- 20-Network Management and Monitoring Command Reference
- 02-NQA commands
- 03-SNMP commands
- 04-RMON commands
- 05-NETCONF commands
- 06-EAA commands
- 07-Process monitoring and maintenance commands
- 08-Flow log commands
- 09-Fast log output commands
- 10-Packet capture commands
- 11-Mirroring commands
- 12-UCC commands
- 13-SQA commands
- 14-SmartMC commands
| 13-SQA commands | 109.51 KB |
SQA commands
The following compatibility matrixes show the support of hardware platforms for SQA:
Hardware series |
Model |
Product code |
SQA compatibility |
WX2500X series |
WX2560X WX2580X |
EWP-WX2560X EWP-WX2580X |
Yes |
WX2500X-E series |
WX2508X-E |
EWP-WX2508X-E |
Yes |
Hardware series |
Model |
Product code |
SQA compatibility |
WX2500X-LI |
WX2510X-LI WX2510X-PWR-LI WX2520X-LI WX2540X-LI WX2550X-LI WX2560X-LI WX2580X-LI |
EWP-WX2510X-LI EWP-WX2510X-PWR-LI EWP-WX2520X-LI EWP-WX2540X-LI EWP-WX2550X-LI EWP-WX2560X-LI EWP-WX2580X-LI |
Yes: · EWP-WX2520X-LI · EWP-WX2540X-LI · EWP-WX2550X-LI · EWP-WX2560X-LI · EWP-WX2580X-LI No: · EWP-WX2510X-LI · EWP-WX2510X-PWR-LI |
Hardware series |
Model |
Product code |
SQA compatibility |
WX2800X series |
WX2812X-PWR WX2860X WX2880X |
EWP-WX2812X-PWR EWP-WX2860X EWP-WX2880X |
Yes |
WSG1800X series |
WSG1808X-PWR WSG1808X-PWR WSG1812X-PWR WSG1840X |
EWP-WSG1808X-PWR EWP-WSG1808X-PWR-JP EWP-WSG1812X-PWR EWP-WSG1840X |
Yes |
application enable
Use application enable to enable SQA for an audio or video application.
Use undo application enable to disable SQA for an audio or video application.
application app-name enable
undo application app-name enable
SQA is disabled for all audio and video applications.
SQA profile view
app-name: Specifies an audio or video application. You can use the application ? command to obtain the list of supported audio or video applications.
After SQA is enabled, the service template bound to the SQA profile will analyze the audio and video traffic of wireless endpoints. The service template also collects and saves basic information (such as source and destination IP addresses) and quality information (such as delay and jitter) about the audio and video streams. The device can report the analysis data to a control terminal through NETCONF.
To enable SQA for multiple audio or video applications, you can execute this command multiple times.
# In SQA profile ssidcompany, enable SQA for the Tencent Meeting application.
[Sysname] sqa profile ssidcompany
[Sysname-sqa-profile-ssidcompany] application tencentmeeting enable
sqa profile
application interval
Use application interval to specify the interval at which analysis data for audio and video applications is collected and sent.
Use undo application interval to restore the default.
application interval interval
Analysis data for audio and video applications is collected and sent at 300-second intervals.
SQA profile view
interval: Specifies the interval at which analysis data for audio and video applications is collected and sent, in the range of 10 to 3600 seconds.
After SQA is enabled, APs will collect and send analysis data to the control terminal that subscribes to the data at the specified.
# In SQA profile ssidcompany, specify the interval for collecting and sending analysis data as 200 seconds.
[Sysname-sqa-profile-ssidcompany] application interval 200
application enable
sqa profile
application name enable
Use application name enable to enable SQA for an application.
Use undo application name enable to disable SQA for an application.
application name app-name enable
undo application name app-name enable
SQA is disabled for an application.
SQA profile view
app-name: Specifies an application. APR signature libraries of different versions support different applications. You can use the application name ? command to obtain the list of applications supported by an APR signature library.
Application scenarios
You can execute the application name app-name enable command multiple times to enable SQA for multiple applications.
This feature is supported only in wireless local forwarding scenarios.
application statistics enable
Use application statistics enable to enable statistics collection for endpoint application traffic.
Use undo application statistics enable to disable statistics collection for endpoint application traffic.
Statistics collection for endpoint application traffic is disabled.
SQA profile view
After this command is executed, the service template bound to the SQA profile will collect traffic statistics on identifiable applications for wireless endpoints. The device can report the statistics to a control terminal through NETCONF. For information about NETCONF, see Network Management and Monitoring Configuration Guide.
# In SQA profile ssidcompany, enable statistics collection for endpoint application traffic.
[Sysname-sqa-profile-ssidcompany] application statistics enable
sqa profile
application statistics interval
Use application statistics interval to specify the interval at which traffic statistics are collected and sent.
Use undo application statistics interval to restore the default.
application statistics interval interval
Traffic statistics for endpoint applications is collected and sent at 5-minute intervals.
SQA profile view
interval: Specifies the interval at which analysis data for traffic statistics for endpoint applications are collected and sent, in the range of 1 to 60 minutes.
After traffic statistics for endpoint applications is enabled, APs will collect and send traffic statistics to the control terminal that subscribes to the data at the specified.
# In SQA profile ssidcompany, specify the interval for collecting and sending traffic statistics as 4 minutes.
[Sysname-sqa-profile-ssidcompany] application statistics interval 4
sqa profile
display sqa profile
Use display sqa profile to display configuration information for SQA profiles.
display sqa profile [ profile-name ]
profile-name: Specifies an SQA profile by its name, a case-insensitive string of 1 to 31 characters. If you do not specify an SQA profile, this command displays configuration information for all SQA profiles.
# Display configuration information for all SQA profiles.
<Sysname> display sqa profile
SQA profile information:
SQA profile name: ssidcompany1
SIP: Enabled
SQA-enabled video&audio apps: tencentmeeting, qq
Application statistics: Enabled
Application SQA interval: 300s
Application statistics interval: 5min
SQA-enabled applications: AirPlay, CiscoWebex, CiscoWebexMeetings, CloudRoom, DingT,
alk, DingTalkVoIP, FeiShu, HaoShiTong, HUAWEICloudWeLink,
TencentMeeting, XiaoYuYiLian, ZhuMuMeeting, Zoom
SQA profile name: ssidcompany2
SIP: Enabled
Total SQA profiles: 2
SQA profile name |
SQA profile name. |
SIP |
Status of SIP-based SQA for the SQA profile: · Enabled. · Disabled. |
application enable
sqa profile
Use sqa profile to create an SQA profile and enter its view, or enter the view of an existing SQA profile.
Use undo sqa profile to delete an SQA profile.
sqa profile profile-name
undo sqa profile profile-name
No SQA profiles exist.
profile-name: Specifies the name of an SQA profile, a case-insensitive string of 1 to 31 characters. The SQA profile name can contain digits, letters, hyphens (-), underscores (_), left brackets ([), right brackets (]), and slashes (/).
# Create SQA profile ssidcompany and enter its view.
display sqa profile
sqa-profile
sqa-profile
Use sqa-profile to bind an SQA profile to a service template.
Use undo sqa-profile to unbind an SQA profile from a service template.
sqa-profile profile-name
undo sqa-profile
No SQA profile is bound to a service template.
Service template view
Use this command to enable a service template to optimize and analyze audio and video traffic for wireless clients associated with the service template.
You can bind only one SQA profile to a service template. To bind a different SQA template to the service template, first unbind the existing SQA profile from the service template.
# Bind SQA profile ssidcompany to service template service.
[Sysname-sqa-profile-ssidcompany] quit
[Sysname] wlan service-template service
[Sysname-wlan-st-service] sqa-profile ssidcompany
sqa profile
