- 20-Network Management and Monitoring Command Reference
- 02-NQA commands
- 03-SNMP commands
- 04-RMON commands
- 05-NETCONF commands
- 06-EAA commands
- 07-Process monitoring and maintenance commands
- 08-Flow log commands
- 09-Fast log output commands
- 10-Packet capture commands
- 11-Mirroring commands
- 12-UCC commands
- 13-SQA commands
- 14-SmartMC commands
| 10-Packet capture commands | 81.34 KB |
display packet-capture status
Use display packet-capture status to display local or remote packet capture status information.
# Display local or remote packet capture status information.
<Sysname> display packet-capture status
AP name : ap1
Radio ID : 1
Radio mode : 802.11n(2.4GHz)
Channel : 1
Status : Capturing
File name : database.pcap
Username : 1
Password : ******
Status |
Packet capture status. Only the Capturing status is supported in the current software version. |
Username |
Username for logging in to the remote FTP server. |
Password |
Password for logging in to the remote FTP server. Both passwords in encrypted form and in plaintext form are displayed as ******. If no password is required or configured, this filed displays N/A. |
packet-capture local ap
Use packet-capture local ap to capture incoming packets on an AP radio and save the captured packets to a file on an FTP server.
packet-capture local ap ap-name radio radio-id [ capture-filter capt-expression | limit-frame-size bytes | autostop filesize kilobytes | autostop duration seconds ] * write url url [ username username [ password { cipher | simple } string ] ]
ap-name: Specifies an AP by its name, a case-insensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
radio radio-id: Specifies a radio by its ID.
capture-filter capt-expression: Specifies an expression to match packets to be captured, a case-sensitive string of 1 to 256 characters. If you do not specify a capture filter expression, the device captures all incoming packets on an interface.
limit-frame-size bytes: Sets the maximum number of bytes to capture for a packet. The value range is 64 to 8000 bytes, and the default value is 8000 bytes. If the frame length of a packet exceeds the frame size limit but is less than or equal to 9196 bytes, the system captures only the specified number of bytes from the packet, starting from the first byte. If the frame length exceeds 9196 bytes, the system does not capture the packet.
autostop filesize kilobytes: Stops capturing packets if the maximum packet file size is exceeded when file rotation is disabled. The kilobytes argument sets the maximum packet file size. The value range is 1 to 65536 kilobytes. If you do not set a limit, the packet file size is unlimited.
autostop duration seconds: Stops capturing packets when the capturing duration expires. The seconds argument sets the capturing duration. The value range is 1 to 2147483647 seconds. If you do not set a limit, the capturing duration is unlimited.
write url url: Specifies the URL of the packet file on an FTP server to store captured packet data. The URL must be a case-sensitive string of 1 to 255 characters. The URL string must not contain at signs (@), and the specified username and password. If you do not specify a URL, the captured packet data is not saved.
username username: Specifies a username for logging in to the FTP server. The username is a case-sensitive string of 1 to 32 characters.
password: Specifies a password for logging in to the FTP server.
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 32 characters. Its encrypted form is a case-sensitive string of 1 to 73 characters.
To stop the capture while it is capturing packets, use the packet-capture stop command.
If you configure both the autostop filesize option and autostop duration option, the packet capture stops when any one of the limits for the stop options is reached.
Follow these restrictions and guidelines to specify the URL, username, and password:
· The URL format is ftp://FTP server address:port number/file name, where the port number is optional, for example, ftp://192.168.1.1/test.cfg and ftp://192.168.1.1:21/test.cfg. If the server is configured with a port number, you must enter the port number in the URL.
· If the server address is an IPv6 address, enclose the address in a pair of brackets, for example, ftp://[2001::1]/test.cfg and ftp://[2001::1]:21/test.cfg.
· You can also specify the DNS domain name for the server address field, for example, ftp://sdp:21/test.cfg.
· The username and password must be the same as those configured on the FTP server. If the server authenticates only the username, the password can be omitted.
Do not set a short capturing duration in the autostop duration seconds option. If the duration is too short, the capture might stop when a user has not logged in to the FTP server. The captured packets cannot be saved because a packet file has not been created.
# Capture incoming packets on radio 1 of AP 1.
<Sysname> packet-capture local ap ap1 radio 1 write url ftp://10.1.1.1/database.pcap username 1 password simple 1
packet-capture stop
packet-capture local interface
Use packet-capture local interface to capture incoming packets on an interface and save the captured packets to a local file or to a remote file on an FTP server.
packet-capture local interface interface-type interface-number [ capture-filter capt-expression | limit-frame-size bytes | autostop filesize kilobytes | autostop duration seconds ] * write { filepath | url url [ username username [ password { cipher | simple } string ] ] }
interface-type interface-number: Specifies an Ethernet interface by its type and number.
write: Stores the captured packet data.
filepath: Specifies the full path of a local packet file to store captured packet data. The path must be a case-sensitive string of up to 64 characters. The filename extension must be .pcap. For more information about setting a file path, see file system management in Fundamentals Configuration Guide.
url url: Specifies the URL of a remote packet file on an FTP server to store captured packet data. The URL must be a case-sensitive string of 1 to 255 characters. The URL string must not contain at signs (@), and the specified username and password. If you do not specify a URL, the captured packet data is not saved.
# Capture incoming packets and store the data in the database.pcap file on the FTP server at 10.1.1.1. The username and password for logging in to the FTP server are 1 and 1, respectively.
<Sysname> packet-capture local interface gigabitethernet 1/0/1 write url ftp://10.1.1.1/database.pcap username 1 password simple 1
packet-capture stop
packet-capture remote ap
Use packet-capture remote ap to capture incoming packets on an AP radio.
packet-capture remote ap ap-name radio radio-id [ port port ]
port port: Specifies the RPCAP service port by its port number. The value range is 1 to 65535, and the default value is 2002.
After you execute this command, the client (such as Wireshark) connected to the RPCAP service port of the AP can obtain packets captured on the AP radio.
# Capture incoming packets on radio 2 of AP 1 and specify the RPCAP service port number as 2014.
<Sysname> packet-capture remote ap ap1 radio 2 port 2014
packet-capture stop
packet-capture remote interface
Use packet-capture remote interface to capture incoming packets on an interface.
packet-capture remote interface interface-type interface-number [ port port ]
After you execute this command, the client connected to the RPCAP service port of the device can obtain packets captured on the specified interface.
# Capture incoming packets on GigabitEthernet 1/0/1 and specify the RPCAP service port number as 2014.
<Sysname> packet-capture remote interface gigabitethernet 1/0/1 port 2014
packet-capture stop
packet-capture stop
Use packet-capture stop to stop the local or remote packet capture.
packet-capture stop
When a local AC on a hierarchical network goes offline, the central AC stops the packet capture management processes for the APs connected to the local AC. However, packet capture continues on the APs. To stop the packet capture, you must enable packet capture on the central AC for the APs again and execute the packet-capture stop command.
# Stop the local or remote packet capture.
<Sysname> packet-capture stop
