16-Security Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WX2800X&WSG1800X Command References(R5605P11)-6W10016-Security Command Reference
12-Connection limit commands
12-Connection limit commands 160.46 KB
connection-limit
Use connection-limit to create a connection limit policy and enter its view, or enter the view of an existing connection limit policy.
Use undo connection-limit to delete a connection limit policy.
connection-limit { ipv6-policy | policy } policy-id
undo connection-limit { ipv6-policy | policy } policy-id
No connection limit policies exist.
ipv6-policy: Specifies an IPv6 connection limit policy.
policy: Specifies an IPv4 connection limit policy.
policy-id: Specifies the ID of a connection limit policy, in the range of 1 to 32.  An IPv4 or IPv6 connection limit policy has its own number.
# Create IPv4 connection limit policy 1 and enter its view.
[Sysname] connection-limit policy 1
[Sysname-connlmt-policy-1]
# Create IPv6 connection limit policy 12 and enter its view.
[Sysname] connection-limit ipv6-policy 12
[Sysname-connlmt-ipv6-policy-12]
connection-limit apply
connection-limit apply global
display connection-limit
limit
Use connection-limit apply to apply a connection limit policy to an interface.
Use undo connection-limit apply to remove a connection limit policy from an interface.
connection-limit apply { ipv6-policy | policy } policy-id
undo connection-limit apply { ipv6-policy | policy }
No connection limit policy is applied to an interface.
Interface view
Only one IPv4 connection limit policy and one IPv6 connection limit policy can be applied to an interface. A new IPv4 or IPv6 connection limit policy overwrites the old one.
# Apply IPv4 connection limit policy 1 to VLAN-interface 2. ‌
[Sysname-Vlan-interface2] connection-limit apply policy 1
# Apply IPv6 connection limit policy 12 to VLAN-interface 2. ‌
[Sysname-Vlan-interface2] connection-limit apply ipv6-policy 12
connection-limit
limit
Use connection-limit apply global to apply a connection limit policy globally.
Use undo connection-limit apply global to remove the application.
connection-limit apply global { ipv6-policy | policy } policy-id
undo connection-limit apply global { ipv6-policy | policy }
No connection limit policy is applied globally.
Only one IPv4 connection limit policy and one IPv6 connection limit policy can be applied globally. A new IPv4 or IPv6 connection limit policy overwrites the old one.
# Apply IPv4 connection limit policy 1 globally.
[Sysname] connection-limit apply global policy 1
# Apply IPv6 connection limit policy 12 globally.
[Sysname] connection-limit apply global ipv6-policy 12
connection-limit
limit
description
Use description to configure a description for a connection limit policy.
A connection limit policy does not have a description.
IPv4 connection limit policy view
IPv6 connection limit policy view
text: Specifies a description, a case-sensitive string of 1 to 127 characters.
# Configure the description as CenterToA for IPv4 connection limit policy 1.
[Sysname-connlmt-policy-1] description CenterToA
Use display connection-limit to display information about connection limit policies.
display connection-limit { ipv6-policy | policy } { policy-id | all }
all: Specifies all connection limit policies.
# Display information about all IPv4 connection limit policies.
<Sysname> display connection-limit policy all
3 policies in total:
 Policy  Rule     Stat Type  HiThres  LoThres  Rate     PermitNew   ACL
      1     2      Dst-Port      800       70     0           Yes   3010
            3       Src-Dst      100       90     0            No   3000
           10  Src-Dst-Port       50       45     0            No   3003
           11           Src      200      200     0            No   3004
          200           --    500000   498000     0            No   2002
     28     4          Port     1500     1400     0            No   3100
            5           Dst     3000      280     0            No   3101
           21       Src-Dst      200      180     0            No   3102
           25      Src-Port       50       35     0            No   3200
Description list:
 Policy      Description
      1       IPv4Description1
     28      Description for IPv4 28
# Display information about IPv4 connection limit policy 1.
<Sysname> display connection-limit policy 1
IPv4 connection limit policy 1 has been applied 5 times, and has 5 limit rules.
Description: IPv4Description1
Limit rule list:
 Application list:
     GigabitEthernet1/0/1
     GigabitEthernet1/0/2
     Vlan-interface2
     Global
# Display information about all IPv6 connection limit policies.
<Sysname> display connection-limit ipv6-policy all
2 policies in total:
      3     1       Src-Dst     1000      800    10           Yes   3010
            2           Dst      500      450     0           Yes   3001
      4     2  Src-Dst-Port      800      700     0           No    3010
            3           Src      100       90     0           No    3020
          200            --   100000    89000     0           No    2005
Description list:
 Policy      Description
      3      IPv6Description3
      4      Description for IPv6 4
# Display information about IPv6 connection limit policy 3.
<Sysname> display connection-limit ipv6-policy 3
IPv6 connection limit policy 3 has been applied 3 times, and has 2 limit rules.
Description: IPv6Description3
Limit rule list:
     3     1       Src-Dst     1000      800     0           Yes   3010
           2           Dst      500      450     0            No   3001
Application list:
    Vlan-interface2
Limit rule list
Connection limit policy information.
Policy
Number of the connection limit policy.
Rule
Number of the connection limit rule.
Stat Type
Statistics types:
·     Src-Dst-Port—Limits connections by source IP, destination IP, and service combination.
·     Src-Dst—Limits connections by source IP address and destination IP address combination.
·     Src-Port—Limits connections by source IP and service combination.
·     Dst-Port—Limits connections by destination IP and service combination.
·     Src—Limits connections by source IP address.
·     Dst—Limits connections by destination IP address.
·     Port—Limits connections by service.
·     Dslite—Limits connections by B4 device of a DS-Lite tunnel.(This value is not supported in the current software version.)
·     --—Limits connections not by a specific IP address or service. All connections that match the ACL used by the rule are limited.
HiThres
Upper limit of the connections.
LoThres
Lower limit of the connections.
Rate
Maximum number of connections established per second.
ACL
Number or name of the ACL used by the rule.
PermitNew
Permit new connections when the connection count or connection rate exceeds the threshold.
Application list
Application list of the connection limit policy, including interface name and Global. Global indicates that the connection limit policy is applied globally.
Connection limit policy description.
Description list
List of connection limit policy descriptions.
connection-limit
limit
display connection-limit ipv6-stat-nodes
Use display connection-limit ipv6-stat-nodes to display statistics about IPv6 connections that match connection limit rules globally or on an interface.
display connection-limit ipv6-stat-nodes { global | interface interface-type interface-number } [ { deny-new | permit-new } | destination destination-ip | service-port port-number | source source-ip ] * [ count ]
global: Displays statistics about IPv6 connections that match connection limit rules globally.
deny-new: Displays limit rule-based statistics sets of which new connections are rejected.
permit-new: Displays limit rule-based statistics sets of which new connections are allowed.
destination destination-ip: Specifies a destination by its IP address.
service-port port-number: Specifies a service port by its port number.
source source-ip: Specifies a source by its IP address.
count: Displays only the number of limit rule-based statistics sets. Detailed information about the specified IPv6 connections is not displayed. If you do not specify this keyword, the command displays detailed information about the specified IPv6 connections that match connection limit rules.
The statistics for this command include the following information:
·     Connection information, including the source/destination IP address, service port, and transport layer protocol of connections.
·     Matching connection limit rules.
·     Number of current connections.
·     Whether or not new connections can be created.
To further filter the output statistics, specify the following options in the command:
·     source source-ip.
·     destination destination-ip.
·     service-port port-number.
·     permit-new.
·     deny-new.
For example, if you specify the source source-ip and destination destination-ip combination, this command displays statistics about IPv6 connections that match connection limit rules by source IP address and destination IP address.
If you specify none of the previously mentioned parameters, this command displays statistics about all IPv6 connections that match connection limit rules.
Deleting or modifying an IPv6 connection limit policy will not delete the effective IPv6 connection limit rule-based statistics sets. An IPv6 connection limit rule-based statistics set will be automatically deleted after all the IPv6 connections for the set are disconnected.
# ‌Display statistics about all IPv6 connections that match the connection limit rule on GigabitEthernet 1/0/1.
<Sysname> display connection-limit ipv6-stat-nodes interface gigabitethernet 1/0/1
Slot 0:
 Src IP address          : Any
     VPN instance        : vpn5
 Dst IP address          : fe80::5ed9:98ff:feb1:69b6
     VPN instance        : abcdefghijklmnopqrstuvwxyzabcde
 DS-Lite tunnel peer     : 9876543210
 Service                 : tcp/12345
 Limit rule ID           : 12345(ACL: 3184)
 Sessions threshold Hi/Lo: 1000000/90000
 Sessions count          : 150000
 Sessions limit rate     : 0
 New session flag        : Permit
# ‌Display statistics about all IPv6 connections that match the connection limit rule on VLAN-interface 2.
<Sysname> display connection-limit ipv6-stat-nodes interface vlan-interface 2
Slot 0:
     VPN instance        : vpn5
 Service                 : tcp/12345
# ‌Display the number of limit rule-based statistics sets by source IP address 2::1.
<Sysname> display connection-limit ipv6-stat-nodes global source 2::1 count
Slot 0:
       Current limit statistic nodes count is 16.
Src IP address
Source IP address.
Dst IP address
Destination IP address.
VPN instance
MPLS L3VPN instance to which the IP address belongs. Two hyphens (--) indicates that the IP address is on the public network.
DS-Lite tunnel peer
Peer IP address of the DS-Lite tunnel to which the connection belongs. Two hyphens (--) indicates that the connection does not belong to a DS-Lite tunnel.
Service
Protocol name and service port number.
For an unwell-known protocol, this field displays unknown(xx).The cross signs (xx) indicates the protocol number. For the ICMP protocol, the protocol number is the decimal digits that are converted from the hexadecimal contents of the type and code fields.
Limit rule ID
ID of the matched rule. The ACL number of the rule is enclosed in parentheses.
Upper and lower connection limits.
Sessions count
Sessions limit rate
New session flag
Whether or not new connections can be created:
·     Permit—New connections can be created.
·     Deny—New connections cannot be created.
When the number of connections reaches the upper limit, this field displays Permit although new connections are not allowed. This field displays Deny only when the number of connections exceeds the upper limit.
limit
display connection-limit statistics
Use display connection-limit statistics to display the connection limit statistics globally or on an interface.
display connection-limit statistics { global | interface interface-type interface-number }
global: Displays the global connection limit statistics.
# ‌Display the global connection limit statistics.
<Sysname> display connection-limit statistics global
Connection limit statistics (Global, slot 0):
    Dropped IPv4 packets:   54781
    Dropped IPv6 packets:   11457
Dropped IPv4 packet
Number of IPv4 packets that are dropped because the upper connection limit is exceeded for the IPv4 connection limit policy that is configured globally or on an interface.
Dropped IPv6 packet
Number of IPv6 packets that are dropped because the upper connection limit is exceeded for the IPv6 connection limit policy that is configured globally or on an interface.
connection-limit
limit
display connection-limit stat-nodes
Use display connection-limit stat-nodes to display statistics about IPv4 connections that match connection limit rules globally or on an interface.
display connection-limit stat-nodes { global | interface interface-type interface-number } [ { deny-new | permit-new } | destination destination-ip | service-port port-number | source source-ip ] * [ count ]
global: Displays statistics about IPv4 connections that match connection limit rules globally.
count: Displays only the number of limit rule-based statistics sets. Detailed information about the specified IPv4 connections is not displayed. If you do not specify this keyword, the command displays detailed information about the specified IPv4 connections that match connection limit rules.
·     source source-ip.
·     permit-new.
·     deny-new.
For example, if you specify the source source-ip and destination destination-ip combination, this command displays statistics about IPv4 connections that match connection limit rules by source IP address and destination IP address.
If you specify none of the previously mentioned parameters, this command displays statistics about all IPv4 connections that match connection limit rules.
Deleting or modifying an IPv4 connection limit policy will not delete the effective IPv4 connection limit rule-based statistics sets. An IPv4 connection limit rule-based statistics set will be automatically deleted after all the IPv4 connections for the set are disconnected.
# ‌Display statistics about all IPv4 connections that match the connection limit rule on GigabitEthernet 1/0/1.
<Sysname> display connection-limit stat-nodes interface gigabitethernet 1/0/1
Slot 0:
 Src IP address          : 100.100.100.100
     VPN instance        : 0123456789012345678901234567890
 Dst IP address          : 200.200.200.200
 DS-Lite tunnel peer     : 1234567890
 Service                 : tcp/12345
 Limit rule ID           : 12345(ACL: 3001)
 Sessions threshold Hi/Lo: 1100000/980000
 Sessions count          : 1050000
# ‌Display statistics about all IPv4 connections that match the connection limit rule on VLAN-interface 2.
<Sysname> display connection-limit stat-nodes interface vlan-interface 2
Slot 0:
 Service                 : tcp/12345
# ‌Display the number of global limit rule-based statistics sets.
<Sysname> display connection-limit stat-nodes global count
Slot 0:
       Current limit statistic nodes count is 5.
Src IP address
Source IP address.
Dst IP address
VPN instance
DS-Lite tunnel peer
Service
For an unwell-known protocol, this field displays unknown(xx). The cross signs (xx) represents the protocol number. For the ICMP protocol, the protocol number is the decimal digits that are converted from the hexadecimal contents of the type and code fields.
Sessions count
Sessions limit rate
New session flag
limit
limit
Use limit to configure a connection limit rule.
Use undo limit to delete a connection limit rule.
In IPv4 connection limit policy view:
limit limit-id acl { acl-number | name acl-name } [ per-destination | per-service | per-source ] * { amount max-amount min-amount | rate rate } * [ description text  | permit-new ] *
limit limit-id acl { acl-number | name acl-name } per-source { threshold threshold | rate rate } * blacklist [ description text ]
undo limit limit-id
In IPv6 connection limit policy view:
limit limit-id acl ipv6 { acl-number | name acl-name } [ per-destination | per-service | per-source ] * { amount max-amount min-amount | rate rate } * [ description text  | permit-new ] *
limit limit-id acl ipv6 { acl-number | name acl-name }  per-source { threshold threshold | rate rate } * blacklist [ description text ]
undo limit limit-id
No connection limit rules exist.
limit-id: Specifies a connection limit rule by its ID in the range of 1 to 256.
acl: Specifies the ACL that matches the user range. Only the user connections that match the ACL are limited.
ipv6: Specifies an IPv6 ACL. If you do not specify this keyword, an IPv4 ACL is used.
acl-number: Specifies an ACL by its number in the range of 2000 to 3999.
name acl-name: Specifies an ACL by its name. The acl-name argument is a case-insensitive string of 1 to 63 characters. It must start with an English letter. To avoid confusion, it cannot be all.
per-destination: Limits connections by destination IP address.
per-service: Limits connections by service depending on transport layer protocol and service port.
per-source: Limits connections by source IP address.
amount: Limits the number of connections.
max-amount: Specifies the upper connection limit in the range of 1 to 4294967294. If the permit-new parameter is not specified, when user connections in a range or of a type exceed the upper limit, new connections cannot be created until the connection count drops below min-amount.
min-amount: Specifies the lower connection limit in the range of 1 to 4294967294. The lower connection limit cannot be greater than the upper connection limit. New connections cannot be created until the connection number goes below the lower connection limit.
rate: Limits the connection establishment rate.
rate: Specifies the maximum number of connections established per second. The value range is 5 to 10000000. If the permit-new parameter is not specified, when user connections in a range or of a type exceed this rate, new connections cannot be created until the connection rate drops below this rate.
description text: Specifies a description for the connection limit rule, a case-sensitive string of 1 to 127 characters. By default, a connection limit rule does not have a description.
permit-new: Permits new connections when the connection count or connection rate exceeds the threshold and generates alarm logs.
threshold: Specifies the upper connection limit in the range of 1 to 4294967294.
blacklist: Adds the source IP addresses of rule-matching connection requests to the blacklist after the existing rule-matching connections have reached the limit on the number of connections or the connection establishment rate. The device will block all packets from a blacklisted source IP address until after it is removed from the blacklist, including packets that belong to the existing connections. For more information about the blacklist feature, see attack detection and prevention configuration in Security Configuration Guide.
Each connection limit policy can define multiple rules, and each rule must specify the used ACL, rule type, and either of upper/lower connection limit and connection establishment rate limit. In one rule, you can specify one or multiple of the keywords per-destination, per-source, and per-service. For example, if the per-destination and per-source combination is specified, connections are limited by the source IP address and destination IP address. Connections with the same source IP address and destination IP address are the same type.
When you configure a connection limit rule, follow these guidelines:
·     Different rules in the same connection limit policy must use different ACLs.
·     If you specify none of the per-destination, per-source, and per-service keywords, all connections that match the specified ACL are limited by the specified value.
·     When the connections established on a device are matched against a connection limit policy, the limit rules in the policy are matched in ascending order of rule ID.
·     When the specified ACL changes, the connections that have been established are limited by the new connection limit policy.
# Configure a connection limit rule to limit the connections established by hosts on the 192.168.0.0/24 network.
1.     ‍Configure ACL 3000 to match traffic from 192.168.0.0/24.
[Sysname] acl advanced 3000
[Sysname-acl-ipv4-adv-3000] rule permit ip source 192.168.0.0 0.0.0.255
2.     Add connection limit rule 1 to IPv4 connection limit policy 1. Limit connections that match ACL 3000 by the source and destination IP addresses, with the upper limit 2000, lower limit 1800, and establishment rate 10 per second.
[Sysname-connlmt-policy-1] limit 1 acl 3000 per-destination per-source amount 2000 1800 rate 10
3.     Verify that when the connection number exceeds 2000, new connections cannot be established until the connection number goes below 1800. (Details not shown.)
# Configure connection limit rule 1 for IPv4 connection limit policy 1:
4.     ‍Configure ACL 3000 to match traffic from 192.168.0.0/24.
5.     Add connection limit rule 1 to IPv4 connection limit policy 1. Limit connections that match ACL 3000 by the source and destination IP addresses, with the upper limit 2000, lower limit 1800, and establishment rate 10 per second. Specify the permit-new keyword.
[Sysname-connlmt-policy-1] limit 1 acl 3000 per-destination per-source amount 2000 1800 rate 10 permit-new
6.     Verify that when the connection number exceeds 2000 or the connection rate exceeds 10 per second, new connections can be established but alarm logs are generated. (Details not shown.)
7.     ‍Configure ACL 3000 to match traffic from 192.168.0.0/24.
8.     Add connection limit rule 1 to IPv4 connection limit policy 1. Use ACL 3000 to match connection requests from the 192.168.0.0/24 network and configure the rule to limit connections by source IP address. Make sure each host on the network can establish only a maximum of 10 connections per second and initiate a maximum of concurrent 2000 connections from the same IP address. When the number of connections initiated by a host from the same IP address exceeds 2000 or the connection establishment rate exceeds 10 connections per second, the device blacklists that IP address.
[Sysname-connlmt-policy-1] limit 1 acl 3000 per-source threshold 2000 rate 10 blacklist
9.     Verify that all traffic from a blacklisted source IP address is blocked until after it is removed from the blacklist. (Details not shown.)
# Configure a connection limit rule to limit the connections established by hosts on the 2:1::/96 network.
10.     ‍Configure ACL 2001 to match traffic from 2:1::/96.
[Sysname] acl ipv6 basic 2001
[Sysname-acl-ipv6-basic-2001] rule permit source 2:1::/96
11.     Add connection limit rule 1 to IPv6 connection limit policy 12. Limit connections that match ACL 2001 by the source and destination IP addresses, with the upper limit 200, lower limit 100, and establishment rate 10 per second.
[Sysname-connlmt-ipv6-policy-12] limit 2 acl ipv6 2001 per-destination amount 200 100 rate 10
12.     Verify that when the connection number exceeds 200, new connections cannot be established until the connection number goes below 100. (Details not shown.)
13.     ‍Configure ACL 2001 to match traffic from 2:1::/96.
14.     Add connection limit rule 1 to IPv6 connection limit policy 12. Limit connections that match ACL 2001 by the destination IP addresses, with the upper limit 200, lower limit 100, and establishment rate 10 per second. Specify the permit-new keyword.
15.     Verify that when the connection number exceeds 200 or the connection rate exceeds 10 per second, new connections can be established but alarm logs are generated. (Details not shown.)
connection-limit
reset connection-limit statistics
Use reset connection-limit statistics to clear the connection limit statistics globally or on an interface.
reset connection-limit statistics { global | interface interface-type interface-number }
global: Clears the global connection limit statistics.
# ‌Clear the connection limit statistics on GigabitEthernet 1/0/1.
<Sysname> reset connection-limit statistics interface gigabitethernet 1/0/1
# ‌Clear the connection limit statistics on VLAN-interface 2.
<Sysname> reset connection-limit statistics interface vlan-interface 2
