H3C Campus Switches M-LAG Configuration Guide-6W102
HomeSupportConfigure & DeployConfiguration GuidesH3C Campus Switches M-LAG Configuration Guide-6W102
06-M-LAG + VXLAN Distributed Gateway Network Configuration Example (Ethernet Aggregate Link as Peer Link) (Campus)
Example: Configuring an M-LAG + VXLAN distributed gateway network (Ethernet aggregate link as peer link) (campus)
As shown in Figure 1:
·     VTEP 1 and VTEP 2 form an M-LAG system, and they use an Ethernet aggregate link as the peer link.
·     Server A is single-homed to VTEP 1, and Server B is connected to the M-LAG system through M-LAG interfaces.
·     VTEP 1 and VTEP 2 are connected to the uplink device P through Equal-Cost Multi-Path (ECMP) routes.
·     VTEP 1, VTEP 2, and VTEP 3 are distributed VXLAN IP gateways connecting to the servers.
Configure the network to meet the following requirements:
·     Server A and Server B belong to VXLAN 10, and Server C belongs to VXLAN 20. Server A and Server B communicate with Server C in dual stack through the distributed VXLAN IP gateways.
·     When a link between the two M-LAG member devices fails, the servers can still communicate.
Figure 1 Network diagram
Device
IP address
Remarks
VTEP 1
Loopback0
1.1.1.1/32
Loopback interface address.
Interface excluded from the shutdown action by M-LAG MAD.
Loopback1
1.2.3.4/32
Tunnel source interface.
XGE 1/0/1
N/A
Server A.
Single-homed interface.
XGE 1/0/2
N/A
Server B.
M-LAG member interface.
XGE 1/0/3
N/A
VTEP 2: XGE 1/0/3.
Peer link member interface.
XGE 1/0/4
60.1.1.1/24
VTEP 2: XGE 1/0/4.
Keepalive link interface.
XGE 1/0/5
N/A
P: XGE 1/0/5.
Vlan-interface 11
11.1.1.1/24
VLAN interface connecting to device P.
Vlan-interface 2
40.94.1.1/24
Interface of the Layer 3 link connecting the two M-LAG member devices, which is used for forwarding east-west traffic or allowing north-south traffic to escape.
VSI-interface 1
10.1.1.1/24
101:10::1/64
Gateway interface of VXLAN 10.
VSI-interface 2
10.1.2.1/24
101:10::1/64
Gateway interface of VXLAN 20.
VTEP 2
Loopback0
2.2.2.2/32
Loopback1
1.2.3.4/32
XGE 1/0/2
N/A
Server B.
XGE 1/0/3
N/A
VTEP 1: XGE 1/0/3.
XGE 1/0/4
60.1.1.2/24
VTEP 1: XGE 1/0/4.
XGE 1/0/5
N/A
P: XGE 1/0/6.
Vlan-interface 12
12.1.1.2/24
Vlan-interface 2
40.94.1.2/24
VSI-interface 1
10.1.1.1/24
101:10::1/64
VSI-interface 2
10.1.2.1/24
101:10::1/64
VTEP 3
Loopback0
4.4.4.4
XGE 1/0/1
N/A
Server C.
XGE 1/0/5
N/A
P: XGE 1/0/7.
Vlan-interface 13
13.1.1.4/24
VSI-interface 1
10.1.1.1/24
101:10::1/64
VSI-interface 2
10.1.2.1/24
101:10::1/64
P
Loopback0
3.3.3.3
Router ID.
XGE 1/0/5
N/A
Leaf 1: XGE 1/0/5.
XGE 1/0/6
N/A
Leaf 2: XGE 1/0/5.
XGE 1/0/7
N/A
Leaf 3: XGE 1/0/5.
Vlan-interface 11
11.1.1.3/24
VLAN interface connecting to VTEP 1.
Vlan-interface 12
12.1.1.3/24
VLAN interface connecting to VTEP 2.
Vlan-interface 13
13.1.1.3/24
VLAN interface connecting to VTEP 3.
Applicable product matrix
In addition to running an applicable software version, you must also install the most recent patch, if any.
Device
Software version
S10500, S10500X, S7600, S7600-X, S7600E-X, S7500X, S7500E
R7625 and later
S12500G-AF (type T cards)
R7625 and later
S12500G-AF (type S cards)
R8054P04 and later
S10500X-G, S7500X-G
R7754P04 and later
S5590XP-HI-G
R7754P04 and later
Analysis
·     VTEP 1 and VTEP 2 act as M-LAG member devices, and an Ethernet aggregate link acts as the peer link.
·     VTEP 1 and VTEP 2 are connected to the uplink device P through ECMP routes.
·     Configure OSPF neighbors on the peer link between VTEP 1 and VTEP 2 to connect the single-homed services. The peer link also acts as a backup path for the network side and single-homed services.
·     On the overlay, both IPv4 and IPv6 network settings exist.
All devices in this example were started with the factory default configuration. When you are working on a live network, make sure you understand the potential impact of every command on your network.
The primary and secondary M-LAG member devices must deploy different uplink VLAN interfaces to avoid loops. As a best practice, disable the spanning tree protocol on the interfaces when making sure no physical loops exist.
On the primary and secondary M-LAG member devices, the frame match criteria of the dynamic ACs on the peer link must be the same.
·     Solution 1: Use the l2vpn m-lag peer-link ac-match-rule vxlan-mapping command to enable the device to create frame match criteria based on VXLAN IDs for the dynamic ACs on the peer link.
If an M-LAG system uses an Ethernet aggregate link as the peer link, each member device creates a dynamic AC on the peer link when an AC (Ethernet service instance) is configured on a site-facing interface. The dynamic AC and the site-facing AC have the same frame match criteria and VSI mapping. If two site-facing ACs on different interfaces have the same frame match criteria but different VSI mappings, the dynamic ACs created for the site-facing ACs will conflict with each other on the peer link. Use this command to resolve the preceding issue.
·     Solution 2: Create an AC on the peer link interface based on the frame match criteria of the site-facing Ethernet service instance.
You do not need to configure other settings. This solution is used by default.
Configuring IP addresses and unicast routing protocols
# On Server A and Server B, specify the gateway address as 10.1.1.1/101: 10::1. On Server C, specify the gateway address as 10.1.2.1/102: 10::1.
# Configure the IP address and subnet mask for each interface. (Details not shown.)
# Configure OSPF on the IP core network to advertise routes for subnets attached to the interfaces (including Loopback interfaces) on each node. Make sure the switches have connectivity to each other. As a best practice, execute the ospf peer hold-max-cost duration 300000 command on OSPF interfaces to enable OSPF to advertise the maximum link cost to neighbors within 300000 milliseconds. (Details not shown.)
Configuring M-LAG member devices
Procedure summary
·     Configuring M-LAG
·     Configuring the Layer 3 link connecting the M-LAG member devices
·     Configuring the interconnect links between the M-LAG member devices and servers
·     Configuring VXLAN
Configuring M-LAG
VTEP 1
VTEP 2
Remarks
m-lag system-mac 1-1-1
Configure the M-LAG system MAC address.
You must assign the same M-LAG system MAC address to the member devices in an M-LAG system.
m-lag system-number 1
m-lag system-number 2
Set the M-LAG system number.
You must assign different M-LAG system numbers to the member devices in an M-LAG system.
m-lag system-priority 10
Set the M-LAG system priority.
You must set the same M-LAG system priority on the member devices in an M-LAG system.
m-lag restore-delay 300
Set the data restoration interval.
This parameter specifies the maximum amount of time for the secondary M-LAG member device to synchronize data with the primary M-LAG member device during M-LAG system setup.
m-lag standalone enable
(Optional.) Enable M-LAG standalone mode.
Enable M-LAG standalone mode to avoid forwarding issues in the multi-active situation that might occur when the M-LAG system splits. Configure this feature before the M-LAG system splits.
m-lag keepalive ip destination 60.1.1.2 source 60.1.1.1
m-lag keepalive ip destination 60.1.1.1 source 60.1.1.2
Configure the destination and source IPv4 addresses of keepalive packets.
N/A
interface Ten-gigabitethernet1/0/4
Enter the interface view for the keepalive link.
N/A
port link-mode route
Configure the interface for the keepalive link to operate in route mode as a Layer 3 interface.
N/A
ip address 60.1.1.1 24
ip address 60.1.1.2 24
Configure the source IPv4 address of keepalive packets.
N/A
Return to system view.
N/A
m-lag mad exclude interface Ten-gigabitethernet1/0/4
Exclude the interface for the keepalive link from the shutdown action by M-LAG MAD.
N/A
interface bridge-aggregation 1
Create an Ethernet aggregate interface.
The interface is used as the peer link interface.
link-aggregation mode dynamic
Configure the aggregate interface of the peer link to operate in dynamic mode.
N/A
N/A
interface Ten-gigabitethernet 1/0/3
Enter the view of the physical interface for the peer link.
N/A
port link-aggregation group 1
Assign the physical interface for the peer link to the peer link aggregation group.
N/A
Quit
N/A
vlan 4094
vlan 4094
Create VLAN 4094.
N/A
N/A
Enter Ethernet aggregate interface view.
N/A
port m-lag peer-link 1
Configure Bridge-Aggregation 1 as the peer link interface.
N/A
port trunk pvid vlan 4094
Set the PVID of the trunk port to VLAN 4094.
As a best practice, set the PVID to 4094 on the peer-link interfaces. If you fail to do so, a device might set the outer VLAN ID matched by an AC to the PVID of its peer-link interface. This error will affect forwarding of the underlay traffic whose VLAN ID is VXLAN ID%4094 + 1.
undo mac-address static source-check enable
Disable source MAC check on the interface to avoid interruption of traffic forwarded at Layer 3 across the peer link.
N/A
N/A
VTEP 1
VTEP 2
Remarks
vlan 2
vlan 2
Create VLAN 2.
N/A
N/A
interface vlan-interface 2
Create VLAN-interface 2.
ip address 40.94.1.1 255.255.255.0
ip address 40.94.1.2 255.255.255.0
Assign an IPv4 address to VLAN-interface 2.
N/A
ospf 1 area 0.0.0.0
ospf 1 area 0.0.0.0
Enable OSPF on the interface.
N/A
m-lag mad exclude interface Vlan-interface 2
Exclude the VLAN interface from the shutdown action by M-LAG MAD.
N/A
VTEP 1
VTEP 2
Remarks
interface bridge-aggregation 3
Create the Ethernet aggregate interface connecting to Server B.
N/A
Configure the aggregate interface to operate in dynamic mode.
N/A
port m-lag group 2
port m-lag group 2
Assign the aggregate interface to M-LAG group 2.
N/A
N/A
interface Ten-gigabitethernet 1/0/2
Enter the view of the physical interface connecting the M-LAG system to Server B.
N/A
port link-aggregation group 3
Assign the interfaces to an M-LAG group.
N/A
N/A
monitor-link group 1
Create a monitor link group.
This feature triggers downlink switchover when an uplink fails to reduce traffic forwarded across the peer link.
port Ten-gigabitethernet 1/0/5 uplink
Configure the network-side interface as an uplink interface.
N/A
port Ten-gigabitethernet 1/0/2 downlink
Configure an M-LAG member interface as a downlink interface.
N/A
N/A
Configuring VXLAN
VTEP 1
VTEP 2
Remarks
l2vpn enable
l2vpn enable
Enable L2VPN.
N/A
interface tunnel 1 mode vxlan
Establish a VXLAN tunnel between Leaf 1/Leaf 2 and Leaf 3.
N/A
source 1.2.3.4
source 1.2.3.4
Specify the source address of the tunnel (IP address of Loopback1).
The two VTEPs in an M-LAG system must use the same tunnel source IP address to establish VXLAN tunnels to other VTEPs.
destination 4.4.4.4
destination 4.4.4.4
Specify the destination address of the tunnel (IP address of Loopback0 on VTEP 3).
N/A
N/A
vsi vpna
vsi vpna
Create VSI instance vpna.
N/A
vxlan 10
vxlan 10
Configure VXLAN 10.
N/A
tunnel 1
tunnel 1
Assign tunnel 1 to VXLAN 10.
N/A
Return to VSI view.
N/A
N/A
vsi vpnb
vsi vpnb
Create VSI instance vpnb.
N/A
vxlan 20
vxlan 20
Configure VXLAN 20.
N/A
tunnel 1
tunnel 1
Assign tunnel 1 to VXLAN 20.
N/A
Return to VSI view.
N/A
N/A
interface Ten-gigabitethernet 1/0/1
N/A
Single-homed interface connecting Leaf 1 to Server A.
N/A
service-instance 1000
N/A
Create Ethernet service instance 1000 on the interface connecting to the server.
N/A
encapsulation s-vid 2
N/A
Configure the instance to match data frames of VLAN 2.
N/A
xconnect vsi vpna
N/A
Map Ethernet service instance 1000 to VSI vpna.
N/A
N/A
Return to Ethernet interface view.
N/A
N/A
N/A
N/A
Create Ethernet service instance 1000 on interface Bridge-Aggregation 5 connecting to the server.
N/A
encapsulation s-vid 3
Configure the instance to match data frames of VLAN 3.
N/A
xconnect vsi vpna
xconnect vsi vpna
N/A
Return to Ethernet aggregate interface view.
N/A
N/A
interface vsi-interface 1
Create VSI-interface 1.
N/A
Configure an IP address, which is to be used as the gateway address of VMs in VXLAN 10.
N/A
ipv6 address 101:10::1/64
Configure an IPv6 address, which is to be used as the gateway address of VMs in VXLAN 10.
N/A
mac-address 0-0-1
mac-address 0-0-1
Assign a MAC address to the interface.
N/A
distributed-gateway local
Specify the VSI interface as a distribute gateway.
N/A
local-proxy-arp enable
Enable local proxy ARP.
N/A
local-proxy-nd enable
Enable local proxy ND.
N/A
N/A
interface vsi-interface 2
Create VSI-interface 2.
N/A
ip address 10.1.2.1 255.255.255.0
Configure an IP address, which is to be used as the gateway address of VMs in VXLAN 20.
N/A
ipv6 address 102:10::1/64
Configure an IPv6 address, which is to be used as the gateway address of VMs in VXLAN 20.
N/A
mac-address 0-0-2
mac-address 0-0-2
N/A
N/A
N/A
N/A
N/A
arp distributed-gateway dynamic-entry synchronize
Enable dynamic ARP entry synchronization for distributed VXLAN IP gateways.
When local proxy ARP is enabled on distributed VXLAN IP gateways, each gateway learns ARP information independently. A gateway does not forward ARP packets destined for its local VSI interfaces to other gateways. For distributed VXLAN IP gateways to have the same ARP entries, you must enable dynamic ARP entry synchronization.
vsi vpna
vsi vpna
Configure a VSI.
N/A
gateway vsi-interface 1
Specify VSI-interface 1 as the gateway interface for the VSI of VXLAN 10.
N/A
N/A
vsi vpnb
vsi vpnb
Configure a VSI.
N/A
gateway vsi-interface 2
Specify VSI-interface 2 as the gateway interface for the VSI of VXLAN 20.
N/A
N/A
m-lag mad exclude interface loopback 1
Exclude interface Loopback 1 from the shutdown action by M-LAG MAD.
Exclude all VXLAN interfaces from the shutdown action by M-LAG MAD.
m-lag mad exclude interface interface vsi-interface 1
Exclude VSI-interface 1 from the shutdown action by M-LAG MAD.
m-lag mad exclude interface interface vsi-interface 2
Exclude VSI-interface 2 from the shutdown action by M-LAG MAD.
m-lag mad exclude interface vlan-interface 11
m-lag mad exclude interface vlan-interface 12
Exclude the underlay VLAN interface from the shutdown action by M-LAG MAD.
Configuring VTEP 3
Procedure summary
·     Configuring VXLAN
Configuring VXLAN
VTEP 3
Remarks
l2vpn enable
Enable L2VPN.
N/A
Establish a VXLAN channel between VTEP 3 and VTEP 1 or VTEP 2.
N/A
source 4.4.4.4
Specify the source address of the tunnel (IP address of Loopback0).
N/A
destination 1.2.3.4
Specify the destination address of the tunnel (IP address of Loopback1 on VTEP 1 or VTEP 2).
N/A
vsi vpna
N/A
vxlan 10
Configure VXLAN 10.
N/A
tunnel 1
N/A
Return to VSI view.
N/A
N/A
vsi vpnb
N/A
vxlan 20
Configure VXLAN 20.
N/A
tunnel 1
N/A
Return to VSI view.
N/A
N/A
interface Ten-gigabitethernet1/0/3
Enter Ethernet interface view.
N/A
N/A
encapsulation s-vid 4
N/A
xconnect vsi vpnb
Map Ethernet service instance 1000 to VSI vpnb.
N/A
N/A
N/A
N/A
N/A
N/A
mac-address 0-0-1
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
mac-address 0-0-2
N/A
N/A
N/A
N/A
N/A
vsi vpna
Enter VSI view.
N/A
N/A
N/A
vsi vpnb
Enter VSI view.
N/A
N/A
N/A
Traffic model
About the traffic model
The traffic model contains the following information:
·     ID—Traffic ID, in O-X-XXX format. The first segment (O) represents overlay traffic. The second segment (X) represents the IP version (4 for IPv4 and 6 for IPv6). The third segment (XXX) represents a unique number for the traffic.
·     Type—Traffic type, such as known unicast/IPv4 and unicast/L2.
·     Direction—Traffic direction, such as inter-leaf east-west traffic and north-south traffic.
·     Path—The nodes that the traffic traverses from the source to the destination.
·     Simulation method—Traffic simulation method. Testers are used to simulate the patterns of traffic on the network set up in this example.
·     Simulation traffic load—The network can be tested under light load (fewer than 1000 simulation traffic flows) or heavy load (more than 1000 simulation traffic flows).
Overlay traffic
ID
Direction
Path
Simulation method
Traffic direction to firewalls/LBs
Remarks
O-4-001
Known unicast/IPv4
Inter-VTEP east-west traffic
Server A-VTEP 1-P-VTEP 3-Server C
Tester
Light
N/A
When the uplink interface fails, traffic is forwarded along the Layer 3 link between M-LAG member devices
O-4-002
Known unicast/IPv4
Server B-VTEP 1&2-P-VTEP 3-Server C
Tester
Light
N/A
When an uplink interface fails, the monitor link group shuts down the corresponding downlink interface and forwards all traffic through the peer device.
O-6-001
Known unicast/IPv6
Tester
Light
N/A
O-6-002
Known unicast/IPv6
Tester
Light
N/A
Convergence performance test results
Failure test results
Table 1 Link failure test results
Device
Failure cause
Traffic downtime
Remarks
VTEP 1
Single member link failure in an M-LAG interface
≤ 500 ms
N/A
Recovery from a single M-LAG interface member link failure
≤ 200 ms
N/A
Single uplink failure
≤ 500 ms
N/A
Recovery from a single uplink failure
≤ 200 ms
N/A
Complete peer link failure
≤ 500 ms
Focus on M-LAG interface services. Single-homed interface services are not assured.
Recovery from a complete peer link failure
≤ 200 ms
Focus on M-LAG interface services. Single-homed interface services can recover.
Keepalive link failure
0 ms
N/A
Recovery from a keepalive link failure
0 ms
N/A
Keepalive link and peer link failure
≤ 4000 ms
Recovery from a keepalive link and peer link failure
≤ 4000 ms
Restart of one M-LAG member device
≤ 500 ms
Recover from M-LAG member device restart
≤ 200 ms
Switching fabric module failure
≤ 100 ms
N/A
Recovery from a switching fabric module failure
≤ 100 ms
N/A
Verification commands
Table 2 Verification commands
VTEP 1
VTEP 2
display interface tunnel
Displays tunnel interface information.
display l2vpn vsi
display l2vpn vsi
Displays VSI information.
1.     Verify that the VXLANs of the M-LAG system are normal.
# On VTEP 1, view tunnel interface information to verify that the VXLAN tunnel is up. The source address of the tunnel is 1.2.3.4.
[VTEP 1]display interface tunnel
Tunnel1
Current state: UP
Line protocol state: UP
Bandwidth: 64 kbps
Tunnel source 1.2.3.4, destination 4.4.4.4
Last 300 seconds output rate: 50506 bytes/sec, 404048 bits/sec, 295 packets/sec
Input: 4 packets, 240 bytes, 0 drops
Output: 257011 packets, 43395523 bytes, 0 drops
# View the VSI information on VTEP 1 to verify that ACs are automatically created on the peer link and they are associated with VSIs.
[VTEP 1] display l2vpn vsi name vpna verbose
VSI Name: vpna
  VSI Index               : 0
  VSI State               : Up
  Bandwidth               : -
  Broadcast Restrain      : 5120 kbps
  Multicast Restrain      : 5120 kbps
  Unknown Unicast Restrain: 5120 kbps
  MAC Table Limit         : -
  MAC Learning rate       : Unlimited
  Drop Unknown            : Disabled
  Statistics              : Disabled
  Gateway Interface       : VSI-interface 1
  VXLAN ID                : 10
  Tunnels:
    Tunnel Name          Link ID    State    Type        Flood proxy
    Tunnel1              0x5000001  UP       Manual      Disabled
  ACs:
    AC                                 Link ID    State       Type
    XGE1/0/1 srv1000                   0          Up          Manual
    BAGG1 srv1                         1          Up          Dynamic (M-LAG)
    BAGG3 srv1000                      2          Up          Manual
# On VTEP 3, view tunnel interface information to verify that the VXLAN tunnel is up.
[VTEP 3]display interface tunnel
Tunnel1
Current state: UP
Bandwidth: 64 kbps
Tunnel source 4.4.4.4, destination 1.2.3.4
Input: 8 packets, 480 bytes, 0 drops
Output: 4 packets, 240 bytes, 0 drops
# On VTEP 3, display VSI information to view the VXLANs created in VSIs, VXLAN tunnels associated with VXLANs, and VSI interfaces associated with VSIs.
[VTEP 3] display l2vpn vsi verbose
VSI Name: vpna
  VSI Index               : 0
  VSI State               : Up
  Bandwidth               : -
  MAC Table Limit         : -
  VXLAN ID                : 10
  Tunnels:
VSI Name: vpnb
  VSI Index               : 1
  VSI State               : Up
  MTU                     : 1500
  Bandwidth               : -
  MAC Table Limit         : -
  Gateway Interface       : VSI-interface 2
  VXLAN ID                : 20
  Tunnels:
ACs:
    XGE1/0/3 srv1000                   0          Up          Manual
2.     Verify that Server A/Server B can normally communicate with Server C.
3.     Verify that traffic can still be forwarded between Server B and Server C when the downlink M-LAG member interface of VTEP 1 or VTEP 2 fails.
Transient packet loss might occur during the switchover process.
4.     Verify that traffic can still be forwarded between Server A/Server B and Server C when the uplink interface of VTEP 1 or VTEP 2 fails.
Upgrade procedure
Pre-upgrade verification commands
Before you perform an upgrade, use the commands in “Verifying the configuration” and the commands in the following table to verify that all requirements are met for an upgrade.
Table 3 Pre-upgrade verification commands
VTEP 1
VTEP 2
display device
display device
Displays summary information about the peer-link interfaces and M-LAG interfaces in the M-LAG system.
display boot-loader
display boot-loader
Displays the current software images and startup software images.
display version
display version
Displays system version information.
Upgrade procedure
To upgrade software:
1.     Execute the display version command to verify the current BootWare image version and startup software version.
2.     Use the release notes for the upgrade software version to evaluate the upgrade impact on your network and verify the following items:
¡     Software and hardware compatibility.
¡     Version and size of the upgrade software.
¡     Compatibility of the upgrade software with the current BootWare image and startup software image.
3.     Use the release notes to verify whether the upgrade software images require a license. If licenses are required, check the system for availability of valid licenses. If no license exists on the device, first install a license. If you do not install a license, the software package will fail to be installed.
4.     Use the dir command to verify that the device has sufficient storage space for the upgrade images. If the storage space is not sufficient, delete unused files by using the delete command. Make sure all MPUs in the system have sufficient storage space.
5.     After VTEP 1 and VTEP 2 form an M-LAG system, perform the following tasks:
a.     Check the LLDP neighbors of VTEP 1 to obtain the LLDP state information of all interfaces on VTEP 1.
b.     Manually shut down all interfaces connecting to the other devices (except M-LAG peer link interfaces and keepalive interfaces) on VTEP 1 to switch all incoming and outgoing traffic of VTEP 1 to VTEP 2.
6.     Save the configuration on VTEP 1, and use FTP or TFTP to transfer the upgrade image file to the root directory of a file system. Upgrade VTEP 1 and reboot it.
7.     When VTEP 1 is being rebooted, manually shut down the interfaces connecting VTEP 2 to VTEP 1. The interfaces are typically peer link interfaces and keepalive interfaces.
8.     After VTEP 1 is rebooted, bring up the interfaces that have been shut down on VTEP 2. Wait for M-LAG to restore between VTEP 1 and VTEP 2.
9.     After VTEP 1 and VTEP 2 form an M-LAG system again, bring up the interfaces connecting to other devices. Wait for the traffic to restore.
For more information about upgrading software on an M-LAG system, see H3C Switches M-LAG System Upgrade Guide.
Upgrade the software. For more information about the software upgrade procedure, see the fundamentals configuration guide for the device.
Estimated upgrade downtime
See “Convergence performance test results.” The upgrade downtime of each device contains the traffic downtime for restart of one M-LAG member device and recovery from M-LAG member device restart.
Post-upgrade verification commands
After the upgrade finishes, use the commands in “Verifying the configuration” and the commands in the following table to verify that the upgrade has been done correctly.
Table 4 Post-upgrade verification commands
VTEP 1
VTEP 2
display device
display device
display boot-loader
display boot-loader
display version
display version
Node expansion
Pre-expansion verification commands
Before you perform a node expansion, use the commands in “Verifying the configuration” and the commands in the following table to verify that all requirements are met for an expansion.
Table 5 Pre-expansion verification commands
VTEP 1
VTEP 2
display device
display device
Displays summary information about the peer link interfaces and M-LAG interfaces in the M-LAG system.
display boot-loader
display boot-loader
display version
display version
Node expansion
1.     Make sure the expansion device is not connected to the management network.
2.     Upgrade the device to the target software version.
3.     Configure the device.
4.     Connect the device to the management network.
Estimated expansion downtime
N/A
Post-expansion verification commands
After the expansion finishes, use the commands in the following table to verify that the expansion has been done correctly.
Table 6 Post-expansion verification commands
VTEP 1
VTEP 2
display device
display device
display boot-loader
display boot-loader
display version
display version
Replacement procedure
Service module replacement
Pre-replacement verification commands
Execute the commands in “Verifying the configuration” and the following commands to verify that all requirements are met for a replacement.
Table 7 Pre-replacement verification commands
VTEP 1
VTEP 2
display device
display device
Displays device information
display boot-loader
display boot-loader
display version
display version
Before you replace an interface module, make sure the service and management traffic has switched over to other interface modules that are operating correctly.
Replace the interface modules online while the system is operating or power off the system before you do the replacement, depending on the evaluation of the conditions.
Estimated replacement downtime
See “Convergence performance test results.” The replacement downtime of each interface module contains the traffic downtime for single member link failure in an M-LAG interface, single uplink failure, recovery from a single member link failure in an M-LAG interface, and recovery from a single uplink failure.
Post-replacement verification commands
Use the same commands for pre-replacement verification to verify that the system can operate correctly after the hardware replacement.
Switching fabric module replacement
Table 8 Pre-replacement verification commands
VTEP 1
VTEP 2
display device
display device
display boot-loader
display boot-loader
display version
display version
Replace the switching fabric module online while the system is operating or power off the system before you do the replacement, depending on the evaluation of the conditions.
See “Convergence performance test results.” The replacement downtime of each switching fabric module contains the traffic downtime for switching fabric module failure and recovery from a switching fabric module failure.
