13-Network Management and Monitoring Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C S6526XE-HI[EI] Switch Series Configuration Guides-R8340Pxx-6W10013-Network Management and Monitoring Configuration Guide
16-Sampler configuration
16-Sampler configuration 41.97 KB
Configuring samplers
About sampler
A sampler selects a packet from sequential packets and sends the packet to other service modules for processing. Sampling is useful when you want to limit the volume of traffic to be analyzed. The sampled data is statistically accurate and sampling decreases the impact on the forwarding capacity of the device.
The random sampling mode is supported. In this mode, any packet might be selected from sequential packets in each sampling.
Creating a sampler
2.     Create a sampler.
sampler sampler-name mode random packet-interval n-power rate
By default, no samplers exist.
Display and maintenance commands for a sampler
Display configuration information about the sampler.
display sampler [ sampler-name ] [ slot slot-number ]
