- 01-Fundamentals Configuration Guide
- 01-CLI configuration
- 02-RBAC configuration
- 03-Login management configuration
- 04-FTP and TFTP configuration
- 05-File system management configuration
- 06-Configuration file management configuration
- 07-Software upgrade configuration
- 08-Automatic configuration
- 09-Target configuration management configuration
04-FTP and TFTP configuration | 199.47 KB |
Restrictions and guidelines: FTP configuration
Using the device as an FTP server
FTP server configuration tasks at a glance
Configuring client authentication and authorization
Configuring FTP server access control
Setting connection management parameters
Specifying an SSL server policy for SFTP connections
Setting the DSCP value for outgoing FTP packets
Configuring the alarm threshold and alarm clearance threshold for FTP login failures
Manually releasing FTP connections
Verifying and maintaining the FTP server
Example: Using the device as an FTP server
Using the device as an FTP client
FTP client configuration tasks at a glance
Establishing an FTP connection
Displaying command help information
Displaying directories and files on the FTP server
Managing directories on the FTP server
Managing directories on the FTP client
Working with files on the FTP server
Changing to another user account
Maintaining and troubleshooting the FTP connection
Terminating the FTP connection
Verifying and maintaining the FTP client
Example: Using the device as an FTP client
Restrictions and guidelines: TFTP configuration
Configuring the device as a TFTP server
Configuring and using the IPv4 TFTP client
Configuring and using the IPv6 TFTP client
Configuring FTP
About FTP
File Transfer Protocol (FTP) is an application layer protocol for transferring files from one host to another over an IP network. It uses TCP port 20 to transfer data and TCP port 21 to transfer control commands.
FTP is based on the client/server model. The device can act as the FTP server or FTP client.
FTP file transfer modes
FTP supports the following transfer modes:
· Binary mode—Used to non-text files, such as .app, .bin, and .btm files.
· ASCII mode—Used to transfer text files, such as .txt, .bat, and .cfg files.
When the device acts as the FTP client, you can set the transfer mode (binary by default). When the device acts as the FTP server, the transfer mode is determined by the FTP client.
FTP operation modes
FTP can operate in either of the following modes:
· Active mode (PORT)—The FTP server initiates the TCP connection. This mode is not suitable when the FTP client is behind a firewall, for example, when the FTP client resides in a private network.
· Passive mode (PASV)—The FTP client initiates the TCP connection. This mode is not suitable when the server does not allow the client to use a random unprivileged port greater than 1024.
FTP operation mode varies depending on the FTP client program.
When the device acts as the FTP server or client and the file system type of the disk where the flash directory resides is VFAT, a file cannot exceed 4 GB. If the size of a file exceeds 4 GB, the device will fail to write the file.
To use the device as an FTP server, you must enable the FTP server and configure authentication and authorization on the device. Other commands are optional.
To use the device as an FTP server, perform the following tasks:
2. Configuring client authentication and authorization
3. (Optional.) Configuring FTP server access control
4. (Optional.) Setting connection management parameters
5. (Optional.) Specifying an SSL server policy for SFTP connections
6. (Optional.) Setting the DSCP value for outgoing FTP packets
7. (Optional.) Manually releasing FTP connections
Enabling the FTP server
1. Enter system view.
2. Enable the FTP server.
ftp server enable
By default, the FTP server is disabled.
Perform this task on the FTP server to authenticate FTP clients and set the authorized directories that authenticated clients can access.
The following authentication modes are available:
· Local authentication—The device looks up the client's username and password in the local user account database. If a match is found, authentication succeeds.
· Remote authentication—The device sends the client's username and password to a remote authentication server for authentication. The user account is configured on the remote authentication server rather than the device.
The following authorization modes are available:
· Local authorization—The device assigns authorized directories to FTP clients based on the locally configured authorization attributes.
· Remote authorization—A remote authorization server assigns authorized directories on the device to FTP clients.
For more information about configuring authentication and authorization, see AAA in User Access and Authentication Configuration Guide.
Use ACLs to prevent unauthorized access.
When no ACL is applied, all FTP clients can access the FTP server. To control FTP access, specify an ACL that exists and has rules so that only FTP clients permitted by the ACL can access the FTP server. If you specify an ACL that does not exist or does not have rules, no FTP clients can access the FTP server.
If a VPN instance is specified in an ACL rule, the rule applies only to the packets of the VPN instance. If no VPN instance is specified in an ACL rule, the rule applies only to the packets on the public network.
The ACL takes effect only for FTP connections to be established. It does not affect existing FTP connections.
For more information about ACLs, see ACL and QoS Configuration Guide.
If you configure FTP server access control multiple times, the most recent configuration takes effect.
2. Use an ACL to control access to the FTP server.
ftp server acl { advanced-acl-number | basic-acl-number | ipv6 { advanced-acl-number | basic-acl-number } }
By default, no ACL is used for access control.
3. Enable logging for FTP login attempts that are denied by the FTP login control ACL.
ftp server acl-deny-log enable
By default, logging is disabled for FTP login attempts that are denied by the FTP login control ACL.
2. Set the FTP connection idle-timeout timer.
ftp timeout minutes
By default, the FTP connection idle-timeout timer is 30 minutes.
If no data transfer occurs on an FTP connection before the idle-timeout timer expires, the FTP server closes the FTP connection.
3. Set the maximum number of concurrent FTP users.
aaa session-limit ftp max-sessions
By default, the maximum number of concurrent FTP users is 32.
Changing this setting does not affect users who are currently online. If the new limit is less than the number of online FTP users, no additional FTP users can log in until the number drops below the new limit. For more information about this command, see User Access and Authentication Command Reference.
After you associate an SSL server policy with the device, a client that supports SFTP will establish a secure connection to the device to ensure data security.
2. Associate an SSL server policy with the FTP server to ensure data security.
ftp server ssl-server-policy policy-name
By default, no SSL server policy is associated with the FTP server.
2. Set the DSCP value for outgoing FTP packets.
IPv4:
ftp server dscp dscp-value
IPv6:
ftp server ipv6 dscp dscp-value
By default, the DSCP value is 0.
2. Set the alarm threshold and alarm clearance threshold for FTP login failures in a statistics period.
ftp server login-failed threshold-alarm upper-limit report-times lower-limit resume-times period period-time
By default, the statistics period is five minutes and the alarm threshold and alarm clearance threshold for FTP login failures in the statistics period is 30 and 20, respectively.
After you execute this command, if the number of FTP login failures reaches the alarm threshold in a statistics period, an alarm message is generated. If the number of FTP login failures drops below the alarm clearance threshold in a statistics period, an alarm clearance message is generated. This helps you obtain real-time information about FTP logins.
To manually release FTP connections, execute the following commands in user view:
· Release the FTP connection established by using a specific user account:
free ftp user username
· Release the FTP connection to a specific IP address:
free ftp user-ip [ ipv6 ] ip-address [ port port ]
Perform all display tasks in any view.
· Display FTP server configuration and status information.
display ftp-server
· Display detailed information about online FTP users.
display ftp-user
· Configure the device as an FTP server.
· Create a local user account named abc on the FTP server. Set the password to hello12345.
· Use the user account to log in to the FTP server from the FTP client.
· Upload the temp.bin file from the FTP client to the FTP server.
· Download configuration file startup.cfg from the FTP server to the FTP client for backup.
Configure IP addresses as shown in Figure 1. Make sure the device and PC can reach other.
1. Configure the device (FTP server):
# Create a local user named abc. Set the password to hello12345.
[Sysname] local-user abc class manage
[Sysname-luser-manage-abc] password simple hello12345
# Assign the network-admin user role to the user. Set the working directory to the root directory of the flash memory on the active MPU. ()
[Sysname-luser-manage-abc] authorization-attribute user-role network-admin work-directory flash:/
NOTE: To set the working directory to the root directory of the flash memory on the standby MPU, you must include the slot number in the directory path. |
# Assign the service type FTP to the user.
[Sysname-luser-manage-abc] service-type ftp
[Sysname-luser-manage-abc] quit
# Enable the FTP server.
[Sysname] ftp server enable
[Sysname] quit
# Examine the storage space for space insufficiency and delete unused files for more free space.
<Sysname> dir
Directory of flash:
0 drw- - Jan 29 2020 18:30:38 logfile
1 drw- - Jan 21 2020 14:51:38 diagfile
2 drw- - Jan 21 2020 14:51:38 seclog
3 -rw- 2943 Jan 02 2020 08:03:08 startup.cfg
4 -rw- 63901 Jan 02 2020 08:03:08 startup.mdb
5 -rw- 716 Jan 21 2020 14:58:02 hostkey
6 -rw- 572 Jan 21 2020 14:58:02 serverkey
7 -rw- 6541264 Jan 04 2020 20:40:49 backup.bin
473664 KB total (467080 KB free)
<Sysname> delete /unreserved flash:/backup.bin
2. Perform FTP operations from the PC (FTP client):
# Log in to the FTP server at 1.1.1.1 using username abc and password hello12345.
c:\> ftp 1.1.1.1
Connected to 1.1.1.1.
220 FTP service ready.
User(1.1.1.1:(none)):abc
331 Password required for abc.
Password:
230 User logged in.
# Use the ASCII mode to download configuration file startup.cfg from the device to the PC for backup.
ftp> ascii
200 TYPE is now ASCII
ftp> get startup.cfg back-startup.cfg
# Use the binary mode to upload the file temp.bin from the PC to the root directory of the flash memory on the active MPU.
ftp> binary
200 TYPE is now 8-bit binary
ftp> put temp.bin
# Exit FTP.
ftp> bye
1. Establishing an FTP connection
2. (Optional.) Displaying command help information
3. (Optional.) Displaying directories and files on the FTP server
4. (Optional.) Managing directories on the FTP server
5. (Optional.) Working with files on the FTP server
6. (Optional.) Changing to another user account
7. (Optional.) Maintaining and troubleshooting the FTP connection
8. (Optional.) Terminating the FTP connection
FTP connection establishment task list
To establish an FTP connection, perform the following tasks:
1. (Optional.) Specifying a source IP address for outgoing FTP packets
2. Establishing an FTP connection
3. Setting the FTP file transfer mode and operation mode
The source IP address specified in the ftp command takes precedence over the one set by the ftp client source command.
The source IP address specified in the ftp ipv6 command takes precedence over the one set by the ftp client ipv6 source command.
2. Specify a source IP address for outgoing FTP packets.
IPv4:
By default, no source IP address is specified. The device uses the primary IP address of the output interface as the source IP address.
IPv6:
ftp client ipv6 source { interface interface-type interface-number | ipv6 source-ipv6-address }
By default, no source IPv6 address is specified. The source address is automatically selected as defined in RFC 3484.
· Log in to the FTP server from user view.
IPv4:
ftp [ ftp-server [ service-port ] [ vpn-instance vpn-instance-name ] [ dscp dscp-value | source { interface interface-type interface-number | ip source-ip-address } | -d ] * ]
IPv6:
ftp ipv6 [ ftp-server [ service-port ] [ vpn-instance vpn-instance-name ] [ dscp dscp-value | source { interface interface-type interface-number | ipv6 source-ipv6-address } | -d ] * [ -i interface-type interface-number ] ]
· Log in to the FTP server from FTP client view.
a. Enter FTP client view.
ftp [ ipv6 ]
b. Log in to the FTP server.
open server-address [ service-port ]
1. Enter FTP client view from user view.
ftp
2. Set the file transfer mode.
¡ Set the file transfer mode to ASCII.
ascii
¡ Set the file transfer mode to binary.
binary
The default file transfer mode is binary.
3. Change the FTP operation mode.
passive
The default FTP operation mode is passive.
ftp
2. Display command help information.
¡ help [ command-name ]
¡ ? [ command-name ]
ftp
2. Display directories and files on the FTP server.
¡ dir [ remotefile [ localfile ] ]
¡ ls [ remotefile [ localfile ] ]
Use the dir or ls command to display the directories and files on the FTP server.
ftp
2. Manage directories on the FTP server.
¡ Display the working directory that is being accessed on the FTP server.
pwd
¡ Change the working directory on the FTP server.
cd { directory | .. | / }
¡ Return to the upper level directory on the FTP server.
cdup
¡ Create a directory on the FTP server.
mkdir directory
¡ Delete a directory from the remote FTP server.
rmdir directory
CAUTION: Delete a directory from the FTP server with caution. When you delete a directory from the FTP server, make sure the directory is no longer in use. |
ftp
2. Display or change the local working directory of the FTP client.
lcd [ directory | / ]
To upload a file, use this command to change to the directory where the file resides. Downloaded files are saved in the working directory.
ftp
2. Work with files on the FTP server.
¡ Delete a file from the FTP server permanently.
delete remotefile
CAUTION: Delete a file from the FTP server permanently with caution. When you delete a file from the FTP server permanently, make sure the file is no longer in use. |
This command requires that you have the delete right.
¡ Rename a file.
rename [ oldfilename [ newfilename ] ]
¡ Upload a file to the FTP server.
put localfile [ remotefile ]
¡ Download a file from the FTP server.
get remotefile [ localfile ]
¡ Add the content of a file on the FTP client to a file on the FTP server.
append localfile [ remotefile ]
¡ Specify the retransmit marker.
restart marker
Use this command together with the put, get, or append command.
¡ Update a local file.
newer remotefile
¡ Get the missing part of a file.
reget remotefile [ localfile ]
After you log in to the FTP server, you can initiate an FTP authentication to change to a new account. By changing to a new account, you can get a different privilege without re-establishing the FTP connection.
For successful account change, you must enter the new username and password correctly. A wrong username or password can cause the FTP connection to be disconnected.
ftp
2. Initiate an FTP authentication on the current FTP connection.
user username [ password ]
After you use the device to establish an FTP connection to the FTP server, use the commands in this section to locate and troubleshoot problems about the FTP connection.
ftp
2. Maintain and troubleshoot the FTP connection.
¡ Display FTP commands supported by the FTP server.
rhelp
¡ Display help information about an FTP command that is supported by the FTP server.
rhelp protocol-command
¡ Display FTP server status.
rstatus
¡ Display detailed information about a directory or file on the FTP server.
rstatus remotefile
¡ Display FTP connection status.
status
¡ Display the system information of the FTP server.
system
¡ Enable or disable FTP operation information display.
verbose
By default, this function is enabled.
¡ Enable FTP client debugging.
debug
By default, FTP client debugging is disabled.
¡ Clear the reply information in the buffer.
reset
ftp
2. Terminate the connection.
¡ Terminate the connection to the FTP server without exiting FTP client view.
disconnect
close
¡ Terminate the connection to the FTP server and return to user view.
bye
To display source IP address information on the FTP client, execute the following command in any view:
As shown in Figure 2, the PC is acting as an FTP server. A user account with username abc and password hello12345 has been created on the PC.
· Use the device as an FTP client to log in to the FTP server.
· Download the temp.bin file from the PC to the device.
· Upload configuration file startup.cfg from the device to the PC for backup.
Configure IP addresses as shown in Figure 2. Make sure the device and PC can reach each other.
# Examine the storage space of the device. If the free space is insufficient, use the delete /unreserved file command to delete unused files. (Details not shown.)
# Log in to the FTP server at 10.1.1.1 using username abc and password hello12345.
<Sysname> ftp 10.1.1.1
Press CTRL+C to abort.
Connected to 10.1.1.1 (10.1.1.1).
User (10.1.1.1:(none)): abc
Password:
230 Logged in successfully
Remote system type is MSDOS.
ftp>
# Set the file transfer mode to binary.
ftp> binary
# Download the temp.bin file from the PC to the root directory of the flash memory on the active MPU.
ftp> get temp.bin
local: temp.bin remote: temp.bin
150 Connecting to port 47457
226 File successfully transferred
23951480 bytes received in 95.399 seconds (251.0 kbyte/s)
# Download the temp.bin file from the PC to the root directory of the flash memory on the standby MPU (in slot 1).
ftp> get temp.bin slot1#flash:/temp.bin
# Use the ASCII mode to upload configuration file startup.cfg from the device to the PC for backup.
ftp> ascii
ftp> put startup.cfg back-startup.cfg
local: startup.cfg remote: back-startup.cfg
150 Connecting to port 47461
3494 bytes sent in 5.646 seconds (618.00 kbyte/s)
ftp> bye
221-Goodbye. You uploaded 2 and downloaded 2 kbytes.
221 Logout.
<Sysname>
Configuring TFTP
About TFTP
Trivial File Transfer Protocol (TFTP) is a simplified version of FTP for file transfer over secure reliable networks. TFTP uses UDP port 69 for data transmission. In contrast to TCP-based FTP, TFTP does not require authentication or complex message exchanges, and is easier to deploy. TFTP is suited for reliable network environments.
You can upload a file from the device to the TFTP server or download a file from the TFTP server to the device.
As a best practice to download a file, specify a nonexistent file name as the destination file name. If you download a file with a file name that exists in the target directory, the device deletes the existing file and saves the new one. If file download fails due to network disconnection or other reasons, the original file cannot be restored.
2. Enable the TFTP server.
tftp server enable
By default, the TFTP server is disabled.
The device can act as the TFTP server on both IPv4 and IPv6 networks.
3. Set the TFTP server working directory.
tftp server work-directory directory
By default, the TFTP server working directory is the root directory of the default file system.
Only a directory on the active MPU can be specified as the TFTP server working directory.
2. (Optional.) Use an ACL to control the client's access to TFTP servers.
tftp-server acl acl-number
3. Specify the source IP address for TFTP packets sent by the TFTP client.
4. Return to user view.
5. Download or upload a file in an IPv4 network.
tftp tftp-server { get | put | sget } source-filename [ destination-filename ] [ vpn-instance vpn-instance-name ] [ dscp dscp-value | source { interface interface-type interface-number | ip source-ip-address } ] * [ -d ]
The source IP address specified in this command takes precedence over the source IP address set by using the tftp client source command.
tftp-server ipv6 acl ipv6-acl-number
3. Specify the source IPv6 address for TFTP packets sent by the TFTP client.
tftp client ipv6 source { interface interface-type interface-number | ipv6 source-ipv6-address }
5. Download or upload a file in an IPv6 network.
tftp ipv6 tftp-server [ -i interface-type interface-number ] { get | put | sget } source-filename [ destination-filename ] [ vpn-instance vpn-instance-name ] [ dscp dscp-value | source { interface interface-type interface-number | ipv6 source-ipv6-address } ] * [ -d ]
The source IP address specified in this command takes precedence over the one set by the tftp client ipv6 source command.
