- 16-Security Command Reference
- 01-ACL commands
- 02-Time range commands
- 03-User profile commands
- 04-Password control commands
- 05-Public key management commands
- 06-PKI commands
- 07-IPsec commands
- 08-SSH commands
- 09-SSL commands
- 10-SSL VPN commands
- 11-Session management commands
- 12-Connection limit commands
- 13-Attack detection and prevention commands
- 14-ARP attack protection commands
- 15-ND attack defense commands
- 16-ASPF commands
- 17-Protocol packet rate limit commands
- 18-Crypto engine commands
- 19-Security policy commands
- 20-Object group commands
| 03-User profile commands | 57.39 KB |
display user-profile
Use display user-profile to display configuration and online user information for user profiles.
display user-profile [ name profile-name ]
name profile-name: Specifies a user profile by its name, a case-sensitive string of 1 to 31 characters. Valid characters include English letters, digits, hyphens (-), and underscores (_). The name must start with an English letter or digit, and cannot contain only digits. The name must be globally unique. If you do not specify this option, the command displays configuration and online user information for all user profiles.
# Display configuration and online user information for user profile aaa.
<Sysname> display user-profile name aaa
User-Profile: aaa
Inbound:
Committed Access Rate:
Rule: If-match any
CIR 64 (kbps), CBS 512 (Bytes), EBS 0 (Bytes), PIR 888 (kbps)
Rule: If-match acl 2000
CIR 3000 (kbps), CBS 187500 (Bytes), EBS 0 (Bytes)
Policy: p1
Outbound:
Rule: If-match acl 3000
CIR 1000 (kbps), CBS 62500 (Bytes), EBS 0 (Bytes)
Rule: If-match any
Line Rate:
CIR 32 (kbps), CBS 2048 (Bytes), EBS 0 (Bytes), PIR 888 (kbps)
Priority queuing: pql 1
General Traffic Shaping:
CIR 200 (kbps), CBS 12500 (Bytes), EBS 0 (Bytes)
Overhead compensation length: 18
User user_1:
Authentication type: Portal
Network attributes:
Interface : GigabitEthernet1/0/1
MAC address : 0000-1111-2222
Failed action list:
Inbound: Policy p1
Inbound: CIR 64 (kbps), CBS 2048 (Bytes), EBS 0 (Bytes), PIR 888 (kbps)
User-Profile |
User profile name. |
Inbound |
Policy applied to incoming traffic. |
Outbound |
Policy applied to outgoing traffic. |
CIR |
Committed information rate, in kbps. |
CBS |
Committed burst size, in bytes. |
Policy |
Policy name. |
Line Rate |
Information about user profile-based rate limiting. When the peer-advertise-bandwidth keyword is specified in the qos lr outbound command, this field displays the peer-advertise-bandwidth configuration information. |
Priority queuing |
Information about priority queuing applied to a user profile. |
General Traffic Shaping |
Information about GTS applied to a user profile. |
User user_1 |
Username of a user account with which a user profile is associated. |
Authentication type |
Authentication type: · 802.1X—802.1X authentication. · Portal—Portal authentication. · PPP—PPP authentication. · MACA—MAC authentication. |
Network attributes |
Online user information. |
Failed action list |
Actions that failed to be applied to the user. |
Overhead compensation length |
Packet compensation length in bytes for outbound traffic policing. |
Rule |
Match criteria. |
user-profile
Use user-profile to create a user profile and enter its view, or enter the view of an existing user profile.
Use undo user-profile to delete a user profile.
user-profile profile-name
undo user-profile profile-name
No user profiles exist.
profile-name: Specifies a user profile by its name, a case-sensitive string of 1 to 31 characters. Valid characters include English letters (a-z, A-Z), digits (0-9), hyphens (-), and underscores (_). The name must start with an English letter or digit, and cannot contain only digits. The name must be globally unique.
# Create user profile a123 and enter the view of a123.
[Sysname] user-profile a123
