02-HH3C-CBQOS2-MIB | 199.33 KB |
hh3cCBQoSClassifierIndexNext (1.3.6.1.4.1.25506.2.65.2.1.1.1)
hh3cCBQoSBehaviorIndexNext (1.3.6.1.4.1.25506.2.65.2.1.2.1)
hh3cCBQoSPolicyIndexNext (1.3.6.1.4.1.25506.2.65.2.1.3.1)
hh3cCBQoSApplyingStatus (1.3.6.1.4.1.25506.2.65.2.1.6.1)
hh3cCBQoSChassis (1.3.6.1.4.1.25506.2.65.2.1.8.1)
hh3cCBQoSSlot (1.3.6.1.4.1.25506.2.65.2.1.8.2)
hh3cCBQoSCPU (1.3.6.1.4.1.25506.2.65.2.1.8.3)
hh3cCBQoSDirection (1.3.6.1.4.1.25506.2.65.2.1.8.4)
hh3cCBQoSRedirectAlarmBehaviorName (1.3.6.1.4.1.25506.2.65.2.1.8.5)
hh3cCBQoSRedirectAlarmProtoFamily (1.3.6.1.4.1.25506.2.65.2.1.8.6)
hh3cCBQoSRedirectAlarmNextHop (1.3.6.1.4.1.25506.2.65.2.1.8.7)
hh3cCBQoSClassMatchRunInfoTable
hh3cCBQoSAccountingRunInfoTable
hh3cCBQoSPolicyAccRunInfoTable
hh3cCBQoSRedirectInvalidAlarmRecover
HH3C-CBQOS2-MIB
About this MIB
Use this MIB to configure class-based QoS (CBQoS).
CBQoS applies different service quality levels to different classes of packets, enabling multiple service support on the network.
MIB file name
hh3c-cbqos2.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cQos2(65)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSClassifierIndexNext (1.3.6.1.4.1.25506.2.65.2.1.1.1) |
read-only |
Integer32 |
Standard MIB values. |
Index of the next available traffic class. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSBehaviorIndexNext (1.3.6.1.4.1.25506.2.65.2.1.2.1) |
read-only |
Integer32 |
Index of the next available traffic behavior. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSPolicyIndexNext (1.3.6.1.4.1.25506.2.65.2.1.3.1) |
read-only |
Integer32 |
Index of the next available QoS policy. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSApplyingStatus (1.3.6.1.4.1.25506.2.65.2.1.6.1) |
read-only |
INTEGER |
idle(1) busy(2) |
QoS policy application status. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSChassis (1.3.6.1.4.1.25506.2.65.2.1.8.1) |
accessible-for-notify |
Integer32 |
0..65534 |
Chassis number. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSSlot (1.3.6.1.4.1.25506.2.65.2.1.8.2) |
Integer32 |
0..65534 |
Slot number. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSCPU (1.3.6.1.4.1.25506.2.65.2.1.8.3) |
Integer32 |
0..65534 |
CPU number. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSDirection (1.3.6.1.4.1.25506.2.65.2.1.8.4) |
DirectionType |
Standard MIB values |
Direction. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSRedirectAlarmBehaviorName (1.3.6.1.4.1.25506.2.65.2.1.8.5) |
OCTET STRING |
SIZE (1..31) |
Traffic behavior name. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSRedirectAlarmProtoFamily (1.3.6.1.4.1.25506.2.65.2.1.8.6) |
InetAddressType |
Protocol type. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSRedirectAlarmNextHop (1.3.6.1.4.1.25506.2.65.2.1.8.7) |
InetAddress |
Next-hop address. |
Tabular objects
About this table
This table obtains matching statistics about a traffic class.
Support for operations
Create:Not supported
Edit/Modify:Not supported
Delete:Not supported
Read:Supported
Columns
The table indexes are hh3cCBQoSApplyObjectIndex and hh3cCBQoSPolicyClassIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSClassBehaviorStatus (1.3.6.1.4.1.25506.2.65.2.1.5.6.2.1.8) |
read-only |
INTEGER |
success(1) failure(2) partialSuccess(3) |
CB association application status. |
As per the MIB. |
hh3cCBQoSCarRunInfoTable
About this table
This table obtains CAR statistics.
Read:Supported
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSCarGreenPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.3.1.1) |
read-only |
Counter64 |
Number of packets matching the CAR configuration |
As per the MIB. |
hh3cCBQoSCarGreenBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.3.1.2) |
read-only |
Counter64 |
Number of bytes matching the CAR configuration |
As per the MIB. |
hh3cCBQoSCarRedPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.3.1.3) |
read-only |
Counter64 |
Number of red packets. |
As per the MIB. |
hh3cCBQoSCarRedBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.3.1.4) |
read-only |
Counter64 |
Number of red bytes. |
As per the MIB. |
hh3cCBQoSCarYellowPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.3.1.5) |
read-only |
Counter64 |
Number of yellow packets. |
As per the MIB. |
hh3cCBQoSCarYellowBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.3.1.6) |
read-only |
Counter64 |
Number of yellow bytes. |
As per the MIB. |
hh3cCBQoSRemarkRunInfoTable
About this table
This table obtains marking statistics.
Read:Supported
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSRemarkedPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.5.1.1) |
read-only |
Counter64 |
Number of packets marked. |
As per the MIB. |
hh3cCBQoSQueueRunInfoTable
About this table
.This table obtains queue-related traffic statistics.
Read:Supported
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSQueueMatchedPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.6.1.1) |
read-only |
Counter64 |
Number of packets matching a queue. |
As per the MIB. |
hh3cCBQoSQueueMatchedBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.6.1.2) |
read-only |
Counter64 |
Number of bytes matching the queue. |
As per the MIB. |
hh3cCBQoSQueueEnqueuedPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.6.1.3) |
read-only |
Counter64 |
Number of packets enqueued. |
As per the MIB. |
hh3cCBQoSQueueEnqueuedBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.6.1.4) |
read-only |
Counter64 |
Number of bytes enqueued. |
As per the MIB. |
hh3cCBQoSQueueDiscardedPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.6.1.5) |
read-only |
Counter64 |
Number of packets dropped by the queue. |
As per the MIB. |
hh3cCBQoSQueueDiscardedBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.6.1.6) |
read-only |
Counter64 |
Number of bytes dropped by the queue. |
As per the MIB. |
About this table
This table obtains traffic statistics.
Read:Supported
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSAccountingPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.8.1.1) |
read-only |
Counter64 |
Number of packets. |
As per the MIB. |
hh3cCBQoSAccountingBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.8.1.2) |
read-only |
Counter64 |
Number of bytes. |
As per the MIB. |
About this table
Read:Supported
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSPolicyAccPackets |
read-only |
Counter64 |
As per the MIB. |
hh3cCBQoSPolicyAccBytes |
read-only |
Counter64 |
Number of bytes. |
As per the MIB. |
Notifications
hh3cCBQoSIfPolicyChanged
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.65.2.1.7.0.1 |
The application status of a QoS policy on an interface changed. |
Informational |
Warning |
N/A (N/A) |
OFF |
Notification triggers
The notification is generated when the application status of a QoS policy on an interface changes.
System impact
The QoS policy applied take effect on the interface.
Status control
ON
CLI: Use the snmp-agent trap enable qos command.
OFF
CLI: Use the undo snmp-agent trap enable qos command.
Object
OID (object name) |
Index |
Type |
Value range |
hh3cCBQoSIfApplyPolicyIfIndex (1.3.6.1.4.1.25506.2.65.2.1.4.1.1.1) |
Interface index |
N/A |
Integer32 |
hh3cCBQoSIfApplyPolicyDirection (1.3.6.1.4.1.25506.2.65.2.1.4.1.1.2) |
Application direction |
N/A |
DirectionType |
Recommended action
No action is required.
hh3cCBQoSVlanPolicyChanged
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.2.1.7.0.2 |
Informational |
Warning |
N/A (N/A) |
OFF |
The notification is generated when the application status of a QoS policy on a VLAN interface changes.
System impact
The QoS policy applied take effect on the VLAN interface.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
hh3cCBQoSVlanApplyPolicyVlanid (1.3.6.1.4.1.25506.2.65.2.1.4.3.1.1) |
VLAN ID |
N/A |
Integer32 |
hh3cCBQoSVlanApplyPolicyDirection (1.3.6.1.4.1.25506.2.65.2.1.4.3.1.2) |
N/A |
DirectionType |
Recommended action
hh3cCBQoSGlobalAclNotSupport
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.2.1.7.0.3 |
The global ACL is not supported. |
Informational |
Warning |
OFF |
The notification is generated when you apply a QoS policy globally but a card does not support the ACL contained in the QoS policy.
System impact
The applied QoS policy does not take effect on that card.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Chassis number |
N/A |
Integer32 |
0 to 65534 |
Slot number |
N/A |
Integer32 |
0 to 65534 |
CPU number |
N/A |
Integer32 |
0 to 65534 |
N/A |
DirectionTyp |
As per the MIB. |
Recommended action
hh3cCBQoSGlobalQPPBNotSupport
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.2.1.7.0.4 |
QPPB is not supported. |
Informational |
Warning |
OFF |
The notification is generated when you apply a QoS policy to an interface for QPPB but the card does not support QPPB.
System impact
The applied QoS policy does not take effect.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Chassis number |
N/A |
Integer32 |
0 to 65534 |
Slot number |
N/A |
Integer32 |
0 to 65534 |
CPU number |
N/A |
Integer32 |
0 to 65534 |
N/A |
DirectionTyp |
As per the MIB. |
Recommended action
Apply a QoS policy on a card that supports QPPB.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.2.1.7.0.5 |
The redirect-to-nexthop function did not take effect. |
Error |
Major |
OFF |
The notification is generated when the next hop for redirection is unreachable.
System impact
The redirection action does not take effect.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.65.2.1.8.5 (hh3cCBQoSRedirectAlarmBehaviorName) |
Traffic behavior name |
N/A |
OCTET STRING |
SIZE (1 to 31) |
1.3.6.1.4.1.25506.2.65.2.1.8.6 (hh3cCBQoSRedirectAlarmProtoFamily) |
Protocol family of the next-hop address |
N/A |
InetAddressType |
As per the MIB. |
1.3.6.1.4.1.25506.2.65.2.1.8.7 (hh3cCBQoSRedirectAlarmNextHop) |
Next-hop address |
N/A |
InetAddress |
As per the MIB. |
Recommended action
Configure a routing protocol to make sure the next hop is learned to the routing table.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.2.1.7.0.6 |
The redirect-to-nexthop function recovered. |
Recovery |
Major |
OFF |
The notification is generated when the redirect-to-nexthop function recovers.
System impact
None.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
OCTET STRING |
SIZE (1 to 31) |
N/A |
InetAddressType |
As per the MIB. |
Next-hop address |
N/A |
InetAddress |
As per the MIB. |
Recommended action
hh3cCBQoSRdtNHLackResAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.2.1.7.0.7 |
The resources for redirection next hop are insufficient. |
Error |
Major |
hh3cCBQoSRdtNHLackResRecover (hh3cCBQoSRdtNHLackResRecover) |
OFF |
The notification is generated when the resources for redirection next hop are insufficient.
System impact
No negative impact on the system.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
OCTET STRING |
SIZE (1..31) |
1.3.6.1.4.1.25506.2.65.2.1.8.2 (hh3cCBQoSSlot) |
Slot number |
N/A |
Integer32 |
0..65534 |
N/A |
InetAddressType |
Next-hop address |
N/A |
InetAddress |
1.3.6.1.4.1.25506.2.65.2.1.8.4 hh3cCBQoSDirection) (1.3.6.1.4.1.25506.2.65.2.1.8.4 hh3cCBQoSDirection)) |
N/A |
DirectionType |
1.3.6.1.4.1.25506.2.65.2.1.8.8 (hh3cCBQoSApplyObject) |
Application object |
N/A |
OCTET STRING |
SIZE (1..127) |
Recommended action
To resolve the issue:
1.Reduce deployed services.
2.If the issue persists, collect alarm information, log messages, and configuration data, and then contact Technical Support for help.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.2.1.7.0.8 |
The resources for redirection next hop become sufficient. |
Recovery |
Major |
N/A (N/A) |
OFF |
The notification is generated when the resources for redirection next hop become sufficient.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
OCTET STRING |
SIZE (1..31) |
Slot number |
N/A |
Integer32 |
0..65534 |
N/A |
InetAddressType |
Next-hop address |
N/A |
InetAddress |
N/A |
DirectionType |
N/A |
OCTET STRING |
SIZE (1..127) |
Recommended action
