H3C Campus Switches M-LAG Configuration Guide-6W102
HomeSupportConfigure & DeployConfiguration GuidesH3C Campus Switches M-LAG Configuration Guide-6W102
09-M-LAG and Mirroring Configuration Example (Campus)
M-LAG and Mirroring Configuration Example (Campus) 1
Network configuration· 1
Applicable product matrixes· 3
Analysis· 3
Restrictions and guidelines· 4
Configure M-LAG devices· 4
Procedure summary· 4
Configuring M-LAG·· 4
Configuring the interconnect links between the M-LAG member devices and Layer 2 switch· 6
Configuring the Layer 3 link connecting the M-LAG member devices· 6
Configuring the M-LAG dual-active gateways· 8
Configuring the interconnect links between the M-LAG system and the uplink device Device C· 8
Configuring uplink device Device C· 9
Procedure summary· 9
Configuring the interconnect links between the uplink device Device C and the M-LAG member devices  9
Configuring the interconnect link between the uplink device Device C and the network· 10
Configuring the interconnect link between the uplink device Device C and the mirroring server 10
Configuring downlink device L2-LSW·· 11
Procedure summary· 11
Configuring the interconnect links between the downlink device L2-LSW and the M-LAG member devices  11
Configuring the interconnect link between the downlink device Device D and the host 12
Configure traffic mirroring· 12
Procedure summary· 12
Configure local port mirroring· 12
Configure local flow mirroring to mirroring traffic to an interface· 12
Configure local flow mirroring to mirror traffic on all interfaces in a VLAN· 14
Configure global flow mirroring to mirror traffic on all interfaces on the device· 15
Configure port mirroring ERSPAN (applicable product matrix 1) 16
Configure port mirroring ERSPAN (applicable product matrix 2) 17
Configure flow mirroring ERSPAN· 18
Traffic forwarding models· 19
About the traffic model 19
Traffic· 20
Testing network convergence upon single points of failure· 20
Testing network convergence upon single points of failure in a local port mirroring scenario· 20
Testing network convergence upon single points of failure in a remote port mirroring scenario· 22
Verifying the configuration· 22
Verification commands· 22
Procedure· 23
Upgrading the devices· 31
Checking the environment 31
Upgrade procedure· 31
Verifying the traffic interruption time during the upgrade· 32
Verifying the upgrade result 32
Expanding the network· 32
Checking the environment 32
Verifying the traffic interruption time· 33
Verifying the expansion result 33
Replacing hardware· 33
Replacing a service module· 33
Replacing a switching fabric module· 34
As shown in Figure 1:
·     Device A and Device B form an M-LAG system. L2-LSW accesses the M-LAG system through M-LAG interfaces.
·     Device A and Device B act as dual-active gateways for Host A through M-LAG.
·     Device A and Device B are connected to uplink device Device C through equal-cost routes.
Configure the network as follows to meet the server access requirements of users:
·     Host A and the network can communicate through both IPv4 and IPv6.
·     Traffic between Host A and the network is mirrored to Server A, Server B, and Server C.
·     When a link between the two M-LAG member devices fails, the servers can still communicate.
Figure 1 M-LAG network
Table 1 Interfaces and IP address assignment
Device
IP address
Remarks or peer interfaces
Device A
LoopBack 0
3.3.3.3/32
2000::3:3:3:3/128
Loopback interface address
Router ID
XGE 3/0/5
N/A
L2-LSW: XGE3/0/1
M-LAG interface
XGE 3/0/15
N/A
Server A
XGE 3/0/4
32.1.1.1/24
32::1/64
Device C: XGE 3/0/4
XGE 3/0/1
21.1.1.1/24
Device B XGE 3/0/1
Keepalive link
XGE 3/0/2
N/A
Device B XGE 3/0/2
Peer-link interface
XGE 3/0/3
N/A
Device B XGE 3/0/3
Peer-link interface
VLAN 100
100.1.1.1/24
100::1/64
Dual-active gateways
VLAN 101
101.1.1.1/24
101::1/64
Layer 3 link connecting the two M-LAG member devices, which is used for forwarding east-west traffic or used as the failover link for north-south traffic or Layer 3 remote mirrored traffic.
Device B
LoopBack 0
4.4.4.4/32
2000::4:4:4:4/128
Router ID.
XGE 3/0/5
N/A
L2-LSW: XGE3/0/2
M-LAG interface
XGE 3/0/4
33.1.1.1/24
33::1/64
Device C: XGE 3/0/5
XGE 3/0/15
N/A
Server B
XGE 3/0/1
21.1.1.2/24
Device A: XGE 3/0/1
Keepalive link
XGE 3/0/2
N/A
Device A: XGE 3/0/2
Peer-link interface
XGE 3/0/3
N/A
Device A: XGE 3/0/3
Peer-link interface
VLAN 100
100.1.1.1/24
100::1/64
VLAN 101
101.1.1.2/24
101::2/64
Interface of the Layer 3 link connecting the two M-LAG member devices, which is used for forwarding east-west traffic or allowing north-south traffic or Layer 3 remote mirrored traffic to escape.
Device C
LoopBack 0
5.5.5.5/32
2000::5:5:5:5/128
Router ID.
XGE 3/0/1
22.1.1.1/24
22::1/64
Network 1
XGE 3/0/4
32.1.1.2/24
32::2/64
Device A: XGE 3/0/4
XGE 3/0/5
33.1.1.2/24
33::2/64
Device B XGE 3/0/4
XGE 3/0/15
2.1.1.1/24
Server C
L2-LSW
XGE 3/0/1
N/A
Device A: XGE 3/0/5
M-LAG interface
XGE 3/0/2
N/A
Device B XGE 3/0/5
M-LAG interface
XGE 3/0/3
N/A
Host A
Host A
N/A
100.1.1.100/24
100::100/64
L2-LSW: XGE 3/0/3
Network 1
N/A
22.1.1.100/24
22::100/64
Device C: XGE 3/0/1
Server C
N/A
2.1.1.2/24
Device C: XGE 3/0/15
In addition to running an applicable software version, you must also install the most recent patch, if any.
Table 2 Applicable product matrix 1
Device
Software version
S10500, S10500X, S7600, S7600-X, S7600E-X, S7500X, S7500E
R7625 and later
S12500G-AF (type T cards)
R7625 and later
Table 3 Applicable product matrix 2
Device
Software version
S12500G-AF (type S cards)
R8054P04 and later
S10500X-G, S7500X-G
R7754P04 and later
S5590XP-HI-G
R7754P04 and later
Analysis
·     Host A connects to the network through two uplinks. Configure the IP address of VLAN 100 as the gateway address.
·     Server A, Server B, and Server C act as mirroring servers.
·     Configure an OSPF/OSPFv3 neighbor between Device A and Device B, which is used as the failover link for Layer 3 remote mirrored traffic and normal traffic.
·     The network is configured with both IPv4 and IPv6 settings.
All the devices were started with the factory default configuration. When you are working on a live network, make sure the existing configuration does not conflict with the following configuration.
VLAN flow mirroring and global flow mirroring support only inbound mirroring.
A peer-link interface cannot act as the monitor port.
Procedure summary
·     Configuring M-LAG
·     Configuring the interconnect links between the M-LAG member devices and Layer 2 switch
·     Configuring the Layer 3 link connecting the M-LAG member devices
·     Configuring the M-LAG dual-active gateways
·     Configuring the interconnect links between the M-LAG system and the uplink device Device C
Configuring M-LAG
Device A
Device B
Remarks
m-lag system-mac 2-2-2
Configure the M-LAG system MAC address.
You must assign the same system MAC address to all member devices in an M-LAG  system.
m-lag system-mac 1
m-lag system-mac 2
Set the M-LAG system number.
You must assign different M-LAG system numbers to the member devices in an M-LAG system.
m-lag system-mac 123
Set the M-LAG system priority.
You must set the same LAG system priority on all member devices in an M-LAG system.
m-lag standalone enable
(Optional.) Enable M-LAG standalone mode.
M-LAG standalone mode helps avoid traffic forwarding issues in this multi-active situation by allowing only the member ports in the M-LAG interfaces on one member device to forward traffic.
m-lag restore-delay 300
Set the maximum amount of time for the secondary M-LAG member device to synchronize data with the primary M-LAG member device during M-LAG system setup, such as MAC address entries.
N/A
m-lag keepalive ip destination 21.1.1.2 source 21.1.1.1
m-lag keepalive ip destination 21.1.1.1 source 21.1.1.2
Configure the source and destination IPv4 addresses of keepalive packets.
N/A
interface Ten-gigabitethernetE3/0/1
Enter the interface view for the keepalive link.
N/A
port link-mode route
Configure the interface for the keepalive link to operate in route mode as a Layer 3 interface.
N/A
ip address 21.1.1.1 24
ip address 21.1.1.2 24
Configure the source IPv4 address of keepalive packets.
N/A
Return to system view.
N/A
m-lag mad exclude interface Ten-gigabitethernetE3/0/1
Exclude the interface for the keepalive link from the shutdown action by M-LAG MAD.
N/A
interface bridge-aggregation 1
Create an aggregate interface.
The interface is used as the peer-ink interface.
link-aggregation mode dynamic
Configure the aggregate interface to operate in dynamic mode.
N/A
N/A
interface range Ten-gigabitethernetE 3/0/2 Ten-gigabitethernetE 3/0/3
Enter interface range view.
N/A
port link-aggregation group 1
Assign the physical interfaces on the peer link  to the M-LAG aggregation group.
N/A
N/A
Enter aggregate interface view.
N/A
port m-lag peer-link 1
Specify the aggregate interface as the peer-link interface.
N/A
undo mac-address static source-check enable
Disable source MAC check to ensure correct Layer 3 unicast forwarding.
N/A
N/A
lldp global enable
lldp global enable
Enable LLDP globally.
N/A
Device A
Device B
interface bridge-aggregation 2
Create the Ethernet aggregate interface connecting to L2-LSW.
Configure the aggregate interface connecting to L2-LSW to operate in dynamic mode.
port m-lag group 1
port m-lag group 1
Assign the aggregate interface (Bridge-Aggregation 2) to M-LAG group 1.
port lacp system-priority 100
port lacp system-priority 101
Set the LACP system priority, so that only member ports with higher priority are selected upon brain split.
interface Ten-gigabitethernetE 3/0/5
Enter the view of the physical interface connecting the M-LAG system to L2-LSW.
port link-aggregation group 2
Assign the interface to an aggregation group.
Device A
Device B
Remarks
router id 3.3.3.3
router id 4.4.4.4
Configure a router ID.
N/A
ospf 1
ospf 1
Enable OSPF.
N/A
import-route direct
import-route direct
Redistribute direct routes.
N/A
area 0
area 0
Configure area 0.
N/A
Return to OSPF view.
N/A
N/A
ospfv3 1
ospfv3 1
Enable OSPFv3
N/A
router-id 3.3.3.3
router-id 4.4.4.4
N/A
import-route direct
import-route direct
N/A
area 0
area 0
Configure area 0.
N/A
Return to OSPFv3 view.
N/A
N/A
interface Loopback 0
Configure a loopback interface.
N/A
ip address 3.3.3.3 255,255,255,255
ip address 4.4.4.4 255,255,255,255
Configure an IPv4 address for the loopback interface.
N/A
ospf 1 area 0
ospf 1 area 0
Enable OSPF on the loopback interface.
N/A
ipv6 address 2000::3:3:3:3/128
ipv6 address 2000::4:4:4:4/128
Configure an IPv6 address for the loopback interface.
N/A
ospfv3 1 area 0
ospfv3 1 area 0
Enable OSPFv3 on the loopback interface.
N/A
N/A
vlan 101
vlan 101
Create VLAN 101.
N/A
N/A
interface vlan-interface 101
Create VLAN-interface 101.
ip address 101.1.1.1 255.255.255.0
ip address 101.1.1.2 255.255.255.0
Assign an IPv4 address to VLAN interface 101.
N/A
ospf 1 area 0
ospf 1 area 0
Enable OSPF on the VLAN interface
N/A
ospf network-type p2p
Configure the OSPF network type for the interface as P2P.
ipv6 address 101::1 64
ipv6 address 101::2 64
Assign an IPv6 address to VLAN interface 101.
N/A
ospfv3 1 area 0
ospfv3 1 area 0
Enable OSPFv3 on the VLAN interface.
N/A
ospfv3 network-type p2p
 Configure the OSPF network type for the VLAN interface as P2P.
N/A
m-lag mad exclude interface Vlan-interface 101
Exclude the VLAN interface from the shutdown action by M-LAG MAD.
N/A
Device A
Device B
Remarks
vlan 100
vlan 100
Create VLAN 100.
N/A
N/A
Enter Ethernet aggregate interface view.
N/A
port link-type trunk
Set the link type of the Layer 2 aggregate interface (Bridge-Aggregation 2) to trunk.
N/A
port trunk permit vlan 1 100
Assign the aggregate interface to VLAN 100.
N/A
undo port trunk permit vlan 1
Remove the aggregate interface from VLAN 1.
N/A
N/A
interface vlan-interface 100
Create VLAN interface 100.
N/A
ip address 100.1.1.1 24
Assign an IPv4 address to VLAN interface 100.
The address acts as the IPv4 dual-active gateway.
ipv6 address 100::1 64
Assign an IPv6 address to VLAN interface 100.
The address acts as the IPv6 dual-active gateway.
mac-address 0002-2222-2222
Assign a MAC address to VLAN interface 100.
N/A
N/A
m-lag mad exclude interface Vlan-interface100
Exclude VLAN interface 100 from the shutdown action by M-LAG MAD.
For M-LAG member devices to synchronize ARP/ND entries, you must exclude the VLAN interfaces of the VLANs to which the M-LAG interfaces belong from the shutdown action.
Device A
Device B
interface Ten-gigabitethernetE 3/0/4
Enter Ethernet interface view.
Configure the interface as a Layer 3 interface.
ip address 32.1.1.1 24
ip address 33.1.1.1 24
Configure an IPv4 address.
ospf 1 area 0
ospf 1 area 0
Enable OSPF on the interface.
ipv6 address 32::1 64
ipv6 address 33::1 64
Configure an IPv6 address.
ospfv3 1 area 0
ospfv3 1 area 0
Enable OSPFv3 on the interface.
Configure the OSPFv3 network type for the interface as P2P.
Procedure summary
·     Configuring the interconnect links between the uplink device Device C and the M-LAG member devices
·     Configuring the interconnect link between the uplink device Device C and the network
·     Configuring the interconnect link between the uplink device Device C and the mirroring server
Device C
router id 5.5.5.5
ospf 1
Enable OSPF.
import-route direct
area 0
Configure area 0.
ospfv3 1
Enable OSPFv3.
router-id 5.5.5.5
import-route direct
area 0
Configure area 0.
ip address 5.5.5.5 255,255,255,255
Configure an IPv4 address for the interface.
ospf 1 area 0.0.0.0
ipv6 address 2000::5:5:5:5/128
Configure an IPv6 address for the interface.
ospfv3 1 area 0.0.0.0
ospf 1 area 0
ospfv3 1 area 0
Configure IPv4 an address.
ospf 1 area 0
ospfv3 1 area 0
lldp global enable
Device C
interface Ten-gigabitethernetE 3/0/1
Configuring the interface as a Layer 3 interface.
ip address 22.1.1.1 255.255.255.0
Assign an IPv4 address to the interface.
ipv6 address 22::1/64
Assign an IPv6 address to the interface.
Device C
vlan 2
Create a VLAN.
interface Ten-gigabitethernetE 3/0/15
port access vlan 2
Assign the interface to  VLAN 2 as an access port.
interface Vlan-interface2
Create VLAN interface 2, which is used to connect with the mirroring server.
ip address 2.1.1.1 255.255.255.0
Procedure summary
·     Configuring the interconnect links between the downlink device L2-LSW and the M-LAG member devices
·     Configuring the interconnect link between the downlink device Device D and the host
L2-LSW
vlan 100
Create a VLAN.
Create the Ethernet aggregate interface connecting to M-LAG member devices.
interface Range Ten-gigabitethernetE 3/0/1 to Ten-gigabitethernetE 3/0/2
Enter the view of the physical interfaces connecting the L2-LSW to M-LAG member devices.
Assign the interfaces to an aggregation group.
port access vlan 100
Assign the interfaces to VLAN 100.
lldp global enable
L2-LSW
Remarks
interface Ten-gigabitethernetE 3/0/3
N/A
Assign the interface (which connects L2-LSW to the host) to VLAN 100 as an access port.
N/A
N/A
Procedure summary
·     Configure local port mirroring
·     Configure local flow mirroring to mirroring traffic to an interface
·     Configure local flow mirroring to mirror traffic on all interfaces in a VLAN
·     Configure global flow mirroring to mirror traffic on all interfaces on the device
·     Configure port mirroring ERSPAN (applicable product matrix 1)
·     Configure port mirroring ERSPAN (applicable product matrix 2)
·     Configure flow mirroring ERSPAN
Device A
Device B
mirroring-group 1 local
Configuring a local port mirroring group.
mirroring-group 1 mirroring-port Ten-GigabitEthernet 3/0/5 both
Configure the source ports for local mirroring.
mirroring-group 1 mirror-port Ten-GigabitEthernet 3/0/15
Configure the mirroring destination port.
Device A
Device B
acl number 3000
acl number 3000
Create ACL 3000.
rule permit tcp source 100.1.1.100 0.0.0.0
Configure an ACL rule for inbound traffic.
acl number 3001
acl number 3001
Create ACL 3001.
rule permit tcp destination 100.1.1.100 0.0.0.0
Configure an ACL rule for outbound traffic.
N/A
acl ipv6 number 3000
Create IPv6 ACL 3001.
rule permit tcp source 100::100 128
Configure an IPv6 ACL rule for inbound traffic.
acl ipv6 number 3001
rule permit tcp destination 100::100 128
Configure an IPv6 ACL rule for outbound traffic.
traffic classifier test-ipv4-in
Create a traffic class for inbound IPv4 traffic.
if-match acl 3000
if-match acl 3000
Use ACL 3000 as the match criterion.
traffic classifier test-ipv4-out
Create a traffic class for outbound IPv4 traffic.
if-match acl 3001
if-match acl 3001
Use ACL 3001 as the match criterion.
traffic classifier test-ipv6-in
Create a traffic class for inbound IPv6 traffic.
if-match acl ipv6 3000
traffic classifier test-ipv6-out
Create a traffic class for outbound IPv6 traffic.
if-match acl ipv6 3001
traffic behavior mir
Configure traffic mirroring behavior
mirror-to interface Ten-gigabitethernet 3/0/15
Configure an action of mirroring traffic to the mirroring server.
qos policy test-in
qos policy test-in
Create a QoS policy for inbound traffic.
classifier test-ipv4-in behavior mir
Associate the traffic class with the traffic behavior for IPv4 traffic.
classifier test-ipv6-in behavior mir
Associate the traffic class with the traffic behavior for IPv6 traffic.
qos policy test-out
qos policy test-out
Create a QoS policy for outbound traffic.
classifier test-ipv4-out behavior mir
classifier test-ipv6-out behavior mir
interface Ten-gigabitethernet 3/0/5
Enter the view of the source port.
qos apply policy test-in inbound
Apply the QoS policy to the inbound direction of the interface.
qos apply policy test-out outbound
Apply the QoS policy to the outbound direction of the interface.
Device A
Device B
acl number 3000
acl number 3000
Create ACL 3000.
Create a QoS traffic class for inbound IPv4 traffic.
if-match acl 3000
if-match acl 3000
Create a traffic behavior.
qos policy test-in
qos policy test-in
Create a QoS policy.
qos vlan-policy test-in vlan 100 inbound
Apply the QoS policy to the inbound direction of the VLAN.
Device A
Device B
acl number 3000
acl number 3000
Create ACL 3000.
if-match acl 3000
if-match acl 3000
Configure a traffic behavior.
qos policy test-in
qos policy test-in
qos apply policy test-in global inbound
Apply the QoS policy to the inbound direction globally.
Device A
Device B
service-loopback group 1 type tunnel
Create service loopback group 1, and specify the tunnel service for the group.
interface Ten-gigabitethernet 3/0/8
Enter interface view. The interface can be any interface that has not been used.
port service-loopback group 1
Assign Ten-GigabitEthernet 3/0/8 to service loopback group 1.
interface tunnel 1 mode gre
Create tunnel interface Tunnel 1 that operates in GRE mode.
ip address 50.1.1.1 24
ip address 50.2.1.1 24
Configure an IP address.
source LoopBack0
source LoopBack0
Configure a source  IP address for Tunnel 1.
destination 5.5.5.5
destination 5.5.5.5
Configure a destination  IP address for Tunnel 1.
Create a local mirroring group.
Configure Ten-GigabitEthernet 3/0/5 as a source port of local mirroring group 1.
mirroring-group 1 monitor-port tunnel 1
Configure Tunnel 1 as the monitor port of local mirroring group 1.
Device C
Enter the view of Ten-GigabitEthernet 3/0/8. The interface can be any interface that has not been used.
Create GRE tunnel interface 1.
ip address 50.1.1.2 24
source LoopBack0
destination 3.3.3.3
interface tunnel 2 mode gre
Create tunnel interface Tunnel 2 that operates in GRE mode.
ip address 50.2.1.2 24
source LoopBack0
Configure a source  IP address for Tunnel 2.
destination 4.4.4.4
Configure a destination IP address for Tunnel 2.
mirroring-group 1 mirroring-port Ten-GigabitEthernet 3/0/4 Ten-GigabitEthernet 3/0/5 inbound
Configure Ten-GigabitEthernet 3/0/4 and Ten-GigabitEthernet 3/0/5 as source ports of local mirroring group 1.
mirroring-group 1 monitor-port Ten-GigabitEthernet 3/0/15
Configure Ten-GigabitEthernet 3/0/15 as the monitor port of local mirroring group 1.
acl number 3000
To prevent GRE mirrored packets from being used for other purposes, use ACLs to filter them.
rule deny gre source 3.3.3.3 0 destination 5.5.5.5 0
Configure a rule to match GRE mirrored packets.
rule deny gre source 4.4.4.4 0 destination 5.5.5.5 0
interface range Ten-gigabitethernet 3/0/4 to Ten-gigabitethernet 3/0/5
Enter the view of the source ports.
packet-filter 3000 inbound
Apply ACL 3000 to the inbound direction of the interfaces.
Device A
Device B
Configure a local mirroring group.
Configure a source port for the mirroring group.
mirroring-group 1 monitor-port Ten-GigabitEthernet 3/0/4 destination-ip 2.1.1.2 source-ip 32.1.1.1
mirroring-group 1 monitor-port Ten-GigabitEthernet 3/0/4 destination-ip 2.1.1.2 source-ip 33.1.1.1
Configure the monitor port for the mirroring group.
Device A
Device B
acl number 3000
acl number 3000
Create ACL 3000.
acl number 3001
acl number 3001
Create ACL 3001.
Create a QoS traffic class for inbound traffic.
if-match acl 3000
if-match acl 3000
Configure a traffic class for outbound IPv4 traffic.
if-match acl 3001
if-match acl 3001
mirror-to interface destination-ip 2.1.1.2 source-ip 3.3.3.3
mirror-to interface destination-ip 2.1.1.2 source-ip 4.4.4.4
Mirror traffic to mirroring servers.
qos policy test-in
qos policy test-in
qos policy test-out
qos policy test-out
Quit
The traffic model contains the following information:
·     ID—Traffic ID, in O-X-XXX format. The first segment (O) represents overlay traffic. The second segment (X) represents the IP version (4 for IPv4 and 6 for Ipv6). The third segment (XXX) represents a unique number for the traffic.
·     Type—Traffic type, such as known unicast/IPv4 and unicast/L2.
·     Direction—Traffic direction, such as inter-leaf east-west traffic and north-west traffic.
·     Forwarding path—Nodes that underlay traffic traverses.
·     Simulation method—Traffic simulation method. Testers are used to simulate the patterns of traffic on the network set up in this example.
·     Simulation traffic load—The network can be tested under light load (fewer than 1000 simulation traffic flows) or heavy load (more than 1000 simulation traffic flows).
Traffic
No.
Direction
Forwarding path
Traffic simulation
Load
Traffic direction to  firewalls/LB
Remarks
O-4-001
Known unicast/IPv4
N/A
HostA-DeviceA/B-Device C-Network
Tester
Light
N/A
When the uplink interface fails, remote mirroring traffic and normal traffic can be forwarded through the Layer 3 link between M-LAG member devices.
O-4-002
Known unicast/IPv4
N/A
Network-Device C-Device A/B-HostA
Tester
Light
N/A
O-6-001
Known unicast/IPv6
N/A
Tester
Light
N/A
O-6-002
Known unicast/IPv6
N/A
Network-Device c-Device A/B-HostA
Tester
Light
N/A
The mirroring function is not affected by single points of failure. The mirroring server cannot receive packets when traffic is not present on the service ports.
Table 4 Network convergence upon single points of failure
Device
Failure type
Local port mirroring
Local flow mirroring configuration applied to an interface
Local flow mirroring configuration applied to VLANs
Local flow mirroring configuration applied globally
Device A
Single member link failure in an M-LAG interface
No impact
No impact
No impact
No impact
Single point of failure restored on M-LAG member links
No impact
No impact
No impact
No impact
Single uplink failure
No impact
No impact
No impact
No impact
Recovery from a single uplink failure
No impact
No impact
No impact
No impact
Peer link failure
No impact
No impact
No impact
No impact
Recovery from a peer link failure
No impact
No impact
No impact
No impact
Keepalive link failure
No impact
No impact
No impact
No impact
Keepalive link failure restored
No impact
No impact
No impact
No impact
Recovery from a keepalive link and peer link failure
No impact
No impact
No impact
No impact
Recovery from a keepalive link failure and a peer link failure
No impact
No impact
No impact
No impact
M-LAG member device restart
No impact
No impact
No impact
No impact
Recovery from M-LAG member device restart
No impact
No impact
No impact
No impact
Switching fabric module failure.
No impact
No impact
No impact
No impact
Recovery from a switching fabric module failure
No impact
No impact
No impact
No impact
Table 5 Network convergence upon single points of failure
Device
Failure type
Layer 3 remote port mirroring (ERSPAN)
Flow mirroring ERSPAN
Device A
No impact
No impact
No impact
No impact
No impact
No impact
No impact
No impact
Peer link failure
No impact
No impact
No impact
No impact
No impact
No impact
No impact
No impact
Keepalive link failure and peer link failure
No impact
No impact
No impact
No impact
No impact
No impact
No impact
No impact
No impact
No impact
No impact
No impact
Table 6 Verification commands
Device A
Device B
display m-lag summary
Display summary information about the peer-link interface and M-LAG interfaces.
display m-lag keepalive
Display M-LAG keepalive packet statistics.
display m-lag role
display m-lag role
Display M-LAG role information.
display m-lag verbose
Display detailed information about the peer-link interface and M-LAG interfaces.
display mirroring-group
Display mirroring group information.
display qos policy interface inbound/outbound
Display the flow mirroring information for interfaces.
display qos vlan-policy vlan vlan-id inbound
Display the flow mirroring information for VLANs.
display qos policy global inbound
Display global  flow mirroring information.
Verifying the M-LAG system state
# Display summary information about the peer-link interface and M-LAG interfaces. The peer-link interface is in up state.
<Device A>display m-lag summary
Flags: A -- Aggregate interface down, B -- No peer M-LAG interface configured
       C -- Configuration consistency check failed
Peer-link interface: BAGG1
Peer-link interface state (cause): UP
Keepalive link state (cause): UP
                     M-LAG interface information
M-LAG IF    M-LAG group  Local state (cause)  Peer state  Remaining down time(s)
BAGG2       1            UP                   UP          -
<Device B>display m-lag summary
BAGG2       1            UP                   UP          -
# Display M-LAG keepalive packet statistics. The keepalive packet sending and receiving states are both successful.
<Device A>display m-lag keepalive
Neighbor keepalive link status (cause): Up
Neighbor is alive for: 590 s 830 ms
Keepalive packet transmission status:
  Sent: Successful
  Received: Successful
Last received keepalive packet information:
  Source IP address: 21.1.1.2
  Time: 2022/08/01 15:53:17
  Action: Accept
M-LAG keepalive parameters:
Destination IP address: 21.1.1.2
Source IP address: 21.1.1.1
Keepalive UDP port : 6400
Keepalive VPN name : N/A
Keepalive interval : 1000 ms
Keepalive timeout  : 5 sec
Keepalive hold time: 3 sec
<Device A>
<Device B>disp m-lag keepalive
Neighbor is alive for: 650 s 238 ms
  Sent: Successful
  Time: 2022/08/01 15:59:11
  Action: Accept
Destination IP address: 21.1.1.1
# Display M-LAG role information. Device A is the secondary device, and Device B is the primary device.
<Device A>display m-lag role
                    Effective role information
Factors                    Local                    Peer
Effective role             Secondary                Primary
Initial role               None                     Primary
MAD DOWN state             Yes                      No
Health level               3                        0
Role priority              32768                    32768
Bridge MAC                 0cda-41c5-aab0           0000-fc00-c7fb
Effective role trigger: Peer link calculation
Effective role reason: Single None role
                    Configured role information
Factors                    Local                    Peer
Configured role            Secondary                Primary
<Device B>disp m-lag role
Factors                    Local                    Peer
Effective role             Primary                  Secondary
Initial role               Primary                  None
MAD DOWN state             No                       Yes
Health level               0                        3
Bridge MAC                 0000-fc00-c7fb           0cda-41c5-aab0
Factors                    Local                    Peer
Configured role            Primary                  Secondary
# Display detailed information about the peer-link interface and M-LAG interfaces.
<Device A>display m-lag verbose
Flags: A -- Home_Gateway, B -- Neighbor_Gateway, C -- Other_Gateway,
       D -- PeerLink_Activity, E -- DRCP_Timeout, F -- Gateway_Sync,
       G -- Port_Sync, H -- Expired
Peer-link interface/Peer-link interface ID: BAGG1/1
State: UP
Cause: -
Local DRCP flags/Peer DRCP flags: ABDFG/ABDFG
Local Selected ports (index): XGE3/0/2 (292), XGE3/0/3 (293)
Peer Selected ports indexes: 207, 208
M-LAG interface/M-LAG group ID: BAGG2/1
Local M-LAG interface state: UP
Peer M-LAG interface state: UP
M-LAG group state: UP
Local M-LAG interface down cause: -
Remaining M-LAG DOWN time: -
Local M-LAG interface LACP MAC: Config=N/A, Effective=0002-0002-0002
Peer M-LAG interface LACP MAC: Config=N/A, Effective=0002-0002-0002
Local M-LAG interface LACP priority: Config=32768, Effective=123
Peer M-LAG interface LACP priority: Config=32768, Effective=123
Local Selected ports (index): XGE3/0/5 (295)
Peer Selected ports indexes: 210
<Device A>
<Device B>disp m-lag verbose
State: UP
Cause: -
Local Selected ports (index): XGE3/0/2 (207), XGE3/0/3 (208)
Peer Selected ports indexes: 292, 293
Local Selected ports (index): XGE3/0/5 (210)
Peer Selected ports indexes: 295
Verifying the local port mirroring configuration
# Verify the local port mirroring configuration for interfaces on a device, for example, on Device A.
[Device A]display mirroring-group 1
Mirroring group 1:
    Type: Local
    Status: Active
    Mirroring port:
        Ten-GigabitEthernet3/0/5  Both
    Monitor port: Ten-GigabitEthernet3/0/15
Verifying the local flow mirroring configuration for interfaces
# Verify the flow mirroring SPAN configuration for interfaces on a device, for example, on Device A.
[Device A]display qos policy interface te 3/0/5
Interface: Ten-GigabitEthernet3/0/5
  Direction: Inbound
  Policy: test-in
   Classifier: test-ipv4-in
     Operator: AND
     Rule(s) :
      If-match acl 3000
     Behavior: mir
      Mirroring:
        Mirror to the interface: Ten-GigabitEthernet3/0/15
   Classifier: test-ipv6-in
     Operator: AND
     Rule(s) :
      If-match acl ipv6 3000
     Behavior: mir
      Mirroring:
  Direction: Outbound
  Policy: test-out
   Classifier: test-ipv4-out
     Operator: AND
     Rule(s) :
      If-match acl 3001
     Behavior: mir
      Mirroring:
 Classifier: test-ipv6-out
     Operator: AND
     Rule(s) :
      If-match acl ipv6 3001
     Behavior: mir
      Mirroring:
Verifying the local flow mirroring configuration for VLANs
# Verify the flow mirroring SPAN configuration for VLANs on a device, for example, on Device A.
[Device A]display qos vlan-policy vlan 100 inbound
Vlan 100
  Direction: Inbound
  Policy: test-in
     Operator: AND
     Rule(s) :
      If-match acl 3000
     Behavior: mir
      Mirroring:
     Operator: AND
     Rule(s) :
     Behavior: mir
      Mirroring:
Verifying the global local flow mirroring configuration
# Verify the global flow mirroring SPAN configuration on a device, for example, on Device A.
[Device A]display qos policy global inbound
  Direction: Inbound
  Policy: test-in
     Operator: AND
     Rule(s) :
      If-match acl 3000
     Behavior: mir
      Mirroring:
     Operator: AND
     Rule(s) :
     Behavior: mir
      Mirroring:
Verifying the Layer 3 remote port mirroring (ERSPAN) configuration (applicable product matrix 1)
# Verify the Layer 3 remote port mirroring (ERSPAN) configuration on Device A.
Mirroring group 1:
    Type: Local
    Status: Active
    Mirroring port:
    Monitor port: Tunnel1
[Device A]display interface Tunnel 1
Tunnel1
Current state: UP
Line protocol state: UP
Bandwidth: 64 kbps
Maximum transmission unit: 1476
Internet address: 50.1.1.1/24 (Primary)
Tunnel source 3.3.3.3 (LoopBack0), destination 5.5.5.5
Tunnel keepalive disabled
Tunnel TTL 255
Tunnel protocol/transport GRE/IP
    GRE key disabled
    Checksumming of GRE packets disabled
Last 5 seconds input rate: 0 bytes/sec, 0 bits/sec, 0 packets/sec
Last 5 seconds output rate: 0 bytes/sec, 0 bits/sec, 0 packets/sec
# Verify the Layer 3 remote port mirroring (ERSPAN) configuration on Device C.
[Device C]display mirroring-group 1
Mirroring group 1:
    Type: Local
    Status: Active
    Mirroring port:
        Ten-GigabitEthernet3/0/4  Inbound
        Ten-GigabitEthernet3/0/5  Inbound
[Device C]display interface Tunnel 1
Tunnel1
Current state: UP
Bandwidth: 64 kbps
Internet address: 50.1.1.2/24 (primary)
Tunnel source 5.5.5.5 (LoopBack0), destination 3.3.3.3
Tunnel TTL 255
    GRE key disabled
Input: 128712 packets, 16243280 bytes, 2 drops
Verifying the Layer 3 remote port mirroring (ERSPAN) configuration (applicable product matrix 2)
[DeviceA] display mirroring-group all
Mirroring group 1:
    Type: Local
    Status: Active
    Mirroring port:
    Monitor port: Ten-GigabitEthernet3/0/4
                  Encapsulation: Destination IP address 32.1.1.1
                                 Source IP address 2.1.1.2
                                 Destination MAC address 00e0-fc00-5128
Verifying the flow mirroring ERSPAN configuration
# Verify the flow mirroring ERSPAN configuration on a device, for example, on Device A.
[Device A]display qos policy interface Ten-GigabitEthernet 3/0/5
  Direction: Inbound
  Policy: test-in
     Operator: AND
     Rule(s) :
      If-match acl 3000
     Behavior: mir
      Mirroring:
        Mirror to the interface: Ten-GigabitEthernet3/0/4(dynamic)
                  Encapsulation: Destination IP address 2.1.1.2
                                 Source IP address 3.3.3.3
                                 Destination-MAC 00e0-fc00-5128
     Operator: AND
     Rule(s) :
     Behavior: mir
      Mirroring:
  Direction: Outbound
  Policy: test-out
     Operator: AND
     Rule(s) :
      If-match acl 3001
     Behavior: mir
      Mirroring:
     Operator: AND
     Rule(s) :
     Behavior: mir
      Mirroring:
Execute the commands in "Verifying the configuration" and the following commands to verify that the device is available for an upgrade.
Table 7 Command check summary before upgrade
Device A
Device B
display device
display device
Display device information.
display boot-loader
display boot-loader
Display current software images and startup software images.
display version
display version
Display system version information.
Upgrade procedure
Before you upgrade the device software, perform the following tasks:
1.     Use the display version command to verify the current BootWare image version and startup software version.
2.     Use the release notes for the upgrade software version to evaluate the upgrade impact on your network and verify the following items:
¡     Software and hardware compatibility.
¡     Version and size of the upgrade software.
¡     Compatibility of the upgrade software with the current BootWare image and startup software image.
3.     Use the release notes to identify whether the software images require a license. If licenses are required, register and activate licenses for each license-based software image. If no license exists on the device, first install a license. If you do not install a license, the software package will fail to be installed.
4.     Use the dir command to verify that the device has sufficient storage space for the upgrade images. If the storage space is not sufficient, delete unused files by using the delete command. Verify that each MPU in the system has sufficient storage space.
5.     After Device E and Device F form an M-LAG system, perform the following tasks:
a.     Check the LLDP neighbors of Device A to obtain the LLDP state information of all interfaces on Device A.
b.     Manually shut down all interfaces connecting to the other devices (except M-LAG peer-link interface and keepalive interfaces) on Device A.
c.     Switch all incoming and outgoing traffic of Device A to Device B.
6.     Save the configuration on Device A, and use FTP or TFTP to transfer the upgrade image file to the root directory of a file system. Upgrade Device A and reboot it.
7.     When Device A is being rebooted, manually shut down the interconnect interfaces connecting Device B to Device A, typically the peer-link interface and keepalive interfaces.
8.     After Device A is rebooted, bring up the interfaces that have been shut down on Device B. Wait for M-LAG to restore between Device A and Device B.
9.     After Device A and Device B form a new M-LAG system again, bring up the interfaces connecting to the other devices. Wait for the traffic to restore.
For the detailed upgrade guide, see H3C Switches M-LAG System Upgrade Guide.
Select an upgrade method according to the live network conditions.
See "Testing network convergence upon single points of failure." The upgrade downtime of each device contains the traffic downtime for restart of one M-LAG member device and recovery from M-LAG member device restart.
Execute the commands in "Verifying the configuration" and the following commands to verify that the device is upgraded successfully.
Table 8 Command check summary after upgrade
Device A
Device B
display device
display device
display boot-loader
display boot-loader
display version
display version
Execute the commands in "Verifying the configuration" and the following commands to verify that the device is available for an expansion.
Table 9 Command check summary before expansion
Device A
Device B
display device
display device
display boot-loader
display boot-loader
display version
display version
1.     Disconnect the device from network management systems.
2.     Upgrade the software of the device as needed.
3.     Configure the device.
4.     Connect the device to the management network.
N/A
Execute the following commands to verify that the device is added successfully.
Table 10 Post-expansion verification commands
Device A
Device B
display device
display device
display boot-loader
display boot-loader
display version
display version
Replacing hardware
Execute the commands in "Verifying the configuration" and the following commands to verify that the target device is available for a replacement.
Table 11 Command check summary before replacement
Device A
Device B
display device
display device
display boot-loader
display boot-loader
display version
display version
Replacing hardware
Switch service and management traffic on the target service module to other service modules.
Power off the device and replace the service module, or replace the service module when the device is running. For more information, see the installation guides for the service module.
See "Testing network convergence upon single points of failure." The replacement downtime of each interface module contains the traffic downtime for single member link failure in an M-LAG interface, single uplink failure, recovery from a single member link failure in an M-LAG interface, and recovery from a single uplink failure.
Verifying the replacement result
Execute the commands in "Checking the environment."
Pre-replacement verification commands
Execute the commands in "Verification commands" and the following commands to verify that the target device is available for a replacement.
Table 12 Command check summary before replacement
Device A
Device B
display device
display device
display boot-loader
display boot-loader
display version
display version
Replacing hardware
Power off the device and replace the switching fabric module, or replace the switching fabric module when the device is running. For more information, see the installation guides for the switching fabric module.
See "Testing network convergence upon single points of failure." The replacement downtime of each switching fabric module contains the traffic downtime for switching fabric module failure and recovery from a switching fabric module failure.
Post-replacement verification commands
