in the current software version. SR-MPLS TE policy name. |
OriNexthop |
Original next hop of the route. If the route is obtained from a BGP update message, this field displays the next hop IP address in the received message. |
# Display detailed next hop information in the RIB.
<Sysname> display rib nib verbose
Age: 00h01m50s
UserKey2: 0x0 IFIndex: 0x10002
OriNexthop: 0.0.0.0
RefCnt: 6 FlushRefCnt: 2
1 nexthop(s):
PrefixIndex: 0 OrigNexthop: 0.0.0.0
RelyDepth: 0 RealNexthop: 0.0.0.0
Interface: NULL0 LocalAddr: 0.0.0.0
TunnelID: N/A Topology: base
Age: 00h01m50s
OriNexthop: 0.0.0.0
RefCnt: 13 FlushRefCnt: 5
1 nexthop(s):
PrefixIndex: 0 OrigNexthop: 127.0.0.1
RelyDepth: 0 RealNexthop: 127.0.0.1
Interface: InLoop0 LocalAddr: 127.0.0.1
NibID: 0x15000003 Sequence: 3
Type: 0x43 Flushed: Yes
Age: 00h01m50s
UserKey0: 0x100010000 VrfNthp: 0
UserKey1: 0x0 Nexthop: 22.22.22.22
LinkID: 0x0 AS-path: 100 200
OriNexthop: 0.0.0.0
Instance: default
RefCnt: 9 FlushRefCnt: 3
Policy: tnl-policy1
1 nexthop(s):
PrefixIndex: 0 OrigNexthop: 22.22.22.22
RelyDepth: 1 RealNexthop: 13.1.1.2
Interface: GE0/1/3 LocalAddr: 13.1.1.1
TunnelCnt: 1 Vrf: default-vrf
TunnelID: 1025 Topology: base
NibID |
Sequence |
Type |
Flushed |
Age |
UserKey0 |
Reserved data 1. |
UserKey1 |
Reserved data 2. |
UserKey2 |
Reserved data 3. |
UserKey3 |
Reserved data 4. |
VrfNthp |
Nexthop |
Next hop address. |
ExtType |
SubNibID |
SubSeq |
NthpCnt |
Samed |
NthpType |
Policy |
Tunnel policy name. |
x nexthop (s) |
Number of next hops. |
PrefixIndex |
Prefix index of the next hop for an ECMP route. |
Vrf |
VPN instance name. For the public network, this field displays default-vrf. |
OrigNexthop |
Original next hop. |
RealNexthop |
Real next hop. |
Output interface. |
LocalAddr |
IFIndex |
Interface index. |
TopoNthp |
Color |
COFlag |
This field is not supported in the current software version. Flag of the color extended community attribute. |
LinkID |
AS-path |
SIDIndex |
This field is not supported in the current software version. SID index value. |
SRPName |
OriNexthop |
RelyDepth |
Recursion depth. |
TunnelCnt |
Number of tunnels after route recursion. |
TunnelID |
ID of the tunnel after route recursion. |
Topology |
(Non-base topologies are not supported in the current software version.) Topology name. For IPv4 routes, this field displays base for the topology on the public network. For IPv6 routes, this field is blank. |
Weight |
ECMP route weight. |
Instance |
RefCnt |
Reference count of the next hop. |
FlushRefCnt |
Reference count of the next hop that is flushed to the FIB. |
Flag |
Flag of the next hop. |
Version |
Version of the next hop. |
Flags |
Flags of the detailed next hop. |
SRPolicyNID |
This field is not supported in the current software version. NIB ID of the route obtained from an SR-MPLS TE policy through route recursion. |
SRInterface |
This field is not supported in the current software version. Output interface of the route obtained from the SR-MPLS TE policy through route recursion. |
ColorWeight |
This field is not supported in the current software version. Weight value of the color attribute in the SR-MPLS TE policy. |
Locator |
IPv6 prefix of the locator to which the SID belongs. N/A indicates that the attribute is not available. |
OrigLinkID |
RealLinkID |
display rib nib record
Use display rib nib record to display next hop records in the RIB.
display rib nib record flush [ delete | update ] [ verbose ]
display rib nib record receive [ add | delete | update ] [ verbose ]
flush: Displays the records for the next hops issued by the RIB to the FIB.
receive: Displays the records for the next hops received by the RIB from the routing protocol.
# Display brief information about the records for the next hops issued by the RIB to the FIB.
<Sysname> display rib nib record flush
210908 15:31:58:753 update 0x10000000
210908 15:31:58:755 update 0x110000001
Total number of next hop records. |
Date |
Time |
Action |
Action on the next hop in the record: · add. · update. · delete. |
VNID |
VN entry ID. |
# Display detailed information about the records for the updated next hops issued by the RIB to the FIB.
<Sysname> display rib nib record flush update verbose
Time: 210928 14:39:14:162 Action: update
NibID: 0x10000000 VNID: 0x10000000
Flag: 0x80 ExtFlags: 0x0
RefCnt: 5 FlushRefCnt: 1
Type: 0x1
VrfIndex: 0x0 Nexthop: 127.0.0.1
IfIndex: 1410 LocalAddr: 127.0.0.1
MemberPort: 0
ExtType2: 0x0
Color: 0 OriNexthop: 0.0.0.0
1 nexthop(s):
Interface: 1410 LocalAddr: 127.0.0.1
VrfIndex: 0 Topology: base
Limit of records |
Maximum number of next hop records. |
Time |
Action |
Action on the next hop in the record: · update. · delete. |
NibID |
VNID |
VN entry ID. |
Sequence |
Version |
Flag |
ExtFlags |
Flags of extended next hop information. |
RefCnt |
FlushRefCnt |
Type |
Next hop type. |
VrfIndex |
Nexthop |
Next hop address. |
IfIndex |
Output interface index. |
LocalAddr |
MemberPort |
Index of a member port in an aggregation group. If this attribute is not available, the field displays 0. |
ExtType1 |
Extended type 1 of the next hop. |
ExtType2 |
Extended type 2 of the next hop. |
NibInstance |
Instance or protocol generated the next hop information: · IFM—Interface management instance. · USR—Static routing. · RIP—RIP or RIPng. · OSPF—OSPF or OSPFv3. · ISIS—IS-IS or IPv6 IS-IS. · LISP—LISP. · BGP—BGP or BGP4+. · RIB—IP routing table instance. · EVPN—EVPN instance. · EIGRP—EIGRP or EIGRPv6. · UNR—User network routing instance. · None—Unknown or invalid instance. |
UserKey0 |
Reserved data 1. |
UserKey1 |
Reserved data 2. |
NewUK0 |
New reserved data 1. |
NewUK1 |
New reserved data 2. |
NewUK2 |
New reserved data 3. |
NewUK3 |
New reserved data 4. |
NewUK4 |
New reserved data 5. |
NewUK5 |
New reserved data 6. |
NewUK6 |
New reserved data 7. |
NewUK7 |
New reserved data 8. |
SIDIndex |
SrPolicyName |
This field is not supported in the current software version. Name of an SR-MPLS TE policy. |
Color |
This field is not supported in the current software version. Color extended community attribute. |
OriNexthop |
Original next hop address of the route. If the route is obtained from a BGP UPDATE message, the address is the next hop IP address in the BGP UPDATE message. |
COFlag |
Locator |
IPv6 prefix of the locator to which the SID belongs. If no locator is available, this field displays N/A. |
SubType |
Subtype of the parent NIB. |
SubNibID |
SubSeq |
NthpCnt |
Samed |
NthpType |
x nexthop (s) |
PrefixIndex |
OrigNexthop |
RelyDepth |
Recursion depth. |
RealNexthop |
Real next hop. |
Output interface. |
Topology |
Topology name. The topology name for the IPv4 public network is base. This field is blank for IPv6, because IPv6 does not support non-base topologies. |
Weight |
Flags |
Flags of the current next hop. |
SRPolicyNID |
SRInterface |
ColorWeight |
Locator |
MemberPort |
Index of a member port in an aggregation group. When this attribute is not available, the field displays 0. |
SRL2Interface |
Number of a member port in an aggregation group. When this attribute is not available, the field displays 0. |
# Display brief information about the records for the next hops received by the RIB from the routing protocol.
<Sysname> display rib nib record receive
210907 14:42:09:471 add 0x10000003 IFM
210907 15:35:45:190 delete 0x10000003 IFM
Date |
Time |
Action |
NibID |
NibInstance |
# Display detailed information about the records for the added next hops received by the RIB from the routing protocol.
<Sysname> display rib nib record receive add verbose
Time: 210928 14:39:14:148 Action: add
ExtType2: 0x0
InstanceId: 0 Nexthop: 127.0.0.1
L2IfIndex: 0
1 nexthop(s):
Limit of records |
Time |
Action |
NibID |
Next hop ID. |
Sequence |
Next hop sequence number. |
NibInstance |
Version |
Flag |
UsrData |
Protocol private data. |
VrfIndex |
VrfName |
Type |
Next hop type. |
Nexthop |
Next hop address. |
ExtType1 |
ExtType2 |
LocalAddr |
InstanceId |
IfIndex |
Interface index. |
L2IfIndex |
Index of a member port in an aggregation group. |
UserKey0 |
Reserved data 1. |
UserKey1 |
Reserved data 2. |
NewUK0 |
NewUK1 |
NewUK2 |
NewUK3 |
NewUK4 |
NewUK5 |
NewUK6 |
NewUK7 |
Color |
COFlag |
BandWidth |
Bandwidth of the link associated with the next hop. |
Weight |
ProtNibID |
Next hop ID carried by the protocol. |
NibFlags |
Flags of the next hop. |
SIDIndex |
SrPolicyName |
SubType |
SubNibID |
SubSeq |
NthpCnt |
Samed |
NthpType |
x nexthop (s) |
PrefixIndex |
OrigNexthop |
RelyDepth |
Recursion depth. |
RealNexthop |
Real next hop. |
Output interface. |
Topology |
Flags |
SRPolicyNID |
SRInterface |
ColorWeight |
Locator |
MemberPort |
SRL2Interface |
display route-direct nib
Use display route-direct nib to display next hop information for direct routes.
verbose: Displays detailed next hop information for direct routes. If you do not specify this keyword, the command displays brief next hop information for direct routes.
# Display brief next hop information for direct routes.
<Sysname> display route-direct nib
Total number of nexthop(s): 116
Age: 00h01m50s
LinkID: 0x0
OriNexthop: 0.0.0.0
Age: 00h01m50s
LinkID: 0x0
OriNexthop: 0.0.0.0
NibID |
ID of the NIB. |
Sequence |
Sequence number of the NIB. |
Type |
Type of the NIB. |
Flushed |
Indicates whether the route with the NIB has been flushed to the FIB. |
Age |
UserKey0 |
Reserved data 1. |
UserKey1 |
Reserved data 2. |
UserKey2 |
Reserved data 3. |
UserKey3 |
Reserved data 4. |
Color |
COFlag |
LinkID |
SIDIndex |
SID index value. |
VrfNthp |
Nexthop |
Next hop address. |
IFIndex |
Interface index. |
LocalAddr |
Local interface IP address. |
TopoNthp |
ExtType |
SRPName |
OriNexthop |
# Display detailed next hop information for direct routes.
<Sysname> display route-direct nib verbose
Age: 00h01m50s
LinkID: 0x0
OriNexthop: 0.0.0.0
RefCnt: 2 FlushRefCnt: 0
1 nexthop(s):
Age: 00h01m50s
LinkID: 0x0
OriNexthop: 0.0.0.0
RefCnt: 5 FlushRefCnt: 0
1 nexthop(s):
NibID |
ID of the NIB. |
Sequence |
Type |
Type of the NIB. |
Flushed |
Age |
UserKey0 |
Reserved data 1. |
UserKey1 |
Reserved data 2. |
UserKey2 |
Reserved data 3. |
UserKey3 |
Reserved data 4. |
VrfNthp |
Nexthop |
Next hop address. |
x nexthop(s) |
PrefixIndex |
Vrf |
OrigNexthop |
RealNexthop |
Real next hop. |
Output interface. |
localAddr |
RelyDepth |
Recursion depth. |
TunnelCnt |
TunnelID |
Topology |
Weight |
RefCnt |
FlushRefCnt |
Flag |
Version |
IFIndex |
Interface index. |
TopoNthp |
ExtType |
Color |
COFlag |
Flag of the extended community attribute. |
LinkID |
SIDIndex |
SID index value. |
SRPName |
OriNexthop |
Flags |
SRPolicyNID |
SRInterface |
ColorWeight |
Locator |
OrigLinkID |
RealLinkID |
ecmp mode enhanced
Use ecmp mode enhanced to enable the IPv4 and IPv6 enhanced ECMP mode.
Use undo ecmp mode to disable the IPv4 and IPv6 enhanced ECMP mode.
ecmp mode enhanced
undo ecmp mode
The IPv4 and IPv6 enhanced ECMP mode is disabled.
When one or multiple ECMP routes fail, the default ECMP mode enables the device to reallocate all traffic to the remaining routes.
The enhanced ECMP mode enables the device to reallocate only the traffic of the failed routes to the remaining routes.
This command takes effect after a device reboot. Before you reboot the device, make sure you understand the potential impact on the network.
# Enable the IPv4 and IPv6 enhanced ECMP mode.
[Sysname] ecmp mode enhanced
The configuration will take effect at the next reboot. Continue? [Y/N]:y
Reboot device to make the configuration take effect.
display ecmp mode
fib lifetime
Use fib lifetime to set the maximum lifetime for IPv4 or IPv6 routes in the FIB.
Use undo fib lifetime to restore the default.
fib lifetime seconds
undo fib lifetime
The maximum lifetime for IPv4 or IPv6 routes in the FIB is 600 seconds.
RIB IPv4 address family view
RIB IPv6 address family view
seconds: Specifies the maximum lifetime for routes in the FIB, in the range of 0 to 6000 seconds. When this argument is set to 0, FIB entries immediately age out after a protocol or RIB process switchover.
When a protocol or RIB process switchover occurs and GR or NSR is not configured, FIB entries age out after the time specified in this command.
# Set the maximum lifetime for IPv4 routes in the FIB to 60 seconds.
[Sysname] rib
[Sysname-rib] address-family ipv4
[Sysname-rib-ipv4] fib lifetime 60
flush route-attribute
Use flush route-attribute to enable the RIB to flush route attribute information to the FIB.
Use undo flush route-attribute remove the configuration.
flush route-attribute protocol
undo flush route-attribute protocol
The RIB does not flush route attribute information to the FIB.
protocol: Specifies a routing protocol. In the current software version, only BGP is supported.
# Enable the RIB to flush BGP route attribute information to the FIB.
[Sysname] rib
[Sysname-rib-ipv4] flush route-attribute bgp
inter-protocol fast-reroute
Use inter-protocol fast-reroute to enable IPv4 or IPv6 RIB inter-protocol FRR.
Use undo inter-protocol fast-reroute to disable IPv4 or IPv6 RIB inter-protocol FRR.
inter-protocol fast-reroute [ vpn-instance vpn-instance-name ]
undo inter-protocol fast-reroute [ vpn-instance vpn-instance-name ]
Inter-protocol FRR is disabled.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command enables inter-protocol FRR for the public network.
This command allows a device to perform fast rerouting between routes of different protocols. A backup next hop is automatically selected to reduce the service interruption time caused by unreachable next hops. When the next hop of the primary link fails, the traffic is redirected to the backup next hop.
This command uses the next hop of a route from a different protocol as the backup next hop for the faulty route, which might cause loops.
Inter-protocol FRR cannot select a backup next hop from routes in the RIB that have the same next hop, output interface, and destination as those of the faulty route.
# Enable IPv4 RIB inter-protocol FRR for the public network.
[Sysname] rib
[Sysname-rib-ipv4] inter-protocol fast-reroute
ip load-sharing mode
Use ip load-sharing mode to configure the load sharing mode.
Use undo ip load-sharing mode to restore the default.
ip load-sharing mode { per-flow [ algorithm algorithm-number [ seed seed-number ] | [ dest-ip | dest-port | flow-label | ingress-port | ip-pro | src-ip | src-port ] * ] | per-packet } { global | slot slot-number }
undo ip load-sharing mode [ per-flow [ algorithm algorithm-number [ seed seed-number ] | [ dest-ip | dest-port | flow-label | ingress-port | ip-pro | src-ip | src-port ] * ] | per-packet ] { global | slot slot-number }
The device performs per-flow load sharing based on the source IP address and destination IP address.
per-flow: Implements per-flow load sharing.
algorithm algorithm-number: Specifies an algorithm by its number for per-flow load sharing.The value range for the algorithm-number argument is 0 to 15.
seed seed-number: Specifies the seed value for the algorithm. The value range is 0 to ffff.
dest-ip: Identifies flows by destination IP address.
dest-port: Identifies flows by destination port.
flow-label: Identifies flows by flow label of IPv6 packets. This keyword is supported by only IPv6 packets.
ingress-port: Identifies flows by ingress port.
ip-pro: Identifies flows by protocol number.
src-ip: Identifies flows by source IP address.
src-port: Identifies flows by source port.
per-packet: Implements per-packet load sharing.
global: Configures the load sharing mode globally.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command configures the load sharing mode for all cards.
Non-default vSystems do not support this command.
You can configure a load sharing mode for each level of algorithm. If multiple levels of algorithms are configured for load sharing, the usage rules for different levels of algorithms depend on the device model.
If you execute this command multiple times for the same algorithm level, the most recent configuration takes effect.
If traffic is not load shared well among interfaces, you can use the seed seed-number option to adjust the algorithm result.
# Configure per-flow load sharing for slot 1.
[Sysname] ip load-sharing mode per-flow slot 1
ip load-sharing symmetric enable
Use ip load-sharing symmetric enable to enable symmetric load sharing.
Use undo ip load-sharing symmetric enable to disable symmetric load sharing.
Symmetric load sharing is disabled.
Symmetric load sharing ensures that bidirectional traffic specific to a particular source and destination address pair flow along the same path.
# Enable symmetric load sharing.
[Sysname] ip load-sharing symmetric enable
ipv6 max-ecmp-num
Use ipv6 max-ecmp-num to set the maximum number of IPv6 ECMP routes.
ipv6 max-ecmp-num number
The maximum number of IPv6 ECMP routes is determined by the maximum number of IPv6 ECMP routes supported by the system.
number: Specifies the maximum number of IPv6 ECMP routes. The value range for this argument is 1 to 128.
# Set the maximum number of IPv6 ECMP routes to 10.
[Sysname] ipv6 max-ecmp-num 10
After reboot, the maximum number of IPv6 ECMP routes is 10.
ipv6 route fast-switchover enable
Use ipv6 route fast-switchover enable to enable IPv6 route fast switchover.
Use undo ipv6 route fast-switchover enable to disable IPv6 route fast switchover.
IPv6 route fast switchover is disabled.
Use this command if a physical interface is the output interface for a large number of routes, including ECMP routes and primary/secondary routes. When a link failure occurs on an interface, the device typically performs the following operations before switching the traffic to a valid route:
1. Deletes all ND entries for the link.
2. Instructs the FIB to delete the associated FIB entries.
This process is time-consuming and interruptive if a large number of routes traverse the interface. Route fast switchover minimizes traffic interruption by instructing the FIB to delete the affected FIB entries immediately without having to wait for the ND entries to be deleted.
# Enable IPv6 route fast switchover.
[Sysname] ipv6 route fast-switchover enable
ipv6 route-direct track
Use ipv6 route-direct track to associate the IPv6 direct routes on an interface with a track entry and apply a cost value to the IPv6 direct routes after the track entry changes to Negative state.
Use undo ipv6 route-direct track to restore the default.
ipv6 route-direct track track-entry-number degrade-cost cost-value
The IPv6 direct routes on an interface are not associated with a track entry.
Interface view
track-entry-number: Specifies a track entry ID in the range of 1 to 1024.
degrade-cost cost-value: Specifies a cost value to apply to the IPv6 direct routes after the track entry changes to Negative state. The value range for the cost-value argument is 1 to 4294967295.
To change the track entry associated with the IPv6 direct routes on an interface, you must first execute the undo ipv6 route-direct track command to remove the original association. For more information about Track, see High Availability Configuration Guide.
# Associate the IPv6 direct routes on GigabitEthernet 1/0/1 with track entry 1 and apply cost 200 to the IPv6 direct routes after the track entry changes to Negative state.
[Sysname-GigabitEthernet1/0/1] ipv6 route-direct track 1 degrade-cost 200
maintenance-probe enable
Use maintenance-probe enable to enable maintenance probe (MTP).
Use undo maintenance-probe enable to disable MTP.
MTP is disabled.
MTP enables the device to automatically ping and tracert a neighbor upon expiration of the neighbor hold timer and record the ping and tracert results. To view detailed fault information, use the display commands of routing protocols, for example, the display bgp troubleshooting command. To view detailed MTP information, use the display logbuffer command.
# Enable MTP.
[Sysname] maintenance-probe enable
display logbuffer (Network Management and Monitoring Command Reference)
max-ecmp-num
Use max-ecmp-num to set the maximum number of ECMP routes.
max-ecmp-num number
The maximum number of ECMP routes is determined by the maximum number of ECMP routes supported by the system.
number: Specifies the maximum number of ECMP routes. The value range for this argument is 1 to 128.
# Set the maximum number of ECMP routes to 10.
[Sysname] max-ecmp-num 10
After reboot, the maximum number of ECMP routes is 10.
nexthop recursive-lookup restrain clear-interval
Use nexthop recursive-lookup restrain clear-interval to set the interval for clearing the recursion loop counter.
Use undo nexthop recursive-lookup restrain clear-interval to restore the default.
nexthop recursive-lookup restrain clear-interval interval
The interval for clearing the recursion loop counter is 600 seconds.
clear-interval interval: Specifies the interval for clearing the recursion loop counter, in the range of 1 to 65535 seconds.
Recursion loop suppression enables the system to use a counter to record the number of route recursion failures. When the counter reaches 20, the system suppresses route recursion for a specified period of time. When the suppression time expires, the system resets the counter and disables route recursion suppression.
# Set the interval for clearing the recursion loop counter to 100 seconds.
[Sysname] rib
[Sysname-rib-ipv4] nexthop recursive-lookup restrain clear-interval 100
nexthop recursive-lookup restrain disable
Use nexthop recursive-lookup restrain disable to disable the suppression for next hop recursion loop.
Use undo nexthop recursive-lookup restrain disable to enable the suppression for next hop recursion loop.
Suppression for next hop recursion loop is enabled.
A recursion loop occurs when a route recurses to a related route that recurses back to the route. It causes a route recursion failure and further lookup for a related route. If recursion loop persists, continuous route flapping will cause high system resource consumption and CPU utilization.
This command enables the system to use a counter to record the number of route recursion failures. When the counter reaches 20, the system suppresses route recursion for a specified period of time to save system resources on the device.
# Disable the suppression for next hop recursion loop.
[Sysname] rib
[Sysname-rib-ipv4] nexthop recursive-lookup restrain disable
non-stop-routing
Use non-stop-routing to enable RIB NSR.
Use undo non-stop-routing to disable RIB NSR.
non-stop-routing
RIB NSR is disabled.
# Enable NSR for the RIB IPv4 address family.
[Sysname] rib
[Sysname-rib-ipv4] non-stop-routing
primary-path-detect bfd
Use primary-path-detect bfd to enable BFD for primary route next hop detection of inter-protocol FRR or ECMP routes.
Use undo primary-path-detect bfd to disable BFD for primary route next hop detection of inter-protocol FRR or ECMP routes.
primary-path-detect bfd { ctrl | echo } [ inter-protocol-frr | protocol-ecmp protocol ]
undo primary-path-detect bfd [ inter-protocol-frr | protocol-ecmp protocol ]
BFD is disabled for primary route next hop detection of inter-protocol FRR or ECMP routes.
ctrl: Specifies the BFD control packet mode.
echo: Specifies the BFD echo packet mode.
inter-protocol-frr: Enables primary route next hop detection for inter-protocol FRR.
protocol-ecmp protocol: Enables primary route next hop detection for ECMP routes of a routing protocol.
· In RIB IPv4 address family view, the value for the protocol argument can be bgp, isis, ospf, or static.
· In RIB IPv6 address family view, the value for the protocol argument depends on the BFD mode.
¡ In BFD control packet mode, the value can be bgp4+, isisv6, ospfv3, or static.
¡ In BFD echo packet mode, the value can be bgp4+ or static.
After you configure this command, device automatically creates an IP FRR BFD session to detect the next hop availability of the primary route. Upon primary route next hop failure, traffic can be immediately switched to the backup route next hop for fast convergence.
· For inter-protocol FRR, the primary route is the route with the highest preference among the routes to the same destination.
· For ECMP routes of a routing protocol, the primary route is each ECMP route. If you specify the ecmp-shared keyword when configuring FRR for a routing protocol, the device will use the LFA algorithm to calculate backup next hops for each ECMP route. The routes destined for the backup next hops are also added to the routing table as ECMP routes and the state of these routes is backup. BFD does not detect these backup ECMP routes.
This command takes effect and automatically creates a BFD session only when the primary route exists and a backup next hop is generated for it.
You can execute this command multiple times to change the BFD mode (echo packet mode or control packet mode).
If you do not specify the inter-protocol-frr or protocol-ecmp keyword, the command applies to both inter-protocol FRR and ECMP routes. The command without the inter-protocol-frr and protocol-ecmp keywords takes precedence over that with the inter-protocol-frr or protocol-ecmp keyword. For example, if you have used the primary-path-detect bfd ctrl command, you can use only the following commands to modify or cancel the command configuration:
· primary-path-detect bfd echo.
· undo primary-path-detect bfd.
A control-packet-mode BFD session can be successfully established through negotiation between the two ends. To use a control-packet-mode BFD session to detect the primary route next hop availability, you must create a static BFD session that meets the following requirements on the next hop device:
· Create a single-hop BFD session in control packet mode.
· The source IP address of the BFD session is the destination IP address of the BFD session automatically created by the local end.
· The destination IP address of the BFD session is the source IP address of the BFD session automatically created by the local end.
· The remote discriminator of the BFD session is the local discriminator of the BFD session automatically created by the local end.
The local device can use a control-packet-mode BFD session to detect the primary route next hop only after you create the static BFD session on the primary route next hop device. For more information about creating static BFD sessions, see BFD configuration in High Availability Configuration Guide.
When another protocol (for example, BGP, OSPF, and IS-IS) uses BFD to detect the primary route next hop, it also automatically create a BFD session. If the next hop to be detected is the same as the next hop of the RIB primary route, the device does not repeatedly create the same type of BFD sessions. Instead, the device reuses the BFD session of other protocols.
# Enable control-mode BFD for primary link availability detection of IS-IS ECMP routes.
[Sysname] rib
[Sysname-rib-ipv4] primary-path-detect bfd ctrl protocol-ecmp isis
display ip routing-table
fast-reroute
protocol lifetime
Use protocol lifetime to set the maximum lifetime for IPv4 or IPv6 routes and labels in the RIB.
Use undo protocol lifetime to restore the default.
undo protocol protocol [ instance instance-name ] lifetime
The maximum lifetime for IPv4 or IPv6 routes and labels in the RIB is 900 seconds.
seconds: Specifies the maximum lifetime, in the range of 1 to 6000 seconds.
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. This argument applies only to the BGP protocol. If you do not specify a BGP instance, this command sets the maximum lifetime for all BGP instances in the RIB.
When GR is enabled, make sure the protocol can complete GR and install all route entries to the RIB within the lifetime configured in this command.
# Set the maximum lifetime for static routes and labels in the RIB to 60 seconds.
[Sysname] rib
[Sysname-rib-ipv4] protocol static lifetime 60
protocol nexthop recursive-lookup
Use protocol nexthop recursive-lookup to configure routing policy-based recursive lookup.
Use undo protocol nexthop recursive-lookup to remove the configuration.
protocol protocol nexthop recursive-lookup route-policy route-policy-name
undo protocol protocol nexthop recursive-lookup route-policy
Routing policy-based recursive lookup is not configured.
protocol: Specifies a routing protocol, which can be bgp or static in RIB IPv4 address family view or bgp4+ in RIB IPv6 address family view.
route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
Configure routing policy-based recursive lookup to control route recursion results. For example, when a route changes, the routing protocol has to perform a route recursion if the next hop is indirectly connected. The routing protocol might select an incorrect path, which can cause traffic loss. To prevent this problem, you can use a routing policy to filter out incorrect routes. The routes that pass the filtering of the routing policy will be used for route recursion.
The apply clauses in the specified routing policy cannot take effect.
Make sure a minimum of one related route can match the routing policy for correct traffic forwarding.
# Configure recursive lookup based on routing policy policy1 for static routes.
[Sysname] rib
[Sysname-rib-ipv4] protocol static nexthop recursive-lookup route-policy policy1
record-limit
Use record-limit to set the maximum number of RIB next hop records or route entry records.
Use undo record-limit to restore the default.
record-limit limit [ rib nib [ flush [ delete | update ] | receive [ add | delete | update ] ] ]
undo record-limit [ rib nib [ flush [ delete | update ] | receive [ add | delete | update ] ] ]
record-limit limit [ routing-table [ flush [ delete | update ] | notify [ delete | update ] | receive [ add | delete | update ] ] ]
undo record-limit [ routing-table [ flush [ delete | update ] | notify [ delete | update ] | receive [ add | delete | update ] ] ]
The maximum number of RIB next hop records or route entry records is 1000.
limit: Sets the maximum number of RIB next hop records or route entry records. The value range is 0 to 1000000. To disable recording for RIB next hops or route entries, set the value to 0. When the number of records reaches the maximum number, the system can record new next hops or route entries. However, the new next hop or route entry records overwrite the oldest next hop or route entry records.
rib nib: Sets the maximum number of RIB next hop records.
routing-table: Sets the maximum number of route entry records.
flush: Sets the maximum number of records flushed from RIB to FIB.
notify: Sets the maximum number of records reported by RIB to routing protocols.
receive: Sets the maximum number of records received by RIB from routing protocols.
add: Sets the maximum number of records that contain the add action.
update: Sets the maximum number of records that contain the update action. If you specify the flush or notify keyword, records that contain the add action are also counted into the update category.
delete: Sets the maximum number of records that contain the delete action.
Repeat the command to set the maximum number for different types of records.
If you do not specify the rib nib or routing-table keywords, the command sets the maximum number for all types of RIB next hop and route entry records.
If you do not specify the add, delete, or update keyword, the command sets the maximum number for records that contain the add, delete, and update actions.
# Set the maximum number of next hop records and route entry records to 100 in the IPv4 RIB.
[Sysname] rib
[Sysname-rib-ipv4] record-limit 100
# Set the maximum number of IPv4 route entry records to 200.
[Sysname] rib
[Sysname-rib-ipv4] record-limit 200 routing-table
# Set the maximum number of next hop records that contain the add action to 300. The records are received by IPv4 RIB from routing protocols.
[Sysname] rib
[Sysname-rib-ipv4] record-limit 300 rib nib receive
# Set the maximum number of route entry records that contain the update action to 400. The records are reported by IPv6 RIB to routing protocols.
[Sysname] rib
[Sysname-rib] address-family ipv6
[Sysname-rib-ipv6] record-limit 400 routing-table notify update
# Set the maximum number of next hop records that contain the delete action to 500. The records are flushed from IPv6 RIB to FIB.
[Sysname] rib
[Sysname-rib-ipv6] record-limit 500 rib nib flush delete
reset ip routing-table record
Use reset ip routing-table record to clear IPv4 routing entry records.
# Clear IPv4 routing entry records.
<Sysname> reset ip routing-table record
reset ip routing-table statistics protocol
Use reset ip routing-table statistics protocol to clear IPv4 route statistics.
reset ip routing-table statistics protocol [ vpn-instance vpn-instance-name ] { protocol | all }
reset ip routing-table [ all-routes | all-vpn-instance ] statistics protocol { protocol | all }
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command clears IPv4 route statistics for the public network.
all-routes: Clears route statistics for the public network and all VPN instances.
all-vpn-instance: Clears route statistics for all VPN instances.
protocol: Clears route statistics for a routing protocol.
all: Clears route statistics for all IPv4 routing protocols.
This command clears IPv4 route statistics for the public network if you do not specify the all-routes, vpn-instance, or all-vpn-instance keyword.
# Clear all IPv4 route statistics for the public network.
<Sysname> reset ip routing-table statistics protocol all
reset ipv6 rib nib record
Use reset ipv6 rib nib record to clear next hop records in the IPv6 RIB.
# Clear next hop records in the IPv6 RIB.
<Sysname> reset ipv6 rib nib record
reset ipv6 routing-table record
Use reset ipv6 routing-table record to clear IPv6 routing entry records.
# Clear IPv6 routing entry records.
<Sysname> reset ipv6 routing-table record
reset ipv6 routing-table statistics protocol
Use reset ipv6 routing-table statistics protocol to clear IPv6 route statistics.
reset ipv6 routing-table statistics protocol [ vpn-instance vpn-instance-name ] { protocol | all }
reset ipv6 routing-table [ all-routes | all-vpn-instance ] statistics protocol { protocol | all }
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command clears the IPv6 route statistics for the public network.
protocol: Clears route statistics for an IPv6 routing protocol.
all: Clears route statistics for all IPv6 routing protocols.
This command clears IPv6 route statistics for the public network if you do not specify the all-routes, vpn-instance, or all-vpn-instance keyword.
# Clear all IPv6 route statistics for the public network.
<Sysname> reset ipv6 routing-table statistics protocol all
reset rib nib record
Use reset rib nib record to clear next hop records in the IPv4 RIB.
# Clear next hop records in the IPv4 RIB.
<Sysname> reset rib nib record
rib
Use rib to enter RIB view.
Use undo rib to remove all configurations in RIB view.
rib
undo rib
# Enter RIB view.
[Sysname] rib
[Sysname-rib]
route-direct track
Use route-direct track to associate the IPv4 direct routes on an interface with a track entry and apply a cost value to the IPv4 direct routes after the track entry changes to Negative state.
Use undo route-direct track to restore the default.
The IPv4 direct routes on an interface are not associated with a track entry.
Interface view
degrade-cost cost-value: Specifies a cost value to apply to the IPv4 direct routes after the track entry changes to Negative state. The value range for the cost-value argument is 1 to 4294967295.
To change the track entry associated with the IPv4 direct routes on an interface, you must first execute the undo route-direct track command to remove the original association. For more information about Track, see High Availability Configuration Guide.
# Associate the IPv4 direct routes on GigabitEthernet 1/0/1 with track entry 1 and apply cost 200 to the IPv4 direct routes after the track entry changes to Negative state.
[Sysname-GigabitEthernet1/0/1] route-direct track 1 degrade-cost 200
routing-table limit
Use routing-table limit to set the maximum number of active IPv4/IPv6 routes supported by the device.
Use undo routing-table limit to restore the default.
The maximum number of active IPv4/IPv6 routes is not set for the device.
number: Specifies the maximum number of active IPv4/IPv6 routes supported by the device, in the range of 1 to 4294967295.
warn-threshold: Specifies an alarm threshold in the range of 1 to 100, in percentage. When the percentage of active routes exceeds the alarm threshold, the system generates a system log message but still accepts active routes. You can take relevant actions based on the message to save system resources. If the number of active routes reaches the maximum number, no more routes can be added and new routes are discarded.
simply-alert: Enables the device to still accept active routes but generate a log message when the number of active IPv4/IPv6 routes exceeds the maximum number.
Configuration in RIB IPv4 address family view limits the number of active IPv4 routes for the public network and all VPN instances.
Configuration in RIB IPv6 address family view limits the number of active IPv6 routes for the public network and all VPN instances.
If you execute this command multiple times in the same view, the most recent configuration takes effect.
# In RIB IPv4 address family view, set the maximum number of active IPv4 routes to 1000 for the public network and all VPN instances. The device still accepts new active routes but generates a system log message when the maximum number of active routes is exceeded.
[Sysname] rib
[Sysname-rib-ipv4] routing-table limit 1000 simply-alert
snmp-agent trap enable ipv6 rib
Use snmp-agent trap enable ipv6 rib to enable IPv6 RIB SNMP notifications.
Use undo snmp-agent trap enable ipv6 rib to disable IPv6 RIB SNMP notifications.
snmp-agent trap enable ipv6 rib [ cyclic-iterate-restrain | cyclic-iterate-restrain-clear | prefix-exceed | prefix-exceed-clear | prefix-threshold-exceed | prefix-thresholdexceed-clear | public-prefix-exceed | public-prefixexceed-clear | public-prefixthreshold-exceed | public-prefixthresholdexceed-clear | vrf-prefix-exceed | vrf-prefixexceed-clear | vrf-prefixthreshold-exceed | vrf-prefixthresholdexceed-clear ] *
undo snmp-agent trap enable ipv6 rib [ cyclic-iterate-restrain | cyclic-iterate-restrain-clear | prefix-exceed | prefix-exceed-clear | prefix-threshold-exceed | prefix-thresholdexceed-clear | public-prefix-exceed | public-prefixexceed-clear | public-prefixthreshold-exceed | public-prefixthresholdexceed-clear | vrf-prefix-exceed | vrf-prefixexceed-clear | vrf-prefixthreshold-exceed | vrf-prefixthresholdexceed-clear ] *
IPv6 RIB SNMP notifications are enabled.
cyclic-iterate-restrain: Specifies notifications for route recursion loop suppression.
cyclic-iterate-restrain-clear: Specifies notifications for clearance of route recursion loop suppression.
prefix-exceed: Specifies notifications when the total number of IPv6 route prefixes reaches the maximum value.
prefix-exceed-clear: Specifies notifications when the total number of IPv6 route prefixes drops below the maximum value.
prefix-threshold-exceed: Specifies notifications when the total number of IPv6 route prefixes reaches the alarm threshold.
prefix-thresholdexceed-clear: Specifies notifications when the total number of IPv6 route prefixes drops below the alarm threshold.
public-prefix-exceed: Specifies notifications when the number of IPv6 route prefixes in the public network instance reaches the maximum value.
public-prefixexceed-clear: Specifies notifications when the number of IPv6 route prefixes in the public network instance drops below the maximum value.
public-prefixthreshold-exceed: Specifies notifications when the number of IPv6 route prefixes in the public network instance reaches the alarm threshold.
public-prefixthresholdexceed-clear: Specifies notifications when the number of IPv6 route prefixes in the public network instance drops below the alarm threshold.
vrf-prefix-exceed: Specifies notifications when the number of IPv6 route prefixes in a single VPN instance reaches the maximum value.
vrf-prefixexceed-clear: Specifies notifications when the number of IPv6 route prefixes in a single VPN instance drops below the maximum value.
vrf-prefixthreshold-exceed: Specifies notifications when the number of IPv6 route prefixes in a single VPN instance reaches the alarm threshold.
vrf-prefixthresholdexceed-clear: Specifies notifications when the number of IPv6 route prefixes in a single VPN instance drops below the alarm threshold.
After you enable this feature, IPv6 RIB can generate notifications and send them to the SNMP module. For the IPv6 RIB notifications to be sent correctly, you must also configure SNMP on the device. For more information about configuring SNMP, see the network management and monitoring configuration guide for the device.
If you do not specify any parameters, the command enables or disables all IPv6 RIB SNMP notifications.
# Disable all IPv6 RIB SNMP notifications.
[Sysname] undo snmp-agent trap enable ipv6 rib
snmp-agent trap enable rib
Use snmp-agent trap enable rib to enable RIB SNMP notifications.
Use undo snmp-agent trap enable rib to disable RIB SNMP notifications.
snmp-agent trap enable rib [ cyclic-iterate-restrain | cyclic-iterate-restrain-clear | prefix-exceed | prefix-exceed-clear | prefix-threshold-exceed | prefix-thresholdexceed-clear | public-prefix-exceed | public-prefixexceed-clear | public-prefixthreshold-exceed | public-prefixthresholdexceed-clear | vrf-prefix-exceed | vrf-prefixexceed-clear | vrf-prefixthreshold-exceed | vrf-prefixthresholdexceed-clear ] *
undo snmp-agent trap enable rib [ cyclic-iterate-restrain | cyclic-iterate-restrain-clear | prefix-exceed | prefix-exceed-clear | prefix-threshold-exceed | prefix-thresholdexceed-clear | public-prefix-exceed | public-prefixexceed-clear | public-prefixthreshold-exceed | public-prefixthresholdexceed-clear | vrf-prefix-exceed | vrf-prefixexceed-clear | vrf-prefixthreshold-exceed | vrf-prefixthresholdexceed-clear ] *
prefix-exceed: Specifies notifications when the total number of IPv4 route prefixes reaches the maximum value.
prefix-exceed-clear: Specifies notifications when the total number of IPv4 route prefixes drops below the maximum value.
prefix-threshold-exceed: Specifies notifications when the total number of IPv4 route prefixes reaches the alarm threshold.
prefix-thresholdexceed-clear: Specifies notifications when the total number of IPv4 route prefixes drops below the alarm threshold.
public-prefix-exceed: Specifies notifications when the number of IPv4 route prefixes in the public network instance reaches the maximum value.
public-prefixexceed-clear: Specifies notifications when the number of IPv4 route prefixes in the public network instance drops below the maximum value.
public-prefixthreshold-exceed: Specifies notifications when the number of IPv4 route prefixes in the public network instance reaches the alarm threshold.
public-prefixthresholdexceed-clear: Specifies notifications when the number of IPv4 route prefixes in the public network instance drops below the alarm threshold.
vrf-prefix-exceed: Specifies notifications when the number of IPv4 route prefixes in a single VPN instance reaches the maximum value.
vrf-prefixexceed-clear: Specifies notifications when the number of IPv4 route prefixes in a single VPN instance drops below the maximum value.
vrf-prefixthreshold-exceed: Specifies notifications when the number of IPv4 route prefixes in a single VPN instance reaches the alarm threshold.
vrf-prefixthresholdexceed-clear: Specifies notifications when the number of IPv4 route prefixes in a single VPN instance drops below the alarm threshold.
After you enable this feature, RIB can generate notifications and send them to the SNMP module. For the RIB notifications to be sent correctly, you must also configure SNMP on the device. For more information about configuring SNMP, see the network management and monitoring configuration guide for the device.
If you do not specify any parameters, the command enables or disables all RIB SNMP notifications.
# Disable all RIB SNMP notifications.
[Sysname] undo snmp-agent trap enable rib
