- 10-MPLS Configuration Guide
- 01-Basic MPLS configuration
- 02-Static LSP configuration
- 03-LDP configuration
- 04-MPLS TE configuration
- 05-Static CRLSP configuration
- 06-RSVP configuration
- 07-Tunnel policy configuration
- 08-MPLS L3VPN configuration
- 09-MPLS L2VPN configuration
- 10-VPLS configuration
- 11-L2VPN access to L3VPN or IP backbone configuration
- 12-MPLS OAM configuration
- 13-MCE configuration
| 12-MPLS OAM configuration | 403.05 KB |
About LSP connectivity verification
Performing MPLS tracert for LSPs
Configuring BFD for LSPs (control packet mode)
Configuring BFD for LSPs (echo packet mode)
Configuring tunnel BFD for LSPs
Configuring periodic MPLS tracert for LSPs
Verifying MPLS TE tunnel connectivity
About MPLS TE tunnel connectivity verification
Performing MPLS ping for MPLS TE tunnels
Performing MPLS tracert for MPLS TE tunnels
Configuring a static BFD session for an MPLS TE tunnel
Configuring BFD for MPLS TE tunnels (control packet mode)
Configuring BFD for MPLS TE tunnels (echo packet mode)
Configuring BFD for PCE-initiated tunnels
Configuring tunnel BFD for MPLS TE tunnels
Configuring tunnel BFD for PCE-initiated tunnels
Configuring SBFD for MPLS TE tunnels
Configuring tunnel SBFD for MPLS TE tunnels
About PW connectivity verification
Restrictions and guidelines for PW connectivity verification
Performing MPLS tracert for a PW
Verifying Flex-Algo LSP connectivity
Performing MPLS ping for a Flex-Algo LSP
Performing MPLS tracert for a Flex-Algo LSP
Configuring SBFD for Flex-Algo LSPs
Verifying the SR-MPLS TE policy tunnel connectivity
About verifying SR-MPLS TE policy tunnel connectivity
Performing MPLS ping for SR-MPLS TE policy tunnels
Performing MPLS tracert for SR-MPLS TE policy tunnels
Configuring SBFD for SR-MPLS TE policy tunnels
Display and maintenance commands for MPLS OAM
MPLS OAM configuration examples
Example: Configuring BFD for LSP
Configuring MPLS OAM
About MPLS OAM
· MPLS data plane connectivity verification.
· Data plane and control plane consistency verification.
· Fault locating.
Fault management tools
The fault management tools include the following types:
· On-demand tools—Tools that must be triggered manually, such as MPLS ping and MPLS tracert.
· Proactive tools—Tools that are triggered by the system automatically, such as BFD for MPLS, and periodic MPLS tracert.
You can use these tools to detect and locate faults of LSPs, MPLS TE tunnels, and MPLS PWs.
MPLS ping
MPLS ping tests the connectivity of an LSP tunnel, an MPLS TE tunnel, a PW, a Flex-Algo LSP, or an SR-MPLS TE policy tunnel. At the ingress node, MPLS ping adds the label associated with a tunnel into an MPLS echo request and sends it to the egress node over the tunnel. The egress node processes the request and returns an MPLS echo reply to the ingress node. An MPLS echo reply with a success notification indicates that the tunnel is available for data forwarding. An MPLS echo reply with an error code indicates that the tunnel has failed.
MPLS tracert
MPLS tracert displays the path that an MPLS LSP tunnel, PW, MPLS TE tunnel, a Flex-Algo LSP, or SR-MPLS TE policy tunnel travels from the ingress to the egress to locate errors on the tunnel. MPLS tracert consecutively sends MPLS echo requests along the tunnel, with the TTL increasing from 1 to a specific value. Each hop along the tunnel returns an MPLS echo reply to the ingress due to TTL timeout so the ingress can collect information about each hop along the tunnel. This information allows you to locate the failed node or access information for each hop, for example, the label allocated by each downstream hop.
BFD for MPLS
BFD for MPLS uses a BFD session to proactively verify the connectivity of an LSP tunnel, an MPLS TE tunnel, or a PW tunnel.
BFD for MPLS supports the following detection modes:
· BFD—Detects primary path failure. When the primary path fails, BFD can quickly detect the failure and notify the device to switch traffic to the backup path. When both the primary and backup paths fail, the BFD detection mechanism fails.
BFD supports detecting failures on the primary path of an MPLS TE tunnel or a PW.
· Tunnel BFD—Detects failures on the primary path and all the backup paths. When both the primary path and the current backup path fail, tunnel BFD can quickly detect the failures and trigger a protection measure, such as MPLS L3VPN ECMP route based load balancing and FRR. This mode can minimize the traffic loss.
BFD can be implemented in control packet mode or echo packet mode. In echo packet mode, BFD for MPLS can verify the connectivity of only MPLS TE tunnels.
BFD control packet mode
In control packet mode, BFD for MPLS performs the following operations:
1. Establishes a BFD session between the ingress and egress of the tunnel to be inspected.
2. Adds the label associated with the tunnel into a BFD control packet at the ingress.
3. Sends the packet to the egress node over the tunnel.
4. Determines the tunnel status according to the BFD control packet returned by the egress.
When BFD detects a connectivity failure, it triggers the pre-configured action, such as FRR or path protection switching, to ensure uninterrupted traffic forwarding.
A BFD session for LSP, MPLS TE tunnel, or PW connectivity verification can be established in one of the following modes:
· Static mode—On the ingress and egress nodes, manually specify the local and remote discriminators through command lines to establish the BFD session.
· Dynamic mode—On the ingress node, manually specify the local and remote discriminators. On the egress node, you do not need to specify local and remote discriminators. After receiving an LSP ping request that carries a BFD TVL, the egress returns an LSP ping reply and establishes a passive mode BFD session.
In static mode, the egress node returns a BFD control packet to the ingress node through the reverse tunnel. If no reverse tunnel exists, the ingress node cannot receive the BFD control packet, resulting in a verification failure.
In dynamic mode, the egress node returns a BFD control packet to the ingress node through the reverse tunnel. If no reverse tunnel exists, the egress mode returns a BFD packet through IP routing.
Use the static mode to test the connectivity of a pair of LSPs or MPLS TE tunnels in opposite directions between two devices. Use the dynamic mode to test the connectivity of one LSP or MPLS TE tunnel from the local device to the remote device.
A PW is bidirectional. You will get the correct result using either the static or dynamic mode.
BFD Echo packet mode
In echo packet mode, BFD for MPLS performs the following operations:
1. Establishes a BFD session at the ingress of the tunnel to be inspected.
2. Adds the label associated with the tunnel into a BFD echo packet at the ingress.
3. Sends the echo packet to the egress node over the tunnel.
4. Without establishing a BFD session at the egress node, makes the egress node forward the echo packet back to the ingress node.
5. Determines the tunnel status according to whether the ingress node receives the BFD echo packet.
SBFD for MPLS
SBFD for MPLS uses an SBFD session to proactively verify the connectivity of an LSP tunnel, MPLS TE tunnel or SR-MPLS TE policy tunnel. After SBFD detects a connection failure, it notifies the device to take a protection measure, such as switching traffic to the backup tunnel.
SBFD performs unidirectional detection for a path. It is faster than BFD. If only one-end of a path requires path connectivity detection, you can deploy SBFD.
SBFD for MPLS supports echo packet mode and control packet mode.
The SBFD echo packet mode operates as follows:
1. Establishes an SBFD session at the ingress of the tunnel to be inspected.
2. Adds the label associated with the tunnel into an echo packet at the ingress.
4. Without establishing an SBFD session at the egress node, makes the egress node forward the echo packet back to the ingress node.
The SBFD control packet mode operates as follows:
1. Establishes an SBFD session between the ingress node and egress node of the tunnel to be verified. The ingress node is the session initiator, and the egress node is the reflector.
2. The ingress node adds the label associated with the tunnel into an SBFD control packet and sends it to the egress node over the tunnel.
3. The egress node gets the SBFD control packet, and returns an SBFD control packet reply to the ingress node.
4. The ingress node determines the connectivity status of the tunnel according to the received reply packet.
The device supports establishing SBFD sessions for MPLS only in static mode. You must use a command to specify the remote discriminator to establish the SBFD session.
Periodic MPLS tracert
The periodic MPLS tracert feature automatically traces an LSP tunnel at intervals. It locates errors on the LSP tunnel, verifies the consistency of the data plane and control plane, and records the detected errors in system logs. You can check the logs to monitor LSP connectivity.
If both BFD and periodic MPLS tracert are configured for an LSP, and the periodic tracert feature detects a data plane and control plane inconsistency, the device performs the following tasks:
1. Deletes the BFD session for the LSP.
2. Re-establishes the BFD session based on the control plane.
Protocols and standards
· RFC 4379, Detecting Multi-Protocol Label Switched (MPLS) Data Plane Failures
· RFC 5085, Pseudowire Virtual Circuit Connectivity Verification (VCCV): A Control Channel for Pseudowires
· RFC 5885, Bidirectional Forwarding Detection (BFD) for the Pseudowire Virtual Circuit Connectivity Verification (VCCV)
Verifying LSP connectivity
To verify LSP connectivity, you can use one of the following methods:
· Use the ping mpls ipv4 command or the tracert mpls ipv4 command to trigger LSP connectivity verification as needed.
· Configure BFD or periodic MPLS tracert for the system to automatically verify LSP connectivity.
Performing MPLS ping for LSPs
Pinging the LSPs for an IPv4 prefix
To verify MPLS LSP connectivity for an IPv4 prefix, execute the following command in any view:
ping mpls [ -a source-ip | -c count | -exp exp-value | -h ttl-value | -m wait-time | -r reply-mode | -rtos tos-value | -s packet-size | -t time-out | -v ] * ipv4 ipv4-address mask-length [ nexthop nexthop-address ] [ destination start-address [ end-address [ address-increment ] ] ] [ fec-type { bgp | generic | isis | ldp | ospf } ] [ remote-fec { ldp remote-ip-addr remote-mask-len | nil } ]
Pinging the LSPs of the specified outgoing labels
To verify MPLS LSP connectivity by specifying the outgoing labels, execute the following command in any view:
ping mpls [ -a source-ip | -c count | -exp exp-value | -h ttl-value | -m wait-time | -r reply-mode | -rtos tos-value | -s packet-size | -t time-out | -v ] * out-labels out-label-value&<1-15> interface interface-type interface-number [ nexthop nexthop-address ]
To use this feature, make sure the mpls ttl expiration enable command is configured on all the devices in the MPLS network. For more information about the mpls ttl expiration enable command, see the basic MPLS commands in MPLS Command Reference.
Tracing the path of the LSPs for an IPv4 prefix
To trace the path that the LSPs for an IPv4 prefix take from the ingress node to the egress node, execute the following command in any view:
tracert mpls [ -a source-ip | -exp exp-value | -h ttl-value | -r reply-mode | -rtos tos-value | -t time-out | -v | ddmap | fec-check ] * ipv4 ipv4-address mask-length [ nexthop nexthop-address ] [ destination start-address [ end-address [ address-increment ] ] ] [ fec-type { bgp | generic | isis | ldp | ospf } ] [ remote-fec { ldp remote-ip-addr remote-mask-len | nil } ]
Tracing the path of the LSPs of the specified outgoing labels
To trace the path that the LSPs of the specified outgoing labels take from the ingress node to the egress node, execute the following command in any view:
tracert mpls [ -a source-ip | -exp exp-value | -h ttl-value | -r reply-mode | -rtos tos-value | -t time-out | -v | fec-check ]* out-labels out-label-value&<1-15> interface interface-type interface-number [ nexthop nexthop-address ]
Perform this task to create a BFD session for LSPs to verify the LSP connectivity.
When an LSP fails, BFD can quickly detect the failure and notify the device to take an action, such as switching traffic to the backup LSP.
To configure BFD for an LSP, configure both the local and remote devices as described in Table 1.
Table 1 Configurations on the local and remote devices
BFD session establishment mode |
Node type |
Execute the "mpls bfd enable" command? |
Execute the "mpls bfd" command? |
Configure the discriminator keyword? |
Static mode |
Local |
Yes |
Yes |
Yes |
Remote |
Yes |
Yes |
Yes |
Dynamic mode |
Local |
Yes |
Yes |
No |
Remote |
Yes |
No |
N/A |
Follow these guidelines to configure BFD for an LSP tunnel:
· To establish a static BFD session, ensure that the local and remote discriminators configured locally are identical with the remote and local discriminators configured on the remote device, respectively.
· On a BFD session established in static mode, the ingress node and egress node both operate in active mode. On a BFD session established in dynamic mode, the ingress node operates in passive mode and the egress node operates in active mode. Executing the bfd session init-mode command on the ingress or egress node does not change the node's operating mode.
The source address of the BFD session is the MPLS LSR ID of the local device. Before configuring BFD for the LSP tunnel, perform the following tasks:
· Configure an MPLS LSR ID for the local device.
· Make sure a route is available on the remote device to reach the MPLS LSR ID.
1. Enter system view.
2. Enable BFD for MPLS.
mpls bfd enable
By default, BFD for MPLS is disabled.
3. (Optional.) Enable dynamic establishment of passive mode BFD sessions.
mpls bfd passive enable
By default, device can dynamically establish passive mode BFD sessions.
This command is required only on the egress node to establish a dynamic BFD session.
4. (Optional.) Remove the Router Alert option in BFD packets.
undo bfd ip-router-alert
By default, the Router Alert option is carried in BFD packets for LSP connectivity verification.
Execute this command on the local device if the peer device cannot identify the Router Alert option in BFD packets.
This command takes effect only on BFD sessions that come up after this command is executed.
5. Configure the BFD control packet mode to verify LSP connectivity for an FEC.
¡ To use a static BFD session:
mpls bfd dest-addr mask-length nexthop nexthop-address discriminator local local-id remote remote-id [ bgp-lsp | isis-srlsp | ldp-lsp | ospf-srlsp | static-lsp ] [ template template-name ]
¡ To use a dynamic BFD session:
mpls bfd dest-addr mask-length nexthop nexthop-address [ ldp-fec | nil-fec ] [ template template-name ] [ source-ip ipv4-address ]
mpls bfd dest-addr mask-length [ ldp-fec ] [ template template-name ] [ source-ip ipv4-address ]
By default, the BFD control packet mode is not configured to verify LSP connectivity for an FEC.
If you specify the next hop of an LSP, the device creates a BFD session for the LSP. If you do not specify a next hop, the device creates BFD sessions for all LSPs destined for the FEC.
You cannot specify the next hop of an LSP when configuring nested LSP connectivity verification.
If both BFD and FRR are enabled for an LSP, set the BFD detection interval for LSP connectivity verification to be longer than that for FRR. Otherwise, the BFD session for LSP connectivity verification will be down during an FRR switchover.
· The source address of the BFD session is the MPLS LSR ID of the local device. Before configuring BFD for the LSP tunnel, perform the following tasks:
¡ Configure an MPLS LSR ID for the local device.
¡ Make sure a route is available on the remote device to reach the MPLS LSR ID.
· Configure the bfd echo-source-ip command on the local device to specify a source IP address for echo packets.
mpls bfd enable
3. Configure the BFD echo packet mode to verify LSP connectivity.
mpls bfd dest-addr mask-length nexthop nexthop-address echo [ template template-name ] [ source-ip ipv4-address ]
mpls bfd dest-addr mask-length echo [ template template-name ] [ source-ip ipv4-address ]
By default, the BFD echo packet mode is not configured to verify LSP connectivity.
The mpls bfd command can detect only the primary LSP failure. When the primary LSP fails, BFD can quickly detect the failure and notify the device to switch traffic to the backup LSP. When both the primary and backup LSPs fail, the BFD detection mechanism fails. Traffic is lost until another mechanism detects the failures and triggers a traffic protection measure (such as MPLS L3VPN ECMP route based load balancing and FRR).
To resolve this issue, you can execute the mpls tunnel-bfd command to configure tunnel BFD, which detects failures on the primary LSP and all the backup LSPs. When both the primary LSP and current backup LSP fail, tunnel BFD can quickly detect the failures and trigger a traffic protection measure to switch traffic to an available backup LSP.
To configure tunnel BFD for an LSP, configure both the local and remote devices as described in Table 2.
Table 2 Configurations on the local and remote devices
Node type |
Execute the "mpls tunnel-bfd" command? |
Static mode |
Local |
Yes |
Yes |
Yes |
Remote |
Yes |
Yes |
Yes |
Dynamic mode |
Local |
Yes |
Yes |
No |
Remote |
Yes |
No |
N/A |
Follow these guidelines to configure tunnel BFD for an LSP tunnel:
The source address of the BFD session is the MPLS LSR ID of the local device. Before configuring tunnel BFD for the LSP tunnel, perform the following tasks:
Configuring control packet mode tunnel BFD for LSPs
mpls bfd enable
3. (Optional.) Remove the Router Alert option in BFD packets.
4. Configure control packet mode tunnel BFD to verify LSP connectivity for an FEC.
mpls tunnel-bfd dest-addr mask-length discriminator local local-id remote remote-id [ bgp-lsp | isis-srlsp | ldp-lsp | ospf-srlsp | static-lsp ] [ template template-name ]
mpls tunnel-bfd dest-addr mask-length [ ldp-fec | nil-fec ][ template template-name ] [ source-ip ipv4-address ]
By default, tunnel BFD is not configured to verify LSP connectivity for an FEC.
Configuring echo packet mode tunnel BFD for LSPs
mpls bfd enable
4. Configure echo packet mode tunnel BFD to verify LSP connectivity for an FEC.
mpls tunnel-bfd dest-addr mask-length echo [ template template-name ] [ source-ip ipv4-address ]
Configuring SBFD for LSPs
Perform this task on the initiator of an SBFD session. On the reflector of the session, specify a local discriminator by using the sbfd local-discriminator command. For more information about the sbfd local-discriminator command, see SBFD configuration in High Availability Configuration Guide.
The remote discriminator specified on the initiator must be the same as the local discriminator specified on the reflector. Otherwise, the reflector will not respond to the initiator.
This feature is supported only when the system operates in SDN-WAN mode. For more information about the system operating mode, see device management in Fundamentals Configuration Guide.
The source address of the SBFD session is the MPLS LSR ID of the local device. Before configuring SBFD for the LSP tunnel, perform the following tasks:
mpls bfd enable
3. Configure SBFD to verify LSP connectivity for an FEC.
mpls sbfd dest-addr mask-length [ nexthop nexthop-address ] remote remote-id [ template template-name ] [ source-ip ipv4-address ]
By default, SBFD is not configured to verify LSP connectivity for an FEC.
mpls bfd enable
3. Enable periodic LSP tracert for an FEC.
mpls periodic-tracert dest-addr mask-length [ -a source-ip | -exp exp-value | -h ttl-value | -m wait-time | -rtos tos-value | -t time-out | -u retry-attempt | fec-check ] *
By default, periodic LSP tracert is disabled.
To verify MPLS TE tunnel connectivity, you can use one of the following methods:
· Use ping mpls te command or the tracert mpls te command to trigger MPLS TE tunnel connectivity verification as needed.
· Configure BFD for the system to automatically verify MPLS TE tunnel connectivity.
MPLS ping for a normal MPLS TE tunnel
To use MPLS ping to verify MPLS TE tunnel connectivity, execute the following command in any view:
ping mpls [ -a source-ip | -c count | -exp exp-value | -h ttl-value | -m wait-time | -r reply-mode | -rtos tos-value | -s packet-size | -t time-out | -v | fec-check ] * te tunnel interface-number [ nil ] [ hot-standby ]
MPLS ping for an MPLS TE tunnel established by using Segment Routing
To use MPLS ping to verify SR-MPLS TE tunnel connectivity, execute the following commands in any view:
ping mpls [ -a source-ip | -c count | -exp exp-value | -h ttl-value | -m wait-time | -r reply-mode | -rtos tos-value | -s packet-size | -t time-out | -v | fec-check ] * segment-routing te tunnel interface-number [ hot-standby ] [ nil-fec ]
MPLS tracert for a normal MPLS TE tunnel
To use MPLS tracert to trace an MPLS TE tunnel, execute the following command in any view:
tracert mpls [ -a source-ip | -exp exp-value | -h ttl-value | -r reply-mode | -rtos tos-value | -t time-out | -v | ddmap | fec-check ] * te tunnel interface-number [ nil ] [ hot-standby ]
MPLS tracert for an MPLS TE tunnel established by using Segment Routing
To use MPLS tracert to trace an SR-MPLS TE tunnel, execute the following commands in any view:
tracert mpls [ -a source-ip | -exp exp-value | fec-check | -h ttl-value | -r reply-mode | -rtos tos-value | -t time-out | -v | ddmap | fec-check ] * segment-routing te tunnel interface-number [ hot-standby ] [ nil-fec ]
An MPLS TE tunnel can contain multiple LSPs. BFD can detect failures for the MPLS TE tunnel or for the primary or backup LSP of the MPLS TE tunnel. If you use BFD to detect failure of the MPLS TE tunnel, the BFD session is set to down only when all the LSPs of the tunnel failed.
mpls bfd enable
3. Create a static BFD session for connectivity verification of an MPLS TE tunnel.
bfd static session-name mpls-te interface interface-type interface-number [ te-lsp [ backup ] ] [ one-arm-echo ]
4. Configure local and remote discriminators for the static BFD session.
discriminator { local local-id | remote remote-id }
This feature enables the device to create BFD sessions to monitor MPLS TE tunnels. When an MPLS TE tunnel fails, BFD can quickly detect the failure and notify the device to take an action, such as switching traffic to the backup MPLS TE tunnel.
To run BFD on an MPLS TE tunnel, configure both the local and remote devices as described in Table 3.
Table 3 Configurations on the local and remote devices
Node type |
Static mode |
Local |
Yes |
Yes |
Yes |
Remote |
Yes |
Yes |
Yes |
Dynamic mode |
Local |
Yes |
Yes |
No |
Remote |
Yes |
No |
N/A |
Follow these guidelines to configure BFD for an MPLS TE tunnel:
· In static BFD session establishment mode, this feature creates a BFD session only for the primary CRLSP on the tunnel interface. In dynamic BFD session establishment mode, this feature creates a BFD session for the primary and backup CRLSPs respectively on the tunnel interface. If the primary and backup CRLSPs fail at the same time, the device puts the MPLS TE tunnel to down state so the tunnel does not receive traffic.
· If both BFD and FRR are enabled for an MPLS TE tunnel, set the BFD detection interval for tunnel connectivity verification to be longer than that for FRR. Otherwise, the BFD session for MPLS TE tunnel connectivity verification will be down during an FRR switchover.
mpls bfd enable
4. (Optional.) Enable the capability of MPLS BFD to trigger tunnel-down.
a. Enter MPLS TE view.
mpls te
b. Enable the capability of MPLS BFD to trigger tunnel-down.
mpls bfd trigger tunnel-down enable
By default, MPLS BFD is able to trigger tunnel-down.
If you configure static MPLS BFD in a primary/backup scenario, the device creates a BFD session for only the primary path. During a primary/backup switchover, the BFD session of the primary path might go down if a large number of MPLS TE tunnel interfaces exist, which results in traffic interruption. To resolve this issue, disable MPLS BFD from triggering tunnel-down. Then, the tunnel interface state remains unchanged when the BFD session of the MPLS TE tunnel interface goes down.
c. Return to system view.
5. Enter the view of an MPLS TE tunnel interface.
interface tunnel number
6. (Optional.) Configure the control packet mode BFD parameters for MPLS TE primary tunnel connectivity verification.
¡ Set the BFD detection time multiplier for the primary tunnel.
mpls bfd detect-multiplier value
By default, the BFD detection time multiplier is not set.
¡ Set the minimum interval for the primary tunnel to receive BFD packets.
mpls bfd min-receive-interval interval
By default, the minimum receive interval is not set.
¡ Set the minimum interval for the primary tunnel to transmit BFD packets.
mpls bfd min-transmit-interval interval
By default, the minimum transmit interval is not set.
7. (Optional.) Configure the control packet mode BFD parameters for MPLS TE backup tunnel connectivity verification.
¡ Set the BFD detection time multiplier for the backup tunnel.
mpls bfd backup detect-multiplier value
¡ Set the minimum interval for the backup tunnel to receive BFD packets.
mpls bfd backup min-receive-interval interval
¡ Set the minimum interval for the backup tunnel to transmit BFD packets.
mpls bfd backup min-transmit-interval interval
8. (Optional.) Configure the capability of MPLS BFD to trigger tunnel-down.
mpls bfd trigger tunnel-down { disable | enable }
By default, the configuration in MPLS TE view is used.
9. Configure the BFD control packet mode to verify MPLS TE tunnel connectivity.
mpls bfd discriminator local local-id remote remote-id [ template template-name ]
mpls bfd [ template template-name ] [ backup-path [ template template-name ] ] [ source-ip ipv4-address ]
By default, the BFD control packet mode is not configured to verify MPLS TE tunnel connectivity.
If you specify a template for each CRLSP, specify greater interval settings for the template of the backup CRLSP than the primary CRLSP. This rule ensures that the BFD session for the new primary CRLSP is up after a primary/backup CRLSP switchover.
mpls bfd enable
3. (Optional.) Enable the capability of MPLS BFD to trigger tunnel-down.
mpls te
4. Enter the view of an MPLS TE tunnel interface.
5. (Optional.) Configure the echo packet mode BFD parameters for MPLS TE primary tunnel connectivity verification.
6. (Optional.) Configure the echo packet mode BFD parameters for MPLS TE backup tunnel connectivity verification.
7. (Optional.) Configure the capability of MPLS BFD to trigger tunnel-down.
8. Enable the BFD echo packet mode to verify MPLS TE tunnel connectivity.
mpls bfd echo [ template template-name ] [ backup-path [ template template-name ] ] [ source-ip ipv4-address ]
mpls bfd reverse-lsp binding-sid label label-value [ template template-name ] [ backup-path [ template template-name ] ] [ source-ip ipv4-address ]
By default, the BFD echo packet mode is not configured to verify MPLS TE tunnel connectivity.
This this enables the device to create a BFD session for each PCE-initiated primary RSVP-TE or SR tunnel to detect the primary tunnel connectivity.
When a primary RSVP-TE or SR tunnel fails, BFD can quickly detect the failure and switches traffic to the backup tunnel to reduce packet loss.
mpls bfd enable
3. Enable BFD for PCE-initiated tunnels.
mpls te bfd enable pce-initiated-lsp { rsvp | segment-routing }
By default, BFD for PCE-initiated tunnels is not enabled.
4. Configure BFD session parameters for PCE-initiated tunnels.
¡ Set the BFD detection time multiplier for PCE-initiated tunnels.
mpls te bfd detect-multiplier value
By default, the BFD detection time multiplier is not set for PCE-initiated tunnels. The BFD detection time multiplier set by the bfd multi-hop detect-multiplier command applies.
¡ Set the minimum interval for PCE-initiated tunnels to receive BFD packets.
mpls te bfd min-receive-interval interval
By default, the minimum interval for receiving BFD packets is not set for PCE-initiated tunnels. The interval set by the bfd multi-hop min-receive-interval command applies.
¡ Set the minimum interval for PCE-initiated tunnels to transmit BFD packets.
mpls te bfd min-transmit-interval interval
By default, the minimum interval for transmitting BFD packets is not set for PCE-initiated tunnels. The interval set by the bfd multi-hop min-transmit-interval command applies.
For more information about the bfd multi-hop detect-multiplier, bfd multi-hop min-receive-interval, and bfd multi-hop min-transmit-interval commands, see BFD commands in High Availability Command Reference.
In an MPLS TE CRLSP backup scenario, you can use the mpls bfd command to create a BFD session for the primary and backup CRLSPs, respectively. When the primary CRLSP fails, BFD can quickly detect the failure and notify the device to switch traffic to the backup CRLSP. When both the primary and backup CRLSPs fail, the BFD detection mechanism fails. Traffic is lost until another mechanism detects the failure and triggers a traffic protection measure (such as MPLS L3VPN ECMP route based load balancing and FRR) to take effect.
To resolve this issue, you can execute the mpls tunnel-bfd command to configure tunnel BFD, which detects failures on the primary CRLSP and all the backup CRLSPs. When both the primary CRLSP and the current backup CRLSP fail, tunnel BFD can quickly detect the failures and trigger a traffic protection measure to switch traffic to an available backup CRLSP.
To run tunnel BFD on an MPLS TE tunnel, configure both the local and remote devices as described in Table 4.
Table 4 Configurations on the local and remote devices
Node type |
Static mode |
Local |
Yes |
Yes |
Yes |
Remote |
Yes |
Yes |
Yes |
Dynamic mode |
Local |
Yes |
Yes |
No |
Remote |
Yes |
No |
N/A |
Follow these guidelines to configure tunnel BFD for an MPLS TE tunnel:
· As a best practice to avoid tunnel flappings, disable MPLS BFD from triggering tunnel-down if you configure tunnel BFD for MPLS TE tunnels. To disable MPLS BFD from triggering tunnel-down, execute mpls bfd trigger tunnel-down disable in tunnel interface view or undo mpls bfd trigger tunnel-down enable in MPLS TE view.
· In scenarios where the primary CRLSP of an MPLS TE tunnel has multiple main paths and one backup path, the device establishes only one BFD session for the primary CRLSP. When this BFD session is down, the device determines that all paths for the primary CRLSP are unavailable and switches traffic to the backup CRLSP of the MPLS TE tunnel.
To enable the BFD echo packet mode, you must first configure the bfd echo-source-ip command on the local device to specify a source IP address for BFD echo packets.
Configuring control packet mode tunnel BFD for an MPLS TE tunnel
mpls bfd enable
By default, device can dynamically estalbish passive mode BFD sessions.
This command is required only on the egress node to establish a dyamic BFD session.
5. (Optional.) Configure BFD session parameters for verifying the MPLS TE tunnel connectivity.
¡ Configure tunnel BFD detection timer multiplier.
mpls tunnel-bfd detect-multiplier value
By default, the tunnel BFD detection time multiplier is not set.
¡ Configure the minimum receive interval for tunnel BFD packets.
mpls tunnel-bfd min-receive-interval interval
¡ Configure the minimum transmit interval for tunnel BFD packets.
mpls tunnel-bfd min-transmit-interval interval
6. Configure control packet mode tunnel BFD to verify MPLS TE tunnel connectivity.
mpls tunnel-bfd discriminator local local-id remote remote-id [ template template-name ]
mpls tunnel-bfd [ template template-name ] [ source-ip ipv4-address ]
By default, tunnel BFD is not configured to verify MPLS TE tunnel connectivity.
If you specify templates for both BFD and tunnel BFD, specify greater interval settings for the BFD template than the tunnel BFD template. This rule ensures that the tunnel BFD session for MPLS TE tunnel is up after a primary/backup LSP switchover.
Configuring echo packet mode tunnel BFD for an MPLS TE tunnel
mpls bfd enable
6. Configure echo packet mode tunnel BFD to verify MPLS TE tunnel connectivity.
mpls tunnel-bfd echo [ template template-name ] [ source-ip ipv4-address ]
mpls tunnel-bfd reverse-lsp binding-sid label label-value [ template template-name ] [ source-ip ipv4-address ]
This feature enables the device to create a tunnel BFD session for each PCE-initiated RSVP-TE or SR tunnel to detect the tunnel connectivity.
A tunnel BFD session detects the primary path and all its backup paths of a PCE-initiated RSVP-TE or SR tunnel. The BFD session remains in up state as long as one of the paths is available. When all the primary and backup paths fail, the BFD session is placed to down state. BFD can quickly detect the failure and trigger another protection measure (such as MPLS L3VPN FRR) to switch traffic to an available forwarding path.
mpls bfd enable
3. Enable tunnel BFD for PCE-initiated tunnels.
mpls te tunnel-bfd enable pce-initiated-lsp { rsvp | segment-routing }
By default, tunnel BFD for PCE-initiated tunnels is not enabled.
4. Configure tunnel BFD session parameters for PCE-initiated tunnels.
¡ Set the tunnel BFD detection time multiplier for PCE-initiated tunnels.
mpls te tunnel-bfd detect-multiplier value
By default, the tunnel BFD detection time multiplier is not set for PCE-initiated tunnels. The multiplier set by the bfd multi-hop detect-multiplier command applies.
¡ Set the tunnel BFD minimum receiving interval for PCE-initiated tunnels.
mpls te tunnel-bfd min-receive-interval interval
By default, the tunnel BFD minimum receiving interval is not set for PCE-initiated tunnels. The interval set by the bfd multi-hop min-receive-interval command applies.
¡ Set the tunnel BFD minimum transmitting interval for PCE-initiated tunnels.
mpls te tunnel-bfd min-transmit-interval interval
By default, the tunnel BFD minimum transmitting interval is not set for PCE-initiated tunnels. The interval set by the bfd multi-hop min-transmit-interval command applies.
When the SBFD control packet mode is used, on the reflector of the SBFD session, specify a local discriminator by using the sbfd local-discriminator command. For more information about the sbfd local-discriminator command, see SBFD configuration in High Availability Configuration Guide. The remote discriminator specified on the initiator must be the same as the local discriminator specified on the reflector. Otherwise, the reflector will not respond to the initiator.
The SBFD echo packet mode supports verifying connectivity only for bidirectional MPLS TE tunnels.
The source address of the SBFD session is the MPLS LSR ID of the local device. Before configuring SBFD for the MPLS TE tunnel, perform the following tasks:
Configuring control packet mode SBFD for an MPLS TE tunnel
mpls bfd enable
3. Enter the view of an MPLS TE tunnel interface.
4. (Optional.) Configure SBFD session parameters for verifying the MPLS TE tunnel connectivity.
¡ Configure SBFD detection timer multiplier.
By default, the SBFD detection time multiplier is not set.
¡ Configure the minimum transmit interval for SBFD packets.
5. (Optional.) Configure SBFD session parameters for verifying the backup MPLS TE tunnel connectivity.
¡ Configure SBFD detection timer multiplier for the backup tunnel.
¡ Configure the minimum transmit interval for SBFD packets for the backup tunnel.
6. Configure SBFD to verify MPLS TE tunnel connectivity.
mpls sbfd remote remote-id [ reverse-lsp binding-sid label label-value control ] [ template template-name ] [ source-ip ipv4-address ]
mpls sbfd reverse-lsp binding-sid label label-value control [ template template-name ] [ source-ip ipv4-address ]
By default, SBFD is not configured to verify MPLS TE tunnel connectivity.
Configuring echo packet mode SBFD for an MPLS TE tunnel
mpls bfd enable
¡ Configure the minimum receive interval for SBFD packets.
¡ Configure the minimum receive interval for SBFD packets for the backup tunnel.
mpls sbfd echo [ template template-name ] [ backup-path [ template template-name ] ] [ source-ip ipv4-address ]
mpls sbfd reverse-lsp binding-sid label label-value [ source-ip ipv4-address ]
About the task
In an MPLS TE network, you can use the mpls sbfd command to create an SBFD session for the primary and backup paths of the MPLS TE tunnel, respectively. When the primary path fails, BFD can quickly detect the failure and notify the device to switch traffic to the backup path. When both the primary and backup paths fail, the SBFD detection mechanism fails. Traffic is lost until another mechanism detects the failure and triggers a traffic protection measure (such as MPLS L3VPN ECMP route based load balancing and FRR) to take effect.
To resolve this issue, you can execute the mpls tunnel-sbfd command to configure tunnel SBFD, which detects failures on the primary path and all the backup paths. When both the primary path and the current backup path fail, tunnel BFD can quickly detect the failures and trigger a traffic protection measure to switch traffic to an available backup path.
Perform this task on the initiator of the SBFD session.
When the SBFD control packet mode is used, an SBFD session can be established in static mode.
· If you specify a remote discriminator in the mpls tunnel-sbfd command, the device uses the specified remote discriminator to establish a static SBFD session.
· If you do not specify a remote discriminator in the mpls tunnel-sbfd command, the device uses the tunnel's remote IP address as the remote discriminator to establish a static SBFD session.
· The remote discriminator specified by the mpls tunnel-sbfd command on the initiator must be the same as the local discriminator specified by the sbfd local-discriminator command on the reflector. Otherwise, the reflector will not respond to the initiator.
As a best practice to avoid tunnel flappings, disable MPLS BFD from triggering tunnel-down if you configure tunnel SBFD for MPLS TE tunnels. To disable MPLS BFD from triggering tunnel-down, execute mpls bfd trigger tunnel-down disable in tunnel interface view or undo mpls bfd trigger tunnel-down enable in MPLS TE view.
The source address of the SBFD session is the MPLS LSR ID of the local device. Before configuring tunnel SBFD for an MPLS TE tunnel, perform the following tasks:
Configuring control packet mode tunnel SBFD for an MPLS TE tunnel
mpls bfd enable
¡ Configure tunnel SBFD detection timer multiplier.
¡ Configure the minimum transmit interval for tunnel SBFD packets.
5. Configure tunnel SBFD to verify MPLS TE tunnel connectivity.
mpls tunnel-sbfd remote remote-id [ reverse-lsp binding-sid label label-value control ] [ template template-name ] [ source-ip ipv4-address ]
mpls tunnel-sbfd reverse-lsp binding-sid label label-value control [ template template-name ] [ source-ip ipv4-address ]
By default, tunnel SBFD is not configured to verify MPLS TE tunnel connectivity.
Configuring echo packet mode tunnel SBFD for an MPLS TE tunnel
mpls bfd enable
¡ Configure the minimum receive interval for tunnel SBFD packets.
mpls tunnel-sbfd echo [ template template-name ] [ source-ip ipv4-address ]
mpls tunnel-sbfd reverse-lsp binding-sid label label-value [ template template-name ] [ source-ip ipv4-address ]
Verifying PW connectivity
Virtual Circuit Connectivity Verification (VCCV) is an L2VPN PW OAM feature to verify PW connectivity in data plane. VCCV can be implemented in the following modes:
· Ping mode—Execute the ping mpls pw command to trigger PW connectivity verification.
· Tracert mode—Execute the tracert mpls pw command to trigger PW connectivity verification.
· Proactive mode—Configure BFD for a PW to test PW connectivity.
The packets used to verify PW connectivity are collectively referred to as VCCV packets. A PE transfers VCCV packets through a control channel (CC).
CCs include the following types:
· Control word—Identifies VCCV packets through the control word (PW-ACH, PW Associated Channel Header). You can use this CC type only when the PW supports control word. For more information about control word, see "Configuring MPLS L2VPN."
· MPLS router alert label—Identifies a VCCV packet by adding an MPLS router alert label before the PW label.
Connectivity Verification (CV) tools include the following types:
· MPLS ping—Uses MPLS ping to verify PW connectivity.
· BFD—Uses BFD to verify PW connectivity. BFD packets use IP/UDP encapsulation (with IP/UDP headers).
In a VPLS network where the primary and backup PWs use ping, tracert, or BFD to verify PW connectivity, you must enable dual receive for PW redundancy if the VCCV CC type is control word. For more information about the dual receive feature, see "Configuring VPLS."
Performing MPLS ping for a PW
Before you configure MPLS ping for a PW, perform the following tasks:
1. Create a PW class, and use the vccv cc command to configure the VCCV CC type in PW class view.
2. Create the PW, and use the PW class created in the previous step for the PW.
To use MPLS ping to verify the connectivity of a PW, execute the following command in any view:
ping mpls [ -a source-ip | -c count | -exp exp-value | -h ttl-value | -m wait-time | -r reply-mode | -rtos tos-value | -s packet-size | -t time-out | -v ] * pw { { peer peer-address pw-id pw-id | vsi vsi-name peer peer-address } [ remote remote-ip-address remote-pw-id ] | vsi vsi-name local-site-id remote-site-id [ control-word ] | vsi vsi-name mac mac-address }
Before you configure MPLS tracert for a PW, perform the following tasks:
To use MPLS tracert to verify the connectivity of a PW, execute the following command in any view:
tracert mpls [ -a source-ip | -exp exp-value | -h ttl-value | -r reply-mode | -rtos tos-value | -t time-out | -v ] * pw { { peer peer-address pw-id pw-id | vsi vsi-name peer peer-address } [ remote remote-ip-address remote-pw-id ] | vsi vsi-name local-site-id remote-site-id [ control-word ] | vsi vsi-name mac mac-address } [ ddmap | full-lsp-path ] *
Configuring BFD for a PW
How BFD verifies PW connectivity depends on the configurations on both PEs:
· If both PEs of the PW have configured BFD and use the same BFD packet encapsulation type, the PEs use the specified encapsulation type to verify PW connectivity. Otherwise, the PEs do not use BFD to verify PW connectivity.
· If both PEs have specified the same VCCV CC type, the specified VCCV CC type is used. Otherwise, the PEs do not use any CC and they cannot establish a BFD session for the PW.
Restrictions and guidelines for configuring BFD for a PW
If BFD sessions are processed by hardware, follow these restrictions and guidelines:
· In standard system operating mode, the device does not support this feature.
· In SDN-WAN system operating mode, only the following cards support this feature:
Card category |
Cards |
CEPC |
CEPC-XP4LX, CEPC-XP24LX, CEPC-XP48RX, CEPC-CP4RX, CEPC-CP4RX-L, CEPC-CQ8L, CEPC-CQ16L1, CEPC-DQ2L1-G |
CSPEX |
CSPEX-1304X, CSPEX-1304S, CSPEX-1404X, CSPEX-1404S, CSPEX-1502X, CSPEX-1504X, CSPEX-1504S, CSPEX-1602X, CSPEX-1804X, CSPEX-1512X, CSPEX-1612X, CSPEX-1812X, NPS400 cards-CSPEX |
SPE |
RX-SPE200, NPS400 cards-SPE |
Creating a PW class
2. Create a PW class and enter PW class view.
pw-class class-name
3. Use BFD to verify PW connectivity.
vccv bfd [ template template-name ]
By default, BFD is not used to verify PW connectivity.
4. Specify the VCCV CC type.
vccv cc { control-word | router-alert }
By default, no VCCV CC type is specified.
You must specify the control-word keyword to use a static BFD session for PW connectivity verification.
Configuring static BFD for a PW
mpls bfd enable
3. Configure a PW, specify a PW class, and enter PW view. Choose one option as needed:
¡ Execute the following commands in sequence to enter cross-connect PW view:
xconnect-group group-name
connection connection-name
peer ip-address pw-id pw-id [ in-label label-value out-label label-value ] pw-class class-name [ tunnel-policy tunnel-policy-name ]
¡ Execute the following commands in sequence to enter VSI static PW view:
vsi vsi-name [ hub-spoke ]
pwsignaling static
peer ip-address pw-id pw-id in-label label-value out-label label-value pw-class class-name [ hub | no-split-horizon | tunnel-policy tunnel-policy-name ] *
¡ Execute the following commands in sequence to enter VSI LDP PW view:
pwsignaling ldp
peer ip-address pw-id pw-id pw-class class-name [ hub | no-split-horizon | tunnel-policy tunnel-policy-name ] *
4. Execute the following commands to return to system view:
5. Create a static BFD session for PW connectivity verification, and enter static BFD session view.
bfd static session-name pw interface interface-type interface-number [ remote-peer remote-ip-address ] [ backup ]
6. Configure local and remote discriminators for the static BFD session.
Configuring BFD for a static PW or an LDP PW of MPLS L2VPN
mpls bfd enable
3. Enter cross-connect group view.
4. Enter cross-connect view.
5. Configure a PW, specify the created PW class for it, and enter PW view.
By default, no PW is configured.
6. (Optional.) Set the local and remote discriminators for the BFD session used to verify PW connectivity.
By default, no local and remote discriminators are set.
Make sure the local and remote PEs use the same local and remote discriminators.
7. (Optional.) Configure a backup PW for BFD detection:
a. Configure a backup PW, specify the PW class for the backup PW, and enter backup PW view.
backup-peer ip-address pw-id pw-id [ in-label label-value out-label label-value ] pw-class class-name [ tunnel-policy tunnel-policy-name ]
By default, no backup PW is configured.
b. (Optional.) Set the local and remote discriminators for the BFD session used to verify the connectivity of the backup PW.
By default, no local and remote discriminators are configured.
Configuring BFD for a VPLS static PW
mpls bfd enable
3. Enter VSI view.
4. Configure the VSI to establish static PWs, and enter VSI static view.
pwsignaling static
By default, no PW signaling protocol is specified for a VSI.
5. Configure a VPLS PW, specify the created PW class for it, and enter VSI static PW view.
By default, no VPLS PW is configured.
7. (Optional.) Configure a static backup PW for BFD detection:
a. Configure a static backup PW, specify the PW class for the backup PW, and enter VSI static backup PW view.
backup-peer ip-address pw-id pw-id in-label label-value out-label label-value pw-class class-name [ tunnel-policy tunnel-policy-name ]
By default, no backup VPLS PW is configured.
b. Set the local and remote discriminators for the BFD session used to verify the connectivity of the backup PW.
Configuring BFD for a VPLS LDP PW
mpls bfd enable
3. Enter VSI view.
4. Configure the VSI to establish PWs using LDP and enter VSI LDP view.
pwsignaling ldp
5. Configure a VPLS PW, specify the created PW class for it, and enter VSI LDP PW view.
7. (Optional.) Configure an LDP backup PW for BFD detection:
a. Configure an LDP backup PW, specify the PW class for the backup PW, and enter VSI LDP backup PW view.
backup-peer ip-address pw-id pw-id pw-class class-name [ tunnel-policy tunnel-policy-name ]
MPLS ping for Flex-Algo LSPs for an IPv4 prefix
To use MPLS ping to verify the connectivity of Flex-Algo LSPs for an IPv4 prefix, execute the following command in any view:
MPLS ping for Flex-Algo LSPs of the specified outgoing labels
To verify Flex-Algo LSP connectivity by specifying the outgoing labels, execute the following command in any view:
ping mpls [ -a source-ip | -c count | -exp exp-value | -h ttl-value | -m wait-time | -r reply-mode | -rtos tos-value | -s packet-size | -t time-out | -v ] * out-labels out-label-value&<1-n> interface interface-type interface-number [ nexthop nexthop-address ]
Tracing the path of the Flex-Algo LSPs for an IPv4 prefix
To trace the path that the Flex-Algo LSPs for an IPv4 prefix take from the ingress node to the egress node, execute the following command in any view:
Tracing the path of the Flex-Algo LSPs of the specified outgoing labels
To trace the path that the Flex-Algo LSPs of the specified outgoing labels take from the ingress node to the egress node, execute the following command in any view:
tracert mpls [ -a source-ip | -exp exp-value | -h ttl-value | -r reply-mode | -rtos tos-value | -t time-out | -v | fec-check ]* out-labels out-label-value&<1-n> interface interface-type interface-number [ nexthop nexthop-address ]
mpls bfd enable
3. Configure SBFD to verify Flex-Algo LSP connectivity.
mpls sbfd flex-algo-lsp dest-address mask-length algorithm flex-algo-id-begin [ to flex-algo-id-end ] [ template template-name ]
By default, SBFD is not configured to verify Flex-Algo LSP connectivity.
To verify SR-MPLS TE policy tunnel connectivity, you can use one of the following methods:
· Use the ping mpls sr-policy command or the tracert mpls sr-policy command to trigger connectivity verification for the SR-MPLS TE policy tunnel as needed.
· Configure SBFD for SR-MPLS TE policy to automatically verify the tunnel connectivity. For more information about SBFD for SR-MPLS TE policy, see SR-MPLS TE policy in Segment Routing Configuration Guide.
To use MPLS ping to verify SR-MPLS TE policy tunnel connectivity, execute the following command in any view:
ping mpls [ -a source-ip | -c count | -exp exp-value | -h ttl-value | -m wait-time | -r reply-mode | -rtos tos-value | -s packet-size | -t time-out | -v ] * sr-policy { policy-name sr-policy-name | end-point ipv4 ip-address color color-value | binding-sid bsid }
If the SR TE policy contains multiple SID lists, the command verifies the connectivity to all SID lists.
To use MPLS tracert to trace an ST-TE policy tunnel, execute the following command in any view:
tracert mpls [ -a source-ip | -exp exp-value | -h ttl-value | -r reply-mode | -rtos tos-value | -t time-out | -v ] * sr-policy { policy-name sr-policy-name | end-point ipv4 ip-address color color-value | binding-sid bsid }
The remote discriminator specified on the initiator must be the same as the local discriminator specified on the reflector. Otherwise, the reflector will not respond to the initiator. By default, the initiator uses the endpoint address as the remote discriminator of the SBFD session.
You can configure SBFD for SR-MPLS TE policy tunnels in SR TE view or in SR-MPLS TE policy view. The configuration in SR TE view applies to all SR-MPLS TE policies. The configuration in SR-MPLS TE policy view applies only to this current SR-MPLS TE policy. An SR-MPLS TE policy prefers the SBFD configuration in its own view over that in SR-TE view.
The source address of the SBFD session is the MPLS LSR ID of the local device. Before configuring SBFD for SR-MPLS TE policy tunnels, perform the following tasks:
2. Enter Segment Routing view.
segment-routing
3. Enter SR TE view.
traffic-engineering
4. Enable SBFD for all SR-MPLS TE policies.
sr-policy sbfd enable
By default, SBFD for SR-MPLS TE policies is disabled in SR TE view.
5. Enter SR-MPLS TE policy view.
policy policy-name
6. Configure SBFD for the SR-MPLS TE policy.
sbfd { disable | enable }
By default, the SBFD configuration in SR TE view is used.
7. (Optional.) Configure SBFD parameters.
sr-policy sbfd timer { detect-multiplier multiplier-value | min-transmit-interval transmit-interval } *
By default, no SBFD detection parameters are configured.
Task |
Command |
Display BFD information for PWs. |
display l2vpn pw bfd [ peer peer-ip { pw-id pw-id | remote-service-id remote-service-id } ] |
Display BFD information for LSP tunnels or MPLS TE tunnels. |
display mpls bfd [ ipv4 ipv4-address mask-length | te tunnel tunnel-number ] |
Display SBFD information for LSP tunnels, MPLS TE tunnels, Flex-Algo LSP tunnels, or SR-MPLS TE policy tunnels. |
display mpls sbfd [ ipv4 ipv4-address mask-length | flex-algo-lsp [ ipv4 ipv4-address mask-length [ algorithm flex-algo-id-begin [ to flex-algo-id-end ] ] ] | sr-policy [ name sr-policy-name | end-point ipv4 ip-address color color-value ] | te tunnel tunnel-number ] |
Use LDP to establish an LSP from 1.1.1.9/32 to 3.3.3.9/32 and an LSP from 3.3.3.9/32 to 1.1.1.9/32. Use BFD to verify LSP connectivity.
1. Configure IP addresses for interfaces. (Details not shown.)
2. Configure OSPF to ensure IP connectivity between the routers:
# Configure Router A.
[RouterA] ospf
[RouterA-ospf-1] area 0
[RouterA-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[RouterA-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[RouterA-ospf-1] quit
# Configure Router B.
<RouterB> system-view
[RouterB] ospf
[RouterB-ospf-1] area 0
[RouterB-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[RouterB-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[RouterB-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[RouterB-ospf-1] quit
# Configure Router C.
<RouterC> system-view
[RouterC] ospf
[RouterC-ospf-1] area 0
[RouterC-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[RouterC-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[RouterC-ospf-1] quit
3. Enable MPLS and LDP:
[RouterA] mpls lsr-id 1.1.1.9
[RouterA] mpls ldp
[RouterA-ldp] quit
[RouterA] interface ten-gigabitethernet 3/1/1
[RouterA-Ten-GigabitEthernet3/1/1] mpls enable
[RouterA-Ten-GigabitEthernet3/1/1] mpls ldp enable
[RouterA-Ten-GigabitEthernet3/1/1] quit
[RouterB] mpls lsr-id 2.2.2.9
[RouterB] mpls ldp
[RouterB-ldp] quit
[RouterB] interface ten-gigabitethernet 3/1/1
[RouterB-Ten-GigabitEthernet3/1/1] mpls enable
[RouterB-Ten-GigabitEthernet3/1/1] mpls ldp enable
[RouterB-Ten-GigabitEthernet3/1/1] quit
[RouterB] interface ten-gigabitethernet 3/1/2
[RouterB-Ten-GigabitEthernet3/1/2] mpls enable
[RouterB-Ten-GigabitEthernet3/1/2] mpls ldp enable
[RouterB-Ten-GigabitEthernet3/1/2] quit
[RouterC] mpls lsr-id 3.3.3.9
[RouterC] mpls ldp
[RouterC-ldp] quit
[RouterC] interface ten-gigabitethernet 3/1/2
[RouterC-Ten-GigabitEthernet3/1/2] mpls enable
[RouterC-Ten-GigabitEthernet3/1/2] mpls ldp enable
[RouterC-Ten-GigabitEthernet3/1/2] quit
4. Enable BFD for MPLS, and configure BFD to verify LSP connectivity:
[RouterA] mpls bfd enable
[RouterA] mpls bfd 3.3.3.9 32
[RouterC] mpls bfd enable
[RouterC] mpls bfd 1.1.1.9 32
# Display BFD information for LSPs on Router A and Router C, for example, on Router A.
[RouterA] display mpls bfd
Total number of sessions: 2, 2 up, 0 down, 0 init
FEC Type: LSP
FEC Info:
Destination: 1.1.1.9
Mask Length: 32
NHLFE ID: -
Local Discr: 513 Remote Discr: 513
Source IP: 1.1.1.9 Destination IP: 3.3.3.9
Session State: Up Session Role: Active
Template Name: -
FEC Type: LSP
FEC Info:
Destination: 3.3.3.9
Mask Length: 32
NHLFE ID: 1042
Local Discr: 514 Remote Discr: 514
Source IP: 1.1.1.9 Destination IP: 127.0.0.1
Session State: Up Session Role: Passive
Template Name: -
The output shows that two BFD sessions have been established between Router A and Router C. One session verifies the connectivity of the LSP from 3.3.3.9/32 to 1.1.1.9/32, and the other session verifies the connectivity of the LSP from 1.1.1.9/32 to 3.3.3.9/32.
