| 02-HH3C-FLASH-MAN-MIB | 67.17 KB |
HH3C-FLASH-MAN-MIB
About this MIB
Use this MIB to obtain information about storage media, partitions, and files as well as manage files on the storage media.
MIB file name
hh3c-flash-man.mib
Notifications
hh3cFlhOperNotification
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.5.1.3.1 |
A file operation completed. |
Informational |
Warning |
N/A |
ON |
Notification triggers
This notification is generated when a file operation completes if the value of hh3cFlhOperEndNotification is true.
The parameters included in this notification vary by file operation. For more information, see the online help for the NMS.
System impact
No impact on the system.
Status control
ON
MIB: Set hh3cFlhOperEndNotification to true(1).
OFF
MIB: Set hh3cFlhOperEndNotification to false(2).
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.5.1.2.1.1.9 (hh3cFlhOperStatus) |
File operation status. |
N/A |
Hh3cFlashOperationStatus |
opInProgress(1) opSuccess(2) opInvalid(3) opInvalidProtocol(4) opInvalidSourceName(5) opInvalidDestName(6) opInvalidServerAddress(7) opDeviceBusy(8) opDeviceOpenError(9) opDeviceError(10) opDeviceNotProgrammable(11) opDeviceFull(12) opFileOpenError(13) opFileTransferError(14) opFileChecksumError(15) opNoMemory(16) opAuthFail(17) opTimeout(18) opUnknownFailure(19) opDeleteFileOpenError(20) opDeleteInvalidDevice(21) opDeleteInvalidFunction(22) opDeleteOperationError(23) opDeleteInvalidFileName(24) opDeleteDeviceBusy(25) opDeleteParaError(26) opDeleteInvalidPath(27) opDeleteFileNotExistInSlave(28) opDeleteFileFailedInSlave(29) opSlaveFull(30) opCopyToSlaveFailure(31) |
Recommended action
· If the operation finishes successfully, no action is required.
· If the operation fails, handle the issue according to the failure reason. If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
hh3cFlhUsageOverThreshold
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.5.1.4.0.1 |
Disk usage exceeded the threshold |
Informational |
Minor |
1.3.6.1.4.1.25506.2.5.1.4.0.2 (hh3cFlhUsageResume) |
ON |
This notification is generated when the disk usage exceeds the threshold.
System impact
Insufficient disk space might cause failure of file operations that require more disk space, such as transferring, downloading, and loading image files.
Status control
This notification cannot be disabled.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.5.1.5.1 (hh3cFlhUsageRate) |
Current disk usage. |
N/A. |
Integer32 |
Standard MIB values. |
1.3.6.1.4.1.25506.2.5.1.5.2 (hh3cFlhUsageRateThreshold) |
Disk usage threshold. |
N/A. |
Integer32 |
1.3.6.1.4.1.25506.2.5.1.5.3 (hh3cFlhNameForTrap) |
Disk name |
N/A. |
DisplayString |
Recommended action
Delete unnecessary disk files.
Collect alarm information and configuration data, and then contact H3C Support.
hh3cFlhUsageResume
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.5.1.4.0.2 |
Disk usage restored to normal |
Informational |
Warning |
N/A |
ON |
This notification is generated when the disk usage restores to normal.
System impact
No negative impact on the system.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Current disk usage |
N/A. |
Integer32 |
N/A. |
Integer32 |
Disk name |
N/A. |
DisplayString |
Recommended action
No action is required.
