01-Fundamentals Command Reference
HomeSupportRoutersCR16000-M SeriesReference GuidesCommand ReferencesH3C CR16000-M Routers Command Reference-R8530Pxx-6W10101-Fundamentals Command Reference
11-Device management commands
11-Device management commands 898.96 KB
Device management commands· 1
clock datetime· 1
clock protocol 2
clock summer-time· 3
clock timezone· 4
command· 5
copyright-info enable· 6
display alarm·· 7
display alarm active· 7
display alarm history· 10
display clock· 12
display copyright 13
display cpu-usage· 13
display cpu-usage configuration· 14
display cpu-usage history· 15
display cpu-usage overload· 17
display cpu-usage overload summary· 19
display current energy-saving· 19
display device· 20
display device manuinfo· 21
display device manuinfo chassis-only· 22
display device manuinfo fan· 22
display device manuinfo power 23
display diagnostic-information· 23
display energy-saving mode· 25
display environment 26
display fan· 28
display fan-speed· 28
display hardware-failure-detection· 29
display hardware-failure-protection· 30
display health· 30
display kernel memory alloc-failure· 31
display kernel memory fragment free· 32
display memory· 33
display memory dma· 34
display memory-threshold· 35
display memory-threshold dma· 37
display non-stop-routing status· 37
display power 38
display power-off high-temp-board· 39
display power-information· 39
display resource-monitor 41
display scheduler job· 42
display scheduler logfile· 42
display scheduler reboot 43
display scheduler schedule· 44
display system stable state· 45
display transceiver alarm·· 46
display transceiver auto-laser-down· 51
display transceiver brief 52
display transceiver diagnosis· 54
display transceiver interface· 55
display transceiver itu-channel 56
display transceiver manuinfo· 58
display transceiver status· 58
display version· 60
display version-update-record· 60
display voltage· 61
energy-saving mode· 62
fan-speed· 63
fan-speed set-rate· 64
forward per-packet 64
forward-path-detection enable· 65
hardware-failure-detection· 66
hardware-failure-protection aggregation· 67
hardware-failure-protection auto-down· 68
header 68
itu-channel 69
job· 70
line-card-mode· 70
link-quality hardware-error enable· 71
memory-threshold· 72
memory-threshold dma· 73
memory-threshold usage· 74
memory-threshold usage resend-interval 75
monitor cpu-usage enable· 76
monitor cpu-usage interval 76
monitor cpu-usage threshold· 77
monitor disk-usage disk· 78
monitor disk-usage interval 79
monitor kernel memory fragment interval 80
monitor kernel memory fragment ratio· 80
monitor resend cpu-usage· 81
monitor resend cpu-usage core-interval 82
monitor resend memory-threshold· 83
monitor resend memory-threshold dma· 84
parity-error consistency-check log enable· 85
parity-error consistency-check threshold· 86
parity-error monitor log enable· 86
parity-error monitor period· 87
parity-error monitor threshold· 88
parity-error unrecoverable log enable· 89
parity-error unrecoverable period· 89
parity-error unrecoverable reboot 90
parity-error unrecoverable threshold· 91
password-recovery enable· 92
power control-mode· 93
power-off high-temp-board clear 93
power-off high-temp-board enable· 94
reboot 94
receive· 96
redundancy-power energy-saving· 96
reset alarm active· 97
reset scheduler logfile· 98
reset transceiver interface· 98
reset version-update-record· 98
resource-monitor minor resend enable· 99
resource-monitor output 100
resource-monitor resource· 100
restore factory-default 104
scheduler job· 105
scheduler logfile size· 105
scheduler reboot at 106
scheduler reboot delay· 107
scheduler schedule· 108
shutdown-interval 108
switch-fabric removal-signal-report enable· 109
sysname· 110
system forward-mode extended· 110
system turbo enable· 111
subslot-working-mode· 111
temperature-limit 112
time at 113
time once· 114
time repeating· 115
transceiver auto-laser-down· 117
transceiver auto-laser-down restart 118
transceiver auto-laser-down restart-mode· 119
transceiver lane cdr 120
transceiver lane enable· 121
transceiver power-mode· 122
user-role· 122
clock datetime
Use clock datetime to set the system time.
clock datetime time date
The factory-default system time is used.
time: Specifies a time in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
date: Specifies a date in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month.
CAUTION
CAUTION:
This command changes the system time, which affects the execution of system time-related features (for example, scheduled tasks) and collaborative operations of the device with other devices (for example, log reporting and statistics collection). Before executing this command, make sure you fully understand its impact on your live network.
Correct system time is essential to network management and communication. You must configure the system time correctly before you run the device on the network.
For the device to use the local system time, execute the clock protocol none command and this command in turn. The specified system time takes effect immediately. Then, the device uses the clock signals generated by its built-in crystal oscillator to maintain the system time.
If you set the time zone or daylight saving time after you execute this command, the device recalculates the system time. To view the system time, use the display clock command.
# Set the system time to 08:08:08 01/01/2012.
<Sysname> clock datetime 8:8:8 1/1/2012
# Set the system time to 08:10:00 01/01/2012.
<Sysname> clock datetime 8:10 2012/1/1
clock protocol
clock summer-time
clock timezone
display clock
clock protocol
Use clock protocol to specify the system time source.
Use undo clock protocol to restore the default.
clock protocol { none | { ntp | ptp } mdc mdc-id }
undo clock protocol
The device obtains the UTC time from an NTP time source.
none: Uses the system time set by using the clock datetime command.
ptp: Uses PTP to obtain the UTC time. You must configure PTP correctly. For more information about PTP and PTP configuration, see Network Management and Monitoring Configuration Guide.
ntp: Uses NTP to obtain the UTC time. You must configure NTP correctly. For more information about NTP and NTP configuration, see Network Management and Monitoring Configuration Guide.
mdc mdc-id: Specifies an MDC by its ID.
The device can use the locally set system time, or obtain the UTC time from a time source on the network and calculate the system time.
·     If you execute the clock protocol none command, the device uses the locally set system time. The device then uses the clock signals generated by its built-in crystal oscillator to maintain the system time.
·     If you execute the clock protocol { ntp | ptp } command, the device obtains the UTC time through NTP or PTP and calculates the system time. The device then periodically synchronizes the UTC time and recalculates the system time.
The system time calculated by using the UTC time from an NTP or PTP time source is more precise.
# Configure the device to use the local system time.
[Sysname] clock protocol none
clock summer-time
Use clock summer-time to set the daylight saving time.
Use undo clock summer-time to restore the default.
The daylight saving time is not set.
name: Specifies a name for the daylight saving time schedule, a case-sensitive string of 1 to 32 characters.
start-time: Specifies the start time in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
start-date: Specifies the start date in one of the following formats:
·     MM/DD. The value range for MM is 1 to 12. The value range for DD varies by month.
·     month week day, where:
¡     month—Takes January, February, March, April, May, June, July, August, September, October, November, or December.
¡     week—Represents week of the month. It takes first, second, third, fourth, fifth, or last.
¡     day—Takes Sunday, Monday, Tuesday, Wednesday, Thursday, Friday, or Saturday.
end-time: Specifies the end time in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
end-date: Specifies the end date in one of the following formats:
¡     month—Takes January, February, March, April, May, June, July, August, September, October, November or December.
add-time: Specifies the time to be added to the standard time, in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
After you set the daylight saving time, the device recalculates the system time. To view the system time, use the display clock command.
Make sure all devices on the network are using the same daylight saving time as the local time.
# Set the system time ahead 1 hour for the period between 06:00:00 on 08/01 and 06:00:00 on 09/01.
[Sysname] clock summer-time PDT 6 08/01 6 09/01 1
clock datetime
clock timezone
display clock
clock timezone
Use clock timezone to set the time zone.
Use undo clock timezone to restore the default.
undo clock timezone
The UTC time zone is used.
zone-name: Specifies a time zone by its name, a case-sensitive string of 1 to 32 characters.
add: Adds an offset to the UTC time or local system time.
minus: Decreases the UTC time or local system time by an offset.
zone-offset: Specifies the offset in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
After you set the time zone, the device recalculates the system time. To view the system time, use the display clock command.
Make sure all devices on the network are using the same time zone as the local time.
# Set the name of the time zone to Z5, and add 5 hours to the UTC time or local system time.
[Sysname] clock timezone Z5 add 5
clock datetime
clock summer-time
display clock
command
Use command to assign a command to a job.
Use undo command to revoke a command.
command id command
undo command id
No command is assigned to a job.
Job view
id: Specifies an ID for the command, in the range of 0 to 4294967295. A command ID uniquely identifies a command in a job. Commands in a job are executed in ascending order of their command IDs.
command: Specifies the command to be assigned to the job.
To assign a command (command A) to a job, you must first assign the job the command or commands for entering the view of command A.
If you specify the ID of an existing command for another command, the existing command is replaced.
Make sure all commands in a schedule are compliant to the command syntax. The system does not examine the syntax when you assign a command to a job.
If a command requires a yes or no answer, the system always assumes that a Y or Yes is entered. If a command requires a character string input, the system assumes that either the default character string (if any) or a null string is entered.
A job cannot contain the telnet, ftp, ssh2, or monitor process command.
# Assign commands to the backupconfig job to back up the startup.cfg file to the TFTP server at 192.168.100.11.
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig] command 2 tftp 192.168.100.11 put flash:/startup.cfg backup.cfg
# Assign commands to the shutdownGE job to shut down Ten-GigabitEthernet 3/0/1.
[Sysname] scheduler job shutdownGE
[Sysname-job-shutdownGE] command 1 system-view
[Sysname-job-shutdownGE] command 2 interface ten-gigabitethernet 3/0/1
[Sysname-job-shutdownGE] command 3 shutdown
scheduler job
Use copyright-info enable to enable copyright statement display.
Use undo copyright-info enable to disable copyright statement display.
Copyright statement display is enabled.
# Enable copyright statement display.
[Sysname] copyright-info enable
The device will display the following statement when a user logs in:
display alarm
Use display alarm to display alarm information.
display alarm [ slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays alarm information for all cards.
If a power module, CPU, or fan is operating abnormally on the device, you can use the display alarm command to view the alarm information. To view historical alarms that have been cleared, use the display alarm history command. To view active alarms that were generated in the past and have not been cleared on the device, use the display alarm active command.
# Display alarm information.
<Sysname> display alarm
Slot   CPU   Level   Info
2      0     ERROR   Board is faulty
Slot
Slot that generated the alarm. If the alarm was generated by the frame, this field displays a hyphen (-).
Level
Alarm severity. Possible values include ERROR, WARNING, NOTICE, and INFO, in descending order of severity.
Info
Detailed alarm information:
·     Board is faulty—The slot is starting up or faulty.
·     Fan n is absent—The specified fan is absent.
·     Power n is absent—The specified power supply is absent.
·     The temperature of sensor n exceeds the lower limit—The temperature of the specified sensor is lower than the low-temperature alarm threshold.
·     The temperature of sensor n exceeds the upper limit—The temperature of the specified sensor is higher than the high-temperature alarm threshold.
Use display alarm active to display information about active alarms.
display alarm active [ verbose ]
verbose: Displays detailed information. If you do not specify this keyword, this command displays brief information.
# Display information about active alarms.
<Sysname> display alarm active
Seq    Level    Time                  Info
24     WARNING  2020-01-11  12:40:00  CPU usage is in minor alarm state on slot 1.
23     WARNING  2020-01-11  12:30:00  Memory minor threshold has been exceeded on slot 1.
22     ERROR    2020-01-11  12:18:00  Board state changed to Fault on slot 1.
Seq
Alarm sequence number, assigned when an alarm occurs.
Level
Alarm severity. The values include Critical, Major, Minor, and Warning, in descending order of severity.
Time
Time when the alarm occurs.
Info
Detailed alarm information. The values include:
·     Board state changed to Fault on slot n—The state of the specified slot changed to Fault. The slot might be starting up or might be faulty.
·     Slot n fan n is absent—The specified fan is absent.
·     Slot n fan n is failed—The specified fan is abnormal.
·     Slot n power n is absent—The specified power module is absent.
·     Slot n power n failed—The specified power module is abnormal.
·     Temperature is higher than the high-temperature alarming threshold on slot n sensor inflow—The temperature of the specified sensor has exceeded the high-temperature warning threshold.
·     Memory minor threshold has been exceeded on slot n—The amount of free memory space on the specified slot has exceeded the minor alarm threshold.
·     CPU usage is in minor alarm state on slot n—The CPU usage on the specified slot has exceeded the minor alarm threshold.
·     Interface-name: RX power is high!—The optical power on the specified interface is too high.
·     Interface-name:The bit error ratio exceeds the upper threshold—The bit error rate of the specified interface has exceeded the upper limit.
·     SSH user username (IP: IP-Address) connected to the server successfully—The specified SSH user at the specified IP address has logged in to the server successfully.
·     Member port xx of aggregation group xx changed to the inactive state, because xx.—The specified member port of the specified aggregation group changed to inactive for a reason.
·     The mpls ldp session status changes. (SessionState=$1, DiscontinuityTime=$2, StatsUnknownMesTypeErrors=$3, StatsUnknownTlvErrors=$4)—The status of an LDP session changes:
¡     $1: LDP session status, including nonexistent, initialized, openrec, opensent, and operational.  For more information about LDP sessions states, see LDP commands in MPLS Command Reference.
¡     $2: Duration when the LDP session is in the operational state.
¡     $3: Times that the LDP session received unknown messages.
¡     $4: Times that the LDP session received unknown TLVs.
·     The number of routes received from the BGP peer exceeded the max number of routes that can be received from the peer. (Instance=$1, AFI=$2, SAFI=$3, PeerAddrType=$4, PeerAddr=$5, MaxRouteNum=$6)
¡     $1: BGP instance name.
¡     $2: Address Family Identifier (AFI).
¡     $3: Subsequent Address Family Identifier (SAFI).
¡     $4: IP type of the BGP peer.
¡     $5: IP address of the BGP peer.
¡     $6: The maximum number of routes that the device can receive from a BGP peer.
·     BGP $1.$2: The number of routes from peer $3 ($4-$5) exceeds the limit $6.
¡     $2: VPN instance name. For a log message on public network, this field is null.
¡     $3: IP address of the BGP peer.
¡     $4: Address Family Identifier (AFI).
¡     $5: Subsequent Address Family Identifier (SAFI).
¡     $6: The maximum number of route prefixes that can be received from the peer.
·     BGP $1.$2: The ratio of the number of routes received from peer $3 ($4-$5) to the number of allowed routes ($6) has reached the threshold ($7).
¡     $7: The number of routes received by the device when the percentage of received routes to the maximum number of allowed routes reaches the alarm threshold.
·     The number of routes received from the BGP peer exceeded the alarm threshold. (Instance=$1, AFI=$2, SAFI=$3, PeerAddrType=$4, PeerAddr=$5, MaxRouteNumber=$6, alarm threshold=$7).
# Display detailed information about active alarms.
<Sysname> display alarm active verbose
Seq 4
Alarm name: BoardStatus
Alarm source: slot 2
Level: Minor
Start time: 2022-05-16 18:58:46
  Info: Board state changed to Fault on slot 2.
Seq
Alarm source
Location where the alarm occurs.
Level
Start time
Info
display alarm
Use display alarm history to display information about historical alarms that have been cleared.
display alarm history [ verbose ]
If a power module, CPU, or fan is operating abnormally on the device, use the display alarm command to view the alarm information. To view historical alarms that have been cleared, use the display alarm history command. To view active alarms that were generated in the past and have not been cleared on the device, use the display alarm active command.
# Display brief information about historical alarms.
<Sysname> display alarm history
Seq        Time                  Info
23         2020-01-11 12:40:00 CPU usage recovered to normal state on slot 1.
For information about the fields in the command output, see Table 2.
# Display detailed information about historical alarms.
<Sysname> display alarm history verbose
Seq 23
Alarm name: CPUUsageMinor
Alarm position: slot 1
Start time: 2020-01-11 12:30:00
Level: Warning
Info: CPU usage is in minor alarm state on slot 1
Recovery time: 2020-01-11 12:40:30
Info: CPU usage minor alarm removed on slot 1.
Seq
Alarm sequence number, assigned automatically by the system when an alarm occurs.
AlarmPosition
Start time
Level
Recovery time
Time when an alarm is cleared.
Info
·     BGP $1.$2: The ratio of the number of routes received from peer $3 ($4-$5) to the number of allowed routes ($6) has fallen below the threshold ($7).
¡     $6: The maximum number of routes that can be received from the peer.
·     The number of routes received from the BGP peer decreased below the alarm threshold. (Instance=$1, AFI=$2, SAFI=$3, PeerAddrType=$4, PeerAddr=$5, MaxRouteNumber=$6, alarm threshold=$7).
·     The number of routes received from the BGP peer decreased below the max number of routes that can be received from the peer. (Instance=$1, AFI=$2, SAFI=$3, PeerAddrType=$4, PeerAddr=$5, MaxRouteNum=$6).
·     BGP $1.$2: The number of routes from peer $3 ($4-$5) fell below the limit $6.
display alarm
display clock
Use display clock to display the system time, date, time zone, and daylight saving time.
display clock
# Display the system time and date when the time zone is not specified.
<Sysname> display clock
10:09:00 UTC Fri 03/16/2015
The time is in the hour:minute:second.milliseconds format.
# Display the system time and date when the time zone Z5 is specified.
15:10:00 Z5 Fri 03/16/2015
Time Zone : Z5 add 05:00:00
# Display the system time and date when the time zone Z5 and daylight saving time PDT are specified.
15:11:00 Z5 Fri 03/16/2015
clock datetime
clock timezone
clock summer-time
display copyright
Use display copyright to display the copyright statement.
display copyright
# Display the copyright statement.
<Sysname> display copyright
display cpu-usage
Use display cpu-usage to display the current CPU usage statistics.
display cpu-usage [ summary ] [ slot slot-number [ cpu cpu-number [ core { core-number | all } ] ] ]
display cpu-usage [ control-plane ] [ summary ] [ slot slot-number [ cpu cpu-number ]
control-plane: Displays CPU usage statistics for the control plane.
summary: Displays CPU usage statistics in table form. If you do not specify this keyword, the command displays CPU usage statistics in text form.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the CPU usage statistics for all cards.
cpu cpu-number: Specifies a CPU by its number.
core core-number: Specifies a CPU core by its number.
core all: Specifies all CPU cores.
If two hyphens (--) are displayed for the CPU usage during the most recent 5-second, 1-minute, and 5-minute intervals, the command might fail to obtain data from the database on the device. Try the command later.
# Display the current CPU usage statistics in text form.
<Sysname> display cpu-usage
Slot 1 CPU 0 CPU usage:
       1% in last 5 seconds
       1% in last 1 minute
       1% in last 5 minutes
# Display the current CPU usage statistics in table form.
<Sysname> display cpu-usage summary
Slot CPU        Last 5 sec        Last 1 min        Last 5 min
1    0          17%               29%               28%
Table 5 Command output
x% in last 5 seconds
Last 5 sec
Average CPU or CPU core usage during the most recent 5-second interval.
y% in last 1 minute
Last 1 min
Average CPU or CPU core usage during the most recent 1-minute interval.
z% in last 5 minutes
Last 5 min
Average CPU or CPU core usage during the most recent 5-minute interval.
Use display cpu-usage configuration to display CPU usage monitoring settings.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the CPU usage monitoring settings for the active MPU.
# Display the CPU usage monitoring settings.
<Sysname> display cpu-usage configuration
CPU usage monitor is enabled.
Current monitor interval is 60 seconds.
Current severe alarm threshold is 99%.
Current minor alarm threshold is 79%.
Current recovery threshold is 69%.
Table 6 Command output
CPU usage monitor is xxx.
Whether CPU usage tracking is enabled.
Current monitor interval is xxx.
Sampling interval for CPU usage tracking.
Current severe alarm threshold is xxx.
Severe CPU usage alarm threshold.
Current minor alarm threshold is xxx.
Minor CPU usage alarm threshold.
Current recovery-threshold is xxx.
CPU usage recovery threshold.
Use display cpu-usage history to display the historical CPU usage statistics in a coordinate system.
job job-id: Specifies a process by its ID in the range of 1 to 2147483647. If you do not specify a process, this command displays the statistics for the entire system's CPU usage (the total CPU usage of all processes). To view the IDs and names of the running processes, use the display process command. For more information, see Network Management and Monitoring Configuration Guide.
slot slot-number: Specifies a card by its slot number. If you specify a process but do not specify a card, this command displays the statistics for the process on the active MPU. If you do not specify any options, this command displays the statistics for all processes on all cards.
cpu cpu-number: Specifies a CPU by its number. If you specify a process but do not specify a CPU, this command displays the statistics for the default CPU. If you do not specify a process or CPU, this command displays the historical statistics for all CPUs.
After CPU usage monitoring is enabled, the system regularly samples CPU usage and saves the samples to the history record buffer. This command displays the most recent 60 samples in a coordinate system as follows:
·     The vertical axis represents the CPU usage. If a statistic is not a multiple of the usage step, it is rounded up or down to the closest multiple of the usage step. For example, if the CPU usage step is 5%, the statistic 53% is rounded up to 55%, and the statistic 52% is rounded down to 50%.
·     The horizontal axis represents the time.
·     Pound signs (#) indicate the CPU usage. The value on the vertical axis for the topmost pound sign at a specific time represents the CPU usage at that time.
# Display the historical CPU usage statistics.
<Sysname> display cpu-usage history
100%|
 95%|
 90%|
 85%|
 80%|
 75%|
 70%|
 65%|
 60%|
 55%|
 50%|
 45%|
 40%|
 35%|
 30%|
 25%|
 20%|
 15%|             #
 10%|            ###  #
  5%|           ########
              10        20        30        40        50        60  (minutes)
                      cpu-usage (Slot 1 CPU 0) last 60 minutes (SYSTEM)
The output shows the following items:
·     Process name. The name SYSTEM represents the entire system.
·     CPU that is holding the process: CPU 0 in slot 1.
·     Historical CPU usage statistics for the entire system during the last 60 minutes.
¡     12 minutes ago—Approximately 5%.
¡     13 minutes ago—Approximately 10%.
¡     14 minutes ago—Approximately 15%.
¡     15 minutes ago—Approximately 10%.
¡     16 and 17 minutes ago—Approximately 5%.
¡     18 minutes ago—Approximately 10%.
¡     19 minutes ago—Approximately 5%.
¡     Other time—2% or lower.
Use display cpu-usage overload to display CPU overload records.
display cpu-usage overload show-number [ stack-info ] slot slot-number [ cpu cpu-number ]
show-number: Specifies the number of CPU overload records to be displayed, in the range of 1 to 10.
stack-info: Displays the stack information about the top three CPU resource-intensive processes. If you do not specify this keyword, the command does not display stack information.
# Display the most recent CPU overload record of a slot, excluding the stack information about the top three CPU resource-intensive processes.
<Sysname> display cpu-usage overload 2 slot 1
CPU overload summary information:
Slot/CPU          Time                     Overload status    Processes
1/0               0000-00-00 00:00:00:000  No overloaded      NA
No CPU overload history.
Table 7 Command output
Time
Time when the overload event occurred. If no overload events occurred, this field displays 0000-00-00 00:00:00:000.
Overload status
Overload status:
·     No overloaded—The CPU is not overloaded. This state is the initial state.
·     Minor alarm—The CPU load exceeded the minor alarm threshold.
·     Severe alarm—The CPU load exceeded the severe alarm threshold.
·     Recovered—The CPU load dropped below the CPU overload alarm-removed threshold.
Processes
Number of processes when the overload event occurred. If no overload events occurred, this field displays NA.
CPU overload history on overload time 2018-11-12 10:00:00:000:
Detailed CPU overload information. If no overload events occurred, this field displays No CPU overload history.
Overload time
Top processes in recent 5 secs
Top CPU resource-intensive processes in recent 5 seconds, in descending order.
JID
Job ID. A job ID uniquely identifies a process and does not change after a process reboot.
PID
Process ID.
PPID
ID of the parent process.
CPU
CPU where the process was running when it was most recently scheduled.
Process status:
·     R—The process is running or in the run queue.
·     S—The process is in interruptible sleeping state.
·     T—The process is in traced or stopped state.
·     D—The process is in uninterruptible sleeping state.
·     Z—The process is in zombie state.
Mem
Memory space used by the process. For a kernel thread, this field displays 0.
5sec
CPU utilization in the last 5 seconds.
1min
CPU utilization in the last minute.
5min
CPU utilization in the last 5 minutes.
Name
Process name. For a kernel thread, this field displays the name in a pair of brackets ([ ]).
Stack information of process PID (process name):
Stack information of a process. The PID indicates the process ID.
Thread LWP 1:
Child process of a traced process.
Switches
Total number of switches.
User stack
User space stack information. This field is displayed only for a process in the user space.
Kernel stack
Kernel space stack information. This field is displayed only for a process in the kernel space.
Use display cpu-usage overload summary to display summary CPU overload information.
# Display summary CPU overload information.
<Sysname> display cpu-usage overload summary
1/0               2018-11-12 12:00:00:000  Recovered          300
                  2018-11-12 11:00:00:000  Minor alarm        400
                  2018-11-12 10:00:00:000  Severe alarm       500
                  2018-11-12 09:00:00:000  Minor alarm        400
For information about the fields in the command output, see Table 7.
Use display current energy-saving to display information about the current energy saving mode and energy saving policies.
# Display information about the current energy saving mode and policies.
<Sysname> display current energy-saving
Current energy-saving mode: basic
 Enabled energy-saving policy including:
  Automatic-transceiver-laser-shutdown
  Redundant-power-modules-sleep
  Interface-auto-sleep
Table 8 Command output
Current energy saving policies that take effect, including:
·     Fan-auto—Fan speed adjustment.
·     Serdes-down—Serdes energy saving.
·     Interface-auto-sleep—Interface sleep.
·     slice-auto-sleep—Slice sleep.
·     Redundant-power-modules-sleep—Redundant power module sleep.
·     Power-auto-down—Power auto shutdown.
·     Halftone-warm-down—Warm standby of switching fabric modules.
·     Automatic-transceiver-laser-shutdown—Transceiver module sleep.
energy-saving mode
display device
Use display device to display device information.
display device [ cf-card | flash | sd-card ] [ slot slot-number | verbose ]
cf-card: Displays CF card information.
flash: Displays flash memory information.
sd-card: Displays SD card information.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays information for all cards.
verbose: Displays detailed information. If you do not specify this keyword, this command displays brief information, and does not display firewall card information.
If you do not specify the cf-card, flash, and sd-card keywords, this command displays information about cards.
# Display device information.
<Sysname> display device
Table 9 Command output
Brd Type
Hardware type of the card.
Brd Status
Card status:
·     Standby—The card is the standby MPU.
·     Master—The card is the active MPU.
·     Absent—The slot is not installed with a card.
·     Fault—The card is faulty and cannot start up.
·     Normal—The card is an interface card and is operating correctly.
·     Off—The card is not powered on.
·     Illegal—The current software version does not support the card. The card cannot operate correctly.
·     Offline—The card is isolated.
·     Mismatched—The card model is not supported on the device or the slot does not support the card.
Use display device manuinfo to display electronic label information for the device.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays electronic label information of all cards.
An electronic label contains the permanent configuration information, including the hardware serial number, manufacturing date, MAC address, and vendor name. The data is written to the storage component during hardware debugging or testing. This command displays only part of the electronic label information.
# Display electronic label information for the device.
<Sysname> display device manuinfo
Use display device manuinfo chassis-only to display electronic label information for the backplane.
# Display electronic label information for the backplane.
<Sysname> display device manuinfo chassis-only
Use display device manuinfo fan to display electronic label information for a fan tray.
display device manuinfo fan fan-id
fan-id: Specifies a fan tray by its ID.
# Display electronic label information for a fan tray.
<Sysname> display device manuinfo fan 1
Fan 1:
DEVICE_NAME          : fan
DEVICE_SERIAL_NUMBER : 210235A36L1234567890
MAC_ADDRESS          : NONE
MANUFACTURING_DATE   : 2010-01-20
VENDOR_NAME          : H3C
Use display device manuinfo power to display electronic label information for a power module.
display device manuinfo power power-id
power-id: Specifies a power module by its ID.
# Display electronic label information for a power module.
<Sysname> display device manuinfo power 1
Use display diagnostic-information to display or save operating information for features and hardware modules.
display diagnostic-information [  hardware | infrastructure | l2 | l3 | service ] [ key-info | verbose ] [ filename ] [ background ]
hardware: Specifies hardware-related operating information.
infrastructure: Specifies operating information for the fundamental features.
l2: Specifies operating information for the Layer 2 features.
l3: Specifies operating information for the Layer 3 features.
service: Specifies operating information for Layer 4 and upper-layer features.
key-info: Displays or saves only critical operating information. The device might have a large amount of operating information if an exception occurs or after the device runs a long period of time. Specifying this keyword reduces the command execution time and helps you focus on critical operating information. If you do not specify this keyword, the command displays or saves both critical and non-critical operating information.
verbose: Saves detailed operating information.
filename: Saves the information to a file. The filename argument must use the .tar.gz suffix. If you do not specify this argument, the command prompts you to choose whether to save the information to a file or display the information.
background: Saves operating information in the background. If you do not specify this keyword, the system displays or saves operating information in the CLI and you cannot execute other commands during the process. It is time consuming if a large amount of operating information is to be collected. If you specify this keyword, the system saves operating information in the background and users can execute other commands in the CLI during the process.
You can use one of the following methods to collect operating statistics for diagnostics and troubleshooting:
·     Use separate display commands to collect operating information feature by feature or module by module.
·     Use the display diagnostic-information command to collect operating information for multiple or all features and hardware modules.
To save storage space, the display diagnostic-information command automatically compresses information before saving information to a file. To view the file content:
1.     Use the tar extract command to extract the file.
2.     Use the gunzip command to decompress the extracted file.
3.     Use the more command to view the content of the decompressed file.
If you abort the display diagnostic-information command, the gunzip command might not be able to decompress the extracted file. To decompress the extracted file, export the extracted file to a PC that is running Linux, and use the gunzip -c command.
If you do not specify any feature parameters, this command displays or saves the operating information for all features and modules.
If you do not specify a file name for the command, the system prompts you to choose whether to display or save the information. If you choose to save the information, the system automatically assigns a file name and displays the file name in brackets. For file name uniqueness, the file name includes the device name and the current system time. If the device name contains any of the following special characters, the system uses an underscore (_) to replace each special character: forward slashes (/), backward slashes (\), colons (:), asterisks (*), question marks (?), less than signs (<), greater than signs (>), and pipeline signs (|). For example, if the device name is A/B, the device name in the file name will be A_B, as in flash:/diag_A_B_20160101-000438.tar.gz.
This command does not support the |, >, or >> option.
While the device is executing this command, do not execute any other commands. Executing other commands might affect the collected operating information.
# Display the operating information for all features and modules.
14:03:55 UTC Thu 01/05/2012
# Save the operating information for all features and modules to the default file.
Save or display diagnostic information (Y=save, N=display)? [Y/N]:y
Please input the file name(*.tar.gz)[flash:/diag_Sysname_20160101-024601.tar.gz]:
Diagnostic information is outputting to flash:/diag_Sysname_20160101-024601.tar.gz.
Please wait...
Save successfully.
Press Enter when the system prompts you to enter the file name.
# Save the operating information for all features and modules to the test.tar.gz file.
<Sysname> display diagnostic-information test.tar.gz
Diagnostic information is outputting to flash:/test.tar.gz.
Please wait...
Save successfully.
# Save the operating information in the background to the default file.
<Sysname> display diagnostic-information background
Please input the file name (*.tar.gz)[flash:/diag_Sysname_20201215-163501.tar.gz]:
Diagnostic information is outputting to flash:/diag_Sysname_20201215-163501.tar.gz in the background.
gunzip
more
tar extract
Use display energy-saving mode to display detailed information about the energy saving modes of the device.
display energy-saving mode [ standard | basic | deep ]
standard: Specifies the standard energy saving mode.
basic: Specifies the basic energy saving mode.
deep: Specifies the deep energy saving mode.
If you do not specify any keyword, this command displays detailed information about all energy saving mode.
# Display detailed information about all energy saving modes.
<Sysname> display energy-saving mode
Energy-saving mode: basic
Energy-saving mode: standard
  Fan-auto
# Display detailed information about the basic energy saving mode.
<Sysname> display energy-saving mode basic
Table 10 Command output
energy-saving mode
display environment
Use display environment to display temperature information.
This command displays information about all temperature sensors on the device if you do not specify a card.
# Display information about all temperature sensors on the device.
<Sysname> display environment
System temperature information (degree centigrade):
 Slot  Sensor    Temperature  Lower  Warning  Alarm  Shutdown
 0     inflow  1 25           0      48       60     NA
 0     hotspot 1 31           0      80       95     NA
 2     inflow  1 29           0      80       97     NA
 2     outflow 1 26           0      80       97     NA
 2     hotspot 1 31           0      80       97     NA
 2     hotspot 2 42           0      80       97     NA
 3     inflow  1 31           0      80       97     NA
 3     outflow 1 32           0      80       97     NA
 3     hotspot 1 47           0      80       97     NA
 3     hotspot 2 38           0      80       97     NA
 4     hotspot 1 30           0      75       90     NA
 6     hotspot 1 41           0      88       100    110
Table 11 Command output
System Temperature information (degree centigrade)
Temperature information (°C).
Slot
slot ID.
sensor
Temperature sensor:
·     hotspot—Hotspot sensor.
·     inflow—Air inlet sensor.
·     outflow—Air outlet sensor.
Temperature
Current temperature.
Lower
Lower temperature limit. If the device does not support this field, this field displays NA.
Warning
Warning temperature threshold. If the device does not support this field, this field displays NA.
Alarm
Alarming temperature threshold. If the device does not support this field, this field displays NA.
Shutdown
Shutdown temperature threshold. When the sensor temperature reaches the limit, the system shuts down automatically. If the device does not support this field, this field displays NA.
display fan
Use display fan to display fan tray operating status information.
display fan [ fan-id ]
fan-id: Specifies a fan tray by its ID. If you do not specify a fan tray, this command displays operating status information for all fan trays at the specified position.
# Display the operating states of all fan trays.
<Sysname> display fan
Fan Frame 0  State: Normal
Table 12 Command output
Fan Frame
Fan tray number.
Fan tray status:
·     Normal—The fan tray is operating correctly.
·     Fault—The fan tray is faulty.
·     Absent—The slot is not installed with a fan tray.
display fan-speed
Use display fan-speed to display the current fan operating mode and the speeds of fans
display fan-speed
# Display the current fan operating mode and the speeds of fans.
<Sysname> display fan-speed
Current fan speed mode is auto
Frame 0 fan 1 speed is 6097 (R.P.M)
Frame 0 fan 2 speed is 5530 (R.P.M)
Frame 0 fan 3 speed is 5647 (R.P.M)
Frame 1 fan 1 speed is 6177 (R.P.M)
Frame 1 fan 2 speed is 5530 (R.P.M)
Frame 1 fan 3 speed is 5673 (R.P.M)
Use display hardware-failure-detection to display the hardware failure detection settings and the latest 10 fix records for each card.
The fix records are stored on the active MPU. You can use this command to display the records for a card even if the card is removed or replaced. The fix records are lost only when you remove or power cycle the active MPU.
# Display hardware failure detection settings and fix records.
<Sysname> display hardware-failure-detection
Current level:
    chip       : warning
    board      : warning
    forwarding : warning
Recent record:
--------------------------Slot  0 executed records:-----------------------------
--------------------------Slot  0 trapped records:-----------------------------
Table 13 Command output
Current level
Fix actions specified for hardware failures.
chip
Fix action for hardware failures on components of cards.
board
Fix action for hardware failures on control paths.
forwarding
Fix action for hardware failures on the forwarding plane.
Recent record
Recent failure fix records.
xxx executed records
Fix records stored on an MPU.
xxx trapped records
Trap records stored on an MPU.
Use display hardware-failure-protection to display the hardware failure detection settings and the latest 10 fix records for each card.
display hardware-failure-protection [ aggregation | port { auto-down | interface-type interface-number } ]
aggregation: Displays the hardware failure protection settings for aggregation groups.
port: Displays the hardware failure protection settings for interfaces.
auto-down: Displays the interfaces on which hardware failure protection is enabled.
interface-type interface-number: Displays the hardware failure protection settings for an interface.
If you do not specify any option, the command displays all hardware failure protection settings on the device.
# Display all hardware failure protection settings.
<Sysname> display hardware-failure-protection
Aggregation: on
Port: XGE3/0/1     XGE3/0/2
# Display the interfaces on which hardware failure protection is enabled.
<Sysname> display hardware-failure-protection port auto-down
# Display whether hardware failure protection is enabled for interface Ten-GigabitEthernet 3/0/2.
<Sysname> display hardware-failure-protection port ten-gigabitethernet 3/0/2
Hardware failure protection is enabled on the interface. The system will shut down the interface when it detects a hardware failure on the interface.
Table 14 Command output
Aggregation
Whether hardware failure protection is enabled for aggregation groups.
Port
Interfaces on which hardware failure protection is enabled.
display health
Use display health to display CPU and memory usage.
display health [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays CPU and memory usage on all cards.
# Display the CPU and memory usage on all slots.
<Sysname> display health
Slot CPU Role         CPU Usage(%) Memory Usage(%) Used/Total(MB)
0    0   MPU(Master)  5            22              3549/15892
1    0   MPU(Standby) 0            21              3385/15892
10   0   LPU          24           36              2853/7872
11   0   LPU          12           35              2827/7872
Table 15 Command output
Role
Card role:
·     MPU(Master)—Active MPU.
·     MPU(Standby)—Standby MPU.
·     LPU—LPU.
CPU Usage(%)
Average CPU usage during the past 5 seconds, in percentage.
Memory Usage(%)
Memory usage in percentage.
Used/Total(MB)
Used memory size and total memory size in MB.
Use display kernel memory alloc-failure to display kernel memory allocation failure information.
display kernel memory alloc-failure [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays kernel memory allocation failure information for the active MPU.
# Display kernel memory allocation failure information.
<System> display kernel memory alloc-failure
kmalloc_tag failures: 55.
kcalloc_tag failures: 0.
kzalloc_tag failures: 0.
krealloc_tag failures: 0.
kmem_cache_alloc_tag failures: 0.
Table 16 Command output
Number of memory allocation failures on the use of kmalloc_tag.
Number of memory allocation failures on the use of kcalloc_tag.
Number of memory allocation failures on the use of kzalloc_tag.
Number of memory allocation failures on the use of krealloc_tag.
Number of memory allocation failures on the use of kmem_cache_alloc_tag.
Use display kernel memory fragment free to display the kernel memory fragment statistics.
display kernel memory fragment free [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays kernel memory fragment statistics for the active MPU.
# Display the kernel memory fragment statistics.
<Sysname> display kernel memory fragment free
Kernel memory free ratio:  0.13%
cfq_io_context                   memory free (in kbytes): 0
LFIB_NhlfeEntryCache26           memory free (in kbytes): 0
LFIB_NhlfeEntryCache74           memory free (in kbytes): 0
L2VFIB_TUNNELBMP_Cache           memory free (in kbytes): 0
NAT_SESSION_EXT_INFO             memory free (in kbytes): 0
ARP_VSISUP_Entry_cache           memory free (in kbytes): 0
LFIB_NhlfeEntryCache1            memory free (in kbytes): 0
FVN_FwdCache19                   memory free (in kbytes): 0
Table 17 Command output
Memory fragment ratio in the kernel space.
Memory fragment size in the slab named cfq_io_context, in KB.
display memory
Use display memory to display memory usage information.
summary: Displays brief information about memory usage. If you do not specify this keyword, the command displays detailed information about memory usage.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays memory usage for all cards.
If two hyphens (--) are displayed for all the fields in a line of the command output, the command might fail to obtain data from the database on the device. Try the command later.
# Display detailed memory usage information.
<Sysname> display memory
Memory statistics are measured in KB:
Slot 0:
             Total      Used      Free    Shared   Buffers    Cached   FreeRatio
Mem:      16274340   3701516  12572824         0      4080    344196       77.8%
-/+ Buffers/Cache:   3353240  12921100
Swap:            0         0         0
Slot 19:
Mem:       8061860   2703732   5358128         0         4    152328       66.5%
-/+ Buffers/Cache:   2551400   5510460
Swap:            0         0         0
# Display brief memory usage information.
<Sysname> display memory summary
Slot CPU        Total      Used      Free  Buffers    Caches FreeRatio
   0   0     16274340   3701456  12572884     4080    344196     77.8%
  19   0      8061860   2703676   5358184        4    152328     66.5%
Table 18 Command output
Mem
Memory usage information.
Total
Total size of the physical memory space that can be allocated.
The memory space is virtually divided into two parts. Part 1 is solely used for kernel code and kernel management functions. Part 2 can be allocated and used for such tasks as running service modules and storing files. The size of part 2 equals the total size minus the size of part 1.
Used
Used physical memory.
Free
Free physical memory.
Shared
Physical memory shared by processes.
If this field is not supported, two hyphens (--) are displayed.
Buffers
Physical memory used for buffers.
Cached
Caches
Physical memory used for caches.
FreeRatio
Free memory ratio.
-/+ Buffers/Cache
-/+ Buffers/Cache:used = Mem:Used – Mem:Buffers – Mem:Cached, which indicates the physical memory used by applications.
-/+ Buffers/Cache:free = Mem:Free + Mem:Buffers + Mem:Cached, which indicates the physical memory available for applications.
Swap
Memory space for swapping.
display memory dma
Use display memory dma to display DMA memory usage information.
display memory dma [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays DMA memory usage information for the active MPU.
# Display DMA memory usage information for slot 1.
<System> display memory dma slot 1
DMA memory statistics measured in KB on slot 1:
Total        Used         Free         FreeRatio
16384        6140         10244        63%
Table 19 Command output
Total
Total size of the DMA memory space, including the free and used DMA memory.
Used
Used DMA memory.
Free
Free DMA memory.
FreeRatio
Free DMA memory ratio.
Use display memory-threshold to display memory alarm thresholds and statistics.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the memory usage thresholds and statistics for the active MPU.
For more information about memory usage notifications, see log information containing MEM_EXCEED_THRESHOLD or MEM_BELOW_THRESHOLD.
# Display memory alarm thresholds and statistics.
<Sysname> display memory-threshold
Memory usage threshold: 100%
Free memory threshold:
     Minor: 64M
     Severe: 48M
     Critical: 32M
     Normal: 96M
Current memory state: Normal
Event statistics:
 [Back to normal state]
    First notification: 2012-5-15 09:21:35.546
    Latest notification: 2012-5-15 09:21:35.546
    Total number of notifications sent: 1
 [Enter minor low-memory state]
    First notification at: 2012-5-15 09:07:05.941
    Latest  notification at: 2012-5-15 09:07:05.941
 [Back to minor low-memory state]
    First notification at: 0.0
    Latest  notification at: 0.0
    Total number of notifications sent: 0
 [Enter severe low-memory state]
 [Back to severe low-memory state]
 [Enter critical low-memory state]
Table 20 Command output
Free-memory thresholds
    Minor
    Severe
    Critical
    Normal
    Early-warning
    Secure
Free-memory thresholds, including:
·     Minor—Minor alarm threshold in MB. If this field displays two hyphens (--), the device failed to obtain the minor alarm threshold.
·     Severe—Severe alarm threshold in MB. If this field displays two hyphens (--), the device failed to obtain the severe alarm threshold.
·     Critical—Critical alarm threshold in MB. If this field displays two hyphens (--), the device failed to obtain the critical alarm threshold.
·     Normal—Normal state threshold in MB. If this field displays two hyphens (--), the device failed to obtain the normal state threshold.
·     Early-warning—Early-warning threshold in MB. If this field displays two hyphens (--), the device failed to obtain the early-warning threshold.
·     Secure—Sufficient-memory threshold in MB. If this field displays two hyphens (--), the device failed to obtain the sufficient-memory threshold.
Current free-memory state
Current state of the free memory in the system:
·     Normal—Normal state.
·     Minor—Minor alarm threshold.
·     Severe—Severe alarm threshold.
·     Critical—Critical alarm threshold.
·     Normal (early-warning)—Early-warning threshold.
·     Normal (secure)—Sufficient-memory state.
Use display memory-threshold dma to display DMA memory alarm information.
display memory-threshold dma [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays DMA memory alarm information for the active MPU.
# Display DMA memory alarm information.
<Sysname> display memory-threshold dma
Free DMA memory thresholds:
    Critical: 2048KB
    Normal: 4096KB
Current DMA memory state: Normal
Free memory event statistics:
    First notification: 0.0
    Latest notification: 0.0
 [Entered to critcal state]
    First notificatio: 0.0
Use display non-stop-routing status to display nonstop routing (NSR) status information for modules that support the NSR feature.
# Display NSR status information for modules that support the NSR feature.
<Sysname> display non-stop-routing status
NSR status: Not ready
Module name(instance name/process ID)                Status
MSDP                                                 Not ready
OSPF(1)                                              Ready
OSPF(2)                                              Ready
BGP(default)                                         Ready
BGP(aaa)                                             Ready
PIM                                                  Not configured
Table 21 Command output
NSR status
Global NSR status:
·     Ready—NSR is in stable state for all NSR-enabled modules.
·     Not ready—NSR is not in stable state for one or more NSR-enabled modules.
·     Not configured—NSR is not enabled for any modules.
·     No standby—No backup hardware exists for NSR.
Name of an NSR-capable module and the instance name or process ID, for example, BGP(default) and OSPF(1). If there is no instance name or process, this field displays only the module name.
Status
NSR status:
·     Ready—NSR is in stable state status for the module.
·     Not ready—NSR is not in stable state for the module. You cannot perform a process switchover or active/standby switchover.
·     Not configured—NSR is not enabled for the module. You cannot perform a process switchover or active/standby switchover.
display power
Use display power to display power module information.
display power [ power-id ]
power-id: Specifies a power module by its ID. If you do not specify a power module, this command displays information about all power modules at the specified position.
# Display brief power supply information.
<Sysname> display power
 Power        0 State: Normal
 Power        1 State: Absent
 Power        2 State: Absent
 Power        3 State: Absent
Table 22 Command output
Power         n State
Power supply status.
·     Absent—The slot is not installed with a power supply.
·     Error—The power supply is faulty.
·     Normal—The power supply is operating correctly.
Use display power-off high-temp-board to display whether the overtemperature auto shutdown feature is enabled.
# Display whether the overtemperature auto shutdown feature is enabled.
<Sysname> display power-off high-temp-board
Power off high temperature board mode: Enable
Use display power-information to display power information about power supplies and cards.
display power-information [ verbose ]
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
# Display power information about power supplies and cards.
<Sysname> display power-information
Power control mode: strict
Device  power:  5000W
Surplus power:  2477W
Fan     power:   380W
Slot No.     Rated Power(W)    Actual Power(W)
 0           64                44         reserve  for  mainboard
 1           64                44         reserve  for  mainboard
 2           80                29
 4           80                34
 5           95                34
 6           80                28
 9           80                27
 10          800               161
 11          800               167
Table 23 Command output
Power control mode
Power control mode of cards:
·     loose.
·     strict.
Device Power
Rated power of the device.
Surplus power
Remaining power of the device.
Fan Power
Maximum fan power.
contain 100 reserve power
Reserved power of 100W.
Slot No.
Slot number of the card.
Rated Power(W)
Maximum card power.
Actual Power(W)
Actual card power.
Reserved power for the MPU.
Power No.
Slot number of the power supply.
Status
Input(V)
Input voltage of the power supply.
Output(V)
Output voltage of the power supply.
Input(A)
Input current of the power supply.
Output(A)
Output current of the power supply.
Input(W)
Input power of the power supply.
Output(W)
Output power of the power supply.
Current input total power
Total power of power supplies.
Current output total power
Total output power of power supplies.
Use display resource-monitor to display resource monitoring information.
display resource-monitor [ resource resource-name ] [ slot slot-number [ cpu cpu-number ] ]
resource resource-name: Specifies a resource type by its name.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays resource monitoring information for all cards.
# Display ARP resource monitoring information.
<Sysname> display resource-monitor resource arpnd
Minor alarms resending: Enabled
Slot 1:
Resource                         Minor Severe Free/Total
                                              (percentage)
arpnd                            50%   20%    99
Table 24 Command output
Status of the minor resource depletion alarm resending feature, Enabled or Disabled.
Resource
Monitored resource type.
Minor
Minor resource depletion threshold, in percentage.
Severe
Severe resource depletion threshold, in percentage.
Free/Total
(percentage)
Numbers of available resources and total resources, in percentage.
display scheduler job
Use display scheduler job to display job configuration information.
job-name: Specifies a job by its name, a case-sensitive string of 1 to 47 characters. If you do not specify a job, this command displays configuration information for all jobs.
# Display configuration information for all jobs.
<Sysname> display scheduler job
Job name: saveconfig
 copy startup.cfg backup.cfg
Job name: backupconfig
Job name: 123
// The output shows that the device has three jobs: the first has one command, the second does not have any commands, and the third has two commands. Jobs are separated by blank lines.
display scheduler logfile
Use display scheduler logfile to display job execution log information.
# Display job execution log information.
<Sysname> display scheduler logfile
Logfile Size: 1902 Bytes.
Job name        : shutdown
Schedule name   : shutdown
Execution time  : Tue Dec 27 10:44:42 2011
Completion time : Tue Dec 27 10:44:47 2011
<Sysname>system-view
[Sysname]interface rang ten-gigabitethernet 3/0/1 to ten-gigabitethernet 3/0/3
[Sysname-if-range]shutdown
Table 25 Command output
Logfile Size
Size of the log file, in bytes.
Schedule name
Schedule to which the job belongs.
Execution time
Time when the job was started.
Completion time
Time when the job was completed. If the job has never been executed or the job does not have any commands, this field is blank.
Job output
Commands in the job and their output.
reset scheduler logfile
display scheduler reboot
Use display scheduler reboot to display the automatic reboot schedule.
# Display the automatic reboot schedule.
<Sysname> display scheduler reboot
System will reboot at 16:32:00 05/23/2011 (in 1 hours and 39 minutes).
scheduler reboot at
scheduler reboot delay
display scheduler schedule
Use display scheduler schedule to display schedule information.
schedule-name: Specifies a schedule by its name, a case-sensitive string of 1 to 47 characters. If you do not specify a schedule, this command displays information about all schedules.
# Display information about all schedules.
<Sysname> display scheduler schedule
Schedule type        : Run once after 0 hours 2 minutes
Start time           : Tue Dec 27 10:44:42 2011
Last execution time  : Tue Dec 27 10:44:42 2011
Last completion time : Tue Dec 27 10:44:47 2011
Execution counts     : 1
shutdown                                          Successful
Table 26 Command output
Schedule type
Execution time setting of the schedule. If no execution time is specified, this field is not displayed.
Start time
Time to execute the schedule for the first time. If no execution time is specified, this field is not displayed.
Last execution time
Last time when the schedule was executed. If no execution time is specified, this field is not displayed. If the schedule has never been executed, "Yet to be executed" is displayed for this field.
Last time when the schedule was completed. If no execution time is specified, this field is not displayed.
Execution counts
Number of times the schedule has been executed. If the schedule has never been executed, this field is not displayed.
Job name
Name of a job under the schedule.
Result of the most recent execution:
·     Successful.
·     Failed.
·     Waiting—The device is executing the schedule and the job is waiting to be executed.
·     In process—The job is being executed.
·     -NA-—The execution time has not arrived yet.
To view information about whether the commands in the job has been executed and the execution results, execute the display scheduler logfile command.
display system stable state
Use display system stable state to display system stability and status information.
display system stable state[ summary ]
summary: Displays brief information about system stability and status, including system status, redundancy status, and NSR status. If you do not specify this keyword, the command displays detailed information about system status, redundancy status, and CPU role and status.
Before performing an MPU or switching fabric switchover, execute this command multiple times to identify whether the system is operating stably. If the value of the Redundancy State field is not Stable, you cannot perform a switchover.
The device/card startup process takes some time. If the values of the status fields do not change to Stable, execute this command multiple times to identify the devices/cards that are not in Stable state. You can also use other commands to identify the faulty components. For example:
·     Use the display device command to identify the device operating status.
·     Use the display system internal process state command in probe view to display service operating status.
# Display brief information about system stability and status.
<Sysname> display system stable state summary
System state      : Stable
Redundancy state  : No redundancy
NSR state         : No standby
# Display CPU status summary, redundancy status, and detailed information about CPU operation.
Redundancy state : No redundance
  Slot    CPU    Role       State
  0       0      Active     Stable
  2       0      Other      Stable
  3       0      Other      Stable
Table 27 Command output
System state
Operating status summary of all CPUs:
·     Stable—All CPUs are operating stably.
·     Not ready—The CPUs are not operating stably. At least one CPU is not operating stably.
Redundancy state
System redundancy status:
·     Stable—Both MPUs are operating stably. You can perform a switchover.
·     No redundance—The system has only one MPU. You cannot perform a switchover.
·     Not ready—The system is not operating stably. You cannot perform a switchover.
NSR state
Readiness of modules for nonstop routing:
·     Ready—NSR is operating correctly.
·     Not ready—The NSR is not operating correctly. You cannot perform a process or active/standby switchover.
·     No standby—No standby MPU exists.
·     Not configured—No module is enabled with NSR.
Role
Role of the card in the system:
·     Active—The card is the active MPU.
·     Other—The card is a service module.
Operating status of the card:
·     Stable—The card is operating stably.
·     Board inserted—The card has just been installed.
·     Kernel initiating—Card kernel is being initialized.
·     Service starting—Services are starting.
·     Service stopping—Services are stopping.
·     HA Batch backup—An HA batch backup is going on.
·     Interface data batch backup—An interface data batch backup is in progress.
·     Service module data batch backup—A service module data batch backup is in progress.
The object is not operating stably.
display device
display transceiver alarm
Use display transceiver alarm to display transceiver alarms.
display transceiver alarm { controller | interface }  [ interface-type interface-number ]
controller [ interface-type interface-number ]: Specifies a controller interface by its type and number. If no controller interface is specified, this command applies to all controller interfaces.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays the alarms present on every transceiver module.
You can use the display transceiver alarm command to display alarms present on transceiver modules.
If no error occurs, None is displayed. The following tables describe the alarm information that might be present on transceiver module.
Table 28 Command output on SFP/SFP28/SFP+/GBIC/SFF transceiver modules
RX signal loss
Receive signal loss.
RX power high alarm
Alarm on a high receive optical power.
RX power high warning
Early warning on a high receive optical power.
RX power low alarm
Alarm on a low receive optical power.
RX power low warning
Early warning on a low receive optical power.
TX fault
Transmit fault.
TX bias high alarm
Alarm on a high transmit bias current.
TX bias high warning
Early warning on a high transmit bias current.
TX bias low alarm
Alarm on a low  transmit bias current.
TX power high warning
Early warning on a high transmit optical power.
TX power high alarm
Alarm on a high transmit optical power.
TX power low alarm
Alarm on a low transmit optical power.
TX power low warning
Early warning on a low transmit optical power.
Temp high alarm
Alarm on a high temperature.
Temp high warning
Early warning on a high temperature.
Temp low alarm
Alarm on a low temperature.
Temp low warning
Early warning on a low temperature.
Voltage high alarm
Alarm on a high voltage.
Voltage high warning
Early warning on a high voltage.
Voltage low alarm
Alarm on a low voltage.
Voltage low warning
Early warning on a low voltage.
Transceiver info I/O error
N/A
Transceiver info checksum error
N/A
Transceiver type and port configuration mismatch
The transceiver type does not match port configuration.
Transceiver type not supported by port hardware
The transceiver type is not supported on the port.
RX CDR loss of lock
Receive CDR loss of lock, indicating poor signal.
TX CDR loss of lock
Transmit CDR loss of lock, indicating poor signal.
Table 29 Command output on QSFP+/QSFP28 transceiver modules
Temp high alarm
Temp high warning
Temp low alarm
Temp low warning
Voltage high alarm
Voltage low alarm
Voltage low warning
RX loss of signal(channel x)
Loss of receive signal in channel x.
TX fault(channel x)
Packet transmission fault in channel x.
TX loss of signal(channel x)
Loss of transmit signal in channel x.
RX power high(channel x)
Alarm on a high receive optical power in channel x.
RX power low(channel x)
Alarm on a low receive optical power in channel x.
TX power high alarm(channel x)
Alarm on a high transmit optical power in channel x.
TX power high warning(channel x)
Early warning on a high transmit optical power in channel x.
TX power low alarm(channel x)
Alarm on a low transmit optical power in channel x.
TX power low warning(channel x)
Early warning on a low transmit optical power in channel x.
TX bias high(channel x)
Alarm on a high bias current in channel x.
TX bias low(channel x)
Alarm on a low bias current in channel x.
N/A
N/A
Transceiver type and port configuration mismatched
Table 30 Command output on CFP transceiver modules
TX jitter PLL unlocked
Transmit Jitter PLL is out of lock.
TX CMU unlocked
Transmit CMU is out of lock.
Overloaded
Alarm on being overloaded.
Loss of REFCLK input
Alarm on loss of REFCLK input.
Channel signals out of alignment
Alarm on channel signals out of alignment.
PLD or flash initialization error
Power supply fault
N/A
CFP checksum error
N/A
TX bias high
TX bias low
Temp high
Temp low
Voltage high
Voltage low
RX signal loss in channel x
Receive signal loss in in channel x.
RX IC unlocked in channel x
Receive IC is out of lock in channel x.
RX FIFO error in channel x
Receive FIFO error in channel x.
TX signal loss in channel x
Transmit signal loss in channel x.
TX IC unlocked in channel x
Transmit IC is out of lock in channel x.
TX FIFO error in channel x
Transmit FIFO error in channel x.
APD supply fault in channel x
N/A
TEC fault in channel x
N/A
Wavelength unlocked in channel x
Optical signal wavelength is out of lock in channel x.
RX power high in lane x
Alarm on a high receive optical power in lane x.
RX power low in lane x
Alarm on a low receive optical power in lane x.
TX power high in lane x
Alarm on a high transmit optical power in lane x.
TX power low in lane x
Alarm on a low transmit optical power in lane x.
TX bias high in lane x
Alarm on a high bias current in lane x.
TX bias low in lane x
Alarm on a low bias current in lane x.
Temp high in lane x
Alarm on a high temperature in lane x.
Temp low in lane x
Alarm on a low temperature in lane x.
N/A
N/A
Table 31 Common alarms for XFP transceiver modules
RX signal loss
RX not ready
The receiving status is not ready.
RX CDR loss of lock
Receive CDR loss of lock.
RX power high alarm
RX power low alarm
TX not ready
The transmission status is ready.
TX fault
Transmit fault.
TX CDR loss of lock
Transmit CDR loss of lock.
TX bias high alarm
TX bias low alarm
TX bias low warning
Early warning on a low transmit bias current.
TX power high alarm
TX power low alarm
Module not ready
The module is not ready.
APD supply fault
Avalanche Photo Diode (APD) supply error.
TEC fault
Thermoelectric Cooler (TEC) error.
Wavelength unlocked
Optical signal wavelength is out of lock.
Temp high alarm
Temp high warning
Temp low alarm
Temp low warning
Voltage high alarm(3.3V)
Alarm on a high voltage (3.3 V).
Voltage high warning(3.3V)
Early warning on a high voltage (3.3 V).
Voltage low alarm(3.3V)
Alarm on a low voltage (3.3 V).
Voltage low warning(3.3V)
Early warning on a low voltage (3.3 V).
Voltage high alarm(5.5V)
Alarm on a high voltage (5.5 V).
Voltage high warning(5.5V)
Early warning on a high voltage (5.5 V).
Voltage low alarm(5.5V)
Alarm on a low voltage (5.5 V).
Voltage low warning(5.5V)
Early warning on a low voltage (5.5 V).
Voltage high alarm(1.8V)
Alarm on a high voltage (1.8 V).
Voltage high warning(1.8V)
Early warning on a high voltage (1.8 V).
Voltage low alarm(1.8V)
Alarm on a low voltage (1.8 V).
Voltage low warning(1.8V)
Early warning on a low voltage (1.8 V).
Voltage high alarm(5.2V)
Alarm on a high voltage (5.2 V).
Voltage high warning(5.2V)
Early warning on a high voltage (5.2 V).
Voltage low alarm(5.2V)
Alarm on a low voltage (5.2 V).
Voltage low warning(5.2V)
Early warning on a low voltage (5.2 V).
N/A
N/A
# Display the alarms present on the transceiver module in interface Ten-GigabitEthernet 3/0/1.
<Sysname> display transceiver alarm interface ten-gigabitethernet 3/0/1
Ten-GigabitEthernet3/0/1 transceiver current alarm information:
  RX signal loss
  RX power low
Table 32 Command output
Alarms present on the transceiver module.
RX signal loss
Input signal loss occurred.
RX power low
Received power is low.
display transceiver auto-laser-down
Use display transceiver auto-laser-down to display information about auto laser shutdown.
display transceiver auto-laser-down { controller | interface } [ interface-type interface-number ]
controller [ interface-type interface-number ]: Specifies a controller interface by its type and number. If no contoller interface is specified, this command applies to all controller interfaces.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command applies to all interfaces.
# Display information about auto laser shutdown for the transceiver module in interface Ten-GigabitEthernet 3/0/1.
<Sysname> display transceiver auto-laser-down interface ten-gigabitethernet 3/0/1
Interface                Auto-laser-down    Laser    Restart    Interval(s)    Width(s)
                         status             status   mode
Ten-GigabitEthernet3/0/1     Enabled            On       Auto        100           2
Table 33 Command output
Auto-laser-down status
Whether auto laser shutdown is enabled:
·     Enabled.
·     Disabled.
Laser status
Whether the transceiver laser is emitting light:
·     On—The laser is emitting light.
·     Off—The laser is not emitting light.
Restart mode
Restart mode of the transceiver laser:
·     Auto.
·     Manual.
Interval(s)
Interval between laser emissions after the laser restart, in seconds.
Width(s)
Pulse width (duration) of each light emission for detection after the laser restart, in seconds.
display transceiver brief
Use display transceiver brief to display information about all transceiver modules, including transceiver module types, receive power, and transmit power.
# Display transceiver module types, receive power, and transmit power of all transceiver modules on the device.
<Sysname> display transceiver brief
Interface  TransceiverType  WaveL(nm)  Mode  Rx(dBm)            Tx(dBm)            Status
                                            Current/Range       Current/Range
XGE3/0/1   10G-10km-QSFPDD  1310      SM    -15.0/[-18.5,-3.0]  -15.0/[-18.5,-3.0]  Normal
XGE3/0/2   10G-10km-QSFPDD  1310      SM    -15.0/[-18.5,-3.0]  -29.0/[-18.5,-3.0]  Beyond threshold
XGE3/0/3   10G-10km-QSFPDD  1310      SM    NA/[-18.5,-3.0]     NA/[-18.5,-3.0]     Unknown
HGE4/0/4   100G-10km-QSFPDD 1310     SM   -15.0/[-18.5,-3.0]  -29.0/[-18.5,-3.0]   Normal
Table 34 Command output
Abbreviated Interface name.
Type of the transceiver module, consisting of the rate, transmission distance, and interface type. Two hyphens (--) indicate that the device failed to obtain data or the transceiver module does not support obtaining type information.
WaveL
Wavelength of the interface. Two hyphens (--) indicate that the device failed to obtain data or the transceiver module does not support obtaining wavelength information.
Mode
Mode of the transceiver module:
·     MM—Multi-mode.
·     SM—Single mode.
·     Two hyphens (--)—The device failed to obtain data or the transceiver module does not support obtaining mode information.
Rx(dBm)
Current/Range
Current receive power/normal receive power range. Two hyphens (--) indicate that the device failed to obtain data or the transceiver module does not support obtaining power information. N/A indicates that the obtained power value is invalid.
Tx(dBm)
Current/Range
Current transmit power/normal transmit power range. Two hyphens (--) indicate that the device failed to obtain data or the transceiver module does not support obtaining power information. N/A indicates that the obtained power value is invalid.
Status
Current power status:
·     Normal—The power is in the normal range.
·     Beyond threshold—The power exceeds the normal range.
·     Unknown—The status is unknown.
·     Two hyphens (--)—The device failed to obtain data or the transceiver module does not support obtaining status information.
display transceiver diagnosis
Use display transceiver diagnosis to display the current values of the digital diagnosis parameters on transceiver modules.
display transceiver diagnosis { controller | interface } [ interface-type interface-number ]
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays the current values of the digital diagnosis parameters on every transceiver module.
# Display the current values of the digital diagnosis parameters on the transceiver module in interface Ten-GigabitEthernet 3/0/1.
<Sysname> display transceiver diagnosis interface ten-gigabitethernet 3/0/1
Ten-GigabitEthernet3/0/1 transceiver diagnostic information:
    Temp(°C)  Voltage(V)  Bias(mA)  RX power(dBm)  TX power(dBm)
    36        3.31        6.13      -35.64          -5.19
  Alarm thresholds:
           Temp(°C)   Voltage(V)  Bias(mA)  RX power(dBM)  TX power(dBM)
    High   50         3.55        1.44      -10.00         5.00
    Low    30         3.01        1.01      -30.00         0.00
  Warning thresholds:
    High   45         3.25        1.25      -15.00         4.00
    Low    25         2.85        0.85      -25.00         1.00
# Display the current values of the digital diagnosis parameters on the QSFP28 transceiver module in interface HundredGigE3/0/1.
<Sysname> display transceiver diagnosis interface hundredgige 3/0/1
HundredGigE3/0/1 transceiver diagnostic information:
[ module]  Temp.(°C) Voltage(V)     Total RX power(dBm)   Total TX power(dBm)
          29         3.33          -33.61                8.41
[channel] Bias(mA)  RX power(dBm)  TX power(dBm)
    1     0.00      -36.96         -36.96
    2     0.00      -36.96         -36.96
    3     0.00      -36.96         -36.96
    4     0.00      -36.96         -36.96
  Alarm thresholds:
          Temp.(°C) Voltage(V)  Bias(mA)  RX power(dBm)  TX power(dBm)
    High  75         3.47        13.00     3.40           5.00
    Low   -5         3.13        3.00      -14.00         -10.00
  Warning thresholds:
    High  70         3.45        11.00     2.40           3.00
    Low   0          3.15        5.00      -11.00         -8.00
  Total average launch power(dBm): 5.90
Table 35 Command output
Digital diagnosis information for the transceiver module in the interface.
Temp.(°C)
Temperature in °C, accurate to 1°C.
Voltage(V)
Voltage in V, accurate to 0.01 V.
Total RX power(dBm)
Total receive power in dBm, accurate to 0.01 dBm.
Total TX power(dBm)
Total transmit power in dBm, accurate to 0.01 dBm.
Bias(mA)
Bias current in mA, accurate to 0.01 mA.
RX power(dBm)
Receive power in dBm, accurate to 0.01 dBm.
TX power(dBm)
Transmit power in dBm, accurate to 0.01 dBm.
Total average launch power on the multi-lane transceiver module in dBM, accurate to 0.01 dBm.
display transceiver interface
Use display transceiver interface to display the key parameters of transceiver modules.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If you do not specify an interface, this command displays the key parameters of every transceiver module.
# Display the key parameters of the transceiver module in interface Ten-GigabitEthernet 3/0/1.
<Sysname> display transceiver interface ten-gigabitethernet 3/0/1
Ten-GigabitEthernet3/0/1 transceiver information:
  Transceiver Type              : 1000_BASE_SX_SFP
  Connector Type                : LC
  Wavelength(nm)                : 850
  Transfer Distance(m)          : 550(50um),275(62.5um)
  Digital Diagnostic Monitoring : YES
  Vendor Name                   : H3C
Table 36 Command output
Connector Type
Connector types:
·     SC—Fiber connector developed by NTT.
·     LC—1.25 mm/RJ-45 fiber connector developed by Lucent.
·     RJ-45.
·     CX 4.
Wavelength(nm)
Central wavelength (in nm) of the transmit laser. If the transceiver supports multiple wavelengths, every two wavelength values are separated by a comma.
For a copper cable, this field displays N/A.
Transfer Distance(xx)
Transmission distance, where xx indicates the distance unit:
·     km—Kilometers, for single-mode transceiver modules.
·     m—Meters, for other transceiver modules.
If the transceiver module supports multiple types of transmission media, this field displays the transmission distance for each type, in the form of transmission distance (medium type).
Transmission medium types include:
·     9 um—9/125 µm single-mode fiber.
·     50 um—50/125 µm multi-mode OM2 fiber.
·     62.5um—62.5/125 um multi-mode OM1 fiber.
·     CX4—CX4 cable.
·     OM3—50 um multi-mode OM3 fiber.
·     OM4—50 um multi-mode OM4 fiber.
·     OM5—50 um multi-mode OM5 fiber.
·     STACK—Stack cable.
·     TP—Twisted pair.
Support for digital diagnosis:
·     YES—Supported.
·     NO—Not supported.
display transceiver itu-channel
Use display transceiver itu-channel to display ITU channel information for transceiver modules.
display transceiver itu-channel { controller | interface } [ interface-type interface-number [ supported-channel ] ]
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays ITU channel information for all transceiver modules.
supported channel: Specifies ITU channels supported on the interface. If this keyword is not specified, the command displays the ITU channel that is being used on the interface.
This command is available only for the HPE X130 10G SFP+ LC LH80 Tunable Transceiver (JL250A), SFP-XG-LH80-Tunable, and CFP2-200G-DCO-Tunable transceiver modules.
# Display ITU channels used by the transceiver module in interface Ten-GigabitEthernet 3/0/1.
<Sysname> display transceiver itu-channel interface ten-gigabitethernet 3/0/1
Interface                           Channel        WaveLength(nm)  Frequency(THz)
XGE3/0/1                              1              1566.72         191.35
# Display ITU channels supported by the transceiver module in interface Ten-GigabitEthernet 3/0/1.
<Sysname> display transceiver itu-channel interface ten-gigabitethernet 3/0/1 supported-channel
ITU channel settings supported on ten-gigabitethernet 3/0/1 :
1          1566.72           191.35
2          1566.31           191.40
3          1565.90           191.45
4          1565.50           191.50
5          1565.09           191.55
6          1564.68           191.60
7          1564.27           191.65
8          1563.86           191.70
Table 37 Command output
WaveLength(nm)
Wavelength of the channel in nm, accurate to 0.01 nm. This field displays a hyphen (-) in the following situations:
·     No transceiver module is installed on the interface.
·     The transceiver module does not support specifying an ITU channel number.
·     The command failed to obtain the ITU channel information.
·     The device does not support the ITU channel number stored on the transceiver module.
Frequency(THz)
Frequency of the channel in THz, accurate to 0.01 THz. This field displays a hyphen (-) in the following situations:
itu-channel
display transceiver manuinfo
Use display transceiver manuinfo to display electronic label information for transceiver modules.
display transceiver manuinfo { controller | interface } [ interface-type interface-number ]
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays electronic label information for all transceiver modules.
# Display electronic label information for the transceiver module in interface Ten-GigabitEthernet 3/0/1.
<Sysname> display transceiver manuinfo interface ten-gigabitethernet 3/0/1
Ten-GigabitEthernet3/0/1 transceiver manufacture information:
  Manu. Serial Number  : 213410A0000054000251
  Manufacturing Date   : 2012-09-01
  Vendor Name          : H3C
Table 38 Command output
Manu. Serial Number
Serial number generated during production of the transceiver module.
Manufacturing Date
Date when the electronic label information was written to the transceiver module.
display transceiver status
Use display transceiver status to display transceiver module status information.
display transceiver status { controller | interface } [ interface-type interface-number ]
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If you do not specify an interface, this command applies to all interfaces.
If an error occurs on transceiver modules on the device, you can execute this command to obtain transceiver module status information. For example, you can identify whether a transceiver module is reset, power mode of a transceiver module, and operation information of each lane on the transceiver module.
This command is supported only on the SFP and QSFP transceiver modules
# Display status information for the QSFP transceiver module in interface HundredGigE 3/0/1.
<Sysname> display transceiver status interface hundredgige 3/0/1
HundredGigE3/0/1 transceiver status information:
  Initialization Complete Flag : Finish
  Power Mode                   : High
  Lane      Tx Disable     Tx CDR         Rx CDR
  Lane1     Yes            ON             OFF
  Lane2     Yes            ON             OFF
  Lane3     Yes            ON             OFF
  Lane4     Yes            ON             OFF
Table 39 Command output
Whether the transceiver module has finished initialization:
·     Finish—The initialization has finished.
·     Unkown—No initialization status is detected.
Power Mode
Power mode of the transceiver module:
·     High.
·     Low.
Tx Disable
Whether packet transmission is enabled for a lane:
·     Yes—Packet transmission is disabled.
·     No—Packet transmission is enabled.
Tx CDR
Whether CDR on the transmit side is enabled:
·     On—Tx CDR is enabled.
·     Off—Tx CDR is disabled.
Rx CDR
Whether CDR on the receive side is enabled:
·     On—Rx CDR is enabled.
·     Off—Rx CDR is disabled.
Lane
Lane ID.
# Display status information for the SFP transceiver module in interface Ten-GigabitEthernet 3/0/1.
<Sysname> display transceiver status interface ten-gigabitethernet 3/0/1
Ten-GigabitEthernet3/0/1 transceiver status information:
Hardware Tx Disable          : YES
Table 40 Command output
Hardware Tx Disable
Whether packet transmission is enabled for a lane via hardware pins:
reset transceiver interface
transceiver cdr
display version
Use display version to display system version information.
display version
# Display system version information.
<Sysname> display version
display version-update-record
Use display version-update-record to display startup software image upgrade records.
The device records its current startup software version information whenever it starts up, and records all software version update information. Such information can survive reboots.
# Display the startup software image upgrade records.
<Sysname> display version-update-record
Record 1  (updated on Apr 18 2014 at 06:23:54):
 *Name        : boot-test.bin
  Version     : 7.1.053 Alpha 7153
  Compile time: Mar 25 2014 15:52:43
 *Name        : system-test.bin
Table 41 Command output
Record n
Number of the startup software image upgrade record. Record 1 is the most recent record.
Name
Software image file name.
The software image version changed during the upgrade.
reset version-update-record
display voltage
Use display voltage to display voltage information.
display voltage [ slot slot-number ]
If you do not specify a card, this command displays voltage information for all cards.
If the voltage is lower than the lower limit or higher than the higher limit, the device sends a log message and a trap.
# Display voltage information.
<Sysname> display voltage
System voltage information (volt):
Slot Sensor Voltage Status Required LowLimit HighLimit Description
1    0      0.763   Normal 0.750    0.675    0.825     0.75
1    1      1.051   Normal 1.050    0.945    1.155     1.05
Table 42 Command output
Slot
Chassis ID/slot ID. For a sensor on a slot, this field displays the slot number.
Sensor
ID of the sensor.
Voltage
Current voltage of the sensor.
Description for the sensor. This field is generated by the device. It displays the rated voltage of the sensor. If another sensor has the same rated voltage value, a string is automatically inserted before the rated voltage value to uniquely identify the item.
energy-saving mode
Use energy-saving mode to specify the energy saving mode for the device.
energy-saving mode { standard | basic | deep }
The standard energy saving mode is specified for the device.
Table 43 shows the energy saving modes that are available for the device. An energy saving mode will takes effect immediately after you specify it.
Table 43 Energy saving modes on the device
Energy saving mode
Standard
Default energy saving mode in the factory-default configuration of the device, which supports the following functions:
·     Intelligent fan speed control is enabled by default.
·     Auto laser shutdown, EEE, and auto power-down are disabled by default.
Basic
Supports the following functions except for those in standard mode:
·     Supports enabling, disabling, and putting unused components into sleep.
·     Auto laser shutdown, EEE, and auto power-down are enabled by default.
After this mode is set, you can execute the redundant-power energy-saving command to configure energy saving settings for excess power modules. You can also execute the transceiver auto-laser-down command to configure auto laser shutdown.
In this mode, the device startup speed might be impacted when no services are configured or no users come online.
Deep
Supports service-based dynamic power consumption adjustment, except for the functions available in basic mode. In this mode, the device automatically adjusts power consumption based on services and supports enabling shutdown of excess cards.
# Specify the basic energy saving mode for the device.
[Sysname] energy-saving mode basic
The system will enable automatic transceiver laser shutdown, energy saving for redundant power supplies, and interface auto sleep. Continue?[Y/N]:y
fan-speed
Use fan-speed to set the fan operating mode.
Use undo fan-speed to restore the default.
fan-speed { auto | high | middle | low }
undo fan-speed
Fans operate in auto mode.
auto: Operates at an adjustable speed. The device adjusts the speed automatically based on the card temperature. As a best practice, use this mode.
high: Operates at a higher speed to provide better cooling service.
middle: Operates at a middle speed.
low: Operates at a lower speed to reduce the noise at the cost of lower cooling service quality. This mode applies to noise-sensitive environments.
# Set the fan operating mode to auto.
[Sysname] fan-speed auto
Fan speed changed successfully!
fan-speed set-rate
Use fan-speed set-rate to adjust the percentage of the current fan speed to the maximum fan speed.
fan-speed set-rate frame frame-id { add | sub } value
frame frame-id: Specifies a fan tray by its tray ID.
add: Increases the percentage of the current fan speed  to the maximum fan speed.
sub: Decreases the percentage of the current fan speed  to the maximum fan speed.
value: Specifies the value of the percentage to be adjusted, in the range of 1 to 10.
The larger the adjusted percentage is, the larger the range of the adjusted fan speed is.
After you execute the fan-speed set-rate command, you can execute the display fan-speed command to view fan speed information after adjustment.
You can execute the fan-speed set-rate command multiple times to adjust the fan speed. This command will not take effect if the fan speed has been adjusted to its maximum value.
[Sysname] fan-speed set-rate frame 0 add 5
display fan-speed
forward per-packet
Use forward per-packet to specify the per-packet load sharing forwarding mode.
Use undo forward per-packet to restore the default.
forward per-packet [ slot slot-number ]
undo forward per-packet [ slot slot-number ]
The per-flow load sharing forwarding mode is used.
This command is available only for testing.
In the per-packet load sharing forwarding mode, when the device forwards packets from service modules to switching fabric modules, the packets are forwarded in sequence for load sharing.
In the per-flow load sharing forwarding mode, when the device forwards packets from service modules to switching fabric modules, the packets are distributed into different flows according to specific rules before being forwarded.
Switching the load sharing forwarding mode might cause packet loss. Contact Technical Support before executing this command.
# Specify the per-packet load sharing forwarding mode.
[Sysname] forward per-packet
forward-path-detection enable
Use forward-path-detection enable to enable data forwarding path failure detection.
Use undo forward-path-detection enable to disable data forwarding path failure detection.
Data forwarding path failure detection is enabled.
You can enable the device to automatically detect data forwarding path failures and output log information for notification.
# Enable data forwarding path failure detection.
[Sysname] forward-path-detection enable
Use hardware-failure-detection to specify the action to be taken in response to hardware failures.
Use undo hardware-failure-detection to restore the default.
hardware-failure-detection { chip | forwarding } { isolate | off | reset | warning }
undo hardware-failure-detection { chip | forwarding }
The system takes the action of warning in response to hardware failures on chips and the action of reset in response to hardware failures on the forwarding plane.
chip: Specifies failures on components of cards such as the chips, capacitances, resistances.
forwarding: Specifies failures on the forwarding plane (including services and other relevant items).
isolate: Takes one or more of the following actions:
·     Shuts down the relevant ports.
·     Prohibits loading software for the relevant cards.
·     Isolates the relevant cards.
·     Powers off the relevant cards to reduce impact from the failures.
off: Takes no action.
reset: Restarts the relevant components or cards to recover from failures.
warning: Sends traps to notify you of the failures.
The system automatically detects hardware failures on components, cards, and the forwarding plane. You can specify the actions to be taken in response to detected failures.
# Configure the device to send traps in response to failures on components.
[Sysname] hardware-failure-detection chip warning
hardware-failure-protection aggregation
Use hardware-failure-protection aggregation to enable hardware failure protection for aggregation groups.
Use undo hardware-failure-protection aggregation to disable hardware failure protection for aggregation groups.
Hardware failure protection is disabled for aggregation groups.
This command takes effect only when the hardware-failure-detection forwarding isolate command is executed.
When the hardware-failure-protection aggregation command is executed, the system uses the following rules when it detects a hardware failure on an aggregation group member interface:
·     If the undo hardware-failure-protection auto-down command is executed on the member interface and the member interface is the only member in up state in the group, the system does not shut down the interface.
·     If the undo hardware-failure-protection auto-down command is executed on the member interface and the member interface is not the only member in up state in the group, the system shuts down the interface.
·     If the hardware-failure-protection auto-down command is executed on the member interface, the system shuts down the interface, whether or not the member interface is the only member in up state in the group.
This command does not take effect on a member interface in the following situations:
·     Loopback testing is enabled (using the loopback { external | internal } command).
·     The interface is forcibly brought up (using the port up-mode command).
·     The undo hardware-failure-protection auto-down command is not executed on the interface.
# Enable hardware failure protection for aggregation groups.
[Sysname] hardware-failure-protection aggregation
Use hardware-failure-protection auto-down to enable hardware failure protection for an interface.
Use undo hardware-failure-protection auto-down to disable hardware failure protection for an interface.
Hardware failure protection is enabled for an interface.
Ethernet interface view
To ensure service continuity, verify that the interface has a backup link before configuring this command.
After you enable hardware failure protection on an interface, the system automatically shuts down the interface when it detects a hardware failure on the interface. An interface shut down this way is in Protect Down state. After the failure on an interface is removed, bring the interface up by using the undo shutdown command.
This command does not take effect on an interface in the following situations:
# Enable hardware failure protection on interface Ten-GigabitEthernet 3/0/1.
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] hardware-failure-protection auto-down
header
Use header to configure a banner.
Use undo header to delete a banner.
header { legal | login | motd | shell } text
undo header { legal | login | motd | shell }
No banner is configured.
legal: Configures the banner to be displayed before a user inputs the username and password to access the CLI.
login: Configures the banner to be displayed before password or scheme authentication is performed for a login user.
motd: Configures the greeting banner to be displayed before the legal banner appears.
shell: Configures the banner to be displayed before a user accesses user view.
text: Specifies the banner message. You can enter the banner message on the same line as the keywords or on different lines. For more information, see Fundamentals Configuration Guide.
# Configure the legal banner.
[Sysname] header legal
Welcome to use the legal banner%
itu-channel
Use itu-channel to set the ITU channel number for a transceiver module.
Use undo itu-channel to restore the default.
itu-channel channel-number
undo itu-channel
The ITU channel number is 1.
channel-number: Specifies the ITU channel number.
This command is available only for the HPE X130 10G SFP+ LC LH80 tunable Transceiver (JL250A), SFP-XG-LH80-Tunable, and CFP2-200G-DCO-Tunable transceiver modules.
The ITU channel number is saved in a register on the transceiver module. It is not saved to the configuration file.
# Set the ITU channel number to 2 for the transceiver module in Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] itu-channel 2
Changing the channel number causes the service to be down for a while. Continue? [Y/N]:Y
job
Use job to assign a job to a schedule.
Use undo job to revoke a job.
job job-name
undo job job-name
No job is assigned to a schedule.
Schedule view
job-name: Specifies the job name, a case-sensitive string of 1 to 47 characters.
You can assign multiple jobs to a schedule. The jobs in a schedule are executed concurrently.
The jobs to be assigned to a schedule must already exist. To create a job, use the scheduler job command.
# Assign the save-job job to the saveconfig schedule.
[Sysname] scheduler schedule saveconfig
[Sysname-schedule-saveconfig] job save-job
scheduler job
scheduler schedule
line-card-mode
Use line-card-mode to specify an operating mode for an interface card..
line-card-mode slot slot-number mode-name
The MIC-SP4L-M interface card operates in the oc-3-pos mode and the MIC-SEC-M interface card operates in the ipsec-sm3-sm4 mode.
mode-name: Specifies an operating mode. Available operating modes depend on the interface card type. The following shows all operating mode values:
·     oc-12-pos: Specifies the oc-12-pos mode. All interfaces on the interface card act as 622 Mbps POS interfaces.
·     oc-3-pos: Specifies the oc-3-pos mode. All interfaces on the interface card act as 155 Mbps POS interfaces.
·     ipsec-md5-aes: Specifies the encryption mode of the IPsec encryption interface card as IPsec-MD5-AES, which supports MD5 authentication algorithm and AES-CBC-256 encryption algorithm.
·     ipsec-sm3-sm4: Specifies the encryption mode of the IPsec encryption interface card as IPsec-SM3-SM4, which supports SM3 authentication algorithm and SM4 encryption algorithm.
If you change the operating mode for an interface card, the card reboots to operate in the new operating mode.
If the card is damaged and replaced with a new one of the same model, the following rules apply:
·     For an MIC-SP4L-M interface card, the operating mode configured currently on the device takes effect on the new card.
·     For an MIC-SEC-M interface card, the default operating mode takes effect. If the default operating mode does not match the operating mode configured for the original card before the replacement, you must reconfigure an operating mode.
# Set the operating mode to oc-12-pos for an interface card.
[Sysname] line-mode slot 3 oc-12-pos
link-quality hardware-error enable
Use link-quality hardware-error enable to enable hardware detection reporting.
Use undo link-quality hardware-error enable to disable hardware detection reporting.
Hardware fault reporting is disabled.
Hardware detection is a mechanism of reliability that automatically triggers upper-layer service modules to take protective measures in response to hardware detection events. This can minimizes the impact of hardware faults on service operations.
When a hardware fault is detected, this feature allows the device to report information such as the fault location, fault cause, and fault status to the platform. The platform will record fault information and notify routing, aggregation, and other service modules. Service modules will adjust the cost value of routing and select ports for aggregation based on the fault information to avoid using faulty hardware for service traffic forwarding.
To view hardware fault causes, execute the display ifmonitor command. For more information about the display ifmonitor command, see error code detection commands in High Availability Command Reference.
# Enable hardware detection reporting.
[Sysname] link-quality hardware-error enable
memory-threshold
Use memory-threshold to set free-memory thresholds.
Use undo memory-threshold to restore the default.
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ]
The free-memory thresholds vary by device model. To obtain the default free-memory thresholds, execute the undo memory-threshold and display memory-threshold commands in sequence.
ratio: Specifies free-memory thresholds in percentage. If you do not specify this keyword, the command sets free-memory thresholds in MB.
minor minor-value: Specifies the minor alarm threshold. This threshold must be equal to or less than the normal state threshold. Setting this threshold to 0 disables the minor alarm feature.
severe severe-value: Specifies the severe alarm threshold. This threshold must be equal to or less than the minor alarm threshold. Setting this threshold to 0 disables the severe alarm feature.
critical critical-value: Specifies the critical alarm threshold. This threshold must be equal to or less than the severe alarm threshold. Setting this threshold to 0 disables the critical alarm feature.
normal normal-value: Specifies the normal state threshold. This threshold must be equal to or less than the total memory size.
early-warning early-warning-value: Specifies the early-warning threshold. To view the value range for this threshold, enter a question mark (?) in the place of the early-warning-value argument. Setting this threshold to 0 disables the early warning feature.
secure secure-value: Specifies the sufficient-memory threshold. To view the value range for this threshold, enter a question mark (?) in the place of the secure-value argument.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command sets free-memory thresholds for the active MPU.
cpu cpu-number: Specifies a CPU by its number.
To ensure correct operation and improve memory efficiency, the system monitors the amount of free memory space in real time. If the amount of free memory space decreases to or below the minor, severe, or critical alarm threshold, the system issues an alarm to affected service modules or processes.
For slots that support low memory, the system monitors only the amount of free low-memory space. You can use the display memory command to display memory usage information. If the LowMem field is displayed for a slot, the slot supports low memory.
For more information about the alarm thresholds, see Fundamentals Configuration Guide.
# Set the minor alarm, severe alarm, critical alarm, and normal state thresholds to 64 MB, 48 MB, 32 MB, and 96 MB, respectively.
[Sysname] memory-threshold minor 64 severe 48 critical 32 normal 96
Use memory-threshold dma to set DMA memory thresholds.
Use undo memory-threshold dma to restore the default.
memory-threshold dma [ slot slot-number [ cpu cpu-number ] ] [ ratio ] critical critical-value normal normal-value
undo memory-threshold dma [ slot slot-number [ cpu cpu-number ] ]
The DMA memory alarm threshold is 2048 KB, and the normal state threshold is 4096 KB.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command sets DMA memory thresholds for the active MPU.
ratio: Specifies DMA memory thresholds in percentage.
critical critical-value: Specifies the DMA memory alarm threshold. If the ratio keyword is specified, the value range for the critical-value argument is 1 to 100 in percentage. If the ratio keyword is not specified, the value range is 0 to 3145728.
normal normal-value: Specifies the normal state threshold. If the ratio keyword is specified, the value range for the normal-value argument is 1 to 100 in percentage. If the ratio keyword is not specified, the value is in the range of critical-value to 3145728.
To ensure correct operation of the services that require DMA memory, the system monitors the amount of free DMA memory space regularly. If the amount of free DMA memory space decreases to or below the alarm threshold, the system generates a notification indicating that the DMA memory space is insufficient. If the amount of free DMA memory space increases above the normal state threshold, the system generates a notification indicating that the DMA memory space is sufficient.
# Set the DMA memory alarm threshold and the normal state threshold to 32KB and 96 KB, respectively, for slot 1.
<System> system-view
[System] memory-threshold dma slot 1 critical 32 normal 96
memory-threshold usage
Use memory-threshold usage to set the memory usage threshold.
Use undo memory-threshold usage to restore the default.
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ] usage
The memory usage threshold is 100%.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command sets the memory usage threshold for the active MPU.
memory-threshold: Specifies the memory usage threshold in percentage. The value range is 0 to 100.
The device samples memory usage at 1-minute intervals. If the sample is greater than the memory usage threshold, the device sends a trap.
# Set the memory usage threshold to 80%.
[Sysname] memory-threshold usage 80
memory-threshold usage resend-interval
Use memory-threshold usage resend-interval to set the memory usage alarm resending interval.
Use undo memory-threshold usage resend-interval to restore the default.
memory-threshold [ slot slot-number [ cpu cpu-number ] ] usage resend-interval interval-value
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ] usage resend-interval
The memory usage alarm resending interval is 300 seconds.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command sets the interval for the active MPU.
resend-interval interval-value: Specifies the memory usage alarm resending interval in the range of 1 to 3600, in minutes.
The device samples memory usage periodically, and compares the sampled value with the memory usage thresholds. If the sampled value exceeds an alarm threshold, the device enters alarm state and generates an alarm (log and trap) to notify the administrator. If the memory usage remains in the alarm state after the memory usage alarm resending interval is reached, the device outputs the alarm again.
# Set the memory usage alarm resending interval to 60 minutes for CPU 0 in slot 1.
[Sysname] memory-threshold slot 1 cpu 0 usage resend-interval 60
monitor cpu-usage enable
Use monitor cpu-usage enable to enable CPU usage monitoring.
Use undo monitor cpu-usage enable to disable CPU usage monitoring.
undo monitor cpu-usage enable [ slot slot-number [ cpu cpu-number ] ]
CPU usage monitoring is enabled.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command enables CPU usage monitoring for the active MPU.
After CPU usage monitoring is enabled, the system samples and saves CPU usage at the interval specified by the monitor cpu-usage interval command. You can use the display cpu-usage history command to view recent CPU usage.
# Enable CPU usage monitoring.
[Sysname] monitor cpu-usage enable
display cpu-usage configuration
Use monitor cpu-usage interval to set the sampling interval for CPU usage monitoring.
Use undo monitor cpu-usage interval to restore the default.
undo monitor cpu-usage interval [ slot slot-number [ cpu cpu-number ] ]
The system samples CPU usage every 1 minute.
interval: Specifies the sampling interval for CPU usage monitoring. Valid values include 5Sec (5 seconds), 1Min (1 minute), and 5Min (5 minutes), case insensitive.
After CPU usage monitoring is enabled, the system samples and saves CPU usage at the specified interval. You can use the display cpu-usage history command to view recent CPU usage.
# Set the sampling interval for CPU usage monitoring to 5 seconds.
[Sysname] monitor cpu-usage interval 5Sec
monitor cpu-usage threshold
Use monitor cpu-usage threshold to set the CPU usage threshold.
Use undo monitor cpu-usage threshold to restore the default.
monitor cpu-usage threshold cpu-threshold [ minor-threshold minor-threshold recovery-threshold recovery-threshold ] [ slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage threshold [ minor-threshold recovery-threshold ] [ slot slot-number [ cpu cpu-number ] ]
The severe CPU usage alarm threshold is 99%. The minor CPU usage alarm threshold is 79%. The CPU usage recovery threshold is 69%.
cpu-threshold: Specifies the severe CPU usage alarm threshold in percentage. The value range for this argument is 2 to 100.
minor-threshold minor-threshold: Specifies the minor CPU usage alarm threshold in percentage. The value range for this argument is 1 to the severe CPU usage alarm threshold minus 1. If you do not specify this option, the minor CPU usage alarm threshold is 80 percent of the severe CPU usage alarm threshold.
recovery-threshold recovery-threshold: Specifies the CPU usage recovery threshold in percentage. The value range for this argument is 0 to the minor CPU usage alarm threshold minus 1. If you do not specify this option, the CPU usage recovery threshold is 70 percent of the severe CPU usage alarm threshold.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command sets the CPU usage threshold for the active MPU.
CAUTION
CAUTION:
If you set the severe CPU usage alarm threshold to a too low value, the device will reach the threshold easily. Normal service processing will be affected.
The device samples CPU usage at 1-minute intervals. If the sample is greater than a CPU usage alarm threshold, the device sends a trap. If the sample is equal to or less than the CPU usage recovery threshold, the device determines that the CPU usage is normal.
# Set the severe CPU usage threshold to 80%.
[Sysname] monitor cpu-usage threshold 80
monitor disk-usage disk
Use monitor disk-usage disk to set the disk usage threshold.
Use undo monitor disk-usage disk to restore the default.
monitor disk-usage [ slot slot-number ] disk disk-name threshold threshold-value
undo monitor disk-usage [ slot slot-number ] disk disk-name threshold
The disk usage threshold is 95%.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, the command applies to the active MPU.
disk disk-name: Specifies a disk by its name. This option is case sensitive. The system will prompt a parameter error if you enter this option incorrectly.
threshold threshold-value: Specifies the disk usage threshold in percentage, in the range of 1 to 100.
After you set the disk usage threshold, the device compares the usage of the disk with the threshold at each sampling. If the usage exceeds the threshold, the device sends a high disk usage alarm to the NETCONF module. For more information about the NETCONF module see Network Management and Monitoring Configuration Guide.
# Set the disk usage threshold to 80%.
[Sysname] monitor disk-usage disk flash threshold 80
monitor disk-usage interval
Use monitor disk-usage interval to set the disk usage sampling interval.
Use undo monitor disk-usage interval to restore the default.
monitor disk-usage interval interval
The disk usage sampling interval is 300 seconds.
interval interval-time: Specifies the disk usage sampling interval in seconds, a multiple of 5 in the range of 5 to 1800.
After you set the disk usage sampling interval, the device samples the disk usage at the specified intervals.
# Set the disk usage sampling interval to 120 seconds.
[Sysname] monitor disk-usage interval 120
monitor kernel memory fragment interval
Use monitor kernel memory fragment interval to set the interval for collecting kernel memory fragment information.
Use undo monitor kernel memory fragment interval to restore the default.
monitor kernel memory fragment interval interval-value [ slot slot-number [ cpu cpu-number ] ]
undo monitor kernel memory fragment interval [ slot slot-number [ cpu cpu-number ] ]
The interval is five minutes for collecting kernel memory fragment information.
interval-value: Specifies the interval in minutes. The value range is 1 to 65535.
The device collects kernel memory fragment statistics at the intervals specified by this command. To view the statistics and identify whether the kernel memory fragment ratio is normal, execute the display kernel memory fragment free command.
# Set the interval for collecting memory fragment information to 5 minutes.
[System] monitor kernel memory fragment interval 5
monitor kernel memory fragment ratio
Use monitor kernel memory fragment ratio to set the kernel memory fragment ratio alarm threshold.
Use undo monitor kernel memory fragment ratio to restore the default.
monitor kernel memory fragment ratio ratio-value [ slot slot-number [ cpu cpu-number ] ]
undo monitor kernel memory fragment ratio [ slot slot-number [ cpu cpu-number ] ]
The kernel memory fragment ratio alarm threshold is 20%.
ratio ratio-value: Specifies the kernel memory fragment ratio alarm threshold in percentage, in the range of 1 to 100.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command sets the kernel memory fragment ratio alarm threshold for the active MPU.
A running kernel thread's process requires memory allocation from the system. The system allocates and releases this memory as a whole. If the process is still running and some memory blocks have been used but are no longer used, these memory blocks will not be released in advance. These free but currently unusable memory blocks are also referred to as memory fragments.
This command enables the device to monitor the kernel memory fragment ratio. If the kernel memory fragment ratio decreases to or below the alarm threshold, the kernel memory usage is low and an alarm notification is generated. If the kernel memory fragment ratio increases above the alarm threshold, the kernel memory usage returns to the normal state and a recovery notification is generated.
# Set the kernel memory fragment ratio alarm threshold to 80 for a slot.
[System] monitor kernel memory fragment ratio 80 slot 1
monitor resend cpu-usage
Use monitor resend cpu-usage to set CPU usage alarm resending intervals.
Use undo monitor resend cpu-usage to restore the default.
undo monitor resend cpu-usage [ minor-interval | severe-interval ] [ slot slot-number [ cpu cpu-number ] ]
The minor CPU usage alarm resending interval is 300 seconds. The severe CPU usage alarm resending interval is 60 seconds.
minor-interval minor-interval: Specifies the minor CPU usage alarm resending interval in seconds, a multiple of 5 in the range of 10 to 3600.
severe-interval severe-interval: Specifies the severe CPU usage alarm resending interval in seconds, a multiple of 5 in the range of 10 to 3600.
The device samples CPU usage at intervals, and compares the samples with CPU usage thresholds to identify the CPU usage status and send alarms or notifications accordingly.
In minor alarm state, the device sends minor alarms periodically until the CPU usage increases above the severe threshold or the minor alarm is removed. In severe alarm state, the device sends severe alarms periodically until the severe alarm is removed. This command sets the alarm resending intervals.
If you do not specify a keyword for the undo monitor resend cpu-usage command, the command restores the default minor and severe CPU usage alarm resending intervals.
# Set the minor CPU usage alarm resending interval to 60 seconds for a slot.
[Sysname] monitor resend cpu-usage minor-interval 60 slot 1 cpu 0
monitor resend cpu-usage core-interval
Use monitor resend cpu-usage core-interval to set CPU core usage alarm resending intervals.
Use undo monitor resend cpu-usage core-interval to restore the default.
monitor resend cpu-usage core-interval { minor-interval minor-interval | severe-interval severe-interval } * [ slot slot-number [ cpu cpu-number ] ]
undo monitor resend cpu-usage core-interval [ minor-interval | severe-interval ] [ slot slot-number [ cpu cpu-number ] ]
The minor CPU core usage alarm resending interval is 300 seconds and severe CPU core usage alarm resending interval is 60 seconds.
minor-interval minor-interval: Specifies the resending interval for minor CPU core usage alarms in seconds, a multiple of 5 in the range of 10 to 3600.
severe-interval severe-interval: Specifies the resending interval for severe CPU core usage alarms in seconds, a multiple of 5 in the range of 10 to 3600.
The device samples CPU core usage at intervals, and compares the samples with CPU core usage thresholds to identify the CPU core usage status and send alarms or notifications accordingly.
In minor alarm state, the device sends minor alarms periodically until the CPU core usage increases above the severe threshold or the minor alarm is removed. In severe alarm state, the device sends severe alarms periodically until the severe alarm is removed. This command sets the alarm resending intervals.
# Set the resending interval for minor CPU core usage alarms to 100 seconds and the resending interval for severe CPU core usage alarms 60 seconds.
[Sysname] monitor resend cpu-usage core-interval minor-interval 100 severe-interval 60
monitor resend memory-threshold
Use monitor resend memory-threshold to set free memory depletion alarm resending intervals.
Use undo monitor resend memory-threshold to restore the default.
undo monitor resend memory-threshold [ critical-interval | early-warning-interval | minor-interval | severe-interval ] * [ slot slot-number [ cpu cpu-number ] ]
·     Early warning resending interval: 1 hour.
·     Minor alarm resending interval: 12 hours.
·     Severe alarm resending interval: 3 hours.
·     Critical alarm resending interval: 1 hour.
critical-interval critical-interval: Specifies the critical alarm resending interval in hours, in the range of 1 to 48.
early-warning-interval early-warning-interval: Specifies the early warning resending interval in hours, in the range of 1 to 48.
minor-interval minor-interval: Specifies the minor alarm resending interval in hours, in the range of 1 to 48.
severe-interval severe-interval: Specifies the severe alarm resending interval in hours, in the range of 1 to 48.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command sets alarm resending intervals for the active MPU.
The device samples the amount of free memory space periodically and compares the sampled value with free-memory thresholds. If the sampled value decreases to or below a threshold, the device enters a memory depletion alarm state and sends an alarm.
In critical alarm state, the device sends critical alarm notifications periodically until the critical alarm is removed.
In a lower alarm state, the device sends notifications for the alarm state periodically until it enters a higher alarm state or the current alarm is removed.
You can use this command to change the alarm resending intervals.
# Set the minor memory depletion alarm resending interval to 12 hours for CPU 0 in slot 1.
[Sysname] monitor resend memory-threshold minor-interval 12 slot 1 cpu 0
monitor resend memory-threshold dma
Use monitor resend memory-threshold dma to set the DMA memory alarm resending interval.
Use undo monitor resend memory-threshold dma to restore the default.
monitor resend memory-threshold dma critical-interval critical-interval [ slot slot-number [ cpu cpu-number ] ]
undo monitor resend memory-threshold dma critical-interval [ slot slot-number [ cpu cpu-number ] ]
The DMA memory alarm resending interval is 300 seconds.
critical-interval critical-interval: Specifies the resending interval for the DMA memory alarms in seconds, in the range of 10 to 3600.
The device samples DMA memory usage at intervals, and compares the samples with the DMA memory alarm threshold to identify the DMA memory usage status and send alarms or notifications accordingly.
# Set the resending interval for the DMA memory alarms to 100 seconds.
[Sysname] monitor resend memory-threshold dma critical-interval 100<Sysname> system-view
parity-error consistency-check log enable
Use parity-error consistency-check log enable to enable consistency error logging for software and hardware forwarding entries.
Use undo parity-error consistency-check log enable to disable consistency error logging for software and hardware forwarding entries.
Consistency error logging is enabled for software and hardware forwarding entries.
To forward packets, the device generates hardware forwarding entries on forwarding chips and software forwarding entries in memory at the same time. The device automatically detects whether the hardware forwarding entries and the software forwarding entries are consistent.
With this command executed, if the number of consistency errors after a scan on software and hardware entries by forwarding chips reaches the logging threshold, the device generates and sends a log message to the information center module. The information center module determines how and where to send the message. For more information about the information center module, see information center configuration in Network Management and Monitoring Configuration Guide.
# Enable consistency error logging for software and hardware forwarding entries.
[Sysname] parity-error consistency-check log enable
parity-error consistency-check threshold
Use parity-error consistency-check threshold to set the logging threshold for consistency errors between software and hardware forwarding entries.
Use undo parity-error consistency-check threshold to restore the default.
parity-error consistency-check threshold value
The logging threshold is 10.
value: Specifies the logging threshold for consistency errors between software and hardware forwarding entries, in the range of 1 to 3600.
After you execute this command, if the number of consistency errors reaches the logging threshold after a scan on software and hardware forwarding entries, the device generates a log message.
# Set the logging threshold to 20 for consistency errors between software and hardware forwarding entries.
[Sysname] parity-error consistency-check threshold 20
parity-error consistency-check period
parity-error monitor log enable
Use parity-error monitor log enable to enable parity error and ECC error logging for entries on forwarding chips.
Use undo parity-error monitor log enable to disable parity error and ECC error logging for entries on forwarding chips.
Parity error and ECC error logging is enabled for entries on forwarding chips.
The device automatically detects parity errors and ECC errors in entries on forwarding chips.
After you execute this command, the device collects parity errors and ECC errors periodically. If the number of parity errors and ECC errors in a statistics period reaches the logging threshold, the device generates and sends a parity error and ECC error log message to the information center module. The information center module determines how and where to send the message. For more information about the information center module, see information center configuration in Network Management and Monitoring Configuration Guide.
# Enable parity error and ECC error logging for entries on forwarding chips.
[Sysname] parity-error monitor log enable
parity-error monitor period
parity-error monitor threshold
Use parity-error monitor period to set the parity error and ECC error statistics period for entries on forwarding chips.
Use undo parity-error monitor period to restore the default.
parity-error monitor period value
The parity error and ECC error statistics period is 300 seconds for entries on forwarding chips.
period: Specifies the parity error and ECC error statistics period in seconds, in the range of 1 to 86400.
The device automatically detects parity errors and ECC errors in entries on forwarding chips. The parity error and ECC error logging feature collects parity error and ECC error statistics periodically, and generates a log message if the number of parity error and ECC errors reaches the logging threshold.
This command determines the period for the device to collect parity error and ECC error statistics.
# Set the parity error and ECC error statistics period to 120 seconds.
[Sysname] parity-error monitor period 120
Use parity-error monitor threshold to set the parity error and ECC error logging threshold for entries on forwarding chips.
Use undo parity-error monitor threshold to restore the default.
parity-error monitor threshold value
The parity error and ECC error logging threshold is 50 for entries on forwarding chips.
value: Specifies the parity error and ECC error logging threshold for entries on forwarding chips, in the range of 1 to 86400.
The device detects parity error and ECC errors in entries on forwarding chips. The parity error and ECC error logging feature collects parity error and ECC error statistics periodically, and generates a log message if the number of parity error and ECC errors reaches the logging threshold. This command sets the logging threshold.
# Set the parity error and ECC error logging threshold to 8000 for entries on forwarding chips.
[Sysname] parity-error monitor threshold 8000
parity-error unrecoverable log enable
Use parity-error unrecoverable log enable to enable uncorrectable parity error and ECC error logging for entries on forwarding chips.
Use undo parity-error unrecoverable log enable to disable uncorrectable parity error and ECC error logging for entries on forwarding chips.
Uncorrectable parity error and ECC error logging is enabled for entries on forwarding chips
The device automatically detects parity errors and ECC errors in entries on forwarding chips and tries to correct the error when an error is detected. The uncorrectable parity error and ECC error logging feature enables the device to collect uncorrectable parity error and ECC error statistics periodically. If the number of uncorrectable parity errors and ECC errors reaches the logging threshold, the device generates and sends an uncorrectable parity error and ECC error log message to the information center module. The information center module determines how and where to send the log message. For more information about the information center module, see information center configuration in Network Management and Monitoring Configuration Guide.
# Enable uncorrectable parity error and ECC error logging for entries on forwarding chips
[Sysname] parity-error unrecoverable log enable
parity-error unrecoverable period
parity-error unrecoverable reboot
parity-error unrecoverable threshold
Use parity-error unrecoverable period to set the statistics period for uncorrectable parity errors and ECC errors for entries on forwarding chips.
Use undo parity-error unrecoverable period to restore the default.
parity-error unrecoverable period period
The statistics period is 60 seconds for uncorrectable parity errors and ECC errors for entries on forwarding chips.
period: Specifies the statistics period for uncorrectable parity errors and ECC errors for entries on forwarding chips, in the range of 1 to 86400, in seconds.
The device automatically detects parity errors and ECC errors in entries on forwarding chips and tries to correct the error when an error is detected. The uncorrectable parity error and ECC error logging feature enables the device to collect uncorrectable parity error and ECC error statistics periodically. If the number of uncorrectable parity errors and ECC errors reaches the logging threshold, the device generates an uncorrectable parity error and ECC error log message.
This command sets the period for the device to collect uncorrectable parity error and ECC error statistics.
# Set the statistics period for uncorrectable parity errors and ECC errors in entries on forwarding chips to 120 seconds.
[Sysname] parity-error unrecoverable period 120
Use parity-error unrecoverable reboot to enable automatic system reboot upon generation of an uncorrectable parity error and ECC error log.
Use undo parity-error unrecoverable reboot to disable automatic system reboot upon generation of an uncorrectable parity error and ECC error log
The system reboots automatically upon generation of an uncorrectable parity error and ECC error log.
Uncorrectable parity errors and ECC errors in entries on forwarding chips might affect system services. To remove the errors from the entries on forwarding chips, you can execute this command to enable automatic system reboot upon generation of an uncorrectable parity error and ECC error log.
If the card to be restarted is an MPU or switching fabric module and the device is installed with only one MPU or switching fabric module, this command will not take effect.
# Enable automatic system reboot upon generation of an uncorrectable parity error and ECC error log.
[Sysname] parity-error unrecoverable reboot
Use parity-error unrecoverable threshold to set the logging threshold for uncorrectable parity errors and ECC errors on entries on forwarding chips.
Use undo parity-error unrecoverable threshold to restore the default.
parity-error unrecoverable threshold value
The logging threshold is 1 for uncorrectable parity errors and ECC errors in entries on forwarding chips.
value: Specifies the logging threshold for uncorrectable parity errors and ECC errors in entries on forwarding chips, in the range of 1 to 86400.
# Set the logging threshold for uncorrectable parity errors and ECC errors in entries on forwarding chips to 10.
[Sysname] parity-error unrecoverable log threshold 10
password-recovery enable
Use password-recovery enable to enable password recovery capability.
Use undo password-recovery enable to disable password recovery capability.
Password recovery capability is enabled.
Password recovery capability controls console user access to the device configuration and SDRAM from BootWare menus.
If password recovery capability is enabled, a console user can access the device configuration without authentication to configure new passwords.
If password recovery capability is disabled, console users must restore the factory-default configuration before they can configure new passwords. Restoring the factory-default configuration deletes the next-startup configuration files.
To enhance system security, disable password recovery capability.
To access the device configuration without authentication, you must connect to the active MPU and access the BootWare menu while the MPU is starting up.
Availability of BootWare menu options depends on the password recovery capability setting. For more information, see the release notes.
# Disable password recovery capability.
[Sysname] undo password-recovery enable
power control-mode
Use power control-mode to set the card power-on control mode.
Use undo power control-mode to restore the default.
power control-mode { loose | strict }
The card power-on control mode is strict.
loose: Specifies the loose mode.
strict: Specifies the strict mode.
When you install a service module or switching fabric module, the device calculates the following items:
·     Total power reserved for fans and MPUs.
·     Total maximum power of all service modules and switching fabric modules, including the newly installed module.
In strict mode, the device powers on the newly installed module only if the sum of the two items is equal to or less than the rated power of the device.
In loose mode, the device powers on the newly installed module as long as the sum of the two items is equal to or less than the rated power of the device * 1.2.
# Set the card power-on control mode to loose.
[Sysname] power control-mode loose
power-off high-temp-board clear
Use power-off high-temp-board clear to restore power supply for cards shut down because of overtemperature.
When the temperature on a card reaches the shutdown temperature threshold, the overtemperature auto shutdown feature automatically shuts down the card. You can use this command to power on the card as appropriate.
# Restore power supply for cards shut down because of overtemperature.
[Sysname] power-off high-temp-board clear
power-off high-temp-board enable
Use power-off high-temp-board enable to enable the overtemperature auto shutdown feature.
undo power-off high-temp-board enable
The overtemperature auto shutdown feature is enabled.
# Enable the overtemperature auto shutdown feature.
[Sysname] power-off high-temp-board enable
display power-off high-temp-board
reboot
Use reboot to reboot the device.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, the command reboots the entire device.
force: Reboots the device immediately without performing software or hard disk check. If this keyword is not specified, the system first identifies whether the reboot might result in data loss or a system failure. For example, the system identifies whether the main system software image file exists and whether a write operation is in progress on a storage medium. If the reboot might cause problems, the system does not reboot the device.
CAUTION
CAUTION:
·     A reboot might interrupt network services.
·     Use the force keyword only when the device fails or a reboot command without the force keyword cannot perform a reboot correctly. A reboot command with the force keyword might result in file system corruption because it does not perform data protection.
If the main startup software images are corrupt or missing, you must re-specify a set of main startup software images before executing the reboot command.
For data security, the device does not reboot if you reboot the device while the device is performing file operations.
If the device does not have a standby MPU, rebooting the active MPU reboots the entire device. If the device has a standby MPU and the standby MPU is operating correctly, rebooting the active MPU triggers a switchover.
To ensure correct operation of the system and cards, do not trigger a switchover by rebooting the active MPU if the standby MPU is not in Stable state. To view the status of the standby MPU, execute the display system stable state command.
# Reboot the device. Save the running configuration at prompt.
<Sysname> reboot
Current configuration will be lost after the reboot, save current configuration? [Y/N]:y
Configuration is saved to mainboard device successfully.
Now rebooting, please wait...
# Reboot the device immediately without performing software check.
<Sysname> reboot force
A forced reboot might cause the storage medium to be corrupted. Continue? [Y/N]:y
receive
Use receive to specify a packet receiving mode for load balancing.
Use undo receive to restore the default.
receive per-packet
undo receive
The per-flow packet receiving mode is specified for load balancing. That is, after receiving packets, an interface divides the packets into different flows, and then send these flows to CPUs. The packets of the same flow are sent through the same link.
per-packet: Specifies the per-packet mode. In this mode, after an interface receives packets, the packets are load-balanced to each link based on the receiving sequence, and then are sent to CPUs.
This command is supported only on the MIC-SEC-M interface module.
# Set the packet receiving mode for load balancing to per-packet.
<Sysname> system
[Sysname] receive per-packet
redundancy-power energy-saving
Use redundancy-power energy-saving to configure energy saving for excess power modules on the device.
Use undo redundancy-power energy-saving to restore the default.
redundancy-power energy-saving { enable | disable }
Energy saving for excess power modules on the device is disabled.
enable: Enables energy saving for excess power modules.
disable: Disables energy saving for excess power modules.
This command can shuts down the output of the excess power modules on the device without affecting MCU operation. The excess power modules refer to additional power modules after you configure redundant power modules. Enabling energy saving for excess power modules does not affect the device operation or power module redundancy. The energy saving feature allows these excess power modules to automatically start up when power consumption increases.
# Enable energy saving for excess power modules.
[Sysname] redundancy-power energy-saving enable
energy-saving mode
reset alarm active
Use reset alarm active to clear active alarm information on the device.
reset alarm active { all | sequence-number sequence-number }
The active alarm information on the device is not cleared.
Parameter
all: Specifies all active alarms.
sequence-number sequence-number: Specifies an active alarm by its sequence number, in the range of 1 to 4294967295.
When the system has information about active alarms, you can execute this command to manually clear these alarms. After clearance, the system will not display information about these alarms.
# Clear the active alarm with sequence number 1.
[Sysname] reset alarm active sequence-number 1
display alarm active
display alarm history
reset scheduler logfile
Use reset scheduler logfile to clear job execution log information.
# Clear job execution log information.
<Sysname> reset scheduler logfile
display scheduler logfile
Use reset transceiver interface to reset a transceiver module.
reset transceiver interface [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command applies to all interfaces.
This command is disruptive. Use this command only when you cannot troubleshoot transceiver modules by using other methods.
This command will restart the transceiver module.
Only the QSFP transceiver module supports this command.
# Reset the QSFP transceiver module in HundredGigE 3/0/1.
<Sysname> reset transceiver interface hundredgige 3/0/1
This operation causes services on the transceiver module to be down for a while. Continue? [Y/N]: Y
Use reset version-update-record to clear startup software image upgrade records.
# Clear the startup software image upgrade records.
[Sysname] reset version-update-record
This command will delete all records of version update. Continue? [Y/N]:y
resource-monitor minor resend enable
Use resource-monitor minor resend enable to enable resending of minor resource depletion alarms.
Use undo resource-monitor minor resend enable to disable resending of minor resource depletion alarms.
Resending of minor resource depletion alarms is enabled.
When a resource type enters minor alarm state, the device issues a minor alarm. If the resource type stays in minor alarm state or changes from severe alarm state to minor alarm state, the device identifies whether resending of minor resource depletion alarms is enabled. If the feature is disabled, the device does not issue additional minor alarms. If the feature is enabled, the device resends minor alarms periodically.
The resending period is fixed at 24 hours for a severe alarm and is fixed at 7 * 24 hours for a minor alarm.
# Enable resending of minor resource depletion alarms.
[Sysname] resource-monitor minor resend enable
display resource-monitor
resource-monitor output
resource-monitor resource
Use resource-monitor output to specify destinations for resource depletion alarms.
Use undo resource-monitor output to remove destinations for resource depletion alarms.
undo resource-monitor output [ netconf-event | snmp-notification | syslog ] *
Resource depletion alarms are sent to NETCONF, SNMP, and the information center.
netconf-event: Sends resource depletion alarms to the NETCONF feature to encapsulate the alarms in NETCONF events. For more information, see NETCONF in Network Management and Monitoring Configuration Guide.
snmp-notification: Sends resource depletion alarms to the SNMP feature to encapsulate the alarms in SNMP traps and informs. For more information, see SNMP in Network Management and Monitoring Configuration Guide.
syslog: Sends resource depletion alarms to the information center to encapsulate the alarms in log messages. For more information, see information center in Network Management and Monitoring Configuration Guide.
If you do not specify any keywords for the undo resource-monitor output command, the command disables resource depletion alarm output.
# Specify the information center module as the output destination for resource depletion alarms.
[Sysname] resource-monitor output syslog
Use resource-monitor resource to set resource depletion thresholds.
Use undo resource-monitor resource to disable resource depletion thresholds.
resource-monitor resource resource-name slot slot-number cpu cpu-number { by-absolute | by-percent } minor-threshold minor-threshold severe-threshold severe-threshold
undo resource-monitor resource resource-name slot slot-number cpu cpu-number
The default settings vary by resource type. Use the display resource-monitor command to display the resource depletion thresholds.
resource-name: Specifies a resource type by its name. The values for this argument are case insensitive and cannot be abbreviated. The resource types that can be monitored are as shown in Table 44. The resource types that can be monitored vary by device model.
Table 44 Resource types that can be monitored
Resource type
acl_car
CAR template resources.
acl_counter
ACL counter resources.
arp
ARP resources.
arpnd
ARP and ND resources.
bfd_hardbfd_session
Hardware BFD sessions
bpa_counter_in
Inbound BGP statistics resources.
bpa_counter_out
cfd_counterid_index
CFD counterid index resources.
cfd_watchdog_index
CFD watchdog index resources.
ecmp
ECMP resources.
efp_acl
Outbound ACL resources.
eth_subif_statistic
Route subinterface statistics counter resources.
flow_mirror
Flow mirror resources.
Ifp_acl
Inbound ACL resources.
ipmc
Layer 3 multicast replication table resources.
ipv4_acl
IPv4 ACL resources.
ipv4_defip
IPv4 route reources.
ipv4fib
IPv4 FIB hardware entry resources.
ipv4mc
IPv4 multicast forwarding entry resources.
ipv6_acl
IPv6 ACL resources.
ipv6_defip
IPv6 route resources.
ipv6_defip64
Resources for IPv6 routes with a prefix length of 0 to 64 bits.
ipv6_defip128
Resources for IPv6 routes with a prefix length of 65 to 128 bits.
ipv6_sr_list
SRv6 list resources
ipv6fib
IPv6 FIB hardware entry resources.
ipv6mc
IPv6 multicst forwarding entry resources.
mac
MAC address table resources.
maptable_in
Inbound flexible priority mapping table resources.
maptable_out
Outbound flexible priority mapping table resources.
mpls_cbts
CBTS statistics resources.
mpls_dynvpnid
VXLAN flooding MAC resources.
mpls_ecmplsp
ECMP LSP resources.
mpls_ilm
ILM label resources.
mpls_inlabel
Inbound MPLS label resources.
mpls_l3vpn
Number of L3VPN instances.
mpls_label
Label index resources.
mpls_lsp
MPLS LSP statistics resources.
mpls_outlabel
Outbound MPLS label resources.
mpls_te
Configured number of MPLS TE tunnels
mpls_outlif
MPLS outlif resources.
mpls_vp
MPLS VP resources.
mpls_vpls_pw
Number of PWs for VPLS instances
mpls_vpws
Configured VPWS number.
mpls_vsi
Number of VSIs.
mpls_vxlan_tunnel
Number of VXLAN tunnels.
mpls_vxlanvni
VXLAN private wire statistics resources.
mpls_pwrestrainres_0
PW rate limit resources.
mtunnel
Multicast tunnel interface resources.
mpls_tecar_profile
Profile resources of CAR rate limit for MPLS TE tunnels.
mpls_tecar_tb
TB resources of CAR rate limit for MPLS TE tunnels.
nd
ND resources.
nexthop
Next hop resources.
nqa_client_1564
Number of NQA client 1564 sessions.
nqa_client_2544
Number of NQA client 2544 sessions.
nqa_client_twamplight
Number of NQA client twamp sessions.
nqa_reflector_remote
Number of NQA server 1564 and 2544 sessions.
nqa_reflector_twamplight
NQA servertwamp sessions.
nqa_veinlif
NQA VEinlif resources.
port_shape
Main interface shaping resources.
qinq_inlif_0
Subinterface QinQ Inlif entry resources where 0 indicates forwarding chip ID.
qinq_inlif_tree_0
Subinterface QinQ Inlif tree entry resources, where 0 indicates forwarding chip ID.
qos_queue
QoS eight-queue resources.
queue_shape
Queue shaping resources.
queue_shape_in
Queue shaping resources in the inbound direction.
queue_shape_out
Queue shaping resources in the outbound direction.
queue_buffer
Queue buffer resources.
queue_buffer_in
Queue buffer resources in the inbound direction.
queue_buffer_out
Queue buffer resources in the outbound direction.
rport
Protocol port entry resources.
sampler
Sampler resources.
share_policy_in
Inbound shared MQC resources.
share_policy_out
Outbound shared MQC resources.
subif_tb_in
Inbound subinterface statistics resources.
subif_tb_out
Outbound subinterface statistics resources.
subport_shape
Subinterface shaping resources.
tunnel
Tunnel interface resources.
v4mcpro
IPv4 multicast entry resources.
v6mcpro
IPv6 multicast entry resources.
vfp_acl
VLAN-related ACL resources.
wfq_weight
Weight resources for weighted fair queuing.
wred_table
WRED template resources.
bras_out
Outbound BRAS user count resources.
bras_in
Inbound BRAS user count resources.
bras_car
CAR profile resources used by BRAS users.
by-absolute: Specifies resource depletion thresholds by using absolute values.
by-percent: Specifies resource depletion thresholds in percentage.
minor-threshold minor-threshold: Specifies the minor resource depletion threshold. To view the value range, enter a question mark (?) in the place of the minor-threshold argument.
severe-threshold severe-threshold: Specifies the severe resource depletion threshold. To view the value range, enter a question mark (?) in the place of the severe-threshold argument.
After you execute this command for a resource type, the device monitors the available amount of the type of resources. The device samples the available amount at intervals, compares the sample with the resource depletion thresholds to identify the resource depletion status, and sends alarms as configured.
# Set the minor resource depletion threshold to 30% and the severe resource depletion threshold to 10% for ARP entry resources on slot 1.
[Sysname] resource-monitor resource arpnd slot 1 cpu 0 by-percent minor-threshold 30 severe-threshold 10
restore factory-default
Use restore factory-default to restore the factory-default configuration for the device.
CAUTION
CAUTION:
This command restores the device to the factory default settings. Before using this command, make sure you fully understand its impact on your live network.
Use this command only when you cannot troubleshoot the device by using other methods, or you want to use the device in a different scenario.
The command takes effect after the device reboots.
# Restore the factory-default configuration for the device.
<Sysname> restore factory-default
This command will restore the system to the factory default configuration and clear the operation data. Continue [Y/N]:y
Restoring the factory default configuration. This process might take a few minutes. Please wait..........................................................................................................Done.
Please reboot the system to place the factory default configuration into effect.
reboot
scheduler job
Use scheduler job to create a job and enter its view, or enter the view of an existing job.
Use undo scheduler job to delete a job.
scheduler job job-name
undo scheduler job job-name
No job exists.
A job can be referenced by multiple schedules. In job view, you can assign commands to the job.
# Create a job named backupconfig and enter job view.
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig]
command
scheduler schedule
scheduler logfile size
Use scheduler logfile size to set the size of the job execution log file.
scheduler logfile size value
The size of the job execution log file is 16 KB.
value: Specifies the size of the job execution log file, in KB. The value range is 16 to 1024.
The job execution log file saves the execution information of jobs. If the file is full, old records are deleted to make room for new records. If the size of the log information to be written to the file is greater than the file size, the excessive information is not written to the file.
# Set the size of the job execution log file to 32 KB.
[Sysname] scheduler logfile size 32
scheduler reboot at
Use scheduler reboot at to specify the reboot date and time.
Use undo scheduler reboot to delete the reboot schedule configuration.
No reboot date or time is specified.
time: Specifies the reboot time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59.
date: Specifies the reboot date in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month.
CAUTION
CAUTION:
This command enables the device to reboot at a scheduled time, which causes service interruption. Before using this command, make sure you fully understand its impact on your live network.
When the date argument is not specified, the system uses the following rules to determine the reboot time:
·     If the reboot time is later than the current time, a reboot occurs at the reboot time of the current day.
·     If the reboot time is earlier than the current time, a reboot occurs at the reboot time the next day.
The device supports only one device reboot schedule. If you execute both the scheduler reboot delay and scheduler reboot at commands or execute one of the commands multiple times, the most recent configuration takes effect.
For data security, the system does not reboot at the reboot time if a file operation is being performed.
# Configure the device to reboot at 12:00 p.m. This example assumes that the current time is 11:43 a.m. on June 6, 2011.
<Sysname> scheduler reboot at 12:00
Reboot system at 12:00:00 06/06/2011 (in 0 hours and 16 minutes). Confirm? [Y/N]:
Use scheduler reboot delay to specify the reboot delay time.
scheduler reboot delay time
No reboot delay time is specified.
time: Specifies the reboot delay time in the hh:mm or mm format. This argument can contain up to six characters. When in the hh:mm format, mm must be in the range of 0 to 59.
CAUTION
CAUTION:
The device supports only one device reboot schedule. If you execute both the scheduler reboot delay and schedule reboot at commands or execute one of the commands multiple times, the most recent configuration takes effect.
# Configure the device to reboot after 88 minutes. This example assumes that the current time is 11:48 a.m. on June 6, 2011.
<Sysname> scheduler reboot delay 88
Reboot system at 13:16 06/06/2011(in 1 hours and 28 minutes). Confirm? [Y/N]:
scheduler schedule
Use scheduler schedule to create a schedule and enter its view, or enter the view of an existing schedule.
Use undo scheduler schedule to delete a schedule.
undo scheduler schedule schedule-name
No schedule exists.
schedule-name: Specifies the schedule name, a case-sensitive string of 1 to 47 characters.
You can configure a schedule to have the device automatically run a command or a set of commands without administrative interference.
To configure a schedule:
1.     Use the scheduler job command to create a job and enter job view.
2.     Use the command command to assign commands to the job.
3.     Use the scheduler schedule command to create a schedule and enter schedule view.
4.     Use the job command to assign the job to the schedule. You can assign multiple jobs to a schedule. The jobs must already exist.
5.     Use the user-role command to assign user roles to the schedule. You can assign up to 64 user roles to a schedule.
6.     Use the time at, time once, or time repeating command to specify an execution time for the schedule. You can specify only one execution time for a schedule.
# Create a schedule named saveconfig.
[Sysname] scheduler schedule saveconfig
job
time at
time once
shutdown-interval
Use shutdown-interval to set the port status detection timer.
Use undo shutdown-interval to restore the default.
shutdown-interval interval
The port status detection timer setting is 30 seconds.
interval: Specifies the port status detection timer value in seconds. The value range is 0 to 300. The value of 0 indicates that port status detection is not automatically performed, and you need to execute the undo shutdown command to restore the port status manually.
The device starts a port status detection timer when a port is shut down by a protocol. If the port has been in down state before the timer expires, the device will set the port status to the port's physical status.
If you change the timer setting during port detection, the device compares the new setting (T1) with the time that elapsed since the port was shut down (T).
·     If T < T1, the port will be brought up after T1 – T seconds.
·     If T ≥ T1, the port is brought up immediately.
For example, the timer setting is 30 seconds. If you change it to 10 seconds 2 seconds after the port is shut down, the port will come up 8 seconds later. If you change the timer setting to 2 seconds 10 seconds after the port is shut down, the port comes up immediately.
# Set the port status detection timer to 100 seconds.
[Sysname] shutdown-interval 100
switch-fabric removal-signal-report enable
Use switch-fabric removal-signal-report enable to enable removal interrupt signal reporting from switching fabric modules.
Use undo switch-fabric removal-signal-report enable to restore the default.
Removal interrupt signal reporting is disabled for switching fabric modules
After this command is used, removing a switching fabric module triggers one removal interrupt signal. Upon receiving the signal, the system switches traffic on the switching fabric module to other switching fabric modules to avoid service interruption.
# Enable removal interrupt signal reporting from switching fabric modules.
[Sysname] switch-fabric removal-signal-report enable
sysname
Use sysname to set the device name.
Use undo sysname to restore the default.
sysname sysname
undo sysname
The device name is H3C.
sysname: Specifies a name for the device, a string of 1 to 64 characters.
A device name identifies a device in a network and is used in CLI view prompts. For example, if the device name is Sysname, the user view prompt is <Sysname>.
# Set the name of the device to R2000.
[Sysname] sysname R2000
[R2000]
system forward-mode extended
Use system forward-mode extended to set the system forwarding mode to extended.
Use undo system forward-mode extended to restore the default.
The system forwarding mode is standard.
In standard mode, the device operates in good condition.
In extended mode, the device records the logs of forwarding modules. This mode is used only for device maintenance.
A system forwarding mode change takes effect after a device reboot.
# Set the system forwarding mode to extended.
<Sysname> system
[Sysname] system forward-mode extended
Do you want to change the system forwarding mode? [Y/N]:y
System forwarding mode changed. For the change to take effect, save the running configuration and reboot the device.
system turbo enable
Use system turbo enable to enable system performance optimization.
Use undo system turbo enable to disable system performance optimization.
system turbo enable
This command is available only for testing.
Contact Technical Support before using this command.
# Enable system performance optimization.
<Sysname> system
[Sysname] system turbo enable
subslot-working-mode
Use subslot-working-mode to set the operating mode of a slot.
Use undo subslot-working-mode to restore the default.
subslot-working-mode slot slot-number { ethernet-flexe | detnet | ethernet-flexe-otn }
undo subslot-working-mode slot slot-number
The operating mode of a slot varies by device model.
ethernet-flexe: Sets the slot operating mode to ethernet-flexe. In this mode, an interface of the card installed to the specified slot supports switching between standard Ethernet mode and flexible Ethernet mode.
detnet: Sets the slot operating mode to detnet. In this mode, an interface of the card installed to the specified slot supports only the detnet mode.
ethernet-flexe-otn: Sets the slot operating mode to ethernet-flexe-otn.
The detnet mode takes effect only on the MIC-CQ1LF-M and MIC-XP10L-M interface cards.
The ethernet-flexe-otn mode takes effect only on the MIC-XP10L-M interface card.
For information about switching between standard Ethernet mode and flexible Ethernet mode, see FlexE interface configuration in Interface Configuration Guide.
# Set the slot operating mode to ethernet-flexe.
[Sysname] subslot-working-mode slot 3 ethernet-flexe
Change of the slot working mode will reboot the subcard. Continue? [Y/N]:
temperature-limit
Use temperature-limit to set the temperature alarm thresholds.
Use undo temperature-limit to restore the default.
temperature-limit slot slot-number { hotspot | inflow | outflow } sensor-number lowlimit warninglimit [ alarmlimit ]
undo temperature-limit slot slot-number { hotspot | inflow | outflow } sensor-number
The defaults vary by temperature sensor model. To view the defaults, execute the undo temperature-limit and display environment commands in turn.
hotspot: Configures temperature alarm thresholds for hotspot sensors. A hotspot sensor is typically located near a high-heat chip to monitor the chip temperature.
inflow: Configures temperature alarm thresholds for inlet sensors. An inflow sensor is located near an air inlet to monitor the ambient temperature.
outflow: Configures temperature alarm thresholds for outlet sensors. An outflow sensor is located near an air outlet to monitor the device temperature.
sensor-number: Specifies a sensor by its number. To view the value range, enter a question mark (?) in the place of this argument.
lowlimit: Specifies the low-temperature threshold in Celsius degrees. The value range varies by temperature sensor. To view the value range, enter a question mark (?) in the place of this argument.
warninglimit: Specifies the high-temperature warning threshold in Celsius degrees. This threshold must be greater than the low-temperature threshold. To view the value range, enter a question mark (?) in the place of this argument.
alarmlimit: Specifies the high-temperature alarming threshold in Celsius degrees. This threshold must be greater than the warning threshold. To view the value range, enter a question mark (?) in the place of this argument.
When the device temperature drops below the low-temperature threshold or reaches the high-temperature warning or alarming threshold, the device performs the following operations:
·     Sends log messages and traps.
·     Sets LEDs on the device panel.
# Set temperature alarm thresholds for hotspot sensor 1 in a slot.
[Sysname] temperature-limit slot 1 hotspot 1 -10 50 60
display environment
time at
Use time at to specify an execution date and time for a non-periodic schedule.
Use undo time to delete the execution date and time configuration for a non-periodic schedule.
time at time date
undo time
No execution time or date is specified for a non-periodic schedule.
Schedule view
time: Specifies the schedule execution time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59.
date: Specifies the schedule execution date in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month.
The specified time (date plus time) must be later than the current system time.
The time at command, the time once command, and the time repeating command overwrite each other. The most recently executed command takes effect.
# Configure the device to execute the saveconfig schedule at 01:01 a.m. on May 11, 2011.
[Sysname-schedule-saveconfig] time at 1:1 2011/05/11
scheduler schedule
time once
Use time once to specify one or more execution days and the execution time for a non-periodic schedule.
Use undo time to delete the execution day and time configuration for a non-periodic schedule.
time once delay time
undo time
No execution time or day is specified for a non-periodic schedule.
Schedule view
at time: Specifies the execution time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59.
month-date month-day: Specifies a day in the current month, in the range of 1 to 31. If you specify a day that does not exist in the current month, the configuration takes effect on that day in the next month.
week-day week-day&<1-7>: Specifies a space-separated list of up to seven week days for the schedule. Valid week day values include Mon, Tue, Wed, Thu, Fri, Sat, and Sun.
delay time: Specifies the delay time for executing the schedule, in the hh:mm or mm format. This argument can have up to six characters. When in the hh:mm format, mm must be in the range of 0 to 59.
If the specified time has already occurred, the schedule will be executed at the specified time the following day.
If the day in the month has already occurred, the schedule will be executed at the specified day in the following month.
If the specified day in a week has already occurred, the schedule will be executed at the specified day in the following week.
# Configure the device to execute the saveconfig schedule once at 15:00.
[Sysname-schedule-saveconfig] time once at 15:00
Schedule starts at 15:00 5/11/2011.
# Configure the device to execute the saveconfig schedule once at 15:00 on the coming 15th day in a month.
[Sysname-schedule-saveconfig] time once at 15:00 month-date 15
# Configure the device to execute the saveconfig schedule at 12:00 p.m. on the coming Monday and Friday.
[Sysname-schedule-saveconfig] time once at 12:00 week-day mon fri
# Configure the device to execute the saveconfig schedule after 10 minutes.
[Sysname-schedule-saveconfig] time once delay 10
scheduler schedule
time repeating
Use time repeating to specify an execution time table for a periodic schedule.
Use undo time to delete the execution time table configuration for a periodic schedule.
time repeating [ at time [ date ] ] interval interval
undo time
No execution time table is specified for a periodic schedule.
Schedule view
at time: Specifies the execution time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. If you do not specify this option, the current system time is used as the execution time.
date: Specifies the start date for the periodic schedule, in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month. If you do not specify this argument, the execution start date is the first day when the specified time arrives.
interval interval: Specifies the execution time interval in the hh:mm or mm format. This argument can have up to six characters. When in the hh:mm format, mm must be in the range of 0 to 59. When in the mm format, this argument must be equal to or greater than 1 minute.
month-date [ month-day | last ]: Specifies a day in a month, in the range 1 to 31. The last keyword indicates the last day of a month. If you specify a day that does not exist in a month, the configuration takes effect on that day in the next month.
The time repeating [ at time [ date ] ] interval interval command configures the device to execute a schedule at intervals from the specified time on.
The time repeating at time [ month-date [ month-day | last ] | week-day week-day&<1-7> ] command configures the device to execute a schedule at the specified time on every specified day in a month or week.
The time at command, the time once command, and the time repeating command overwrite each other, whichever is executed most recently takes effect.
# Configure the device to execute the saveconfig schedule once an hour from 8:00 a.m. on.
[Sysname-schedule-saveconfig] time repeating at 8:00 interval 60
# Configure the device to execute the saveconfig schedule at 12:00 p.m. every day.
[Sysname-schedule-saveconfig] time repeating at 12:00
# Configure the device to execute the saveconfig schedule at 8:00 a.m. on the 5th of every month.
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date 5
# Configure the device to execute the saveconfig schedule at 8:00 a.m. on the last day of every month.
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date last
# Configure the device to execute the saveconfig schedule at 8:00 a.m. every Friday and Saturday.
[Sysname-schedule-saveconfig] time repeating at 8:00 week-day fri sat
scheduler schedule
transceiver auto-laser-down
Use transceiver auto-laser-down to configure auto laser shutdown.
Use undo transceiver auto-laser-down to restore the default.
transceiver auto-laser-down { enable | disable | uniform-control }
The auto laser shutdown is under unified control.
Ethernet interface view
POS interface view
CPOS interface view
enable: Enables auto laser shutdown.
disable: Disables auto laser shutdown.
uniform-control: Puts auto laser shutdown under unified control. That is, the enabling status of auto laser shutdown depends on the energy saving mode of the device.
If you put auto laser shutdown under unified control, the enabling status of auto laser shutdown depends on the energy saving mode of the device:
·     If the standard energy saving mode is set, auto laser shutdown is disabled.
·     If the basic or deep energy saving mode is set, auto laser shutdown is enabled.
If you execute this command to enable or disable auto laser shutdown, the enabling status of auto laser shutdown will not change with the energy saving mode of the device.
Only fiber interfaces that are not used for unidirectional communication support this command, and copper interfaces do not support this command.
The fiber interfaces that are connected to high-speed cables or fiber-to-copper transceiver modules do not support this command. If a fiber interface is connected to high-speed cables or fiber-to-copper transceiver modules, the system will clear all commands related with auto laser shutdown on this interface.
After auto laser shutdown is enabled, the transceiver laser on an interface will automatically shut down when the interface goes down. In this case, you need to execute transceiver auto-laser-down restart-mode to specify the laser restart mode to manually or automatically enable the laser to send pulses. If the auto restart mode is specified, the system will send pulses at intervals (100s by default) until the interface for the transceiver module comes up. Then, the laser can operate normally.
Support for this command depends on the device configuration. When the device is installed with subcards that do not support this command, you cannot execute this command on the device.
# Enable auto laser shutdown for interface Ten-GigabitEthernet 3/0/1.
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] transceiver auto-laser-down enable
display transceiver auto-laser-down
energy-saving mode
Use transceiver auto-laser-down restart to restart the laser of a transceiver module.
POS interface view
CPOS interface view
Before you execute this command, enable auto laser shutdown and specify the manual laser restart mode.
After the optical fiber recovers from failure, you can execute this command to start up the laser immediately.
# Manually restart the laser of the transceiver module in interface Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] transceiver auto-laser-down restart
Use transceiver auto-laser-down restart-mode to specify the restart mode for the laser of a transceiver module.
Use undo transceiver auto-laser-down restart-mode to restore the default.
transceiver auto-laser-down restart-mode { auto [ pulse-interval interval ] | manual } [ pulse-width width ]
The auto restart mode is specified for the laser of a transceiver module.
POS interface view
CPOS interface view
auto [ pulse-interval interval ]: Specifies the auto restart mode. In this mode, the laser sends pulses at an interval that is specified by the pulse-interval interval option after the laser restart, in seconds. The value for the interval argument varies by device model.
manual: Specifies the manual restart mode.
pulse-width width: Specifies the pulse width (duration) for optical detection after the laser restart, in seconds. The value for the width argument varies by device model.
Before you execute this command for a transceiver module, enable the auto laser shutdown for the transceiver module.
If the auto restart mode is specified for a laser, the laser sends pulses at an interval specified by the pulse-interval argument to detect whether the link is recovered.
To quickly restore data communication when you can obtain information about the fiber link recovery in time, you can specify the manual restart mode to make the laser emit light immediately. If the manual restart mode is specified, execute the transceiver auto-laser-down restart command for the laser to send a pulse when you need to restart the laser.
# Specify the manual restart mode for the laser of the transceiver module in Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] transceiver auto-laser-down restart-mode manual
# Specify the auto restart mode for the laser of the transceiver module in Ten-GigabitEthernet 3/0/1, the interval for sending pulses as 150s, and pulse width as 3s.
[Sysname-Ten-GigabitEthernet3/0/1] transceiver auto-laser-down restart-mode auto pulse-interval 150 pulse-width 3
transceiver lane cdr
Use transceiver lane cdr to configure CDR on a transmit or receive lane for a QSFP transceiver module.
Use undo transceiver lane cdr to restore the default.
transceiver lane [ lane-number ] cdr { tx | rx } { on | off }
undo transceiver lane [ lane-number ] cdr { tx | rx }
CDR is enabled on a transmit or receive lane on a QSFP transceiver module.
lane-number: Specifies a transceiver lane number, in the range of 1 to 4. If you do not specify a transceiver lane, the command applies to all transceiver lanes.
tx: Specifies the transmit link on the transceiver module.
rx: : Specifies the receive link on the transceiver module.
on: Enables CDR.
off: Disables CDR.
Enabling CDR can reduce the jitter to improve transmission performance, and disabling CDR degrades transmission performance. Both the enable and disable operations might cause oscillation on device ports.
The configuration by this command is saved in a register on the transceiver module. It is not saved to the configuration file.
This command is supported only on the QSFP transceiver modules.
# Enable CDR on the transmit side on the QSFP transceiver module in interface HundredGigE 3/0/1.
[Sysname] interface hundredgige 3/0/1
[Sysname-HundredGigE3/0/1] transceiver lane cdr tx on
This command will engage the internal retiming function of transceiver Tx route. Continue? [Y/N]:Y
# Disable CDR on the receive side on the QSFP transceiver module in interface HundredGigE 3/0/1.
[Sysname-HundredGigE3/0/1] transceiver lane cdr rx off
This command will enable an internal bypassing mode of transceiver Rx route, which directs traffic around the internal CDR. Continue? [Y/N]:Y
display transceiver status
transceiver lane enable
Use transceiver lane enable to enable a lane on a transceiver module.
Use undo transceiver lane to disable a lane on a transceiver module.
transceiver lane [ lane-number ] enable
undo transceiver lane [ lane-number ] enable
All lanes on a transceiver module are enabled.
lane-number: Specifies a lane by its number. If you do not specify a lane, this command enables all lanes on the transceiver module. The value range is fixed at 1 for an SFP transceiver module, and 1 to 4 for a QSFP transceiver module. If you do not specify a lane, this command enables all lanes on the transceiver module.
Execute this command only to verify that a transceiver module operates correctly.
Disabling a lane will stop signal transmission on the lane.
Disabling a lane will stop signal transmission on the fiber port where the lane is located.
This setting is saved in a register on the transceiver module. It is not saved to the configuration file.
This command is supported only on the SFP and QSFP transceiver modules.
# Enable lane 1 on the QSFP transceiver module in interface HundredGigE 3/0/1.
[Sysname-HundredGigE3/0/1] transceiver lane 1 enable
transceiver power-mode
Use transceiver power-mode to set the power mode for a transceiver module.
Use undo transceiver power-mode to restore the default.
transceiver power-mode { high | low }
The transceiver module operates in high power mode.
A transceiver module typically operates in high power mode. If a transceiver module will be idle for a long time, you can switch it to low power mode to reduce power consumption. In low power mode, the transceiver module does not transmit signals. For a transceiver module to transmit signals, you must configure it to operate in high power mode.
This command is supported only on a QSFP transceiver module.
# Configure the QSFP transceiver module in HundredGigE 3/0/1 to operate in high power mode.
[Sysname-HundredGigE3/0/1] transceiver power-mode high
# Configure the QSFP transceiver module in HundredGigE 3/0/1 to operate in low power mode.
[Sysname-HundredGigE3/0/1] transceiver power-mode low
This command will place the transceiver module in low-power-consumption mode, disabling the transceiver module from transmitting data. Continue? [Y/N]:Y
user-role
Use user-role to assign user roles to a schedule.
Use undo user-role to remove user roles from a schedule.
user-role role-name
undo user-role role-name
A schedule has the user roles of the schedule creator.
Schedule view
role-name: Specifies a user role name, a case-sensitive string of 1 to 63 characters. The user role can be user-defined or predefined. Predefined user roles include network-admin, network-operator, and level-0 to level-15.
A schedule must have one or more user roles. A command in a schedule can be executed if it is permitted by one or more user roles of the schedule. For more information about user roles, see the RBAC configuration in Fundamentals Configuration Guide.
A schedule can have a maximum of 64 user roles. After the limit is reached, you cannot assign additional user roles to the schedule.
The security log manager user role is mutually exclusive with other user roles. That is, if the security log manager user role has been assigned, the system will automatically remove the existing other user roles. If the other user roles have been assigned, the system will automatically remove the existing security log manager user role.
# Assign the rolename user role to the test schedule.
<sysname> system-view
[Sysname] scheduler schedule test
[Sysname-schedule-test] user-role rolename
# Assign the security-audit user role to the test schedule.
[Sysname-schedule-test]user-role security-audit
This operation will delete all other user roles for the schedule. Are you sure? [Y/N]:y
# Change the user role assigned to the test schedule from security-audit to network-admin.
[Sysname-schedule-test]user-role network-admin
This operation will delete security auditor user role for the schedule. Are you sure? [Y/N]:y
command
scheduler schedule
