02-HH3C-LswINF-MIB | 162.29 KB |
hh3cSlotPortMax (1.3.6.1.4.1.25506.8.35.5.1.1)
hh3cSwitchPortMax (1.3.6.1.4.1.25506.8.35.5.1.2)
hh3cIsolateGroupMax (1.3.6.1.4.1.25506.8.35.5.1.5)
hh3cMaxMacLearnRange (1.3.6.1.4.1.25506.8.35.5.1.12)
HH3C-LswINF-MIB
About this MIB
Use this MIB to manage interfaces.
An isolation group either can have only one uplink port or does not have any uplink port. You can create an isolation group, specify an uplink port for the group, add member ports to the group, and then remove the uplink port.
Speed autonegotiation allows an interface to operate at the possible fastest speed. You can set the speed modes that an interface can automatically negotiated with the peer interface to meet various speed requirements.
MIB file name
hh3c-splat-inf.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cRhw(8).hh3clswCommon(35) .hh3cLswL2InfMib(5)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSlotPortMax (1.3.6.1.4.1.25506.8.35.5.1.1) |
read-only |
INTEGER |
1..65535 |
Maximum number of ports on a slot. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSwitchPortMax (1.3.6.1.4.1.25506.8.35.5.1.2) |
read-only |
INTEGER |
1..65535 |
Maximum number of ports on the switch. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIsolateGroupMax (1.3.6.1.4.1.25506.8.35.5.1.5) |
read-only |
Integer32 |
Integer32(1..2147483647) |
Maximum number of isolation groups supported by the switch. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMaxMacLearnRange (1.3.6.1.4.1.25506.8.35.5.1.12) |
read-only |
Integer32 |
Maximum number of MAC addresses supported by an interface. |
Implementation varies by product. |
Tabular objects
hh3cifXXTable
About this table
This table contains extended information for an interface.
Support for operations
Create:Not supported
Edit/Modify:Not supported
Delete:Not supported
Read:Supported
Columns
The table index is hh3cifUnBoundPort.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cifMirrorPort (1.3.6.1.4.1.25506.8.35.1.1.1.4) |
read-write |
TruthValue |
true(1), false(2) |
Whether the interface is a mirroring interface. |
Not supported. When read, this object returns false. |
hh3cifVLANType (1.3.6.1.4.1.25506.8.35.1.1.1.5) |
read-write |
INTEGER |
vLANTrunk(1), access(2), hybrid(3), fabric(4) |
VLAN type of the interface. |
Value fabric(4) is not supported. |
hh3cifMcastControl (1.3.6.1.4.1.25506.8.35.1.1.1.6) |
read-write |
INTEGER |
INTEGER (0..100) |
Multicast suppression threshold. |
hh3cifFlowControl (1.3.6.1.4.1.25506.8.35.1.1.1.7) |
read-write |
TruthValue |
true(1), false(2) |
Flow control status on the interface. |
As per the MIB. |
hh3cifClearStat (1.3.6.1.4.1.25506.8.35.1.1.1.9) |
read-write |
INTEGER |
clear(1) |
Clear packet statistics on the interface. |
Supports only the read operation. |
hh3cifXXBasePortIndex (1.3.6.1.4.1.25506.8.35.1.1.1.10) |
read-only |
INTEGER |
INTEGER |
Index of the interface. |
As per the MIB. |
hh3cifXXDevPortIndex (1.3.6.1.4.1.25506.8.35.1.1.1.11) |
read-only |
INTEGER |
INTEGER |
As per the MIB. |
hh3cifPpsMcastControl (1.3.6.1.4.1.25506.8.35.1.1.1.12) |
read-write |
Integer32 |
Integer32 (-2147483648..2147483647) |
Multicast suppression threshold in pps. |
As per the MIB. |
hh3cifUniSuppression (1.3.6.1.4.1.25506.8.35.1.1.1.18) |
read-write |
Integer32 |
Unicast suppression threshold in percentage. |
hh3cifPpsUniSuppression (1.3.6.1.4.1.25506.8.35.1.1.1.19) |
read-write |
Integer32 |
Unicast suppression threshold in pps. |
As per the MIB. |
hh3cifMulSuppression (1.3.6.1.4.1.25506.8.35.1.1.1.20) |
read-write |
Integer32 |
Multicast suppression threshold in percentage. |
hh3cifPpsMulSuppression (1.3.6.1.4.1.25506.8.35.1.1.1.21) |
read-write |
Integer32 |
As per the MIB. |
hh3cifMulSuppressionFlag (1.3.6.1.4.1.25506.8.35.1.1.1.41) |
read-write |
INTEGER |
all(1), unknown(2) |
Flag of multicast suppression. |
As per the MIB. |
hh3cifHybridPortTable
About this table
This table contains hybrid interface information.
Read:Supported
Columns
The table index is hh3cifHybridPortIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cifHybridPortIndex (1.3.6.1.4.1.25506.8.35.1.3.1.1) |
read-only |
INTEGER |
INTEGER |
Index of a hybrid interface. |
As per the MIB. |
hh3cifHybridTaggedVlanListLow (1.3.6.1.4.1.25506.8.35.1.3.1.2) |
read-write |
OCTET STRING |
OCTET STRING (0..256) |
Per-bit representation of tagged VLANs (in the range of VLAN 1 to VLAN 2048). Each bit in an octet represents a VLAN. If a bit is set to 1, the VLAN represented by this bit is a tagged VLAN. |
As per the MIB. |
hh3cifHybridTaggedVlanListHigh (1.3.6.1.4.1.25506.8.35.1.3.1.3) |
read-write |
OCTET STRING |
Per-bit representation of tagged VLANs (in the range of VLAN 2049 to VLAN 4094). Each bit in an octet represents a VLAN. If a bit is set to 1, the VLAN represented by this bit is a tagged VLAN. |
As per the MIB. |
hh3cifHybridUnTaggedVlanListLow (1.3.6.1.4.1.25506.8.35.1.3.1.4) |
read-write |
OCTET STRING |
Per-bit representation of untagged VLANs (in the range of VLAN 1 to VLAN 2048). Each bit in an octet represents a VLAN. If a bit is set to 1, the VLAN represented by this bit is an untagged VLAN. |
As per the MIB. |
hh3cifHybridUnTaggedVlanListHigh (1.3.6.1.4.1.25506.8.35.1.3.1.5) |
read-write |
OCTET STRING |
Per-bit representation of untagged VLANs (in the range of VLAN 2049 to VLAN 4094). Each bit in an octet represents a VLAN. If a bit is set to 1, the VLAN represented by this bit is an untagged VLAN. |
As per the MIB. |
hh3cifPktBufTable
About this table
This table contains packet buffer information for an interface.
Read:Supported
Columns
The table index is hh3cifPktBufFree.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cifPktBufFree (1.3.6.1.4.1.25506.8.35.1.5.1.1) |
read-only |
Integer32 |
Size of the available packet buffer for an interface. |
As per the MIB. |
hh3cifPktBufInit (1.3.6.1.4.1.25506.8.35.1.5.1.2) |
read-only |
Integer32 |
Number of packet buffers allocated to the interface when the interface was created. |
As per the MIB. |
hh3cifPktBufMin (1.3.6.1.4.1.25506.8.35.1.5.1.3) |
read-only |
Integer32 |
Minimum number of packet buffers allocated to the interface. |
As per the MIB. |
hh3cifPktBufMiss (1.3.6.1.4.1.25506.8.35.1.5.1.4) |
read-only |
Counter64 |
Counter64 (0..18446744073709551615) |
Number of times that the interface failed to obtain a packet buffer before dropping the packet. |
As per the MIB. |
hh3cifPktBufInDrop (1.3.6.1.4.1.25506.8.35.1.5.1.5) |
read-only |
Counter64 |
Number of incoming packets dropped by the interface because of insufficient data buffer. |
As per the MIB. |
hh3cifPktBufEgDrop (1.3.6.1.4.1.25506.8.35.1.5.1.6) |
read-only |
Counter64 |
Number of outgoing packets dropped by the interface because of insufficient data buffer. |
As per the MIB. |
hh3cifQueuePktBufTable
About this table
This table contains packet buffer queue information for an interface.
Read:Supported
Columns
The table index is hh3cifQueueId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cifQueueId (1.3.6.1.4.1.25506.8.35.1.6.1.1) |
read-only |
Integer32 |
Integer32(1..8) |
ID of a packet buffer queue. |
As per the MIB. |
hh3cifQueuePktBufTotal (1.3.6.1.4.1.25506.8.35.1.6.1.2) |
read-only |
Unsigned32 |
Unsigned32 |
Number of packet buffers for the queue. |
As per the MIB. |
hh3cifQueueBufUsed (1.3.6.1.4.1.25506.8.35.1.6.1.3) |
read-only |
Unsigned32 |
Unsigned32 |
Number of packet buffers used by the queue. |
As per the MIB. |
hh3cifQueueBufThreCount (1.3.6.1.4.1.25506.8.35.1.6.1.4) |
read-only |
Counter32 |
Counter32 |
Number of times that a queue of the interface has exceeded the threshold. |
As per the MIB. |
hh3cifQueueBufUsageIn5Seconds (1.3.6.1.4.1.25506.8.35.1.6.1.5) |
read-only |
Integer32 |
Integer32(0..100) |
Buffer usage in the most recent 5 seconds for the queue. |
As per the MIB. |
hh3cifQueueBufUsageIn1Minute (1.3.6.1.4.1.25506.8.35.1.6.1.6) |
read-only |
Integer32 |
Integer32(0..100) |
Buffer usage in the most recent 1 minute for the queue. |
As per the MIB. |
hh3cifQueueBufUsageIn5Minutes (1.3.6.1.4.1.25506.8.35.1.6.1.7) |
read-only |
Integer32 |
Integer32(0..100) |
Buffer usage in the most recent 5 minutes for the queue. |
As per the MIB. |
hh3cifVLANTrunkStatusTable
About this table
This table contains GVRP attributes for a trunk port.
Read:Supported
Columns
The table index is hh3cifVLANTrunkIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cifVLANTrunkIndex (1.3.6.1.4.1.25506.8.35.5.1.3.1.1) |
read-only |
INTEGER |
INTEGER |
Index of a trunk port. |
As per the MIB. |
hh3cifVLANTrunkPassListLow (1.3.6.1.4.1.25506.8.35.5.1.3.1.4) |
read-only |
OCTET STRING |
Per-bit representation of permitted VLANs (in the range of VLAN 1 to VLAN 2048) on the port. Each bit in an octet represents a VLAN. If a bit is set to 1, the VLAN represented by this bit is a trunked VLAN. |
As per the MIB. |
hh3cifVLANTrunkPassListHigh (1.3.6.1.4.1.25506.8.35.5.1.3.1.5) |
read-only |
OCTET STRING |
Per-bit representation of permitted VLANs (in the range of VLAN 2049 to VLAN 4094) on the port. Each bit in an octet represents a VLAN. If a bit is set to 1, the VLAN represented by this bit is a trunked VLAN. |
As per the MIB. |
hh3cifVLANTrunkAllowListLow (1.3.6.1.4.1.25506.8.35.5.1.3.1.6) |
read-write |
OCTET STRING |
You must specify this object and hh3cifVLANTrunkAllowListHigh in pairs in an SNMP request. |
hh3cifVLANTrunkAllowListHigh (1.3.6.1.4.1.25506.8.35.5.1.3.1.7) |
read-write |
OCTET STRING |
You must specify this object and hh3cifVLANTrunkAllowListLow in pairs in an SNMP request. |
hh3cethernetTable
About this table
This table contains Layer 2 interface settings.
Read:Supported
Columns
The table index is hh3cifEthernetDuplex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cifEthernetDuplex (1.3.6.1.4.1.25506.8.35.5.1.4.1.3) |
read-write |
INTEGER |
full(1), half(2), auto(3) |
Duplex mode of an interface. |
Values half and auto are supported only when the interface operates at a speed higher than 1000 Mbps or is connected to a fiber connector. Layer 3 interfaces do not support write operation. |
hh3cifEthernetMTU (1.3.6.1.4.1.25506.8.35.5.1.4.1.4) |
read-write |
INTEGER |
1..65535 |
MTU of the interface. |
Only interfaces that operate in Layer 2 mode or allow jumbo frames to pass through support write operation. Implementation varies by product. When write, value 1 indicates to set the maximum value in the value range. Value 2 indicates to set the minimum value in the value range. |
hh3cifEthernetSpeed (1.3.6.1.4.1.25506.8.35.5.1.4.1.5) |
read-write |
INTEGER |
auto(0), s10M(10), s100M(100), s1000M(1000), s2500M(2500), s5000M(5000), s10000M(10000), s24000M(24000), s40000M(40000), s20000M(20000), s25000M(25000), s50000M(50000), s100000M(100000) |
Speed of the interface. |
Ethernet interfaces do not support values s1000 and higher. GE interfaces do not support values s10000 and higher. |
hh3cifEthernetMdi (1.3.6.1.4.1.25506.8.35.5.1.4.1.7) |
read-write |
INTEGER |
mdi-ii(1), mdi-x(2), mdi-auto(3) |
MDI type of the interface. |
GE, XGE, 20GE, 25GE, 40GE, 50GE, and 100GE interfaces that connect to fiber connectors do not support write operation. |
hh3cMaxMacLearn (1.3.6.1.4.1.25506.8.35.5.1.4.1.8) |
read-write |
INTEGER |
-1..2147483647 |
Maximum number of MAC addresses that the interface can learn. |
The value of this object must be smaller than the maximum number of MAC addresses supported on the interface. |
hh3cifMacAddressLearn (1.3.6.1.4.1.25506.8.35.5.1.4.1.9) |
read-only |
INTEGER |
enabled(1), disabled(2) |
Enabling status of MAC address learning on the interface. |
As per the MIB. |
hh3cifEthernetFlowInterval (1.3.6.1.4.1.25506.8.35.5.1.4.1.12) |
read-write |
INTEGER |
5..300 |
Flow interval of the interface. |
hh3cifIsolateGroupID (1.3.6.1.4.1.25506.8.35.5.1.4.1.17) |
read-write |
Integer32 |
ID of the isolation group to which the interface belongs. |
Value 0 indicates that the interface does not belong to any isolation group. |
hh3cifEthernetAutoSpeedMask (1.3.6.1.4.1.25506.8.35.5.1.4.1.19) |
read-only |
SpeedModeFlagBITS |
BITS{ s10M(0), s100M(1), s1000M(2), s10000M(3), s24000M(4), s40000M(5), s100000M(6), s2500M(7), s5000M(8), s20000M(9), s25000M(10), s50000M(11) } |
Speed modes that can be negotiated |
As per the MIB. |
hh3cifEthernetAutoSpeed (1.3.6.1.4.1.25506.8.35.5.1.4.1.20) |
read-write |
SpeedModeFlagBITS |
Speed modes that are negotiable on this port |
As per the MIB. |
hh3cPortIsolateGroupTable
About this table
This table contains isolation group settings.
Edit/Modify:Supported
Delete:Supported
Read:Supported
Columns
The table index is hh3cPortIsolateGroupIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPortIsolateGroupIndex (1.3.6.1.4.1.25506.8.35.5.1.11.1.1) |
not-accessible |
Integer32 |
Index of an isolation group. |
As per the MIB. |
hh3cPortIsolateGroupRowStatus (1.3.6.1.4.1.25506.8.35.5.1.11.1.3) |
read-create |
INTEGER |
INTEGER |
Row status. |
Supports only the following values: createAndGo, destroy, and active. Isolation group is available only when the row is in active status. You can set this object only when the device supports multiple isolation groups. |
hh3cifPortProtocolStatTable
About this table
This table contains IPv4 and IPv6 packet statistics for an interface.
Read:Supported
Columns
The table index is hh3cifIPv4InOctets.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cifIPv4InOctets (1.3.6.1.4.1.25506.8.35.5.1.13.1.1) |
read-only |
Counter64 |
Number of octets in IPv4 packets received on an interface. |
As per the MIB. |
hh3cifIPv4InUcastPkts (1.3.6.1.4.1.25506.8.35.5.1.13.1.2) |
read-only |
Counter64 |
Number of IPv4 unicast packets received on the interface. |
As per the MIB. |
hh3cifIPv4InMultiPkts (1.3.6.1.4.1.25506.8.35.5.1.13.1.3) |
read-only |
Counter64 |
Number of IPv4 multicast packets received on the interface. |
As per the MIB. |
hh3cifIPv4InBroadcastPkts (1.3.6.1.4.1.25506.8.35.5.1.13.1.4) |
read-only |
Counter64 |
Number of IPv4 broadcast packets received on the interface. |
As per the MIB. |
hh3cifIPv4InDiscards (1.3.6.1.4.1.25506.8.35.5.1.13.1.5) |
read-only |
Counter64 |
Number of incoming IPv4 packets dropped by the interface. |
As per the MIB. |
hh3cifIPv4InErrors (1.3.6.1.4.1.25506.8.35.5.1.13.1.6) |
read-only |
Counter64 |
Number of incoming IPv4 error packets on the interface. |
As per the MIB. |
hh3cifIPv4OutOctets (1.3.6.1.4.1.25506.8.35.5.1.13.1.7) |
read-only |
Counter64 |
Number of IPv4 packets transmitted by the interface. |
As per the MIB. |
hh3cifIPv4OutUcastPkts (1.3.6.1.4.1.25506.8.35.5.1.13.1.8) |
read-only |
Counter64 |
Number of IPv4 unicast packets transmitted by the interface. |
As per the MIB. |
hh3cifIPv4OutMultiPkts (1.3.6.1.4.1.25506.8.35.5.1.13.1.9) |
read-only |
Counter64 |
Number of IPv4 multicast packets transmitted by the interface. |
As per the MIB. |
hh3cifIPv4OutBroadcastPkts (1.3.6.1.4.1.25506.8.35.5.1.13.1.10) |
read-only |
Counter64 |
Number of IPv4 broadcast packets transmitted by the interface. |
As per the MIB. |
hh3cifIPv4OutDiscards (1.3.6.1.4.1.25506.8.35.5.1.13.1.11) |
read-only |
Counter64 |
Number of outgoing IPv4 packets transmitted by the interface. |
As per the MIB. |
hh3cifIPv4OutErrors (1.3.6.1.4.1.25506.8.35.5.1.13.1.12) |
read-only |
Counter64 |
Number of outgoing IPv4 error packets transmitted by the interface. |
As per the MIB. |
hh3cifIPv6InOctets (1.3.6.1.4.1.25506.8.35.5.1.13.1.13) |
read-only |
Counter64 |
Number of octets in IPv6 packets received on an interface. |
As per the MIB. |
hh3cifIPv6InUcastPkts (1.3.6.1.4.1.25506.8.35.5.1.13.1.14) |
read-only |
Counter64 |
Number of IPv6 unicast packets received on the interface. |
As per the MIB. |
hh3cifIPv6InMultiPkts (1.3.6.1.4.1.25506.8.35.5.1.13.1.15) |
read-only |
Counter64 |
Number of IPv6 multicast packets received on the interface. |
As per the MIB. |
hh3cifIPv6InAnycastPkts (1.3.6.1.4.1.25506.8.35.5.1.13.1.16) |
read-only |
Counter64 |
Number of IPv6 broadcast packets received on the interface. |
As per the MIB. |
hh3cifIPv6InDiscards (1.3.6.1.4.1.25506.8.35.5.1.13.1.17) |
read-only |
Counter64 |
Number of incoming packets dropped by the interface. |
As per the MIB. |
hh3cifIPv6InErrors (1.3.6.1.4.1.25506.8.35.5.1.13.1.18) |
read-only |
Counter64 |
Number of incoming error packets received on the interface. |
As per the MIB. |
hh3cifIPv6OutOctets (1.3.6.1.4.1.25506.8.35.5.1.13.1.19) |
read-only |
Counter64 |
Number of octets in IPv6 packets transmitted by the interface. |
As per the MIB. |
hh3cifIPv6OutUcastPkts (1.3.6.1.4.1.25506.8.35.5.1.13.1.20) |
read-only |
Counter64 |
Number of IPv6 unicast packets transmitted by the interface. |
As per the MIB. |
hh3cifIPv6OutMultiPkts (1.3.6.1.4.1.25506.8.35.5.1.13.1.21) |
read-only |
Counter64 |
Number of IPv6 multicast packets transmitted by the interface. |
As per the MIB. |
hh3cifIPv6OutAnycastPkts (1.3.6.1.4.1.25506.8.35.5.1.13.1.22) |
read-only |
Counter64 |
Number of IPv6 broadcast packets transmitted by the interface. |
As per the MIB. |
hh3cifIPv6OutDiscards (1.3.6.1.4.1.25506.8.35.5.1.13.1.23) |
read-only |
Counter64 |
Number of outgoing packets dropped by the interface. |
As per the MIB. |
hh3cifIPv6OutErrors (1.3.6.1.4.1.25506.8.35.5.1.13.1.24) |
read-only |
Counter64 |
Number of outgoing error packets received on the interface. |
As per the MIB. |
