| Title | Size | Downloads |
| V7-IPS-1.0.329.dat | 15.35 MB |
Version number
V7-IPS-1.0.329
MD5 number
c77fd4dc1b2e96e4ff50bed9f3e73269
Update time
2024-12-05
Update attack list
Key new rules:
54058 CVE-2024-1252_Tongda_Office_Anywhere_SQL_Injection_Vulnerability[2]
---- Category: Vulnerability
---- Description: TONGDA Office Anywhere is a set of collaborative office OA system. TONGDA Office Anywhere 2017 version 11.9 and earlier
---- has an SQL injection vulnerability, which is caused by incorrect operation of parameter ASK_DUTY_ID resulting in SQL injection.
54019 CVE-2024-38023_Microsoft_SharePoint_Server_Remote_Code_Execution_Vulnerability[2]
---- Description: Microsoft SharePoint is an enterprise business collaboration platform from Microsoft Corporation. The platform is used
---- to integrate business information and to share work, collaborate with others, organize projects and work groups, and search for
---- people and information. Microsoft SharePoint has a security vulnerability. An attacker could exploit the vulnerability to remotely
---- execute code.
53988 Dahua_ICC_Intelligent_IoT_Integrated_Management_Platform_Command_Execution_Vulnerability[3]
---- Description: The Dahua ICC Intelligent IoT Integrated Management Platform modularizes and loosely couples technical components,
---- hierarchically levels solutions, and enhances data access and ecological cooperation capabilities for smart IoT. There is a command
---- execution vulnerability in the Dahua ICC Intelligent IoT Integrated Management Platform, which attackers can exploit to execute
---- system commands.
Note
[1] Indicates that this change is incorporated into all security products
[2] Indicates that this change is only incorporated into the full series of F5000, T5000, T9000, M9000, F1030 and above F series products
[3] The device memory is greater than 2GB. After loading the IPS rules library file of this version, 23977 predefined rules can be generated in "Intrusion Prevention System"
[4] The device memory is less than or equal to 2GB. After loading the IPS rules library file of this version, 3274 predefined rules can be generated in "Intrusion Prevention System"
