01-Fundamentals Command Reference
HomeSupportRoutersCR16000-M SeriesReference GuidesCommand ReferencesH3C CR16000-M Routers Command Reference-R8530Pxx-6W10101-Fundamentals Command Reference
09-Automatic configuration commands
09-Automatic configuration commands 37.13 KB
autodeploy udisk enable
Use autodeploy udisk enable to enable USB-based automatic configuration.
Use undo autodeploy udisk enable to disable USB-based automatic configuration.
USB-based automatic configuration is enabled.
# Disable USB-based automatic configuration.
[Sysname] undo autodeploy udisk enable
autodeploy url enable
Use autodeploy url enable to enable URL-based automatic configuration.
Use undo autodeploy url enable to disable URL-based automatic configuration.
URL-based automatic configuration is enabled.
With URL-based automatic configuration enabled on a device, the administrator can automatically deploy basic configuration to the device through an URL link to complete zero-touch provisioning for the device.
# Enable URL-based automatic configuration.
[Sysname] autodeploy url enable
