- H3C UniServer R4900 G5 Hardware Options Installation and Replacement Videos-6W101
- 01-Install standard, ball-bearing, or short-distance slide rails
- 02-Install the server to a rack
- 03-Remove the server from a rack
- 04-Install and remove a cable management arm (CMA)
- 05-Replace a DIMM
- 06-Install a processor
- 07-Replace a processor
- 08-Replace a drive
- 09-Replace the intelligent security bezel
- 10-Replace the system board
- 11-Replace a mid GPU adapter
- 12-Install a riser card on PCIe riser connector 3 or 4
- 13-Replace a front drive backplane
- 14-Replace a riser card
- 15-Replace a standard storage controller and the power fail safeguard module
- 16-Replace a OCP storage controller and the power fail safeguard module
- 17-Replace a standard PCIe
- 18-Replace an OCP network adapter
- 19-Replace the OCP adapter
- 20-Replace a GPU
- 21-Replace a SATA M.2 SSD
- 22-Replace a SATA M.2 expander module
- 23-Replace SD card
- 24-Replace the dual SD card extended
- 25-Replace an NVMe SSD expander
- 26-Install an LCD smart management module
- 27-Replace the LCD smart management module
- 28-Use the LCD smart management module
- 29-Install a TPM or TCM
- 30-Replace the NVMe VROC module
- 31-Replace the system battery
- 32-Replace a fan module
- 33-Replace a power supply
- 34-Connect power cords
- 35-Replace a chassis ear
- 36-Install or remove blanks
- 37-Install a rear drive cage
- 38-Replace a rear drive cage
- 39-Replace a rear drive backplane
- 40-Replace the mid drive cage
- 41-Replace a mid drive
- 42-Replace an NVMe M.2 SSD expander module
- 43-Replace an NVMe M. 2 SSD
- 44-Replace an NVMe SSD expander module
- 45-Replace a GPU on the 4GPU module
- 46-Replace a PCIe module on the 4GPU module
- 47-Replace the 4GPU module
- 48-Install a GPU on the 4GPU module
27-Replace the LCD smart management module | 105.13 MB |
Watch online
